  4. [gelöst]Benötige Hilfe, Adapter lassen sich nicht mehr updaten
    5.6k
31 Beiträge 5 Kommentatoren 5.7k Aufrufe
    SigiMOE
    @Homoran:
    @SigiMOE:
    Ich denke da wurde nichts upgedatet ?! `
    Was sagt denn````
    sudo iobroker update
    zumindest bezgl. js-controller?
    Rainer `
    root@raspberrypi:~# sudo iobroker update
    update done
    Adapter "zwave" : 0.4.4
    Adapter "yr" : 1.0.5
    Adapter "yamaha" : 0.2.23
    Adapter "xs1" : 0.5.2
    Adapter "wolf" : 0.9.2
    Adapter "wifilight" : 0.0.36
    Adapter "wm-bus" : 0.1.10
    Adapter "web" : 2.0.0 , installed 1.7.5 [Updateable]
    Adapter "weatherunderground": 1.0.2 , installed 1.0.2
    Adapter "vis-timeandweather": 1.1.7 , installed 1.1.6 [Updateable]
    Adapter "vis-rgraph" : 0.0.2
    Adapter "vis-plumb" : 0.1.6
    Adapter "vis-players" : 0.1.4
    Adapter "vis-metro" : 1.0.4 , installed 1.0.4
    Adapter "vis-map" : 0.1.3
    Adapter "vis-lcars" : 1.0.1
    Adapter "vis-keyboard" : 0.0.2
    Adapter "vis-justgage" : 0.7.1
    Adapter "vis-jqui-mfd" : 1.0.5 , installed 1.0.5
    Adapter "vis-hqwidgets" : 1.0.6 , installed 1.0.6
    Adapter "vis-history" : 0.2.4
    Adapter "vis-google-fonts": 0.1.0
    Adapter "vis-fancyswitch": 1.0.0
    Adapter "vis-colorpicker": 1.1.1
    Adapter "vis-canvas-gauges": 0.1.5
    Adapter "vis-bars" : 0.1.2 , installed 0.1.2
    Adapter "vis" : 0.10.15 , installed 0.10.15
    Adapter "vcard" : 0.0.8
    Adapter "upnp" : 0.3.3
    Adapter "tvspielfilm" : 0.2.2
    Adapter "tr-064" : 0.1.31
    Adapter "text2command" : 1.1.3
    Adapter "terminal" : 0.1.2
    Adapter "telegram" : 1.0.2
    Adapter "tankerkoenig" : 1.0.0 , installed 1.0.0
    Adapter "starline" : 0.2.0
    Adapter "sonos" : 1.4.2
    Adapter "solarwetter" : 0.1.2
    Adapter "socketio" : 1.7.4 , installed 1.7.3 [Updateable]
    Adapter "squeezebox" : 0.1.0
    Adapter "sql" : 1.4.2
    Adapter "simple-api" : 1.3.0
    Adapter "scenes" : 0.2.6
    Adapter "sayit" : 1.4.0
    Adapter "samsung" : 0.0.15
    Adapter "s7" : 0.2.5
    Adapter "rwe-smarthome" : 0.1.11
    Adapter "rpi2" : 0.3.1
    Adapter "rickshaw" : 0.4.4
    Adapter "rflink" : 1.0.8
    Adapter "radar" : 0.7.3
    Adapter "pushover" : 1.0.2
    Adapter "pushsafer" : 0.1.7
    Adapter "pushbullet" : 0.0.11
    Adapter "ping" : 1.2.0
    Adapter "piface" : 0.0.50
    Adapter "phantomjs" : 0.1.2
    Adapter "parser" : 0.1.0
    Adapter "owntracks" : 0.2.0
    Adapter "owfs" : 0.3.4
    Adapter "onkyo" : 0.2.0
    Adapter "nut" : 1.0.0
    Adapter "noolite" : 0.0.1
    Adapter "node-red" : 1.1.6
    Adapter "netatmo" : 1.0.0
    Adapter "mysensors" : 1.0.6
    Adapter "mpd" : 0.2.4
    Adapter "mqtt-client" : 0.3.0
    Adapter "mqtt" : 1.2.5
    Adapter "modbus" : 0.4.7
    Adapter "mobile" : 0.4.10
    Adapter "miele" : 0.0.30
    Adapter "megad" : 1.2.1
    Adapter "lightify" : 0.0.26 , installed 0.0.24 [Updateable]
    Adapter "lgtv" : 1.0.0
    Adapter "kodi" : 0.2.0
    Adapter "knx" : 0.7.3
    Adapter "km200" : 0.4.3
    Controller "js-controller" : 0.15.3 , installed 0.12.2 [Updateable]
    Adapter "javascript" : 3.2.4
    Adapter "innogy-smarthome": 0.1.4
    Adapter "influxdb" : 1.3.1
    Adapter "icons-ultimate-png": 0.1.0
    Adapter "icons-open-icon-library-png": 0.1.3
    Adapter "icons-mfd-svg" : 1.0.2 , installed 1.0.0 [Updateable]
    Adapter "icons-mfd-png" : 1.0.2 , installed 1.0.0 [Updateable]
    Adapter "icons-material-svg": 0.1.0
    Adapter "icons-material-png": 0.1.0
    Adapter "icons-icons8" : 0.0.1
    Adapter "icons-fatcow-hosting": 0.1.0
    Adapter "icons-addictive-flavour-png": 0.1.0
    Adapter "ical" : 1.2.0 , installed 1.2.0
    Adapter "hmm" : 1.0.1
    Adapter "homepilot" : 0.2.0
    Adapter "homekit2" : 0.1.6
    Adapter "hue" : 0.6.0
    Adapter "hm-rpc" : 1.4.1 , installed 1.3.3 [Updateable]
    Adapter "hm-rega" : 1.4.1 , installed 1.3.0 [Updateable]
    Adapter "history" : 1.5.1
    Adapter "hid" : 0.1.11
    Adapter "harmony" : 0.6.0 , installed 0.5.6 [Updateable]
    Adapter "geofency" : 0.1.5
    Adapter "fritzbox" : 0.2.1 , installed 0.2.1
    Adapter "foobar2000" : 0.2.0
    Adapter "feiertage" : 0.3.6
    Adapter "flot" : 1.5.6
    Adapter "find-my-iphone": 0.0.11 , installed 0.0.6 [Updateable]
    Adapter "fhem" : 0.2.2 , installed 0.2.2
    Adapter "epson_stylus_px830": 0.0.2
    Adapter "email" : 1.0.1
    Adapter "dwd" : 2.1.1
    Adapter "cul" : 0.2.2
    Adapter "cloud" : 0.4.2
    Adapter "chromecast" : 1.2.3
    Adapter "botvac" : 0.5.0
    Adapter "b-control-em" : 0.2.1
    Adapter "artnet" : 0.1.6
    Adapter "amazon-dash" : 0.1.2
    Adapter "admin" : 1.6.11 , installed 1.6.7 [Updateable]
      SigiMOE
      @Homoran:
      @fsjoke:
      stoppe mal iobroker und führe im /opt/iobroker verzeichnis ein
      npm install iobroker.js-controller –production `
      am besten vorweg noch ein````
      npm cache clean
      Rainer `
      IOBROKER habe ich gestoppt und
      wenn ich nun npm cache clean eingebe, kommt :
      root@raspberrypi:/opt/iobroker# npm cache clean
      SyntaxError: Unexpected token ILLEGAL
          at exports.runInThisContext (vm.js:53:16)
          at Module._compile (module.js:373:25)
          at Object.Module._extensions..js (module.js:416:10)
          at Module.load (module.js:343:32)
          at Function.Module._load (module.js:300:12)
          at Module.require (module.js:353:17)
          at require (internal/module.js:12:17)
          at Object. <anonymous>(/usr/lib/node_modules/npm/node_modules/request/node_modules/tough-cookie/lib/cookie.js:34:17)
          at Module._compile (module.js:409:26)
      npm ERR! Linux 4.4.21-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "cache" "clean"
      npm ERR! node v4.6.0
      npm ERR! npm  v2.15.9
      npm ERR! Unexpected token ILLEGAL
      npm ERR!
      npm ERR! If you need help, you may report this error at:
      npm ERR!     <https: github.com/npm/issues="">root@raspberrypi:/opt/iobroker#</https:></anonymous>
      und wenn ich npm install iobroker.js-controller –production eingebe kommt :
      root@raspberrypi:/opt/iobroker# npm install iobroker.js-controller --production
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "--production"
      npm ERR!
      ich denke dieses hier macht mir enorme Probleme : npm ERR! Unexpected token ILLEGAL
      • BluefoxB Offline
        BluefoxB Offline
        @SigiMOE:
        @Homoran:
        @fsjoke:
        npm cache clean
        Rainer `
        npm ERR!
        npm ERR!
        ich denke dieses hier macht mir enorme Probleme : npm ERR! Unexpected token ILLEGAL `
        Ich vermute npm ist kaputt.
        Versuch mal neu zu installieren:
        curl https://npmjs.org/install.sh | sudo sh
          SigiMOE
          geht leider nicht….
          root@raspberrypi:~# curl https://npmjs.org/install.sh | sudo sh
            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                           Dload  Upload   Total   Spent    Left  Speed
          100   193  100   193    0     0    264      0 --:--:-- --:--:-- --:--:--   264
          sh: 1: cannot open html: No such file
          sh: 2: Syntax error: redirection unexpected
          root@raspberrypi:~#
          noch eine andere Idee ?
            SigiMOE
            Hi , nochmal,
            Jemand noch eine Idee was ich ausprobieren könnte ?
            CU
            Sigi
            • frankjokeF Offline
              frankjokeF Offline
              frankjoke
              Sigi,
              zuerst eine Frage, warum machst alles als root?
              Ich installiere nur in root wenn's unbeding notwendig ist (wenn man z.B. -g option verwendet).
              npm auf letzten Stand bringen:
              sudo npm install npm@latest -g
              anstatt latest kannst auch 'ne Version angeben.
              und als root auch auf's sudo.
              Da bei dir ein sehr komischer Fehler auftritt der auch nicht wirklich mit ioBroker selbst zu tun hat würde ich:
              a) in /opt/iobroker/node_modules listen welche iobroker* adapter du installiert hast
              b) dann nodejs neu installieren mit curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
              c) sudo apt-get update + upgrade
              d) npm auf letzten Stand bringen: sudo npm install npm@latest -g
              wenn du da schon fehler kriegst dann muss nodejs mit apt-get de-installiert werden und alle Verzeichnisse die nodejs oder npm verwendet gelöscht werden, sind einige :(
              e) dann in /opt/iobroker das Verzeichn is node_modules und die Datei iobroker löschen
              f) dann iobroker neu installieren: sudo npm install iobroker –unsafe-perm
              Da wird js-controller und admin mitinstalliert
              g) dann sollte iobroker (ohne Adapter) wieder laufen bzw starten können, mit iobroker stop stoppen
              h) im /opt/iobroker dann die adapter wieder installieren mit npm install iobroker.adapter --production
              i) iobroker upload all und sudo iobroker start sollte die alte Konfiguration wieder starten wenn nichts im iobroker-data kaputt war.
              Hatte das nur einmal zu machen da mir die SD abgeschmiert ist (seitdem hab ich das Betriebssystem und iobroker nur noch auf USB sticks).
              Frank,
              NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
              Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
                SigiMOE
                @fsjoke:
                Sigi,
                Ich installiere nur in root wenn's unbeding notwendig ist (wenn man z.B. -g option verwendet).. `
                Also, da ich ein Linux Neuling bin, habe ich mir gedacht, dass es besser wäre, da sonst evtl die fehlende Rechte mir ein
                Strich durch die Rechnung machen könnte. Also ohne besondern Grund. Als Pi User leider auch nicht viel besser…
                Wenn ich das "sudo npm install npm@latest -g"eingebe kommt leider immer noch der gleiche Fehler :
                pi@raspberrypi:/opt/iobroker $ sudo npm install npm@latest -g
                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "npm@latest" "-g"
                ! npm ERR! Unexpected token ILLEGAL
                npm ERR!
                npm ERR! <https: github.com/npm/issues="">[1]+ Fertig sudo apt-get update
                pi@raspberrypi:/opt/iobroker $</https:></anonymous>
                >! b-c, also :
                >! b) dann nodejs neu installieren mit curl -sL [https://deb.nodesource.com/setup_6.x](https://deb.nodesource.com/setup_6.x) | sudo -E bash -
                pi@raspberrypi:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                ! ## Installing the NodeSource Node.js v6.x repo...
                ! ## Populating apt-get cache...
                ! + apt-get update
                Holen: 1 http://archive.raspberrypi.org jessie InRelease [22,9 kB]
                Holen: 2 http://mirrordirector.raspbian.org jessie InRelease [14,9 kB]
                Holen: 3 https://deb.nodesource.com jessie InRelease [3.914 B]
                Holen: 4 http://archive.raspberrypi.org jessie/main armhf Packages [141 kB]
                Holen: 5 http://mirrordirector.raspbian.org jessie/main armhf Packages [8.982 kB]
                Holen: 6 https://deb.nodesource.com jessie/main Sources [761 B]
                Holen: 7 https://deb.nodesource.com jessie/main armhf Packages [969 B]
                Holen: 8 http://archive.raspberrypi.org jessie/ui armhf Packages [53,6 kB]
                Holen: 9 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
                Ign http://archive.raspberrypi.org jessie/main Translation-en
                Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
                Ign http://archive.raspberrypi.org jessie/ui Translation-en
                Holen: 10 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 11 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37,5 kB]
                Holen: 12 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70,3 kB]
                Holen: 13 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1.356 B]
                Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
                Holen: 14 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
                Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/main Translation-en
                Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
                Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
                Holen: 15 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Holen: 16 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 17 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 18 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Holen: 19 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 20 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 21 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Holen: 22 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 23 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 24 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Ign https://deb.nodesource.com jessie/main Translation-de_DE
                Holen: 25 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 26 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Ign https://deb.nodesource.com jessie/main Translation-en
                Es wurden 9.329 kB in 28 s geholt (331 kB/s).
                ! ## Confirming "jessie" is supported...
                ! + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_6.x/dists/jessie/Release'
                ! ## Adding the NodeSource signing key to your keyring...
                ! + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                OK
                ! ## Creating apt sources list file for the NodeSource Node.js v6.x repo...
                ! + echo 'deb https://deb.nodesource.com/node_6.x jessie main' > /etc/apt/sources.list.d/nodesource.list
                • echo 'deb-src https://deb.nodesource.com/node_6.x jessie main' >> /etc/apt/sources.list.d/nodesource.list
                ! ## Running apt-get update for you...
