  3. Entwicklung
  4. FRONIUS Adapter Entwicklung eingestellt?
    6.3k
fronius
440 Beiträge 44 Kommentatoren 150.2k Aufrufe 45 Beobachtet
  • JB_SullivanJ Offline
    JB_Sullivan
    schrieb am zuletzt editiert von JB_Sullivan
    #341
    Mahlzeit zusammen,
    hatte von Euch schonmal jemand über den ioB Adapter von Fronius folgendes Problem?
    fronius.0	2021-08-15 15:56:06.829	error	(13152) IP is not a Fronis inverter
    BTW -> es muss FRONIUS und nicht FRONIS inverter heißen. Das ist aber Kleinkram
    fronius.0	2021-08-15 15:52:34.376	debug	(13152) Unable to read data from inverters solarAPI
    fronius.0	2021-08-15 15:52:34.376	debug	(13152) Exception thrown in check API: SyntaxError: Unexpected token < in JSON at position 0
    fronius.0	2021-08-15 15:52:34.359	debug	(13152) Unable to read data from inverters solarAPI
    fronius.0	2021-08-15 15:52:34.358	debug	(13152) Exception thrown in check API: SyntaxError: Unexpected token < in JSON at position 0
    fronius.0	2021-08-15 15:52:34.222	debug	(13152) System command: C:\WINDOWS\system32\cmd.exe /s /c " C:\WINDOWS\system32\ping.exe -n 1 -w 2000 10.122.60.57 "
    fronius.0	2021-08-15 15:52:34.214	debug	(13152) System command: C:\WINDOWS\system32\cmd.exe /s /c " C:\WINDOWS\system32\ping.exe -n 1 -w 2000 10.122.60.57 "
    fronius.0	2021-08-15 15:52:34.188	info	(13152) starting. Version 1.1.3 in C:/iobroker/GLT/node_modules/iobroker.fronius, node: v14.16.0, js-controller: 3.3.15
    fronius.0	2021-08-15 15:52:33.680	debug	(13152) statesDB connected
    fronius.0	2021-08-15 15:52:33.679	debug	(13152) States connected to redis: 127.0.0.1:9000
    fronius.0	2021-08-15 15:52:33.655	debug	(13152) States create User PubSub Client
    fronius.0	2021-08-15 15:52:33.654	debug	(13152) States create System PubSub Client
    fronius.0	2021-08-15 15:52:33.636	debug	(13152) Redis States: Use Redis connection: 127.0.0.1:9000
    fronius.0	2021-08-15 15:52:33.633	debug	(13152) objectDB connected
    fronius.0	2021-08-15 15:52:33.620	debug	(13152) Objects connected to redis: 127.0.0.1:9001
    fronius.0	2021-08-15 15:52:33.591	debug	(13152) Objects client initialize lua scripts
    fronius.0	2021-08-15 15:52:33.590	debug	(13152) Objects create User PubSub Client
    fronius.0	2021-08-15 15:52:33.588	debug	(13152) Objects create System PubSub Client
    fronius.0	2021-08-15 15:52:33.586	debug	(13152) Objects client ready ... initialize now
    fronius.0	2021-08-15 15:52:33.522	debug	(13152) Redis Objects: Use Redis connection: 127.0.0.1:9001
    host.GLT(GLT)	2021-08-15 15:52:31.276	info	instance system.adapter.fronius.0 started with pid 13152
    host.GLT(GLT)	2021-08-15 15:52:29.375	info	instance system.adapter.fronius.0 terminated with code null ()
    host.GLT(GLT)	2021-08-15 15:52:29.375	warn	instance system.adapter.fronius.0 terminated due to SIGTERM
    host.GLT(GLT)	2021-08-15 15:52:29.242	info	stopInstance system.adapter.fronius.0 killing pid 15140
    Seit Monaten läuft alles was mit Fronius zu tun hat 1A. Unter der im Adapter eingetragenen IP erreiche ich den WR direkt. Auch solarweb funktioniert einwandfrei und über den Fritzbox Router ist der WR ebenfalls unter der IP erreichbar.
    Ich habe den Adapter, als auch ioB selber schon neu gestartet, aber der Fronius Adpter bleibt mit der oben genannten Fehlermeldung gelb und baut auch keine Verbindung mehr zum WR auf.
    Das Phänomen trat irgendwann heute Vormittag auf, OHNE das ich in den letzten Tagen etwas verändert hätte - quasi von jetzt auf gleich.
    Hat jemand eine Idee dazu?
