<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;)]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">nach einem Backup und anschließendem Restore in einer Neuinstallation (selbes Gerät) erhielt ich ich beim Aufruf des Admin-Adapters folgende Fehlermeldung:</p>
<pre><code>Error: Cannot find module '../encodings'
Require stack:
- /opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js
- /opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js
- /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js
- /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/types/json.js
- /opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/index.js
- /opt/iobroker/node_modules/iobroker.admin/node_modules/express/lib/express.js
- /opt/iobroker/node_modules/iobroker.admin/node_modules/express/index.js
- /opt/iobroker/node_modules/iobroker.admin/lib/web.js
- /opt/iobroker/node_modules/iobroker.admin/main.js
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    at Module.require (internal/modules/cjs/loader.js:887:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at Object.getCodec (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:65:27)
    at Object.getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/iconv-lite/lib/index.js:127:23)
    at getDecoder (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:45:18)
    at readStream (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:180:15)
    at getRawBody (/opt/iobroker/node_modules/iobroker.admin/node_modules/raw-body/index.js:108:12)
    at read (/opt/iobroker/node_modules/iobroker.admin/node_modules/body-parser/lib/read.js:77:3)
</code></pre>
<p dir="auto">Der Sachverhalt scheint vergleichbar zu sein mit <a href="https://forum.iobroker.net/topic/47169/gel%C3%B6st-hilfe-fehler-nach-restore">https://forum.iobroker.net/topic/47169/gelöst-hilfe-fehler-nach-restore</a> und <a href="https://forum.iobroker.net/topic/45599/cannot-find-module-encodings/6">https://forum.iobroker.net/topic/45599/cannot-find-module-encodings/6</a></p>
<p dir="auto">Ein "iobroker status" als der Fehler noch bestand brachte:</p>
<pre><code>iobroker is running on this host.
Objects type: file
States  type: file
</code></pre>
<p dir="auto">Lösung bei mir war der Vorschlag von <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a>:</p>
<pre><code>sudo apt dist-upgrade
sudo reboot
</code></pre>
<p dir="auto">Seither kann ich keine Fehler mehr feststellen.</p>
<p dir="auto">Kann mir jemand sagen, was hier schief lief? Wie hätte verhindert werden können, dass dieser Fehler auftritt?</p>
<p dir="auto">Ich habe den alten ioBroker-Ordner noch, d.h. ich kann jederzeit wieder auf das alte System zurück und z.B. ein erneutes Backup erstellen, falls wir etwas testen wollen.</p>
<p dir="auto">ioBroker-Version: 3.3.15<br />
nodejs-Version: v12.22.5<br />
npm-Version: 6.14.14<br />
System läuft unter Hyper-V auf Debian 10.</p>
<p dir="auto">Vielen Dank.</p>
]]></description><link>https://forum.iobroker.net/topic/47396/restore-fehlermeldung-cannot-find-module-encodings</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 15:58:22 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/47396.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 Aug 2021 18:10:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Thu, 02 Sep 2021 18:29:08 GMT]]></title><description><![CDATA[<p dir="auto">Kleines Update, weil ich gerade noch ein Backup/Restore durchführen musste: nun habe ich nach erfolgreichem Restore (10 Minuten, nachdem im Log über die Konsole keine Restore-Aktivität mehr zu sehen war) direkt einen Reboot ausgeführt. Nach dem Anmelden via Browser erschien wieder die oben gezeigte Meldung. Es musste dann erneut (!) ein Reboot durchgeführt werden, damit die Meldung verschwindet.</p>
]]></description><link>https://forum.iobroker.net/post/673143</link><guid isPermaLink="true">https://forum.iobroker.net/post/673143</guid><dc:creator><![CDATA[IOBaer]]></dc:creator><pubDate>Thu, 02 Sep 2021 18:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 19:11:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iobaer" aria-label="Profile: iobaer">@<bdi>iobaer</bdi></a></p>
<p dir="auto"><img src="/assets/uploads/files/1630177899172-1.jpg" alt="1.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/670970</link><guid isPermaLink="true">https://forum.iobroker.net/post/670970</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sat, 28 Aug 2021 19:11:41 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 19:09:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a> Hat tatsächlich das Problem behoben. Meine Neustarts fanden immer nur zuvor statt. Sorry - und vielen Dank an Euch <a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: Glasfaser">@<bdi>Glasfaser</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a>!</p>
]]></description><link>https://forum.iobroker.net/post/670969</link><guid isPermaLink="true">https://forum.iobroker.net/post/670969</guid><dc:creator><![CDATA[IOBaer]]></dc:creator><pubDate>Sat, 28 Aug 2021 19:09:39 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 19:04:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iobaer" aria-label="Profile: iobaer">@<bdi>iobaer</bdi></a></p>
<p dir="auto">ja wenn die Fehlermeldung kommt  ,dann</p>
<pre><code>sudo reboot
</code></pre>
]]></description><link>https://forum.iobroker.net/post/670965</link><guid isPermaLink="true">https://forum.iobroker.net/post/670965</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sat, 28 Aug 2021 19:04:20 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 18:54:22 GMT]]></title><description><![CDATA[<p dir="auto">Danke Euch.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: Glasfaser">@<bdi>Glasfaser</bdi></a> was genau soll ich testen? Ob ein Neustart genügt? :)</p>
]]></description><link>https://forum.iobroker.net/post/670960</link><guid isPermaLink="true">https://forum.iobroker.net/post/670960</guid><dc:creator><![CDATA[IOBaer]]></dc:creator><pubDate>Sat, 28 Aug 2021 18:54:22 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 18:42:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iobaer" aria-label="Profile: iobaer">@<bdi>iobaer</bdi></a> sagte in <a href="/post/670933">Restore-Fehlermeldung ("Cannot find module '../encodings")</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Dann teste mal !</p>
]]></description><link>https://forum.iobroker.net/post/670956</link><guid isPermaLink="true">https://forum.iobroker.net/post/670956</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sat, 28 Aug 2021 18:42:23 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 18:38:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/glasfaser" aria-label="Profile: glasfaser">@<bdi>glasfaser</bdi></a></p>
<p dir="auto">Ich glaube der simple Neustart hat da geholfen.</p>
]]></description><link>https://forum.iobroker.net/post/670952</link><guid isPermaLink="true">https://forum.iobroker.net/post/670952</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 28 Aug 2021 18:38:56 GMT</pubDate></item><item><title><![CDATA[Reply to Restore-Fehlermeldung (&quot;Cannot find module &#x27;..&#x2F;encodings&quot;) on Sat, 28 Aug 2021 18:29:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iobaer" aria-label="Profile: iobaer">@<bdi>iobaer</bdi></a> sagte in <a href="/post/670933">Restore-Fehlermeldung ("Cannot find module '../encodings")</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Der Befehl von Thomas bezog sich aber auf:</p>
<pre><code>&gt;14 packages can be upgraded. Run 'apt list --upgradable' to see them.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/670947</link><guid isPermaLink="true">https://forum.iobroker.net/post/670947</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Sat, 28 Aug 2021 18:29:17 GMT</pubDate></item></channel></rss>
