  4. [gelöst]Benötige Hilfe, Adapter lassen sich nicht mehr updaten
    5.6k
31 Beiträge 5 Kommentatoren 5.7k Aufrufe
    SigiMOE
    Hier mal noch was, was nicht funktioniert hat : npm install iobroker.js-controller –production
    pi@raspberrypi:/opt/iobroker $ npm cache clean
    pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller --production
    npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
    ! > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
    node-gyp rebuild
    ! make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
    CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    /usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1plus: symbol lookup error: /usr/lib/arm-linux-gnueabihf/libmpfr.so.4: undefined symbol: __g?rfR_one
    unix_dgram.target.mk:92: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
    make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack at emitTwo (events.js:106:13)
    gyp ERR! stack at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
    gyp ERR! System Linux 4.4.21-v7+
    gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! node -v v6.9.4
    gyp ERR! node-gyp -v v3.5.0
    gyp ERR! not ok
    ! > iobroker.js-controller@0.15.3 install /opt/iobroker/node_modules/iobroker.js-controller
    node lib/setup.js setup first
    ! array-flatten@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/array-flatten -> node_modules/array-flatten
    base64-url@1.3.3 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe/node_modules/base64-url -> node_modules/base64-url
    bytes@2.4.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/bytes -> node_modules/bytes
    connect-flash@0.1.1 node_modules/iobroker.admin/node_modules/connect-flash -> node_modules/connect-flash
    content-type@1.0.2 node_modules/iobroker.admin/node_modules/body-parser/node_modules/content-type -> node_modules/content-type
    cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/cookie-parser/node_modules/cookie-signature -> node_modules/cookie-signature
    cookie-parser@1.4.3 node_modules/iobroker.admin/node_modules/cookie-parser -> node_modules/cookie-parser
    depd@1.1.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/depd -> node_modules/depd
    destroy@1.0.4 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/destroy -> node_modules/destroy
    ee-first@1.1.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/on-finished/node_modules/ee-first -> node_modules/ee-first
    encodeurl@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/encodeurl -> node_modules/encodeurl
    escape-html@1.0.3 node_modules/iobroker.admin/node_modules/express/node_modules/escape-html -> node_modules/escape-html
    etag@1.7.0 node_modules/iobroker.admin/node_modules/express/node_modules/etag -> node_modules/etag
    ms@0.7.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/debug/node_modules/ms -> node_modules/express/node_modules/ms
    debug@2.2.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/debug -> node_modules/express/node_modules/debug
    qs@6.2.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/qs -> node_modules/express/node_modules/qs
    ms@0.7.1 node_modules/iobroker.admin/node_modules/express/node_modules/debug/node_modules/ms -> node_modules/finalhandler/node_modules/ms
    debug@2.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/debug -> node_modules/finalhandler/node_modules/debug
    forwarded@0.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr/node_modules/forwarded -> node_modules/forwarded
    fresh@0.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/fresh -> node_modules/fresh
    • isarray@0.0.1 node_modules/has-binary/node_modules/isarray
    • inherits@2.0.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/inherits
    • setprototypeof@1.0.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/setprototypeof
    • http-errors@1.5.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors
    • iconv-lite@0.4.13 node_modules/iobroker.admin/node_modules/body-parser/node_modules/iconv-lite
    • raw-body@2.1.7 node_modules/iobroker.admin/node_modules/body-parser/node_modules/raw-body
    • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/mime-types/node_modules/mime-db
    • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/mime-types
    • type-is@1.6.13 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is
    • body-parser@1.15.2 node_modules/iobroker.admin/node_modules/body-parser
    • cookie@0.3.1 node_modules/iobroker.admin/node_modules/cookie-parser/node_modules/cookie
    • cookie@0.3.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/cookie
    • cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/express-session/node_modules/cookie-signature
    • crc@3.4.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/crc
    • ms@0.7.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/debug/node_modules/ms
    • depd@1.1.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
    • parseurl@1.3.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/parseurl
    • utils-merge@1.0.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/utils-merge
    • express-session@1.14.2 node_modules/iobroker.admin/node_modules/express-session
    • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/mime-types/node_modules/mime-db
    • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/mime-types
    • negotiator@0.6.1 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/negotiator
    • accepts@1.3.3 node_modules/iobroker.admin/node_modules/express/node_modules/accepts
    • content-disposition@0.5.1 node_modules/iobroker.admin/node_modules/express/node_modules/content-disposition
