  4. mqtt <-> sonoff
    6.4k
mqtt <-> sonoff
5 Beiträge 3 Kommentatoren 400 Aufrufe 3 Beobachtet
    tubabrokerio
    Hallo
    Ich habe IO Broker mit einigen Sonoff Steckdosen am laufen. Mir ist Aufgefallen, daß der Sonoff und mqtt Adapter alle 5 Minuten eine Zeitüberschreitung hat. Was kann ich dagegen machen?
    2021-09-17 16:49:11.754 - info: sonoff.0 (4595) Client [iobroker.mqtt.0] connection closed: timeout
    2021-09-17 16:49:11.755 - info: mqtt.0 (1359) Disconnected from localhost: undefined
    2021-09-17 16:49:11.768 - info: sonoff.0 (4595) Client [iobroker.mqtt.0] connected with secret 1631890151768_4147
    2021-09-17 16:49:11.770 - info: mqtt.0 (1359) Connected to localhost
    2021-09-17 16:49:11.770 - info: mqtt.0 (1359) Subscribe on: "#"
    2021-09-17 16:49:11.771 - info: mqtt.0 (1359) All states published
    2021-09-17 16:54:11.772 - info: sonoff.0 (4595) Client [iobroker.mqtt.0] connection closed: timeout
    2021-09-17 16:54:11.775 - info: mqtt.0 (1359) Disconnected from localhost: undefined
    2021-09-17 16:54:11.791 - info: sonoff.0 (4595) Client [iobroker.mqtt.0] connected with secret 1631890451790_8470
    2021-09-17 16:54:11.795 - info: mqtt.0 (1359) Connected to localhost
    2021-09-17 16:54:11.796 - info: mqtt.0 (1359) Subscribe on: "#"
    2021-09-17 16:54:11.799 - info: mqtt.0 (1359) All states published
    2021-09-17 16:59:11.800 - info: sonoff.0 (4595) Client [iobroker.mqtt.0] connection closed: timeout
    2021-09-17 16:59:11.803 - info: mqtt.0 (1359) Disconnected from localhost: undefined
    2021-09-17 16:59:11.819 - info: sonoff.0 (4595) Client [iobroker.mqtt.0] connected with secret 1631890751818_5528
    2021-09-17 16:59:11.822 - info: mqtt.0 (1359) Connected to localhost
    2021-09-17 16:59:11.823 - info: mqtt.0 (1359) Subscribe on: "#"
    2021-09-17 16:59:11.826 - info: mqtt.0 (1359) All states published
    • T tubabrokerio
      Hallo
      mickymM Offline
      mickymM Offline
      mickym
      @tubabrokerio Vielleicht laufen beide auf gleichem Port - das geht nicht - mache einen auf 1884
      • mickymM mickym
        tubabrokerio
        @mickym Das funktioniert nicht, Wenn ich den Port ändere, dann verliert der Adapter die Verbindung
        mickymM ChaotC 2 Antworten Letzte Antwort
        • T tubabrokerio
          mickymM Offline
          mickymM Offline
          mickym
          @tubabrokerio Wie gesagt die können nicht auf dem gleichen Port laufen, wenn beide als Broker agieren sollen. Meines Erachtens ist der sonoff immer Broker und niemals Client. Also wenn die miteinander kommunizieren sollen, dann muss ja der mqtt-Adapter als Client definiert sein. Warum man das macht erschließt sich mir allerdings nicht.
          • T tubabrokerio
            ChaotC Offline
            ChaotC Offline
            Chaot
            @tubabrokerio Was willst du machen oder anders gefragt, warum hast du MQTT und Sonoff Adapter am Laufen?
            Nur für die Sonoffs benötigst du keinen MQTT Adapter.
            Bei mir ist der im Einsatz für 3 Geräte die nur per MQTT ansprechbar sind und für die kein eigener Adapter existiert.
            Sonoffs laufen auf dem Sonoff Adapter mit dem MQTT Port 1500 seit Beginn ohne größere Probleme.
            Natürlich musst du an den Sonoffs den geänderten Port auch angeben.
            Was die Verbindungsabbrüche angeht kann es aber auch an einer alten Firmware der Sonoffs liegen. Was hast du da im Einsatz?
