  4. mihome-vacuum Verbindungsprobleme
    6.5k
mihome-vacuumverbindungsproblemexiaomi mi vacuum mop pro
35 Beiträge 5 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • S Schranzer
    @Schranzer ```
    2021-01-01 23:16:41.291 - info: host.IOBROKER-PI4 "system.adapter.mihome-vacuum.0" disabled
    2021-01-01 23:16:41.302 - info: host.IOBROKER-PI4 stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
    2021-01-01 23:16:41.314 - info: mihome-vacuum.0 (23795) Got terminate signal TERMINATE_YOURSELF
    2021-01-01 23:16:41.307 - info: host.IOBROKER-PI4 stopInstance system.adapter.mihome-vacuum.0 send kill signal
    2021-01-01 23:16:41.318 - info: mihome-vacuum.0 (23795) terminating
    2021-01-01 23:16:41.320 - info: mihome-vacuum.0 (23795) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-01 23:16:41.864 - info: host.IOBROKER-PI4 instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-01-01 23:18:56.130 - info: host.IOBROKER-PI4 "system.adapter.mihome-vacuum.0" enabled
    2021-01-01 23:18:56.187 - info: host.IOBROKER-PI4 instance system.adapter.mihome-vacuum.0 started with pid 31143
    2021-01-01 23:18:59.624 - info: mihome-vacuum.0 (31143) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.0, js-controller: 3.1.6
    2021-01-01 23:18:59.696 - info: mihome-vacuum.0 (31143) Expert mode disabled, states deleted
    2021-01-01 23:18:59.699 - info: mihome-vacuum.0 (31143) Cloud control disabled
    2021-01-01 23:18:59.818 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:19:00.236 - info: mihome-vacuum.0 (31143) set nächster Timer: Nicht verfügbar
    2021-01-01 23:19:19.780 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:19:39.748 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:19:59.818 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:20:19.790 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:20:39.756 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:20:59.825 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:21:19.794 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:21:39.764 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:21:59.832 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:22:19.801 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:22:39.768 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:22:59.838 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:23:19.807 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:23:39.775 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:23:59.848 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:24:19.816 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:24:39.782 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:24:59.856 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:25:19.820 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:25:39.795 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:25:59.859 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:26:19.830 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:26:39.795 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:26:59.866 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:27:19.834 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:27:39.802 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:27:59.873 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:28:19.841 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:28:39.809 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:28:59.880 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    2021-01-01 23:29:19.848 - info: mihome-vacuum.0 (31143) connecting, this can take up to 10 minutes ...
    haselchenH Offline
    haselchenH Offline
    haselchen
    @Schranzer
    Du bist immer noch bei INFO
    DEBUG musst du bitte einstellen, wie ich es eben beschrieben habe.
    Instanzen, Info anklicken und Debug auswählen. Vorher Expert Modus einstellen.
    • haselchenH haselchen
      @Schranzer
      Schranzer
      Wenn ich des anklick passiert nichts ...wo würde ich den expertenmodus aktivieren?
      • S Schranzer
        haselchenH Offline
        haselchenH Offline
        haselchen
        @Schranzer
        Bitte genau lesen, hab es jetzt 3 mal geschrieben.
        Unter Instanzen, oben links das Männchen anklicken. Dann erscheint die Spalte Info.
        Dort draufklicken beim Adapter Mihome und Debug auswählen.