    • content-type@1.0.2 node_modules/iobroker.admin/node_modules/express/node_modules/content-type
    • cookie@0.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/cookie
    • cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/express/node_modules/cookie-signature
    • depd@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/depd
    • statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler/node_modules/statuses
    • unpipe@1.0.0 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler/node_modules/unpipe
    • ee-first@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/on-finished/node_modules/ee-first
    • on-finished@2.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/on-finished
    • finalhandler@0.5.0 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler
    • ipaddr.js@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr/node_modules/ipaddr.js
    • proxy-addr@1.1.2 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr
    • qs@6.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/qs
    • inherits@2.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors/node_modules/inherits
    • setprototypeof@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors/node_modules/setprototypeof
    • mime@1.3.4 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/mime
    • statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/statuses
    • http-errors@1.5.0 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors
    • send@0.14.1 node_modules/iobroker.admin/node_modules/express/node_modules/send
    • serve-static@1.11.1 node_modules/iobroker.admin/node_modules/express/node_modules/serve-static
    • media-typer@0.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/media-typer
    • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/mime-types/node_modules/mime-db
    • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/mime-types
    • type-is@1.6.13 node_modules/iobroker.admin/node_modules/express/node_modules/type-is
    • express@4.14.0 node_modules/iobroker.admin/node_modules/express
    • passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport-local/node_modules/passport-strategy
    • aws-sign2@0.6.0 node_modules/iobroker.admin/node_modules/request/node_modules/aws-sign2
    • aws4@1.5.0 node_modules/iobroker.admin/node_modules/request/node_modules/aws4
    • caseless@0.11.0 node_modules/iobroker.admin/node_modules/request/node_modules/caseless
    • delayed-stream@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
    • combined-stream@1.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/combined-stream
    • extend@3.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/extend
    • forever-agent@0.6.1 node_modules/iobroker.admin/node_modules/request/node_modules/forever-agent
    • asynckit@0.4.0 node_modules/iobroker.admin/node_modules/request/node_modules/form-data/node_modules/asynckit
    • ansi-styles@2.2.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/ansi-styles
    • escape-string-regexp@1.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/escape-string-regexp
    • ansi-regex@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/node_modules/ansi-regex
    • has-ansi@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi
    • ansi-regex@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/node_modules/ansi-regex
    • strip-ansi@3.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi
    • supports-color@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/supports-color
    • chalk@1.1.3 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk
    • graceful-readlink@1.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/commander/node_modules/graceful-readlink
    • commander@2.9.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/commander
    • generate-function@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-function
    • is-property@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/node_modules/is-property
    • generate-object-property@1.2.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property
    • jsonpointer@4.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/jsonpointer
    • pinkie@2.0.4 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/node_modules/pinkie
    • pinkie-promise@2.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise
    • hoek@2.16.3 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/hoek
    • boom@2.10.1 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/boom
    • cryptiles@2.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/cryptiles
    • sntp@1.0.9 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/sntp
    • hawk@3.1.3 node_modules/iobroker.admin/node_modules/request/node_modules/hawk
    • assert-plus@0.2.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/assert-plus
    • extsprintf@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/extsprintf
    • json-schema@0.2.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/json-schema
    • verror@1.3.6 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror
    • jsprim@1.3.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim
    • asn1@0.2.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/asn1
    • assert-plus@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/assert-plus
    • dashdash@1.14.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/dashdash
    • getpass@0.1.6 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/getpass
    • jsbn@0.1.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/jsbn
    • ecc-jsbn@0.1.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/ecc-jsbn
