  4. Iobroker neu installiert invalid mode
    6.5k
7 Beiträge 3 Kommentatoren 887 Aufrufe 3 Beobachtet
  • E Offline
    Elofix
    ich habe iobroker neu installiert aber bei sämtliche Adaptern
    bekomme ich die Fehlermeldung invalid mode.
    Was mache ich falsch?
    host.raspberrypi
    	2021-09-03 07:43:32.483	error	system.adapter.fritzdect.0 invalid mode
    admin.0
    	2021-09-03 07:42:52.756	error	error
    admin.0
    	2021-09-03 07:42:52.686	error	error
    host.raspberrypi
    	2021-09-03 07:39:40.865	error	system.adapter.vis.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:39.025	error	system.adapter.tr-064.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:38.336	error	system.adapter.sonos.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:37.393	error	system.adapter.net-tools.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:36.106	error	system.adapter.plex.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:35.389	error	system.adapter.javascript.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:34.654	error	system.adapter.jarvis.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:33.502	error	system.adapter.info.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:32.783	error	system.adapter.hue-extended.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:32.146	error	system.adapter.hue.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:31.541	error	system.adapter.history.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:30.914	error	system.adapter.fritzdect.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:39:27.419	error	system.adapter.ping.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:36:37.992	error	system.adapter.hue.0 invalid mode
    host.raspberrypi
    	2021-09-03 07:35:06.546	error	system.adapter.fritzdect.0 invalid mode
    vis.0
    	2021-09-03 07:33:17.657	error	Cannot write file cache.manifest: vis is not an object of type "meta"
    vis.0
    	2021-09-03 07:33:17.632	error	Cannot write file css/vis-common-user.css: vis is not an object of type "meta"
    vis.0
    	2021-09-03 07:33:17.630	error	Cannot write file js/config.js: vis is not an object of type "meta"
    vis.0
    	2021-09-03 07:33:17.464	error	No license found for vis. Please get one on https://iobroker.net !
    • E Elofix
      host.raspberrypi
      admin.0
      admin.0
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      vis.0
      vis.0
      vis.0
      vis.0
      arteckA Offline
      arteckA Offline
      arteck
      @elofix sagte in Iobroker neu installiert invalid mode:
      wie hast du das gemacht ??
      E 1 Antwort Letzte Antwort
      • arteckA arteck
        Elofix
        @arteck neues image mit dem Raspberry imager installiert und dann über die Konsole iobroker mit den angegebenen Befehlen installiert.
        • E Elofix
          arteckA Offline
          arteckA Offline
          arteck
          @elofix nach welcher Anleitung ??
          von hier
          https://www.iobroker.net/#de/download
          • arteckA arteck
            von hier
            Elofix
            @arteck Ja genau so hab ich das gemacht.
            • E Elofix
              GlasfaserG Offline
              GlasfaserG Offline
              host.raspberrypi
              2021-09-03 07:35:06.546 error system.adapter.fritzdect.0 invalid mode...
              vis.0
              .... aber erst nach dem Backup einspielen kam diese Meldungen !?
              • GlasfaserG Glasfaser
                host.raspberrypi
                vis.0
                Elofix
                @glasfaser ich habe kein backup die Meldungen kommen erst wenn ich die Adapter starten will die installiert wurden
