  4. Vis starten und Viewechsel dauern sehr lange
    2.3k
    4.2k
33 Beiträge 5 Kommentatoren 4.2k Aufrufe 2 Beobachtet
  • F fuso
    @thomas-braun ```
    pi@raspi4VisDisplay:~ $ dmesg -T
    [So Aug 15 15:20:35 2021] Booting Linux on physical CPU 0x0
    [So Aug 15 15:20:35 2021] Linux version 5.10.52-v7l+ (dom@buildbot) (arm-linux-g
    [So Aug 15 15:20:35 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr
    [So Aug 15 15:20:35 2021] CPU: div instructions available: patching division cod
    [So Aug 15 15:20:35 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct
    [So Aug 15 15:20:35 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [So Aug 15 15:20:35 2021] random: fast init done
    [So Aug 15 15:20:35 2021] Memory policy: Data cache writealloc
    [So Aug 15 15:20:35 2021] Reserved memory: created CMA memory pool at 0x00000000
    [So Aug 15 15:20:35 2021] OF: reserved mem: initialized node linux,cma, compatib
    [So Aug 15 15:20:35 2021] Zone ranges:
    [So Aug 15 15:20:35 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [So Aug 15 15:20:35 2021]   Normal   empty
    [So Aug 15 15:20:35 2021]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
    [So Aug 15 15:20:35 2021] Movable zone start for each node
    [So Aug 15 15:20:35 2021] Early memory node ranges
    [So Aug 15 15:20:35 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff
    [So Aug 15 15:20:35 2021]   node   0: [mem 0x0000000040000000-0x000000007fffffff
    [So Aug 15 15:20:35 2021] Initmem setup node 0 [mem 0x0000000000000000-0x0000000
    [So Aug 15 15:20:35 2021] On node 0 totalpages: 504832
    [So Aug 15 15:20:35 2021]   DMA zone: 1728 pages used for memmap
    [So Aug 15 15:20:35 2021]   DMA zone: 0 pages reserved
    [So Aug 15 15:20:35 2021]   DMA zone: 196608 pages, LIFO batch:63
    [So Aug 15 15:20:35 2021]   HighMem zone: 308224 pages, LIFO batch:63
    [So Aug 15 15:20:35 2021] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u819
    [So Aug 15 15:20:35 2021] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
    [So Aug 15 15:20:35 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [So Aug 15 15:20:35 2021] Built 1 zonelists, mobility grouping on.  Total pages:
    [So Aug 15 15:20:35 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 B:8B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0
    [So Aug 15 15:20:35 2021] Kernel parameter elevator= does not have any effect an
                              Please use sysfs to set IO scheduler for individual de
    [So Aug 15 15:20:35 2021] Dentry cache hash table entries: 131072 (order: 7, 524
    [So Aug 15 15:20:35 2021] Inode-cache hash table entries: 65536 (order: 6, 26214
    [So Aug 15 15:20:35 2021] mem auto-init: stack:off, heap alloc:off, heap free:of
    [So Aug 15 15:20:35 2021] software IO TLB: mapped [mem 0x0000000025a00000-0x0000
    [So Aug 15 15:20:35 2021] Memory: 1850028K/2019328K available (10240K kernel cod
    [So Aug 15 15:20:35 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod
    [So Aug 15 15:20:35 2021] ftrace: allocating 34303 entries in 67 pages
    [So Aug 15 15:20:35 2021] ftrace: allocated 67 pages with 3 groups
    [So Aug 15 15:20:35 2021] rcu: Hierarchical RCU implementation.
    [So Aug 15 15:20:35 2021]       Rude variant of Tasks RCU enabled.
    [So Aug 15 15:20:35 2021]       Tracing variant of Tasks RCU enabled.
    [So Aug 15 15:20:35 2021] rcu: RCU calculated value of scheduler-enlistment dela
    [So Aug 15 15:20:35 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [So Aug 15 15:20:35 2021] GIC: Using split EOI/Deactivate mode
    [So Aug 15 15:20:35 2021] random: get_random_bytes called from start_kernel+0x3c
    [So Aug 15 15:20:35 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr
    [So Aug 15 15:20:35 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff
    [So Aug 15 15:20:35 2021] bcm2835: system timer (irq = 25)
    [So Aug 15 15:20:35 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [So Aug 15 15:20:35 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff
    [So Aug 15 15:20:35 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps
    [So Aug 15 15:20:35 2021] Switching to timer-based delay loop, resolution 18ns
    [So Aug 15 15:20:35 2021] Console: colour dummy device 80x30
    [So Aug 15 15:20:35 2021] printk: console [tty1] enabled
    [So Aug 15 15:20:35 2021] Calibrating delay loop (skipped), value calculated usi
    [So Aug 15 15:20:35 2021] pid_max: default: 32768 minimum: 301
    [So Aug 15 15:20:35 2021] LSM: Security Framework initializing
    [So Aug 15 15:20:35 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 b
    [So Aug 15 15:20:35 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8
    [So Aug 15 15:20:35 2021] cgroup: Disabling memory control group subsystem
    [So Aug 15 15:20:35 2021] CPU: Testing write buffer coherency: ok
    [So Aug 15 15:20:35 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [So Aug 15 15:20:35 2021] Setting up static identity map for 0x200000 - 0x20003c
    [So Aug 15 15:20:35 2021] rcu: Hierarchical SRCU implementation.
    [So Aug 15 15:20:35 2021] smp: Bringing up secondary CPUs ...
    [So Aug 15 15:20:35 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [So Aug 15 15:20:35 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [So Aug 15 15:20:35 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [So Aug 15 15:20:35 2021] smp: Brought up 1 node, 4 CPUs
    [So Aug 15 15:20:35 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS)
    [So Aug 15 15:20:35 2021] CPU: All CPU(s) started in HYP mode.
    [So Aug 15 15:20:35 2021] CPU: Virtualization extensions available.
    [So Aug 15 15:20:35 2021] devtmpfs: initialized
    [So Aug 15 15:20:35 2021] VFP support v0.3: implementor 41 architecture 3 part 4
    [So Aug 15 15:20:35 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf
    [So Aug 15 15:20:35 2021] futex hash table entries: 1024 (order: 4, 65536 bytes,
    [So Aug 15 15:20:35 2021] pinctrl core: initialized pinctrl subsystem
    [So Aug 15 15:20:35 2021] NET: Registered protocol family 16
    [So Aug 15 15:20:35 2021] DMA: preallocated 1024 KiB pool for atomic coherent al
    [So Aug 15 15:20:35 2021] audit: initializing netlink subsys (disabled)
    [So Aug 15 15:20:35 2021] audit: type=2000 audit(0.030:1): state=initialized aud
    [So Aug 15 15:20:35 2021] thermal_sys: Registered thermal governor 'step_wise'
    [So Aug 15 15:20:35 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4
    [So Aug 15 15:20:35 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [So Aug 15 15:20:35 2021] Serial: AMBA PL011 UART driver
    [So Aug 15 15:20:35 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [So Aug 15 15:20:35 2021] raspberrypi-firmware soc:firmware: Attached to firmwar
    [So Aug 15 15:20:35 2021] raspberrypi-firmware soc:firmware: Firmware hash is 40
    [So Aug 15 15:20:35 2021] Kprobes globally optimized
    [So Aug 15 15:20:35 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac
    [So Aug 15 15:20:35 2021] vgaarb: loaded
    [So Aug 15 15:20:35 2021] SCSI subsystem initialized
    [So Aug 15 15:20:35 2021] usbcore: registered new interface driver usbfs
    [So Aug 15 15:20:35 2021] usbcore: registered new interface driver hub
    [So Aug 15 15:20:35 2021] usbcore: registered new device driver usb
    [So Aug 15 15:20:35 2021] usb_phy_generic phy: supply vcc not found, using dummy
    [So Aug 15 15:20:35 2021] clocksource: Switched to clocksource arch_sys_counter
    [So Aug 15 15:20:36 2021] VFS: Disk quotas dquot_6.6.0
    [So Aug 15 15:20:36 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 40
    [So Aug 15 15:20:36 2021] FS-Cache: Loaded
    [So Aug 15 15:20:36 2021] CacheFiles: Loaded
    [So Aug 15 15:20:36 2021] NET: Registered protocol family 2
    [So Aug 15 15:20:36 2021] IP idents hash table entries: 16384 (order: 5, 131072
    [So Aug 15 15:20:36 2021] tcp_listen_portaddr_hash hash table entries: 512 (orde
    [So Aug 15 15:20:36 2021] TCP established hash table entries: 8192 (order: 3, 32
    [So Aug 15 15:20:36 2021] TCP bind hash table entries: 8192 (order: 4, 65536 byt
    [So Aug 15 15:20:36 2021] TCP: Hash tables configured (established 8192 bind 819
    [So Aug 15 15:20:36 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, li
    [So Aug 15 15:20:36 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byte
    [So Aug 15 15:20:36 2021] NET: Registered protocol family 1
    [So Aug 15 15:20:36 2021] RPC: Registered named UNIX socket transport module.
    [So Aug 15 15:20:36 2021] RPC: Registered udp transport module.
    [So Aug 15 15:20:36 2021] RPC: Registered tcp transport module.
    [So Aug 15 15:20:36 2021] RPC: Registered tcp NFSv4.1 backchannel transport modu
    [So Aug 15 15:20:36 2021] PCI: CLS 0 bytes, default 64
    [So Aug 15 15:20:36 2021] Initialise system trusted keyrings
    [So Aug 15 15:20:36 2021] workingset: timestamp_bits=14 max_order=19 bucket_orde
    [So Aug 15 15:20:36 2021] zbud: loaded
    [So Aug 15 15:20:36 2021] FS-Cache: Netfs 'nfs' registered for caching
    [So Aug 15 15:20:36 2021] NFS: Registering the id_resolver key type
    [So Aug 15 15:20:36 2021] Key type id_resolver registered
    [So Aug 15 15:20:36 2021] Key type id_legacy registered
    [So Aug 15 15:20:36 2021] nfs4filelayout_init: NFSv4 File Layout Driver Register
    [So Aug 15 15:20:36 2021] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver
    [So Aug 15 15:20:36 2021] Key type asymmetric registered
    [So Aug 15 15:20:36 2021] Asymmetric key parser 'x509' registered
    [So Aug 15 15:20:36 2021] bounce: pool size: 64 pages
    [So Aug 15 15:20:36 2021] Block layer SCSI generic (bsg) driver version 0.4 load
    [So Aug 15 15:20:36 2021] io scheduler mq-deadline registered
    [So Aug 15 15:20:36 2021] io scheduler kyber registered
    [So Aug 15 15:20:36 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000
    [So Aug 15 15:20:36 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb
    [So Aug 15 15:20:36 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063f
    [So Aug 15 15:20:36 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007f
    [So Aug 15 15:20:36 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS
    [So Aug 15 15:20:36 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0
    [So Aug 15 15:20:36 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [So Aug 15 15:20:36 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x
    [So Aug 15 15:20:36 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [So Aug 15 15:20:36 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [So Aug 15 15:20:36 2021] PCI: bus0: Fast back to back transfers disabled
    [So Aug 15 15:20:36 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [So Aug 15 15:20:36 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff
    [So Aug 15 15:20:36 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
    [So Aug 15 15:20:36 2021] PCI: bus1: Fast back to back transfers disabled
    [So Aug 15 15:20:36 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6
    [So Aug 15 15:20:36 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6
    [So Aug 15 15:20:36 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [So Aug 15 15:20:36 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6
    [So Aug 15 15:20:36 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [So Aug 15 15:20:36 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
    [So Aug 15 15:20:36 2021] bcm2708_fb soc:fb: FB found 1 display(s)
    [So Aug 15 15:20:36 2021] Console: switching to colour frame buffer device 160x5
    [So Aug 15 15:20:36 2021] bcm2708_fb soc:fb: Registered framebuffer for display
    [So Aug 15 15:20:36 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enable
    [So Aug 15 15:20:36 2021] bcm2835-aux-uart fe215040.serial: there is not valid m
    [So Aug 15 15:20:36 2021] iproc-rng200 fe104000.rng: hwrng registered
    [So Aug 15 15:20:36 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_s
    [So Aug 15 15:20:36 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe
    [So Aug 15 15:20:36 2021] brd: module loaded
    [So Aug 15 15:20:36 2021] loop: module loaded
    [So Aug 15 15:20:36 2021] Loading iSCSI transport class v2.0-870.
