  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер Flot
    5.9k
Драйвер Flot
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
54 Beiträge 11 Kommentatoren 18.5k Aufrufe
  • H Offline
    Ho Hum
    @Bluefox:
    Можно заметить, что график с линией разметки у тебя за 5 дней, а без линии за 12 часов.
    Какие стоят настройки? `
    В том то и дело, что настройки одинаковые - 12 часов.
    Верхний график
    http://192.168.1.200:8082/flot/index.html?timeArt=relative&relativeEnd=now&range=720&live=300&start=2016-03-01&aggregateType=count&aggregateSpan=1500&width=400&height=250&noBorder=noborder&titlePos=top%3A35%3Bleft%3A65&hoverDetail=true&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=Home.0.System.LoadAverage.01min&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bart%5D=average&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=8&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=1&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Baggregate%5D=onchange&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5BafterComma%5D=0&timeType=relative&zoom=true&noedit=true&animation=0&barFontColor=rgb(255%2C+255%2C+255)&m%5B0%5D%5Bl%5D=0&m%5B0%5D%5Bv%5D=2&m%5B0%5D%5Bf%5D=false&m%5B0%5D%5Bc%5D=%2336FF00&m%5B0%5D%5Bt%5D=1&m%5B0%5D%5Bs%5D=1&m%5B0%5D%5Bd%5D=&m%5B0%5D%5Bp%5D=l&m%5B0%5D%5Bpy%5D=0&m%5B0%5D%5Bfc%5D=%23000000&m%5B0%5D%5Bfs%5D=
    Нижний график
    http://192.168.1.200:8082/flot/index.html?timeArt=relative&relativeEnd=now&range=720&live=300&start=2016-03-01&aggregateType=count&aggregateSpan=1500&width=400&height=250&noBorder=noborder&titlePos=top%3A35%3Bleft%3A65&hoverDetail=true&timeFormat=%25H%3A%25M&useComma=false&l%5B0%5D%5Bid%5D=Home.0.System.Processor.Load.AllCPU&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Bart%5D=average&l%5B0%5D%5Bcolor%5D=%23FF0000&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bmax%5D=100&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=1&l%5B0%5D%5BchartType%5D=area&l%5B0%5D%5Baggregate%5D=onchange&l%5B0%5D%5BignoreNull%5D=true&l%5B0%5D%5BafterComma%5D=0&timeType=relative&zoom=true&noedit=true&animation=0&barFontColor=rgb(255%2C+0%2C+0)
    • BluefoxB Offline
      BluefoxB Offline
      Нашёл ошибку. Попробуй с гита.
      • H Offline
        Ho Hum
        @Bluefox:
        Нашёл ошибку. Попробуй с гита. `
        Спасибо,все заработало.
        http://radikal.ru
          andrey99986
          Есть показания электросчётчика по таррифам T1,T2 в БД iobroker sql, пишутся каждый час.
          Чтобы вытащить статистику потребления по суткам сделал sql запрос:
          SELECT
           DATE(t1.eventdate) as date,
           round(MAX(t1.val)-MIN(t1.val),2) as rashod_T1,
           round(MAX(t2.val)-MIN(t2.val),2) as rashod_T2,
           ( round(MAX(t1.val)-MIN(t1.val),2) + round(MAX(t2.val)-MIN(t2.val),2) ) as Total_rashod
           FROM (SELECT val, DATE_ADD(FROM_UNIXTIME(ts/1000), interval -315619200 second) as eventdate from iobroker.ts_number  where id=9) t1
           LEFT JOIN (SELECT val, DATE_ADD(FROM_UNIXTIME(ts/1000), interval -315619200 second) as eventdate from iobroker.ts_number  where id=10) t2
           ON (t1.eventdate=t2.eventdate)
           GROUP BY DATE(t1.eventdate);
          Я так понимаю прямого способа sql-запрос отобразить в flot-е невозможно…
          И чтобы построить график:
          1. Способ: надо каждые сутки например записывать в БД то что выводит sql-запрос в свойствах нового объекта в БД.
          2. Способ: обмануть flot - скриптом записать данные, сформированные из запроса напрямую с id нового объекта в БД.
          Это гемор какой-то... Может всё таки разработчики добавят возможность строить график по произвольному sql-запросу?
          • BluefoxB Offline
            BluefoxB Offline
            Проблема в одной и
              andrey99986
              Как должна работать настройка в "Входные-данные"-"Ещё"-"Сглаживание" ?
              Установил параметр в 10, по логике должно брать среднее из 10 соседних значений (+-5) (линейно или более сложно используя вес).
              У меня вот такая картинка выходит. Думаю что при "сглаживании" в новом графике не должны превышаться исходные реальные максимальные значения.
              Красная линия - исходные данные.
              Зелёная линия - те же данные со сглаживанием "10".
              • V Offline
                V Offline
                VictorS
                Доброго дня,
                сподобился тут построить графики потребления электричества и воды по суткам и месяцам. Даже не мог представить что это есть большая проблема :(
                Исторически данные есть в виде: время/показания.
