  4. Ist der Raspi überlastet?
    5.6k
64 Beiträge 7 Kommentatoren 4.3k Aufrufe 5 Beobachtet
  • M maxpd
    @maxpd So, um 10 uhr hat sich der Swap um 15,2% gefüllt (rote Linie) und hält den Wert momentan konstant. Der Log für diese eine Minute. Die Grüne Linie ist der freie Speicher. Mit 200mb angegeben, wobei ich im htop 400 sehe:
    2021-09-05 09:59:39.002  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
    2021-09-05 09:59:41.855  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 09:59:41.856  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 09:59:48.803  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
    2021-09-05 09:59:52.052  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632._info.mac" has to be type "number" but received type "string"
    2021-09-05 09:59:52.188  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
    2021-09-05 09:59:52.195  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
    2021-09-05 09:59:52.202  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
    2021-09-05 09:59:52.345  - info: mihome-vacuum.0 (1336) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2021-09-05 09:59:58.802  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
    2021-09-05 09:59:59.338  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
    2021-09-05 10:00:00.142  - info: host.iobroker instance system.adapter.coronavirus-statistics.0 started with pid 9065
    2021-09-05 10:00:01.924  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:01.925  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 10:00:01.962  - info: coronavirus-statistics.0 (9065) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.1, js-controller: 3.3.15
    2021-09-05 10:00:04.176  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 9085
    2021-09-05 10:00:04.829  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.active_bright" has to be type "number" but received type "string"
    2021-09-05 10:00:04.831  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.ct" has to be type "number" but received type "string"
    2021-09-05 10:00:05.882  - info: daswetter.0 (9085) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.1, js-controller: 3.3.15
    2021-09-05 10:00:06.060  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.active_bright" has to be type "number" but received type "string"
    2021-09-05 10:00:06.061  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.ct" has to be type "number" but received type "string"
    2021-09-05 10:00:06.974  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821611698,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:07.148  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821611864,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:07.298  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612007,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:07.513  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612177,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:07.762  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612403,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:07.892  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612571,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:08.049  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612765,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:08.805  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
    2021-09-05 10:00:15.557  - info: host.iobroker instance system.adapter.ical.0 started with pid 9101
    2021-09-05 10:00:16.008  - info: mihome-vacuum.0 (1336) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2021-09-05 10:00:16.750  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821612918,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:17.460  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613304,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:17.686  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613458,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:17.925  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613590,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:18.151  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821613816,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:18.500  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614000,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:18.801  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
    2021-09-05 10:00:18.801  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614146,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:19.100  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614401,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:19.413  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821614567,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_2.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:19.616  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
    2021-09-05 10:00:20.202  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821615031,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:20.667  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821615254,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:20.806  - info: ical.0 (9101) starting. Version 1.11.2 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.1, js-controller: 3.3.15
    2021-09-05 10:00:21.004  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821615427,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:21.178  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821616447,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:21.399  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821616673,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:21.562  - info: ical.0 (9101) processing URL: Abfuhrtermine https://calendar.google.com/calendar/ical/gteg5rprkrdlshhholvk9ot354%40group.calendar.google.com/private-0251115518dfd8b3c71688e9dd691e07/basic.ics
    2021-09-05 10:00:21.715  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821616919,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:21.893  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:21.894  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 10:00:21.968  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821617130,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:22.155  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821617402,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_3.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:22.510  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632._info.mac" has to be type "number" but received type "string"
    2021-09-05 10:00:22.662  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.0" has to be one of type "string", "number", "boolean" but received type "object"
    2021-09-05 10:00:22.671  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.1" has to be one of type "string", "number", "boolean" but received type "object"
    2021-09-05 10:00:22.678  - info: wled.0 (2784) State value to set for "wled.0.98cdac26b632.seg.0.col.2" has to be one of type "string", "number", "boolean" but received type "object"
    2021-09-05 10:00:22.745  - info: coronavirus-statistics.0 (9065) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-09-05 10:00:22.804  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821617966,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:22.919  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618138,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:23.563  - info: host.iobroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-09-05 10:00:23.616  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618318,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:23.729  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618435,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:23.864  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618718,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:23.977  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821618935,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.135  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619147,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.252  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619356,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_4.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.495  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619711,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.613  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821619864,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_2","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.709  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620011,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_3","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.829  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620133,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_4","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:24.928  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620248,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_5","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:25.036  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620348,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_6","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:25.145  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620443,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_7","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:25.256  - warn: daswetter.0 (9085) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswetter.0","user":"system.user.admin","ts":1630821620589,"_id":"daswetter.0.NextDaysDetailed.Location_1.Day_5.Hour_8","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    2021-09-05 10:00:25.360  - info: daswetter.0 (9085) Terminated (NO_ERROR): Without reason
    2021-09-05 10:00:25.873  - info: daswetter.0 (9085) cleaned everything up...