    [So Aug 15 15:20:36 2021] libphy: Fixed MDIO Bus: probed
    [So Aug 15 15:20:36 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [So Aug 15 15:20:36 2021] libphy: bcmgenet MII bus: probed
    [So Aug 15 15:20:36 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [So Aug 15 15:20:36 2021] usbcore: registered new interface driver r8152
    [So Aug 15 15:20:36 2021] usbcore: registered new interface driver lan78xx
    [So Aug 15 15:20:36 2021] usbcore: registered new interface driver smsc95xx
    [So Aug 15 15:20:36 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [So Aug 15 15:20:36 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [So Aug 15 15:20:36 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigne
    [So Aug 15 15:20:36 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi
    [So Aug 15 15:20:36 2021] usb usb1: New USB device found, idVendor=1d6b, idProdu
    [So Aug 15 15:20:36 2021] usb usb1: New USB device strings: Mfr=3, Product=2, Se
    [So Aug 15 15:20:36 2021] usb usb1: Product: xHCI Host Controller
    [So Aug 15 15:20:36 2021] usb usb1: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
    [So Aug 15 15:20:36 2021] usb usb1: SerialNumber: 0000:01:00.0
    [So Aug 15 15:20:36 2021] hub 1-0:1.0: USB hub found
    [So Aug 15 15:20:36 2021] hub 1-0:1.0: 1 port detected
    [So Aug 15 15:20:36 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee
    [So Aug 15 15:20:36 2021] usb usb2: New USB device found, idVendor=1d6b, idProdu
    [So Aug 15 15:20:36 2021] usb usb2: New USB device strings: Mfr=3, Product=2, Se
    [So Aug 15 15:20:36 2021] usb usb2: Product: xHCI Host Controller
    [So Aug 15 15:20:36 2021] usb usb2: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
    [So Aug 15 15:20:36 2021] usb usb2: SerialNumber: 0000:01:00.0
    [So Aug 15 15:20:36 2021] hub 2-0:1.0: USB hub found
    [So Aug 15 15:20:36 2021] hub 2-0:1.0: 4 ports detected
    [So Aug 15 15:20:36 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [So Aug 15 15:20:36 2021] dwc_otg: FIQ enabled
    [So Aug 15 15:20:36 2021] dwc_otg: NAK holdoff enabled
    [So Aug 15 15:20:36 2021] dwc_otg: FIQ split-transaction FSM enabled
    [So Aug 15 15:20:36 2021] Module dwc_common_port init
    [So Aug 15 15:20:36 2021] usbcore: registered new interface driver uas
    [So Aug 15 15:20:36 2021] usbcore: registered new interface driver usb-storage
    [So Aug 15 15:20:36 2021] mousedev: PS/2 mouse device common for all mice
    [So Aug 15 15:20:36 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim
    [So Aug 15 15:20:36 2021] sdhci: Secure Digital Host Controller Interface driver
    [So Aug 15 15:20:36 2021] sdhci: Copyright(c) Pierre Ossman
    [So Aug 15 15:20:36 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri
    [So Aug 15 15:20:36 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [So Aug 15 15:20:36 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [So Aug 15 15:20:36 2021] hid: raw HID events driver (C) Jiri Kosina
    [So Aug 15 15:20:36 2021] usbcore: registered new interface driver usbhid
    [So Aug 15 15:20:36 2021] usbhid: USB HID core driver
    [So Aug 15 15:20:36 2021] Initializing XFRM netlink socket
    [So Aug 15 15:20:36 2021] NET: Registered protocol family 17
    [So Aug 15 15:20:36 2021] Key type dns_resolver registered
    [So Aug 15 15:20:36 2021] Registering SWP/SWPB emulation handler
    [So Aug 15 15:20:36 2021] registered taskstats version 1
    [So Aug 15 15:20:36 2021] Loading compiled-in X.509 certificates
    [So Aug 15 15:20:36 2021] Key type ._fscrypt registered
    [So Aug 15 15:20:36 2021] Key type .fscrypt registered
    [So Aug 15 15:20:36 2021] Key type fscrypt-provisioning registered
    [So Aug 15 15:20:36 2021] uart-pl011 fe201000.serial: there is not valid maps fo
    [So Aug 15 15:20:36 2021] uart-pl011 fe201000.serial: cts_event_workaround enabl
    [So Aug 15 15:20:36 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36,
    [So Aug 15 15:20:36 2021] printk: console [ttyS0] disabled
    [So Aug 15 15:20:36 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 38, b
    [So Aug 15 15:20:37 2021] printk: console [ttyS0] enabled
    [So Aug 15 15:20:37 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power do
    [So Aug 15 15:20:37 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [So Aug 15 15:20:37 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [So Aug 15 15:20:37 2021] of_cfs_init
    [So Aug 15 15:20:37 2021] of_cfs_init: OK
    [So Aug 15 15:20:37 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [So Aug 15 15:20:37 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [So Aug 15 15:20:37 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emm
    [So Aug 15 15:20:37 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [So Aug 15 15:20:37 2021] Waiting for root device /dev/mmcblk0p2...
    [So Aug 15 15:20:38 2021] usb 1-1: new high-speed USB device number 2 using xhci
    [So Aug 15 15:20:38 2021] mmc1: new high speed SDIO card at address 0001
    [So Aug 15 15:20:38 2021] mmc0: new ultra high speed DDR50 SDXC card at address
    [So Aug 15 15:20:38 2021] mmcblk0: mmc0:aaaa SB64G 59.5 GiB
    [So Aug 15 15:20:38 2021]  mmcblk0: p1 p2
    [So Aug 15 15:20:38 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered d
    [So Aug 15 15:20:38 2021] VFS: Mounted root (ext4 filesystem) readonly on device
    [So Aug 15 15:20:38 2021] devtmpfs: mounted
    [So Aug 15 15:20:38 2021] Freeing unused kernel memory: 2048K
    [So Aug 15 15:20:38 2021] Run /sbin/init as init process
    [So Aug 15 15:20:38 2021] usb 1-1: New USB device found, idVendor=2109, idProduc
    [So Aug 15 15:20:38 2021]   with arguments:
    [So Aug 15 15:20:38 2021]     /sbin/init
    [So Aug 15 15:20:38 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser
    [So Aug 15 15:20:38 2021]   with environment:
    [So Aug 15 15:20:38 2021] usb 1-1: Product: USB2.0 Hub
    [So Aug 15 15:20:38 2021]     HOME=/
    [So Aug 15 15:20:38 2021]     TERM=linux
    [So Aug 15 15:20:38 2021] hub 1-1:1.0: USB hub found
    [So Aug 15 15:20:38 2021] hub 1-1:1.0: 4 ports detected
    [So Aug 15 15:20:38 2021] usb 1-1.1: new high-speed USB device number 3 using xh
    [So Aug 15 15:20:38 2021] usb 1-1.1: New USB device found, idVendor=0781, idProd
    [So Aug 15 15:20:38 2021] usb 1-1.1: New USB device strings: Mfr=1, Product=2, S
    [So Aug 15 15:20:38 2021] usb 1-1.1: Product: Cruzer Blade
    [So Aug 15 15:20:38 2021] usb 1-1.1: Manufacturer: SanDisk
    [So Aug 15 15:20:38 2021] usb 1-1.1: SerialNumber: 4C530000010912120044
    [So Aug 15 15:20:38 2021] usb-storage 1-1.1:1.0: USB Mass Storage device detecte
    [So Aug 15 15:20:38 2021] scsi host0: usb-storage 1-1.1:1.0
    [So Aug 15 15:20:38 2021] systemd[1]: System time before build time, advancing c
    [So Aug 15 15:20:38 2021] usb 1-1.2: new high-speed USB device number 4 using xh
    [So Aug 15 15:20:39 2021] NET: Registered protocol family 10
    [So Aug 15 15:20:39 2021] Segment Routing with IPv6
    [So Aug 15 15:20:39 2021] usb 1-1.2: New USB device found, idVendor=1a40, idProd
    [So Aug 15 15:20:39 2021] usb 1-1.2: New USB device strings: Mfr=0, Product=1, S
    [So Aug 15 15:20:39 2021] usb 1-1.2: Product: USB 2.0 Hub
    [So Aug 15 15:20:39 2021] hub 1-1.2:1.0: USB hub found
    [So Aug 15 15:20:39 2021] hub 1-1.2:1.0: 4 ports detected
    [So Aug 15 15:20:39 2021] systemd[1]: systemd 241 running in system mode. (+PAM hierarchy=hybrid)
    [So Aug 15 15:20:39 2021] systemd[1]: Detected architecture arm.
    [So Aug 15 15:20:39 2021] usb 1-1.3: new low-speed USB device number 5 using xhc
    [So Aug 15 15:20:39 2021] systemd[1]: Set hostname to <raspi4VisDisplay>.
    [So Aug 15 15:20:39 2021] usb 1-1.3: New USB device found, idVendor=0603, idProd
    [So Aug 15 15:20:39 2021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, S
    [So Aug 15 15:20:39 2021] usb 1-1.3: Product: USB Composite Device
    [So Aug 15 15:20:39 2021] usb 1-1.3: Manufacturer: SINO WEALTH
    [So Aug 15 15:20:39 2021] input: SINO WEALTH USB Composite Device as /devices/pl
    [So Aug 15 15:20:39 2021] hid-generic 0003:0603:0002.0001: input,hidraw0: USB HI
    [So Aug 15 15:20:39 2021] input: SINO WEALTH USB Composite Device Mouse as /devi
    [So Aug 15 15:20:39 2021] input: SINO WEALTH USB Composite Device System Control
    [So Aug 15 15:20:39 2021] usb 1-1.2.4: new full-speed USB device number 6 using
    [So Aug 15 15:20:39 2021] input: SINO WEALTH USB Composite Device Consumer Contr
    [So Aug 15 15:20:39 2021] hid-generic 0003:0603:0002.0002: input,hiddev96,hidraw
    [So Aug 15 15:20:39 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade
    [So Aug 15 15:20:39 2021] usb 1-1.2.4: New USB device found, idVendor=222a, idPr
    [So Aug 15 15:20:39 2021] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2,
    [So Aug 15 15:20:39 2021] usb 1-1.2.4: Product: Multi-Touch-V3000
    [So Aug 15 15:20:39 2021] usb 1-1.2.4: Manufacturer: ILITEK
    [So Aug 15 15:20:39 2021] input: ILITEK Multi-Touch-V3000 as /devices/platform/s
    [So Aug 15 15:20:39 2021] hid-generic 0003:222A:0001.0003: input,hidraw2: USB HI
    [So Aug 15 15:20:39 2021] input: ILITEK Multi-Touch-V3000 Mouse as /devices/plat
    [So Aug 15 15:20:39 2021] hid-generic 0003:222A:0001.0004: input,hiddev97,hidraw
    [So Aug 15 15:20:40 2021] systemd[1]: /etc/systemd/system/teamviewerd.service:8:.
    [So Aug 15 15:20:40 2021] random: systemd: uninitialized urandom read (16 bytes
    [So Aug 15 15:20:40 2021] systemd[1]: Set up automount Arbitrary Executable File
    [So Aug 15 15:20:40 2021] systemd[1]: Listening on udev Control Socket.
    [So Aug 15 15:20:40 2021] systemd[1]: Listening on Syslog Socket.
