  4. VIS zeigt sich als 22 Mal installiert
    2.4k
    4.3k
26 Beiträge 4 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • reimucR reimuc
    @reimuc
    jetzt auf stable umgestellt
    pi@raspberrypi:~ $ iobroker update -i
    Used repository: stable
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
    Adapter    "alias-manager" : 1.2.3    , installed 1.2.4
    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
    Adapter    "coronavirus-statistics": 0.8.3   , installed 0.8.3
    Adapter    "daswetter"     : 3.0.7    , installed 3.0.8
    Adapter    "deconz"        : 1.3.19   , installed 2.0.5
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "discovery"     : 2.7.0    , installed 2.7.3
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "feiertage"     : 1.0.17   , installed 1.0.23
    Adapter    "flot"          : 1.10.6   , installed 1.10.7
    Adapter    "history"       : 1.9.13   , installed 1.9.13
    Adapter    "hm-rega"       : 3.0.31   , installed 3.0.31
    Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "influxdb"      : 1.9.5    , installed 2.2.0
    Adapter    "info"          : 1.9.8    , installed 1.9.10
    Adapter    "iot"           : 1.8.22   , installed 1.8.24
    Adapter    "javascript"    : 5.2.8    , installed 5.2.13
    Controller "js-controller" : 3.3.18   , installed 3.3.18
    Adapter    "material"      : 1.0.4    , installed 1.0.4
    Adapter    "parser"        : 1.0.7    , installed 1.0.7
    Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
    Adapter    "rickshaw"      : 1.0.0    , installed 1.0.0
    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
    Adapter    "sayit"         : 1.12.3   , installed 1.12.3
    Adapter    "shelly"        : 4.0.7    , installed 4.0.8
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "sonos"         : 2.1.1    , installed 2.1.1
    Adapter    "tado"          : 0.3.7    , installed 0.3.7
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "text2command"  : 2.1.1    , installed 2.1.1
    Adapter    "unifi"         : 0.5.10   , installed 0.5.10
    Adapter    "vis"           : 1.4.4    , installed 1.4.4
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
    Adapter    "vis-icontwo"   : 0.80.0   , installed 0.81.0
    Adapter    "vis-inventwo"  : 3.2.0    , installed 3.2.0
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.2
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"   : 0.1.6    , installed 0.1.6
    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
    Adapter    "web"           : 3.4.7    , installed 3.4.9
    Adapter    "zigbee"        : 1.5.6    , installed 1.6.3
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ iob list instances
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
      system.adapter.coronavirus-statistics.0 : coronavirus-statistics: raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.material.0               : material              : raspberrypi                              - disabled
    + system.adapter.nello.0                  : nello                 : raspberrypi                              - disabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis                   : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis                   : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis                   : raspberrypi                              - disabled
      system.adapter.vis-google-fonts.0       : vis                   : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis                   : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis                   : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis                   : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis                   : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis                   : raspberrypi                              - disabled
      system.adapter.vis-keyboard.0           : vis                   : raspberrypi                              - disabled
      system.adapter.vis-lcars.0              : vis                   : raspberrypi                              - disabled
      system.adapter.vis-map.0                : vis                   : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis                   : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis                   : raspberrypi                              - disabled
      system.adapter.vis-material.0           : vis                   : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis                   : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis                   : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis                   : raspberrypi                              - disabled
      system.adapter.vis-plumb.0              : vis                   : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis                   : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis                   : raspberrypi                              - disabled
      system.adapter.vis-weather.0            : vis                   : raspberrypi                              - disabled
    + instance is alive
    pi@raspberrypi:~ $
    Reboot ist erledigt. Leider hat sich die Situation nicht geändert. Es zeigt immer noch 22 VIS im Adapter. und in den Instanzen fehlt die VIS "Mutter". Vielleicht muss ich ein Downgrade machen?
    Wenn ja, was muss ich dabei beachten?
    GlasfaserG Offline
    GlasfaserG Offline
    @reimuc
    Zeige mal die Ausgaben von :
    cat /opt/iobroker/package.json
    cat /opt/iobroker/package-lock.json
    cat /opt/iobroker/node_modules/iobroker.vis/package.json
    iobroker update -i
    reimucR 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @reimuc
      iobroker update -i
      reimucR Offline
      reimucR Offline
      reimuc
      schrieb am zuletzt editiert von reimuc
      @glasfaser
      Vielen Dank nochmals.
      die Ausgabe hat zuviele Zeichen. Daher als Datei im Anhang.
      putty.log
      Ein Downgrade habe ich nicht gemacht, zumindest nicht bewusst.
