  4. Probleme beim admin adapter update
    6.3k
12 Beiträge 4 Kommentatoren 2.9k Aufrufe 3 Beobachtet
  • P peter_pan
    Seit einiger Zeit versuche ich den admin Adapter zu Updaten, aber das schlägt immer wieder fehl. Ich habe schon viel probiert, aber nichts hat geholfen. Eventuell kann mir ja jemand den richtigen Hinweis geben.
    Would you like to upgrade admin from @4.2.2 to @5.1.25 now? [(y)es, (n)o]: y
    Update admin from @4.2.2 to @5.1.25
    host.Server Adapter "system.adapter.admin.0" is stopped.
    NPM version: 7.20.3
    npm install iobroker.admin@5.1.25 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! invalid options argument
    npm ERR!     /home/iobroker/.npm/_logs/2021-10-31T09_51_16_456Z-debug.log
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Adapter "admin" updated
    host.Server Adapter "system.adapter.admin.0" is started
    Adapter "airconwithme"   is not installed.
    Adapter "airzone"        is not installed.
    Adapter "alarm"          is not installed.
    Adapter "alexa2"         is up to date.
    Adapter "alias-manager"  is not installed.
    Adapter "alpha2"         is not installed.
    Adapter "amazon-dash"    is not installed.
    Adapter "anelhut"        is not installed.
    Adapter "artnet"         is not installed.
    Adapter "asterisk"       is not installed.
    Adapter "asuswrt"        is not installed.
    Adapter "awattar"        is not installed.
    Adapter "b-control-em"   is not installed.
    Der Log zum Install:
    0 verbose cli [
    0 verbose cli   '/usr/local/bin/node',
    0 verbose cli   '/usr/local/bin/npm',
    0 verbose cli   'install',
    0 verbose cli   'iobroker.admin@5.1.25',
    0 verbose cli   '--loglevel',
    0 verbose cli   'error',
    0 verbose cli   '--prefix',
    0 verbose cli   '/opt/iobroker'
    0 verbose cli ]
    1 info using npm@7.20.3
    2 info using node@v16.6.2
    3 timing npm:load:whichnode Completed in 1ms
    4 timing config:load:defaults Completed in 8ms
    5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 17ms
    6 timing config:load:builtin Completed in 17ms
    7 timing config:load:cli Completed in 16ms
    8 timing config:load:env Completed in 2ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 7ms
    10 timing config:load:project Completed in 9ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 1ms
    13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 1ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:validate Completed in 1ms
    16 timing config:load:credentials Completed in 5ms
    17 timing config:load:setEnvs Completed in 4ms
    18 timing config:load Completed in 66ms
    19 timing npm:load:configload Completed in 66ms
    20 timing npm:load:setTitle Completed in 0ms
    21 timing npm:load:setupLog Completed in 16ms
    22 timing npm:load:cleanupLog Completed in 29ms
    23 timing npm:load:configScope Completed in 0ms
    24 timing npm:load:projectScope Completed in 2ms
    25 timing npm:load Completed in 116ms
    26 timing config:load:flatten Completed in 27ms
    27 timing arborist:ctor Completed in 5ms
    28 timing idealTree:init Completed in 28ms
    29 timing idealTree:userRequests Completed in 11ms
    30 silly idealTree buildDeps
    31 silly fetch manifest iobroker.admin@5.1.25
    32 verbose stack TypeError: invalid options argument
    32 verbose stack     at optsArg (/usr/local/lib/node_modules/npm/node_modules/mkdirp/lib/opts-arg.js:13:11)
    32 verbose stack     at mkdirp (/usr/local/lib/node_modules/npm/node_modules/mkdirp/index.js:11:10)
    32 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    32 verbose stack     at ret (eval at makeNodePromisifiedEval (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promisify.js:184:12), <anonymous>:13:39)
    32 verbose stack     at Object.mkdirfix (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/lib/util/fix-owner.js:36:10)
    32 verbose stack     at makeTmp (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/lib/content/write.js:121:19)
    32 verbose stack     at write (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/lib/content/write.js:35:19)
    32 verbose stack     at putData (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/put.js:11:10)
    32 verbose stack     at Object.x.put (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/locales/en.js:28:37)
    32 verbose stack     at WriteStream._flush (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/cache.js:156:21)
    32 verbose stack     at WriteStream._write (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/index.js:36:35)
    32 verbose stack     at doWrite (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream/lib/_stream_writable.js:428:64)
    32 verbose stack     at writeOrBuffer (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream/lib/_stream_writable.js:417:5)
    32 verbose stack     at WriteStream.Writable.write (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream/lib/_stream_writable.js:3>
    32 verbose stack     at WriteStream.end (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/index.js:45:41)
    32 verbose stack     at WriteStream.end (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/index.js:42:47)
    33 verbose cwd /opt/iobroker
    34 verbose Linux 5.10.0-9-amd64
    35 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin@5.1.25" "--loglevel" "error" "--prefix" "/opt/iobroker"
    36 verbose node v16.6.2
    37 verbose npm  v7.20.3
    38 error invalid options argument
    39 verbose exit 1
    lessthanmore
    @peter_pan npm und node sind zu hoch.
    npm 6.x und node 14.x.
    Am besten vorher downgraden.
    P 1 Antwort Letzte Antwort
    • L lessthanmore
      peter_pan
      @lessthanmore
      Hab ich Probiert, hat leider nichts gebracht. Gibt es noch weitere Hinweise?