    [So Aug 15 15:20:40 2021] systemd[1]: Listening on initctl Compatibility Named P
    [So Aug 15 15:20:40 2021] systemd[1]: Created slice system-systemd\x2dfsck.slice
    [So Aug 15 15:20:40 2021] systemd[1]: Created slice system-serial\x2dgetty.slice
    [So Aug 15 15:20:40 2021] i2c /dev entries driver
    [So Aug 15 15:20:41 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [So Aug 15 15:20:41 2021] systemd-journald[136]: Received request to flush runti
    [So Aug 15 15:20:42 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi
    [So Aug 15 15:20:42 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem
    [So Aug 15 15:20:42 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi
    [So Aug 15 15:20:42 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial
    [So Aug 15 15:20:42 2021] mc: Linux media interface: v0.10
    [So Aug 15 15:20:42 2021] videodev: Linux video capture interface: v2.00
    [So Aug 15 15:20:42 2021] vc_sm_cma: module is from the staging directory, the q
    [So Aug 15 15:20:42 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory drive
    [So Aug 15 15:20:42 2021] [vc_sm_connected_init]: start
    [So Aug 15 15:20:42 2021] [vc_sm_connected_init]: installed successfully
    [So Aug 15 15:20:42 2021] bcm2835_mmal_vchiq: module is from the staging directo
    [So Aug 15 15:20:42 2021] bcm2835_isp: module is from the staging directory, the
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Device node output[0] registe
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regist
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regist
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Device node stats[2] register
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Register output node 0 with m
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with
    [So Aug 15 15:20:42 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [So Aug 15 15:20:42 2021] snd_bcm2835: module is from the staging directory, the
    [So Aug 15 15:20:42 2021] bcm2835_audio bcm2835_audio: card created with 4 chann
    [So Aug 15 15:20:42 2021] bcm2835_v4l2: module is from the staging directory, th
    [So Aug 15 15:20:42 2021] bcm2835_codec: module is from the staging directory, t
    [So Aug 15 15:20:42 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [So Aug 15 15:20:42 2021] bcm2835-codec bcm2835-codec: Device registered as /dev
    [So Aug 15 15:20:42 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [So Aug 15 15:20:42 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [So Aug 15 15:20:42 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [So Aug 15 15:20:42 2021] cfg80211: Loading compiled-in X.509 certificates for r
    [So Aug 15 15:20:42 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c
    [So Aug 15 15:20:43 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
    [So Aug 15 15:20:43 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4
    [So Aug 15 15:20:43 2021] usbcore: registered new interface driver brcmfmac
    [So Aug 15 15:20:43 2021] input: ILITEK Multi-Touch-V3000 as /devices/platform/s
    [So Aug 15 15:20:43 2021] hid-multitouch 0003:222A:0001.0003: input,hidraw2: USB
    [So Aug 15 15:20:43 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 w
    [So Aug 15 15:20:44 2021] ads7846 spi0.1: supply vcc not found, using dummy regu
    [So Aug 15 15:20:44 2021] ads7846 spi0.1: touchscreen, irq 65
    [So Aug 15 15:20:44 2021] input: ADS7846 Touchscreen as /devices/platform/soc/fe
    [So Aug 15 15:21:10 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:21:10 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:21:10 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:21:40 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:21:40 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:21:40 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:21:41 2021] sd 0:0:0:0: [sda] 30605312 512-byte logical blocks: (1
    [So Aug 15 15:22:10 2021] random: crng init done
    [So Aug 15 15:22:10 2021] random: 7 urandom warning(s) missed due to ratelimitin
    [So Aug 15 15:22:11 2021] uart-pl011 fe201000.serial: no DMA platform data
    [So Aug 15 15:22:11 2021] Bluetooth: Core ver 2.22
    [So Aug 15 15:22:11 2021] NET: Registered protocol family 31
    [So Aug 15 15:22:11 2021] Bluetooth: HCI device and connection manager initializ
    [So Aug 15 15:22:11 2021] Bluetooth: HCI socket layer initialized
    [So Aug 15 15:22:11 2021] Bluetooth: L2CAP socket layer initialized
    [So Aug 15 15:22:11 2021] Bluetooth: SCO socket layer initialized
    [So Aug 15 15:22:11 2021] Bluetooth: HCI UART driver ver 2.3
    [So Aug 15 15:22:11 2021] Bluetooth: HCI UART protocol H4 registered
    [So Aug 15 15:22:11 2021] Bluetooth: HCI UART protocol Three-wire (H5) registere
    [So Aug 15 15:22:11 2021] Bluetooth: HCI UART protocol Broadcom registered
    [So Aug 15 15:22:11 2021] 8021q: 802.1Q VLAN Support v1.8
    [So Aug 15 15:22:11 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:22:11 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:22:11 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:22:11 2021] sd 0:0:0:0: [sda] Write Protect is off
    [So Aug 15 15:22:11 2021] sd 0:0:0:0: [sda] Mode Sense: 00 00 00 00
    [So Aug 15 15:22:11 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents
    [So Aug 15 15:22:12 2021] bcmgenet fd580000.ethernet: configuring instance for e
    [So Aug 15 15:22:12 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [So Aug 15 15:22:12 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [So Aug 15 15:22:12 2021] Bluetooth: BNEP filters: protocol multicast
    [So Aug 15 15:22:12 2021] Bluetooth: BNEP socket layer initialized
    [So Aug 15 15:22:12 2021] Bluetooth: RFCOMM TTY layer initialized
    [So Aug 15 15:22:12 2021] Bluetooth: RFCOMM socket layer initialized
    [So Aug 15 15:22:12 2021] Bluetooth: RFCOMM ver 1.11
    [So Aug 15 15:22:16 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu
    [So Aug 15 15:22:16 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read
    [So Aug 15 15:22:17 2021] fuse: init (API version 7.32)
    [So Aug 15 15:22:17 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (s
    [So Aug 15 15:22:42 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:22:42 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:22:42 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:22:42 2021] sd 0:0:0:0: [sda] Asking for cache data failed
    [So Aug 15 15:22:42 2021] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [So Aug 15 15:23:12 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:23:12 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:23:13 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:23:43 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:23:43 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:23:43 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:24:14 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:24:14 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:24:14 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:24:45 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:24:45 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:24:45 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:24:45 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [So Aug 15 15:25:15 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:25:15 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:25:15 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:25:46 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:25:46 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:25:46 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:25:56 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:25:56 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:25:56 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:26:27 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:26:27 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:26:27 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:26:37 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:26:37 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:26:37 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:27:08 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:27:08 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:27:08 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:27:39 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:27:39 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:27:39 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:28:09 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:28:09 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:28:09 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:28:42 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:28:42 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:28:42 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:29:15 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:29:15 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:29:15 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:29:47 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:29:47 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:29:47 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:30:20 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:30:20 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:30:20 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:30:53 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:30:53 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:30:53 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:31:25 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:31:25 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:31:25 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:31:58 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:31:58 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:31:58 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:32:31 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:32:31 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:32:31 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:33:03 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:33:03 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:33:03 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:33:36 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:33:36 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:33:36 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:34:08 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:34:08 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:34:09 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:34:41 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:34:41 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:34:41 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:35:14 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:35:14 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:35:14 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:35:46 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:35:46 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:35:46 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:36:19 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:36:19 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:36:19 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:36:52 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:36:52 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:36:52 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:37:24 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:37:24 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:37:24 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:37:57 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:37:57 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:37:57 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:38:30 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:38:30 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:38:30 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:39:02 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:39:02 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:39:02 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:39:35 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:39:35 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:39:35 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:40:07 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:40:07 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:40:08 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:40:40 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:40:40 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:40:40 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:41:13 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:41:13 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:41:13 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:41:45 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:41:45 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:41:46 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:42:18 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:42:18 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:42:18 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:42:51 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:42:51 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:42:51 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:43:23 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:43:23 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:43:23 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:43:56 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:43:56 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:43:56 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:44:29 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:44:29 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:44:29 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:45:01 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:45:01 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:45:01 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:45:34 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:45:34 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:45:34 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:46:07 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:46:07 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:46:07 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:46:39 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:46:39 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:46:39 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:47:12 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:47:12 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:47:12 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:47:44 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:47:44 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:47:45 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:48:17 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:48:17 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:48:17 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:48:50 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:48:50 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:48:50 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:49:22 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:49:22 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:49:22 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:49:55 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:49:55 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:49:55 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:50:28 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:50:28 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:50:28 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:51:00 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:51:00 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:51:00 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:51:33 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:51:33 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:51:33 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:52:06 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:52:06 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:52:06 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:52:38 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:52:38 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:52:38 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:53:11 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:53:11 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:53:11 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:53:44 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:53:44 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:53:44 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:54:16 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:54:16 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:54:16 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:54:49 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:54:49 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:54:49 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:55:21 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:55:21 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:55:22 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:55:54 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:55:54 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:55:54 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:56:27 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:56:27 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:56:27 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:56:59 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:56:59 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:56:59 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:57:32 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:57:32 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:57:32 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:58:05 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:58:05 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:58:05 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:58:37 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:58:37 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:58:37 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:59:10 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:59:10 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:59:10 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 15:59:43 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 15:59:43 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 15:59:43 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:00:15 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:00:15 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:00:15 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:00:48 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:00:48 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:00:48 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:01:20 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:01:20 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:01:21 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:01:53 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:01:53 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:01:53 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:02:26 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:02:26 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:02:26 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:02:58 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:02:58 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:02:59 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:03:31 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:03:31 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:03:31 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:04:04 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:04:04 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:04:04 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:04:36 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:04:36 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:04:36 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:05:09 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:05:09 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:05:09 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:05:42 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:05:42 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:05:42 2021] usb 1-1.1: reset high-speed USB device number 3 using
    [So Aug 15 16:06:14 2021] xhci_hcd 0000:01:00.0: WARN Cannot submit Set TR Deq P
    [So Aug 15 16:06:14 2021] xhci_hcd 0000:01:00.0: A Set TR Deq Ptr command is pen
    [So Aug 15 16:06:14 2021] usb 1-1.1: reset high-speed USB device number 3 using
    @fuso Die Zeilen sind abgeschnitten.
    Jedenfalls spinnt da dieses USB-Gerät herum.
    Schmeiß es raus, wenn es nicht gerade ein internes ist.
    Wenn es ein USB3-Port ist: Steck das dortige Gerät an einen USB 2-Port.
    F 2 Antworten Letzte Antwort
      fuso
      habe einen USB für swap stecken und so ein blödes Bluethoot Teil für die Tatstatur. Habe das Keyboard tool mal entfernt, bootet nun.
      • F fuso
        @fuso
        Warum ein USB-Stick für Swap? Macht ja wenig bis gar keinen Sinn.
        F 1 Antwort Letzte Antwort
          fuso
          So, fertig. Hab nochmal ein log da.
          View ist immer noch am starten.
          [So Aug 15 16:36:21 2021] Booting Linux on physical CPU 0x0
          [So Aug 15 16:36:21 2021] Linux version 5.10.52-v7l+ (dom@buildbot) (arm-linux-gnueabihf-        gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1441        SMP Tue Aug 3 18:11:56 BST 2021
          [So Aug 15 16:36:21 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
          [So Aug 15 16:36:21 2021] CPU: div instructions available: patching division code
          [So Aug 15 16:36:21 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
          [So Aug 15 16:36:21 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
          [So Aug 15 16:36:21 2021] random: fast init done
          [So Aug 15 16:36:21 2021] Memory policy: Data cache writealloc
          [So Aug 15 16:36:21 2021] Reserved memory: created CMA memory pool at 0x000000002ac00000,        size 64 MiB
          [So Aug 15 16:36:21 2021] OF: reserved mem: initialized node linux,cma, compatible id sha        red-dma-pool
          [So Aug 15 16:36:21 2021] Zone ranges:
          [So Aug 15 16:36:21 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
          [So Aug 15 16:36:21 2021]   Normal   empty
          [So Aug 15 16:36:21 2021]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
          [So Aug 15 16:36:21 2021] Movable zone start for each node
          [So Aug 15 16:36:21 2021] Early memory node ranges
          [So Aug 15 16:36:21 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
          [So Aug 15 16:36:21 2021]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
          [So Aug 15 16:36:21 2021] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff        ]
          [So Aug 15 16:36:21 2021] On node 0 totalpages: 504832
          [So Aug 15 16:36:21 2021]   DMA zone: 1728 pages used for memmap
          [So Aug 15 16:36:21 2021]   DMA zone: 0 pages reserved
          [So Aug 15 16:36:21 2021]   DMA zone: 196608 pages, LIFO batch:63
          [So Aug 15 16:36:21 2021]   HighMem zone: 308224 pages, LIFO batch:63
          [So Aug 15 16:36:21 2021] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920
          [So Aug 15 16:36:21 2021] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
          [So Aug 15 16:36:21 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [So Aug 15 16:36:21 2021] Built 1 zonelists, mobility grouping on.  Total pages: 503104
          [So Aug 15 16:36:21 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm28        35.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbhe        ight=800 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:28:5B:8B vc_mem.mem_base=0x3ec0000        0 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root        =/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait fbcon=map:10 fbcon=font:ProFon        t6x11 logo.nologo
          [So Aug 15 16:36:21 2021] Kernel parameter elevator= does not have any effect anymore.
                                    Please use sysfs to set IO scheduler for individual devices.
          [So Aug 15 16:36:21 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes        , linear)
          [So Aug 15 16:36:21 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes,        linear)
          [So Aug 15 16:36:21 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
          [So Aug 15 16:36:21 2021] software IO TLB: mapped [mem 0x0000000025a00000-0x0000000029a00        000] (64MB)
          [So Aug 15 16:36:21 2021] Memory: 1850028K/2019328K available (10240K kernel code, 1364K        rwdata, 3188K rodata, 2048K init, 891K bss, 103764K reserved, 65536K cma-reserved, 123289        6K highmem)
          [So Aug 15 16:36:21 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [So Aug 15 16:36:21 2021] ftrace: allocating 34303 entries in 67 pages
          [So Aug 15 16:36:21 2021] ftrace: allocated 67 pages with 3 groups
          [So Aug 15 16:36:21 2021] rcu: Hierarchical RCU implementation.
          [So Aug 15 16:36:21 2021]       Rude variant of Tasks RCU enabled.
          [So Aug 15 16:36:21 2021]       Tracing variant of Tasks RCU enabled.
          [So Aug 15 16:36:21 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 j        iffies.
          [So Aug 15 16:36:21 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
          [So Aug 15 16:36:21 2021] GIC: Using split EOI/Deactivate mode
          [So Aug 15 16:36:21 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c w        ith crng_init=1
          [So Aug 15 16:36:21 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every        2147483647500ns
          [So Aug 15 16:36:21 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 1911260446275 ns
          [So Aug 15 16:36:21 2021] bcm2835: system timer (irq = 25)
          [So Aug 15 16:36:21 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [So Aug 15 16:36:21 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycle        s: 0xc743ce346, max_idle_ns: 440795203123 ns
          [So Aug 15 16:36:21 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 439        8046511102ns
          [So Aug 15 16:36:21 2021] Switching to timer-based delay loop, resolution 18ns
          [So Aug 15 16:36:21 2021] Console: colour dummy device 80x30
          [So Aug 15 16:36:21 2021] printk: console [tty1] enabled
          [So Aug 15 16:36:21 2021] Calibrating delay loop (skipped), value calculated using timer        frequency.. 108.00 BogoMIPS (lpj=540000)
          [So Aug 15 16:36:21 2021] pid_max: default: 32768 minimum: 301
          [So Aug 15 16:36:21 2021] LSM: Security Framework initializing
          [So Aug 15 16:36:21 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, lin        ear)
          [So Aug 15 16:36:21 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes        , linear)
          [So Aug 15 16:36:21 2021] cgroup: Disabling memory control group subsystem
          [So Aug 15 16:36:21 2021] CPU: Testing write buffer coherency: ok
          [So Aug 15 16:36:21 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [So Aug 15 16:36:21 2021] Setting up static identity map for 0x200000 - 0x20003c
          [So Aug 15 16:36:21 2021] rcu: Hierarchical SRCU implementation.
