  4. Test Adapter Fahrplan
    6.8k
adapterdeutsche bahnfahrplanhafasöbb
263 Beiträge 44 Kommentatoren 74.4k Aufrufe 40 Beobachtet
  • A AggroRalf
    @johgre Hi, immer noch Fehler ?
    JohGreJ Offline
    JohGreJ Offline
    JohGre
    #87
    @aggroralf
    Ja leider.
    fahrplan.0	2021-03-26 15:54:07.869	debug	(17231) system.adapter.admin.0: logging true
    fahrplan.0	2021-03-26 15:54:03.846	error	(17231) Error occured: Exception receiving Message for Adapter in main/onMessage
    fahrplan.0	2021-03-26 15:54:03.839	error	(17231) Error occured: Exception receiving Stations in fHelpers/createHTML [FetchError: invalid json response body at https://fahrplan.oebb.at/bin/mgate.exe? reason: Unexpected token < in JSON at pos
    fahrplan.0	2021-03-26 15:54:03.692	debug	(17231) [Adapter] Executing HAFAS search for Stations: Provider = OEBB SearchString = Linz
    fahrplan.0	2021-03-26 15:53:58.027	debug	(17231) system.adapter.admin.0: logging false
    fahrplan.0	2021-03-26 15:53:56.020	error	(17231) Error occured: Exception receiving Message for Adapter in main/onMessage
    fahrplan.0	2021-03-26 15:53:56.012	error	(17231) Error occured: Exception receiving Stations in fHelpers/createHTML [FetchError: invalid json response body at https://fahrplan.oebb.at/bin/mgate.exe? reason: Unexpected token < in JSON at pos
    fahrplan.0	2021-03-26 15:53:55.851	debug	(17231) [Adapter] Executing HAFAS search for Stations: Provider = OEBB SearchString = wels
    fahrplan.0	2021-03-26 15:53:34.061	info	(17231) [Departure Timetable] Updated 1 departure timetables, 0 enabled and 0 disabled
    fahrplan.0	2021-03-26 15:53:34.061	error	(17231) Unknown Station defined in Departure Timetable #0
    fahrplan.0	2021-03-26 15:53:33.910	debug	(17231) [Departure Timetable] 1 Departure Timetables defined, continuing
    fahrplan.0	2021-03-26 15:53:33.909	info	(17231) [Route] Updated 2 routes, 0 enabled and 0 disabled
    fahrplan.0	2021-03-26 15:53:33.909	error	(17231) Unknown Station defined in Route #1
    fahrplan.0	2021-03-26 15:53:33.762	error	(17231) Unknown Station defined in Route #0
    fahrplan.0	2021-03-26 15:53:33.531	debug	(17231) [Route] 2 Routes defined, continuing
    fahrplan.0	2021-03-26 15:53:33.531	debug	(17231) [Adapter] Timer Event
    fahrplan.0	2021-03-26 15:53:33.529	info	(17231) [Adapter] Adapter started, Updates every 5 minutes
    fahrplan.0	2021-03-26 15:53:33.495	info	(17231) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.fahrplan, node: v12.21.0, js-controller: 3.2.16
    fahrplan.0	2021-03-26 15:53:33.339	debug	(17231) Plugin sentry Initialize Plugin (enabled=true)
    fahrplan.0	2021-03-26 15:53:33.020	debug	(17231) statesDB connected
    fahrplan.0	2021-03-26 15:53:33.020	debug	(17231) States connected to redis: 10.0.0.227:9000
    fahrplan.0	2021-03-26 15:53:33.009	debug	(17231) States create User PubSub Client
    fahrplan.0	2021-03-26 15:53:33.008	debug	(17231) States create System PubSub Client
    fahrplan.0	2021-03-26 15:53:32.973	debug	(17231) Redis States: Use Redis connection: 10.0.0.227:9000
    fahrplan.0	2021-03-26 15:53:32.972	debug	(17231) objectDB connected
    fahrplan.0	2021-03-26 15:53:32.965	debug	(17231) Objects connected to redis: 10.0.0.227:9001
    fahrplan.0	2021-03-26 15:53:32.953	debug	(17231) Objects client initialize lua scripts
    fahrplan.0	2021-03-26 15:53:32.952	debug	(17231) Objects create User PubSub Client
    fahrplan.0	2021-03-26 15:53:32.951	debug	(17231) Objects create System PubSub Client
    fahrplan.0	2021-03-26 15:53:32.919	debug	(17231) Objects client ready ... initialize now
    fahrplan.0	2021-03-26 15:53:32.887	debug	(17231) Redis Objects: Use Redis connection: 10.0.0.227:9001
    host.VM-Slave	2021-03-26 15:53:32.117	info	instance system.adapter.fahrplan.0 started with pid 17231
    host.VM-Slave	2021-03-26 15:53:31.762	info	"system.adapter.fahrplan.0" enabled
    nuc i5: RaspberryMatic, ioBroker, pi-hole, SQL-Server, OMV-NAS, Influx-DB & Grafana, OpenHab, tasmoadmin
    derhuerstD 1 Antwort Letzte Antwort
    • JohGreJ JohGre
      @aggroralf
      Ja leider.