    • jodid25519@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/jodid25519
    • tweetnacl@0.14.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/tweetnacl
    • bcrypt-pbkdf@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/bcrypt-pbkdf
    • sshpk@1.10.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk
    • http-signature@1.1.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature
    • is-typedarray@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/is-typedarray
    • isstream@0.1.2 node_modules/iobroker.admin/node_modules/request/node_modules/isstream
    • json-stringify-safe@5.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/json-stringify-safe
    • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/request/node_modules/mime-types/node_modules/mime-db
    • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/request/node_modules/mime-types
    • form-data@2.1.2 node_modules/iobroker.admin/node_modules/request/node_modules/form-data
    • node-uuid@1.4.7 node_modules/iobroker.admin/node_modules/request/node_modules/node-uuid
    • oauth-sign@0.8.2 node_modules/iobroker.admin/node_modules/request/node_modules/oauth-sign
    • stringstream@0.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/stringstream
    • punycode@1.4.1 node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/node_modules/punycode
    • tough-cookie@2.3.2 node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie
    • tunnel-agent@0.4.3 node_modules/iobroker.admin/node_modules/request/node_modules/tunnel-agent
    • ms@0.7.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug/node_modules/ms
    • debug@2.2.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug
    • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/mime-types/node_modules/mime-db
    • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/mime-types
    • negotiator@0.6.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/negotiator
    • accepts@1.3.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts
    • base64id@0.1.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/base64id
    • after@0.8.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after
    • arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/arraybuffer.slice
    • base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer
    • blob@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/blob
    • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary/node_modules/isarray
    • has-binary@0.1.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary
    • wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/wtf-8
    • engine.io-parser@1.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser
    • options@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/options
    • ultron@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/ultron
    • ws@1.1.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
    • engine.io@1.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io
    • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/has-binary/node_modules/isarray
    • has-binary@0.1.7 node_modules/iobroker.admin/node_modules/socket.io/node_modules/has-binary
    • benchmark@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/benchmark
    • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/component-emitter
    • debug@0.7.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/debug
    • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/isarray
    • json3@3.2.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/json3
    • socket.io-parser@2.2.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser
    • socket.io-adapter@0.4.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter
    • backo2@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/backo2
    • component-bind@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-bind
    • component-emitter@1.2.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-emitter
    • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter
    • component-inherit@0.0.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-inherit
    • after@0.8.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/after
    • arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/arraybuffer.slice
    • base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/base64-arraybuffer
    • blob@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/blob
    • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary/node_modules/isarray
    • has-binary@0.1.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary
    • wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/wtf-8
    • engine.io-parser@1.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser
    • has-cors@1.1.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/has-cors
    • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson/node_modules/better-assert/node_modules/callsite
    • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson/node_modules/better-assert
    • parsejson@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson
    • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs/node_modules/better-assert/node_modules/callsite
    • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs/node_modules/better-assert
    • parseqs@0.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs
    • options@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/options
    • ultron@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/ultron
    • ws@1.1.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
    • xmlhttprequest-ssl@1.5.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/xmlhttprequest-ssl