          [So Aug 15 16:36:21 2021] smp: Bringing up secondary CPUs ...
          [So Aug 15 16:36:21 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [So Aug 15 16:36:21 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
          [So Aug 15 16:36:21 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
          [So Aug 15 16:36:21 2021] smp: Brought up 1 node, 4 CPUs
          [So Aug 15 16:36:21 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
          [So Aug 15 16:36:21 2021] CPU: All CPU(s) started in HYP mode.
          [So Aug 15 16:36:21 2021] CPU: Virtualization extensions available.
          [So Aug 15 16:36:21 2021] devtmpfs: initialized
          [So Aug 15 16:36:21 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant        8 rev 0
          [So Aug 15 16:36:21 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff,        max_idle_ns: 19112604462750000 ns
          [So Aug 15 16:36:21 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [So Aug 15 16:36:21 2021] pinctrl core: initialized pinctrl subsystem
          [So Aug 15 16:36:21 2021] NET: Registered protocol family 16
          [So Aug 15 16:36:21 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
          [So Aug 15 16:36:21 2021] audit: initializing netlink subsys (disabled)
          [So Aug 15 16:36:21 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enable        d=0 res=1
          [So Aug 15 16:36:21 2021] thermal_sys: Registered thermal governor 'step_wise'
          [So Aug 15 16:36:21 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoin        t registers.
          [So Aug 15 16:36:21 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
          [So Aug 15 16:36:21 2021] Serial: AMBA PL011 UART driver
          [So Aug 15 16:36:21 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [So Aug 15 16:36:21 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 20        21-08-03T18:14:56, variant start
          [So Aug 15 16:36:21 2021] raspberrypi-firmware soc:firmware: Firmware hash is 40787ee5905        644f639a2a0f6e00ae12e517a2211
          [So Aug 15 16:36:21 2021] Kprobes globally optimized
          [So Aug 15 16:36:21 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
          [So Aug 15 16:36:21 2021] vgaarb: loaded
          [So Aug 15 16:36:21 2021] SCSI subsystem initialized
          [So Aug 15 16:36:21 2021] usbcore: registered new interface driver usbfs
          [So Aug 15 16:36:21 2021] usbcore: registered new interface driver hub
          [So Aug 15 16:36:21 2021] usbcore: registered new device driver usb
          [So Aug 15 16:36:21 2021] usb_phy_generic phy: supply vcc not found, using dummy regulato        r
          [So Aug 15 16:36:21 2021] clocksource: Switched to clocksource arch_sys_counter
          [So Aug 15 16:36:22 2021] VFS: Disk quotas dquot_6.6.0
          [So Aug 15 16:36:22 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
          [So Aug 15 16:36:22 2021] FS-Cache: Loaded
          [So Aug 15 16:36:22 2021] CacheFiles: Loaded
          [So Aug 15 16:36:22 2021] NET: Registered protocol family 2
          [So Aug 15 16:36:22 2021] IP idents hash table entries: 16384 (order: 5, 131072 bytes, li        near)
          [So Aug 15 16:36:22 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 614        4 bytes, linear)
          [So Aug 15 16:36:22 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes        , linear)
          [So Aug 15 16:36:22 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linea        r)
          [So Aug 15 16:36:22 2021] TCP: Hash tables configured (established 8192 bind 8192)
          [So Aug 15 16:36:22 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
          [So Aug 15 16:36:22 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear        )
          [So Aug 15 16:36:22 2021] NET: Registered protocol family 1
          [So Aug 15 16:36:22 2021] RPC: Registered named UNIX socket transport module.
          [So Aug 15 16:36:22 2021] RPC: Registered udp transport module.
          [So Aug 15 16:36:22 2021] RPC: Registered tcp transport module.
          [So Aug 15 16:36:22 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [So Aug 15 16:36:22 2021] PCI: CLS 0 bytes, default 64
          [So Aug 15 16:36:22 2021] Initialise system trusted keyrings
          [So Aug 15 16:36:22 2021] workingset: timestamp_bits=14 max_order=19 bucket_order=5
          [So Aug 15 16:36:22 2021] zbud: loaded
          [So Aug 15 16:36:22 2021] FS-Cache: Netfs 'nfs' registered for caching
          [So Aug 15 16:36:22 2021] NFS: Registering the id_resolver key type
          [So Aug 15 16:36:22 2021] Key type id_resolver registered
          [So Aug 15 16:36:22 2021] Key type id_legacy registered
          [So Aug 15 16:36:22 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [So Aug 15 16:36:22 2021] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registeri        ng...
          [So Aug 15 16:36:22 2021] Key type asymmetric registered
          [So Aug 15 16:36:22 2021] Asymmetric key parser 'x509' registered
          [So Aug 15 16:36:22 2021] bounce: pool size: 64 pages
          [So Aug 15 16:36:22 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major        249)
          [So Aug 15 16:36:22 2021] io scheduler mq-deadline registered
          [So Aug 15 16:36:22 2021] io scheduler kyber registered
          [So Aug 15 16:36:22 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [So Aug 15 16:36:22 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d5        00000, using [bus 00-ff]
          [So Aug 15 16:36:22 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff ->        0x00c0000000
          [So Aug 15 16:36:22 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff ->        0x0400000000
          [So Aug 15 16:36:22 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [So Aug 15 16:36:22 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [So Aug 15 16:36:22 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
          [So Aug 15 16:36:22 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff        ] (bus address [0xc0000000-0xffffffff])
          [So Aug 15 16:36:22 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [So Aug 15 16:36:22 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
          [So Aug 15 16:36:22 2021] PCI: bus0: Fast back to back transfers disabled
          [So Aug 15 16:36:22 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [So Aug 15 16:36:22 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [So Aug 15 16:36:22 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
          [So Aug 15 16:36:22 2021] PCI: bus1: Fast back to back transfers disabled
          [So Aug 15 16:36:22 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [So Aug 15 16:36:22 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff        64bit]
          [So Aug 15 16:36:22 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
          [So Aug 15 16:36:22 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [So Aug 15 16:36:22 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
          [So Aug 15 16:36:22 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
          [So Aug 15 16:36:22 2021] bcm2708_fb soc:fb: FB found 1 display(s)
          [So Aug 15 16:36:22 2021] Console: switching to colour frame buffer device 160x50
          [So Aug 15 16:36:22 2021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1        280x800
          [So Aug 15 16:36:22 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
          [So Aug 15 16:36:22 2021] bcm2835-aux-uart fe215040.serial: there is not valid maps for s        tate default
          [So Aug 15 16:36:22 2021] iproc-rng200 fe104000.rng: hwrng registered
          [So Aug 15 16:36:22 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x400        00000(1024 MiB)
          [So Aug 15 16:36:22 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xf        e200000
          [So Aug 15 16:36:22 2021] brd: module loaded
          [So Aug 15 16:36:22 2021] loop: module loaded
          [So Aug 15 16:36:22 2021] Loading iSCSI transport class v2.0-870.
          [So Aug 15 16:36:22 2021] libphy: Fixed MDIO Bus: probed
          [So Aug 15 16:36:22 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [So Aug 15 16:36:22 2021] libphy: bcmgenet MII bus: probed
          [So Aug 15 16:36:22 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [So Aug 15 16:36:22 2021] usbcore: registered new interface driver r8152
          [So Aug 15 16:36:22 2021] usbcore: registered new interface driver lan78xx
          [So Aug 15 16:36:22 2021] usbcore: registered new interface driver smsc95xx
          [So Aug 15 16:36:22 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
          [So Aug 15 16:36:22 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [So Aug 15 16:36:22 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus num        ber 1
          [So Aug 15 16:36:22 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100        quirks 0x0000060000000890
          [So Aug 15 16:36:22 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002,        bcdDevice= 5.10
          [So Aug 15 16:36:22 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumbe        r=1
          [So Aug 15 16:36:22 2021] usb usb1: Product: xHCI Host Controller
          [So Aug 15 16:36:22 2021] usb usb1: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
          [So Aug 15 16:36:22 2021] usb usb1: SerialNumber: 0000:01:00.0
          [So Aug 15 16:36:22 2021] hub 1-0:1.0: USB hub found
          [So Aug 15 16:36:22 2021] hub 1-0:1.0: 1 port detected
          [So Aug 15 16:36:22 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus num        ber 2
          [So Aug 15 16:36:22 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [So Aug 15 16:36:22 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003,        bcdDevice= 5.10
          [So Aug 15 16:36:22 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumbe        r=1
          [So Aug 15 16:36:22 2021] usb usb2: Product: xHCI Host Controller
          [So Aug 15 16:36:22 2021] usb usb2: Manufacturer: Linux 5.10.52-v7l+ xhci-hcd
          [So Aug 15 16:36:22 2021] usb usb2: SerialNumber: 0000:01:00.0
          [So Aug 15 16:36:22 2021] hub 2-0:1.0: USB hub found
          [So Aug 15 16:36:22 2021] hub 2-0:1.0: 4 ports detected
          [So Aug 15 16:36:22 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [So Aug 15 16:36:22 2021] dwc_otg: FIQ enabled
          [So Aug 15 16:36:22 2021] dwc_otg: NAK holdoff enabled
          [So Aug 15 16:36:22 2021] dwc_otg: FIQ split-transaction FSM enabled
          [So Aug 15 16:36:22 2021] Module dwc_common_port init
          [So Aug 15 16:36:22 2021] usbcore: registered new interface driver uas
          [So Aug 15 16:36:22 2021] usbcore: registered new interface driver usb-storage
          [So Aug 15 16:36:22 2021] mousedev: PS/2 mouse device common for all mice
          [So Aug 15 16:36:22 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [So Aug 15 16:36:22 2021] sdhci: Secure Digital Host Controller Interface driver
          [So Aug 15 16:36:22 2021] sdhci: Copyright(c) Pierre Ossman
          [So Aug 15 16:36:22 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
          [So Aug 15 16:36:22 2021] sdhci-pltfm: SDHCI platform and OF driver helper
          [So Aug 15 16:36:22 2021] ledtrig-cpu: registered to indicate activity on CPUs
          [So Aug 15 16:36:22 2021] hid: raw HID events driver (C) Jiri Kosina
          [So Aug 15 16:36:22 2021] usbcore: registered new interface driver usbhid
          [So Aug 15 16:36:22 2021] usbhid: USB HID core driver
          [So Aug 15 16:36:22 2021] Initializing XFRM netlink socket
          [So Aug 15 16:36:22 2021] NET: Registered protocol family 17
          [So Aug 15 16:36:22 2021] Key type dns_resolver registered
          [So Aug 15 16:36:22 2021] Registering SWP/SWPB emulation handler
          [So Aug 15 16:36:22 2021] registered taskstats version 1
          [So Aug 15 16:36:22 2021] Loading compiled-in X.509 certificates
          [So Aug 15 16:36:22 2021] Key type ._fscrypt registered
          [So Aug 15 16:36:22 2021] Key type .fscrypt registered
          [So Aug 15 16:36:22 2021] Key type fscrypt-provisioning registered
          [So Aug 15 16:36:22 2021] uart-pl011 fe201000.serial: there is not valid maps for state d        efault
          [So Aug 15 16:36:22 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [So Aug 15 16:36:22 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_bau        d = 0) is a PL011 rev2
          [So Aug 15 16:36:22 2021] printk: console [ttyS0] disabled
          [So Aug 15 16:36:22 2021] fe215040.serial: ttyS0 at MMIO 0xfe215040 (irq = 38, base_baud        = 62500000) is a 16550
          [So Aug 15 16:36:23 2021] printk: console [ttyS0] enabled
          [So Aug 15 16:36:23 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains dri        ver
          [So Aug 15 16:36:23 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [So Aug 15 16:36:23 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [So Aug 15 16:36:23 2021] of_cfs_init
          [So Aug 15 16:36:23 2021] of_cfs_init: OK
          [So Aug 15 16:36:23 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
          [So Aug 15 16:36:23 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [So Aug 15 16:36:23 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using        ADMA
          [So Aug 15 16:36:23 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
          [So Aug 15 16:36:23 2021] Waiting for root device /dev/mmcblk0p2...