    2021-09-05 10:00:25.884  - info: host.iobroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-09-05 10:00:26.996  - info: ical.0 (9101) Terminated (NO_ERROR): Without reason
    2021-09-05 10:00:27.521  - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2021-09-05 10:00:28.803  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
    2021-09-05 10:00:34.833  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.active_bright" has to be type "number" but received type "string"
    2021-09-05 10:00:34.835  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Hinter_TV.control.ct" has to be type "number" but received type "string"
    2021-09-05 10:00:36.050  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.active_bright" has to be type "number" but received type "string"
    2021-09-05 10:00:36.051  - info: yeelight-2.0 (1838) State value to set for "yeelight-2.0.Neben_Couch3.control.ct" has to be type "number" but received type "string"
    2021-09-05 10:00:36.570  - info: mihome-vacuum.0 (1336) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
    2021-09-05 10:00:38.804  - info: javascript.0 (1282) script.js.Lichter.Licht_Büro: 180 sec
    2021-09-05 10:00:39.856  - warn: zigbee.0 (2329) Send command to 0x847127fffe1738bc failed with: Code 205 (No network route)
    2021-09-05 10:00:41.860  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:41.861  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 10:00:47.699  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:47.699  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 10:00:47.703  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:47.703  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 10:00:48.725  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:48.726  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    2021-09-05 10:00:48.728  - info: chromecast.0 (2730) Received keep alive for disconnected device Google Home Wohnzimmer
    2021-09-05 10:00:48.728  - info: chromecast.0 (2730) Reconnecting Google Home Wohnzimmer to xxx.xxx.xxx.76:8009
    @maxpd sagte: um 10 uhr hat sich der Swap um 15,2% gefüllt
    Es starten drei scheduled Instanzen um 10:00 Uhr: coronavirus-statistics.0, ical.0 und daswetter.0. Sollte man vermeiden.
      liv-in-skyL Offline
      liv-in-skyL Offline
      finde ich einen nachteil im admin 5 - man sieht nicht mehr -"auf einem blick" , welche schedules man eingestellt hat - ist im admin 4 besser
      • liv-in-skyL liv-in-sky
        maxpd
        schrieb am zuletzt editiert von maxpd
        Da bin ich wieder.
        Pünktlich Nachts um 0 Uhr wurde der Swap geleert.
        An Tag 2 habe ich Coronavirus und das Wetter deaktiviert. Danach wurde der Swap nicht mehr ganz geleert, aber auch nicht mehr ganz voll. Der normale RAM zeigt seit dem auch weniger Bewegung, aber ist dennoch nicht "freier".
        An Tag 3 habe ich ICal deaktiviert. Keine große Veränderung.
        Ich hab damit das Gefühl, dass der SWAP nicht für die Trägheit verantwortlich ist. Heute um ~19 Uhr war wieder alles sehr langsam. Keine Auffälligkeiten in der Auslastung. Es ging um eine Abfrage von Werten aus dem Modbus Adapter. Die Werte waren fernab jeglicher Realität, respektive verzögert.
        @paul53 Schedules habe ich auf unterschiedliche Minuten gelegt und auch im Abstand reduziert.
        maxpd
        OliverIOO HomoranH 2 Antworten Letzte Antwort
        • M maxpd
          Da bin ich wieder.
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @maxpd
          Der swap leert sich eigentlich nicht einfach so plötzlich.
          Wenn dann sind die Programme beendet worden die den Speicher belegen.