          @Schranzer
          Schranzer
          schrieb am zuletzt editiert von Schranzer
          @haselchen ```
          code_text
          mihome-vacuum.0	2021-01-01 23:52:30.862	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:52:30.861	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa7aeffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:52:25.812	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:52:25.810	debug	(4242) no answer for id:6 received, giving up
          mihome-vacuum.0	2021-01-01 23:52:20.807	debug	(4242) sendMsg[3] >>> {"id":6,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:52:15.804	debug	(4242) sendMsg[2] >>> {"id":6,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:52:10.800	debug	(4242) sendMsg[1] >>> {"id":6,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:52:10.791	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:52:10.790	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:52:10.788	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa79affffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:52:05.844	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:52:05.842	debug	(4242) no answer for id:5 received, giving up
          mihome-vacuum.0	2021-01-01 23:52:00.838	debug	(4242) sendMsg[3] >>> {"id":5,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:55.835	debug	(4242) sendMsg[2] >>> {"id":5,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:50.832	debug	(4242) sendMsg[1] >>> {"id":5,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:50.823	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:51:50.822	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:51:50.820	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa786ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:51:45.792	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:51:45.791	debug	(4242) no answer for id:4 received, giving up
          mihome-vacuum.0	2021-01-01 23:51:40.788	debug	(4242) sendMsg[3] >>> {"id":4,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:35.785	debug	(4242) sendMsg[2] >>> {"id":4,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:30.781	debug	(4242) sendMsg[1] >>> {"id":4,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:30.775	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:51:30.774	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:51:30.773	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa772ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:51:25.805	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:51:25.803	debug	(4242) no answer for id:3 received, giving up
          mihome-vacuum.0	2021-01-01 23:51:20.801	debug	(4242) sendMsg[3] >>> {"id":3,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:15.798	debug	(4242) sendMsg[2] >>> {"id":3,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:10.795	debug	(4242) sendMsg[1] >>> {"id":3,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:51:10.785	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:51:10.784	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:51:10.782	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa75effffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:51:05.834	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:51:05.832	debug	(4242) no answer for id:2 received, giving up
          mihome-vacuum.0	2021-01-01 23:51:00.831	debug	(4242) sendMsg[3] >>> {"id":2,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:50:55.828	debug	(4242) sendMsg[2] >>> {"id":2,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:50:50.825	debug	(4242) sendMsg[1] >>> {"id":2,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:50:50.816	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:50:50.815	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:50:50.813	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa74affffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:50:45.901	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:50:45.898	debug	(4242) no answer for id:1 received, giving up
          mihome-vacuum.0	2021-01-01 23:50:40.895	debug	(4242) sendMsg[3] >>> {"id":1,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:50:35.892	debug	(4242) sendMsg[2] >>> {"id":1,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:50:33.869	debug	(4242) system.adapter.admin.0: logging true
          mihome-vacuum.0	2021-01-01 23:50:31.284	info	(4242) set nächster Timer: Nicht verfügbar
          mihome-vacuum.0	2021-01-01 23:50:30.890	debug	(4242) sendMsg[1] >>> {"id":1,"method":"get_status"}
          mihome-vacuum.0	2021-01-01 23:50:30.858	debug	(4242) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
          mihome-vacuum.0	2021-01-01 23:50:30.855	info	(4242) connecting, this can take up to 10 minutes ...
          mihome-vacuum.0	2021-01-01 23:50:30.851	debug	(4242) Receive <<< Helo <<< 2131002000000000166375305fefa736ffffffffffffffffffffffffffffffff
          mihome-vacuum.0	2021-01-01 23:50:30.820	debug	(4242) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          mihome-vacuum.0	2021-01-01 23:50:30.776	debug	(4242) server started on 0.0.0.0:53421
          mihome-vacuum.0	2021-01-01 23:50:30.747	info	(4242) Cloud control disabled
          mihome-vacuum.0	2021-01-01 23:50:30.744	info	(4242) Expert mode disabled, states deleted
          mihome-vacuum.0	2021-01-01 23:50:30.684	info	(4242) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.0, js-controller: 3.1.6