      Nur von Beta auf Stable umgestellt.
      update & upgrade gemacht wie des öfteren.
      Das ganze viel mir gestern auf und dann habe ich WEB.0 wieder installiert. Das war irgendwie weg. Dann habe ich experimentiert und einfach alle VIS entfernt und die dann wieder installiert. Das sah dann schön aus. Es zeigte sich die 1 Vis "Mutter" und dann die anderen VIS Widgets: "alle schön" wie es sein soll.
      Leider bemerkte ich aber dass alle Vis Daten / Visualisierungen jetzt futsch waren.
      Also habe ich dann ein Backup eingespielt. Jetzt sind die Visualisierungen wieder da, laufen zwar nicht richtig aber ich kann die bestimmt wieder aktivieren.
      Allerdings ist das Problem mit den VIS Adaptern wieder das gleiche wie vor meinen Änderungen. Daher wende ich mich an Euch weil ich mit meinen eigenen Möglichkeiten am Ende bin.
      • reimucR reimuc
        @glasfaser
        putty.log
        GlasfaserG Offline
        GlasfaserG Offline
        @reimuc
        Mhhh .. ich habe noch nicht alles durch ..... da wäre was
        "npm": {
              "version": "7.24.2",
              "resolved": "https://registry.npmjs.org/npm/-/npm-7.24.2.tgz",
        Zeige mal :
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          @reimuc
          "npm": {
          Zeige mal :
          reimucR Offline
          reimucR Offline
          reimuc
          @glasfaser
          hier kommt es:
          pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v12.22.6
          /usr/bin/node
          v12.22.6
          /usr/bin/npm
          6.14.15
          nodejs:
            Installed: 12.22.6-deb-1nodesource1
            Candidate: 12.22.6-deb-1nodesource1
            Version table:
           *** 12.22.6-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
                  500 http://archive.raspbian.org/raspbian buster/main armhf Packages
          pi@raspberrypi:~ $
          • reimucR reimuc
            @glasfaser
            putty.log
            GlasfaserG Offline
            GlasfaserG Offline
            @reimuc sagte in VIS zeigt sich als 22 Mal installiert:
            ...Es zeigte sich die 1 Vis "Mutter" und dann die anderen VIS Widgets: "alle schön" wie es sein soll.
            Ich verstehe es gerade nicht , hast du jetzt zwischendurch was gemacht !?
            Wie ist denn jetzt der aktuelle stand im Admin ?
            das Wundert mich :
            danach ist alles 22 mal drin !?
              das Wundert mich :
              reimucR Offline
              reimucR Offline
              reimuc
              @glasfaser
              Sorry wenn ich mit meiner Beschreibung Verwirrung gestiftet habe.
              Gestern sah ich die Situation mit den 22 VIS. Und ich sah dass WEB fehlte.
              Dann entfernte ich gestern alle VIS. packte die wieder drauf. Dann sah alles schön aus. Allerdings waren meine Visualisierungen weg.
              Dann installierte ich das Backup.
              Als Resultat waren wieder 22 VIS zu sehen. Das WEB war auch wieder weg. Das habe ich dann heute morgen also installiert.
              Seit wir hier schreiben habe ich nichts gemacht außer den Anweisungen zu folgen und von Beta auf Stable umgestellt. Es macht ja keinen Sinn sich helfen zu lassen und dabei zusätlich selbst herumzudoktern.
              Im Admin / Adapter / Instanzen sieht es so aus (unverändert):
              • GlasfaserG Offline
                GlasfaserG Offline
                In wie weit fehlte WEB, als installierte Instanz nicht mehr sichtbar im Admin oder im Allgemeinen der Port 8082 für den Aufruf von VIS.
                Es ist sehr schwer nachzuvollziehen warum WEB nicht mehr da ist und wie es bei dir dazu gekommen ist .
                @Garfonso hat ein Hinweis geschrieben mit dem js-controller , hast du eventuell vorher die alte Version gehabt und es ist dir nicht aufgefallen !?
                  reimucR Offline
                  reimucR Offline
                  reimuc
                  @glasfaser
                  Die WEB.0 Instanz war einfach nicht mehr da. der Port 8082 ging nicht mehr für den Aufruf von VIS.
                  Warum es nicht mehr da war ist mir nicht bekannt.