          [So Aug 15 16:36:24 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [So Aug 15 16:36:24 2021] mmc1: new high speed SDIO card at address 0001
          [So Aug 15 16:36:24 2021] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
          [So Aug 15 16:36:24 2021] mmcblk0: mmc0:aaaa SB64G 59.5 GiB
          [So Aug 15 16:36:24 2021]  mmcblk0: p1 p2
          [So Aug 15 16:36:24 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode.        Opts: (null)
          [So Aug 15 16:36:24 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [So Aug 15 16:36:24 2021] devtmpfs: mounted
          [So Aug 15 16:36:24 2021] Freeing unused kernel memory: 2048K
          [So Aug 15 16:36:24 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, b        cdDevice= 4.21
          [So Aug 15 16:36:24 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber        =0
          [So Aug 15 16:36:24 2021] usb 1-1: Product: USB2.0 Hub
          [So Aug 15 16:36:24 2021] Run /sbin/init as init process
          [So Aug 15 16:36:24 2021]   with arguments:
          [So Aug 15 16:36:24 2021]     /sbin/init
          [So Aug 15 16:36:24 2021]   with environment:
          [So Aug 15 16:36:24 2021]     HOME=/
          [So Aug 15 16:36:24 2021]     TERM=linux
          [So Aug 15 16:36:24 2021] hub 1-1:1.0: USB hub found
          [So Aug 15 16:36:24 2021] hub 1-1:1.0: 4 ports detected
          [So Aug 15 16:36:24 2021] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
          [So Aug 15 16:36:24 2021] usb 1-1.1: New USB device found, idVendor=0781, idProduct=5567,        bcdDevice= 1.00
          [So Aug 15 16:36:24 2021] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumb        er=3
          [So Aug 15 16:36:24 2021] usb 1-1.1: Product: Cruzer Blade
          [So Aug 15 16:36:24 2021] usb 1-1.1: Manufacturer: SanDisk
          [So Aug 15 16:36:24 2021] usb 1-1.1: SerialNumber: 4C530000010912120044
          [So Aug 15 16:36:24 2021] usb-storage 1-1.1:1.0: USB Mass Storage device detected
          [So Aug 15 16:36:24 2021] scsi host0: usb-storage 1-1.1:1.0
          [So Aug 15 16:36:24 2021] usb 1-1.2: new high-speed USB device number 4 using xhci_hcd
          [So Aug 15 16:36:24 2021] systemd[1]: System time before build time, advancing clock.
          [So Aug 15 16:36:24 2021] usb 1-1.2: New USB device found, idVendor=1a40, idProduct=0101,        bcdDevice= 1.11
          [So Aug 15 16:36:24 2021] NET: Registered protocol family 10
          [So Aug 15 16:36:25 2021] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumb        er=0
          [So Aug 15 16:36:25 2021] Segment Routing with IPv6
          [So Aug 15 16:36:25 2021] usb 1-1.2: Product: USB 2.0 Hub
          [So Aug 15 16:36:25 2021] hub 1-1.2:1.0: USB hub found
          [So Aug 15 16:36:25 2021] hub 1-1.2:1.0: 4 ports detected
          [So Aug 15 16:36:25 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +S        ELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4        +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
          [So Aug 15 16:36:25 2021] systemd[1]: Detected architecture arm.
          [So Aug 15 16:36:25 2021] systemd[1]: Set hostname to <raspi4VisDisplay>.
          [So Aug 15 16:36:25 2021] usb 1-1.2.4: new full-speed USB device number 5 using xhci_hcd
          [So Aug 15 16:36:25 2021] usb 1-1.2.4: New USB device found, idVendor=222a, idProduct=000        1, bcdDevice= 0.00
          [So Aug 15 16:36:25 2021] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNu        mber=0
          [So Aug 15 16:36:25 2021] usb 1-1.2.4: Product: Multi-Touch-V3000
          [So Aug 15 16:36:25 2021] usb 1-1.2.4: Manufacturer: ILITEK
          [So Aug 15 16:36:25 2021] input: ILITEK Multi-Touch-V3000 as /devices/platform/scb/fd5000        00.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/0003:222A        :0001.0001/input/input0
          [So Aug 15 16:36:25 2021] hid-generic 0003:222A:0001.0001: input,hidraw0: USB HID v1.10 D        evice [ILITEK Multi-Touch-V3000] on usb-0000:01:00.0-1.2.4/input0
          [So Aug 15 16:36:25 2021] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00        PQ: 0 ANSI: 6
          [So Aug 15 16:36:25 2021] input: ILITEK Multi-Touch-V3000 Mouse as /devices/platform/scb/        fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.1/000        3:222A:0001.0002/input/input1
          [So Aug 15 16:36:25 2021] hid-generic 0003:222A:0001.0002: input,hiddev96,hidraw1: USB HI        D v1.10 Mouse [ILITEK Multi-Touch-V3000] on usb-0000:01:00.0-1.2.4/input1
          [So Aug 15 16:36:25 2021] sd 0:0:0:0: [sda] 30605312 512-byte logical blocks: (15.7 GB/14        .6 GiB)
          [So Aug 15 16:36:25 2021] sd 0:0:0:0: [sda] Write Protect is off
          [So Aug 15 16:36:25 2021] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
          [So Aug 15 16:36:25 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, d        oesn't support DPO or FUA
          [So Aug 15 16:36:25 2021]  sda: sda1
          [So Aug 15 16:36:25 2021] sd 0:0:0:0: [sda] Attached SCSI removable disk
          [So Aug 15 16:36:26 2021] systemd[1]: /etc/systemd/system/teamviewerd.service:8: PIDFile=        references path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /r        un/teamviewerd.pid; please update the unit file accordingly.
          [So Aug 15 16:36:26 2021] random: systemd: uninitialized urandom read (16 bytes read)
          [So Aug 15 16:36:26 2021] systemd[1]: Created slice system-systemd\x2dfsck.slice.
          [So Aug 15 16:36:26 2021] systemd[1]: Listening on Journal Socket (/dev/log).
          [So Aug 15 16:36:26 2021] systemd[1]: Created slice system-getty.slice.
          [So Aug 15 16:36:26 2021] systemd[1]: Listening on Syslog Socket.
          [So Aug 15 16:36:26 2021] systemd[1]: Started Forward Password Requests to Wall Directory        Watch.
          [So Aug 15 16:36:26 2021] systemd[1]: Created slice system-serial\x2dgetty.slice.
          [So Aug 15 16:36:26 2021] i2c /dev entries driver
          [So Aug 15 16:36:27 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          [So Aug 15 16:36:27 2021] systemd-journald[130]: Received request to flush runtime journa        l from PID 1
          [So Aug 15 16:36:28 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: R        egisters at 0xfeb00000 length 0x00010000
          [So Aug 15 16:36:28 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialis        ed: Registers at 0xfeb10000 length 0x00001000
          [So Aug 15 16:36:28 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: R        egisters at 0xfeb20000 length 0x00010000
          [So Aug 15 16:36:28 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Reg        isters at 0xfeb30000 length 0x00010000
          [So Aug 15 16:36:28 2021] vc_sm_cma: module is from the staging directory, the quality is        unknown, you have been warned.
          [So Aug 15 16:36:28 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [So Aug 15 16:36:28 2021] [vc_sm_connected_init]: start
          [So Aug 15 16:36:28 2021] mc: Linux media interface: v0.10
          [So Aug 15 16:36:28 2021] [vc_sm_connected_init]: installed successfully
          [So Aug 15 16:36:28 2021] videodev: Linux video capture interface: v2.00
          [So Aug 15 16:36:28 2021] snd_bcm2835: module is from the staging directory, the quality        is unknown, you have been warned.
          [So Aug 15 16:36:28 2021] bcm2835_audio bcm2835_audio: card created with 4 channels
          [So Aug 15 16:36:28 2021] bcm2835_mmal_vchiq: module is from the staging directory, the q        uality is unknown, you have been warned.
          [So Aug 15 16:36:28 2021] bcm2835_isp: module is from the staging directory, the quality        is unknown, you have been warned.
          [So Aug 15 16:36:28 2021] bcm2835_v4l2: module is from the staging directory, the quality        is unknown, you have been warned.
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /d        ev/video13
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /        dev/video14
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /        dev/video15
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /de        v/video16
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media cont        roller
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media con        troller
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media con        troller
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media con        troller
          [So Aug 15 16:36:28 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [So Aug 15 16:36:28 2021] bcm2835_codec: module is from the staging directory, the qualit        y is unknown, you have been warned.
          [So Aug 15 16:36:28 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [So Aug 15 16:36:28 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [So Aug 15 16:36:28 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [So Aug 15 16:36:28 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [So Aug 15 16:36:28 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [So Aug 15 16:36:28 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [So Aug 15 16:36:28 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory        database
          [So Aug 15 16:36:28 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
          [So Aug 15 16:36:28 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [So Aug 15 16:36:28 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
          [So Aug 15 16:36:28 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio        for chip BCM4345/6
          [So Aug 15 16:36:28 2021] usbcore: registered new interface driver brcmfmac
          [So Aug 15 16:36:28 2021] input: ILITEK Multi-Touch-V3000 as /devices/platform/scb/fd5000        00.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/0003:222A        :0001.0001/input/input3
          [So Aug 15 16:36:28 2021] hid-multitouch 0003:222A:0001.0001: input,hidraw0: USB HID v1.1        0 Device [ILITEK Multi-Touch-V3000] on usb-0000:01:00.0-1.2.4/input0
          [So Aug 15 16:36:29 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio        for chip BCM4345/6
          [So Aug 15 16:36:29 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan        4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
          [So Aug 15 16:36:29 2021] ads7846 spi0.1: supply vcc not found, using dummy regulator
          [So Aug 15 16:36:29 2021] ads7846 spi0.1: touchscreen, irq 65
          [So Aug 15 16:36:29 2021] input: ADS7846 Touchscreen as /devices/platform/soc/fe204000.sp        i/spi_master/spi0/spi0.1/input/input4
          [So Aug 15 16:36:30 2021] Adding 15302636k swap on /dev/sda1.  Priority:-2 extents:1 acro        ss:15302636k FS
          [So Aug 15 16:36:31 2021] random: crng init done
          [So Aug 15 16:36:31 2021] random: 7 urandom warning(s) missed due to ratelimiting
          [So Aug 15 16:36:31 2021] uart-pl011 fe201000.serial: no DMA platform data
          [So Aug 15 16:36:31 2021] 8021q: 802.1Q VLAN Support v1.8
          [So Aug 15 16:36:32 2021] Bluetooth: Core ver 2.22
          [So Aug 15 16:36:32 2021] NET: Registered protocol family 31
          [So Aug 15 16:36:32 2021] Bluetooth: HCI device and connection manager initialized
          [So Aug 15 16:36:32 2021] Bluetooth: HCI socket layer initialized
          [So Aug 15 16:36:32 2021] Bluetooth: L2CAP socket layer initialized
          [So Aug 15 16:36:32 2021] Bluetooth: SCO socket layer initialized
          [So Aug 15 16:36:32 2021] Bluetooth: HCI UART driver ver 2.3
          [So Aug 15 16:36:32 2021] Bluetooth: HCI UART protocol H4 registered
          [So Aug 15 16:36:32 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [So Aug 15 16:36:32 2021] Bluetooth: HCI UART protocol Broadcom registered
          [So Aug 15 16:36:32 2021] Adding 102396k swap on /var/swap.  Priority:-3 extents:1 across        :102396k SSFS
          [So Aug 15 16:36:33 2021] bcmgenet fd580000.ethernet: configuring instance for external R        GMII (RX delay)
          [So Aug 15 16:36:33 2021] bcmgenet fd580000.ethernet eth0: Link is Down
          [So Aug 15 16:36:33 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [So Aug 15 16:36:33 2021] Bluetooth: BNEP filters: protocol multicast
          [So Aug 15 16:36:33 2021] Bluetooth: BNEP socket layer initialized
          [So Aug 15 16:36:33 2021] Bluetooth: RFCOMM TTY layer initialized
          [So Aug 15 16:36:33 2021] Bluetooth: RFCOMM socket layer initialized
          [So Aug 15 16:36:33 2021] Bluetooth: RFCOMM ver 1.11
          [So Aug 15 16:36:37 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow        control rx/tx
          [So Aug 15 16:36:37 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [So Aug 15 16:36:38 2021] fuse: init (API version 7.32)
          [So Aug 15 16:36:38 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) n        et.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
          pi@raspi4VisDisplay:~ $
            @fuso
            fuso
            Die Auslastungsdatei war permanent auf 100%. Habe versucht im Netz rauszufinden wie man das bereinigen könnte. Bin dadurch auf ein Tutorial gestoßen, wo das gemacht wurde. Das war vor ca. einer woche.
            Aber an dem langsamen starten und umschalten der Views hat das leider gar nichts verändert. Soll ich den swap komplett deaktivieren?
            • F fuso
              pi@raspi4VisDisplay:~ $ dmesg -T
              liv-in-skyL Offline
              liv-in-skyL Offline
              @fuso
              schon mal einen view wechsel auf dem pc mit chrome gemacht und gleichzeitig die entwicklertools aufgehabt - evtl sind dort fehler in der browser console zu sehen
              chrome - weitere tools - entwicklertools
              • F fuso
                @fuso
                Das Swap File zu nutzen verlangsamt den Rechner grundsätzlich schonmal. Und wenn das dann auch noch über den langsamen USB-Bus läuft nochmal.
                free -ht --mega
                Ich würde eher das System so schlank wie möglich aufsetzen. Da läuft vermutlich alles mögliche an Desktop-Zeugs mit.
                Ein Rpi4 mit 2GB RAM könnte da zu knapp kalkuliert sein.
                Bei mir braucht ein headless-System mit gar nicht vielen Instanzen schon 1,2GB.
                echad@chet:~ $ free -ht --mega
                              gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                Speicher:       7,9G        1,2G        5,8G        0,0K        910M        6,8G
                Swap:            99M          0B         99M
                Gesamt:         8,0G        1,2G        5,9G
                echad@chet:~ $
                • liv-in-skyL liv-in-sky
                  @fuso
                  fuso
                  @liv-in-sky
                  Hab ich mal gemacht,
                  Oh je, am Ende der Consoleneinträge gibts jede Menge Fehler. Ich häng das mal mit an.
