  4. [SOLVED] Frust: ioBroker-slave, conbee2, Tradfri lampe
    6.3k
28 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • D diwoma
    @thomas-braun said in Frust: ioBroker-slave, conbee2, Tradfri lampe:
    Danach sollte der zigbee-Adapter auch laufen.
    Das war anzunehmen.
    Aber wir sind wieder bei dem Anfangsproblem. Das Pairing funktioniert nicht.
    @diwoma
    Im LogFile steht dazu?
      @diwoma
      diwoma
      @thomas-braun Wenn Du diesen Bereich meinst?
      zigbee.0
      	2021-10-17 17:28:01.318	debug	LQI succeeded for 'Coordinator'
      zigbee.0
      	2021-10-17 17:28:01.301	debug	sendTo "getCoordinatorInfo" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:28:01.300	debug	getCoorinatorInfo result: {"installSource":"iobroker.zigbee@1.6.3","channel":"11","port":"/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2455071-if00","type":"ConBee2/RaspBee2","revision":"0x26580700","version":"0-0.38.88.0."}
      zigbee.0
      	2021-10-17 17:28:01.296	debug	sendTo "getGroups" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:28:01.295	debug	getGroups result: {}
      zigbee.0
      	2021-10-17 17:28:01.279	debug	sendTo "getLibData" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:24:06.895	debug	sendTo "letsPairing" to system.adapter.admin.0 from system.adapter.zigbee.0: Start pairing!
      zigbee.0
      	2021-10-17 17:24:06.894	info	Zigbee: allowing new devices to join.
      zigbee.0
      	2021-10-17 17:24:02.551	debug	sendTo "listUart" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:24:02.551	debug	List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyAMA0"},{"comName":"/dev/ttyS0"}]
      zigbee.0
      	2021-10-17 17:24:02.511	debug	sendTo "getExclude" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:24:02.504	debug	sendTo "getBinding" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:24:02.503	debug	getBinding result: []
      zigbee.0
      	2021-10-17 17:24:02.502	debug	getExclude result: []
      zigbee.0
      	2021-10-17 17:24:02.434	debug	sendTo "getMap" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:24:02.434	debug	getMap result: {"lqis":[],"routing":[]}
      zigbee.0
      	2021-10-17 17:24:02.433	debug	Get map succeeded []
      zigbee.0
      	2021-10-17 17:24:02.433	debug	Routing table succeeded for 'Coordinator'
      zigbee.0
      	2021-10-17 17:24:02.432	debug	Routing for 'Coordinator': {"table":[]}
      zigbee.0
      	2021-10-17 17:24:02.429	debug	sendTo "getDevices" to system.adapter.admin.0 from system.adapter.zigbee.0
      zigbee.0
      	2021-10-17 17:24:02.428	debug	getDevices result: [{"_id":"0x00212effff07924e","icon":"img/unknown.png","paired":true,"info":{"type":"device","device":{"ID":1,"_type":"Coordinator","_ieeeAddr":"0x00212effff07924e","_networkAddress":0,"_manufacturerID":4405,"_endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[0,10,25],"outputClusters":[1,32,1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff07924e","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff07924e","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"_interviewCompleted":true,"_interviewing":false,"_skipDefaultResponse":false,"_skipTimeResponse":false,"meta":{},"_lastSeen":null},"mapped":null,"endpoint":{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[0,10,25],"outputClusters":[1,32,1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff07924e","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},"endpoints":[{"ID":1,"profileID":260,"deviceID":5,"inputClusters":[0,10,25],"outputClusters":[1,32,1280],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff07924e","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]},{"ID":242,"profileID":41440,"deviceID":100,"inputClusters":[],"outputClusters":[33],"deviceNetworkAddress":0,"deviceIeeeAddress":"0x00212effff07924e","clusters":{},"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":[]}],"name":"0x00212effff07924e"},"common":{},"native":{}}]
      zigbee.0
      -- diwoma
      ioBroker in LX-Container in Proxmox
      Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
      • D diwoma
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        zigbee.0
        @diwoma
        Keine kritischen Meldungen, soweit ich sehe.
        Aber die Firmware von dem Stick würde ich aktualisieren.
          @diwoma
          diwoma
          @diwoma
          Habe ich getan, aber es pairt sich nicht.
          Wenn es Deiner Meinung nach jetzt richtig ist, und im Log auch keine Fehlermeldungen auftauchen, kann man annehmen, dass die Tadfri sich weigert. Also warte ich auf andere Devices von Xiaomi und Tuya. Dann werde ich weitersehen
          -- diwoma
          • D diwoma
            @diwoma
            @diwoma
            Ich hatte bei mir Tradfri laufen an einem raspbee I.
              @diwoma
              diwoma
              @diwoma
              Alle anderen anscheinend auch, wenn man sich die Videos ansieht. Hilft mir nur nichts.
              -- diwoma
              • D diwoma
                @diwoma
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                schrieb am zuletzt editiert von Jey Cee
                @diwoma du hast aber schon geschaut ob die Lampe vom Zigbee Adapter auch unterstützt wird?!
                https://www.zigbee2mqtt.io/information/supported_devices.html#
                Die wurde erst vor 7 Tagen in den Core integriert, da ist die noch eine weile nicht im Adapter verfügbar.
                https://github.com/Koenkk/zigbee2mqtt/issues/9108
                Persönlicher Support
                Spenden -> paypal.me/J3YC33
                • Jey CeeJ Jey Cee
                  diwoma
                  @jey-cee Danke für diese Info. Habe zwar nach der LED-Bezeichnung gesucht, aber alles bekommen nur nicht diesen Thread :(
                  Allerdings habe ich dann sicher auch auch andere Threads über missing Devices falsch interpretiert. Dort schrieb man, dass sie gepairt wurden, dann aber als unbekannt angezeigt wurden. Deshalb habe ich angenommen, das könnte auch bei mir der Fall sein.
