<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Probleme beim admin adapter update]]></title><description><![CDATA[<p dir="auto">Seit einiger Zeit versuche ich den admin Adapter zu Updaten, aber das schlägt immer wieder fehl. Ich habe schon viel probiert, aber nichts hat geholfen. Eventuell kann mir ja jemand den richtigen Hinweis geben.</p>
<pre><code>Would you like to upgrade admin from @4.2.2 to @5.1.25 now? [(y)es, (n)o]: y
Update admin from @4.2.2 to @5.1.25
host.Server Adapter "system.adapter.admin.0" is stopped.
NPM version: 7.20.3
npm install iobroker.admin@5.1.25 --loglevel error --prefix "/opt/iobroker" (System call)
npm ERR! invalid options argument
npm ERR!     /home/iobroker/.npm/_logs/2021-10-31T09_51_16_456Z-debug.log
upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
Adapter "admin" updated
host.Server Adapter "system.adapter.admin.0" is started
Adapter "airconwithme"   is not installed.
Adapter "airzone"        is not installed.
Adapter "alarm"          is not installed.
Adapter "alexa2"         is up to date.
Adapter "alias-manager"  is not installed.
Adapter "alpha2"         is not installed.
Adapter "amazon-dash"    is not installed.
Adapter "anelhut"        is not installed.
Adapter "artnet"         is not installed.
Adapter "asterisk"       is not installed.
Adapter "asuswrt"        is not installed.
Adapter "awattar"        is not installed.
Adapter "b-control-em"   is not installed.
</code></pre>
<p dir="auto">Der Log zum Install:</p>
<pre><code>0 verbose cli [
0 verbose cli   '/usr/local/bin/node',
0 verbose cli   '/usr/local/bin/npm',
0 verbose cli   'install',
0 verbose cli   'iobroker.admin@5.1.25',
0 verbose cli   '--loglevel',
0 verbose cli   'error',
0 verbose cli   '--prefix',
0 verbose cli   '/opt/iobroker'
0 verbose cli ]
1 info using npm@7.20.3
2 info using node@v16.6.2
3 timing npm:load:whichnode Completed in 1ms
4 timing config:load:defaults Completed in 8ms
5 timing config:load:file:/usr/local/lib/node_modules/npm/npmrc Completed in 17ms
6 timing config:load:builtin Completed in 17ms
7 timing config:load:cli Completed in 16ms
8 timing config:load:env Completed in 2ms
9 timing config:load:file:/opt/iobroker/.npmrc Completed in 7ms
10 timing config:load:project Completed in 9ms
11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
12 timing config:load:user Completed in 1ms
13 timing config:load:file:/opt/iobroker/etc/npmrc Completed in 1ms
14 timing config:load:global Completed in 1ms
15 timing config:load:validate Completed in 1ms
16 timing config:load:credentials Completed in 5ms
17 timing config:load:setEnvs Completed in 4ms
18 timing config:load Completed in 66ms
19 timing npm:load:configload Completed in 66ms
20 timing npm:load:setTitle Completed in 0ms
21 timing npm:load:setupLog Completed in 16ms
22 timing npm:load:cleanupLog Completed in 29ms
23 timing npm:load:configScope Completed in 0ms
24 timing npm:load:projectScope Completed in 2ms
25 timing npm:load Completed in 116ms
26 timing config:load:flatten Completed in 27ms
27 timing arborist:ctor Completed in 5ms
28 timing idealTree:init Completed in 28ms
29 timing idealTree:userRequests Completed in 11ms
30 silly idealTree buildDeps
31 silly fetch manifest iobroker.admin@5.1.25
32 verbose stack TypeError: invalid options argument
32 verbose stack     at optsArg (/usr/local/lib/node_modules/npm/node_modules/mkdirp/lib/opts-arg.js:13:11)
32 verbose stack     at mkdirp (/usr/local/lib/node_modules/npm/node_modules/mkdirp/index.js:11:10)
32 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
32 verbose stack     at ret (eval at makeNodePromisifiedEval (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promisify.js:184:12), &lt;anonymous&gt;:13:39)
32 verbose stack     at Object.mkdirfix (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/lib/util/fix-owner.js:36:10)
32 verbose stack     at makeTmp (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/lib/content/write.js:121:19)
32 verbose stack     at write (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/lib/content/write.js:35:19)
32 verbose stack     at putData (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/put.js:11:10)
32 verbose stack     at Object.x.put (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/cacache/locales/en.js:28:37)
32 verbose stack     at WriteStream._flush (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/node_modules/make-fetch-happen/cache.js:156:21)
32 verbose stack     at WriteStream._write (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/index.js:36:35)
32 verbose stack     at doWrite (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream/lib/_stream_writable.js:428:64)
32 verbose stack     at writeOrBuffer (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream/lib/_stream_writable.js:417:5)
32 verbose stack     at WriteStream.Writable.write (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/node_modules/readable-stream/lib/_stream_writable.js:3&gt;
32 verbose stack     at WriteStream.end (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/index.js:45:41)
