  4. FRITZDECT Adapter -Problem
    6.8k
6 Beiträge 2 Kommentatoren 253 Aufrufe 2 Beobachtet
  • W Offline
    W Offline
    wrod
    schrieb am zuletzt editiert von wrod
    seit zwei Tagen läuft iobroker bei mir. Und nun stelle ich fest, dass der FRITZDECT-Adapter (besser: die Instanz) seit gestern abend keine Werte mehr liefert. Update schlägt leider fehl. Ebenso Neuinstallation: Fehlermeldung:
    $ iobroker add fritzdect --host raspberrypi
    NPM version: 6.14.13npm install iobroker.fritzdect@2.1.12 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EACCES
    npm ERR! syscall unlinknpm ERR! path /opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.jsnpm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'
    npm ERR! [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'] {
    npm ERR! cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'] {
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'npm ERR! },npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js',npm ERR! parent: 'mqtt'npm ERR! }
    npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-06-30T14_27_40_746Z-debug.log
    host.raspberrypi Cannot install iobroker.fritzdect@2.1.12: 243
    ERROR: Process exited with code 25
    Damit kann ich wenig anfangen.
    Was kann ich tun?
    Dank im Voraus,
    W.
    • W wrod
      Was kann ich tun?
      Dank im Voraus,
      W.
      @wrod sagte in FRITZDECT Adapter -Problem:
      Was kann ich tun?
      Den Kram in CodeTags einbetten, damit man das besser lesen kann.
      • W wrod
        Was kann ich tun?
        Dank im Voraus,
        W.
        @wrod
        Da scheint irgendwas an den Rechten verbogen zu sein.
        iobroker fix
        und dann mal schauen ob nodeJS korrekt installiert ist:
        which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
        Mir wäre es auch neu, wenn der fritzdect was mit mqtt zu schaffen hätte. Da hast du dir wohl einen anderen Fehler auf das System geschaufelt.
        W 1 Antwort Letzte Antwort
          @wrod
          iobroker fix
          W Offline
          W Offline
          wrod
          @thomas-braun Danke. Fix habe ich gemacht. Der which gibt aus:
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.17.1
          v14.17.1
          6.14.13
          nodejs:
            Installed: 14.17.1-1nodesource1
            Candidate: 14.17.1-1nodesource1
            Version table:
           *** 14.17.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
          • W wrod
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v14.17.1
            v14.17.1
            6.14.13
            nodejs:
              Version table:
            @wrod
            iobroker update
            Bitte komplette Ein- und Ausgabezeilen posten.
              @wrod
              iobroker update
              W Offline
              W Offline
              wrod
              @thomas-braun Danke! Scheint wieder vollständig zu gehen