                  Version vis-canvas-gauges: 0.1.5
                  index.html:4038 Version vis-colorpicker: 1.2.0
                  index.html:5211 Version coronavirus-statistics: 0.1.0
                  index.html:6116 Version vis-history: 1.0.0
                  info.js:21 Version Info-Adapter-Widget: 0.0.9
                  index.html:7173 Version vis-jqui-mfd: 1.0.12
                  justgage.js:115 Version justgage: 1.0.2
                  keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
                  index.html:11561 Version vis-map: 1.0.3
                  material.js:29 Version material: 0.1.3
                  index.html:12881 Metro version: "1.1.2"
                  mytime.js:22 Version mytime: 0.0.1
                  players.js:55 Version players: 0.1.0
                  adapter/mytime/words.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                  tvprogram.js:36 Version tvprogram: 0.0.1
                  vis-material-advanced.js:184 Version vis-material-advanced: 1.6.0
                  index.html:22072 Version vis-weather: 2.4.1
                  time-switch.js:38 Version time-switch: 2.2.2
                  conn.js:305 2021-08-15T14:51:20.650Z Connected => authenticate
                  conn.js:326 2021-08-15T14:51:20.789Z Authenticated: true
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0365416.1.FILLING_LEVEL
                  vis.js:3311 Create inner vis object hm-rpc.0.JEQ0715222.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0803481.4.SET_TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0803481.4.ACTUAL_TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0803481.4.VALVE_STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0803481.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.JEQ0715222.1.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.LEQ0992520.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ1780271.2.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ1780271.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0611804.2.LEVEL
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0611804.2.WORKING
                  vis.js:3311 Create inner vis object hm-rpc.0.PEQ0157065.1.LEVEL
                  vis.js:3311 Create inner vis object hm-rpc.0.PEQ1603514.1.LEVEL
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0005406.1.TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0005406.1.HUMIDITY
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0005406.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ1363451.1.LEVEL
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0770866.2.POWER
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.Batterie_Leer_HMGerät
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WT7WH590-68A40E1CD4C5.general.connected
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.status.BSH_Common_Status_OperationState
                  vis.js:3311 Create inner vis object hm-rpc.1.000E5A49A8F279.1.ACTUAL_TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.1.000E5A49A8F279.1.HUMIDITY
                  vis.js:3311 Create inner vis object hm-rpc.1.000E5A49A8F279.0.LOW_BAT
                  vis.js:3311 Create inner vis object upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.Layer1DownstreamMaxBitRate
                  vis.js:3311 Create inner vis object upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.Layer1UpstreamMaxBitRate
                  vis.js:3311 Create inner vis object upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewByteReceiveRate
                  vis.js:3311 Create inner vis object upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewByteSendRate
                  vis.js:3311 Create inner vis object javascript.0.scriptEnabled.common.FritzBox_zyklisch_abfragen
                  vis.js:3311 Create inner vis object upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived
                  vis.js:3311 Create inner vis object upnp.0.WANDevice_-_FRITZ!Box_7590.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesSent
                  vis.js:3311 Create inner vis object fritzbox.0.calls.ringLastNumber
                  vis.js:3311 Create inner vis object fritzbox.0.calls.ringLastMissedNumber
                  vis.js:3311 Create inner vis object fritzbox.0.calls.callLastNumber
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0365416.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0053807.1.TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0241288.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0241288.0.LOWBAT
                  vis.js:3311 Create inner vis object robonect.0.batteries.0.charge
                  vis.js:3311 Create inner vis object robonect.0.status.mode
                  vis.js:3311 Create inner vis object robonect.0.status.status
                  vis.js:3311 Create inner vis object robonect.0.timer.0.start_time
                  vis.js:3311 Create inner vis object hm-rpc.1.00021709A1CDD3.2.STATE
                  vis.js:3311 Create inner vis object robonect.0.timer.0.enabled
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0053807.1.HUMIDITY
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.BRIGHTNESS
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.WIND_SPEED
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.WIND_DIRECTION
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.RAINING
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0863982.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0863982.1.POWER
                  vis.js:3311 Create inner vis object robonect.0.status.Shaun_schläft_17-9
                  vis.js:3311 Create inner vis object 0_userdata.0.Regenmenge_heute
                  vis.js:3311 Create inner vis object 0_userdata.0.Regenmenge_gestern
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommene_Menge
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Geschirrspüler.alive
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.active.BSH_Common_Root_ActiveProgram
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.active.options.BSH_Common_Option_ProgramProgress
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.active.options.BSH_Common_Option_RemainingProgramTime
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.active.options.Dishcare_Dishwasher_Option_BrillianceDry
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.selected.options.Auto2.Dishcare_Dishwasher_Option_IntensivZone
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.active.options.Dishcare_Dishwasher_Option_SilenceOnDemand
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.programs.active.options.Dishcare_Dishwasher_Option_VarioSpeedPlus
                  vis.js:3311 Create inner vis object homeconnect.0.010110387973009441.status.BSH_Common_Status_DoorState
                  vis.js:3311 Create inner vis object hm-rega.1.40103
                  vis.js:3311 Create inner vis object hm-rega.1.PEQ1948186.0.FIRMWARE_VERSION
                  vis.js:3311 Create inner vis object backitup.0.oneClick.ccu
                  vis.js:3311 Create inner vis object backitup.0.history.ccuLastTime
                  vis.js:3311 Create inner vis object backitup.0.info.ccuNextTime
                  vis.js:3311 Create inner vis object backitup.0.history.ccuSuccess
                  vis.js:3311 Create inner vis object info.0.sysinfo.cpu.currentLoad.currentload
                  vis.js:3311 Create inner vis object admin.0.info.updatesNumber
                  vis.js:3311 Create inner vis object admin.0.info.updatesList
                  vis.js:3311 Create inner vis object info.0.sysinfo.os.info.release
                  vis.js:3311 Create inner vis object info.0.sysinfo.os.info.distro
                  vis.js:3311 Create inner vis object info.0.sysinfo.os.info.hostname
                  vis.js:3311 Create inner vis object info.0.sysinfo.os.info.codename
                  vis.js:3311 Create inner vis object info.0.sysinfo.cpu.info.brand
                  vis.js:3311 Create inner vis object backitup.0.oneClick.iobroker
                  vis.js:3311 Create inner vis object backitup.0.info.latestBackup
                  vis.js:3311 Create inner vis object backitup.0.history.iobrokerLastTime
                  vis.js:3311 Create inner vis object backitup.0.history.iobrokerSuccess
                  vis.js:3311 Create inner vis object backitup.0.info.iobrokerNextTime
                  vis.js:3311 Create inner vis object system.adapter.admin.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.admin.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.admin.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.admin.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.backitup.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.backitup.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.backitup.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.backitup.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.admin.0.alive
                  vis.js:3311 Create inner vis object system.adapter.backitup.0.alive
                  vis.js:3311 Create inner vis object system.adapter.hm-rega.1.outputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rega.1.inputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rega.1.cputime
                  vis.js:3311 Create inner vis object system.adapter.hm-rega.1.alive
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.0.alive
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.1.alive
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.1.cpu
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.1.cputime
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.1.inputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.1.outputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.2.alive
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.2.cpu
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.2.cputime
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.2.inputCount
                  vis.js:3311 Create inner vis object system.adapter.hm-rpc.2.outputCount
                  vis.js:3311 Create inner vis object system.adapter.homeconnect.0.alive
                  vis.js:3311 Create inner vis object system.adapter.homeconnect.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.homeconnect.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.homeconnect.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.info.0.alive
                  vis.js:3311 Create inner vis object system.adapter.info.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.info.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.info.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.info.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.javascript.0.alive
                  vis.js:3311 Create inner vis object system.adapter.javascript.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.javascript.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.javascript.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.mihome-vacuum.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.mihome-vacuum.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.mihome-vacuum.0.alive
                  vis.js:3311 Create inner vis object system.adapter.mihome-vacuum.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.ping.0.alive
                  vis.js:3311 Create inner vis object system.adapter.ping.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.ping.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.ping.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.ping.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.robonect.0.alive
                  vis.js:3311 Create inner vis object system.adapter.robonect.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.robonect.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.robonect.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.robonect.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.sql.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.sql.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.sql.0.cputime
                  vis.js:3311 Create inner vis object sql.0.info.connection
                  vis.js:3311 Create inner vis object system.adapter.systeminfo.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.systeminfo.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.systeminfo.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.systeminfo.0.alive
                  vis.js:3311 Create inner vis object system.adapter.upnp.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.upnp.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.upnp.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.upnp.0.alive
                  vis.js:3311 Create inner vis object system.adapter.web.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.web.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.web.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.web.0.alive
                  vis.js:3311 Create inner vis object system.adapter.synology.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.synology.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.synology.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.synology.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.tankerkoenig.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.tankerkoenig.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.tankerkoenig.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.tankerkoenig.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.synology.0.alive
                  vis.js:3311 Create inner vis object system.adapter.tankerkoenig.0.alive
                  vis.js:3311 Create inner vis object system.adapter.volumio.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.volumio.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.volumio.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.volumio.0.alive
                  vis.js:3311 Create inner vis object system.adapter.web-speedy.0.alive
                  vis.js:3311 Create inner vis object system.adapter.web-speedy.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.web-speedy.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.web-speedy.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.web-speedy.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.schoolfree.0.alive
                  vis.js:3311 Create inner vis object system.adapter.schoolfree.0.cpu
                  vis.js:3311 Create inner vis object system.adapter.schoolfree.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.schoolfree.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.schoolfree.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.scenes.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.scenes.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.scenes.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.scenes.0.alive
                  vis.js:3311 Create inner vis object system.adapter.email.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.email.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.email.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.email.0.alive
                  vis.js:3311 Create inner vis object system.adapter.panasonic-viera.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.panasonic-viera.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.panasonic-viera.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.panasonic-viera.0.alive
                  vis.js:3311 Create inner vis object system.adapter.openweathermap.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.openweathermap.0.alive
                  vis.js:3311 Create inner vis object system.adapter.fritzbox.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.fritzbox.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.fritzbox.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.fritzbox.0.alive
                  vis.js:3311 Create inner vis object system.adapter.harmony.0.outputCount
                  vis.js:3311 Create inner vis object system.adapter.harmony.0.inputCount
                  vis.js:3311 Create inner vis object system.adapter.harmony.0.cputime
                  vis.js:3311 Create inner vis object system.adapter.harmony.0.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_67
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_30
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_47
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Raspi4VisDisplay.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_27
                  vis.js:3311 Create inner vis object web-speedy.0.info.connection
                  vis.js:3311 Create inner vis object ping.0.ioBroker.iobroker_host.alive
                  vis.js:3311 Create inner vis object ping.0.ioBroker.ALPMA_Laptop.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_59
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_52
                  vis.js:3311 Create inner vis object system.adapter.hm-rega.0.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_57
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_44
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_46
                  vis.js:3311 Create inner vis object synology.0.info.connection
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_48
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Kostal_Piko.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_55
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_21
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_38
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Xiaomi_Saugroboter.alive
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Robonect.alive
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Technisat_Digit_STC_WZ.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_51
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_20
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_50
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_69
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Galaxy_Tab_S6.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.Homematic_LAN_Gateway
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_49
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Sebastians_HTC.alive
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Raspberry_Teamviewer.alive
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_71
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_73
                  vis.js:3311 Create inner vis object ping.0.ioBroker.Fredis_Dell_laptop.alive
                  vis.js:3311 Create inner vis object ping.0.ioBroker.HP_Envy_Tintenstrahldrucker.alive
                  vis.js:3311 Create inner vis object web-speedy.0.Results.speeds.download_Mb
                  vis.js:3311 Create inner vis object web-speedy.0.running_download_progress
                  vis.js:3311 Create inner vis object web-speedy.0.test_specific
                  vis.js:3311 Create inner vis object web-speedy.0.running_download_speed
                  vis.js:3311 Create inner vis object web-speedy.0.running_upload
                  vis.js:3311 Create inner vis object web-speedy.0.running_upload_progress
                  vis.js:3311 Create inner vis object web-speedy.0.running_upload_speed
                  vis.js:3311 Create inner vis object web-speedy.0.Results.speeds.upload_Mb
                  vis.js:3311 Create inner vis object web-speedy.0.Results.Last_Run
                  vis.js:3311 Create inner vis object web-speedy.0.test_duration
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0675758.1.TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0675758.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ1434736.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0442172.1.STATE
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WM4YH741-68A40E1D98E8.general.connected
                  vis.js:3311 Create inner vis object hm-rpc.0.PEQ0413303.2.ENERGY_COUNTER
                  vis.js:3311 Create inner vis object hm-rpc.1.001E1A498F6ADE.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.1.001E1A498F6ADE.0.LOW_BAT
                  vis.js:3311 Create inner vis object hm-rpc.1.000ADB3393B82B.0.LOW_BAT
