  4. Zigbee Adapter geht nicht auf grün
    2.0k
8 Beiträge 5 Kommentatoren 636 Aufrufe 5 Beobachtet
    djsirius
    Moin zusammen,
    ich habe seit gestern das Problem, dass der Zigbee Adapter nicht mehr funktioniert.
    Ich habe nichts verändert.
    Ich habe einen cc2531 Stick.
    Alle Adapter sind uptodate!
    Dieser wird unter Linux auch angezeigt:
    Hier die Fehlermeldung, wenn ich versuche den Adapter neu zu starten:
    zigbee.0
    2021-08-24 09:51:25.727	error	Cannot read property 'getEntries' of null
    zigbee.0
    2021-08-24 09:51:25.725	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0
    2021-08-24 09:51:25.718	error	unhandled promise rejection: Cannot read property 'getEntries' of null
    zigbee.0
    2021-08-24 09:51:25.716	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2021-08-24 09:51:16.913	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    zigbee.0
    2021-08-24 09:48:10.461	error	getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    Kann mir eventuell helfen?
    Vielen Dank.
    djsirius
    AsgothianA GlasfaserG 2 Antworten Letzte Antwort
    • D djsirius
      Moin zusammen,
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      Vielen Dank.
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @djsirius
      Da kann dir nur dann jemand helfen wenn du das vollständige log vom startup des zigbee Adapters postest. Der Fehler den du gepostet hast kommt aus einer Bibliothek die nicht sauber initialisiert wurde weil der Start des Adapters abgebrochen wurde.
      A.
      • AsgothianA Asgothian
        @djsirius
        A.
        djsirius
        schrieb am zuletzt editiert von djsirius
        @asgothian Vielen Dank!
        zigbee.0
        4312	2021-08-24 11:02:51.340	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        4312	2021-08-24 11:02:50.688	debug	Starting zigbee-herdsman...
        zigbee.0
        4312	2021-08-24 11:02:50.686	info	Starting Zigbee npm ...
        zigbee.0
        4312	2021-08-24 11:02:50.679	debug	Using zigbee-herdsman with settings: {"network":{"panID":6755,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"}}
        zigbee.0
        4312	2021-08-24 11:02:50.629	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.15
        zigbee.0
        4246	2021-08-24 11:02:10.759	warn	Got terminate signal. Checking desired PID: 4301 vs own PID 4246
        zigbee.0
        4246	2021-08-24 11:02:10.741	error	Cannot read property 'getEntries' of null
        zigbee.0
        4246	2021-08-24 11:02:10.738	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0
        4246	2021-08-24 11:02:10.732	error	unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0
        4246	2021-08-24 11:02:10.729	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        4246	2021-08-24 11:02:10.724	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        4246	2021-08-24 11:02:10.721	info	terminating
        zigbee.0
        4246	2021-08-24 11:02:10.718	warn	Failed to stop zigbee during startup
        zigbee.0
        4246	2021-08-24 11:02:10.712	info	Zigbee: disabling joining new devices.
        zigbee.0
        4246	2021-08-24 11:02:10.697	info	cleaned everything up...
        zigbee.0
        4246	2021-08-24 11:02:10.692	warn	Got terminate signal. Checking desired PID: 0 vs own PID 4246
        zigbee.0
        4246	2021-08-24 11:01:45.583	info	Installed Version: iobroker.zigbee@1.5.6
        zigbee.0
        4246	2021-08-24 11:01:44.949	debug	Starting zigbee-herdsman...
        zigbee.0
        4246	2021-08-24 11:01:44.947	info	Starting Zigbee npm ...
        zigbee.0
        4246	2021-08-24 11:01:44.940	debug	Using zigbee-herdsman with settings: {"network":{"panID":6755,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[221,221,221,221,221,221,221,221]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"}}
        zigbee.0
        4246	2021-08-24 11:01:44.890	info	starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.3.15
        zigbee.0
        4246	2021-08-24 11:01:44.370	debug	statesDB connected
        zigbee.0
        4246	2021-08-24 11:01:44.368	debug	States connected to redis: 192.168.1.16:9000
        zigbee.0
        4246	2021-08-24 11:01:44.312	debug	States create User PubSub Client
        zigbee.0
        4246	2021-08-24 11:01:44.309	debug	States create System PubSub Client
        zigbee.0
        4246	2021-08-24 11:01:44.293	debug	Redis States: Use Redis connection: 192.168.1.16:9000
        zigbee.0
        4246	2021-08-24 11:01:44.288	debug	objectDB connected
        zigbee.0
        4246	2021-08-24 11:01:44.270	debug	Objects connected to redis: 192.168.1.16:9001
        zigbee.0
        4246	2021-08-24 11:01:44.246	debug	Objects client initialize lua scripts
        zigbee.0
        4246	2021-08-24 11:01:44.244	debug	Objects create User PubSub Client
        zigbee.0
        4246	2021-08-24 11:01:44.241	debug	Objects create System PubSub Client
        zigbee.0
        4246	2021-08-24 11:01:44.231	debug	Objects client ready ... initialize now
        zigbee.0
        4246	2021-08-24 11:01:44.172	debug	Redis Objects: Use Redis connection: 192.168.1.16:9001
        zigbee.0
        4235	2021-08-24 11:01:40.166	warn	Got terminate signal. Checking desired PID: 4246 vs own PID 4235