                  Zumindest ist diese Frage dann geklärt.
                  Ich hoffe, das ich in dieser Woche noch Tuya-Plugins bekomme, dann kann ich meine Versuche am Wochenende fortführen.
                  -- diwoma
                  • D diwoma
                    Hi Leute,
                    ich verstehe einfach nicht, wieso es in den Videos immer funktioniert und ich immer gegen die Wand laufe :)
                    Vielleicht, weil die Videos schon zu alt sind (meistens 2 Jahre) und sich alles geändert hat oder weil ich verschiedene Dinge vermische und falsch zuordne oder weil in meiner Kette irgendwo was nicht kompatibel ist oder ich einfach zu dämlich bin :(
                    Ausgangslage:
                    Ich starte mit ioBroker und will meine Devices als Zigbee-Devices steuern, weil die IP-Devices immer schlechter auf Tasmota zu flashen sind. Da ich aber meinen Main-ioBroker als LXC im Proxmox habe und die Hardware am äusseren Rand des Hauses platziert ist, ich aber lieber einen zentralen Punkt für das Gateway hätte, habe ich einen RPI 4 als ioBroker-Slave aufgesetzt und dort den Conbee2 angesteckt.
                    Warum Conbee? Den brauchte ich nicht extra flashen (d.H. Hardware für einmal dazukaufen) und er sollte nach den Videos nicht schlecht sein.
                    Auf dem RPI den Stick angesteckt, er wird erkannt und sollte bereit sein.
                    Das Dilemma ist, dass ich noch kein Zigbee-Device hatte, also schnell zu IKEA und dort was aus der TradFri-Abteilung geholt. Allerdings waren weder Taster noch Sensoren vorhanden, nur eine LED-Kerze mir der Bezeichnung LED1949C5.
                    Den RPI als Slave an den Master gebunden, auf dem Slave den Zigbee-Adapter (V 1.6.3) installiert und er ist im Master sichtbar. In den Einstellungen die USB-Schnittstelle eingetragen und als Typ Deconz/Conbee eingestellt, den Timeout auf 300 und dann die entsprechenden Parameter gesetzt. Gespeichert und der Adapter wurde dann irgendwann mal grün (aber erst nach Reboot des Slaves).
                    Voller Freude den Anlernbutton im Adapter gedrückt, die Lampe eingeschaltet und hingehalten und nix passiert. Nachgelesen, wie man ein Factory-Reset macht, durchgeführt und nix passiert (gefühlte 100 mal, realistisch aber wohl 20 mal).
                    Dann eine Information bekommen, bei Conbee könne man nur über Phoscon anlernen, also Phoscon auf dem Slave installiert, Webinterface funktioniert nicht!
                    Nachgelesen warum - das braucht einen User 1000 (alter pi-User, den habe ich gelöscht). Also einen neuen User angelegt (der hat dann 1000 gekommen, den die Gruppe dialout hinzugefügt) und der Service ist gelaufen und die GUI konnte aufgerufen werden.
                    In den Modus "Lampen Anlernen" gebracht und das wieder gefühlte 100 mal die gleiche Prozedur durchgeführt wie vorher - ohne Ergebnis. Nur dass der Zigbee-Adapter nach einem Reboot zickt, weil der Conbee schon in Verwendung ist (durch den schneller startenden deCONZ-Service).
                    Also ist das ziemlich frustrierend für mich und ich kann den Fehler in der Kette nicht identifizieren:
                    Master - Slave - Stick - Lampe - ich.
                    Solange ich noch keine Devices anderer Hersteller habe, kann ich nicht weitermachen, ausser Ihr erkennt auf Anhieb (oder über auf Nachfrage gelieferter Daten), wo es hakt.
                    Sorry für den langen Thread-Start, aber ich wollte den Weg beschreiben den ich gegangen bin, das man weiss auf welchen Stand und in welchem Zustand ich bin.
                    diwoma
                    schrieb am zuletzt editiert von diwoma
                    @diwoma SOLVED:
                    Es hätte wahrscheinlich meinen Frust nicht gegeben, wenn ich auf gewisse Vorschläge im Web früher gehört hätte 🙂
                    Nachdem ich einige Tuya-Plugs bekommen habe, die schon mal eingebunden waren, habe ich mit diesen probiert. Und es hat auch nicht funktionert. Aber die Plugs waren etwas weiter vom Stick entfernt und konnten mechanisch nicht näher an den Stick gebracht werden, also habe ich mich erinnert, dass eine USB-Verlängerung zwischen PI und Stick empfohlen wird.
                    Und mit dieser Verlängerung sind die Plugs ohne Probleme ge'pair't worden.
                    Und auch die Tradfri-Bulb wurde eingebunden, zwar als unbekannt (weil nicht in der Liste), aber sie wurde connected.
                    Bei mir war es wahrscheinlich auch zusätzlich das Problem, daß mein Slave-PI in einem Pulk von 10 anderen PI's gelegen ist.
                    Also bin ich selbst Schuld an meinem Frust.
                    -- diwoma
                    • D diwoma
                      @diwoma SOLVED:
                      @diwoma sagte in [SOLVED] Frust: ioBroker-slave, conbee2, Tradfri lampe:
                      oder der Stick hing am (störungsfreudigen) USB3
