  4. Backup / Restore von Raspberry Pi auf Synology [gelöst]
    6.7k
46 Beiträge 6 Kommentatoren 5.2k Aufrufe 5 Beobachtet
  • Z ZoXx
    @da_Woody backup ist durchgelaufen, kann jedoch den Container nicht mehr auflösen.
    Folgende Fehlermeldung in Chrome: ERR_EMPTY_RESPONSE
    Ich kopiere mal den Log:
    2021-07-07 20:07:29.311  - info: host.IoBroker received SIGTERM
    2021-07-07 20:07:29.318  - info: admin.0 (110) terminating http server on port 8081
    2021-07-07 20:07:29.319  - info: info.0 (152) cleaned everything up...
    2021-07-07 20:07:29.332  - info: backitup.0 (629) cleaned everything up...
    2021-07-07 20:07:29.331  - info: host.IoBroker stopInstance system.adapter.admin.0 (force=false, process=true)
    2021-07-07 20:07:29.332  - info: host.IoBroker stopInstance system.adapter.discovery.0 (force=false, process=true)
    2021-07-07 20:07:29.334  - info: host.IoBroker stopInstance system.adapter.info.0 (force=false, process=true)
    2021-07-07 20:07:29.336  - info: host.IoBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    2021-07-07 20:07:29.352  - info: admin.0 (110) Got terminate signal TERMINATE_YOURSELF
    2021-07-07 20:07:29.355  - info: info.0 (152) Got terminate signal TERMINATE_YOURSELF
    2021-07-07 20:07:29.354  - info: discovery.0 (125) Got terminate signal TERMINATE_YOURSELF
    2021-07-07 20:07:29.356  - info: backitup.0 (629) Got terminate signal TERMINATE_YOURSELF
    2021-07-07 20:07:29.362  - info: discovery.0 (125) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-07-07 20:07:29.363  - info: host.IoBroker stopInstance system.adapter.admin.0 send kill signal
    2021-07-07 20:07:29.364  - info: info.0 (152) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-07-07 20:07:29.365  - info: admin.0 (110) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-07-07 20:07:29.366  - debug: backitup.0 (629) Plugin sentry destroyed
    2021-07-07 20:07:29.367  - info: backitup.0 (629) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-07-07 20:07:29.401  - info: host.IoBroker stopInstance system.adapter.discovery.0 send kill signal
    2021-07-07 20:07:29.402  - info: host.IoBroker stopInstance system.adapter.info.0 send kill signal
    2021-07-07 20:07:29.403  - info: host.IoBroker stopInstance system.adapter.backitup.0 send kill signal
    2021-07-07 20:07:30.224  - info: host.IoBroker instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-07-07 20:07:30.275  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-07-07 20:07:30.278  - info: host.IoBroker instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-07-07 20:07:30.279  - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2021-07-07 20:07:30.280  - info: host.IoBroker All instances are stopped.
    2021-07-07 20:07:30.374  - info: host.IoBroker terminated
    2021-07-07 20:35:29.873  - info: host.98f3f68508a4 iobroker.js-controller version 3.2.16 js-controller starting
    2021-07-07 20:35:29.883  - info: host.98f3f68508a4 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-07-07 20:35:29.884  - info: host.98f3f68508a4 hostname: 98f3f68508a4, node: v12.22.1
    2021-07-07 20:35:29.886  - info: host.98f3f68508a4 ip addresses: 172.17.0.6
    2021-07-07 20:35:30.785  - info: host.98f3f68508a4 connected to Objects and States
    2021-07-07 20:35:30.901  - info: host.98f3f68508a4 added notifications configuration of host
    2021-07-07 20:35:31.880  - info: host.98f3f68508a4 Delete host system.host.IoBroker
    2021-07-07 20:35:31.981  - info: host.98f3f68508a4 28 instances found
    2021-07-07 20:35:32.016  - warn: host.98f3f68508a4 does not start any instances on this host
    GlasfaserG Offline
    GlasfaserG Offline
    @zoxx sagte in Backup / Restore von Raspberry Pi auf Synology:
    Mach nochmal :
    pkill -u iobroker
    iobroker host this
    und danach den Container neu starten .
