  4. ioBroker: Fernzugriff weg - SOS
    6.5k
fernzugriff iot cloud
47 Beiträge 6 Kommentatoren 3.1k Aufrufe 5 Beobachtet
  • qqolliQ qqolli
    @ilovegym
    Hab den upnp.0 einfach mal angehalten, aber trotzdem immer noch:
    cloud.0
    2021-08-13 11:23:42.441	info	Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
    cloud.0
    2021-08-13 11:23:42.416	info	Connection changed: connect
    cloud.0
    2021-08-13 11:23:42.305	info	Trying to connect as system.user.admin
    cloud.0
    2021-08-13 11:23:42.124	info	Connecting with https://iobroker.pro:10555 with "@pro_xxx"
    cloud.0
    2021-08-13 11:23:41.747	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.4, js-controller: 3.3.15
    cloud.0
    2021-08-13 11:23:37.252	warn	Terminated (-100): Without reason
    cloud.0
    2021-08-13 11:23:27.249	info	Restart adapter by disconnect
    cloud.0
    2021-08-13 11:23:27.248	info	Connection lost
    cloud.0
    2021-08-13 11:23:27.248	info	Connection changed: io client disconnect
    cloud.0
    2021-08-13 11:23:27.246	error	Sending to many events. Account is blocked for 5 minutes. Please restart cloud adapter.
    cloud.0
    2021-08-13 11:23:27.225	info	Connection changed: connect
    cloud.0
    2021-08-13 11:23:27.137	info	Trying to connect as system.user.admin
    cloud.0
    2021-08-13 11:22:57.090	info	Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
    cloud.0
    2021-08-13 11:22:57.064	info	Connection changed: connect
    cloud.0
    2021-08-13 11:22:56.955	info	Trying to connect as system.user.admin
    cloud.0
    2021-08-13 11:22:56.770	info	Connecting with https://iobroker.pro:10555 with "@pro_xxx"
    cloud.0
    2021-08-13 11:22:56.377	info	starting. Version 4.1.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.4, js-controller: 3.3.15
    cloud.0
    2021-08-13 11:22:49.073	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    cloud.0
    2021-08-13 11:22:49.070	info	terminating
    cloud.0
    2021-08-13 11:22:49.068	info	Got terminate signal TERMINATE_YOURSELF
    @qqolli sagte in ioBroker: Fernzugriff weg - SOS:
    So schnell wirst du wohl noch nicht wieder freigeschaltet worden sein
    qqolliQ 1 Antwort Letzte Antwort
      qqolliQ Offline
      qqolliQ Offline
      qqolli
      Na ja, 24 Stunden später nochmal versucht (sollte genug Zeit gewesen sein zum freischalten):
      cloud.0
      2021-08-15 13:38:17.240	error	Cloud says: Too many updates or requests
      cloud.0
      2021-08-15 13:38:17.237	error	Cloud says: Too many updates or requests
      cloud.0
      2021-08-15 13:38:17.235	error	Cloud says: Too many updates or requests
      Und es gibt zumindest in den Protokollen keinen Prozess (mehr), der zu einem Überlauf führen könnte.
      • qqolliQ qqolli
        cloud.0
        cloud.0
        cloud.0
        @qqolli Hast du den Cloud adapter auch mal ein paar Minuten gestoppt, damit wirklich nichts mehr geschickt wird.. ?`?
        Oder ist der die ganze Zeit mitgelaufen??
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          @ilovegym
          Nein, hatte ich nicht gemacht. Mach ich aber gleich mal und berichte dann.
          • qqolliQ qqolli
            @ilovegym
            @qqolli jo, solange dein System dauernd da soviel Zeugs hinballert ist der Account dicht, da hilft nur, schauen, warum das so ist und ob das so sein muss, also Adapter logfiles debuggen und natuerlich erstmal den Account wieder leben lassen.
            Musst halt alle Adapter mal durchgehen, irgendwo scheint was kraeftig viel Traffic zu erzeugen...
              qqolliQ Offline
              qqolliQ Offline
              qqolli
              @ilovegym
              cloud-Adapter stoppen für eine gewisse Zeit brachte leider auch nichts, gleiches Ergebnis.
              Soweit ich in den Logs sehen kann, scheint es keinen Adapter zu geben der viel Traffic generiert. Oder wie könnte ich das am besten rausfinden?
                failed to download new sources
                Kann es sein, dass du einen Knoten in deinem Netzwerk hast?