        zigbee.0
        4235	2021-08-24 11:01:40.152	error	Cannot read property 'error' of undefined
        zigbee.0
        4235	2021-08-24 11:01:40.150	error	TypeError: Cannot read property 'error' of undefined at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:700:22) at Zigbee.emit (events.js:314:20) at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8747:22) at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5539:29) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:234:37) at processImmediate (internal/timers.js:461:21)
        zigbee.0
        4235	2021-08-24 11:01:40.137	error	unhandled promise rejection: Cannot read property 'error' of undefined
        zigbee.0
        4235	2021-08-24 11:01:40.134	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        4235	2021-08-24 11:01:40.124	warn	Got terminate signal. Checking desired PID: 0 vs own PID 4235
        zigbee.0
        4235	2021-08-24 11:01:39.767	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        zigbee.0
        4235	2021-08-24 11:01:39.701	error	adapter disabled
        zigbee.0
        4235	2021-08-24 11:01:39.330	debug	statesDB connected
        zigbee.0
        4235	2021-08-24 11:01:39.328	debug	States connected to redis: 192.168.1.16:9000
        zigbee.0
        4235	2021-08-24 11:01:39.269	debug	States create User PubSub Client
        zigbee.0
        4235	2021-08-24 11:01:39.266	debug	States create System PubSub Client
        zigbee.0
        4235	2021-08-24 11:01:39.249	debug	Redis States: Use Redis connection: 192.168.1.16:9000
        zigbee.0
        4235	2021-08-24 11:01:39.244	debug	objectDB connected
        zigbee.0
        4235	2021-08-24 11:01:39.226	debug	Objects connected to redis: 192.168.1.16:9001
        zigbee.0
        4235	2021-08-24 11:01:39.201	debug	Objects client initialize lua scripts
        zigbee.0
        4235	2021-08-24 11:01:39.199	debug	Objects create User PubSub Client
        zigbee.0
        4235	2021-08-24 11:01:39.197	debug	Objects create System PubSub Client
        zigbee.0
        4235	2021-08-24 11:01:39.193	debug	Objects client ready ... initialize now
        zigbee.0
        4235	2021-08-24 11:01:39.133	debug	Redis Objects: Use Redis connection: 192.168.1.16:9001
        zigbee.0
        1427	2021-08-24 11:01:31.692	error	Cannot read property 'getEntries' of null
        zigbee.0
        1427	2021-08-24 11:01:31.691	error	TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55) at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16) at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31) at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49) at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41) at runMicrotasks (<anonymous>) at processTicksAndRejections (internal/process/task_queues.js:97:5)
        zigbee.0
        1427	2021-08-24 11:01:31.689	error	unhandled promise rejection: Cannot read property 'getEntries' of null
        zigbee.0
        1427	2021-08-24 11:01:31.688	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        1427	2021-08-24 11:01:31.686	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        zigbee.0
        1427	2021-08-24 11:01:31.684	info	terminating
        zigbee.0
        1427	2021-08-24 11:01:31.683	warn	Failed to stop zigbee during startup
        zigbee.0
        1427	2021-08-24 11:01:31.680	info	Zigbee: disabling joining new devices.
        zigbee.0
        1427	2021-08-24 11:01:31.675	info	cleaned everything up...
        zigbee.0
        1427	2021-08-24 11:01:31.673	info	Got terminate signal TERMINATE_YOURSELF
        Reicht das so???
        djsirius
        • D djsirius
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          Reicht das so???
          djsirius
          Moin.
          Kann mir hier keiner Helfen?
          Reicht das Log nicht??
          Vielen Dank!
          djsirius
          • D djsirius
            Moin.
            Vielen Dank!
            mickymM Offline
            mickymM Offline
            mickym
            @djsirius Wenn Du wirklich nichts verändert hast und Du vielleicht nur Deine Maschine runter gefahren hast, dann boote Deine Maschine mehrfach und wenn Du das 3-4 mal gemacht hast und immer noch nicht geht, dann ist vielleicht Dein Stick kaputt gegangen. Wenn er sich plötzlich ohne runterfahren verabschiedet hat, dann ist das evtl. sogar wahrscheinlich, dass Du ein HW Problem hast.
            • KusselinK Offline
              KusselinK Offline
              Kusselin
              zieh den Stick mal raus neustart......dann reinstecken und wieder neustart!
              • D djsirius
                Moin zusammen,
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                Vielen Dank.
                GlasfaserG Offline
                GlasfaserG Offline
                @djsirius sagte in Zigbee Adapter geht nicht auf grün:
                zigbee.0 4235 2021-08-24 11:01:39.767 warn Terminated (NO_ADAPTER_CONFIG_FOUND) :
                Laut Log ,fehlt die Config .
                • GlasfaserG Glasfaser
                  djsirius
                  Vielen Dank für die Tipps. Leider alles ohne Erfolg.
                  Der Stick funktioniert leider auch nicht auf meinem Master. Ich gehe davon aus, dass er kaputt ist.
                  djsirius