    EDIT: Ich habe in der Zwischenzeit nochmal alles mögliche ausprobiert, was mir so in den Sinn gekommen ist. Interessant daran ist, das der ModBus Adapter der auf die gleiche Adresse des Gerätes zugreift, nach wie vor z.B. die Gehäuse Temperatur und bei Bedarf auch andere Werte abholt.
    Ich finde diese beiden Meldungen interessant - was ist mit dem Invalid Token gemeint`? Ist das etwas was ggf. nicht lokal läuft, sondern auf den Fronius Servern? Sind das ggf. anzeichen für das lange angekündigte Firmware Update incl. API 2.x?
    EDIT Teil 2: Hmmmm - es wird immer lustiger - jetzt habe ich den Adapter und die Objekte gelöscht und von GIT die Version 1.1.6 neu installiert.
    Jetzt bekomme ich die folgende Meldung, obwohl der Adapter incl. IP konfiguriert ist ?!?!?!
    fronius.0	2021-08-15 17:36:54.817	error	(11492) Please configure the Fronius adapter
    fronius.0	2021-08-15 17:36:54.804	info	(11492) starting. Version 1.1.3 in C:/iobroker/GLT/node_modules/iobroker.fronius, node: v14.16.0, js-controller: 3.3.15
    AHH - ich glaube jetzt weiß ich was er will. Durch die Neuinstallation ist der Ausleseintervall verloren gegangen. Da die Prüfung der IP Adresse fehlt schlägt, kann man auch keinen Aktualisierungsintervall eingeben. Die IP ist aber 100%ig korrekt - verstehe es gerade nicht, warum er sich nicht mehr mit dem WR verbinden mag :(
      stan23
      #342
      Bei mir läuft der Adapter am Symo 10.0-3-M bisher ohne Probleme, aber zumindest die Kleinigkeit ist erledigt ;)
      https://github.com/iobroker-community-adapters/ioBroker.fronius/pull/132
      Viele Grüße
      Marco
      • JB_SullivanJ JB_Sullivan
        Mahlzeit zusammen,
        da_WoodyD Offline
        da_WoodyD Offline
        #343
        @jb_sullivan bei mir funzt alles tadellos, allerdings muss ich noch die 1.0.5 verwenden. bei höherer version wird storage (die batterie) nicht mehr aktualisiert.
          JB_Sullivan
          #344
          Ich habe mittlerweile heraus gefunden, das auch meine Wallbox sich zur gleichen Zeit aufgehängt hatte. Wer jetzt letzendlich der Auslöser für dieses Wallbox / Wechselrichter durcheinander ist, habe ich noch nicht heraus gefunden.
          Ich habe daraufhin gestern Abend noch ein Backup eingespielt. Das Interessante daran - nach dem Backup wurden bei den Objekten ein "inverter 1" angelegt und alle Daten vom WR werden seit dem nur noch in den inverter 1 hinein geschrieben und aktualisiert.
          Der vorhandene inverter0 enthält die alten Daten von vor dem "Aufhänger" und wird auch nicht mehr "bedient".
          Ist natürlich saublöd, da alle Skripte, VIS und Grafana Bilder sich auf inverter0 beziehen. Ich habe keine Ahnung, wie das zustande gekommen sein kann, zumal ich am Wechselrichter nichts verändert habe und auch nur einen Inverter besitze.
          NegaleinN da_WoodyD 2 Antworten Letzte Antwort
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #345
            @jb_sullivan sagte in FRONIUS Adapter Entwicklung eingestellt?:
            Kann dir leider nicht wirklich weiterhelfen, wir haben zwar nur den Symo 10.0-3-M, aber das "Inverter 1" hatte ich schon seit der ersten Version vom Adapter.
            Inverter 0 gabs bei uns noch nie.
            ° Fixer ---> iob fix
              da_WoodyD Offline
              da_WoodyD Offline
              #346
              @jb_sullivan hmm, kanns nicht beschwören, hab aber auch nur
              in den objekten...
              hab aber nach update versuchen auch mal den kompletten bau gelöscht. dadurch bich ich ja drauf gekommen, daß bei höher als 1.0.5 meine BYD nicht mehr tutet...
                JB_Sullivan
                #347
                Es gibt mitlerweile eine Erklärung zum inverter.0 / inverter.1 Problem. Lag in einer früheren Version des Adapters begründet.
                Wer den Objekte Baum nach einem der Updates nicht gelöscht hat, wurde jetzt, so wie ich, mit dem inverter.1 "Problem" überrascht, sobald er in der Instanz Einstellung die IP Adresse erneut verifizieren wollte.
                https://github.com/iobroker-community-adapters/ioBroker.fronius/issues/142
                Warum es aber zum totalen Aufhänger der API Kommunikation hier in ioBroker und auch zur openWB Wallbox kam, ist damit noch nicht geklärt. Wenigstens die ID Zuweisung ist jetzt plausiebel und von mir nun in allen meinen Skripten, VIS und Influxdb Verwendungsstellen geändert worden.