          Kannst du mal in Iobroker log und/oder ins syslog schauen ob zu dieser Uhrzeit da etwas steht?
          Meine Adapter und Widgets
          Links im Profil
          • M maxpd
            Da bin ich wieder.
            @maxpd sagte in Ist der Raspi überlastet?:
            was verstehst du darunter?
            geht dann der SWAP auf 0?
            Dann wäre das:
            @oliverio sagte in Ist der Raspi überlastet?:
            genau andersrum!
            wenn SWAP -> 0, dann wird der Speicherfresser gestartet
              Dann wäre das:
              genau andersrum!
              maxpd
              @homoran Das sind die roten Graphen in meinem Screenshot. Um 0 Uhr geht der Swap von 100 auf 25%, wenn ich alle Scheduled Jobs an habe. Wenn ich alle Scheduled Jobs ausschalte geht er zurück auf 55%.
              Habe noch Probleme in Flot nah ran zu zoomen um die exakten Sekunden rauszufinden, wann der Swap geleert wird. Sobald ich zoome verschwindet der Graph..
              maxpd
              • M maxpd
                ah, das sind % genutzter SWAP??
                und der geht einfach so auf 0%?
                die Linie ist da unterbrochen!
                und es ist nicht
                sondern früher
                scheduled jobs heben eigentlich keinerlei dauerhafte Auswirkung auf den Speicher, sondern nur dann, wenn der schedule startet
                was ist denn die grüne Linie?
                da schnellt irgendwas hoch.
                (eine Legende wäre hilfreich)
                kann es sein, dass dein RasPi da neu startet?
                das kann verschiedene Gründe haben.
                z.B. benötigt eine Linie mindestens zwei Punkte
                  und es ist nicht
                  sondern früher
                  maxpd
                  Die Legende hatte ich oben mal schriftlich drin. Grün ist der freie RAM in mb. Swap ist belegt in MB, wobei es nur 100MB Swap gibt, sodass es gleichzeitig % sind.
                  Wenn die grüne Linie hochschnellt wird also RAM frei.
                  Ja die Linie ist unterbrochen. Kann aber noch nicht erfolgreich ran zoomen.
                  btw wo finde ich das System Log?
                  Ich habe keinen Neustart eingebaut, wüsste nicht wie ^^. Wie finde ich raus ob er neu startet?
                  maxpd
                  Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
                  • M maxpd
                    Schau mit
                    uptime
                    wie lange der Server schon läuft.
                      Schau mit
                      uptime
                      maxpd
                      @thomas-braun Ok, also der selbe wert wie in htop
                      pi@iobroker:~ $ uptime
                       14:34:43 up 5 days,  6:20,  2 users,  load average: 0,10, 0,25, 0,22
                      maxpd
                        @maxpd ok - bin mir auch nicht sicher, ob wir da eine lösung brauchen - wenn der swap halt voll ist, wäre es schon gut, zu wissen, wer da vollschreibt
                        was hast du den außer iobroker noch am laufen
                        der befehl, der funktionieren sollte ist:
                        for proc in /proc/*; do cat $proc/smaps 2>/dev/null ; done
                        wenn die konsole schwarz bleibt, stimmt der awk befehl nicht - aber mit diesem befehl kannst du halt überprüfen, was im swap los ist
                        wenn du ein bashscript machen kannst, ginge noch das http://hslomka.de/techno/?p=474
                        der bash:
                        #!/bin/bash
                         THRESHOLD=2000
                         for pid in `ls /proc`; do
                           vmswap=`awk '/VmSwa/{print $2}' /proc/${pid}/status 2>/dev/null`;
                           if [ ${vmswap} -gt ${THRESHOLD} ];then
                             pName=`ps -ef|awk '$2=="'"${pid}"'" {print $8}'`;
                             echo "PID ${pid}: ${vmswap} kB (${pName})";
                           fi;
                         done 2>/dev/null|sort -un -k3
                        mit top geht es auch https://serverfault.com/questions/132084/system-swapping-how-do-i-figure-out-what-the-problem-is
                        maxpd
                        @liv-in-sky dein befehl geht, aber ich glaube die putty Konsole kann nicht alles auflisten. Muss ich wohl noch andere Optionen ausprobieren, wenn das wirklich der sinnvolle Weg ist :)
                        KernelPageSize:        4 kB
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        ShmemPmdMapped:        0 kB
                        FilePmdMapped:         0 kB
                        Shared_Hugetlb:        0 kB
                        Private_Hugetlb:       0 kB
                        Swap:                748 kB
                        SwapPss:             748 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd wr mr mw me ac
                        b68a9000-b68b2000 r-xp 00000000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd ex mr mw me
                        b68b2000-b68c2000 ---p 00009000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b68c2000-b68c3000 r--p 00009000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd mr mw me ac
                        b68c3000-b68c4000 rw-p 0000a000 b3:02 1569       /lib/arm-linux-gnueabihf/libnss        _files-2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b68c4000-b68ca000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b68d4000-b6b4e000 r--p 0006b000 b3:02 903        /usr/lib/locale/locale-archive
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6b4e000-b6d4e000 r--p 00000000 b3:02 903        /usr/lib/locale/locale-archive
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6d4e000-b6e86000 r-xp 00000000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6e86000-b6e96000 ---p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6e96000-b6e98000 r--p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  8 kB
                        SwapPss:               8 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6e98000-b6e99000 rw-p 0013a000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6e99000-b6e9c000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                 12 kB
                        SwapPss:              12 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6e9c000-b6e9e000 r-xp 00000000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6e9e000-b6ead000 ---p 00002000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6ead000-b6eae000 r--p 00001000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6eae000-b6eaf000 rw-p 00002000 b3:02 1540       /lib/arm-linux-gnueabihf/libdl-        2.28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6eaf000-b6ecd000 r-xp 00000000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6ecd000-b6edd000 ---p 0001e000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6edd000-b6edf000 r--p 0001e000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  8 kB