          mihome-vacuum.0	2021-01-01 23:50:29.893	debug	(4242) statesDB connected
          mihome-vacuum.0	2021-01-01 23:50:29.891	debug	(4242) States connected to redis: 127.0.0.1:9000
          mihome-vacuum.0	2021-01-01 23:50:29.878	debug	(4242) States create System PubSub Client
          mihome-vacuum.0	2021-01-01 23:50:29.869	debug	(4242) States create User PubSub Client
          mihome-vacuum.0	2021-01-01 23:50:29.855	debug	(4242) Redis States: Use Redis connection: 127.0.0.1:9000
          mihome-vacuum.0	2021-01-01 23:50:29.850	debug	(4242) objectDB connected
          mihome-vacuum.0	2021-01-01 23:50:29.837	debug	(4242) Objects connected to redis: 127.0.0.1:9001
          mihome-vacuum.0	2021-01-01 23:50:29.810	debug	(4242) Objects client initialize lua scripts
          mihome-vacuum.0	2021-01-01 23:50:29.807	debug	(4242) Objects create User PubSub Client
          mihome-vacuum.0	2021-01-01 23:50:29.803	debug	(4242) Objects create System PubSub Client
          mihome-vacuum.0	2021-01-01 23:50:29.779	debug	(4242) Objects client ready ... initialize now
          mihome-vacuum.0	2021-01-01 23:50:29.499	debug	(4242) Redis Objects: Use Redis connection: 127.0.0.1:9001
          host.IOBROKER-PI4	2021-01-01 23:50:27.380	info	instance system.adapter.mihome-vacuum.0 started with pid 4242
          host.IOBROKER-PI4	2021-01-01 23:50:27.345	info	"system.adapter.mihome-vacuum.0" enabled
          host.IOBROKER-PI4	2021-01-01 23:49:41.812	info	instance system.adapter.mihome-vacuum.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
          mihome-vacuum.0	2021-01-01 23:49:41.242	warn	(4089) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
          mihome-vacuum.0	2021-01-01 23:49:41.213	error	(4089) adapter disabled
          host.IOBROKER-PI4	2021-01-01 23:49:40.477	info	stopInstance system.adapter.mihome-vacuum.0 killing pid 4089
          host.IOBROKER-PI4	2021-01-01 23:49:39.472	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
          host.IOBROKER-PI4	2021-01-01 23:49:39.468	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
          host.IOBROKER-PI4	2021-01-01 23:49:39.463	info	"system.adapter.mihome-vacuum.0" disabled
          host.IOBROKER-PI4	2021-01-01 23:49:37.392	info	instance system.adapter.mihome-vacuum.0 started with pid 4089
          host.IOBROKER-PI4	2021-01-01 23:49:37.313	info	"system.adapter.mihome-vacuum.0" enabled
          host.IOBROKER-PI4	2021-01-01 23:44:24.246	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          host.IOBROKER-PI4	2021-01-01 23:44:20.029	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          host.IOBROKER-PI4	2021-01-01 23:42:29.260	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          host.IOBROKER-PI4	2021-01-01 23:42:24.790	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          host.IOBROKER-PI4	2021-01-01 23:41:24.660	info	Update repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
          host.IOBROKER-PI4	2021-01-01 23:37:15.933	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          mihome-vacuum.0	2021-01-01 23:37:15.360	info	(31143) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          mihome-vacuum.0	2021-01-01 23:37:15.359	info	(31143) terminating
          mihome-vacuum.0	2021-01-01 23:37:15.353	info	(31143) Got terminate signal TERMINATE_YOURSELF
          host.IOBROKER-PI4	2021-01-01 23:37:15.346	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
          host.IOBROKER-PI4	2021-01-01 23:37:15.342	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
          host.IOBROKER-PI4	2021-01-01 23:37:15.332	info	"system.adapter.mihome-vacuum.0" disabled
          • S Schranzer
            @haselchen ```
            code_text
            Schranzer
            @Schranzer OK jetzt danke sry
            • S Schranzer
              haselchenH Offline
              haselchenH Offline
              haselchen
              @Schranzer
              Das sollte schon den Betreffenden weiterhelfen.
              Ich kann mit Redis nichts anfangen.
              Vielleicht ist da schon der Fehler zu finden.
              Kannst du hiermit auf file umstellen?
              iobroker stop
              iobroker setup custom
              • MeistertrM Offline
                MeistertrM Offline
                Meistertr
                @Schranzer nach ein bisschen Reschere hätte dir auffallen sollen, das der "normale" Adapter den Mi Mop Pro noch nicht untertützt. nutze hierfür mal bitte den 3.x aus meinem Repository https://github.com/MeisterTR/ioBroker.mihome-vacuum
                S M 2 Antworten Letzte Antwort
                • MeistertrM Meistertr
                  Schranzer
                  @Meistertr @haselchen Vielen Dank erstmal für eure schnellen Antworten! Ich mit noch ein Neuling was Raspberry Pi, IoBroker und wie das Forum hier funktioniert. Ich werde das jetzt mal ausprobieren @Meistertr ! :)
                  Edit:
                  Super hat geklappt!!! Jetzt habe ich die Werte ! :)
                  Eine Frage noch lohnt, es sich die 4.x Version zu installieren oder soll ich noch warten?
                    masterandre
                    @meistertr ich habe seit kurzem auch Probleme mit der Verbindung, ich habe den adpater in der neuesten Version installiert nach rund 30min ging die instance dann wieder auf grün, jedoch bekomme ich die räume nicht mehr angezeigt. Installiert ist 3.2.1, Ich nutze ein Roborock S6:
                    Was kann ich machen?