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.1.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.1.e10.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.cheapest.e5.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.cheapest.e5.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.6.e10.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.6.diesel.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.6.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.5.e10.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.5.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.2.e10.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.2.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.0.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.0.e10.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.6.e5.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.5.diesel.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.5.e5.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.cheapest.diesel.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.cheapest.diesel.name
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.2.diesel.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.2.e5.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.1.diesel.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.1.e5.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.0.diesel.short
                  vis.js:3311 Create inner vis object tankerkoenig.0.stations.0.e5.short
                  vis.js:3311 Create inner vis object hm-rpc.1.001898A997F875.0.LOW_BAT
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0206138.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.1.001898A997F875.1.ALARMSTATE
                  vis.js:3311 Create inner vis object hm-rpc.1.000D18A9A5AD4A.34.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1270762.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1273385.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1275465.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0750513.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0067234.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0053807.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.1.000D18A9A5AD4A.18.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0206138.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0066617.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0066617.0.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.1.00105BE98B2128.3.STATE
                  vis.js:3311 Create inner vis object hm-rpc.1.00105BE98B2128.0.LOW_BAT
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1273385.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0750513.1.STATE
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.Klingelzähler
                  vis.js:3311 Create inner vis object hm-rega.1.42350
                  vis.js:3311 Create inner vis object hm-rpc.1.000ADB3393B82B.3.ACOUSTIC_ALARM_ACTIVE
                  vis.js:3311 Create inner vis object 0_userdata.0.Raspi_Display_Temperatur
                  vis.js:3311 Create inner vis object hm-rega.1.37902
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommen_Menge_heute
                  vis.js:3311 Create inner vis object mihome-vacuum.0.control.fan_power
                  vis.js:3311 Create inner vis object mihome-vacuum.0.info.battery
                  vis.js:3311 Create inner vis object mihome-vacuum.0.info.error
                  vis.js:3311 Create inner vis object mihome-vacuum.0.consumable.filter_reset
                  vis.js:3311 Create inner vis object mihome-vacuum.0.consumable.main_brush_reset
                  vis.js:3311 Create inner vis object mihome-vacuum.0.consumable.sensors_reset
                  vis.js:3311 Create inner vis object mihome-vacuum.0.consumable.side_brush_reset
                  vis.js:3311 Create inner vis object mihome-vacuum.0.consumable.water_filter_reset
                  vis.js:3311 Create inner vis object mihome-vacuum.0.info.state
                  vis.js:3311 Create inner vis object mihome-vacuum.0.info.wifi_signal
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_22
                  vis.js:3311 Create inner vis object mihome-vacuum.0.info.water_box
                  vis.js:3311 Create inner vis object mihome-vacuum.0.control.start
                  vis.js:3311 Create inner vis object mihome-vacuum.0.control.pause
                  vis.js:3311 Create inner vis object mihome-vacuum.0.control.home
                  vis.js:3311 Create inner vis object octoprint.0.printjob.progress.completion
                  vis.js:3311 Create inner vis object octoprint.0.temperature.bed.target
                  vis.js:3311 Create inner vis object octoprint.0.info.connection
                  vis.js:3311 Create inner vis object octoprint.0.printjob.progress.printtime
                  vis.js:3311 Create inner vis object octoprint.0.printjob.progress.printtime_left
                  vis.js:3311 Create inner vis object octoprint.0.temperature.tool0.target
                  vis.js:3311 Create inner vis object octoprint.0.temperature.tool0.actual
                  vis.js:3311 Create inner vis object octoprint.0.temperature.bed.actual
                  vis.js:3311 Create inner vis object octoprint.0.printer_status
                  vis.js:3311 Create inner vis object octoprint.0.printjob.file.name
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0377258.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.MEQ0187849.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.1.00021A4994AE51.3.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.REQ0228444.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0066617.1.LOWBAT
                  vis.js:3311 Create inner vis object linux-control.0.Raspi4VisDisplay.control.restart
                  vis.js:3311 Create inner vis object linux-control.0.command.execute
                  vis.js:3311 Create inner vis object linux-control.0.Raspi4VisDisplay.control.shutdown
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.PV_Lieferung_gestern
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.PV_Lieferung_gesamt_in_Euro
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.PV_Lieferung_gestern_in_Euro
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.PV_Lieferung_bereinigt
                  vis.js:3311 Create inner vis object rpi2.1.temperature.soc_temp
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0750513.1.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.NEQ0442172.1.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0931291.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ0931291.1.LOWBAT
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1275465.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1270762.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0._OEQ1273385.1.STATE
                  vis.js:3311 Create inner vis object hm-rpc.0._OEQ0750513.1.STATE
                  vis.js:3311 Create inner vis object javascript.0.Astro.Zeiten.02 - sunriseEnd
                  vis.js:3311 Create inner vis object javascript.0.Astro.Zeiten.07 - sunset
                  vis.js:3311 Create inner vis object javascript.0.Threshold_EG_rauf
                  vis.js:3311 Create inner vis object javascript.0.Threshold_EG_runter
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.Status_Rollos_EG_oben
                  vis.js:3311 Create inner vis object javascript.0.Verzögerung_EG_rauf
                  vis.js:3311 Create inner vis object javascript.0.Verzögerung_EG_runter
                  vis.js:3311 Create inner vis object javascript.0.Threshold_OG_rauf
                  vis.js:3311 Create inner vis object javascript.0.Threshold_OG_runter
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.Status_Rollos_OG_oben
                  vis.js:3311 Create inner vis object javascript.0.Verzögerung_OG_rauf
                  vis.js:3311 Create inner vis object javascript.0.Verzögerung_OG_runter
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.EG_rauf_Zeittrigger_WT
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.EG_runter_Zeittrigger_WE
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.EG_rauf_Zeittrigger_WE
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.EG_runter_Zeittrigger_WT
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.OG_rauf_Zeittrigger_WT
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.OG_runter_Zeittrigger_WE
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.OG_rauf_Zeittrigger_WE
                  vis.js:3311 Create inner vis object Datenpunkte.piVis.OG_runter_Zeittrigger_WT
                  vis.js:3311 Create inner vis object javascript.0.Dämmerung_EG_runter
                  vis.js:3311 Create inner vis object javascript.0.Dämmerung_EG_rauf
                  vis.js:3311 Create inner vis object hm-rpc.1.000D18A9A5AD4A.38.STATE
                  vis.js:3311 Create inner vis object hm-rpc.1.000D18A9A5AD4A.10.STATE
                  vis.js:3311 Create inner vis object robonect.0.status.battery
                  vis.js:3311 Create inner vis object robonect.0.error.0.message
                  vis.js:3311 Create inner vis object robonect.0.status.stopped
                  vis.js:3311 Create inner vis object robonect.0.status.duration
                  vis.js:3311 Create inner vis object robonect.0.batteries.0.voltage
                  vis.js:3311 Create inner vis object robonect.0.batteries.0.temperature
                  vis.js:3311 Create inner vis object robonect.0.hours.charges
                  vis.js:3311 Create inner vis object robonect.0.batteries.0.current
                  vis.js:3311 Create inner vis object robonect.0.blades.quality
                  vis.js:3311 Create inner vis object robonect.0.blades.days
                  vis.js:3311 Create inner vis object robonect.0.motor.drive.left.current
                  vis.js:3311 Create inner vis object robonect.0.blades.hours
                  vis.js:3311 Create inner vis object robonect.0.motor.blade.current
                  vis.js:3311 Create inner vis object robonect.0.motor.blade.speed
                  vis.js:3311 Create inner vis object robonect.0.motor.drive.right.current
                  vis.js:3311 Create inner vis object robonect.0.motor.drive.right.power
                  vis.js:3311 Create inner vis object robonect.0.motor.drive.left.power
                  vis.js:3311 Create inner vis object robonect.0.motor.drive.right.speed
                  vis.js:3311 Create inner vis object robonect.0.motor.drive.left.speed
                  vis.js:3311 Create inner vis object robonect.0.wlan.signal
                  vis.js:3311 Create inner vis object ping.0.iobroker-nuc.192_168_178_26
                  vis.js:3311 Create inner vis object robonect.0.timer.1.enabled
                  vis.js:3311 Create inner vis object robonect.0.timer.2.enabled
                  vis.js:3311 Create inner vis object robonect.0.error.0.date
                  vis.js:3311 Create inner vis object robonect.0.error.0.time
                  vis.js:3311 Create inner vis object robonect.0.error.Fehler_reset
                  vis.js:3311 Create inner vis object robonect.0.timer.0.end_time
                  vis.js:3311 Create inner vis object robonect.0.timer.2.start_time
                  vis.js:3311 Create inner vis object robonect.0.timer.2.end_time
                  vis.js:3311 Create inner vis object robonect.0.timer.1.start_time
                  vis.js:3311 Create inner vis object robonect.0.timer.1.end_time
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.monday
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.tuesday
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.wednesday
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.thursday
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.friday
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.saturday
                  vis.js:3311 Create inner vis object robonect.0.timer.0.weekdays.sunday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.monday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.tuesday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.wednesday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.thursday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.friday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.saturday
                  vis.js:3311 Create inner vis object robonect.0.timer.1.weekdays.sunday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.monday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.tuesday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.wednesday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.thursday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.friday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.saturday
                  vis.js:3311 Create inner vis object robonect.0.timer.2.weekdays.sunday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.weekdays.sunday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.weekdays.saturday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.weekdays.friday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.weekdays.thursday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.weekdays.tuesday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.weekdays.monday
                  vis.js:3311 Create inner vis object robonect.0.timer.3.enabled
                  vis.js:3311 Create inner vis object robonect.0.timer.3.start_time
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WT7WH590-68A40E1CD4C5.programs.selected.BSH_Common_Root_SelectedProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WT7WH590-68A40E1CD4C5.programs.active.options.BSH_Common_Option_RemainingProgramTime
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WT7WH590-68A40E1CD4C5.commands.BSH_Common_Command_StopProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WT7WH590-68A40E1CD4C5.commands.BSH_Common_Command_ResumeProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WT7WH590-68A40E1CD4C5.commands.BSH_Common_Command_PauseProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WM4YH741-68A40E1D98E8.commands.BSH_Common_Command_ResumeProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WM4YH741-68A40E1D98E8.commands.BSH_Common_Command_StopProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WM4YH741-68A40E1D98E8.commands.BSH_Common_Command_PauseProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WM4YH741-68A40E1D98E8.programs.selected.BSH_Common_Root_SelectedProgram
                  vis.js:3311 Create inner vis object homeconnect.0.SIEMENS-WM4YH741-68A40E1D98E8.programs.selected.options.BSH_Common_Option_RemainingProgramTime
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.TEMPERATURE
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.HUMIDITY
                  vis.js:3311 Create inner vis object hm-rpc.0.OEQ1962485.1.RAIN_COUNTER
                  vis.js:3311 Create inner vis object 0_userdata.0.Regenmenge_aktueller_Monat
                  vis.js:3311 Create inner vis object 0_userdata.0.Regenmenge_letzter_Monat
                  vis.js:3311 Create inner vis object 0_userdata.0.Regenmenge_aktuelles_Jahr
                  vis.js:3311 Create inner vis object time-switch.0.onoff.0.data
                  vis.js:3311 Create inner vis object time-switch.0.onoff.0.enabled
                  vis.js:3311 Create inner vis object time-switch.0.onoff.1.data
                  vis.js:3311 Create inner vis object time-switch.0.onoff.1.enabled
                  vis.js:3311 Create inner vis object time-switch.0.onoff.2.data
                  vis.js:3311 Create inner vis object time-switch.0.onoff.2.enabled
                  vis.js:3311 Create inner vis object hm-rpc.0.KEQ0365416.Füllstand_in_Liter
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommene_Menge_letztes_Jahr
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommene_Menge_gestern
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommene_Menge_dieser_Monat
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommene_Menge_dieses_Jahr
                  vis.js:3311 Create inner vis object 0_userdata.0.Zisterne_entnommene_Menge_letzter_Monat
                  jquery-1.11.2.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
                  send @ jquery-1.11.2.min.js:4
                  jquery-1.11.2.min.js:4 Failed to load resource: the server responded with a status of 404 (Not Found)
                  conn.js:1256 Error: can't render tplPlump_tank_simple w00182 on "a_Test_View":
                  conn.js:1256 Error: 0 - Error: can.view: No template or empty template:tplPlump_tank_simple.ejsError: can.view: No template or empty template:tplPlump_tank_simple.ejs
                  conn.js:1256 Error: 1 -     at u (http://192.168.178.84:8082/vis/lib/js/can.custom.min.js:58:256)
                  conn.js:1256 Error: 2 -     at Object.error (http://192.168.178.84:8082/vis/lib/js/can.custom.min.js:58:953)
                  conn.js:1256 Error: 3 -     at j (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:2:27295)
                  conn.js:1256 Error: 4 -     at Object.fireWith [as rejectWith] (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:2:28108)
                  conn.js:1256 Error: 5 -     at x (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:4:22086)
                  conn.js:1256 Error: 6 -     at b (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:4:25980)
                  conn.js:1256 Error: 7 -     at Object.send (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:4:26084)
                  conn.js:1256 Error: 8 -     at Object.ajax (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:4:21520)
                  conn.js:1256 Error: 9 -     at o (http://192.168.178.84:8082/vis/lib/js/can.custom.min.js:58:899)
                  conn.js:1256 Error: 10 -     at http://192.168.178.84:8082/vis/lib/js/can.custom.min.js:46:3358
                  index.html:16561 Version vis-timeandweather: 1.1.7
                  hqwidgets.js:906 Version vis-hqwidgets: 1.1.7
                  conn.js:1256 Error: can't render tplPlump_pipe_H w00442 on "FritzBox":
                  conn.js:1256 Error: 0 - Error: can.view: No template or empty template:tplPlump_pipe_H.ejsError: can.view: No template or empty template:tplPlump_pipe_H.ejs
                  data.js:429 Sun Aug 08 2021 16:51:22 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:22 GMT+0200 (Mitteleuropäische Sommerzeit)
                  2data.js:429 Sat Aug 14 2021 16:51:22 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:22 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:429 Thu Jul 15 2021 16:51:24 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:24 GMT+0200 (Mitteleuropäische Sommerzeit)
                  conn.js:1256 Error: can't render tplPlump_tank_simple w01786 on "Octoprint":
                  data.js:429 Sat Aug 14 2021 16:51:24 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:24 GMT+0200 (Mitteleuropäische Sommerzeit)
                  2data.js:429 Sat Aug 14 2021 16:51:24 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:24 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:429 Thu Jul 15 2021 16:51:27 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:27 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:429 Sun Aug 01 2021 16:51:27 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:27 GMT+0200 (Mitteleuropäische Sommerzeit)
                  2data.js:429 Fri Aug 13 2021 16:51:27 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:27 GMT+0200 (Mitteleuropäische Sommerzeit)
                  ​ Sat Aug 14 2021 16:51:29 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:29 GMT+0200 (Mitteleuropäische Sommerzeit)
                  ​ Sat Aug 14 2021 16:51:28 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:28 GMT+0200 (Mitteleuropäische Sommerzeit)
                  app-6f06d3c165.js:3 [TEME]: volumio3 [VARIANT]: volumio
                  fbevents.js:25 Uncaught DOMException: Failed to read the 'sessionStorage' property from 'Window': Access is denied for this document.