                ! + apt-get update
                OK http://mirrordirector.raspbian.org jessie InRelease
                Holen: 1 https://deb.nodesource.com jessie InRelease [3.914 B]
                OK http://archive.raspberrypi.org jessie InRelease
                OK http://mirrordirector.raspbian.org jessie/main armhf Packages
                Holen: 2 https://deb.nodesource.com jessie/main Sources [762 B]
                OK http://mirrordirector.raspbian.org jessie/contrib armhf Packages
                OK http://mirrordirector.raspbian.org jessie/non-free armhf Packages
                OK http://mirrordirector.raspbian.org jessie/rpi armhf Packages
                Holen: 3 https://deb.nodesource.com jessie/main armhf Packages [962 B]
                Holen: 4 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                OK http://archive.raspberrypi.org jessie/main armhf Packages
                Holen: 5 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 6 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 7 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                OK http://archive.raspberrypi.org jessie/ui armhf Packages
                Holen: 8 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 9 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 10 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Holen: 11 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 12 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 13 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Holen: 14 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 15 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Holen: 16 https://deb.nodesource.com jessie/main Translation-de_DE [162 B]
                Holen: 17 https://deb.nodesource.com jessie/main Translation-de [162 B]
                Holen: 18 https://deb.nodesource.com jessie/main Translation-en [162 B]
                Es wurden 5.638 B in 15 s geholt (373 B/s).
                ! ## Run apt-get install nodejs (as root) to install Node.js v6.x and npm
                lief mit 1 Fehler durch…
                ! pi@raspberrypi:/opt/iobroker $ sudo apt-get update && sudo apt-get upgrade Holen: 1 http://mirrordirector.raspbian.org jessie InRelease [14,9 kB] OK https://deb.nodesource.com jessie InRelease OK http://archive.raspberrypi.org jessie InRelease Holen: 2 http://mirrordirector.raspbian.org jessie/main armhf Packages [8.982 kB] OK https://deb.nodesource.com jessie/main Sources OK https://deb.nodesource.com jessie/main armhf Packages Holen: 3 https://deb.nodesource.com jessie/main Translation-de_DE [162 B] OK http://archive.raspberrypi.org jessie/main armhf Packages OK http://archive.raspberrypi.org jessie/ui armhf Packages Holen: 4 https://deb.nodesource.com jessie/main Translation-de [162 B] Holen: 5 https://deb.nodesource.com jessie/main Translation-en [162 B] Holen: 6 https://deb.nodesource.com jessie/main Translation-de_DE [162 B] Holen: 7 https://deb.nodesource.com jessie/main Translation-de [162 B] Holen: 8 https://deb.nodesource.com jessie/main Translation-en [162 B] Holen: 9 https://deb.nodesource.com jessie/main Translation-de_DE [162 B] Holen: 10 https://deb.nodesource.com jessie/main Translation-de [162 B] Holen: 11 https://deb.nodesource.com jessie/main Translation-en [162 B] Ign http://archive.raspberrypi.org jessie/main Translation-de_DE Holen: 12 https://deb.nodesource.com jessie/main Translation-de_DE [162 B] Ign http://archive.raspberrypi.org jessie/main Translation-de Holen: 13 https://deb.nodesource.com jessie/main Translation-de [162 B] Holen: 14 https://deb.nodesource.com jessie/main Translation-en [162 B] Holen: 15 https://deb.nodesource.com jessie/main Translation-de_DE [162 B] Ign https://deb.nodesource.com jessie/main Translation-de_DE Ign http://archive.raspberrypi.org jessie/main Translation-en Holen: 16 https://deb.nodesource.com jessie/main Translation-de [162 B] Ign https://deb.nodesource.com jessie/main Translation-de Holen: 17 https://deb.nodesource.com jessie/main Translation-en [162 B] Ign https://deb.nodesource.com jessie/main Translation-en Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE Ign http://archive.raspberrypi.org jessie/ui Translation-de Ign http://archive.raspberrypi.org jessie/ui Translation-en Holen: 18 http://mirrordirector.raspbian.org jessie/contrib armhf Packages [37,5 kB] Holen: 19 http://mirrordirector.raspbian.org jessie/non-free armhf Packages [70,3 kB] Holen: 20 http://mirrordirector.raspbian.org jessie/rpi armhf Packages [1.356 B] Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE Ign http://mirrordirector.raspbian.org jessie/main Translation-de Ign http://mirrordirector.raspbian.org jessie/main Translation-en Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en Es wurden 9.106 kB in 32 s geholt (284 kB/s). Paketlisten werden gelesen... Fertig Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Paketaktualisierung (Upgrade) wird berechnet... Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt: rlwrap Verwenden Sie »apt-get autoremove«, um es zu entfernen. Fertig Die folgenden Pakete sind zurückgehalten worden: gstreamer1.0-plugins-bad libgl1-mesa-dri libgstreamer-plugins-bad1.0-0 lxpanel lxpanel-data plymouth raspberrypi-sys-mods raspberrypi-ui-mods sonic-pi xserver-xorg-input-all Die folgenden Pakete werden aktualisiert (Upgrade): apt apt-transport-https apt-utils bash bind9-host bluej ca-certificates curl dbus dbus-x11 file gdb gdbserver greenfoot gstreamer1.0-plugins-good libapt-inst1.5 libapt-pkg4.12 libasound2 libasound2-data libbind9-90 libc-bin libc-dev-bin libc6 libc6-dbg libc6-dev libcairo-gobject2 libcairo2 libcurl3 libcurl3-gnutls libdbus-1-3 libdns-export100 libdns100 libdrm-amdgpu1 libdrm-freedreno1 libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl1-mesa libfcgi-perl libgbm1 libgd3 libgl1-mesa-glx libglapi-mesa libgles1-mesa libgles2-mesa libgme0 libgnutls-deb0-28 libgnutls-openssl27 libgudev-1.0-0 libhogweed2 libicu52 libio-socket-ssl-perl libirs-export91 libisc-export95 libisc95 libisccc90 libisccfg-export90 libisccfg90 liblcms2-2 liblightdm-gobject-1-0 liblwres90 libmagic1 libmpg123-0 libnettle4 libnspr4 libnss3 libobrender29 libobt2 libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libpcsclite1 libpng12-0 libpng12-dev libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 libsmbclient libssl1.0.0 libsystemd0 libtevent0 libtiff5 libudev1 libva1 libwayland-client0 libwayland-cursor0 libwayland-server0 libwbclient0 libxfont1 libxml2 libxpm4 libxslt1.1 lightdm locales multiarch-support nodejs nuscratch omxplayer openbox openssl pcmanfm pi-bluetooth pi-package pi-package-data pi-package-session pipanel pishutdown python-pil python-rpi.gpio python3-pil python3-rpi.gpio raspberrypi-bootloader raspberrypi-kernel raspberrypi-net-mods raspi-config raspi-gpio rc-gui samba-common samba-libs sed systemd systemd-sysv tzdata udev va-driver-all vim-common vim-tiny wireless-regdb x11-common xserver-common xserver-xorg xserver-xorg-core xserver-xorg-input-evdev xserver-xorg-input-synaptics xserver-xorg-video-fbdev xserver-xorg-video-fbturbo 139 aktualisiert, 0 neu installiert, 0 zu entfernen und 10 nicht aktualisiert. Es müssen 169 MB an Archiven heruntergeladen werden. Nach dieser Operation werden 9.397 kB Plattenplatz zusätzlich benutzt. Möchten Sie fortfahren? [J/n] j Holen: 1 http://archive.raspberrypi.org/debian/ jessie/main libdrm2 armhf 2.4.71-1+rpi1 [32,4 kB] Holen: 2 http://archive.raspberrypi.org/debian/ jessie/main libdrm-amdgpu1 armhf 2.4.71-1+rpi1 [24,2 kB] Holen: 3 http://archive.raspberrypi.org/debian/ jessie/main libdrm-freedreno1 armhf 2.4.71-1+rpi1 [23,8 kB] Holen: 4 http://archive.raspberrypi.org/debian/ jessie/main libdrm-nouveau2 armhf 2.4.71-1+rpi1 [23,9 kB] Holen: 5 http://mirrordirector.raspbian.org/raspbian/ jessie/main bash armhf 4.3-11+deb8u1 [1.092 kB] Holen: 6 http://archive.raspberrypi.org/debian/ jessie/main libdrm-radeon1 armhf 2.4.71-1+rpi1 [27,8 kB] Holen: 7 https://deb.nodesource.com/node_6.x/ jessie/main nodejs armhf 6.9.4-1nodesource1~jessie1 [8.841 kB] Holen: 8 http://archive.raspberrypi.org/debian/ jessie/main libwayland-client0 armhf 1.11.0-2 [20,0 kB] Holen: 9 http://archive.raspberrypi.org/debian/ jessie/main libwayland-server0 armhf 1.11.0-2 [23,9 kB] Holen: 10 http://archive.raspberrypi.org/debian/ jessie/main libgbm1 armhf 13.0.0-1+rpi1 [55,3 kB] Holen: 11 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-dev-bin armhf 2.19-18+deb8u7 [231 kB] Holen: 12 http://mirrordirector.raspbian.org/raspbian/ jessie/main sed armhf 4.2.2-4+deb8u1 [237 kB] Holen: 13 http://archive.raspberrypi.org/debian/ jessie/main libegl1-mesa armhf 13.0.0-1+rpi1 [97,5 kB] Holen: 14 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc6-dev armhf 2.19-18+deb8u7 [1.724 kB] Holen: 15 http://archive.raspberrypi.org/debian/ jessie/main libgles2-mesa armhf 13.0.0-1+rpi1 [52,4 kB] Holen: 16 http://mirrordirector.raspbian.org/raspbian/ jessie/main libapt-pkg4.12 armhf 1.0.9.8.4 [713 kB] Holen: 17 http://archive.raspberrypi.org/debian/ jessie/main libgles1-mesa armhf 13.0.0-1+rpi1 [46,1 kB] Holen: 18 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc-bin armhf 2.19-18+deb8u7 [1.206 kB] Holen: 19 http://archive.raspberrypi.org/debian/ jessie/main libgl1-mesa-glx armhf 13.0.0-1+rpi1 [156 kB] Holen: 20 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam0g armhf 1.1.8-3.1+deb8u2 [120 kB] Holen: 21 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc6-dbg armhf 2.19-18+deb8u7 [3.179 kB] Holen: 22 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-modules armhf 1.1.8-3.1+deb8u2 [287 kB] Holen: 23 http://mirrordirector.raspbian.org/raspbian/ jessie/main libsystemd0 armhf 215-17+deb8u6 [85,5 kB] Holen: 24 http://archive.raspberrypi.org/debian/ jessie/main libglapi-mesa armhf 13.0.0-1+rpi1 [64,7 kB] Holen: 25 http://archive.raspberrypi.org/debian/ jessie/ui liblightdm-gobject-1-0 armhf 1.10.3-3+rpi [45,5 kB] Holen: 26 http://archive.raspberrypi.org/debian/ jessie/main gdb armhf 7.7.1+dfsg-5+rpi1 [1.964 kB] Holen: 27 http://mirrordirector.raspbian.org/raspbian/ jessie/main libapt-inst1.5 armhf 1.0.9.8.4 [166 kB] Holen: 28 http://mirrordirector.raspbian.org/raspbian/ jessie/main dbus armhf 1.8.22-0+deb8u1 [248 kB] Holen: 29 http://mirrordirector.raspbian.org/raspbian/ jessie/main libc6 armhf 2.19-18+deb8u7 [4.082 kB] Holen: 30 http://mirrordirector.raspbian.org/raspbian/ jessie/main libhogweed2 armhf 2.7.1-5+deb8u2 [117 kB] Holen: 31 http://archive.raspberrypi.org/debian/ jessie/main gdbserver armhf 7.7.1+dfsg-5+rpi1 [205 kB] Holen: 32 http://mirrordirector.raspbian.org/raspbian/ jessie/main file armhf 1:5.22+15-2+deb8u3 [60,1 kB] Holen: 33 http://archive.raspberrypi.org/debian/ jessie/main libcairo2 armhf 1.14.0-2.1+deb8u2+rpi1 [662 kB] Holen: 34 http://mirrordirector.raspbian.org/raspbian/ jessie/main apt armhf 1.0.9.8.4 [1.067 kB] Holen: 35 http://archive.raspberrypi.org/debian/ jessie/main libcairo-gobject2 armhf 1.14.0-2.1+deb8u2+rpi1 [304 kB] Holen: 36 http://mirrordirector.raspbian.org/raspbian/ jessie/main libudev1 armhf 215-17+deb8u6 [53,3 kB] Holen: 37 http://mirrordirector.raspbian.org/raspbian/ jessie/main udev armhf 215-17+deb8u6 [850 kB] Holen: 38 http://archive.raspberrypi.org/debian/ jessie/main libasound2-data all 1.0.28-1+rpi2 [65,2 kB] Holen: 39 http://mirrordirector.raspbian.org/raspbian/ jessie/main liblcms2-2 armhf 2.6-3+deb8u1 [116 kB] Holen: 40 http://archive.raspberrypi.org/debian/ jessie/main libasound2 armhf 1.0.28-1+rpi2 [322 kB] Holen: 41 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-modules-bin armhf 1.1.8-3.1+deb8u2 [101 kB] Holen: 42 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-systemd armhf 215-17+deb8u6 [113 kB] Holen: 43 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd armhf 215-17+deb8u6 [2.212 kB] Holen: 44 http://mirrordirector.raspbian.org/raspbian/ jessie/main libnspr4 armhf 2:4.12-1+debu8u1 [95,5 kB] Holen: 45 http://archive.raspberrypi.org/debian/ jessie/ui libobt2 armhf 3.5.2-8+rpi3 [60,8 kB] Holen: 46 http://archive.raspberrypi.org/debian/ jessie/ui libobrender29 armhf 3.5.2-8+rpi3 [69,7 kB] Holen: 47 http://mirrordirector.raspbian.org/raspbian/ jessie/main systemd-sysv armhf 215-17+deb8u6 [36,3 kB] Holen: 48 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpam-runtime all 1.1.8-3.1+deb8u2 [212 kB] Holen: 49 http://archive.raspberrypi.org/debian/ jessie/main libva1 armhf 1.7.3-2 [46,7 kB] Holen: 50 http://mirrordirector.raspbian.org/raspbian/ jessie/main libwbclient0 armhf 2:4.2.14+dfsg-0+deb8u2 [117 kB] Holen: 51 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdbus-1-3 armhf 1.8.22-0+deb8u1 [150 kB] Holen: 52 http://archive.raspberrypi.org/debian/ jessie/main libwayland-cursor0 armhf 1.11.0-2 [11,9 kB] Holen: 53 http://mirrordirector.raspbian.org/raspbian/ jessie/main libssl1.0.0 armhf 1.0.1t-1+deb8u6 [853 kB] Holen: 54 http://archive.raspberrypi.org/debian/ jessie/main libxfont1 armhf 1:1.5.2-1 [119 kB] Holen: 55 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnutls-openssl27 armhf 3.3.8-6+deb8u4 [139 kB] Holen: 56 http://archive.raspberrypi.org/debian/ jessie/ui lightdm armhf 1.10.3-3+rpi [139 kB] Holen: 57 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgnutls-deb0-28 armhf 3.3.8-6+deb8u4 [625 kB] Holen: 58 http://mirrordirector.raspbian.org/raspbian/ jessie/main libnettle4 armhf 2.7.1-5+deb8u2 [178 kB] Holen: 59 http://archive.raspberrypi.org/debian/ jessie/main nuscratch armhf 20161021 [11,9 MB] Holen: 60 http://mirrordirector.raspbian.org/raspbian/ jessie/main samba-common all 2:4.2.14+dfsg-0+deb8u2 [269 kB] Holen: 61 http://mirrordirector.raspbian.org/raspbian/ jessie/main libmagic1 armhf 1:5.22+15-2+deb8u3 [244 kB] Holen: 62 http://mirrordirector.raspbian.org/raspbian/ jessie/main libxml2 armhf 2.9.1+dfsg1-5+deb8u4 [705 kB] Holen: 63 http://mirrordirector.raspbian.org/raspbian/ jessie/main curl armhf 7.38.0-4+deb8u5 [196 kB] Holen: 64 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3 armhf 7.38.0-4+deb8u5 [232 kB] Holen: 65 http://mirrordirector.raspbian.org/raspbian/ jessie/main libcurl3-gnutls armhf 7.38.0-4+deb8u5 [225 kB] Holen: 66 http://mirrordirector.raspbian.org/raspbian/ jessie/main libisc-export95 armhf 1:9.9.5.dfsg-9+deb8u9 [124 kB] Holen: 67 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim-tiny armhf 2:7.4.488-7+deb8u1 [357 kB] Holen: 68 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdns-export100 armhf 1:9.9.5.dfsg-9+deb8u9 [397 kB] Holen: 69 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpng12-dev armhf 1.2.50-2+deb8u3 [237 kB] Holen: 70 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpng12-0 armhf 1.2.50-2+deb8u3 [161 kB] Holen: 71 http://mirrordirector.raspbian.org/raspbian/ jessie/main libisccfg90 armhf 1:9.9.5.dfsg-9+deb8u9 [50,4 kB] Holen: 72 http://mirrordirector.raspbian.org/raspbian/ jessie/main liblwres90 armhf 1:9.9.5.dfsg-9+deb8u9 [47,7 kB] Holen: 73 http://mirrordirector.raspbian.org/raspbian/ jessie/main apt-transport-https armhf 1.0.9.8.4 [134 kB] Holen: 74 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtiff5 armhf 4.0.3-12.3+deb8u2 [197 kB] Holen: 75 http://mirrordirector.raspbian.org/raspbian/ jessie/main libxpm4 armhf 1:3.5.12-0+deb8u1 [43,7 kB] Holen: 76 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgd3 armhf 2.1.0-5+deb8u8 [127 kB] Holen: 77 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgudev-1.0-0 armhf 215-17+deb8u6 [40,5 kB] Holen: 78 http://mirrordirector.raspbian.org/raspbian/ jessie/main libicu52 armhf 52.1-8+deb8u4 [6.556 kB] Holen: 79 http://mirrordirector.raspbian.org/raspbian/ jessie/main libisccfg-export90 armhf 1:9.9.5.dfsg-9+deb8u9 [37,9 kB] Holen: 80 http://mirrordirector.raspbian.org/raspbian/ jessie/main libirs-export91 armhf 1:9.9.5.dfsg-9+deb8u9 [36,5 kB] Holen: 81 http://archive.raspberrypi.org/debian/ jessie/main omxplayer armhf 0.3.7~git20160923~dfea8c9 [4.330 kB] Holen: 82 http://mirrordirector.raspbian.org/raspbian/ jessie/main libmpg123-0 armhf 1.20.1-2+deb8u1 [115 kB] Holen: 83 http://mirrordirector.raspbian.org/raspbian/ jessie/main libnss3 armhf 2:3.26-1+debu8u1 [951 kB] Holen: 84 http://mirrordirector.raspbian.org/raspbian/ jessie/main libpcsclite1 armhf 1.8.13-1+deb8u1 [53,7 kB] Holen: 85 http://mirrordirector.raspbian.org/raspbian/ jessie/main libtevent0 armhf 0.9.28-0+deb8u1 [23,5 kB] Holen: 86 http://mirrordirector.raspbian.org/raspbian/ jessie/main libsmbclient armhf 2:4.2.14+dfsg-0+deb8u2 [138 kB] Holen: 87 http://mirrordirector.raspbian.org/raspbian/ jessie/main samba-libs armhf 2:4.2.14+dfsg-0+deb8u2 [4.244 kB] Holen: 88 http://archive.raspberrypi.org/debian/ jessie/ui openbox armhf 3.5.2-8+rpi3 [277 kB] Holen: 89 http://mirrordirector.raspbian.org/raspbian/ jessie/main libxslt1.1 armhf 1.1.28-2+deb8u2 [213 kB] Holen: 90 http://mirrordirector.raspbian.org/raspbian/ jessie/main multiarch-support armhf 2.19-18+deb8u7 [180 kB] Holen: 91 http://archive.raspberrypi.org/debian/ jessie/ui pcmanfm armhf 1.2.3-1.1+rpi6 [256 kB] Holen: 92 http://mirrordirector.raspbian.org/raspbian/ jessie/main tzdata all 2016j-0+deb8u1 [186 kB] Holen: 93 http://mirrordirector.raspbian.org/raspbian/ jessie/main apt-utils armhf 1.0.9.8.4 [353 kB] Holen: 94 http://mirrordirector.raspbian.org/raspbian/ jessie/main vim-common armhf 2:7.4.488-7+deb8u1 [184 kB] Holen: 95 http://archive.raspberrypi.org/debian/ jessie/main pi-bluetooth armhf 0.1.2 [3.398 B] Holen: 96 http://mirrordirector.raspbian.org/raspbian/ jessie/main bind9-host armhf 1:9.9.5.dfsg-9+deb8u9 [65,5 kB] Holen: 97 http://archive.raspberrypi.org/debian/ jessie/ui pi-package-data all 0.2 [1.047 kB] Holen: 98 http://mirrordirector.raspbian.org/raspbian/ jessie/main libisc95 armhf 1:9.9.5.dfsg-9+deb8u9 [149 kB] Holen: 99 http://mirrordirector.raspbian.org/raspbian/ jessie/main libdns100 armhf 1:9.9.5.dfsg-9+deb8u9 [599 kB] Holen: 100 http://mirrordirector.raspbian.org/raspbian/ jessie/main libisccc90 armhf 1:9.9.5.dfsg-9+deb8u9 [34,3 kB] Holen: 101 http://mirrordirector.raspbian.org/raspbian/ jessie/main libbind9-90 armhf 1:9.9.5.dfsg-9+deb8u9 [41,2 kB] Holen: 102 http://mirrordirector.raspbian.org/raspbian/ jessie/main locales all 2.19-18+deb8u7 [3.946 kB] Holen: 103 http://archive.raspberrypi.org/debian/ jessie/ui pi-package-session armhf 0.2 [73,0 kB] Holen: 104 http://archive.raspberrypi.org/debian/ jessie/ui pi-package armhf 0.2 [130 kB] Holen: 105 http://archive.raspberrypi.org/debian/ jessie/ui pipanel armhf 20161206~130650 [13,7 kB] Holen: 106 http://archive.raspberrypi.org/debian/ jessie/ui pishutdown armhf 0.7 [6.010 B] Holen: 107 http://archive.raspberrypi.org/debian/ jessie/main python-rpi.gpio armhf 0.6.3~jessie-1 [23,5 kB] Holen: 108 http://archive.raspberrypi.org/debian/ jessie/main python3-rpi.gpio armhf 0.6.3~jessie-1 [28,2 kB] Holen: 109 http://archive.raspberrypi.org/debian/ jessie/main raspi-gpio armhf 0.20170105 [8.682 B] Holen: 110 http://archive.raspberrypi.org/debian/ jessie/main raspi-config all 20161207 [17,7 kB] Holen: 111 http://archive.raspberrypi.org/debian/ jessie/ui rc-gui armhf 1.5 [38,0 kB] Holen: 112 http://mirrordirector.raspbian.org/raspbian/ jessie/main openssl armhf 1.0.1t-1+deb8u6 [652 kB] Holen: 113 http://archive.raspberrypi.org/debian/ jessie/main va-driver-all armhf 1.7.3-2 [11,2 kB] Holen: 114 http://archive.raspberrypi.org/debian/ jessie/main x11-common all 1:7.7+16 [251 kB] Holen: 115 http://mirrordirector.raspbian.org/raspbian/ jessie/main ca-certificates all 20141019+deb8u2 [207 kB] Holen: 116 http://mirrordirector.raspbian.org/raspbian/ jessie/main dbus-x11 armhf 1.8.22-0+deb8u1 [72,5 kB] Holen: 117 http://mirrordirector.raspbian.org/raspbian/ jessie/main gstreamer1.0-plugins-good armhf 1.4.4-2+deb8u2 [2.218 kB] Holen: 118 http://archive.raspberrypi.org/debian/ jessie/main xserver-common all 2:1.18.4-2+rpi1 [1.969 kB] Holen: 119 http://mirrordirector.raspbian.org/raspbian/ jessie/main libfcgi-perl armhf 0.77-1+deb8u1 [34,9 kB] Holen: 120 http://mirrordirector.raspbian.org/raspbian/ jessie/main libgme0 armhf 0.5.5-2+deb8u1 [88,0 kB] Holen: 121 http://mirrordirector.raspbian.org/raspbian/ jessie/main libio-socket-ssl-perl all 2.002-2+deb8u2 [172 kB] Holen: 122 http://mirrordirector.raspbian.org/raspbian/ jessie/main python-pil armhf 2.6.1-2+deb8u3 [278 kB] Holen: 123 http://mirrordirector.raspbian.org/raspbian/ jessie/main python3-pil armhf 2.6.1-2+deb8u3 [278 kB] Holen: 124 http://mirrordirector.raspbian.org/raspbian/ jessie/main wireless-regdb all 2016.06.10-1~deb8u1 [8.504 B] Holen: 125 http://archive.raspberrypi.org/debian/ jessie/main xserver-xorg-video-fbturbo armhf 1.20161111~122359 [23,3 kB] Holen: 126 http://archive.raspberrypi.org/debian/ jessie/main xserver-xorg-video-fbdev armhf 1:0.4.4-1+rpi2 [22,1 kB] Holen: 127 http://archive.raspberrypi.org/debian/ jessie/main xserver-xorg armhf 1:7.7+16 [93,5 kB] Holen: 128 http://archive.raspberrypi.org/debian/ jessie/main xserver-xorg-core armhf 2:1.18.4-2+rpi1 [3.031 kB] Holen: 129 http://archive.raspberrypi.org/debian/ jessie/main xserver-xorg-input-evdev armhf 1:2.10.3-1 [116 kB] Holen: 130 http://archive.raspberrypi.org/debian/ jessie/main xserver-xorg-input-synaptics armhf 1.8.3-2 [211 kB] Holen: 131 http://archive.raspberrypi.org/debian/ jessie/main bluej all 3.1.7b [10,1 MB] Holen: 132 http://archive.raspberrypi.org/debian/ jessie/main greenfoot all 2.4.2a [9.107 kB] Holen: 133 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi-dev armhf 1.20161215-1 [397 kB] Holen: 134 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi-doc armhf 1.20161215-1 [31,4 MB] Holen: 135 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-kernel armhf 1.20161215-1 [30,1 MB] Holen: 136 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi-bin armhf 1.20161215-1 [331 kB] Holen: 137 http://archive.raspberrypi.org/debian/ jessie/main libraspberrypi0 armhf 1.20161215-1 [842 kB] Holen: 138 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-bootloader armhf 1.20161215-1 [3.260 kB] Holen: 139 http://archive.raspberrypi.org/debian/ jessie/main raspberrypi-net-mods all 1.2.5 [2.526 B] Es wurden 169 MB in 1 min 31 s geholt (1.842 kB/s). Lese Changelogs... Fertig Extrahiere Vorlagen aus Paketen: 100% Vorkonfiguration der Pakete ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../bash_4.3-11+deb8u1_armhf.deb ... Entpacken von bash (4.3-11+deb8u1) über (4.3-11) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... Trigger für install-info (5.2.0.dfsg.1-6) werden verarbeitet ... bash (4.3-11+deb8u1) wird eingerichtet ... update-alternatives: /usr/share/man/man7/bash-builtins.7.gz wird verwendet, um /usr/share/man/man7/builtins.7.gz (builtins.7.gz) im automatischen Modus bereitzustellen (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../sed_4.2.2-4+deb8u1_armhf.deb ... Entpacken von sed (4.2.2-4+deb8u1) über (4.2.2-4) ... Trigger für install-info (5.2.0.dfsg.1-6) werden verarbeitet ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... sed (4.2.2-4+deb8u1) wird eingerichtet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libc6-dev_2.19-18+deb8u7_armhf.deb ... Entpacken von libc6-dev:armhf (2.19-18+deb8u7) über (2.19-18+deb8u6) ... Vorbereitung zum Entpacken von .../libc-dev-bin_2.19-18+deb8u7_armhf.deb ... Entpacken von libc-dev-bin (2.19-18+deb8u7) über (2.19-18+deb8u6) ... Vorbereitung zum Entpacken von .../libc-bin_2.19-18+deb8u7_armhf.deb ... Entpacken von libc-bin (2.19-18+deb8u7) über (2.19-18+deb8u6) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... libc-bin (2.19-18+deb8u7) wird eingerichtet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libc6-dbg_2.19-18+deb8u7_armhf.deb ... Entpacken von libc6-dbg:armhf (2.19-18+deb8u7) über (2.19-18+deb8u6) ... Vorbereitung zum Entpacken von .../libc6_2.19-18+deb8u7_armhf.deb ... Entpacken von libc6:armhf (2.19-18+deb8u7) über (2.19-18+deb8u6) ... libc6:armhf (2.19-18+deb8u7) wird eingerichtet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libapt-pkg4.12_1.0.9.8.4_armhf.deb ... Entpacken von libapt-pkg4.12:armhf (1.0.9.8.4) über (1.0.9.8.3) ... libapt-pkg4.12:armhf (1.0.9.8.4) wird eingerichtet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../apt_1.0.9.8.4_armhf.deb ... Entpacken von apt (1.0.9.8.4) über (1.0.9.8.3) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... apt (1.0.9.8.4) wird eingerichtet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libudev1_215-17+deb8u6_armhf.deb ... Entpacken von libudev1:armhf (215-17+deb8u6) über (215-17+deb8u5) ... libudev1:armhf (215-17+deb8u6) wird eingerichtet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../udev_215-17+deb8u6_armhf.deb ... Entpacken von udev (215-17+deb8u6) über (215-17+deb8u5) ... Trigger für systemd (215-17+deb8u5) werden verarbeitet ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... udev (215-17+deb8u6) wird eingerichtet ... addgroup: Die Gruppe »input« existiert bereits als Systemgruppe. Programmende. update-initramfs: deferring update (trigger activated) Trigger für initramfs-tools (0.120+deb8u2) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam0g_1.1.8-3.1+deb8u2_armhf.deb ... Entpacken von libpam0g:armhf (1.1.8-3.1+deb8u2) über (1.1.8-3.1+deb8u1) ... libpam0g:armhf (1.1.8-3.1+deb8u2) wird eingerichtet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-modules-bin_1.1.8-3.1+deb8u2_armhf.deb ... Entpacken von libpam-modules-bin (1.1.8-3.1+deb8u2) über (1.1.8-3.1+deb8u1) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... libpam-modules-bin (1.1.8-3.1+deb8u2) wird eingerichtet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-modules_1.1.8-3.1+deb8u2_armhf.deb ... Entpacken von libpam-modules:armhf (1.1.8-3.1+deb8u2) über (1.1.8-3.1+deb8u1) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... libpam-modules:armhf (1.1.8-3.1+deb8u2) wird eingerichtet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libsystemd0_215-17+deb8u6_armhf.deb ... Entpacken von libsystemd0:armhf (215-17+deb8u6) über (215-17+deb8u5) ... libsystemd0:armhf (215-17+deb8u6) wird eingerichtet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-systemd_215-17+deb8u6_armhf.deb ... Entpacken von libpam-systemd:armhf (215-17+deb8u6) über (215-17+deb8u5) ... Vorbereitung zum Entpacken von .../systemd_215-17+deb8u6_armhf.deb ... Entpacken von systemd (215-17+deb8u6) über (215-17+deb8u5) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... Trigger für dbus (1.8.20-0+deb8u1) werden verarbeitet ... systemd (215-17+deb8u6) wird eingerichtet ... addgroup: Die Gruppe »systemd-journal« existiert bereits als Systemgruppe. Programmende. Failed to execute operation: File exists (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../systemd-sysv_215-17+deb8u6_armhf.deb ... Entpacken von systemd-sysv (215-17+deb8u6) über (215-17+deb8u5) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... systemd-sysv (215-17+deb8u6) wird eingerichtet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libpam-runtime_1.1.8-3.1+deb8u2_all.deb ... Entpacken von libpam-runtime (1.1.8-3.1+deb8u2) über (1.1.8-3.1+deb8u1) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... libpam-runtime (1.1.8-3.1+deb8u2) wird eingerichtet ... (Lese Datenbank ... 117895 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../libdbus-1-3_1.8.22-0+deb8u1_armhf.deb ... Entpacken von libdbus-1-3:armhf (1.8.22-0+deb8u1) über (1.8.20-0+deb8u1) ... Vorbereitung zum Entpacken von .../dbus_1.8.22-0+deb8u1_armhf.deb ... Entpacken von dbus (1.8.22-0+deb8u1) über (1.8.20-0+deb8u1) ... Vorbereitung zum Entpacken von .../libapt-inst1.5_1.0.9.8.4_armhf.deb ... Entpacken von libapt-inst1.5:armhf (1.0.9.8.4) über (1.0.9.8.3) ... Vorbereitung zum Entpacken von .../libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb ... Entpacken von libssl1.0.0:armhf (1.0.1t-1+deb8u6) über (1.0.1t-1+deb8u5) ... Vorbereitung zum Entpacken von .../libgnutls-openssl27_3.3.8-6+deb8u4_armhf.deb ... Entpacken von libgnutls-openssl27:armhf (3.3.8-6+deb8u4) über (3.3.8-6+deb8u3) ... Vorbereitung zum Entpacken von .../libgnutls-deb0-28_3.3.8-6+deb8u4_armhf.deb ... Entpacken von libgnutls-deb0-28:armhf (3.3.8-6+deb8u4) über (3.3.8-6+deb8u3) ... Vorbereitung zum Entpacken von .../libhogweed2_2.7.1-5+deb8u2_armhf.deb ... Entpacken von libhogweed2:armhf (2.7.1-5+deb8u2) über (2.7.1-5+deb8u1) ... Vorbereitung zum Entpacken von .../libnettle4_2.7.1-5+deb8u2_armhf.deb ... Entpacken von libnettle4:armhf (2.7.1-5+deb8u2) über (2.7.1-5+deb8u1) ... Vorbereitung zum Entpacken von .../file_1%3a5.22+15-2+deb8u3_armhf.deb ... Entpacken von file (1:5.22+15-2+deb8u3) über (1:5.22+15-2+deb8u2) ... Vorbereitung zum Entpacken von .../libmagic1_1%3a5.22+15-2+deb8u3_armhf.deb ... Entpacken von libmagic1:armhf (1:5.22+15-2+deb8u3) über (1:5.22+15-2+deb8u2) ... Vorbereitung zum Entpacken von .../libxml2_2.9.1+dfsg1-5+deb8u4_armhf.deb ... Entpacken von libxml2:armhf (2.9.1+dfsg1-5+deb8u4) über (2.9.1+dfsg1-5+deb8u3) ... Vorbereitung zum Entpacken von .../curl_7.38.0-4+deb8u5_armhf.deb ... Entpacken von curl (7.38.0-4+deb8u5) über (7.38.0-4+deb8u4) ... Vorbereitung zum Entpacken von .../libcurl3_7.38.0-4+deb8u5_armhf.deb ... Entpacken von libcurl3:armhf (7.38.0-4+deb8u5) über (7.38.0-4+deb8u4) ... Vorbereitung zum Entpacken von .../libcurl3-gnutls_7.38.0-4+deb8u5_armhf.deb ... Entpacken von libcurl3-gnutls:armhf (7.38.0-4+deb8u5) über (7.38.0-4+deb8u4) ... Vorbereitung zum Entpacken von .../libisc-export95_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libisc-export95 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libdns-export100_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libdns-export100 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libdrm2_2.4.71-1+rpi1_armhf.deb ... Entpacken von libdrm2:armhf (2.4.71-1+rpi1) über (2.4.65-3~bpo8+1) ... Vorbereitung zum Entpacken von .../libdrm-amdgpu1_2.4.71-1+rpi1_armhf.deb ... Entpacken von libdrm-amdgpu1:armhf (2.4.71-1+rpi1) über (2.4.65-3~bpo8+1) ... Vorbereitung zum Entpacken von .../libdrm-freedreno1_2.4.71-1+rpi1_armhf.deb ... Entpacken von libdrm-freedreno1:armhf (2.4.71-1+rpi1) über (2.4.65-3~bpo8+1) ... Vorbereitung zum Entpacken von .../libdrm-nouveau2_2.4.71-1+rpi1_armhf.deb ... Entpacken von libdrm-nouveau2:armhf (2.4.71-1+rpi1) über (2.4.65-3~bpo8+1) ... Vorbereitung zum Entpacken von .../libdrm-radeon1_2.4.71-1+rpi1_armhf.deb ... Entpacken von libdrm-radeon1:armhf (2.4.71-1+rpi1) über (2.4.65-3~bpo8+1) ... Vorbereitung zum Entpacken von .../libwayland-client0_1.11.0-2_armhf.deb ... Entpacken von libwayland-client0:armhf (1.11.0-2) über (1.6.0-2) ... Vorbereitung zum Entpacken von .../libwayland-server0_1.11.0-2_armhf.deb ... Entpacken von libwayland-server0:armhf (1.11.0-2) über (1.6.0-2) ... Vorbereitung zum Entpacken von .../libgbm1_13.0.0-1+rpi1_armhf.deb ... Entpacken von libgbm1:armhf (13.0.0-1+rpi1) über (11.1.0-1+rpi1) ... Vorbereitung zum Entpacken von .../libegl1-mesa_13.0.0-1+rpi1_armhf.deb ... Entpacken von libegl1-mesa:armhf (13.0.0-1+rpi1) über (11.1.0-1+rpi1) ... Vorbereitung zum Entpacken von .../libpng12-dev_1.2.50-2+deb8u3_armhf.deb ... Entpacken von libpng12-dev:armhf (1.2.50-2+deb8u3) über (1.2.50-2+deb8u2) ... Vorbereitung zum Entpacken von .../libpng12-0_1.2.50-2+deb8u3_armhf.deb ... Entpacken von libpng12-0:armhf (1.2.50-2+deb8u3) über (1.2.50-2+deb8u2) ... Vorbereitung zum Entpacken von .../libtiff5_4.0.3-12.3+deb8u2_armhf.deb ... Entpacken von libtiff5:armhf (4.0.3-12.3+deb8u2) über (4.0.3-12.3+deb8u1) ... Vorbereitung zum Entpacken von .../libxpm4_1%3a3.5.12-0+deb8u1_armhf.deb ... Entpacken von libxpm4:armhf (1:3.5.12-0+deb8u1) über (1:3.5.11-1) ... Vorbereitung zum Entpacken von .../libgd3_2.1.0-5+deb8u8_armhf.deb ... Entpacken von libgd3:armhf (2.1.0-5+deb8u8) über (2.1.0-5+deb8u6) ... Vorbereitung zum Entpacken von .../libgles2-mesa_13.0.0-1+rpi1_armhf.deb ... Entpacken von libgles2-mesa:armhf (13.0.0-1+rpi1) über (11.1.0-1+rpi1) ... Vorbereitung zum Entpacken von .../libgles1-mesa_13.0.0-1+rpi1_armhf.deb ... Entpacken von libgles1-mesa:armhf (13.0.0-1+rpi1) über (11.1.0-1+rpi1) ... Vorbereitung zum Entpacken von .../libgl1-mesa-glx_13.0.0-1+rpi1_armhf.deb ... Entpacken von libgl1-mesa-glx:armhf (13.0.0-1+rpi1) über (11.1.0-1+rpi1) ... Vorbereitung zum Entpacken von .../libglapi-mesa_13.0.0-1+rpi1_armhf.deb ... Entpacken von libglapi-mesa:armhf (13.0.0-1+rpi1) über (11.1.0-1+rpi1) ... Vorbereitung zum Entpacken von .../libgudev-1.0-0_215-17+deb8u6_armhf.deb ... Entpacken von libgudev-1.0-0:armhf (215-17+deb8u6) über (215-17+deb8u5) ... Vorbereitung zum Entpacken von .../libicu52_52.1-8+deb8u4_armhf.deb ... Entpacken von libicu52:armhf (52.1-8+deb8u4) über (52.1-8+deb8u3) ... Vorbereitung zum Entpacken von .../libisccfg-export90_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libisccfg-export90 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libirs-export91_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libirs-export91 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../liblcms2-2_2.6-3+deb8u1_armhf.deb ... Entpacken von liblcms2-2:armhf (2.6-3+deb8u1) über (2.6-3) ... Vorbereitung zum Entpacken von .../liblightdm-gobject-1-0_1.10.3-3+rpi_armhf.deb ... Entpacken von liblightdm-gobject-1-0 (1.10.3-3+rpi) über (1.10.3-3) ... Vorbereitung zum Entpacken von .../libmpg123-0_1.20.1-2+deb8u1_armhf.deb ... Entpacken von libmpg123-0:armhf (1.20.1-2+deb8u1) über (1.20.1-2) ... Vorbereitung zum Entpacken von .../libnspr4_2%3a4.12-1+debu8u1_armhf.deb ... Entpacken von libnspr4:armhf (2:4.12-1+debu8u1) über (2:4.10.7-1+deb8u1) ... Vorbereitung zum Entpacken von .../libnss3_2%3a3.26-1+debu8u1_armhf.deb ... Entpacken von libnss3:armhf (2:3.26-1+debu8u1) über (2:3.17.2-1.1+deb8u2) ... Vorbereitung zum Entpacken von .../libpcsclite1_1.8.13-1+deb8u1_armhf.deb ... Entpacken von libpcsclite1:armhf (1.8.13-1+deb8u1) über (1.8.13-1) ... Vorbereitung zum Entpacken von .../libwbclient0_2%3a4.2.14+dfsg-0+deb8u2_armhf.deb ... Entpacken von libwbclient0:armhf (2:4.2.14+dfsg-0+deb8u2) über (2:4.2.10+dfsg-0+deb8u3) ... Vorbereitung zum Entpacken von .../libtevent0_0.9.28-0+deb8u1_armhf.deb ... Entpacken von libtevent0:armhf (0.9.28-0+deb8u1) über (0.9.25-0+deb8u1) ... Vorbereitung zum Entpacken von .../libsmbclient_2%3a4.2.14+dfsg-0+deb8u2_armhf.deb ... Entpacken von libsmbclient:armhf (2:4.2.14+dfsg-0+deb8u2) über (2:4.2.10+dfsg-0+deb8u3) ... Vorbereitung zum Entpacken von .../samba-libs_2%3a4.2.14+dfsg-0+deb8u2_armhf.deb ... Entpacken von samba-libs:armhf (2:4.2.14+dfsg-0+deb8u2) über (2:4.2.10+dfsg-0+deb8u3) ... Vorbereitung zum Entpacken von .../libxslt1.1_1.1.28-2+deb8u2_armhf.deb ... Entpacken von libxslt1.1:armhf (1.1.28-2+deb8u2) über (1.1.28-2+deb8u1) ... Vorbereitung zum Entpacken von .../samba-common_2%3a4.2.14+dfsg-0+deb8u2_all.deb ... Entpacken von samba-common (2:4.2.14+dfsg-0+deb8u2) über (2:4.2.10+dfsg-0+deb8u3) ... Vorbereitung zum Entpacken von .../multiarch-support_2.19-18+deb8u7_armhf.deb ... Entpacken von multiarch-support (2.19-18+deb8u7) über (2.19-18+deb8u6) ... Trigger für systemd (215-17+deb8u6) werden verarbeitet ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... multiarch-support (2.19-18+deb8u7) wird eingerichtet ... (Lese Datenbank ... 117898 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../tzdata_2016j-0+deb8u1_all.deb ... Entpacken von tzdata (2016j-0+deb8u1) über (2016f-0+deb8u1) ... tzdata (2016j-0+deb8u1) wird eingerichtet ... ! Current default time zone: 'Europe/Berlin' Local time is now: Tue Jan 31 12:48:39 CET 2017. Universal Time is now: Tue Jan 31 11:48:39 UTC 2017. Run 'dpkg-reconfigure tzdata' if you wish to change it. ! (Lese Datenbank ... 117910 Dateien und Verzeichnisse sind derzeit installiert.) Vorbereitung zum Entpacken von .../apt-utils_1.0.9.8.4_armhf.deb ... Entpacken von apt-utils (1.0.9.8.4) über (1.0.9.8.3) ... Vorbereitung zum Entpacken von .../vim-tiny_2%3a7.4.488-7+deb8u1_armhf.deb ... Entpacken von vim-tiny (2:7.4.488-7+deb8u1) über (2:7.4.488-7) ... Vorbereitung zum Entpacken von .../vim-common_2%3a7.4.488-7+deb8u1_armhf.deb ... Entpacken von vim-common (2:7.4.488-7+deb8u1) über (2:7.4.488-7) ... Vorbereitung zum Entpacken von .../bind9-host_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von bind9-host (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libisc95_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libisc95 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libdns100_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libdns100 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libisccc90_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libisccc90 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libisccfg90_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libisccfg90 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../libbind9-90_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von libbind9-90 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../liblwres90_1%3a9.9.5.dfsg-9+deb8u9_armhf.deb ... Entpacken von liblwres90 (1:9.9.5.dfsg-9+deb8u9) über (1:9.9.5.dfsg-9+deb8u7) ... Vorbereitung zum Entpacken von .../locales_2.19-18+deb8u7_all.deb ... Entpacken von locales (2.19-18+deb8u7) über (2.19-18+deb8u6) ... dpkg: Fehler beim Bearbeiten des Archivs /var/cache/apt/archives/locales_2.19-18+deb8u7_all.deb (--unpack): »./usr/share/i18n/charmaps/ISO-IR-90.gz« (was gerade installiert werden sollte) konnte nicht mit stat abgefragt werden: Die Struktur muss bereinigt werden dpkg-deb: Fehler: Unterprozess einfügen wurde durch Signal (Datenübergabe unterbrochen (broken pipe)) getötet Vorbereitung zum Entpacken von .../apt-transport-https_1.0.9.8.4_armhf.deb ... Entpacken von apt-transport-https (1.0.9.8.4) über (1.0.9.8.3) ... Vorbereitung zum Entpacken von .../openssl_1.0.1t-1+deb8u6_armhf.deb ... Entpacken von openssl (1.0.1t-1+deb8u6) über (1.0.1t-1+deb8u5) ... Vorbereitung zum Entpacken von .../ca-certificates_20141019+deb8u2_all.deb ... Entpacken von ca-certificates (20141019+deb8u2) über (20141019+deb8u1) ... Vorbereitung zum Entpacken von .../dbus-x11_1.8.22-0+deb8u1_armhf.deb ... Entpacken von dbus-x11 (1.8.22-0+deb8u1) über (1.8.20-0+deb8u1) ... Vorbereitung zum Entpacken von .../gdb_7.7.1+dfsg-5+rpi1_armhf.deb ... Entpacken von gdb (7.7.1+dfsg-5+rpi1) über (7.7.1+dfsg-5) ... Vorbereitung zum Entpacken von .../gdbserver_7.7.1+dfsg-5+rpi1_armhf.deb ... Entpacken von gdbserver (7.7.1+dfsg-5+rpi1) über (7.7.1+dfsg-5) ... Vorbereitung zum Entpacken von .../libcairo2_1.14.0-2.1+deb8u2+rpi1_armhf.deb ... Entpacken von libcairo2:armhf (1.14.0-2.1+deb8u2+rpi1) über (1.14.0-2.1+deb8u1+rpi1) ... Vorbereitung zum Entpacken von .../libcairo-gobject2_1.14.0-2.1+deb8u2+rpi1_armhf.deb ... Entpacken von libcairo-gobject2:armhf (1.14.0-2.1+deb8u2+rpi1) über (1.14.0-2.1+deb8u1+rpi1) ... Vorbereitung zum Entpacken von .../gstreamer1.0-plugins-good_1.4.4-2+deb8u2_armhf.deb ... Entpacken von gstreamer1.0-plugins-good:armhf (1.4.4-2+deb8u2) über (1.4.4-2) ... Vorbereitung zum Entpacken von .../libasound2-data_1.0.28-1+rpi2_all.deb ... Entpacken von libasound2-data (1.0.28-1+rpi2) über (1.0.28-1+rpi1) ... Vorbereitung zum Entpacken von .../libasound2_1.0.28-1+rpi2_armhf.deb ... Entpacken von libasound2:armhf (1.0.28-1+rpi2) über (1.0.28-1+rpi1) ... Vorbereitung zum Entpacken von .../libfcgi-perl_0.77-1+deb8u1_armhf.deb ... Entpacken von libfcgi-perl (0.77-1+deb8u1) über (0.77-1+b1) ... Vorbereitung zum Entpacken von .../libgme0_0.5.5-2+deb8u1_armhf.deb ... Entpacken von libgme0 (0.5.5-2+deb8u1) über (0.5.5-2) ... Vorbereitung zum Entpacken von .../libio-socket-ssl-perl_2.002-2+deb8u2_all.deb ... Entpacken von libio-socket-ssl-perl (2.002-2+deb8u2) über (2.002-2+deb8u1) ... Vorbereitung zum Entpacken von .../libobt2_3.5.2-8+rpi3_armhf.deb ... Entpacken von libobt2 (3.5.2-8+rpi3) über (3.5.2-8+rpi2) ... Vorbereitung zum Entpacken von .../libobrender29_3.5.2-8+rpi3_armhf.deb ... Entpacken von libobrender29 (3.5.2-8+rpi3) über (3.5.2-8+rpi2) ... Vorbereitung zum Entpacken von .../libva1_1.7.3-2_armhf.deb ... Entpacken von libva1:armhf (1.7.3-2) über (1.4.1-1) ... Vorbereitung zum Entpacken von .../libwayland-cursor0_1.11.0-2_armhf.deb ... Entpacken von libwayland-cursor0:armhf (1.11.0-2) über (1.6.0-2) ... Vorbereitung zum Entpacken von .../libxfont1_1%3a1.5.2-1_armhf.deb ... Entpacken von libxfont1:armhf (1:1.5.2-1) über (1:1.5.1-1) ... Vorbereitung zum Entpacken von .../lightdm_1.10.3-3+rpi_armhf.deb ... Entpacken von lightdm (1.10.3-3+rpi) über (1.10.3-3) ... Vorbereitung zum Entpacken von .../nuscratch_20161021_armhf.deb ... »Umleitung von /usr/bin/scratch zu /usr/bin/scratch.old durch nuscratch« wird beibehalten »Umleitung von /usr/bin/squeak zu /usr/bin/squeak.old durch nuscratch« wird beibehalten »Umleitung von /usr/share/scratch/locale/ja_HIRA.po zu /usr/share/scratch/locale/ja_HIRA.po.old durch nuscratch« wird beibehalten »Umleitung von /usr/share/scratch/locale/ja.po zu /usr/share/scratch/locale/ja.po.old durch nuscratch« wird beibehalten Entpacken von nuscratch (20161021) über (20160915+1) ... Vorbereitung zum Entpacken von .../omxplayer_0.3.7~git20160923~dfea8c9_armhf.deb ... Entpacken von omxplayer (0.3.7~git20160923~dfea8c9) über (0.3.7~git20160506~6c90c75) ... Vorbereitung zum Entpacken von .../openbox_3.5.2-8+rpi3_armhf.deb ... Entpacken von openbox (3.5.2-8+rpi3) über (3.5.2-8+rpi2) ... Vorbereitung zum Entpacken von .../pcmanfm_1.2.3-1.1+rpi6_armhf.deb ... Entpacken von pcmanfm (1.2.3-1.1+rpi6) über (1.2.3-1.1+rpi5) ... Vorbereitung zum Entpacken von .../pi-bluetooth_0.1.2_armhf.deb ... Entpacken von pi-bluetooth (0.1.2) über (0.1.1) ... Vorbereitung zum Entpacken von .../pi-package-data_0.2_all.deb ... Entpacken von pi-package-data (0.2) über (0.1.0-1) ... Vorbereitung zum Entpacken von .../pi-package-session_0.2_armhf.deb ... Entpacken von pi-package-session (0.2) über (0.1.0-1) ... Vorbereitung zum Entpacken von .../pi-package_0.2_armhf.deb ... Entpacken von pi-package (0.2) über (0.1.0-1) ... Vorbereitung zum Entpacken von .../pipanel_20161206~130650_armhf.deb ... Entpacken von pipanel (20161206~130650) über (20160719~175800) ... Vorbereitung zum Entpacken von .../pishutdown_0.7_armhf.deb ... »Umleitung von /usr/bin/lxde-pi-shutdown-helper zu /usr/bin/lxde-pi-shutdown-helper.old durch pishutdown« wird beibehalten Entpacken von pishutdown (0.7) über (0.6) ... Vorbereitung zum Entpacken von .../python-pil_2.6.1-2+deb8u3_armhf.deb ... Entpacken von python-pil:armhf (2.6.1-2+deb8u3) über (2.6.1-2+deb8u2) ... Vorbereitung zum Entpacken von .../python-rpi.gpio_0.6.3~jessie-1_armhf.deb ... Entpacken von python-rpi.gpio (0.6.3~jessie-1) über (0.6.2~jessie-1) ... Vorbereitung zum Entpacken von .../python3-pil_2.6.1-2+deb8u3_armhf.deb ... Entpacken von python3-pil:armhf (2.6.1-2+deb8u3) über (2.6.1-2+deb8u2) ... Vorbereitung zum Entpacken von .../python3-rpi.gpio_0.6.3~jessie-1_armhf.deb ... Entpacken von python3-rpi.gpio (0.6.3~jessie-1) über (0.6.2~jessie-1) ... Vorbereitung zum Entpacken von .../raspi-gpio_0.20170105_armhf.deb ... Entpacken von raspi-gpio (0.20170105) über (0.20150914) ... Vorbereitung zum Entpacken von .../raspi-config_20161207_all.deb ... Entpacken von raspi-config (20161207) über (20160810) ... Vorbereitung zum Entpacken von .../archives/rc-gui_1.5_armhf.deb ... Entpacken von rc-gui (1.5) über (1.1-1) ... Vorbereitung zum Entpacken von .../va-driver-all_1.7.3-2_armhf.deb ... Entpacken von va-driver-all:armhf (1.7.3-2) über (1.4.1-1) ... Vorbereitung zum Entpacken von .../wireless-regdb_2016.06.10-1~deb8u1_all.deb ... Entpacken von wireless-regdb (2016.06.10-1~deb8u1) über (2014.11.18-1) ... Vorbereitung zum Entpacken von .../x11-common_1%3a7.7+16_all.deb ... Entpacken von x11-common (1:7.7+16) über (1:7.7+7) ... Vorbereitung zum Entpacken von .../xserver-common_2%3a1.18.4-2+rpi1_all.deb ... Entpacken von xserver-common (2:1.18.4-2+rpi1) über (2:1.17.2-1+rpi1) ... Vorbereitung zum Entpacken von .../xserver-xorg-video-fbturbo_1.20161111~122359_armhf.deb ... Entpacken von xserver-xorg-video-fbturbo (1.20161111~122359) über (1.20150305~205709) ... Vorbereitung zum Entpacken von .../xserver-xorg-video-fbdev_1%3a0.4.4-1+rpi2_armhf.deb ... Entpacken von xserver-xorg-video-fbdev (1:0.4.4-1+rpi2) über (1:0.4.4-1+rpi1) ... Vorbereitung zum Entpacken von .../xserver-xorg_1%3a7.7+16_armhf.deb ... Entpacken von xserver-xorg (1:7.7+16) über (1:7.7+7+b1) ... Vorbereitung zum Entpacken von .../xserver-xorg-core_2%3a1.18.4-2+rpi1_armhf.deb ... Entpacken von xserver-xorg-core (2:1.18.4-2+rpi1) über (2:1.17.2-1+rpi1) ... Vorbereitung zum Entpacken von .../xserver-xorg-input-evdev_1%3a2.10.3-1_armhf.deb ... Entpacken von xserver-xorg-input-evdev (1:2.10.3-1) über (1:2.9.2-1~bpo8+1) ... Vorbereitung zum Entpacken von .../xserver-xorg-input-synaptics_1.8.3-2_armhf.deb ... Entpacken von xserver-xorg-input-synaptics (1.8.3-2) über (1.8.2-1~bpo8+1) ... Vorbereitung zum Entpacken von .../archives/bluej_3.1.7b_all.deb ... Entpacken von bluej (3.1.7b) über (3.1.7a) ... Vorbereitung zum Entpacken von .../greenfoot_2.4.2a_all.deb ... Entpacken von greenfoot (2.4.2a) über (2.4.2) ... Vorbereitung zum Entpacken von .../libraspberrypi-dev_1.20161215-1_armhf.deb ... Entpacken von libraspberrypi-dev (1.20161215-1) über (1.20160921-1) ... Vorbereitung zum Entpacken von .../libraspberrypi-doc_1.20161215-1_armhf.deb ... Entpacken von libraspberrypi-doc (1.20161215-1) über (1.20160921-1) ... Vorbereitung zum Entpacken von .../raspberrypi-kernel_1.20161215-1_armhf.deb ... »Umleitung von /boot/bcm2708-rpi-b-plus.dtb zu /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/bcm2708-rpi-b.dtb zu /usr/share/rpikernelhack/bcm2708-rpi-b.dtb durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/bcm2708-rpi-cm.dtb zu /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/bcm2709-rpi-2-b.dtb zu /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/bcm2710-rpi-3-b.dtb zu /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/bcm2710-rpi-cm3.dtb zu /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/kernel.img zu /usr/share/rpikernelhack/kernel.img durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/kernel7.img zu /usr/share/rpikernelhack/kernel7.img durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/COPYING.linux zu /usr/share/rpikernelhack/COPYING.linux durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/README zu /usr/share/rpikernelhack/overlays/README durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/adau1977-adc.dtbo zu /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/ads1015.dtbo zu /usr/share/rpikernelhack/overlays/ads1015.