                    mihome-vacuum.0	2021-07-04 11:27:52.113	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:50.111	debug	(22611) Message= {"id":75,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:27:50.111	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:27:50.110	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:50.110	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:49.635	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:27:49.635	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17f16ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:27:48.108	debug	(22611) Message= {"id":74,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:27:48.108	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:27:48.108	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:48.107	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:46.105	debug	(22611) Message= {"id":73,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:27:46.105	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:27:46.104	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:44.103	debug	(22611) Message= {"id":72,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:27:44.102	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:44.101	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:42.101	debug	(22611) Message= {"id":71,"method":"get_sound_volume"}
                    mihome-vacuum.0	2021-07-04 11:27:42.100	debug	(22611) Error at getSetNetwork: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:42.100	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:40.098	debug	(22611) Message= {"id":70,"method":"get_network_info"}
                    mihome-vacuum.0	2021-07-04 11:27:40.098	debug	(22611) ERROR at setGetStatus: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:40.097	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:39.631	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:27:39.630	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17f0cffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:27:38.095	debug	(22611) Message= {"id":69,"method":"get_status"}
                    mihome-vacuum.0	2021-07-04 11:27:38.094	debug	(22611) get params for stock Vacuum
                    mihome-vacuum.0	2021-07-04 11:27:29.626	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:27:29.626	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17f02ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:27:19.619	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:27:19.619	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17ef8ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:27:18.093	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:16.091	debug	(22611) Message= {"id":68,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:27:16.091	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:27:16.090	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:16.090	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:14.088	debug	(22611) Message= {"id":67,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:27:14.088	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:27:14.088	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:14.087	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:12.085	debug	(22611) Message= {"id":66,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:27:12.085	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:27:12.084	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:10.084	debug	(22611) Message= {"id":65,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:27:10.083	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:10.083	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:09.616	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:27:09.615	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17eeeffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:27:08.081	debug	(22611) Message= {"id":64,"method":"get_sound_volume"}
                    mihome-vacuum.0	2021-07-04 11:27:08.081	debug	(22611) Error at getSetNetwork: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:08.080	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:06.079	debug	(22611) Message= {"id":63,"method":"get_network_info"}
                    mihome-vacuum.0	2021-07-04 11:27:06.078	debug	(22611) ERROR at setGetStatus: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:27:06.078	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:27:04.076	debug	(22611) Message= {"id":62,"method":"get_status"}
                    mihome-vacuum.0	2021-07-04 11:27:04.076	debug	(22611) get params for stock Vacuum
                    mihome-vacuum.0	2021-07-04 11:26:59.612	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:26:59.612	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17ee4ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:26:49.605	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:26:49.604	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17edaffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:26:44.074	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:42.073	debug	(22611) Message= {"id":61,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:26:42.073	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:26:42.072	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:42.072	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:40.071	debug	(22611) Message= {"id":60,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:26:40.070	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:26:40.070	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:40.069	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:39.601	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:26:39.601	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17ed0ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:26:38.069	debug	(22611) Message= {"id":59,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:26:38.068	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:26:38.068	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:36.066	debug	(22611) Message= {"id":58,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:26:36.065	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:36.065	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:34.063	debug	(22611) Message= {"id":57,"method":"get_sound_volume"}
                    mihome-vacuum.0	2021-07-04 11:26:34.063	debug	(22611) Error at getSetNetwork: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:34.062	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:32.060	debug	(22611) Message= {"id":56,"method":"get_network_info"}
                    mihome-vacuum.0	2021-07-04 11:26:32.060	debug	(22611) ERROR at setGetStatus: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:32.059	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:30.058	debug	(22611) Message= {"id":55,"method":"get_status"}
                    mihome-vacuum.0	2021-07-04 11:26:30.057	debug	(22611) get params for stock Vacuum
                    mihome-vacuum.0	2021-07-04 11:26:29.597	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:26:29.597	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17ec6ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:26:19.593	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:26:19.592	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17ebcffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:26:10.057	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:09.589	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:26:09.589	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17eb2ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:26:08.055	debug	(22611) Message= {"id":54,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:26:08.055	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:26:08.055	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:08.054	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:06.053	debug	(22611) Message= {"id":53,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:26:06.052	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:26:06.052	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:06.051	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:04.051	debug	(22611) Message= {"id":52,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:26:04.050	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:26:04.050	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:02.049	debug	(22611) Message= {"id":51,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:26:02.048	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:02.048	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:26:00.047	debug	(22611) Message= {"id":50,"method":"get_sound_volume"}