                      at https://connect.facebook.net/en_US/fbevents.js:25:2206
                      at https://connect.facebook.net/en_US/fbevents.js:25:3896
                      at Object.SignalsFBEvents.plugins.iwlbootstrapper (https://connect.facebook.net/en_US/fbevents.js:25:3916)
                      at Function.f.__fbeventsModules.f.getFbeventsModules (https://connect.facebook.net/en_US/fbevents.js:24:2534)
                      at https://connect.facebook.net/en_US/fbevents.js:25:3940
                      at https://connect.facebook.net/en_US/fbevents.js:25:4174
                      at https://connect.facebook.net/en_US/fbevents.js:25:4178
                  ​ Sat Aug 14 2021 16:51:33 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:33 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:429 Sat Aug 14 2021 16:51:34 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:34 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:429 Thu Jul 15 2021 16:51:39 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:39 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:429 Sun Aug 01 2021 16:51:54 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:54 GMT+0200 (Mitteleuropäische Sommerzeit)
                  time-switch.js:52 a
                  time-switch.js:55 Widget not found, waiting ...
                  createOnOffWidget @ time-switch.js:55
                  time-switch.js:52 a
                  data.js:429 Sat Aug 14 2021 16:51:54 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:51:54 GMT+0200 (Mitteleuropäische Sommerzeit)
                  time-switch.js:52 a
                  OnOffScheduleWidget.js:120 widget id change
                  OnOffScheduleWidget.js:127 old settings
                  OnOffScheduleWidget.js:128 undefined
                  OnOffScheduleWidget.js:227 new settings
                  OnOffScheduleWidget.js:228 a
                  OnOffScheduleWidget.js:235 sending change switched oids
                  OnOffScheduleWidget.js:247 sending change switched values
                  time-switch.js:52 a
                  time-switch.js:52 a
                  time-switch.js:52 a
                  time-switch.js:52 a
                  time-switch.js:52 a
                  conn.js:1256 Error: can't render tplPlump_tank_simple w00503 on "Zisterne":
                  vis.js:3067 Uncaught DOMException: Blocked a frame with origin "http://192.168.178.84:8082" from accessing a cross-origin frame.
                      at HTMLIFrameElement.<anonymous> (http://192.168.178.84:8082/vis/js/vis.js:3067:40)
                      at Function.each (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:2:2975)
                      at m.fn.init.each (http://192.168.178.84:8082/lib/js/jquery-1.11.2.min.js:2:835)
                      at Object.updateIframeZoom (http://192.168.178.84:8082/vis/js/vis.js:3066:25)
                      at Object.postChangeView (http://192.168.178.84:8082/vis/js/vis.js:1947:14)
                      at http://192.168.178.84:8082/vis/js/vis.js:1896:22
                      at http://192.168.178.84:8082/vis/js/vis.js:990:35
                  (anonymous) @ vis.js:3067
                  each @ jquery-1.11.2.min.js:2
                  updateIframeZoom @ vis.js:3066
                  postChangeView @ vis.js:1947
                  (anonymous) @ vis.js:1896
                  (anonymous) @ vis.js:990
                  setTimeout (async)
                  (anonymous) @ vis.js:988
                  subscribeStates @ vis.js:2857
                  renderView @ vis.js:844
                  changeView @ vis.js:1889
                  (anonymous) @ vis.js:712
                  renderViews @ vis.js:801
                  (anonymous) @ vis.js:807
                  setTimeout (async)
                  (anonymous) @ vis.js:2881
                  (anonymous) @ conn.js:801
                  r.onack @ socket.io.js:8
                  r.onpacket @ socket.io.js:8
                  (anonymous) @ socket.io.js:8
                  r.emit @ socket.io.js:6
                  r.ondecoded @ socket.io.js:6
                  a.add @ socket.io.js:6
                  r.ondata @ socket.io.js:6
                  r.onPacket @ socket.io.js:6
                  (anonymous) @ socket.io.js:6
                  r.onPacket @ socket.io.js:7
                  r.onData @ socket.io.js:7
                  ws.onmessage @ socket.io.js:8
                  2VM29540 flot.js:1 Tue Jun 15 2021 16:52:02 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:52:02 GMT+0200 (Mitteleuropäische Sommerzeit)
                  2DevTools failed to load source map: Could not load content for http://192.168.178.84:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                      at http://192.168.178.84:8082/vis/js/vis.js:1882:26
                  (anonymous) @ vis.js:1882
                  setTimeout (async)
                  changeView @ vis.js:1855
                  (anonymous) @ vis.js:2696
                  setTimeout (async)
                  orientationChange @ vis.js:2692
                  (anonymous) @ vis.js:3684
                  setTimeout (async)
                  (anonymous) @ index.html:753
                  dispatch @ jquery-1.11.2.min.js:3
                  r.handle @ jquery-1.11.2.min.js:3
                  2VM63734 flot.js:1 Tue Jun 15 2021 16:52:26 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:52:26 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:798 on time
                  3data.js:429 Fri Aug 13 2021 16:52:37 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:52:37 GMT+0200 (Mitteleuropäische Sommerzeit)
                  2vis.js:3067 Uncaught DOMException: Blocked a frame with origin "http://192.168.178.84:8082" from accessing a cross-origin frame.
                  setTimeout (async)
                  2data.js:429 Tue Jun 15 2021 16:53:08 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:53:08 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:798 on time
                  data.js:429 Sun Aug 08 2021 16:53:25 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:53:25 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:798 on time
                  3data.js:429 Fri Aug 13 2021 16:53:36 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:53:36 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:798 on time
                  3data.js:429 Fri Aug 13 2021 16:54:36 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:54:36 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:798 on time
                  data.js:429 Sun Aug 08 2021 16:55:25 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:55:25 GMT+0200 (Mitteleuropäische Sommerzeit)
                  data.js:798 on time
                  3data.js:429 Fri Aug 13 2021 16:55:36 GMT+0200 (Mitteleuropäische Sommerzeit) - Sun Aug 15 2021 16:55:36 GMT+0200 (Mitteleuropäische Sommerzeit)
                    @fuso
                    free -ht --mega
                    Swap:            99M          0B         99M
                    echad@chet:~ $
                    fuso
                    @thomas-braun sagte in Vis starten und Viewechsel dauern sehr lange:
                    free -ht --mega
                    pi@raspi4VisDisplay:~ $ free -ht --mega
                    Mem:           1,9G        903M        192M         70M        776M        828M
                    Swap:           15G          0B         15G
                    Total:          16G        903M         15G
                    Ja, denke mal ich muss da komplett abspecken. Trotzdem seltsam. Das ganze ist erst seit ein paar Wochen soo träge.
                    Übrigends IoBroker ist immer aktuell. Aber nur stable Versionen.
                    haselchenH Thomas BraunT 2 Antworten Letzte Antwort
                    • F fuso
                      free -ht --mega
                      Swap:           15G          0B         15G
                      Total:          16G        903M         15G
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @fuso
                      Wenn du das schon so machst mit dem SWAP (wie @Thomas-Braun schon schrieb, völlig unnötig)
                      dann hätte ich es doch umgedreht. 15GB für Iobroker und 2GB SWAP
                      • F fuso
                        free -ht --mega
                        Swap:           15G          0B         15G
                        Total:          16G        903M         15G
                        @fuso
                        Die Speichersituation schaut doch überraschend gut aus. Swap wird nicht genutzt.
                        Da würde ich eher die Bremse im vis suchen. Da scheint einiges krumm zu sein. Da hab ich aber keine Ahnung von.
                        F 1 Antwort Letzte Antwort
                        • haselchenH haselchen
                          @fuso
                          @haselchen sagte in Vis starten und Viewechsel dauern sehr lange:
                          Und sie 13GB lötet er dann auf den Raspberry drauf, oder wie soll dort RAM auf 15 GB gebracht werden?
                            @fuso
                            fuso
                            Jede Erkenntnis bringt mich näher an die Lösung.
                            Vielen dank für Deine Hilfe.
                            Vielleicht fällt ja noch jemanden was ein.
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              Sorry, bin vom Speicher ausgegangen.
                              Die 2GB sind trotzdem knapp bemessen.
                              Wie du schon schriebst, wäre vermutlich die 4GB Variante die bessere Wahl.
                              • F fuso
                                @liv-in-sky
                                time-switch.js:52 a
                                time-switch.js:52 a
                                time-switch.js:52 a
                                time-switch.js:52 a
                                time-switch.js:52 a
                                time-switch.js:52 a
                                time-switch.js:52 a
                                time-switch.js:52 a
                                setTimeout (async)
                                setTimeout (async)
                                setTimeout (async)
                                setTimeout (async)
                                setTimeout (async)
                                data.js:798 on time
                                setTimeout (async)
                                data.js:798 on time
                                data.js:798 on time
                                data.js:798 on time
                                data.js:798 on time
                                data.js:798 on time
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @fuso
                                weißt du wo dieses widget benutzt wird
                                mal rausnehmen, wenn du es findest
                                dieser fehler mt facebook sagt mir nichts - was kann das in der vis sein
                                ein widget vom time-switch adapter - stimmt auch was nicht
                                time-switch.js:52 a
                                hier irgendwas mit iframe
                                da vielleicht mal ansetzen und diese fehler bereinigen
                                • F fuso
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @fuso
                                  zur not mal ein neues project in der vis anlegen und ein, zwei einfache views hineinkopieren und dann dieses project mal testen - ob das auch sooo langsam ist
                                  dann weißt du, ob die fehler ein problem sind
                                    @fuso
                                    time-switch.js:52 a
                                    fuso
                                    @liv-in-sky sagte in Vis starten und Viewechsel dauern sehr lange:
                                    @fuso
                                    **Da war irgendwo eine Leiche drin. Das war in mehreren Views. Denke ich habe alle gefunden. Sind weg.
                                    Habe keine Ahnung wie der Facebook Sch.. da reinkommt. Bin nicht bei Facebook und klick normalerweise auch alles weg was damit zu tun hat. Wie könnte ich denn da weiter kommen?
                                    die time switch widget habe ich alle rausgeworfen. Da hatte ich sowieso keine Freude daran
                                    time-switch.js:52 a
                                    Könntest Du mir da noch einen Tip geben, wie ich den besser eingrenzen kann?
                                    • F fuso
                                      @fuso
                                      time-switch.js:52 a
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @fuso
                                      facebook:
                                      nur das gegoogelt
                                      https://stackoverflow.com/questions/24456891/iframe-in-chrome-error-uncaught-securityerror-failed-to-read-the-sessionstora
                                      iframe:
                                      hast du iframe widget am laufen
                                      oder irgendwas, was eine fremde webseite anzeigt (kamera,flot, webseiten,...)
                                      ist schwierig - hatte z.b mal fehler mit dem map widget -suchte ich auch lange danach
                                        @fuso
                                        facebook:
                                        nur das gegoogelt
                                        iframe:
                                        fuso
                                        @liv-in-sky
                                        Schritt für Schritt komme ich weiter.
                                        Ob Du´s glaubst oder nicht, vor ca. 1,5h hatten wir ein schweres Gewitter. Mitten unterm debuggen hat irgendwo in einem Verteiler der Blitz eingeschlagen. Telefon ging nicht mehr und der strom war auch weg für ein paar Minuten. Und was soll ich sagen, mein schönes 13" Touchdisplay für die Vis hat´s zerschossen.
                                        Gottseidank hatte ich noch mein altes 10" rumliegen. Wusste doch ich brauch das nochmal.
                                        Dank Deiner Hilfe habe ich nur noch einen Eintrag im Browser log. Siehe unten. Ist auch gefühlt schon schneller das Umschalten. Ist das so wie Du es mal hattest. Wie finde ich denn raus, welche ifram das ist?
                                        • F fuso
                                          @liv-in-sky
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @fuso nutzt du flot
                                          ps: is ja blöd mit dem 13 "er