    EDIT :
    was ist das denn , hast du so ein Netzwerk :
    Thomas BraunT Z 2 Antworten Letzte Antwort
    • GlasfaserG Glasfaser
      Mach nochmal :
      pkill -u iobroker
      iobroker host this
      EDIT :
      @glasfaser Extravagant, aber ein zugelassener Private IP-Bereich.
        Mach nochmal :
        pkill -u iobroker
        iobroker host this
        EDIT :
        Z Offline
        Z Offline
        ZoXx
        @glasfaser said in Backup / Restore von Raspberry Pi auf Synology:
        pkill -u iobroker        iobroker host this
        Anbei der Log als Screenhot.
        EDIT :
        Negativ, stammt evtl. vom Docker selbst?
        • Z ZoXx
          EDIT :
          GlasfaserG Offline
          GlasfaserG Offline
          Was negativ ?
          Keine Ahnung was du da hast ,
          Welche IP hat denn deine Syn , hast du die gleiche dann für ioBroker , oder hast du was anderes eingestellt .
          Nutzt du Host oder Bridge-Modus .
          Funktioniert jetzt ioBroker ?
          Z 1 Antwort Letzte Antwort
            Was negativ ?
            Z Offline
            Z Offline
            ZoXx
            Was negativ ?
            Nein, die IP-Adresse nutze ich nicht und kenne ich auch nicht.
            Meine IP-Adresse fängt mit 192.168. ... an.
            Die anderen Container lösen diese auch sauber auf. IoBroker lief bis zum Restore damit ja selbst auch.
            Ich nutze den bridge Modus mit festen zugeordneten Ports.
            Nein, gleicher Fehler wie oben.
            • Z ZoXx
              Was negativ ?
              GlasfaserG Offline
              GlasfaserG Offline
              @zoxx
              Zeige mal :
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              iobroker update -i
              iobroker list instances
              iobroker list adapters
              iobroker version
                @zoxx
                Zeige mal :
                iobroker update -i
                iobroker version
                Z Offline
                Z Offline
                ZoXx
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs iobroker update -i iobroker list instances iobroker list adapters iobroker version
                Guten Morgen zusammen,
                sind ein paar Screenshots mehr.
                Was mich wundert, dass einigen Instanzen als "disabled" stehen?
                Hier die Bilder:
                Viele Grüße
                • Z ZoXx
                  Was negativ ?
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Die aktuelle wäre Interessant .
                  Das heißt du , bekommst kein zugriff auf Admin 8081 .
                  Mache mal :
                  iobroker upload all
                  INFO:
                  Bitte keine Screenshot , Ausgabe in </> code-tags
                  was sagt
                  iobroker status
                    Mache mal :
                    iobroker upload all
                    INFO:
                    was sagt
                    iobroker status
                    Z Offline
                    Z Offline
                    ZoXx
                    iobroker upload all
                    Stop!!!!
                    Habe es gerade noch einmal probiert, es läuft nun!!! :)
                    Kann man sagen, woran es nun gescheitert ist vorher?
                    Vielen vielen Dank erst einmal!!!
                    • Z ZoXx
                      iobroker upload all
                      Stop!!!!
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Ich denke mal du warst zu ungeduldig , denn das Backup ist minimal ist auch gut so , denn alle Adapter werden dann nachinstalliert und das dauert nun mal mit der Restore .
                      da_WoodyD Z 2 Antworten Letzte Antwort
                        da_WoodyD Offline
                        da_WoodyD Offline
                        @glasfaser sagte in Backup / Restore von Raspberry Pi auf Synology:
                        und das kann stunden dauern... kommt halt auf die menge der adapter an.
                          Z Offline
                          Z Offline
                          ZoXx
                          Okay. Heißt einfach der restore dauert in der Regel sehr lang und ich habe es zu "früh" probiert?
                          • Z ZoXx
                            da_WoodyD Offline
                            da_WoodyD Offline
                            @zoxx sieht so aus... :)
                            • Z ZoXx
                              iobroker upload all
                              Stop!!!!
                              GlasfaserG Offline
                              GlasfaserG Offline
                              , es läuft nun!!!
                              Dann setzte den Thread auf [gelöst]