                Ich hatte es auch schonmal im Rahmen der ganzen js-controller / Admin 5.xx Updates angemerkt. Das löschen des Objektebaum ist in meinen Augen immer das letzte Mittel, da gerade DP`s die in Influxdb / sourceanalytix oder ähnlichen verwendet werden, dann mühsam von Hand wieder verknüpft werden müssen.
                Da gehen oftmals div. Werte über die Wupper (z.B. bei sourceanalytix)
                • F Offline
                  fleck.a87
                  #348
                  Moin alle zusammen,
                  ich möchte aktuell ein Scribt zusammenschreiben mit dem man bei Stromausfall und start des Wechselrichters in Notstrom bzw. Inselbetrieb ich automatisch Verbraucher abschalten kann.
                  Soweit is alle vorbereitet mit dem GEN 24 symo und Homematic komponenten.
                  Wir der Notstrombetrieb überhaupt an einem Datenpunkt angezeigt und wenn ja wie?
                  Dachte da evtl an den Status oder so:
                  Hat jemand eine Idee wie bzw. wo man das auslesen kann damit ich den Wert in einem Script weiterverwenden kann?
                  Gruß Andi
                  JB_SullivanJ T R 3 Antworten Letzte Antwort
                  • F fleck.a87
                    Moin alle zusammen,
                    Gruß Andi
                    JB_Sullivan
                    #349
                    @fleck-a87 Aus dem Adapter soweit ich weiß nicht, aber vielleicht bekommst du das über eine der Modbus Adressen heraus. Dann müsstest du dir allerdings noch zusätzlich den ioB Modbus Adapter installieren.
                    Musste ich leider auch machen, da ich die Geräte Temperatur haben wollte und diese über den Fronius Adapter aktuell nicht ausgelesen wird - über Modbus aber schon.
                    • F fleck.a87
                      Moin alle zusammen,
                      Gruß Andi
                      tigiba
                      schrieb am zuletzt editiert von tigiba
                      #350
                      @fleck-a87 bei meiner Anlage erkenne ich den Notstrombetrieb daran, dass in diesem der Fronius Smart Meter nicht aktiv ist und daher keine seiner Werte gemeldet werden. Hab das aber bisher nicht in nem Script verwendet.
                        ThomKast
                        #351
                        Hallo zusammen. GLASFASER meinte ich solle die Anfrage besser in diesem Chat einstellen. Würde mich also auch über Eure Ideen freuen ;-)
                        In folgender Ausgangssituation stecke ich fest:
                        FRONIUS IG 70 plus ist aktuell mit einer COM-Card via RS-422 an einen SolarLog 500 angeschlossen.
                        Diesen SolarLog 500 habe ich auch erfolgreich im iob integriert.
                        Nun möchte ich aber den IG70+ direkt auslesen und den SolarLog in Rente schicken.
                        Dazu habe ich von DSD Tech einen SH-U11l RS-422/USB-Adapter erworben.
                        wie von DSD beschrieben habe ich den D2XX Treiber von FTDI geladen und eingebunden.
                        Und zwar den 1.4.24. ARMV6 hard-float *** für ARM-Prozessor.
                        Wobei mir der Abschnitt "Compiling and Running Sample D2XX Applications" nichts sagte und ich diesen nicht ausführte...
                        Folgende Kabel-Verbindungen zwischen IG70+ und RS422-Adapter wurden vorgenommen
                        IG70+ T/RX+ auf RS422 T/R+
                        IG70+ T/RX- auf RS422 T/R-
                        IG70+ R/TX+ auf RS422 RXD+
                        IG70+ R/TX- auf RS422 RXD-
                        ls /dev/ttyU* ergibt /dev/ttyUSB0 und /dev/ttyUSB1
                        Am /dev/ttyUSB0 hängt der Weidmann IR-Lesekopf
                        Und am /dev/ttyUSB1 hängt der RS422/USB-Adapter
                        Ein cat /dev/ttyUSB1 liefert leider nur einen blinkenden Cursor.
                        Welche Tests kann ich noch durchführen, um die Datenübertragung zu prüfen?
                        Und mit welchem iob-Adapter würde ich es abschließend abfragen, wenn es denn technisch rennt...
