<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mqtt &lt;-&gt; sonoff]]></title><description><![CDATA[<p dir="auto">Hallo<br />
Ich habe IO Broker mit einigen Sonoff Steckdosen am laufen. Mir ist Aufgefallen, daß der Sonoff und mqtt Adapter alle 5 Minuten eine Zeitüberschreitung hat. Was kann ich dagegen machen?</p>
<p dir="auto">2021-09-17 16:49:11.754  - [32minfo[39m: sonoff.0 (4595) Client [iobroker.mqtt.0] connection closed: timeout<br />
2021-09-17 16:49:11.755  - [32minfo[39m: mqtt.0 (1359) Disconnected from localhost: undefined<br />
2021-09-17 16:49:11.768  - [32minfo[39m: sonoff.0 (4595) Client [iobroker.mqtt.0] connected with secret 1631890151768_4147<br />
2021-09-17 16:49:11.770  - [32minfo[39m: mqtt.0 (1359) Connected to localhost<br />
2021-09-17 16:49:11.770  - [32minfo[39m: mqtt.0 (1359) Subscribe on: "#"<br />
2021-09-17 16:49:11.771  - [32minfo[39m: mqtt.0 (1359) All states published<br />
2021-09-17 16:54:11.772  - [32minfo[39m: sonoff.0 (4595) Client [iobroker.mqtt.0] connection closed: timeout<br />
2021-09-17 16:54:11.775  - [32minfo[39m: mqtt.0 (1359) Disconnected from localhost: undefined<br />
2021-09-17 16:54:11.791  - [32minfo[39m: sonoff.0 (4595) Client [iobroker.mqtt.0] connected with secret 1631890451790_8470<br />
2021-09-17 16:54:11.795  - [32minfo[39m: mqtt.0 (1359) Connected to localhost<br />
2021-09-17 16:54:11.796  - [32minfo[39m: mqtt.0 (1359) Subscribe on: "#"<br />
2021-09-17 16:54:11.799  - [32minfo[39m: mqtt.0 (1359) All states published<br />
2021-09-17 16:59:11.800  - [32minfo[39m: sonoff.0 (4595) Client [iobroker.mqtt.0] connection closed: timeout<br />
2021-09-17 16:59:11.803  - [32minfo[39m: mqtt.0 (1359) Disconnected from localhost: undefined<br />
2021-09-17 16:59:11.819  - [32minfo[39m: sonoff.0 (4595) Client [iobroker.mqtt.0] connected with secret 1631890751818_5528<br />
2021-09-17 16:59:11.822  - [32minfo[39m: mqtt.0 (1359) Connected to localhost<br />
2021-09-17 16:59:11.823  - [32minfo[39m: mqtt.0 (1359) Subscribe on: "#"<br />
2021-09-17 16:59:11.826  - [32minfo[39m: mqtt.0 (1359) All states published</p>
]]></description><link>https://forum.iobroker.net/topic/47825/mqtt-sonoff</link><generator>RSS for Node</generator><lastBuildDate>Thu, 28 May 2026 02:20:37 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/47825.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 17 Sep 2021 19:37:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mqtt &lt;-&gt; sonoff on Sun, 19 Sep 2021 09:35:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tubabrokerio" aria-label="Profile: tubabrokerio">@<bdi>tubabrokerio</bdi></a> Was willst du machen oder anders gefragt, warum hast du MQTT und Sonoff Adapter am Laufen?</p>
<p dir="auto">Nur für die Sonoffs benötigst du keinen MQTT Adapter.<br />
Bei mir ist der im Einsatz für 3 Geräte die nur per MQTT ansprechbar sind und für die kein eigener Adapter existiert.<br />
Sonoffs laufen auf dem Sonoff Adapter mit dem MQTT Port 1500 seit  Beginn ohne größere Probleme.</p>
<p dir="auto">Natürlich musst du an den Sonoffs den geänderten Port auch angeben.<br />
Was die Verbindungsabbrüche angeht kann es aber auch an einer alten Firmware der Sonoffs liegen. Was hast du da im Einsatz?</p>
]]></description><link>https://forum.iobroker.net/post/678724</link><guid isPermaLink="true">https://forum.iobroker.net/post/678724</guid><dc:creator><![CDATA[Chaot]]></dc:creator><pubDate>Sun, 19 Sep 2021 09:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt &lt;-&gt; sonoff on Sat, 18 Sep 2021 20:07:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tubabrokerio" aria-label="Profile: tubabrokerio">@<bdi>tubabrokerio</bdi></a> Wie gesagt die können nicht auf dem gleichen Port laufen, wenn beide als Broker agieren sollen. Meines Erachtens ist der sonoff immer Broker und niemals Client. Also wenn die miteinander kommunizieren sollen, dann muss ja der mqtt-Adapter als Client definiert sein. Warum man das macht erschließt sich mir allerdings nicht.</p>
]]></description><link>https://forum.iobroker.net/post/678604</link><guid isPermaLink="true">https://forum.iobroker.net/post/678604</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Sat, 18 Sep 2021 20:07:18 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt &lt;-&gt; sonoff on Sat, 18 Sep 2021 20:01:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickym" aria-label="Profile: mickym">@<bdi>mickym</bdi></a> Das funktioniert nicht, Wenn ich den Port ändere, dann verliert der Adapter die Verbindung</p>
]]></description><link>https://forum.iobroker.net/post/678603</link><guid isPermaLink="true">https://forum.iobroker.net/post/678603</guid><dc:creator><![CDATA[tubabrokerio]]></dc:creator><pubDate>Sat, 18 Sep 2021 20:01:51 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt &lt;-&gt; sonoff on Fri, 17 Sep 2021 22:35:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tubabrokerio" aria-label="Profile: tubabrokerio">@<bdi>tubabrokerio</bdi></a> Vielleicht laufen beide auf gleichem Port - das geht nicht - mache einen auf 1884</p>
]]></description><link>https://forum.iobroker.net/post/678261</link><guid isPermaLink="true">https://forum.iobroker.net/post/678261</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Fri, 17 Sep 2021 22:35:36 GMT</pubDate></item></channel></rss>