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/ads7846.dtbo zu /usr/share/rpikernelhack/overlays/ads7846.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/akkordion-iqdacplus.dtbo zu /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo zu /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/at86rf233.dtbo zu /usr/share/rpikernelhack/overlays/at86rf233.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/audioinjector-wm8731-audio.dtbo zu /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/audremap.dtbo zu /usr/share/rpikernelhack/overlays/audremap.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/bmp085_i2c-sensor.dtbo zu /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/dht11.dtbo zu /usr/share/rpikernelhack/overlays/dht11.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/dionaudio-loco.dtbo zu /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/dpi18.dtbo zu /usr/share/rpikernelhack/overlays/dpi18.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/dpi24.dtbo zu /usr/share/rpikernelhack/overlays/dpi24.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/dwc-otg.dtbo zu /usr/share/rpikernelhack/overlays/dwc-otg.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/dwc2.dtbo zu /usr/share/rpikernelhack/overlays/dwc2.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/enc28j60-spi2.dtbo zu /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/enc28j60.dtbo zu /usr/share/rpikernelhack/overlays/enc28j60.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/gpio-ir.dtbo zu /usr/share/rpikernelhack/overlays/gpio-ir.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/gpio-poweroff.dtbo zu /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hifiberry-amp.dtbo zu /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hifiberry-dac.dtbo zu /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hifiberry-dacplus.dtbo zu /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hifiberry-digi-pro.dtbo zu /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hifiberry-digi.dtbo zu /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hy28a.dtbo zu /usr/share/rpikernelhack/overlays/hy28a.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/hy28b.dtbo zu /usr/share/rpikernelhack/overlays/hy28b.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c-gpio.dtbo zu /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c-mux.dtbo zu /usr/share/rpikernelhack/overlays/i2c-mux.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c-pwm-pca9685a.dtbo zu /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c-rtc.dtbo zu /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c-sensor.dtbo zu /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c0-bcm2708.dtbo zu /usr/share/rpikernelhack/overlays/i2c0-bcm2708.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2c1-bcm2708.dtbo zu /usr/share/rpikernelhack/overlays/i2c1-bcm2708.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2s-gpio28-31.dtbo zu /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/i2s-mmap.dtbo zu /usr/share/rpikernelhack/overlays/i2s-mmap.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/iqaudio-dac.dtbo zu /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/iqaudio-dacplus.dtbo zu /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/iqaudio-digi-wm8804-audio.dtbo zu /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/justboom-dac.dtbo zu /usr/share/rpikernelhack/overlays/justboom-dac.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/justboom-digi.dtbo zu /usr/share/rpikernelhack/overlays/justboom-digi.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/lirc-rpi.dtbo zu /usr/share/rpikernelhack/overlays/lirc-rpi.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/mcp23017.dtbo zu /usr/share/rpikernelhack/overlays/mcp23017.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/mcp23s17.dtbo zu /usr/share/rpikernelhack/overlays/mcp23s17.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/mcp2515-can0.dtbo zu /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/mcp2515-can1.dtbo zu /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/mmc.dtbo zu /usr/share/rpikernelhack/overlays/mmc.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/mz61581.dtbo zu /usr/share/rpikernelhack/overlays/mz61581.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pi3-act-led.dtbo zu /usr/share/rpikernelhack/overlays/pi3-act-led.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pi3-disable-bt.dtbo zu /usr/share/rpikernelhack/overlays/pi3-disable-bt.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pi3-miniuart-bt.dtbo zu /usr/share/rpikernelhack/overlays/pi3-miniuart-bt.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/piscreen.dtbo zu /usr/share/rpikernelhack/overlays/piscreen.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/piscreen2r.dtbo zu /usr/share/rpikernelhack/overlays/piscreen2r.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pisound.dtbo zu /usr/share/rpikernelhack/overlays/pisound.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pitft22.dtbo zu /usr/share/rpikernelhack/overlays/pitft22.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pitft28-capacitive.dtbo zu /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pitft28-resistive.dtbo zu /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pitft35-resistive.dtbo zu /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pps-gpio.dtbo zu /usr/share/rpikernelhack/overlays/pps-gpio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pwm-2chan.dtbo zu /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/pwm.dtbo zu /usr/share/rpikernelhack/overlays/pwm.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/qca7000.dtbo zu /usr/share/rpikernelhack/overlays/qca7000.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/raspidac3.dtbo zu /usr/share/rpikernelhack/overlays/raspidac3.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rpi-backlight.dtbo zu /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rpi-dac.dtbo zu /usr/share/rpikernelhack/overlays/rpi-dac.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rpi-display.dtbo zu /usr/share/rpikernelhack/overlays/rpi-display.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rpi-ft5406.dtbo zu /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rpi-proto.dtbo zu /usr/share/rpikernelhack/overlays/rpi-proto.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rpi-sense.dtbo zu /usr/share/rpikernelhack/overlays/rpi-sense.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/rra-digidac1-wm8741-audio.dtbo zu /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/sc16is750-i2c.dtbo zu /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/sc16is752-spi1.dtbo zu /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/sdhost.dtbo zu /usr/share/rpikernelhack/overlays/sdhost.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/sdio-1bit.dtbo zu /usr/share/rpikernelhack/overlays/sdio-1bit.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/sdio.dtbo zu /usr/share/rpikernelhack/overlays/sdio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/sdtweak.dtbo zu /usr/share/rpikernelhack/overlays/sdtweak.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/smi-dev.dtbo zu /usr/share/rpikernelhack/overlays/smi-dev.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/smi-nand.dtbo zu /usr/share/rpikernelhack/overlays/smi-nand.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/smi.dtbo zu /usr/share/rpikernelhack/overlays/smi.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi-gpio35-39.dtbo zu /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi-rtc.dtbo zu /usr/share/rpikernelhack/overlays/spi-rtc.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi0-hw-cs.dtbo zu /usr/share/rpikernelhack/overlays/spi0-hw-cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi1-1cs.dtbo zu /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi1-2cs.dtbo zu /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi1-3cs.dtbo zu /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi2-1cs.dtbo zu /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi2-2cs.dtbo zu /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/spi2-3cs.dtbo zu /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/tinylcd35.dtbo zu /usr/share/rpikernelhack/overlays/tinylcd35.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/uart1.dtbo zu /usr/share/rpikernelhack/overlays/uart1.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/vc4-fkms-v3d.dtbo zu /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/vc4-kms-v3d.dtbo zu /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/vga666.dtbo zu /usr/share/rpikernelhack/overlays/vga666.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/w1-gpio-pullup.dtbo zu /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/w1-gpio.dtbo zu /usr/share/rpikernelhack/overlays/w1-gpio.dtbo durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/overlays/wittypi.dtbo zu /usr/share/rpikernelhack/overlays/wittypi.dtbo durch rpikernelhack« wird hinzugefügt Entpacken von raspberrypi-kernel (1.20161215-1) über (1.20160921-1) ... run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.21+ /boot/kernel.img run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.4.21-v7+ /boot/kernel7.img Vorbereitung zum Entpacken von .../libraspberrypi-bin_1.20161215-1_armhf.deb ... Entpacken von libraspberrypi-bin (1.20161215-1) über (1.20160921-1) ... Vorbereitung zum Entpacken von .../libraspberrypi0_1.20161215-1_armhf.deb ... Entpacken von libraspberrypi0 (1.20161215-1) über (1.20160921-1) ... Vorbereitung zum Entpacken von .../raspberrypi-bootloader_1.20161215-1_armhf.deb ... »Umleitung von /boot/start.elf zu /usr/share/rpikernelhack/start.elf durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/start_cd.elf zu /usr/share/rpikernelhack/start_cd.elf durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/start_db.elf zu /usr/share/rpikernelhack/start_db.elf durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/start_x.elf zu /usr/share/rpikernelhack/start_x.elf durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/fixup.dat zu /usr/share/rpikernelhack/fixup.dat durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/fixup_cd.dat zu /usr/share/rpikernelhack/fixup_cd.dat durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/fixup_db.dat zu /usr/share/rpikernelhack/fixup_db.dat durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/fixup_x.dat zu /usr/share/rpikernelhack/fixup_x.dat durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/bootcode.bin zu /usr/share/rpikernelhack/bootcode.bin durch rpikernelhack« wird hinzugefügt »Umleitung von /boot/LICENCE.broadcom zu /usr/share/rpikernelhack/LICENCE.broadcom durch rpikernelhack« wird hinzugefügt Entpacken von raspberrypi-bootloader (1.20161215-1) über (1.20160921-1) ... Vorbereitung zum Entpacken von .../nodejs_6.9.4-1nodesource1~jessie1_armhf.deb ... Detected old npm client, removing... Entpacken von nodejs (6.9.4-1nodesource1~jessie1) über (4.6.0-1nodesource1~jessie1) ... Vorbereitung zum Entpacken von .../raspberrypi-net-mods_1.2.5_all.deb ... Entpacken von raspberrypi-net-mods (1.2.5) über (1.2.4) ... Trigger für man-db (2.7.0.2-5) werden verarbeitet ... Trigger für hicolor-icon-theme (0.13-1) werden verarbeitet ... Trigger für gnome-menus (3.13.3-6) werden verarbeitet ... Trigger für desktop-file-utils (0.22-1) werden verarbeitet ... Trigger für mime-support (3.58) werden verarbeitet ... Trigger für libc-bin (2.19-18+deb8u7) werden verarbeitet ... Trigger für systemd (215-17+deb8u6) werden verarbeitet ... Trigger für libglib2.0-0:armhf (2.42.1-1) werden verarbeitet ... Fehler traten auf beim Bearbeiten von: /var/cache/apt/archives/locales_2.19-18+deb8u7_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) pi@raspberrypi:/opt/iobroker $ !
                EDIT : jetzt ist es ohne Fehler durchgelaufen ( "sudo npm install npm@latest -g" )
                pi@raspberrypi:/opt/iobroker $ sudo npm install npm@latest -g
                /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
                • delegates@1.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/delegates
                • are-we-there-yet@1.1.2 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/are-we-there-yet
                • console-control-strings@1.1.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/console-control-strings
                • has-color@0.1.7 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/has-color
                • object-assign@4.1.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/object-assign
                • signal-exit@3.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/signal-exit
                • number-is-nan@1.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/code-point-at/node_modules/number-is-nan
                • code-point-at@1.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/code-point-at
                • number-is-nan@1.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/is-fullwidth-code-point/node_modules/number-is-nan
                • is-fullwidth-code-point@1.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/is-fullwidth-code-point
                • string-width@1.0.2 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/string-width
                • wide-align@1.1.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge/node_modules/wide-align