                        Ich weiß. dass es schon sehr speziell ist. Aber andere Einträge dazu habe ich nicht gefunden. Und nun hoffe ich, dass sich jemand von Euch erbarmt und mir helfen kann.
                        Und selbstverständlich nehme ich auch jede andere Anbindung des FRONIUS WRs an.
                        Beste Grüße, Thomas
                        • T ThomKast
                          Beste Grüße, Thomas
                          Bavarian
                          #352
                          mir ist aufgefallen, dass die Daten im SolarWeb / App nicht mit den Daten aus den Zählerpunkten übereinstimmen.
                          Ich nutze Datenpunkte wie fronius.0.inverter.1.TOTAL_ENERGY bzw. fronius.0.powerflow.E_Total (PV Power Total) um den täglichen Ertrag zu loggen. Gestern zB. 9 kW per Adapter ausgelesen. Der Wert stimmt wenn ich im History Adapter um 00:00 Uhr nachsehe und um 23:59 Uhr. Im SolarWeb werden daraus 6,5 kW. An anderen Tagen zeigt SolarWeb / App deutlich mehr an.
                          Ich nutze folgende Datenpunkte:
                          PV Ertrag = fronius.0.inverter.1.TOTAL_ENERGY
                          Energie ins Netz eingespeist = fronius.0.meter.0.EnergyReal_WAC_Minus_Absolute
                          Energie aus dem Netz bezogen = fronius.0.meter.0.EnergyReal_WAC_Plus_Absolute
                          Eigentlich finde ich diese Daten aus dem Adapter schlüssiger als die von SolarWeb / App.
                          Da es mir auch um das Thema Abrechnung geht möchte ich natürlich schon wissen was da stimmt.
                          Wenn SolarWEb doch die Daten selben Daten erhält, wieso kommt es da teils zu gravierenden unterschieden?
                          C 1 Antwort Letzte Antwort
                          • B Bavarian
                            c1olli
                            #353
                            ich habe den Adapter nun schon eine Weile am Laufen und alles funktioniert soweit, aber es kommt immer folgende Fehlermeldung:
                            "State "fronius.0.inverter.1.Power_DC_String_2" has no existing object, this might lead to an error in future versions"
                            An String 2 hängt nichts dran. Im Git ist auch schon ein Issue mit einer Lösung,
                            https://github.com/iobroker-community-adapters/ioBroker.fronius/issues/97
                            aber ich weiss leider nicht wo die Änderung eingefügt werden muß.
                            Olli
                            MassiveAttackM 2 Antworten Letzte Antwort
                            • C c1olli
                              MassiveAttackM Offline
                              MassiveAttack
                              #354
                              @c1olli
                              würde mich auch interessieren
                                @roman3103
                                Nein, das liegt aber an der Firmware. Die Daten werden über die aktuell zur Verfügung stehende API nicht ausgegeben.
                                Triple-M
                                #355
                                @jb_sullivan
                                Kann man den Gesamtertrag mittlerweile mit der neuen Gen24 Firmware auslesen?
                                • T Triple-M
                                  @jb_sullivan
                                  JB_Sullivan
                                  #356
                                  @triple-m Leider nein, es gibt zwar einen Datenpunkt, der ist aber nach wie vor beim GEN24 leer.
                                    Triple-M
                                    #357
                                    @jb_sullivan
                                    Ok danke dir. Kannst du mir denn die Register Nummer dazu sagen?
                                    • T Triple-M
                                      @jb_sullivan
                                      JB_Sullivan
                                      #358
                                      @triple-m RegisterNr. ? Du arbeitest mit ModBus? Ich habe das hier aus dem Gen24 Adapter, das es den neuen DP gibt.
                                      Wenn Fronius nach dem Update die ModBus Tabelle angepasst hat, sollte das da irgenwo zu finden sein. ....... aber da bin ich gerade überfragt.
                                      T da_WoodyD 2 Antworten Letzte Antwort
                                        Triple-M
                                        schrieb am zuletzt editiert von Triple-M
                                        #359
                                        @JB_Sullivan
                                        Ja ich nutze Modbus über den Loxone Miniserver und diese Register-Adresse fehlt mir noch.
                                        Ich habe auch den iobroker Adapter mal installiert (die neueste Version von GitHub) aber die Instanz bleibt immer gelb und wird nicht grün, obwohl die IP natürlich stimmt. Eine Fehlermeldung bekomme ich nicht.
                                        • C c1olli
                                          MassiveAttack
                                          #360
                                          @c1olli said in FRONIUS Adapter Entwicklung eingestellt?:
                                          Ich habe das gleiche Problem. Kann mir bitte jemand sagen, wie man das beheben kann?
                                          Danke!
