  4. Restore-Fehlermeldung ("Cannot find module '../encodings")
    6.4k
9 Beiträge 3 Kommentatoren 813 Aufrufe 3 Beobachtet
  • I Offline
    I Offline
    IOBaer
    schrieb am zuletzt editiert von IOBaer
    nach einem Backup und anschließendem Restore in einer Neuinstallation (selbes Gerät) erhielt ich ich beim Aufruf des Admin-Adapters folgende Fehlermeldung:
    Error: Cannot find module '../encodings'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/types/json.js
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/index.js
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js
    - /opt/iobroker/node_modules/iobroker.admin/node_modules/express/index.js
    - /opt/iobroker/node_modules/iobroker.admin/lib/web.js
    - /opt/iobroker/node_modules/iobroker.admin/main.js
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
        at Function.Module._load (internal/modules/cjs/loader.js:667:27)
        at Module.require (internal/modules/cjs/loader.js:887:19)
        at require (internal/modules/cjs/helpers.js:74:18)
        at Object.getCodec (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:65:27)
        at Object.getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:127:23)
        at getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:45:18)
        at readStream (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:180:15)
        at getRawBody (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:108:12)
        at read (/opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js:77:3)
    Der Sachverhalt scheint vergleichbar zu sein mit https://forum.iobroker.net/topic/47169/gelöst-hilfe-fehler-nach-restore und https://forum.iobroker.net/topic/45599/cannot-find-module-encodings/6
    Ein "iobroker status" als der Fehler noch bestand brachte:
    Objects type: file
    States  type: file
    Lösung bei mir war der Vorschlag von @Thomas-Braun:
    sudo apt dist-upgrade
    sudo reboot
    Seither kann ich keine Fehler mehr feststellen.
    Kann mir jemand sagen, was hier schief lief? Wie hätte verhindert werden können, dass dieser Fehler auftritt?
    Ich habe den alten ioBroker-Ordner noch, d.h. ich kann jederzeit wieder auf das alte System zurück und z.B. ein erneutes Backup erstellen, falls wir etwas testen wollen.
    ioBroker-Version: 3.3.15
    nodejs-Version: v12.22.5
    npm-Version: 6.14.14
    System läuft unter Hyper-V auf Debian 10.
    Vielen Dank.
    • I IOBaer
      Require stack:
      Objects type: file
      States  type: file
      sudo reboot
      Vielen Dank.
      GlasfaserG Offline
      GlasfaserG Offline
      @iobaer sagte in Restore-Fehlermeldung ("Cannot find module '../encodings"):
      Der Befehl von Thomas bezog sich aber auf:
      >14 packages can be upgraded. Run 'apt list --upgradable' to see them.
      • GlasfaserG Glasfaser
        @glasfaser
        Ich glaube der simple Neustart hat da geholfen.
        • GlasfaserG Offline
          GlasfaserG Offline
          Dann teste mal !
          • I Offline
            I Offline
            IOBaer
            Danke Euch.
            @Glasfaser was genau soll ich testen? Ob ein Neustart genügt? :)
            • I IOBaer
              Danke Euch.
              GlasfaserG Offline
              GlasfaserG Offline
              @iobaer
              ja wenn die Fehlermeldung kommt ,dann
              sudo reboot
              • I Offline
                I Offline
                IOBaer
                @glasfaser Hat tatsächlich das Problem behoben. Meine Neustarts fanden immer nur zuvor statt. Sorry - und vielen Dank an Euch @Glasfaser @Thomas-Braun!
                • I IOBaer
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @iobaer
                  • I Offline
                    I Offline
                    IOBaer
                    Kleines Update, weil ich gerade noch ein Backup/Restore durchführen musste: nun habe ich nach erfolgreichem Restore (10 Minuten, nachdem im Log über die Konsole keine Restore-Aktivität mehr zu sehen war) direkt einen Reboot ausgeführt. Nach dem Anmelden via Browser erschien wieder die oben gezeigte Meldung. Es musste dann erneut (!) ein Reboot durchgeführt werden, damit die Meldung verschwindet.