                • gauge@2.6.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/gauge
                • set-blocking@2.0.0 node_modules/npm/node_modules/node-gyp/node_modules/npmlog/node_modules/set-blocking
                • npmlog@3.1.2 node_modules/npm/node_modules/node-gyp/node_modules/npmlog
                • ms@0.7.1 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index/node_modules/debug/node_modules/ms
                • debug@2.2.0 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index/node_modules/debug
                • es6-iterator@2.0.0 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index/node_modules/es6-symbol/node_modules/es5-ext/node_modules/es6-iterator
                • es5-ext@0.10.12 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index/node_modules/es6-symbol/node_modules/es5-ext
                • d@0.1.1 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index/node_modules/es6-symbol/node_modules/d
                • es6-symbol@3.1.0 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index/node_modules/es6-symbol
                • array-index@1.0.0 node_modules/npm/node_modules/node-gyp/node_modules/path-array/node_modules/array-index
                • path-array@1.0.1 node_modules/npm/node_modules/node-gyp/node_modules/path-array
                • delegates@1.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/are-we-there-yet/node_modules/delegates
                • are-we-there-yet@1.1.2 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/are-we-there-yet
                • console-control-strings@1.1.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/console-control-strings
                • has-color@0.1.7 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/has-color
                • object-assign@4.1.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/object-assign
                • signal-exit@3.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/signal-exit
                • number-is-nan@1.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/code-point-at/node_modules/number-is-nan
                • code-point-at@1.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/code-point-at
                • number-is-nan@1.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/is-fullwidth-code-point/node_modules/number-is-nan
                • is-fullwidth-code-point@1.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/is-fullwidth-code-point
                • string-width@1.0.2 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/string-width
                • wide-align@1.1.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge/node_modules/wide-align
                • gauge@2.6.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/gauge
                • set-blocking@2.0.0 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog/node_modules/set-blocking
                • npmlog@3.1.2 node_modules/npm/node_modules/npm-registry-client/node_modules/npmlog
                • retry@0.10.0 node_modules/npm/node_modules/npm-registry-client/node_modules/retry
                • has-color@0.1.7 node_modules/npm/node_modules/npmlog/node_modules/gauge/node_modules/has-color
                • number-is-nan@1.0.0 node_modules/npm/node_modules/npmlog/node_modules/gauge/node_modules/string-width/node_modules/code-point-at/node_modules/number-is-nan
                • core-util-is@1.0.2 node_modules/npm/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/core-util-is
                • isarray@1.0.0 node_modules/npm/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/isarray
                • process-nextick-args@1.0.7 node_modules/npm/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/process-nextick-args
                • string_decoder@0.10.31 node_modules/npm/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/string_decoder
                • util-deprecate@1.0.2 node_modules/npm/node_modules/request/node_modules/bl/node_modules/readable-stream/node_modules/util-deprecate
                • readable-stream@2.0.6 node_modules/npm/node_modules/request/node_modules/bl/node_modules/readable-stream
                • bl@1.1.2 node_modules/npm/node_modules/request/node_modules/bl
                • node-uuid@1.4.7 node_modules/npm/node_modules/request/node_modules/node-uuid
                  /usr/lib
                  └─┬ npm@4.1.2
                  ├── glob@7.1.1
                  ├── graceful-fs@4.1.11
                  ├── inflight@1.0.6
                  ├─┬ JSONStream@1.3.0
                  │ ├── jsonparse@1.2.0
                  │ └── through@2.3.8
                  ├── lockfile@1.0.3
                  ├─┬ mississippi@1.2.0
                  │ ├─┬ concat-stream@1.5.2
                  │ │ ├─┬ readable-stream@2.0.6
                  │ │ │ ├── core-util-is@1.0.2
                  │ │ │ ├── isarray@1.0.0
                  │ │ │ ├── process-nextick-args@1.0.7
                  │ │ │ ├── string_decoder@0.10.31
                  │ │ │ └── util-deprecate@1.0.2
                  │ │ └── typedarray@0.0.6
                  │ ├─┬ duplexify@3.4.5
                  │ │ ├─┬ end-of-stream@1.0.0
                  │ │ │ └── once@1.3.3
                  │ │ └── stream-shift@1.0.0
                  │ ├─┬ end-of-stream@1.1.0
                  │ │ └── once@1.3.3
                  │ ├── flush-write-stream@1.0.0
                  │ ├── from2@2.3.0
                  │ ├── pump@1.0.1
                  │ ├── pumpify@1.3.5
                  │ ├── stream-each@1.1.2
                  │ └─┬ through2@2.0.1
                  │ └── xtend@4.0.1
                  ├─┬ node-gyp@3.5.0
                  │ └── nopt@3.0.6
                  ├─┬ nopt@4.0.1
                  │ └─┬ osenv@0.1.4
                  │ ├── os-homedir@1.0.2
                  │ └── os-tmpdir@1.0.2
                  ├── npm-registry-client@7.4.5
                  ├─┬ npmlog@4.0.2
                  │ └─┬ gauge@2.7.2
                  │ ├── signal-exit@3.0.2
                  │ ├─┬ string-width@1.0.2
                  │ │ ├── code-point-at@1.1.0
                  │ │ └─┬ is-fullwidth-code-point@1.0.0
                  │ │ └── number-is-nan@1.0.1
                  │ └── supports-color@0.2.0
                  ├─┬ osenv@0.1.4
                  ├── readable-stream@2.2.2
                  ├─┬ request@2.79.0
                  │ ├── aws4@1.5.0
                  │ ├── form-data@2.1.2
                  │ ├─┬ http-signature@1.1.1
                  │ │ └─┬ sshpk@1.10.1
                  │ │ └── dashdash@1.14.1
                  │ ├─┬ mime-types@2.1.13
                  │ │ └── mime-db@1.25.0
                  │ ├── qs@6.3.0
                  │ └─┬ tough-cookie@2.3.2
                  │ └── punycode@1.4.1
                  ├── retry@0.10.1
                  ├─┬ sorted-union-stream@2.1.3
                  │ ├─┬ from2@1.3.0
                  │ │ └─┬ readable-stream@1.1.14
                  │ │ ├── isarray@0.0.1
                  │ │ └── string_decoder@0.10.31
                  │ └── stream-iterate@1.1.1
                  ├── uuid@3.0.1
                  ├── which@1.2.12
                  └── write-file-atomic@1.3.1
                ! pi@raspberrypi:/opt/iobroker $
                  SigiMOE
                  Hier mal noch was, was nicht funktioniert hat : npm install iobroker.js-controller –production
                  pi@raspberrypi:/opt/iobroker $ npm cache clean
                  pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller --production
                  npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
                  ! > unix-dgram@0.2.3 install /opt/iobroker/node_modules/unix-dgram
                  node-gyp rebuild
                  ! make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                  CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  /usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1plus: symbol lookup error: /usr/lib/arm-linux-gnueabihf/libmpfr.so.4: undefined symbol: __g?rfR_one
                  unix_dgram.target.mk:92: recipe for target 'Release/obj.target/unix_dgram/src/unix_dgram.o' failed
                  make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
                  make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                  gyp ERR! build error
                  gyp ERR! stack Error: make failed with exit code: 2
                  gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                  gyp ERR! stack at emitTwo (events.js:106:13)
                  gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                  gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                  gyp ERR! System Linux 4.4.21-v7+
                  gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                  gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
                  gyp ERR! node -v v6.9.4
                  gyp ERR! node-gyp -v v3.5.0
                  gyp ERR! not ok
                  ! > iobroker.js-controller@0.15.3 install /opt/iobroker/node_modules/iobroker.js-controller
                  node lib/setup.js setup first
                  ! array-flatten@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/array-flatten -> node_modules/array-flatten
                  base64-url@1.3.3 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe/node_modules/base64-url -> node_modules/base64-url
                  bytes@2.4.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/bytes -> node_modules/bytes
                  connect-flash@0.1.1 node_modules/iobroker.admin/node_modules/connect-flash -> node_modules/connect-flash
                  content-type@1.0.2 node_modules/iobroker.admin/node_modules/body-parser/node_modules/content-type -> node_modules/content-type
                  cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/cookie-parser/node_modules/cookie-signature -> node_modules/cookie-signature
                  cookie-parser@1.4.3 node_modules/iobroker.admin/node_modules/cookie-parser -> node_modules/cookie-parser
                  depd@1.1.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/depd -> node_modules/depd
                  destroy@1.0.4 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/destroy -> node_modules/destroy
                  ee-first@1.1.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/on-finished/node_modules/ee-first -> node_modules/ee-first
                  encodeurl@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/encodeurl -> node_modules/encodeurl
                  escape-html@1.0.3 node_modules/iobroker.admin/node_modules/express/node_modules/escape-html -> node_modules/escape-html
                  etag@1.7.0 node_modules/iobroker.admin/node_modules/express/node_modules/etag -> node_modules/etag
                  ms@0.7.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/debug/node_modules/ms -> node_modules/express/node_modules/ms
                  debug@2.2.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/debug -> node_modules/express/node_modules/debug
                  qs@6.2.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/qs -> node_modules/express/node_modules/qs
                  ms@0.7.1 node_modules/iobroker.admin/node_modules/express/node_modules/debug/node_modules/ms -> node_modules/finalhandler/node_modules/ms
                  debug@2.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/debug -> node_modules/finalhandler/node_modules/debug
                  forwarded@0.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr/node_modules/forwarded -> node_modules/forwarded
                  fresh@0.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/fresh -> node_modules/fresh
                  • isarray@0.0.1 node_modules/has-binary/node_modules/isarray
                  • inherits@2.0.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/inherits
                  • setprototypeof@1.0.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/setprototypeof
                  • http-errors@1.5.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors
                  • iconv-lite@0.4.13 node_modules/iobroker.admin/node_modules/body-parser/node_modules/iconv-lite
                  • raw-body@2.1.7 node_modules/iobroker.admin/node_modules/body-parser/node_modules/raw-body
                  • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/mime-types/node_modules/mime-db
                  • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/mime-types
                  • type-is@1.6.13 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is
                  • body-parser@1.15.2 node_modules/iobroker.admin/node_modules/body-parser
                  • cookie@0.3.1 node_modules/iobroker.admin/node_modules/cookie-parser/node_modules/cookie
                  • cookie@0.3.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/cookie
                  • cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/express-session/node_modules/cookie-signature
                  • crc@3.4.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/crc
                  • ms@0.7.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/debug/node_modules/ms
                  • depd@1.1.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/depd
                  • parseurl@1.3.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/parseurl
                  • utils-merge@1.0.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/utils-merge
                  • express-session@1.14.2 node_modules/iobroker.admin/node_modules/express-session
                  • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/mime-types/node_modules/mime-db
                  • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/mime-types
                  • negotiator@0.6.1 node_modules/iobroker.admin/node_modules/express/node_modules/accepts/node_modules/negotiator
                  • accepts@1.3.3 node_modules/iobroker.admin/node_modules/express/node_modules/accepts
                  • content-disposition@0.5.1 node_modules/iobroker.admin/node_modules/express/node_modules/content-disposition
                  • content-type@1.0.2 node_modules/iobroker.admin/node_modules/express/node_modules/content-type
                  • cookie@0.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/cookie
                  • cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/express/node_modules/cookie-signature
                  • depd@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/depd
                  • statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler/node_modules/statuses
                  • unpipe@1.0.0 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler/node_modules/unpipe
                  • ee-first@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/on-finished/node_modules/ee-first
                  • on-finished@2.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/on-finished