                        SwapPss:               8 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6edf000-b6ee0000 rw-p 00020000 b3:02 8684       /lib/arm-linux-gnueabihf/libtin        fo.so.6.1
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6ee0000-b6ee4000 r-xp 00000000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6ee4000-b6ef3000 ---p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6ef3000-b6ef4000 r--p 00003000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6ef4000-b6ef5000 rw-p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6ef5000-b6f15000 r-xp 00000000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd ex mr mw me dw
                        b6f17000-b6f19000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f1c000-b6f23000 r--s 00000000 b3:02 12627      /usr/lib/arm-linux-gnueabihf/gc        onv/gconv-modules.cache
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd mr me ms
                        b6f23000-b6f25000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  8 kB
                        SwapPss:               8 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f25000-b6f26000 r--p 00020000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd mr mw me dw ac
                        b6f26000-b6f27000 rw-p 00021000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  4 kB
                        SwapPss:               4 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd wr mr mw me dw ac
                        bee52000-bee73000 rw-p 00000000 00:00 0          [stack]
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                 24 kB
                        SwapPss:              24 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd wr mr mw me gd ac
                        befdc000-befdd000 r-xp 00000000 00:00 0          [sigpage]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd ex mr mw me de
                        befdd000-befde000 r--p 00000000 00:00 0          [vvar]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd mr de
                        befde000-befdf000 r-xp 00000000 00:00 0          [vdso]
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   0 kB
                        Shared_Clean:          4 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            4 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        ffff0000-ffff1000 r-xp 00000000 00:00 0          [vectors]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd ex mr me
                        00010000-00016000 r-xp 00000000 b3:02 687        /bin/cat
                        MMUPageSize:           4 kB
                        Rss:                  24 kB
                        Pss:                  24 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:        24 kB
                        Private_Dirty:         0 kB
                        Referenced:           24 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        00025000-00026000 r--p 00005000 b3:02 687        /bin/cat
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        00026000-00027000 rw-p 00006000 b3:02 687        /bin/cat
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        01735000-01756000 rw-p 00000000 00:00 0          [heap]
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6951000-b6973000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6973000-b6bed000 r--p 0006b000 b3:02 903        /usr/lib/locale/locale-archive
                        MMUPageSize:           4 kB
                        Rss:                 172 kB
                        Pss:                  88 kB
                        Shared_Clean:        168 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         4 kB
                        Private_Dirty:         0 kB
                        Referenced:          172 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6bed000-b6ded000 r--p 00000000 b3:02 903        /usr/lib/locale/locale-archive
                        MMUPageSize:           4 kB
                        Rss:                 248 kB
                        Pss:                 128 kB
                        Shared_Clean:        240 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         8 kB
                        Private_Dirty:         0 kB
                        Referenced:          248 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6ded000-b6f25000 r-xp 00000000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                 712 kB
                        Pss:                  15 kB
                        Shared_Clean:        712 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:          712 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f25000-b6f35000 ---p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6f35000-b6f37000 r--p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   8 kB
                        Pss:                   8 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         8 kB
                        Referenced:            8 kB
                        Anonymous:             8 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f37000-b6f38000 rw-p 0013a000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f38000-b6f3b000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   8 kB
                        Pss:                   8 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         8 kB
                        Referenced:            8 kB
                        Anonymous:             8 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f3b000-b6f3f000 r-xp 00000000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                  16 kB
                        Pss:                   0 kB
                        Shared_Clean:         16 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:           16 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f3f000-b6f4e000 ---p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6f4e000-b6f4f000 r--p 00003000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f4f000-b6f50000 rw-p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f50000-b6f70000 r-xp 00000000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                 128 kB
                        Pss:                   2 kB