      derhuerstD Offline
      derhuerstD Offline
      derhuerst
      #88
      @johgre Ich habe hafas-client@5.15.2 veröffentlicht, damit sollte es jetzt gehen.
      JohGreJ 1 Antwort Letzte Antwort
      • derhuerstD derhuerst
        JohGreJ Offline
        JohGreJ Offline
        JohGre
        #89
        @derhuerst
        Danke, damit das aber im Adapter funktioniert muss dieser aber aktualisiert werden, Oder? Momentan geht's nämlich noch nicht. Oder kann/soll ich das Modul installieren?
        • JohGreJ JohGre
          @derhuerst
          AggroRalf
          #90
          @johgre Hab die neue Version im Adapter integriert. Kannst bitte mal über Git installieren und eine Rückmeldung geben ob es funktioniert ? Danke.
          @derhuerst : Jannis, danke wie immer für die sehr prompte Reaktion :-)
          • A AggroRalf
            JohGreJ Offline
            JohGreJ Offline
            JohGre
            schrieb am zuletzt editiert von JohGre
            #91
            @aggroralf Hi, weder eine Installation über die "Katze" noch direkt über den Github Link und anschließendem Upload behob das Problem.
            Habs jetzt noch mal mit dem richtigen Link probiert und nun schauts gut aus.
            • JohGreJ JohGre
              AggroRalf
              #92
              @johgre Hi,
              habe gerade 1.0.7 veröffentlicht im Beta-Zweig, dort ist die Änderung drin.
              Außerdem kann man die Farbe bei Pünktlich und Verspätet nun einfach anpassen.
              VG Ralf
              • A AggroRalf
                @johgre Hi,
                VG Ralf
                JohGreJ Offline
                JohGreJ Offline
                JohGre
                #93
                @aggroralf Danke, installiert und läuft
                • JohGreJ Offline
                  JohGreJ Offline
                  JohGre
                  #94
                  @AggroRalf Habe jetzt seit 16:55 folgende Fehler:
                  Error at HAFAS (Parser error: root.svcResL.svcResL.res.common.rtSrcL.rtSrcL.type)
                  Hast du das schon am Radar?
                    AggroRalf
                    #95
                    @johgre Hi,
                    was auch immer die ÖBB da dauernd macht :-/
                    Ist der Fehler permanent ? Aktualisiert die Routen überhaupt noch ?
                    VG Ralf
                    • A AggroRalf
                      @johgre Hi,
                      VG Ralf
                      JohGreJ Offline
                      JohGreJ Offline
                      JohGre
                      #96
                      @aggroralf sagte in Test Adapter Fahrplan v0.2.x:
                      War permanent ist nun wieder weg und die Routen aktualisieren auch.
                      • JohGreJ JohGre
                        AggroRalf
                        #97
                        Hi @johgre ,
                        nach Rücksprache mit @derhuerst habe ich ein erweitertes Fehlerreporting via Sentry für HAFAS-Fehler integriert.