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                habe es gerade nochmal gemacht:
                pi@ioBroker:~ $ iobroker update -i
                hash unchanged, use cached sources
                update done
                Immerhin sagt er jetzt nicht mehr "failed to download new sources, ...", aber benutzt immer noch cached sources.
                Ist das "ok" und wenn nicht, woran könnte es liegen?
                • qqolliQ qqolli
                  update done
                  Ist das "ok"
                  wenn es nichts neues gibt, ja!
                  • am Pfad
                  • am Netzwerk
                  • an der Installation
                  • am Raspi
                  aber:
                  Die Liste sollte er aber trotzdem bringen
                    Ist das "ok"
                    • am Pfad
                    • am Netzwerk
                    • am Raspi
                    aber:
                    qqolliQ Offline
                    qqolliQ Offline
                    qqolli
                    Ganz verwegen würde ich sagen, da es vorher lief, das ich (ja, ich weiss das sagen sie alle) nichts an den von dir genannten Dingen (Pfad, Netzwerk, ...) geändert habe. Was ich gemacht hatte, war ein Update auf den neuen Admin.
                    Hatte ich schon ein paar Mal gefragt, aber keine Antwort bekommen. Ist das so ok?:
                    Anbei die vollständige Liste:
                    update done
                    Adapter    "admin"         : 5.1.23   , installed 5.1.23
                    Adapter    "alexa2"        : 3.9.3    , installed 3.9.3
                    Adapter    "backitup"      : 2.1.13   , installed 2.1.13
                    Adapter    "bring"         : 1.7.8    , installed 1.7.8
                    Adapter    "bydhvs"        : 1.2.3    , installed 1.2.3
                    Adapter    "cloud"         : 4.1.0    , installed 4.1.0
                    Adapter    "coronavirus-statistics": 0.6.3   , installed 0.7.0-4
                    Adapter    "countdown"     : 1.2.3    , installed 1.2.5
                    Adapter    "daswetter"     : 3.0.7    , installed 3.0.7
                    Adapter    "deconz"        : 1.3.19   , installed 1.3.19
                    Adapter    "devices"       : 1.0.9    , installed 1.0.9
                    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
                    Adapter    "fb-checkpresence": 1.1.7   , installed 1.1.7
                    Adapter    "feiertage"     : 1.0.17   , installed 1.0.23
                    Adapter    "flot"          : 1.10.6   , installed 1.10.6
                    Adapter    "fritzdect"     : 2.1.15   , installed 2.1.15
                    Adapter    "fronius"       : 1.0.5    , installed 1.1.3
                    Adapter    "fullybrowser"  : 2.0.8    , installed 2.0.9
                    Adapter    "history"       : 1.9.13   , installed 1.9.13
                    Adapter    "hm-rega"       : 3.0.29   , installed 3.0.29
                    Adapter    "hm-rpc"        : 1.14.43  , installed 1.14.43
                    Adapter    "ical"          : 1.11.2   , installed 1.11.2
                    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
                    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
                    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
                    Adapter    "influxdb"      : 1.9.5    , installed 1.9.5
                    Adapter    "info"          : 1.9.8    , installed 1.9.8
                    Adapter    "iot"           : 1.8.22   , installed 1.8.22
                    Adapter    "javascript"    : 5.2.8    , installed 5.2.8
                    Controller "js-controller" : 3.3.15   , installed 3.3.15
                    Adapter    "mercedesme"    : 0.0.54   , installed 0.0.54
                    Adapter    "mobile"        : 1.0.1    , installed 1.0.1
                    Adapter    "modbus"        : 3.4.11   , installed 3.4.11
                    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
                    Adapter    "nut"           : 1.5.0    , installed 1.5.0
                    Adapter    "ph803w"        : 1.0.1    , installed 1.0.1
                    Adapter    "ping"          : 1.5.0    , installed 1.5.0
                    Adapter    "pollenflug"    : 1.0.6    , installed 1.0.6
                    Adapter    "pushover"      : 2.0.5    , installed 2.0.5
                    Adapter    "rpi2"          : 1.3.1    , installed 1.3.1
                    Adapter    "sainlogic"     : 0.7.2    , installed 0.6.0 [Updateable]
                    Adapter    "sayit"         : 1.12.3   , installed 1.12.3
                    Adapter    "shelly"        : 4.0.7    , installed 4.0.7
                    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
                    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                    Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
                    Adapter    "sonos"         : 2.1.1    , installed 2.1.1
                    Adapter    "synology"      : 1.0.0    , installed 1.0.0
                    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
                    Adapter    "text2command"  : 2.1.1    , installed 2.1.1
                    Adapter    "tr-064"        : 4.2.14   , installed 4.2.14
                    Adapter    "trashschedule" : 1.2.0    , installed 1.2.0