      NPM version: 6.14.15
      npm ERR! Cannot read property 'resolve' of undefined
      npm ERR!     /home/iobroker/.npm/_logs/2021-10-31T10_18_38_439Z-debug.log
      Das Log
      0 info it worked if it ends with ok
      1 verbose cli [
      1 verbose cli   '/usr/local/bin/node',
      1 verbose cli   '/usr/local/bin/npm',
      1 verbose cli   'install',
      1 verbose cli   'iobroker.admin@5.1.25',
      1 verbose cli   '--loglevel',
      1 verbose cli   'error',
      1 verbose cli   '--prefix',
      1 verbose cli   '/opt/iobroker'
      1 verbose cli ]
      2 info using npm@6.14.15
      3 info using node@v14.18.1
      4 verbose npm-session 692ba3ff9c99812d
      5 silly install loadCurrentTree
      6 silly install readLocalPackageData
      7 silly fetchPackageMetaData error for iobroker.admin@5.1.25 Cannot read property 'resolve' of undefined
      8 timing stage:rollbackFailedOptional Completed in 30ms
      9 timing stage:runTopLevelLifecycles Completed in 14664ms
      10 verbose stack TypeError: Cannot read property 'resolve' of undefined
      10 verbose stack     at regFetch (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/index.js:88:23)
      10 verbose stack     at fetchPackument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/packument.js:42:10)
      10 verbose stack     at packument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/packument.js:20:10)
      10 verbose stack     at getManifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:22:10)
      10 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:13:10)
      10 verbose stack     at Object.manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/index.js:17:12)
      10 verbose stack     at Object.Fetcher#manifest [as manifest] (/usr/local/lib/node_modules/npm/node_modules/genfun/lib/genfun.js:15:38)
      10 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetch.js:23:18)
      10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/pacote/manifest.js:24:12
      10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:29:24
      10 verbose stack     at Promise._execute (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/debuggability.js:313:9)
      10 verbose stack     at Promise._resolveFromExecutor (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:488:18)
      10 verbose stack     at new Promise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:79:10)
      10 verbose stack     at _inflight (/usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:28:25)
      10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:22:14
      10 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
      11 verbose cwd /opt/iobroker
      12 verbose Linux 5.10.0-9-amd64
      13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin@5.1.25" "--loglevel" "error" "--prefix" "/opt/iobroker"
      14 verbose node v14.18.1
      15 verbose npm  v6.14.15
      16 error Cannot read property 'resolve' of undefined
      17 verbose exit [ 1, true ]
      • P peter_pan
        @lessthanmore
        Das Log
        1 verbose cli [
        1 verbose cli ]
        @peter_pan sagte in Probleme beim admin adapter update:
        Hab ich Probiert,
        wie?
        was sagt: which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
        • P peter_pan
          @lessthanmore
          Das Log
          1 verbose cli [
          1 verbose cli ]
          Node (höchstwahrscheinlich) falsch installiert.
          Schau in meiner Signatur wie es geht.
            peter_pan
            Das hat geholfen.
            Node hab ich komplett runter geworfen und neu installiert. Wohl durch zu viel rum probieren, waren auch 2 verschiedene Node Versionen in unterschiedlichen Ordnern installiert.
            Jetzt hat das Update funktioniert.
            • P peter_pan
              Das hat geholfen.
              @peter_pan
              Was sagt denn nun
                @peter_pan
                Was sagt denn nun
                peter_pan
                Das ist das Ergebnis
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.18.1
                v14.18.1
                6.14.15
                nodejs:
                  Installiert:           14.18.1-deb-1nodesource1
                  Installationskandidat: 14.18.1-deb-1nodesource1
                  Versionstabelle:
                 *** 14.18.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://ftp.rrzn.uni-hannover.de/debian/debian stable/main amd64 Packages
                        500 http://ftp.de.debian.org/debian stable/main amd64 Packages
                     10.24.0~dfsg-1~deb10u1 500
                        500 http://security.debian.org stable/updates/main amd64 Packages
                        500 http://ftp.at.debian.org/debian buster/main amd64 Packages
                -1
                • P peter_pan
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.18.1
                  v14.18.1
                  6.14.15
                  nodejs:
                    Versionstabelle:
                  @peter_pan
                  Es sollten die Releases nicht gemischt werden.
                  bullseye passt nicht zum buster, was du da wohl eigentlich fährst.
                  lsb_release -a
                  und dann die Repositories angleichen.
                    @peter_pan
                    lsb_release -a
                    peter_pan
                    @thomas-braun sagte in Probleme beim admin adapter update:
                    lsb_release -a
                    Ich habe das aktuelle Stable Bullseye.
                    lsb_release -a
                    No LSB modules are available.
                    Distributor ID:	Debian
                    Description:	Debian GNU/Linux 11 (bullseye)
                    Release:	11
                    Codename:	bullseye
                    Der unterschied kommt, da ich teilweise mit Namen, teilweise einfach nur stable in der Liste stehen habe. Muss ich noch ändern, aber das System ist aktuell.
                    • P peter_pan
                      lsb_release -a
                      lsb_release -a
                      Release:	11
                      Codename:	bullseye
                      @peter_pan wieso sehe ich keinen Prompt und keine Befehlszeile?
                      • P peter_pan
                        lsb_release -a
                        lsb_release -a
                        Release:	11
                        Codename:	bullseye
                        @peter_pan
                        Also in einer der .list-Dateien aus /etc/apt/sources.list muss noch was von buster drin stehen.