                        Shared_Clean:        128 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:          128 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f7e000-b6f80000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   8 kB
                        Pss:                   8 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         8 kB
                        Referenced:            8 kB
                        Anonymous:             8 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f80000-b6f81000 r--p 00020000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f81000-b6f82000 rw-p 00021000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        becae000-beccf000 rw-p 00000000 00:00 0          [stack]
                        MMUPageSize:           4 kB
                        Rss:                  12 kB
                        Pss:                  12 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:        12 kB
                        Referenced:           12 kB
                        Anonymous:            12 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        bee1e000-bee1f000 r-xp 00000000 00:00 0          [sigpage]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        bee1f000-bee20000 r--p 00000000 00:00 0          [vvar]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd mr de
                        bee20000-bee21000 r-xp 00000000 00:00 0          [vdso]
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   0 kB
                        Shared_Clean:          4 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            4 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        MMUPageSize:           4 kB
                        Rss:                  24 kB
                        Pss:                  24 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Dirty:         0 kB
                        Referenced:           24 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        0161d000-0163e000 rw-p 00000000 00:00 0          [heap]
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b698e000-b69b0000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b69b0000-b6c2a000 r--p 0006b000 b3:02 903        /usr/lib/locale/locale-archive
                        MMUPageSize:           4 kB
                        Rss:                 160 kB
                        Pss:                  88 kB
                        Shared_Clean:        144 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:        16 kB
                        Private_Dirty:         0 kB
                        Referenced:          160 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6c2a000-b6e2a000 r--p 00000000 b3:02 903        /usr/lib/locale/locale-archive
                        MMUPageSize:           4 kB
                        Rss:                 188 kB
                        Pss:                 102 kB
                        Shared_Clean:        172 kB
                        Shared_Dirty:          0 kB
                        Private_Dirty:         0 kB
                        Referenced:          188 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6e2a000-b6f62000 r-xp 00000000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                 784 kB
                        Pss:                  17 kB
                        Shared_Clean:        784 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:          784 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f62000-b6f72000 ---p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6f72000-b6f74000 r--p 00138000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   8 kB
                        Pss:                   8 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         8 kB
                        Referenced:            8 kB
                        Anonymous:             8 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f74000-b6f75000 rw-p 0013a000 b3:02 1375       /lib/arm-linux-gnueabihf/libc-2        .28.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f75000-b6f78000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   8 kB
                        Pss:                   8 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         8 kB
                        Referenced:            8 kB
                        Anonymous:             8 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f78000-b6f7c000 r-xp 00000000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                  16 kB
                        Pss:                   0 kB
                        Shared_Clean:         16 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:           16 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f7c000-b6f8b000 ---p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: mr mw me
                        b6f8b000-b6f8c000 r--p 00003000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f8c000-b6f8d000 rw-p 00004000 b3:02 12187      /usr/lib/arm-linux-gnueabihf/li        barmmem-v7l.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6f8d000-b6fad000 r-xp 00000000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                 128 kB
                        Pss:                   2 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:          128 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6fbb000-b6fbd000 rw-p 00000000 00:00 0
                        MMUPageSize:           4 kB
                        Rss:                   8 kB
                        Pss:                   8 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         8 kB
                        Referenced:            8 kB
                        Anonymous:             8 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6fbd000-b6fbe000 r--p 00020000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        b6fbe000-b6fbf000 rw-p 00021000 b3:02 1353       /lib/arm-linux-gnueabihf/ld-2.2        8.so
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   4 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         4 kB
                        Referenced:            4 kB
                        Anonymous:             4 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        bed84000-beda5000 rw-p 00000000 00:00 0          [stack]
                        MMUPageSize:           4 kB
                        Rss:                  12 kB
                        Pss:                  12 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Referenced:           12 kB