    • yeast@0.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/yeast
    • indexof@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/indexof
    • object-component@0.0.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/object-component
    • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/node_modules/better-assert/node_modules/callsite
    • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/node_modules/better-assert
    • parseuri@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri
    • engine.io-client@1.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client
    • to-array@0.1.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/to-array
    • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter
    • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/isarray
    • json3@3.3.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/json3
    • socket.io-parser@2.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser
    • socket.io-client@1.5.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client
    • socket.io@1.5.1 node_modules/iobroker.admin/node_modules/socket.io
    • xtend@4.0.1 node_modules/iobroker.admin/node_modules/xtend
    • is-my-json-valid@2.15.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid
    • har-validator@2.0.6 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator
    • request@2.78.0 node_modules/iobroker.admin/node_modules/request
      media-typer@0.3.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/media-typer -> node_modules/media-typer
      merge-descriptors@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/merge-descriptors -> node_modules/merge-descriptors
      methods@1.1.2 node_modules/iobroker.admin/node_modules/express/node_modules/methods -> node_modules/methods
      on-finished@2.3.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/on-finished -> node_modules/on-finished
      on-headers@1.0.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/on-headers -> node_modules/on-headers
      parseurl@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/parseurl -> node_modules/parseurl
      passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport/node_modules/passport-strategy -> node_modules/passport-strategy
      passport-local@1.0.0 node_modules/iobroker.admin/node_modules/passport-local -> node_modules/passport-local
      passport.socketio@3.7.0 node_modules/iobroker.admin/node_modules/passport.socketio -> node_modules/passport.socketio
      path-to-regexp@0.1.7 node_modules/iobroker.admin/node_modules/express/node_modules/path-to-regexp -> node_modules/path-to-regexp
      pause@0.0.1 node_modules/iobroker.admin/node_modules/passport/node_modules/pause -> node_modules/pause
      passport@0.3.2 node_modules/iobroker.admin/node_modules/passport -> node_modules/passport
      random-bytes@1.0.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe/node_modules/random-bytes -> node_modules/random-bytes
      range-parser@1.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/range-parser -> node_modules/range-parser
      qs@6.3.0 node_modules/iobroker.admin/node_modules/request/node_modules/qs -> node_modules/request/node_modules/qs
      ms@0.7.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/ms -> node_modules/send/node_modules/debug/node_modules/ms
      debug@2.2.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/debug -> node_modules/send/node_modules/debug
    • isarray@0.0.1 node_modules/socket.io-parser/node_modules/isarray
      statuses@1.3.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/statuses -> node_modules/statuses
      uid-safe@2.1.3 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe -> node_modules/uid-safe
      unpipe@1.0.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/raw-body/node_modules/unpipe -> node_modules/unpipe
      utils-merge@1.0.0 node_modules/iobroker.admin/node_modules/express/node_modules/utils-merge -> node_modules/utils-merge
      vary@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/vary -> node_modules/vary
      iobroker.core@1.0.0 /opt/iobroker
      └─┬ iobroker.js-controller@0.15.3
      ├─┬ iobroker.admin@1.6.11
      │ ├─┬ body-parser@1.16.0
      │ │ ├── debug@2.6.0
      │ │ ├─┬ http-errors@1.5.1
      │ │ │ └── setprototypeof@1.0.2
      │ │ ├── iconv-lite@0.4.15
      │ │ ├── qs@6.2.1
      │ │ ├── raw-body@2.2.0
      │ │ └── type-is@1.6.14
      │ ├─┬ express@4.14.1
      │ │ ├── content-disposition@0.5.2
      │ │ ├── finalhandler@0.5.1
      │ │ ├─┬ proxy-addr@1.1.3
      │ │ │ └── ipaddr.js@1.2.0
      │ │ ├── send@0.14.2
      │ │ └── serve-static@1.11.2
      │ └─┬ express-session@1.15.0
      │ └── crc@3.4.4
      ├─┬ jszip@3.1.3
      │ └─┬ readable-stream@2.0.6
      │ └── isarray@1.0.0
      ├─┬ letsencrypt@2.1.8
      │ └─┬ rsa-compat@1.2.7
      │ └─┬ ursa@0.9.4
      │ └── nan@2.5.1
      ├─┬ socket.io@1.7.2
      │ ├── debug@2.3.3
      │ ├─┬ engine.io@1.8.2
      │ │ └── debug@2.3.3
      │ ├─┬ has-binary@0.1.7
      │ │ └── isarray@0.0.1
      │ └─┬ socket.io-adapter@0.5.0
      │ └── debug@2.3.3
      └─┬ socket.io-client@1.7.2
      ├── debug@2.3.3
      └─┬ engine.io-client@1.8.2
      └── debug@2.3.3
    ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    noch eine Idee was ich alles machen könnte ?
      @SigiMOE:
      noch eine Idee was ich alles machen könnte ? `
      Ja!
      Die gleichen Befehle mit sudo absetzen.
      Du bist als user pi angemeldet.
        SigiMOE
        bingo !!!!
        Jetzt geht es wieder….
        #PUHVIELENDANKHABICHECHTNOCHMALGLÜCKGEHABT
        Vielen Dank an alle, Die mir geholfen haben...