                  Jetzt ist es ja nach installation wider da. Was ich aber wider hinbekommen möchte ist das VIS richtig funktioniert.
                  bezgl. js-controller sollte eigentlich auch immer die passende / aktuelle Version installiert sein.
                  Updates mache ich regelmäßig / wöchentlich mit diesem Kommando und schaue auch nach ob iob selbst auch ein update benötigt:
                  sudo apt update && sudo apt upgrade -y && iob update && iob upgrade -y
                  • reimucR reimuc
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Das macht mich auch noch stutzig .
                    Also hast du ein frisches ioBroker aufgesetzt und ein Backup mit Backitup eingespielt oder !?
                      reimucR Offline
                      reimucR Offline
                      reimuc
                      @glasfaser
                      Nein, kein frisches iobroker aufgesetzt sondern einfach nur das Backup eingespielt.
                      Danach war die Situation die gleiche mit den 22 VIS Instanzen.
                      Siehst du eine Möglichkeit wie ich das Problem mit den 22 VIS lösen kann?
                      Eine Möglichkeit wie die VIS "Mutter" wieder in den Instanzen sichtbar wird?
                      • reimucR reimuc
                        @glasfaser
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Per Hammermethode kann man alles , aber es fehlt der Hintergund dazu zu diesem Fehler .
                        @reimuc
                        @glasfaser sagte in VIS zeigt sich als 22 Mal installiert:
                        du schreibst :
                        Dann wäre die Frage wie machst du Backup´s .....
                        ..... Dann holst du immer die gleichen Fehler mit rein , wie du es auch einspielen solltest .
                        Mache ein Backup mit Backitup , setzte ein frisches ioBroker auf und spiele dieses Backup wieder ein.
                        @homoran sagte in VIS zeigt sich als 22 Mal installiert:
                        erstmal alle Informationen sammeln, bevor operative Hektik entsteht!
                        @Homoran @Thomas-Braun
                        Hab noch eine Idee !
                          @reimuc
                          du schreibst :
                          Latürnich!
                          Wenn ich jetzt nichts durcheinanderbringe (bei 100 parallelen Threads durchaus möglich ;-) )
                          Wenn der Wurm in der Grundinstallation war, wovon ich ausgehe (buggy-Version vom Controller, vorübergehend mit npm7 gespielt...), nutzt ein Einspielen eines Backups nur bedingt, da in der Basis der Fehler ist.
                          Ich würde nochmals alles neu aufsetzen und wenn da alles gut aussieht das letzte funktionierende Backup neu einspielen.
                          Beim Pi ist das ja kein Problem, wenn alles auf einer SD-Karte ist. Dann nimmt man für die Versuche einfach eine neue Karte und hat die alte Installation immer noch zur Reserve
                            Latürnich!
                            reimucR Offline
                            reimucR Offline
                            reimuc
                            Ja, das ist eine gute Möglichkeit. Leider kann ich so einen Kartentausch erst machen wenn wieder daheim in D-land. Bin derzeit in Asien und arbeite remote :-)
                            GIbt es eine andere Möglichkeit die VIS Installation remote zu reparieren? Ich bin doch jetzt etwas in Aktion getreten und habe einfach mal das installierte VIS downgegraded.
                            Als Ergebnis war nur die Lizenz futsch (Error log: "No license found for vis."). Sichtbar in den Instanzen ist es leider nicht.
                            Jetzt deinstalliere ich mal die anderen VIS meta Adapter einzeln und werde später berichten was passiert ist
                            • reimucR reimuc
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Ahh .. damit ist meine Frage ja beantwortet , zu :
                              @reimuc
                              du schreibst :
                                @reimuc
                                du schreibst :
                                reimucR Offline
                                reimucR Offline
                                reimuc
                                @glasfaser
                                Ja, ich denke auch dass hier ein Backup einspielen nicht funktioniert.
                                Das hatte ich ja schon gemacht.
                                Ich werde wohl VIS komplett entfernen und alles wieder langsam aufbauen müssen. Das ist schon viel Aufwand. :-(
                                • reimucR reimuc
                                  @glasfaser
                                  reimucR Offline
                                  reimucR Offline
                                  reimuc
                                  @reimuc
                                  mit viel Geduld Problem gelößt.
                                  Nach und nach habe ich alle VIS adapter entfernt. Bis auf die VIS Mutter.
                                  Es viel auf das einige Adapter sich nicht löschen ließen. Der letzte war "Plumb". Den habe ich dann reinstalliert nachdem ich den 2 Mal gelöscht hatte. Schwups war dann der VIS.0 sichtbar und einstellbar.
