  2. English
  3. ioBroker general
  4. ioBroker does not respond SOLVED
Geplant Angeheftet Gesperrt Verschoben ioBroker general
12 Beiträge 3 Kommentatoren 2.5k Aufrufe 2 Beobachtet
  • A
    A
    ap2017
    schrieb am zuletzt editiert von ap2017
    Recently my Linux based ioBroker server stopped responding, giving message "This site can’t be reached 192.168.1.74 refused to connect". I can login to Linux using PuTTY with no problem. I suspect low SSD available memory, here is my df -h log:
    ap@AP-Tiny:/opt/iobroker$ df -h
    Filesystem      Size  Used Avail Use% Mounted on
    udev            1.9G     0  1.9G   0% /dev
    tmpfs           377M  1.2M  376M   1% /run
    /dev/sda1       110G  105G     0 100% /
    tmpfs           1.9G     0  1.9G   0% /dev/shm
    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
    tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
    tmpfs           377M  4.0K  377M   1% /run/user/111
    tmpfs           377M     0  377M   0% /run/user/1000
    MOD-Edit: added code-tags
    If I am low on memory, where I can delete Linux / ioBorker temporarily files or history logs over PuTTY?
    • A ap2017
      @ap2017 sagte in ioBroker does not respond:
      there is low memory but not no space left.
      what is zhe output of iobroker list instances
      A 2 Antworten Letzte Antwort
        A
        A
        ap2017
        ap@AP-Tiny:~$ iobroker list instances
        + system.adapter.accuweather.0            : accuweather           : AP-Tiny                                  -  enabled
        + system.adapter.admin.0                  : admin                 : AP-Tiny                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : AP-Tiny                                  -  enabled
          system.adapter.cloud.0                  : cloud                 : AP-Tiny                                  - disabled
          system.adapter.deconz.0                 : deconz                : AP-Tiny                                  - disabled, port: 8080
        + system.adapter.discovery.0              : discovery             : AP-Tiny                                  -  enabled
          system.adapter.echarts.0                : echarts               : AP-Tiny                                  -  enabled
          system.adapter.flot.0                   : flot                  : AP-Tiny                                  -  enabled
        + system.adapter.history.0                : history               : AP-Tiny                                  -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : AP-Tiny                                  -  enabled
        + system.adapter.info.0                   : info                  : AP-Tiny                                  -  enabled
        + system.adapter.javascript.0             : javascript            : AP-Tiny                                  -  enabled
        + system.adapter.mysensors.0              : mysensors             : AP-Tiny                                  -  enabled, port: 5003, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : AP-Tiny                                  -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.0               : socketio              : AP-Tiny                                  -  enabled, port: 8084, bind: 192.168.1.74, run as: admin
          system.adapter.sonoff.0                 : sonoff                : AP-Tiny                                  - disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : AP-Tiny                                  -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : AP-Tiny                                  -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : AP-Tiny                                  -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : AP-Tiny                                  -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : AP-Tiny                                  -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : AP-Tiny                                  -  enabled
          system.adapter.vis-material.0           : vis-material          : AP-Tiny                                  -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : AP-Tiny                                  -  enabled
          system.adapter.vis-metro.0              : vis-metro             : AP-Tiny                                  -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : AP-Tiny                                  -  enabled
          system.adapter.vis.0                    : vis                   : AP-Tiny                                  -  enabled
        + system.adapter.web.0                    : web                   : AP-Tiny                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : AP-Tiny                                  -  enabled, port: /dev/ttyACM1
        + system.adapter.zwave2.0                 : zwave2                : AP-Tiny                                  -  enabled
        + instance is alive
        Server Cannot save Dataset to /opt/iobroker/iobroker-data/states.json.new: ENOSPC: no space left on device, write
        Server Cannot save /opt/iobroker/iobroker-data/states.json: Error: ENOSPC: no space left on device, write
        ap@AP-Tiny:~$
        • A ap2017
          + instance is alive
          ap@AP-Tiny:~$
          @ap2017 thanks - looks good
          iobroker status
          EDIT- it doesn't :-(
            A
            A
            ap2017
            ap@AP-Tiny:~$ iobroker status
            Objects type: file
            States  type: file
            A K 2 Antworten Letzte Antwort
            • A ap2017
              Objects type: file
              States  type: file
              A
              A
              ap2017
              @ap2017 What if I clone existing drive onto larger drive using Acronis, will it work? It should, right?
              • A ap2017
                + instance is alive
                ap@AP-Tiny:~$
                @ap2017 You had been right ENOSPC!
                you should delete some data
                possible data can be logs or history.
                I'm not sure how to do it with puTTY, I prefer filezilla for file-operations.
                There you can save the history data to your pc before you delete them.
                the data will be found in /opt/iobroker/iobroker-data/history or /opt/iobroker/log
                if you have made some backups, stired locally, they will be in /opt/iobroker/backups
                • A ap2017
                  It should, right?
                  yes
                    A
                    A
                    ap2017
                    @homoran Thank you. I will try to clone drive first, if it does not help will start deleting
                    history files.
                      It should, right?
                      yes
                      A
                      A
                      ap2017
                      @homoran Worked smooth, thank you!
                      • A ap2017
                        Congrats
                        Thanks for your feedback
                        • A ap2017
                          Objects type: file
                          States  type: file
                          K
                          K
                          Karabas
                          @ap2017
                          Hi see this link
                          https://www.youtube.com/watch?v=FZeWNwXC7rk&t=48s
                          this work
                          84.2k