32 verbose stack     at WriteStream.end (/usr/local/lib/node_modules/npm/node_modules/flush-write-stream/index.js:42:47)
33 verbose cwd /opt/iobroker
34 verbose Linux 5.10.0-9-amd64
35 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin@5.1.25" "--loglevel" "error" "--prefix" "/opt/iobroker"
36 verbose node v16.6.2
37 verbose npm  v7.20.3
38 error invalid options argument
39 verbose exit 1
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/48948/probleme-beim-admin-adapter-update</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 14:52:42 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/48948.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Oct 2021 09:57:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 17:17:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a></p>
<blockquote>
<p dir="auto">500 <a href="http://ftp.at.debian.org/debian" rel="nofollow ugc">http://ftp.at.debian.org/debian</a> buster/main amd64 Packages</p>
</blockquote>
<p dir="auto">Also in einer der <em>.list-Dateien aus /etc/apt/sources.list</em> muss noch was von buster drin stehen.</p>
]]></description><link>https://forum.iobroker.net/post/696343</link><guid isPermaLink="true">https://forum.iobroker.net/post/696343</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 31 Oct 2021 17:17:33 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 17:15:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a> wieso sehe ich keinen Prompt und keine Befehlszeile?</p>
]]></description><link>https://forum.iobroker.net/post/696342</link><guid isPermaLink="true">https://forum.iobroker.net/post/696342</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 31 Oct 2021 17:15:48 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 17:13:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/696159">Probleme beim admin adapter update</a>:</p>
<blockquote>
<p dir="auto">lsb_release -a</p>
</blockquote>
<p dir="auto">Ich habe das aktuelle Stable Bullseye.</p>
<pre><code>lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 11 (bullseye)
Release:	11
Codename:	bullseye
</code></pre>
<p dir="auto">Der unterschied kommt, da ich teilweise mit Namen, teilweise einfach nur stable in der Liste stehen habe. Muss ich noch ändern, aber das System ist aktuell.</p>
]]></description><link>https://forum.iobroker.net/post/696338</link><guid isPermaLink="true">https://forum.iobroker.net/post/696338</guid><dc:creator><![CDATA[peter_pan]]></dc:creator><pubDate>Sun, 31 Oct 2021 17:13:27 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 13:27:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a><br />
Es sollten die Releases nicht gemischt werden.<br />
bullseye passt nicht zum buster, was du da wohl eigentlich fährst.</p>
</code></pre>
<p dir="auto">und dann die Repositories angleichen.</p>
]]></description><link>https://forum.iobroker.net/post/696159</link><guid isPermaLink="true">https://forum.iobroker.net/post/696159</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 31 Oct 2021 13:27:09 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 13:00:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Das ist das Ergebnis</p>
<pre><code>which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; apt policy nodejs
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v14.18.1
v14.18.1
6.14.15
nodejs:
  Installiert:           14.18.1-deb-1nodesource1
  Installationskandidat: 14.18.1-deb-1nodesource1
  Versionstabelle:
 *** 14.18.1-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_14.x bullseye/main amd64 Packages
        100 /var/lib/dpkg/status
     12.22.5~dfsg-2~11u1 500
        500 http://ftp.rrzn.uni-hannover.de/debian/debian stable/main amd64 Packages
        500 http://ftp.de.debian.org/debian stable/main amd64 Packages
     10.24.0~dfsg-1~deb10u1 500
        500 http://security.debian.org stable/updates/main amd64 Packages
        500 http://ftp.at.debian.org/debian buster/main amd64 Packages
</code></pre>
]]></description><link>https://forum.iobroker.net/post/696148</link><guid isPermaLink="true">https://forum.iobroker.net/post/696148</guid><dc:creator><![CDATA[peter_pan]]></dc:creator><pubDate>Sun, 31 Oct 2021 13:00:44 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 12:46:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a><br />
Was sagt denn nun</p>
</code></pre>
]]></description><link>https://forum.iobroker.net/post/696145</link><guid isPermaLink="true">https://forum.iobroker.net/post/696145</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 31 Oct 2021 12:46:16 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 12:36:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Danke</p>
<p dir="auto">Das hat geholfen.<br />
Node hab ich komplett runter geworfen und neu installiert. Wohl durch zu viel rum probieren, waren auch 2 verschiedene Node Versionen in unterschiedlichen Ordnern installiert.</p>
<p dir="auto">Jetzt hat das Update funktioniert.</p>
]]></description><link>https://forum.iobroker.net/post/696141</link><guid isPermaLink="true">https://forum.iobroker.net/post/696141</guid><dc:creator><![CDATA[peter_pan]]></dc:creator><pubDate>Sun, 31 Oct 2021 12:36:32 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 10:56:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a> sagte in <a href="/post/696058">Probleme beim admin adapter update</a>:</p>