                        Anonymous:            12 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        beddf000-bede0000 r-xp 00000000 00:00 0          [sigpage]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        bede0000-bede1000 r--p 00000000 00:00 0          [vvar]
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        VmFlags: rd mr de
                        bede1000-bede2000 r-xp 00000000 00:00 0          [vdso]
                        MMUPageSize:           4 kB
                        Rss:                   4 kB
                        Pss:                   0 kB
                        Shared_Clean:          4 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            4 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        MMUPageSize:           4 kB
                        Rss:                   0 kB
                        Pss:                   0 kB
                        Shared_Clean:          0 kB
                        Shared_Dirty:          0 kB
                        Private_Clean:         0 kB
                        Private_Dirty:         0 kB
                        Referenced:            0 kB
                        Anonymous:             0 kB
                        LazyFree:              0 kB
                        AnonHugePages:         0 kB
                        FilePmdMapped:         0 kB
                        Swap:                  0 kB
                        SwapPss:               0 kB
                        Locked:                0 kB
                        THPeligible:    0
                        maxpd
                        • M maxpd
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                748 kB
                          SwapPss:             748 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  8 kB
                          SwapPss:               8 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                 12 kB
                          SwapPss:              12 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  8 kB
                          SwapPss:               8 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  8 kB
                          SwapPss:               8 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  4 kB
                          SwapPss:               4 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                 24 kB
                          SwapPss:              24 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: rd mr de
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   0 kB
                          Shared_Clean:          4 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            4 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                  24 kB
                          Pss:                  24 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Dirty:         0 kB
                          Referenced:           24 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 172 kB
                          Pss:                  88 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         4 kB
                          Private_Dirty:         0 kB
                          Referenced:          172 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 248 kB
                          Pss:                 128 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         8 kB
                          Private_Dirty:         0 kB
                          Referenced:          248 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 712 kB
                          Pss:                  15 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:          712 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   8 kB
                          Pss:                   8 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         8 kB
                          Referenced:            8 kB
                          Anonymous:             8 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   8 kB
                          Pss:                   8 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         8 kB
                          Referenced:            8 kB
                          Anonymous:             8 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                  16 kB
                          Pss:                   0 kB
                          Shared_Clean:         16 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:           16 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 128 kB
                          Pss:                   2 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:          128 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   8 kB
                          Pss:                   8 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         8 kB
                          Referenced:            8 kB
                          Anonymous:             8 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                  12 kB
                          Pss:                  12 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Referenced:           12 kB
                          Anonymous:            12 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: rd mr de
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   0 kB
                          Shared_Clean:          4 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            4 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                  24 kB
                          Pss:                  24 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Dirty:         0 kB
                          Referenced:           24 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 160 kB
                          Pss:                  88 kB
                          Shared_Dirty:          0 kB
                          Private_Dirty:         0 kB
                          Referenced:          160 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 188 kB
                          Pss:                 102 kB
                          Shared_Dirty:          0 kB
                          Private_Dirty:         0 kB
                          Referenced:          188 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 784 kB
                          Pss:                  17 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:          784 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   8 kB
                          Pss:                   8 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         8 kB
                          Referenced:            8 kB
                          Anonymous:             8 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   8 kB