                Но для нужных графиков мне нужно взять дельту от показания за сутки 0:00 текущих суток, и 0:00 предыдущих и так далее.
                И как это реализовать при помощи flot?
                update: увидел что тема подымалась уже…
                видимо при помощи flot - никак. но вот тут https://iobroker.biz:8080/ в одном из примеров вроде видел подобные графики когда то.. а сейчас не могу найти…
                • BluefoxB Offline
                  BluefoxB Offline
                  А так?
                  • BluefoxB Offline
                    BluefoxB Offline
                    @andrey99986:
                    Зелёная линия - те же данные со сглаживанием "10". `
                    Очень интересно:
                    Используется вот этот алгоритм. https://github.com/ioBroker/ioBroker.fl … ta.js#L713
                    Сейчас вижу ошибку, но она возможна только если попадаются null значения.
                    Обновил на гите алгоритм.
                      andrey99986
                      @Bluefox:
                      @andrey99986:
                      Очень интересно:
                      Обновил на гите алгоритм. `
                      Спасибо, вроде заработало когда поставил "Игнорировать null".
                      • V Offline
                        V Offline
                        VictorS
                        @Bluefox:
                        А так? `
                        немного не так. сдвиг оси x в один день с одновременным изменением интервала выборки вместо now -> end of day приводит к тому что показываются данные за предыдущие сутки. никакого вычитания значений не происходит.
                        • BluefoxB Offline
                          BluefoxB Offline
                          @VictorS:
                          @Bluefox:
                          А так? `
                          немного не так. сдвиг оси x в один день с одновременным изменением интервала выборки вместо now -> end of day приводит к тому что показываются данные за предыдущие сутки. никакого вычитания значений не происходит. `
                          вычитания??
                          Это же не excel :)
                          Тебе нужны influxdb + graphite. Я именно из-за этого встроил influxDB.
                          • V Offline
                            V Offline
                            VictorS
                            @Bluefox:
                            @VictorS:
                            @Bluefox:
                            А так? `
                            вычитания??
                            Это же не excel :)
                            Тебе нужны influxdb + graphite. Я именно из-за этого встроил influxDB. `
                            ну под вычитанием я имел ввиду разницу между показаниями начала суток предудущего и текущего дня. Иначе в чем смысл твокго совета сдвинуть X-axis на сутки?
                            насчет influxdb + graphite - ты имел ввиду наверное influxdb + grafana? ибо и influxdb и graphite - это по сути time series DB, плюс в последней есть инструменты по визуализации..
                            очень интересные инструменты, надо изучить… кстати я так понимаю что именно DB подобные influxdb идеальная база для IOB, так как в любой db он хранит информацию как time series. ее вообще по умолчанию включить можно было бы...
                            кстати, а flot будет тянуть данные из influxdb без проблем?
                            • BluefoxB Offline
                              BluefoxB Offline
                              @VictorS:
                              @Bluefox:
                              @VictorS:
                              вычитания??
                              Это же не excel :)
                              кстати, а flot будет тянуть данные из influxdb без проблем? `
                              я имел ввиду именно graphite. Т.к. grafana такого не может. (Не могла 2 года назад. Сейчас не знаю).
                              InfluxDB надо инсталлировать. Ты бы знал, сколько проблем просто с node.js. Люди ничего не могут и не хотят знать. А ты предлагаешь их заставить ставить ещё базу данных :?
                              • F Offline
                                Freemen
                                Почему то не могу построить график данных с точностью до сотых. В sql данные точность до сотых, на графике целые. Где эти настройки? Описание драйвера и его настройка прочитал, но есть ли такая настройка и где она так и не понял 😢 . Тыкните носом плиз..
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @Freemen:
                                  Почему то не могу построить график данных с точностью до сотых. В sql данные точность до сотых, на графике целые. Где эти настройки? Описание драйвера и его настройка прочитал, но есть ли такая настройка и где она так и не понял 😢 . Тыкните носом плиз.. `
                                  • F Offline
                                    Freemen
                                    @Bluefox:
                                    @Freemen:
                                    Самое первое что делал, так это. Не помогает.
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      @Freemen:
                                      @Bluefox:
                                      @Freemen:
                                      Самое первое что делал, так это. Не помогает. `
                                      А что ты там написал?
                                      • F Offline
                                        Freemen
                                        Ну поставил, 2 знака после запятой :roll:. Если есть время можно посмотреть:
                                        https://drive.google.com/open?id=0BwZuz … zN6azBiS3M
                                        На вэб страничке устройства графики рисуются с thingspeak.com. В брокере имею целочисленные показания
                                        • BluefoxB Offline
                                          BluefoxB Offline
                                          @Freemen:
                                          На вэб страничке устройства графики рисуются с thingspeak.com. В брокере имею целочисленные показания `
                                          У тебя значения "25._75". Там пробел в значении и поэтому оно интерпретируется, как
                                          parseFloat("25. 75") => 25.0