                        Damit können wir dann solche HAFAS-Fehler besser analysieren.
                        Würdest Du bitte die aktuellste Version über die Katze installieren ? Die Versionsnummer hat sich erstmal nicht geändert.
                        Bei neuen Fehlern bitte kurz melden, dann seh ich ob es korrekt funktioniert und auch in Sentry mit den Fehlerdetails ankommt.
                        Vielen Dank und viele Grüße
                        Ralf
                        • A AggroRalf
                          Hi @johgre ,
                          Ralf
                          JohGreJ Offline
                          JohGreJ Offline
                          JohGre
                          #98
                          @aggroralf mach ich
                          • JohGreJ Offline
                            JohGreJ Offline
                            JohGre
                            #99
                            @AggroRalf So jetzt gerade eben ein Error at HAFAS (CGI_READ_FAILED)
                            • JohGreJ JohGre
                              AggroRalf
                              #100
                              @johgre Hi,
                              Hab’s in Sentry gesehen. Hab aktuell wenig Zeit aber schau es mir die Tage mal an.
                              Danke und viele Grüße
                              Ralf
                              N 1 Antwort Letzte Antwort
                              • A AggroRalf
                                @johgre Hi,
                                Ralf
                                N Offline
                                N Offline
                                namor
                                #101
                                @aggroralf
                                Hi, ich habe seit einiger Zeit (habs jetzt erst festgestellt) keine Daten mehr im DepartureTimetable!
                                Ist das bekannt?
                                Ich habe das in meinem View und die Kids beschweren sich das sie nicht mehr sehen wann die Straba fährt ;-)
                                • N namor
                                  @aggroralf
                                  Ist das bekannt?
                                  AggroRalf
                                  #102
                                  @namor Hi,
                                  nein, grundsätzlich ist nichts bekannt. Hast Du denn Fehler im Log ? Was sagen die Datenfelder, werden diese aktualisiert ?
                                  • A AggroRalf
                                    MOD-EDIT: Versionsnummer aus dem Threadtitel entfernt!
                                    Aktuelle Test Version 0.2.1
                                    Veröffentlichungsdatum 09.11.2020
                                    Github Link https://github.com/gaudes/ioBroker.fahrplan
                                    der Adapter bietet kurz zusammengefasst folgende Funktionen:
                                    • Fahrplan für Verbindungen (Routen)
                                      Hierbei werden die nächsten drei Verbindungen von A nach B als HTML und optional als Objekte abgebildet.
                                    • Verspätungsalarm
                                      Für die konfigurierten Routen kann ein Verspätungsalarm aktiviert werden. So kann beispielsweise eine Benachrichtigung via Telegram oder Alexa erfolgen, falls alle oder eine bestimmte Verbindung verspätet ist.
                                    • Abfahrtstafel für Stationen
                                      Die nächsten drei Abfahrten einer Station werden abgerufen und als Objekte und HTML dargestellt.
                                    Der Adapter verwendet den HAFAS-Client und beherrscht aktuell Deutsche Bahn und ÖBB.
                                    Der Adapter ist recht einfach. Man definiert in den Einstellungen die gewünschten Routen mit Optionen. Als Optionen kann man z.B. Zwischenhalte, Anzahl Umstiege, Verkehrsmittel (S-Bahn, Regio, etc.) angeben. Start, Ziel und eventuell Zwischenhalte müssen mit Ihrer e-Bahnhofs-ID angegeben werden. Der Adapter bietet hierfür in den Einstellungen eine Suche.
                                    Als Ergebnis werden Objekte angelegt. Pro Route (erste Ebene) gibt es einen Kanal, darunter dann jeweils drei "Reisen" (zweite Ebene), also Fahrten. Darunter gibt es dann die jeweiligen Reiseabschnitte (dritte Ebene). Zusätzlich gibt es Informationen zu den Start- und Zielbahnhöfen sowie zur jeweiligen Linie.
