  4. Auswertung für smartmeter
62 Beiträge 16 Kommentatoren 13.6k Aufrufe 4 Beobachtet
  • a200A Offline
    a200A Offline
    a200
    @chemieka:
    Kannst du aus dieser Fehler Meldung was lesen?
    at TCP.onread (net.js:548:20)
    host.	2017-02-12 19:00:00.826	error	at Socket.Readable.push (_stream_readable.js:134:10)
    host.	2017-02-12 19:00:00.826	error	at readableAddChunk (_stream_readable.js:176:18)
    host.	2017-02-12 19:00:00.826	error	at Socket.emit (events.js:188:7)
    host.	2017-02-12 19:00:00.826	error	at emitOne (events.js:96:13)
    host.	2017-02-12 19:00:00.826	error	at Socket. (/opt/iobroker/node_modules/redis/index.js:274:27)
    host.	2017-02-12 19:00:00.826	error	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:560:12)
    host.	2017-02-12 19:00:00.826	error	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
    host.	2017-02-12 19:00:00.826	error	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:828:9)
    host.	2017-02-12 19:00:00.826	error	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:789:18)
    host.	2017-02-12 19:00:00.826	error	at RedisClient.emit (events.js:194:7)
    host.	2017-02-12 19:00:00.826	error	at emitThree (events.js:116:13)
    host.	2017-02-12 19:00:00.826	error	at RedisClient. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:92:25)
    host.	2017-02-12 19:00:00.826	error	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2866:37)
    host.	2017-02-12 19:00:00.826	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:252:17)
    host.	2017-02-12 19:00:00.826	error	at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:580:17)
    host.	2017-02-12 19:00:00.826	error	at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3161:17)
    host.	2017-02-12 19:00:00.826	error	at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:584:47
    host.	2017-02-12 19:00:00.826	error	TypeError: Cannot read property 'callback' of undefined
    host.	2017-02-12 19:00:00.823	error	pmessage io.javascript.0.Stromzähler.Hager.Hour {"val":255.70000000006985,"ack":true,"ts":1486922400817,"q":0,"from":"system.adapter.javascript.0","lc":1486922400817} Cannot read property 'callback'
    Leider nicht. Da müsste einer von den ioBroker Spezialisten sagen, was diese Fehlermeldung bedeutet. Dann kann ich sagen ob es am Script liegt. Nichtsdestotrotz will ich demnächst die unschöne double Berechnung der Zahlen abstellen.
    IoBroker auf QNAP TS-451, Raspi und NUC
    • a200A Offline
      a200A Offline
      a200
      @chemieka:
      Könnte man den Monatsverbrauch nicht auch aus den Summen der Tages oder Wochenverbrauchs berechnen, dann müsste man nicht so lange warten? Denke viel ungenauer wirds damit auch nicht. `
      Nein. Du kannst den Gesamtverbrauch eines Monats erst dann berechnen, wenn ein ganzer Monat (vom ersten bis zum letzten eines Monats) auch vergangen ist. Vorher nicht. Ich kann noch einen neuen Datenpunkt: Aktueller Monat bzw. aktuelle Woche berechnen. Funktioniert so ähnlich wie Today. D.h. Der Verbrauch sein dem 1. eines Monats bzw. seit Montag einer Woche um 0:00 bis heute.
      Dort würden schon Werte landen noch bevor die komplette Periode abgelaufen ist, allerdings werden die Werte im ersten Monat / ersten Woche nicht korrekt sein (können).
      Wenn also noch ein paar Leute sich melden, dass Sie die Funktion haben wollen, dann werde ich sie auch einbauen.
      LG,
      • apollon77A Offline
        Bitte das JS posten. sieht für mich nach nem Fehler beim subscribe aus!
        • a200A Offline
          a200A Offline
          a200
          @apollon77:
          Bitte das JS posten. sieht für mich nach nem Fehler beim subscribe aus! `
          Schau mal in ersten Posting ist ein Spoiler! ;)
            simpixo
            Also es wäre nicht schlecht ein Objekt zu haben -> Stromverbrauch Monatsanfang bis heute [emoji6]
            Adrian
            • a200A Offline
              a200A Offline
              a200
              @simpixo:
              Adrian
              Gesendet von iPhone mit Tapatalk Pro `
              Willst du es testen? ;)
                simpixo
                Klar, warum nicht [emoji3]
                • a200A Offline
                  a200A Offline
                  a200
                  @simpixo:
                  Testen habe ich gesagt, also keine Garantie. :)
                  1. kopiere den Wert deinen aktuellen Gesamtverbrauches in die Datenpunkte Total-m und Total-w
                  2. benutze die unten stehende Version 0.11b
                  zu nächsten vollen Stunde werden die Datenpunkte CurrentWeek und CurrentMonth gefüllt.
                  Falls du eigenen Pfad zu den Datenpunkten hast, dann brauchst du diese nur einmal anpassen (PathToDP).