        CU bis zum nächsten SUPERGAU
          skorpil
          Brauche zum gleichen Thema Hilfe:
          Ich habe alle oben aufgeführten Schritte durchgeführt, nachdem auch bei mir das update fehlgeschlagen ist.
          Alle Schritte laufen durch, bis auf " sudo npm install iobroker –unsafe-perm "
          da kriege ich dann folgendes Fehlerlog. Kann mir jemand einen Rat geben, wie ich das löse?
          0 info it worked if it ends with ok
          1 verbose cli [ '/usr/bin/nodejs',
          1 verbose cli   '/usr/bin/npm',
          1 verbose cli   'install',
          1 verbose cli   'iobroker',
          1 verbose cli   '--unsafe-perm' ]
          2 info using npm@4.1.2
          3 info using node@v6.9.5
          4 silly loadCurrentTree Starting
          5 silly install loadCurrentTree
          6 silly install readLocalPackageData
          7 silly fetchPackageMetaData iobroker
          8 silly fetchOtherPackageData iobroker
          9 silly cache add args [ 'iobroker', null ]
          10 verbose cache add spec iobroker
          11 silly cache add parsed spec Result {
          11 silly cache add   raw: 'iobroker',
          11 silly cache add   scope: null,
          11 silly cache add   escapedName: 'iobroker',
          11 silly cache add   name: null,
          11 silly cache add   rawSpec: 'iobroker',
          11 silly cache add   spec: '/opt/iobroker/iobroker',
          11 silly cache add   type: 'local' }
          12 silly addLocalTarball shasum (computed) 172d89ea6df6ab508c7b69dc0540b583db07e40c
          13 verbose addTmpTarball /opt/iobroker/iobroker not in flight; adding
          14 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
          15 verbose addTmpTarball validating metadata from /opt/iobroker/iobroker
          16 verbose tar unpack /opt/iobroker/iobroker
          17 verbose tar unpacking to /tmp/npm-17981-2b62b2d6/unpack-0ba91d68
          18 silly gentlyRm /tmp/npm-17981-2b62b2d6/unpack-0ba91d68 is being purged
          19 verbose gentlyRm don't care about contents; nuking /tmp/npm-17981-2b62b2d6/unpack-0ba91d68
          20 silly gunzTarPerm modes [ '755', '644' ]
          21 error not a package /opt/iobroker/iobroker
          22 error addLocal Could not install /opt/iobroker/iobroker
          23 silly fetchPackageMetaData Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
          23 silly fetchPackageMetaData     at Error (native)
          23 silly fetchPackageMetaData  error for iobroker { Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
          23 silly fetchPackageMetaData   errno: -2,
          23 silly fetchPackageMetaData   code: 'ENOENT',
          23 silly fetchPackageMetaData   syscall: 'open',
          23 silly fetchPackageMetaData   path: '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json' }
          24 silly rollbackFailedOptional Starting
          25 silly rollbackFailedOptional Finishing
          26 silly runTopLevelLifecycles Finishing
          27 silly install printInstalled
          28 verbose stack Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
          28 verbose stack     at Error (native)
          29 verbose cwd /opt/iobroker
          30 error Linux 4.4.38-v7+
          31 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker" "--unsafe-perm"
          32 error node v6.9.5
          33 error npm  v4.1.2
          34 error path /tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json
          35 error code ENOENT
          36 error errno -2
          37 error syscall open
          38 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
          39 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
          39 error enoent This is most likely not a problem with npm itself
          39 error enoent and is related to npm not being able to find a file.
          40 verbose exit [ -2, true ]
            @skorpil:
            Kann mir jemand einen Rat geben, wie ich das löse? `
            Leider nein :(
            Ich habe auch in der letzten Woche drei Installationen zerschossen mit diesem Ergebnis.
            @skorpil:
            38 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json' `
            Bei zweien war ich definitiv selber schuld, beim dritten weiss ich es noch nicht warum.
            Leider scheint es so, dass bei dieser Fehlermeldung anscheinen keine Rettung mehr möglich ist.
            Ich habe die SD-Karten zur Seite gelegt und jeweils auf einer neuen Karte neu installiert.