                                    Hier mal ein Beispiel: Ihr wollt von A nach C. Das ist die Route. Hierfür werden in HAFAS die nächsten drei Fahrten gesucht, z.B. 12:00 Uhr, 13:00 Uhr und 14:00 Uhr. Das sind die Reisen.
                                    Um 12:00 Uhr müsst Ihr von A nach B mit Linie S1 fahren, dann von B nach C mit Linie RB45. Das sind die Reiseabschnitte.
                                    Neben den Objekten wird optional eine HTML-Tabelle pro Route erzeugt, in dieser Tabelle werden z.B. Verspätungen farblich markiert. Das Inhalt der Tabelle ist konfigurierbar.
                                    Zusätzlich gibt es optional eine HTML-Tabelle pro Reise mit allen Reiseabschnitten.
                                    Außerdem gibt es einen Verspätungsalarm. Zu den eingestellten Routen lassen sich Verspätungsalarme für eine geplante Abfahrtszeit oder für alle Verbindungen einstellen. Die Ausgabe erfolgt dabei in ein Objekt in ioBroker, z.B. Alexa oder Telegram.
                                    Zusätzlich gibt es einen Abfahrtsmonitor. Hier werden Stationen in den Einstellungen angegeben. Pro Station wird dann neben den Objekten eine HTML-Tabelle mit den nächsten drei Abfahrten ab der Station erzeugt.
                                    Der Adapter hat bereits recht fehlerfrei einen Alpha-Test hinter sich gebracht, danke an alle Beteiligten.
                                    Weitere Infos und Hilfe zur Konfiguration gibt es in der Readme auf GitHub
                                    Was tun bei Fehlern oder Problemen?
                                    Bei Fehlern sollte zuerst das Log in ioBroker geprüft werden. Ich habe versucht, möglichst treffende Fehlermeldungen inklusive Route, Reise oder Reiseabschnitt mitzugeben.
                                    Bitte lasst die Option "JSON-Elemente speichern" aktiviert. Bei einem Fehler bei einer bestimmten Route, Reise oder Reiseabschnitt sendet bitte immer die aktuellen JSON-Objektinhalte mit. Dies ist notwendig, da der Fehler wirklich nur für eine bestimmte Reise zu einem bestimmten Zeitpunkt auftreten kann. Sonst kann ich Fehler oft nicht nachvollziehen.
                                    Bekannte Fehler
                                    Bei der Auswahl der Verkehrsmittel in der Route kann man leider nicht vorne beim Kästchen klicken, sondern muss beim Eintrag hinten in den leeren Bereich klicken. Es scheint ein CSS-Problem zu sein, was übergeordnet gelöst werden muss. Ich habe bereits ein Issue hierzu geöffnet.
                                    Bei Fragen oder Problemen gibt es für den Adapter auch den Kanal #fahrplan in Discord.
                                    O Offline
                                    O Offline
                                    Oli
                                    schrieb am zuletzt editiert von Oli
                                    #103
                                    @aggroralf
                                    bei mir funktioniert leider die Suche nach den Haltestellen ID nicht.
                                    Ist das allgemein so?
                                    Gibt es eine andere Möglichkeit die ID's herauszufinden?
                                    Oliver
                                    • O Oli
                                      @aggroralf
                                      AggroRalf
                                      #104
                                      Hi @oli
                                      welcher Anbieter ? DB, SBB oder OEBB ?
                                      SBB verwendet wohl leider kein HAFAS mehr, daher habe ich SBB in der neuesten Version entfernt.
                                      VG Ralf
                                      O 1 Antwort Letzte Antwort
                                      • A AggroRalf
                                        Hi @oli
                                        VG Ralf
                                        O Offline
                                        O Offline
                                        Oli
                                        #105
                                        @AggroRalf
                                        DB, ich kann den Button der Suche nicht betätigen. Der wird immer nur dunkelblau unterlegt und nichts passiert.
                                        Oliver
                                          AggroRalf
                                          #106
                                          @oli Läuft der Adapter, also ist er gestartet ? Hast mal einen anderen Webbrowser versucht ?
                                          O 2 Antworten Letzte Antwort