                    Adapter    "unifi"         : 0.5.10   , installed 0.5.10
                    Adapter    "upnp"          : 1.0.19   , installed 1.0.19
                    Adapter    "vis"           : 1.4.3    , installed 1.4.3
                    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
                    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
                    Adapter    "vis-google-fonts": 0.1.0   , installed 0.1.0
                    Adapter    "vis-hqwidgets" : 1.1.7    , installed 1.1.7
                    Adapter    "vis-icontwo"   : 0.77.0   , installed 0.77.0
                    Adapter    "vis-inventwo"  : 3.0.11   , installed 3.0.11
                    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
                    Adapter    "vis-keyboard"  : 0.0.2    , installed 0.0.2
                    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
                    Adapter    "vis-material-advanced": 1.7.0   , installed 1.7.0
                    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
                    Adapter    "vis-weather"   : 2.5.3    , installed 2.5.3
                    Adapter    "weatherunderground": 3.3.1   , installed 3.3.1
                    Adapter    "web"           : 3.4.7    , installed 3.4.7
                    Adapter    "windows-control": 0.1.5   , installed 0.1.5
                    Adapter    "yahka"         : 0.12.0   , installed 0.13.1
                    Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                    • qqolliQ qqolli
                      update done
                      Super - dann gibt es im Moment nichts neues.
                      Das Problem mit dem gesperrten cloud-Zugriff muss aber andere Gründe haben
                        qqolliQ Offline
                        qqolliQ Offline
                        qqolli
                        Ja, diese Gründe würde ich auch gene wissen :-(
                        So ganz allgemein, woran könnte es liegen das niemand einen Tip geben kann was hier einzustellen ist oder ob es so passt:
                        • qqolliQ qqolli
                          weil das nichts mit dem Problem zu tun hat.
                          Was soll da nicht passen?
                            qqolliQ Offline
                            qqolliQ Offline
                            qqolli
                            Wieso hat das nichts mit dem Problem zu tun?
                            Da ich mich nicht so genau auskenne habe ich ja gefragt, also wieso soll ich dann wissen ob es passt oder nicht?
                            • qqolliQ qqolli
                              das ist doch die Einstellung vom admin, oder?
                              so abgeschnittene Screenshots helfen nicht wirklich!
                                qqolliQ Offline
                                qqolliQ Offline
                                qqolli
                                Wie ich weiter oben bereits geschrieben hatte, ist das die Einstellung des Web-Adapters (Reiter: Haupteinstellungen), nicht die des Admin!
                                Es hilft auch nicht wirklich etwas zu behaupten ohne es wirklich zu wissen, oder?
                                • qqolliQ qqolli
                                  ok - ist zu lange her 😢
                                  oder!
                                  Das ist "eigentlich" alles so ok. Auch für den web.
                                  Natürlich kann man da noch so einiges verändern, sollte aber üblicherweise nicht nötig sein.
                                  Außerdem hast du ja keine Probleme mit dem Cloudzugang wegen deiner Konfiguration, sondern wegen deiner zu häufigen Anfragen (warum auch immer)
                                    oder!
                                    qqolliQ Offline
                                    qqolliQ Offline
                                    qqolli
                                    ja, da hast Du eigentlich recht. Ich hab trotz längerem suchen noch nichts gefunden :-(
                                    Adapterseitig soweit im Protokoll vermerkt, ist z. Zt. kein Adapter mit häufigen anfragen zu erkennen.
                                    Bin echt ein wenig frustriert, da es vorher ja gut lief. Dachte, vielleicht ist ja auch der Speicher "voll", aber der sollte ok sein:
                                    pi@ioBroker:~ $ free -ht
                                    Mem:          3,7Gi       2,8Gi       445Mi       7,0Mi       532Mi       1,4Gi
                                    Swap:          99Mi       2,0Mi        97Mi
                                    Total:        3,8Gi       2,8Gi       542Mi
                                    Na ja, vielleicht hat irgendwer noch eine gute Idee :-)
                                    • qqolliQ qqolli
                                      Zumindest war der reguläre Speicher schon mal knapp, sonst wäre swap nicht angeknabbert.
                                        qqolliQ Offline
                                        qqolliQ Offline
                                        qqolli
                                        Ja, vor ein paar Tagen war der Swap komplett belegt, also 0 free.
                                        Gerade eben sah es wie eben beschrieben aus und ehrlich gesagt, weiß ich nicht warum.