            War für mich nicht lebenswichtig, da es eigentlich nur Testinstallationen waren. Ich wollte irgendwann einmal die iobroker.data aus den alten Installationen in die neuen kopieren, ob dann wieder alles da ist.
            Sorry for bad news :(
            Aber vielleicht hat einer da mehr Glück gehabt.
              skorpil
              Homoran,
              erstmal Danke.
              –-um aber meine Verwirrung jetzt komplett zu machen: iobroker läuft, wenn ich ihn über den browser aufrufe. Allerdings mit js-controller 0.15.3. Und den wollte ich ja updaten.
              Und ganz merkwürdig ist: wenn ich "iobroker stop" eingebe, kommt als Antwort "iobroker Controller daemon is not running". Ja was denn jetzt? Er läuft und läßt sich nicht stoppen? Was ist das?
                @skorpil:
                Homoran,
                erstmal Danke.
                Und ganz merkwürdig ist: wenn ich "iobroker stop" eingebe, kommt als Antwort "iobroker Controller daemon is not running". Ja was denn jetzt? Er läuft und läßt sich nicht stoppen? Was ist das? `
                Vielleicht kommen wir so sogar der Ursache auf die Spur, auch wenn ich mich immer noch als Linux-Noob einordne.
                In allen Installationen lag (weil eben nur Testinstallation) eine tlw. uralte Controller-Version vor.
                Bei einer Installation habe ich den Code, wie er im Admin unter Reiter Hosts angezeigt wird, wenn man auf das Update-Icon klickt, ungeprüft in die Konsole kopiert.
                Leider sind dort Backslashs statt slashs gewesen (cd ****opt****iobroker, anstelle (cd ****/opt/****iobroker).
                Dadurch wurde im Verzeichnis root erneut installiert.
                Wenn da etwas ähnliches bei dir ist, hast du vielleicht auch zwei verschiedene Installationen.
                  skorpil
                  Rainer,
                  das habe ich mir auch gedacht. Es muß ja irgendwo ein iobroker laufen. Nur, wo resp. wie finde ich diese. Gerade lasse ich mein root Verzeichnis nach Dateien "iobroker" durchsuchen. Dauert etwas…
                  Den finde ich gar nicht. Bei mir steht unter hosts nur bei Plattform "Javascript/Node.js" und sonst nichts. oder ich bin zu dumm…
                    @skorpil:
                    oder ich bin zu dumm… `
                    nö, du hast ja jetzt die aktuelle Version.
                    Dieser Button erscheint nur, wenn es eine neuere Version als die installierte gibt.
                      skorpil
                      und die ist "0.15.3" (installiert) und "0.15.3" (verfügbar). Zumindest steht das so unter host.
                      Meine Installation des iobroker findet sich im Verzeichnis /opt/iobroker Sonst finde ich nur noch eine weitere Datei iobroker in user/bin.
                      Ich verstehe es nicht.
                        skorpil
                        Ich bin ein Stückchen weiter: als root kann ich iobroker stoppen, aber nicht als pi. Was sagt uns das?
                          @skorpil:
                          Ich bin ein Stückchen weiter: als root kann ich iobroker stoppen, aber nicht als pi. Was sagt uns das? `
                          Hattest du das Upgrade des controllers als root durchgeführt?
                          Und die Suche nach ioBroker als pi?
                            skorpil
                            Ich weiß es nicht mehr, um ehrlich zu sein. Ich glaube, den Controller Update als pi. Die Suche habe ich sowohl als auch laufen lassen.
                            Ich versuche jetzt den Controller Update als Root…
                              skorpil
                              So, habe jetzt folgendes als root ohn Fehlermeldung hinbekommen:
                              cd /opt/iobroker
                              sudo iobroker stop
                              sudo iobroker update
                              sudo iobroker upgrade.self
                              sudo iobroker start
                              und es läuft. Als root kann ich stoppen und starten.
                              Ich bin jetzt aber dennoch etwas verwirrt.
                              Ich habe die Versionen ich habe node v6.9.5 und npm v4.1.2 drauf. Und im iobroker wird angezeigt Javascript/Node.js in Version 0.15.3. Ist das alles so aktuell?