                  Warte auf deine Freigabe! :D
                  // NEU - Zählerstand vom Anfang der akt. Stunde wird ermittelt v 0.11
                  ! var AktWoche = true; // Berechnung des Wertes: Aktuelle Woche ein-/ausschalten
                  var AktMonat = true; // Berechnung des Wertes: Aktueller Monat ein-/ausschalten
                  var PathToDP = "javascript.0.Stromzähler.Hager."; // Pfad zum Datenpunkt
                  ! var cronH = "0 * * * *";
                  var cronD = "59 23 * * *";
                  var cronW = "0 0 * * 1";
                  var cronM = "0 0 1 * ";
                  ! var idHAGTotH = PathToDP + "tmp.Total-h";
                  var idHAGTotD = PathToDP + "tmp.Total-d";
                  var idHAGTotW = PathToDP + "tmp.Total-w";
                  var idHAGTotM = PathToDP + "tmp.Total-m";
                  var idHAGTotal = PathToDP + "smartmeter.0.1-0:1_8_0
                  255.value"; /Stromverbrauch insgesammt/
                  var idHAGZielH = PathToDP + "Hour";
                  var idHAGZielD = PathToDP + "Day";
                  var idHAGZielW = PathToDP + "Week";
                  var idHAGZielM = PathToDP + "Month";
                  var idHAGZielT = PathToDP + "Today";
                  var idHAGZielCW = PathToDP + "CurrentWeek";
                  var idHAGZielCM = PathToDP + "CurrentMonth";
                  ! var debug = false;
                  ! var DPArray = [idHAGTotH, idHAGTotD , idHAGTotW, idHAGTotM, idHAGZielH, idHAGZielD, idHAGZielW, idHAGZielM, idHAGZielT, idHAGZielCW, idHAGZielCM];
                  var DPUnit = "Wh";
                  ! DPArray.forEach(function(wert, index, array) {
                  var DPType = wert.split(".");
                  var DPDescr = "Power consumption of " + (DPType[DPType.length - 1]);
                  if(index > 3) DPUnit = "Wh";
                  createState(wert, 0, {
                      desc: DPDescr,
                      type: 'number',
                      unit: DPUnit,
                      role: 'value'
                  ! function haupt (VorId, ZielId, SetN) {
                  var nVorwert = getState(VorId).val;
                  var nAktuell = getState(idHAGTotal).val;
                  var nDiff = ((nAktuell * 10) - (nVorwert * 10)) * 100;
                  setState(ZielId, nDiff, true);
                  if(debug) log("Aus: " + nAktuell +" - "+ nVorwert + " = " + nDiff);
                  if(SetN) {
                  var shandler = on ({id: ZielId, change: 'any'}, function(data) {
                  setState(VorId, (nAktuell*10)/10, true);
                  unsubscribe(shandler);
                  ! // regelmässige Wiederholungen
                  ! schedule(cronH, function () {
                  haupt(idHAGTotH, idHAGZielH, true);
                  haupt(idHAGTotD, idHAGZielT, false);
                  if(AktWoche) haupt(idHAGTotW, idHAGZielCW, false);
                  if(AktMonat) haupt(idHAGTotM, idHAGZielCM, false);
                  ! schedule(cronD, function () {
                  haupt(idHAGTotD, idHAGZielD, true);
                  ! schedule(cronW, function () {
                  haupt(idHAGTotW, idHAGZielW, true);
                  ! schedule(cronM, function () {
                  haupt(idHAGTotM, idHAGZielM, true);
                    simpixo
                    @a200:
                    Testen habe ich gesagt, also keine Garantie. :) `
                    Dann teste ich mal ;)
                    Hab dein Script mal übernommen und schaue was passiert
                    Adrian
                      simpixo
                      Hallo a200
                      irgendwas ist komisch….
                      warum ist das eine Minus Zahl? Soll das so sein? oder habe ich was falsch gemacht?
                      Adrian
                      • a200A Offline
                        a200A Offline
                        a200
                        @simpixo:
                        Hallo a200
                        Adrian `
                        aus
                        var idHAGTotal = PathToDP + "smartmeter.0.1-0:1_8_0*255.value"; /Stromverbrauch insgesammt/
                        mach
                        var idHAGTotal = "smartmeter.0.1-0:1_8_0*255.value"; /Stromverbrauch insgesammt/
                        Ein fataler Fehler! Die aktueller Wert konnte nicht ausgelesen werden! Etwas zu viel Cut&Paste 😢
                        Kopiere vorher den aktuellen Wert in Total-d und Total-h
                        Danach sollte es gehen.
                          simpixo
                          Welchen Wert meinst du denn genau!? Den Gesamten Verbrauch!?
                          • a200A Offline
                            a200A Offline
                            a200
                            @simpixo:
                            Ja. Gesamtverbrauch.
                              simpixo
                              @a200:
                              aus
                              mach
                              Danach sollte es gehen. `
                              Habe gerade angepasst…. schauen wir mal ob das Ganze jetzt funktioniert :)
                              Adrian
                              • a200A Offline
                                a200A Offline
                                a200
                                Ich warte.
                                • a200A Offline
                                  a200A Offline
                                  a200
                                  Und? Die volle Stunde ist um.
                                    simpixo
                                    @a200:
                                    Und? Die volle Stunde ist um. `
                                    Leider vergessen das Script zu starten [emoji23][emoji23][emoji23]
                                    Jetzt müssen wir bis 22 Uhr warten [emoji53]
                                    Adrian
                                    • a200A Offline
                                      a200A Offline
                                      a200
                                      [FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY][FACE WITH TEARS OF JOY]
                                        simpixo
                                        Hallo
                                        habe gerade nachgesehen die ersten Werte sind schon da, aber dennoch sieht es komisch aus
                                        Total-h wandelt der selbständig um in kWh meine ich, habe das nämlich als Wh angeben, aber jetzt ist das Koma an der falschen Stelle
                                        Was sagst du dazu? :shock:
                                        • a200A Offline
                                          a200A Offline
                                          a200
                                          @simpixo:
                                          Hallo
                                          Was sagst du dazu? :shock: `
                                          hast du die kWh Berechnung rein gemacht?
                                          außerdem ist Total-w, Total-m leer. Dort sollte aber der Gesamtverbrauchswert stehen.
                                          Akt. Gesamtverbrauch - Total-w = currentWeek
                                          oben hattest du einen Wert in Total-m und Total-w