                    mihome-vacuum.0	2021-07-04 11:26:00.046	debug	(22611) Error at getSetNetwork: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:26:00.046	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:59.585	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:25:59.584	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17ea8ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:25:58.044	debug	(22611) Message= {"id":49,"method":"get_network_info"}
                    mihome-vacuum.0	2021-07-04 11:25:58.044	debug	(22611) ERROR at setGetStatus: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:58.043	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:56.042	debug	(22611) Message= {"id":48,"method":"get_status"}
                    mihome-vacuum.0	2021-07-04 11:25:56.041	debug	(22611) get params for stock Vacuum
                    mihome-vacuum.0	2021-07-04 11:25:49.581	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:25:49.580	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e9effffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:25:39.569	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:25:39.569	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e94ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:25:36.041	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:34.039	debug	(22611) Message= {"id":47,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:25:34.039	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:25:34.038	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:34.038	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:32.037	debug	(22611) Message= {"id":46,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:25:32.036	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:25:32.036	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:32.035	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:30.034	debug	(22611) Message= {"id":45,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:25:30.034	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:25:30.033	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:29.564	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:25:29.564	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e8affffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:25:28.032	debug	(22611) Message= {"id":44,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:25:28.032	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:28.031	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:26.030	debug	(22611) Message= {"id":43,"method":"get_sound_volume"}
                    mihome-vacuum.0	2021-07-04 11:25:26.030	debug	(22611) Error at getSetNetwork: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:26.029	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:24.028	debug	(22611) Message= {"id":42,"method":"get_network_info"}
                    mihome-vacuum.0	2021-07-04 11:25:24.027	debug	(22611) ERROR at setGetStatus: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:24.026	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:22.025	debug	(22611) Message= {"id":41,"method":"get_status"}
                    mihome-vacuum.0	2021-07-04 11:25:22.025	debug	(22611) get params for stock Vacuum
                    mihome-vacuum.0	2021-07-04 11:25:19.560	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:25:19.559	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e80ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:25:09.556	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:25:09.556	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e76ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:25:02.024	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:25:00.022	debug	(22611) Message= {"id":40,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:25:00.022	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:25:00.022	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:25:00.021	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:59.552	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:24:59.552	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e6cffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:24:58.019	debug	(22611) Message= {"id":39,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:24:58.018	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:24:58.018	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:58.018	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:56.017	debug	(22611) Message= {"id":38,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:24:56.016	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:24:56.016	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:54.014	debug	(22611) Message= {"id":37,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:24:54.014	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:54.013	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:52.012	debug	(22611) Message= {"id":36,"method":"get_sound_volume"}
                    mihome-vacuum.0	2021-07-04 11:24:52.012	debug	(22611) Error at getSetNetwork: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:52.011	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:50.011	debug	(22611) Message= {"id":35,"method":"get_network_info"}
                    mihome-vacuum.0	2021-07-04 11:24:50.010	debug	(22611) ERROR at setGetStatus: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:50.010	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:49.550	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:24:49.549	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e62ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:24:48.008	debug	(22611) Message= {"id":34,"method":"get_status"}
                    mihome-vacuum.0	2021-07-04 11:24:48.008	debug	(22611) get params for stock Vacuum
                    mihome-vacuum.0	2021-07-04 11:24:39.547	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:24:39.546	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e58ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:24:29.544	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:24:29.543	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e4effffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:24:28.006	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:26.005	debug	(22611) Message= {"id":33,"method":"get_map_v1"}
                    mihome-vacuum.0	2021-07-04 11:24:26.005	debug	(22611) Startup: setGetConsumable Anser: false
                    mihome-vacuum.0	2021-07-04 11:24:26.004	debug	(22611) ERROR at setGetConsumable: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:26.004	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:24.002	debug	(22611) Message= {"id":32,"method":"get_consumable"}
                    mihome-vacuum.0	2021-07-04 11:24:24.001	debug	(22611) Startup: setGetCleanSummary Anser: false
                    mihome-vacuum.0	2021-07-04 11:24:24.001	debug	(22611) ERROR at setGetCleanSummary: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:24.000	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:21.999	debug	(22611) Message= {"id":31,"method":"get_clean_summary"}
                    mihome-vacuum.0	2021-07-04 11:24:21.999	debug	(22611) Startup: getMultiMapsList Anser: false
                    mihome-vacuum.0	2021-07-04 11:24:21.998	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:19.995	debug	(22611) Message= {"id":30,"method":"get_multi_maps_list"}
                    mihome-vacuum.0	2021-07-04 11:24:19.995	debug	(22611) ERROR at setGetSoundVolume: MESSAGE TIMEOUT
                    mihome-vacuum.0	2021-07-04 11:24:19.994	debug	(22611) MIIO Receive Timeout<<<
                    mihome-vacuum.0	2021-07-04 11:24:19.540	debug	(22611) Time difference between Mihome Vacuum and ioBroker: 1 sec
                    mihome-vacuum.0	2021-07-04 11:24:19.540	debug	(22611) Receive <<< Helo <<< 2131002000000000132796f260e17e44ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2021-07-04 11:24:17.993	debug	(22611) Message= {"id":29,"method":"get_sound_volume"}
                    Mod-Edit: Code in </> Code-Tag gepackt!
                    • M masterandre
                      @masterandre
                      Bitte die Bleiwüste in CodeTags setzen. Dann kann man das auch lesen.