                          Pss:                   8 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         8 kB
                          Referenced:            8 kB
                          Anonymous:             8 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                  16 kB
                          Pss:                   0 kB
                          Shared_Clean:         16 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:           16 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: mr mw me
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                 128 kB
                          Pss:                   2 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:          128 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   8 kB
                          Pss:                   8 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         8 kB
                          Referenced:            8 kB
                          Anonymous:             8 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   4 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         4 kB
                          Referenced:            4 kB
                          Anonymous:             4 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                  12 kB
                          Pss:                  12 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Referenced:           12 kB
                          Anonymous:            12 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          VmFlags: rd mr de
                          MMUPageSize:           4 kB
                          Rss:                   4 kB
                          Pss:                   0 kB
                          Shared_Clean:          4 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            4 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          MMUPageSize:           4 kB
                          Rss:                   0 kB
                          Pss:                   0 kB
                          Shared_Clean:          0 kB
                          Shared_Dirty:          0 kB
                          Private_Clean:         0 kB
                          Private_Dirty:         0 kB
                          Referenced:            0 kB
                          Anonymous:             0 kB
                          LazyFree:              0 kB
                          AnonHugePages:         0 kB
                          FilePmdMapped:         0 kB
                          Swap:                  0 kB
                          SwapPss:               0 kB
                          Locked:                0 kB
                          THPeligible:    0
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @maxpd
                          eigentlich nutze ich ja ein bash script - da sieht man das ziemlich deutlich
                          simple und schnell:
                          cd /usr/local/bin
                          nano seeSwap
                          • kopiere das rein
                          #!/bin/bash
                          THRESHOLD=2000
                             fi;
                          drücke ctrl und die x-taste und speichere das ganze
                          anschliessend : chmod +x seeSwap
                          dann kannst du das aufrufen und bei mir sieht das so aus:
                          • M maxpd
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @maxpd
                            Das syslog findest du unter /var/log/syslog
                            Links im Profil
                              @maxpd
                              simple und schnell:
                              cd /usr/local/bin
                              nano seeSwap
                              • kopiere das rein
                              #!/bin/bash
                              THRESHOLD=2000
                                 fi;
                              maxpd
                              @liv-in-sky kannst mir bitte auf die Sprünge helfen? :)
                              maxpd
                              • M maxpd
                                @maxpd
                                ls -l /usr/local/bin/seeSwap
                                  @maxpd
                                  maxpd
                                  @thomas-braun dann bekomme ich nur das raus.
                                  pi@iobroker:~ $ ls -l /usr/local/bin/seeSwap
                                  -rw-r--r-- 1 root root 306 Sep 10 20:35 /usr/local/bin/seeSwap
                                  vllt hab ich das script falsch erstellt. unter dem link stehen dazu keine details. und bei liv-in-sky hab ich das "nano" nicht verstanden. ich bin einfach in den pfad, habe eine datei angelegt, das script reinkopiert und gespeichert.
                                  maxpd
                                  • M maxpd
                                    @maxpd
                                    nano ist ein Editor auf Kommandozeile.
                                    sudo chmod +x /usr/local/bin/seeSwap
                                    Mit welchen Programmen? Irgendwelchem graphischem Kram? Das ist 'verboten' auf einem Server.
                                    M 2 Antworten Letzte Antwort
                                      @maxpd
                                      maxpd
                                      @thomas-braun Mit WinSCP
                                      maxpd
                                        @maxpd
                                        maxpd
                                        @thomas-braun also ob ich die Datei mit winscp oder dem nano erstelle ändert nichts daran, dass keine Ergebnisse ausgeworfen werden:
                                        pi@iobroker:~ $ cd /usr/local/bin
                                        pi@iobroker:/usr/local/bin $ nano seeSwap
                                        pi@iobroker:/usr/local/bin $ sudo nano seeSwap
                                        pi@iobroker:/usr/local/bin $ sudo chmod +x seeSwap
                                        pi@iobroker:/usr/local/bin $ sudo chmod +x /usr/local/bin/seeSwap
                                        pi@iobroker:/usr/local/bin $ ls -l /usr/local/bin/seeSwap
                                        -rwxr-xr-x 1 root root 307 Sep 11 21:57 /usr/local/bin/seeSwap
                                        maxpd
                                        • M maxpd
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @maxpd auch nicht mit sudo seeswap
