<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FRITZDECT Adapter -Problem]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
seit zwei Tagen läuft iobroker bei mir. Und nun stelle ich fest, dass der FRITZDECT-Adapter (besser: die Instanz) seit gestern abend keine Werte mehr liefert. Update schlägt leider fehl. Ebenso Neuinstallation: Fehlermeldung:</p>
<pre><code>$ iobroker add fritzdect --host raspberrypi
NPM version: 6.14.13npm install iobroker.fritzdect@2.1.12 --loglevel error --prefix "/opt/iobroker" (System call)
npm ERR! code EACCES
npm ERR! syscall unlinknpm ERR! path /opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.jsnpm ERR! errno -13
npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'
npm ERR! [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'] {
npm ERR! cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'] {
npm ERR! errno: -13,
npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js'npm ERR! },npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/mqtt/node_modules/.ws.DELETE/lib/buffer-util.js',npm ERR! parent: 'mqtt'npm ERR! }
npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-06-30T14_27_40_746Z-debug.log
host.raspberrypi Cannot install iobroker.fritzdect@2.1.12: 243
ERROR: Process exited with code 25
</code></pre>
<p dir="auto">Damit kann ich wenig anfangen.<br />
Was kann ich tun?</p>
<p dir="auto">Dank im Voraus,<br />
W.</p>
]]></description><link>https://forum.iobroker.net/topic/46114/fritzdect-adapter-problem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 20:21:03 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/46114.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Jun 2021 14:45:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FRITZDECT Adapter -Problem on Wed, 30 Jun 2021 16:02:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Danke! Scheint wieder vollständig zu gehen</p>
]]></description><link>https://forum.iobroker.net/post/648071</link><guid isPermaLink="true">https://forum.iobroker.net/post/648071</guid><dc:creator><![CDATA[wrod]]></dc:creator><pubDate>Wed, 30 Jun 2021 16:02:26 GMT</pubDate></item><item><title><![CDATA[Reply to FRITZDECT Adapter -Problem on Wed, 30 Jun 2021 15:24:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrod" aria-label="Profile: wrod">@<bdi>wrod</bdi></a></p>
<pre><code>iobroker update
</code></pre>
<p dir="auto">Bitte komplette Ein- und Ausgabezeilen posten.</p>
]]></description><link>https://forum.iobroker.net/post/648056</link><guid isPermaLink="true">https://forum.iobroker.net/post/648056</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 30 Jun 2021 15:24:52 GMT</pubDate></item><item><title><![CDATA[Reply to FRITZDECT Adapter -Problem on Wed, 30 Jun 2021 15:23:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Danke. Fix habe ich gemacht. Der which gibt aus:</p>
<pre><code>/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v14.17.1
v14.17.1
6.14.13
nodejs:
  Installed: 14.17.1-1nodesource1
  Candidate: 14.17.1-1nodesource1
  Version table:
 *** 14.17.1-1nodesource1 500
        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
        100 /var/lib/dpkg/status
     10.24.0~dfsg-1~deb10u1 500
</code></pre>
]]></description><link>https://forum.iobroker.net/post/648055</link><guid isPermaLink="true">https://forum.iobroker.net/post/648055</guid><dc:creator><![CDATA[wrod]]></dc:creator><pubDate>Wed, 30 Jun 2021 15:23:16 GMT</pubDate></item><item><title><![CDATA[Reply to FRITZDECT Adapter -Problem on Wed, 30 Jun 2021 15:16:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrod" aria-label="Profile: wrod">@<bdi>wrod</bdi></a></p>
<p dir="auto">Da scheint irgendwas an den Rechten verbogen zu sein.</p>
<pre><code>iobroker fix
</code></pre>
<p dir="auto">und dann mal schauen ob nodeJS korrekt installiert ist:</p>
<pre><code>which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; apt policy nodejs
</code></pre>
<p dir="auto">Mir wäre es auch neu, wenn der fritzdect was mit mqtt zu schaffen hätte. Da hast du dir wohl einen anderen Fehler auf das System geschaufelt.</p>
]]></description><link>https://forum.iobroker.net/post/648054</link><guid isPermaLink="true">https://forum.iobroker.net/post/648054</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 30 Jun 2021 15:16:43 GMT</pubDate></item><item><title><![CDATA[Reply to FRITZDECT Adapter -Problem on Wed, 30 Jun 2021 14:51:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wrod" aria-label="Profile: wrod">@<bdi>wrod</bdi></a> sagte in <a href="/post/648043">FRITZDECT Adapter -Problem</a>:</p>
<blockquote>
<p dir="auto">Was kann ich tun?</p>
</blockquote>
<p dir="auto">Den Kram in CodeTags einbetten, damit man das besser lesen kann.</p>
]]></description><link>https://forum.iobroker.net/post/648047</link><guid isPermaLink="true">https://forum.iobroker.net/post/648047</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 30 Jun 2021 14:51:02 GMT</pubDate></item></channel></rss>