                  • finalhandler@0.5.0 node_modules/iobroker.admin/node_modules/express/node_modules/finalhandler
                  • ipaddr.js@1.1.1 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr/node_modules/ipaddr.js
                  • proxy-addr@1.1.2 node_modules/iobroker.admin/node_modules/express/node_modules/proxy-addr
                  • qs@6.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/qs
                  • inherits@2.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors/node_modules/inherits
                  • setprototypeof@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors/node_modules/setprototypeof
                  • mime@1.3.4 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/mime
                  • statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/statuses
                  • http-errors@1.5.0 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/http-errors
                  • send@0.14.1 node_modules/iobroker.admin/node_modules/express/node_modules/send
                  • serve-static@1.11.1 node_modules/iobroker.admin/node_modules/express/node_modules/serve-static
                  • media-typer@0.3.0 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/media-typer
                  • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/mime-types/node_modules/mime-db
                  • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/express/node_modules/type-is/node_modules/mime-types
                  • type-is@1.6.13 node_modules/iobroker.admin/node_modules/express/node_modules/type-is
                  • express@4.14.0 node_modules/iobroker.admin/node_modules/express
                  • passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport-local/node_modules/passport-strategy
                  • aws-sign2@0.6.0 node_modules/iobroker.admin/node_modules/request/node_modules/aws-sign2
                  • aws4@1.5.0 node_modules/iobroker.admin/node_modules/request/node_modules/aws4
                  • caseless@0.11.0 node_modules/iobroker.admin/node_modules/request/node_modules/caseless
                  • delayed-stream@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
                  • combined-stream@1.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/combined-stream
                  • extend@3.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/extend
                  • forever-agent@0.6.1 node_modules/iobroker.admin/node_modules/request/node_modules/forever-agent
                  • asynckit@0.4.0 node_modules/iobroker.admin/node_modules/request/node_modules/form-data/node_modules/asynckit
                  • ansi-styles@2.2.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/ansi-styles
                  • escape-string-regexp@1.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/escape-string-regexp
                  • ansi-regex@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi/node_modules/ansi-regex
                  • has-ansi@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/has-ansi
                  • ansi-regex@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi/node_modules/ansi-regex
                  • strip-ansi@3.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/strip-ansi
                  • supports-color@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk/node_modules/supports-color
                  • chalk@1.1.3 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/chalk
                  • graceful-readlink@1.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/commander/node_modules/graceful-readlink
                  • commander@2.9.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/commander
                  • generate-function@2.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-function
                  • is-property@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property/node_modules/is-property
                  • generate-object-property@1.2.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/generate-object-property
                  • jsonpointer@4.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid/node_modules/jsonpointer
                  • pinkie@2.0.4 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise/node_modules/pinkie
                  • pinkie-promise@2.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/pinkie-promise
                  • hoek@2.16.3 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/hoek
                  • boom@2.10.1 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/boom
                  • cryptiles@2.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/cryptiles
                  • sntp@1.0.9 node_modules/iobroker.admin/node_modules/request/node_modules/hawk/node_modules/sntp
                  • hawk@3.1.3 node_modules/iobroker.admin/node_modules/request/node_modules/hawk
                  • assert-plus@0.2.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/assert-plus
                  • extsprintf@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/extsprintf
                  • json-schema@0.2.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/json-schema
                  • verror@1.3.6 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim/node_modules/verror
                  • jsprim@1.3.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/jsprim
                  • asn1@0.2.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/asn1
                  • assert-plus@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/assert-plus
                  • dashdash@1.14.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/dashdash
                  • getpass@0.1.6 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/getpass
                  • jsbn@0.1.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/jsbn
                  • ecc-jsbn@0.1.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/ecc-jsbn
                  • jodid25519@1.0.2 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/jodid25519
                  • tweetnacl@0.14.3 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/tweetnacl
                  • bcrypt-pbkdf@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk/node_modules/bcrypt-pbkdf
                  • sshpk@1.10.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature/node_modules/sshpk
                  • http-signature@1.1.1 node_modules/iobroker.admin/node_modules/request/node_modules/http-signature
                  • is-typedarray@1.0.0 node_modules/iobroker.admin/node_modules/request/node_modules/is-typedarray
                  • isstream@0.1.2 node_modules/iobroker.admin/node_modules/request/node_modules/isstream
                  • json-stringify-safe@5.0.1 node_modules/iobroker.admin/node_modules/request/node_modules/json-stringify-safe
                  • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/request/node_modules/mime-types/node_modules/mime-db
                  • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/request/node_modules/mime-types
                  • form-data@2.1.2 node_modules/iobroker.admin/node_modules/request/node_modules/form-data
                  • node-uuid@1.4.7 node_modules/iobroker.admin/node_modules/request/node_modules/node-uuid
                  • oauth-sign@0.8.2 node_modules/iobroker.admin/node_modules/request/node_modules/oauth-sign
                  • stringstream@0.0.5 node_modules/iobroker.admin/node_modules/request/node_modules/stringstream
                  • punycode@1.4.1 node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie/node_modules/punycode
                  • tough-cookie@2.3.2 node_modules/iobroker.admin/node_modules/request/node_modules/tough-cookie
                  • tunnel-agent@0.4.3 node_modules/iobroker.admin/node_modules/request/node_modules/tunnel-agent
                  • ms@0.7.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug/node_modules/ms
                  • debug@2.2.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug
                  • mime-db@1.24.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/mime-types/node_modules/mime-db
                  • mime-types@2.1.12 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/mime-types
                  • negotiator@0.6.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts/node_modules/negotiator
                  • accepts@1.3.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/accepts
                  • base64id@0.1.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/base64id
                  • after@0.8.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/after
                  • arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/arraybuffer.slice
                  • base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/base64-arraybuffer
                  • blob@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/blob
                  • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary/node_modules/isarray
                  • has-binary@0.1.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/has-binary
                  • wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser/node_modules/wtf-8
                  • engine.io-parser@1.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/engine.io-parser
                  • options@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/options
                  • ultron@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/ultron
                  • ws@1.1.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                  • engine.io@1.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io
                  • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/has-binary/node_modules/isarray
                  • has-binary@0.1.7 node_modules/iobroker.admin/node_modules/socket.io/node_modules/has-binary
                  • benchmark@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/benchmark
                  • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/component-emitter
                  • debug@0.7.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/debug
                  • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/isarray
                  • json3@3.2.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser/node_modules/json3
                  • socket.io-parser@2.2.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter/node_modules/socket.io-parser
                  • socket.io-adapter@0.4.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-adapter
                  • backo2@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/backo2
                  • component-bind@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-bind
                  • component-emitter@1.2.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/component-emitter
                  • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter
                  • component-inherit@0.0.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-inherit
                  • after@0.8.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/after
                  • arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/arraybuffer.slice
                  • base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/base64-arraybuffer
                  • blob@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/blob
                  • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary/node_modules/isarray
                  • has-binary@0.1.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/has-binary
                  • wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser/node_modules/wtf-8
                  • engine.io-parser@1.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/engine.io-parser
                  • has-cors@1.1.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/has-cors
                  • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson/node_modules/better-assert/node_modules/callsite
                  • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson/node_modules/better-assert
                  • parsejson@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parsejson
                  • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs/node_modules/better-assert/node_modules/callsite
                  • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs/node_modules/better-assert
                  • parseqs@0.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/parseqs
                  • options@0.0.6 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/options
                  • ultron@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/ultron
                  • ws@1.1.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                  • xmlhttprequest-ssl@1.5.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/xmlhttprequest-ssl
                  • yeast@0.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/yeast
                  • indexof@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/indexof
                  • object-component@0.0.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/object-component
                  • callsite@1.0.0 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/node_modules/better-assert/node_modules/callsite
                  • better-assert@1.0.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri/node_modules/better-assert
                  • parseuri@0.0.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/parseuri
                  • engine.io-client@1.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client
                  • to-array@0.1.4 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/to-array
                  • component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/component-emitter
                  • isarray@0.0.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/isarray
                  • json3@3.3.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser/node_modules/json3
                  • socket.io-parser@2.3.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-parser
                  • socket.io-client@1.5.1 node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client
                  • socket.io@1.5.1 node_modules/iobroker.admin/node_modules/socket.io
                  • xtend@4.0.1 node_modules/iobroker.admin/node_modules/xtend
                  • is-my-json-valid@2.15.0 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator/node_modules/is-my-json-valid
                  • har-validator@2.0.6 node_modules/iobroker.admin/node_modules/request/node_modules/har-validator
                  • request@2.78.0 node_modules/iobroker.admin/node_modules/request
                    media-typer@0.3.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/type-is/node_modules/media-typer -> node_modules/media-typer
