  4. CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB
    5.5k
zigbee-stickzigbee2mqtt und zigbee
10 Beiträge 3 Kommentatoren 619 Aufrufe 2 Beobachtet
    Digi-Bit
    ich habe mir einen Zigbee stick geholt und versuch den seit 4 Stunden einzubinden.
    Habe hier viel gelesen und auch woanders mir Infos versucht zu besorgen.
    Ich habe jetzt den Adapter 1.6.4 installiert wo einige Fehlermeldungen verschwunden sind aber so richtig starten will der immer noch nicht.
    zigbee.0
       2021-10-08 09:53:44.386	error	Error herdsman start
    zigbee.0
       2021-10-08 09:53:44.385	error	Failed to start Zigbee
    zigbee.0
       2021-10-08 09:53:44.384	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
       2021-10-08 09:53:44.173	info	Installed Version: ioBroker/ioBroker.zigbee
    zigbee.0
       2021-10-08 09:53:44.135	info	Starting Zigbee npm ...
    zigbee.0
       2021-10-08 09:53:44.133	info	Try to reconnect. 1 attempts left
    zigbee.0
       2021-10-08 09:53:34.131	error	Error herdsman start
    zigbee.0
       2021-10-08 09:53:34.130	error	Failed to start Zigbee
    zigbee.0
       2021-10-08 09:53:34.128	error	Starting zigbee-herdsman problem : "AREQ - ZDO - stateChangeInd after 60000ms"
    zigbee.0
       2021-10-08 09:52:31.473	info	Installed Version: ioBroker/ioBroker.zigbee
    zigbee.0
       2021-10-08 09:52:31.004	info	Starting Zigbee npm ...
    zigbee.0
       2021-10-08 09:52:30.905	info	starting. Version 1.6.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.18
    zigbee.0
       2021-10-08 09:52:30.880	info	Plugin sentry Sentry Plugin disabled for this process because data reporting is disabled on instance
    zigbee.0
       2021-10-08 09:52:25.086	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0
       2021-10-08 09:52:25.085	info	terminating
    zigbee.0
       2021-10-08 09:52:24.847	info	Zigbee: disabling joining new devices.
    zigbee.0
       2021-10-08 09:52:24.843	info	cleaned everything up...
    zigbee.0
       2021-10-08 09:52:24.841	info	Got terminate signal TERMINATE_YOURSELF
    Kann mir da einer weiter helfen damit die letzte grüner Lampe auch grün wird?
    p.s. ich habe auch eine Hui und eine Ikea Gatway aber die waren beide aus bei der installation.
    mfg
    Router: Ubiquiti UniFi Dream Machine Pro|Iobroker I.NUCi5/Debian, 6 x Switche, 3 x APs, 3 x Cam, 2 x Nas(Qnap 4 & 8 Bay's)
    7 x Echos, 76 x Tasmota, 58 x ZigBee, Homatic Ip, 2 x USV
    • D Digi-Bit
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      mfg
      dimaiv
      schrieb am zuletzt editiert von dimaiv
      @digi-bit sagte in CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB:
      mfg
      1. Verkäufer kontaktieren?
      2. Mit einem Stift grün bemalen?
      3. Oder die Suchfunktion hier im Forum benutzen.
      ioBroker- NUC8i3 / Proxmox / VM
      Node.js v22.21.0
      NPM v10.9.4
      JS controller 7.1.0
      Admin 7.7.20
      ZigBee Adapter 3.3.1alpha.0
      Zigbee LAN Gateway CC2652P
      Zigbee Firmware 20250321
      • arteckA Offline
        arteckA Offline
        arteck
        adapter version ist schon mal genannt.. aber wo steckt der drin ??
        • D dimaiv
          mfg
          Digi-Bit
          @dimaiv sagte in CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB:
          mfg
          hab ich auch schon aber das dauert wohl ....
          1. Mit einem Stift grün bemalen?
          ist blöd auf den monitor .........^^
          50. Oder die Suchfunktion hier im Forum benutzen.
          habe ich 2 oder 3 stunden lang.....
          ich find da aber nix passendes ;
          Zaunpfahl da ? 😵
          mfg
          • arteckA arteck
            Digi-Bit
            schrieb am zuletzt editiert von Digi-Bit
            @arteck sagte in CC2531 ZigBee Stick zigbee2mqtt ioBroker FHEM openHAB:
            im Usb Port vom raspberry pi unten links ^^
            ttyACM0
            pi@raspberrypi4pi:~ $ ls -l /dev/serial/by-id
            insgesamt 0
            lrwxrwxrwx 1 root root 13 Okt 8 09:29 usb-Texas_Instruments_TI_CC2531_USB_CDC__ _0X00124B0014D9038F-if00 -> ../../ttyACM0
            • D Digi-Bit
              ttyACM0
              insgesamt 0
              dimaiv
              @digi-bit
              Und was ist in Einstellungen beim Zigbee Adapter eingetragen?
              Node.js v22.21.0
              NPM v10.9.4
              JS controller 7.1.0
              Admin 7.7.20
              • D dimaiv
                @digi-bit
                Digi-Bit
                @digi-bit
                dies hier
                • arteckA Offline
                  arteckA Offline
                  arteck
                  @digi-bit bist sicher das der CC2531 ge'flasht ist ?
                  • arteckA arteck
                    Digi-Bit
                    öhmmmmmmm, najaaaaaaaa, laut beschreibung schon
                    CC2531 Zigbee USB Stick
                    vorinstalliert mit neuster Firmware von Koenkk
                    sofort nutzbar mit ioBroker, openHAB, FHEM und zigbee2mqtt
                    kein Zusatzgerät erforderlich
                    im stabilen Gehäuse zum Schutz der Elektroni
                    Produktinformation
                    Verpackungsabmessungen ‏ : ‎ 8.2 x 5.1 x 0.5 cm; 10 Gramm
                    Im Angebot von Amazon.de seit ‏ : ‎ 8. September 2020
                    Hersteller ‏ : ‎ ITSTUFF
                    ASIN ‏ : ‎ B08L21T681
                    Herstellerreferenz ‏ : ‎ CC2531-CASE
                    das ist der hier wenn man den Link posten darf
                    https://www.amazon.de/gp/product/B08L21T681/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                    kann ich das selber irgend wo auslesen ?
                    mfg
                    Post740.pdf
                    ps.s der zettel war bei
                    • D Digi-Bit
                      Produktinformation
                      mfg
                      Post740.pdf
                      Digi-Bit
                      hi....
                      er rennt......
                      Hab bei Amazon nach anderen Sticks gesucht......
                      Irgend wo stand das einer auch Probs hatte und eine USB verlängerung genommen hat.
                      Zack, geht....
                      trotzdem danke für die versuchte hilf !
                      mfg