<blockquote>
<p dir="auto">'/usr/local/bin/node</p>
</blockquote>
<p dir="auto">Node (höchstwahrscheinlich) falsch installiert.<br />
Schau in meiner Signatur wie es geht.</p>
]]></description><link>https://forum.iobroker.net/post/696066</link><guid isPermaLink="true">https://forum.iobroker.net/post/696066</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 31 Oct 2021 10:56:26 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 10:22:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a> sagte in <a href="/post/696058">Probleme beim admin adapter update</a>:</p>
<blockquote>
<p dir="auto">Hab ich Probiert,</p>
</blockquote>
<p dir="auto">wie?</p>
<blockquote>
<p dir="auto">hat leider nichts gebracht. Gibt es noch weitere Hinweise?</p>
</blockquote>
<p dir="auto">was sagt: <code>which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; apt policy nodejs</code></p>
]]></description><link>https://forum.iobroker.net/post/696059</link><guid isPermaLink="true">https://forum.iobroker.net/post/696059</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sun, 31 Oct 2021 10:22:30 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 10:21:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lessthanmore" aria-label="Profile: lessthanmore">@<bdi>lessthanmore</bdi></a></p>
<p dir="auto">Hab ich Probiert, hat leider nichts gebracht. Gibt es noch weitere Hinweise?</p>
NPM version: 6.14.15
npm ERR! Cannot read property 'resolve' of undefined
npm ERR!     /home/iobroker/.npm/_logs/2021-10-31T10_18_38_439Z-debug.log
</code></pre>
<p dir="auto">Das Log</p>
<pre><code>0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli   '/usr/local/bin/node',
1 verbose cli   '/usr/local/bin/npm',
1 verbose cli   'install',
1 verbose cli   'iobroker.admin@5.1.25',
1 verbose cli   '--loglevel',
1 verbose cli   'error',
1 verbose cli   '--prefix',
1 verbose cli   '/opt/iobroker'
1 verbose cli ]
2 info using npm@6.14.15
3 info using node@v14.18.1
4 verbose npm-session 692ba3ff9c99812d
5 silly install loadCurrentTree
6 silly install readLocalPackageData
7 silly fetchPackageMetaData error for iobroker.admin@5.1.25 Cannot read property 'resolve' of undefined
8 timing stage:rollbackFailedOptional Completed in 30ms
9 timing stage:runTopLevelLifecycles Completed in 14664ms
10 verbose stack TypeError: Cannot read property 'resolve' of undefined
10 verbose stack     at regFetch (/usr/local/lib/node_modules/npm/node_modules/npm-registry-fetch/index.js:88:23)
10 verbose stack     at fetchPackument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/packument.js:42:10)
10 verbose stack     at packument (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/packument.js:20:10)
10 verbose stack     at getManifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:22:10)
10 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:13:10)
10 verbose stack     at Object.manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/index.js:17:12)
10 verbose stack     at Object.Fetcher#manifest [as manifest] (/usr/local/lib/node_modules/npm/node_modules/genfun/lib/genfun.js:15:38)
10 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/pacote/lib/fetch.js:23:18)
10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/pacote/manifest.js:24:12
10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:29:24
10 verbose stack     at Promise._execute (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/debuggability.js:313:9)
10 verbose stack     at Promise._resolveFromExecutor (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:488:18)
10 verbose stack     at new Promise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:79:10)
10 verbose stack     at _inflight (/usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:28:25)
10 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:22:14
10 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
11 verbose cwd /opt/iobroker
12 verbose Linux 5.10.0-9-amd64
13 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.admin@5.1.25" "--loglevel" "error" "--prefix" "/opt/iobroker"
14 verbose node v14.18.1
15 verbose npm  v6.14.15
16 error Cannot read property 'resolve' of undefined
17 verbose exit [ 1, true ]
</code></pre>
]]></description><link>https://forum.iobroker.net/post/696058</link><guid isPermaLink="true">https://forum.iobroker.net/post/696058</guid><dc:creator><![CDATA[peter_pan]]></dc:creator><pubDate>Sun, 31 Oct 2021 10:21:33 GMT</pubDate></item><item><title><![CDATA[Reply to Probleme beim admin adapter update on Sun, 31 Oct 2021 10:03:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter_pan" aria-label="Profile: peter_pan">@<bdi>peter_pan</bdi></a> npm und node sind zu hoch.<br />
npm 6.x und node 14.x.<br />
Am besten vorher downgraden.</p>
]]></description><link>https://forum.iobroker.net/post/696037</link><guid isPermaLink="true">https://forum.iobroker.net/post/696037</guid><dc:creator><![CDATA[lessthanmore]]></dc:creator><pubDate>Sun, 31 Oct 2021 10:03:42 GMT</pubDate></item></channel></rss>