                    merge-descriptors@1.0.1 node_modules/iobroker.admin/node_modules/express/node_modules/merge-descriptors -> node_modules/merge-descriptors
                    methods@1.1.2 node_modules/iobroker.admin/node_modules/express/node_modules/methods -> node_modules/methods
                    on-finished@2.3.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/on-finished -> node_modules/on-finished
                    on-headers@1.0.1 node_modules/iobroker.admin/node_modules/express-session/node_modules/on-headers -> node_modules/on-headers
                    parseurl@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/parseurl -> node_modules/parseurl
                    passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport/node_modules/passport-strategy -> node_modules/passport-strategy
                    passport-local@1.0.0 node_modules/iobroker.admin/node_modules/passport-local -> node_modules/passport-local
                    passport.socketio@3.7.0 node_modules/iobroker.admin/node_modules/passport.socketio -> node_modules/passport.socketio
                    path-to-regexp@0.1.7 node_modules/iobroker.admin/node_modules/express/node_modules/path-to-regexp -> node_modules/path-to-regexp
                    pause@0.0.1 node_modules/iobroker.admin/node_modules/passport/node_modules/pause -> node_modules/pause
                    passport@0.3.2 node_modules/iobroker.admin/node_modules/passport -> node_modules/passport
                    random-bytes@1.0.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe/node_modules/random-bytes -> node_modules/random-bytes
                    range-parser@1.2.0 node_modules/iobroker.admin/node_modules/express/node_modules/range-parser -> node_modules/range-parser
                    qs@6.3.0 node_modules/iobroker.admin/node_modules/request/node_modules/qs -> node_modules/request/node_modules/qs
                    ms@0.7.1 node_modules/iobroker.admin/node_modules/express/node_modules/send/node_modules/ms -> node_modules/send/node_modules/debug/node_modules/ms
                    debug@2.2.0 node_modules/iobroker.admin/node_modules/express-session/node_modules/debug -> node_modules/send/node_modules/debug
                  • isarray@0.0.1 node_modules/socket.io-parser/node_modules/isarray
                    statuses@1.3.1 node_modules/iobroker.admin/node_modules/body-parser/node_modules/http-errors/node_modules/statuses -> node_modules/statuses
                    uid-safe@2.1.3 node_modules/iobroker.admin/node_modules/express-session/node_modules/uid-safe -> node_modules/uid-safe
                    unpipe@1.0.0 node_modules/iobroker.admin/node_modules/body-parser/node_modules/raw-body/node_modules/unpipe -> node_modules/unpipe
                    utils-merge@1.0.0 node_modules/iobroker.admin/node_modules/express/node_modules/utils-merge -> node_modules/utils-merge
                    vary@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/vary -> node_modules/vary
                    iobroker.core@1.0.0 /opt/iobroker
                    └─┬ iobroker.js-controller@0.15.3
                    ├─┬ iobroker.admin@1.6.11
                    │ ├─┬ body-parser@1.16.0
                    │ │ ├── debug@2.6.0
                    │ │ ├─┬ http-errors@1.5.1
                    │ │ │ └── setprototypeof@1.0.2
                    │ │ ├── iconv-lite@0.4.15
                    │ │ ├── qs@6.2.1
                    │ │ ├── raw-body@2.2.0
                    │ │ └── type-is@1.6.14
                    │ ├─┬ express@4.14.1
                    │ │ ├── content-disposition@0.5.2
                    │ │ ├── finalhandler@0.5.1
                    │ │ ├─┬ proxy-addr@1.1.3
                    │ │ │ └── ipaddr.js@1.2.0
                    │ │ ├── send@0.14.2
                    │ │ └── serve-static@1.11.2
                    │ └─┬ express-session@1.15.0
                    │ └── crc@3.4.4
                    ├─┬ jszip@3.1.3
                    │ └─┬ readable-stream@2.0.6
                    │ └── isarray@1.0.0
                    ├─┬ letsencrypt@2.1.8
                    │ └─┬ rsa-compat@1.2.7
                    │ └─┬ ursa@0.9.4
                    │ └── nan@2.5.1
                    ├─┬ socket.io@1.7.2
                    │ ├── debug@2.3.3
                    │ ├─┬ engine.io@1.8.2
                    │ │ └── debug@2.3.3
                    │ ├─┬ has-binary@0.1.7
                    │ │ └── isarray@0.0.1
                    │ └─┬ socket.io-adapter@0.5.0
                    │ └── debug@2.3.3
                    └─┬ socket.io-client@1.7.2
                    ├── debug@2.3.3
                    └─┬ engine.io-client@1.8.2
                    └── debug@2.3.3
                  ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  noch eine Idee was ich alles machen könnte ?
                    @SigiMOE:
                    noch eine Idee was ich alles machen könnte ? `
                    Ja!
                    Die gleichen Befehle mit sudo absetzen.
                    Du bist als user pi angemeldet.
                      SigiMOE
                      bingo !!!!
                      Jetzt geht es wieder….
                      #PUHVIELENDANKHABICHECHTNOCHMALGLÜCKGEHABT
                      Vielen Dank an alle, Die mir geholfen haben...
                      CU bis zum nächsten SUPERGAU
                        skorpil
                        Brauche zum gleichen Thema Hilfe:
                        Ich habe alle oben aufgeführten Schritte durchgeführt, nachdem auch bei mir das update fehlgeschlagen ist.
                        Alle Schritte laufen durch, bis auf " sudo npm install iobroker –unsafe-perm "
                        da kriege ich dann folgendes Fehlerlog. Kann mir jemand einen Rat geben, wie ich das löse?
                        0 info it worked if it ends with ok
                        1 verbose cli [ '/usr/bin/nodejs',
                        1 verbose cli   '/usr/bin/npm',
                        1 verbose cli   'install',
                        1 verbose cli   'iobroker',
                        1 verbose cli   '--unsafe-perm' ]
                        2 info using npm@4.1.2
                        3 info using node@v6.9.5
                        4 silly loadCurrentTree Starting
                        5 silly install loadCurrentTree
                        6 silly install readLocalPackageData
                        7 silly fetchPackageMetaData iobroker
                        8 silly fetchOtherPackageData iobroker
                        9 silly cache add args [ 'iobroker', null ]
                        10 verbose cache add spec iobroker
                        11 silly cache add parsed spec Result {
                        11 silly cache add   raw: 'iobroker',
                        11 silly cache add   scope: null,
                        11 silly cache add   escapedName: 'iobroker',
                        11 silly cache add   name: null,
                        11 silly cache add   rawSpec: 'iobroker',
                        11 silly cache add   spec: '/opt/iobroker/iobroker',
                        11 silly cache add   type: 'local' }
                        12 silly addLocalTarball shasum (computed) 172d89ea6df6ab508c7b69dc0540b583db07e40c
                        13 verbose addTmpTarball /opt/iobroker/iobroker not in flight; adding
                        14 verbose correctMkdir /root/.npm correctMkdir not in flight; initializing
                        15 verbose addTmpTarball validating metadata from /opt/iobroker/iobroker
                        16 verbose tar unpack /opt/iobroker/iobroker
                        17 verbose tar unpacking to /tmp/npm-17981-2b62b2d6/unpack-0ba91d68
                        18 silly gentlyRm /tmp/npm-17981-2b62b2d6/unpack-0ba91d68 is being purged
                        19 verbose gentlyRm don't care about contents; nuking /tmp/npm-17981-2b62b2d6/unpack-0ba91d68
                        20 silly gunzTarPerm modes [ '755', '644' ]
                        21 error not a package /opt/iobroker/iobroker
                        22 error addLocal Could not install /opt/iobroker/iobroker
                        23 silly fetchPackageMetaData Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
                        23 silly fetchPackageMetaData     at Error (native)
                        23 silly fetchPackageMetaData  error for iobroker { Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
                        23 silly fetchPackageMetaData   errno: -2,
                        23 silly fetchPackageMetaData   code: 'ENOENT',
                        23 silly fetchPackageMetaData   syscall: 'open',
                        23 silly fetchPackageMetaData   path: '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json' }
                        24 silly rollbackFailedOptional Starting
                        25 silly rollbackFailedOptional Finishing
                        26 silly runTopLevelLifecycles Finishing
                        27 silly install printInstalled
                        28 verbose stack Error: ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
                        28 verbose stack     at Error (native)
                        29 verbose cwd /opt/iobroker
                        30 error Linux 4.4.38-v7+
                        31 error argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker" "--unsafe-perm"
                        32 error node v6.9.5
                        33 error npm  v4.1.2
                        34 error path /tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json
                        35 error code ENOENT
                        36 error errno -2
                        37 error syscall open
                        38 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
                        39 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json'
                        39 error enoent This is most likely not a problem with npm itself
                        39 error enoent and is related to npm not being able to find a file.
                        40 verbose exit [ -2, true ]
                          @skorpil:
                          Kann mir jemand einen Rat geben, wie ich das löse? `
                          Leider nein :(
                          Ich habe auch in der letzten Woche drei Installationen zerschossen mit diesem Ergebnis.
                          @skorpil:
                          38 error enoent ENOENT: no such file or directory, open '/tmp/npm-17981-2b62b2d6/unpack-0ba91d68/package.json' `
                          Bei zweien war ich definitiv selber schuld, beim dritten weiss ich es noch nicht warum.
                          Leider scheint es so, dass bei dieser Fehlermeldung anscheinen keine Rettung mehr möglich ist.
                          Ich habe die SD-Karten zur Seite gelegt und jeweils auf einer neuen Karte neu installiert.
                          War für mich nicht lebenswichtig, da es eigentlich nur Testinstallationen waren. Ich wollte irgendwann einmal die iobroker.data aus den alten Installationen in die neuen kopieren, ob dann wieder alles da ist.
                          Sorry for bad news :(
                          Aber vielleicht hat einer da mehr Glück gehabt.
                            skorpil
                            Homoran,
                            erstmal Danke.
                            –-um aber meine Verwirrung jetzt komplett zu machen: iobroker läuft, wenn ich ihn über den browser aufrufe. Allerdings mit js-controller 0.15.3. Und den wollte ich ja updaten.
                            Und ganz merkwürdig ist: wenn ich "iobroker stop" eingebe, kommt als Antwort "iobroker Controller daemon is not running". Ja was denn jetzt? Er läuft und läßt sich nicht stoppen? Was ist das?
                              @skorpil:
                              Homoran,
                              erstmal Danke.
                              Und ganz merkwürdig ist: wenn ich "iobroker stop" eingebe, kommt als Antwort "iobroker Controller daemon is not running". Ja was denn jetzt? Er läuft und läßt sich nicht stoppen? Was ist das? `
                              Vielleicht kommen wir so sogar der Ursache auf die Spur, auch wenn ich mich immer noch als Linux-Noob einordne.
                              In allen Installationen lag (weil eben nur Testinstallation) eine tlw. uralte Controller-Version vor.
                              Bei einer Installation habe ich den Code, wie er im Admin unter Reiter Hosts angezeigt wird, wenn man auf das Update-Icon klickt, ungeprüft in die Konsole kopiert.
                              Leider sind dort Backslashs statt slashs gewesen (cd ****opt****iobroker, anstelle (cd ****/opt/****iobroker).
                              Dadurch wurde im Verzeichnis root erneut installiert.
                              Wenn da etwas ähnliches bei dir ist, hast du vielleicht auch zwei verschiedene Installationen.
                                skorpil
                                Rainer,
                                das habe ich mir auch gedacht. Es muß ja irgendwo ein iobroker laufen. Nur, wo resp. wie finde ich diese. Gerade lasse ich mein root Verzeichnis nach Dateien "iobroker" durchsuchen. Dauert etwas…
                                Den finde ich gar nicht. Bei mir steht unter hosts nur bei Plattform "Javascript/Node.js" und sonst nichts. oder ich bin zu dumm…
                                  @skorpil:
                                  oder ich bin zu dumm… `
                                  nö, du hast ja jetzt die aktuelle Version.
                                  Dieser Button erscheint nur, wenn es eine neuere Version als die installierte gibt.
                                    skorpil
                                    und die ist "0.15.3" (installiert) und "0.15.3" (verfügbar). Zumindest steht das so unter host.
                                    Meine Installation des iobroker findet sich im Verzeichnis /opt/iobroker Sonst finde ich nur noch eine weitere Datei iobroker in user/bin.
                                    Ich verstehe es nicht.
                                      skorpil
                                      Ich bin ein Stückchen weiter: als root kann ich iobroker stoppen, aber nicht als pi. Was sagt uns das?
                                        @skorpil:
                                        Ich bin ein Stückchen weiter: als root kann ich iobroker stoppen, aber nicht als pi. Was sagt uns das? `
                                        Hattest du das Upgrade des controllers als root durchgeführt?
                                        Und die Suche nach ioBroker als pi?
                                          skorpil
                                          Ich weiß es nicht mehr, um ehrlich zu sein. Ich glaube, den Controller Update als pi. Die Suche habe ich sowohl als auch laufen lassen.
                                          Ich versuche jetzt den Controller Update als Root…
