  3. Entwicklung
  4. UniFi Adapter v0.5.7 stable
    5.4k
unifistableupdatev0.5.7
54 Beiträge 16 Kommentatoren 9.2k Aufrufe 23 Beobachtet
    @tom-son gibts dazu ein issue?
    Tom SonT Offline
    Tom SonT Offline
    Tom Son
    schrieb am zuletzt editiert von Tom Son
    @crunchip Fehler wie weiter oben schon beschrieben... nur der Rückschritt auf 0.5.5 bringt Ruhe ins Log
    das ist das Log:
    unifi.0
    	2021-05-23 12:04:56.237	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 12:03:56.602	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 12:02:56.467	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 12:01:56.481	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 12:00:56.977	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:59:56.508	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:58:56.899	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:57:56.624	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:56:56.670	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:55:56.245	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:54:56.588	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:53:57.702	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:52:56.563	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:51:58.842	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:50:56.417	error	fetchAlarms: Returned data is not in valid format
    unifi.0
    	2021-05-23 11:50:28.197	error	fetchAlarms: Returned data is not in valid format
    TI Board CC2652R1 / latest / js-Controler 3.3.18 / NodeJS 12.22.7
    • Tom SonT Tom Son
      das ist das Log:
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      unifi.0
      crunchipC Abwesend
      crunchipC Abwesend
      @tom-son ich habe 0.5.8 und wie oben geschrieben, in der config den Punkt Alarm herausgenommen
      Tom SonT 1 Antwort Letzte Antwort
        Tom SonT Offline
        Tom SonT Offline
        Tom Son
        @crunchip kann ich mal versuchen, aber was ist mit damit dass er nicht mit dem Host verbunden ist?
        • Tom SonT Offline
          Tom SonT Offline
          Tom Son
          Bin wieder zurück auf 0.5.5 bis das Problem gefixt wurde...
          • Tom SonT Tom Son
            crunchipC Abwesend
            crunchipC Abwesend
            @tom-son das liegt an der 0.5.9 hab doch geschrieben, habe 0.5.8
            Tom SonT 2 Antworten Letzte Antwort
              Tom SonT Offline
              Tom SonT Offline
              Tom Son
              @crunchip Funktioniert bei mir leider nicht, alles was höher ist als 0.5.5 kann keine Verbindung zu den Geräten oder Diensten aufbauen, siehe Bild oben...
                Tom SonT Offline
                Tom SonT Offline
                Tom Son
                @crunchip Habe heute nun die neue Version 0.5.10 installiert, auch diese Version kann bei mir keine Verbindung zu Geräten oder Dienste aufbauen (siehe Bild weiter oben) Was mach ich denn falsch?
                Die general Einstellungen hab ich nicht verändert, da kann man auch nicht viel machen, mit dem eingetragenen Benutzer kann ich mich auf dem Unifi Kontroller (Cloudkey gen2 plus) anmelden, das klappt.
                Wenn ich wieder zurück gehe auf 0.5.5 (alle nächst höheren Versionen haben das selbe Feherlbild) dann läuft alles wie es soll... Bin ich der einzige bei dem das nicht klappt??
                Mein CC läuft mit der Firmware 2.0.26
                UI 6.0.44
                Backend 6.0.45
                Build atag_6.0.45_14358
                integer63I crunchipC 2 Antworten Letzte Antwort
                • Tom SonT Tom Son
                  UI 6.0.44
                  Backend 6.0.45
                  integer63I Offline
                  integer63I Offline
                  integer63
                  schrieb am zuletzt editiert von integer63
                  @tom-son Also bei mir läuft der Unifi Controller in der Version 6.2.25 (oder wie er neuerdings genannt wird: UniFi Network Application) auf einer Linux VM (also self-hosted). Ich bekomme alle paar Minuten ein Update aller Datenpunkte, welche ich zuvor in der Konfiguration des Adapters aktiviert habe.
                  [edit] und ich habe aktuell 0.5.8 installiert
                  • integer63I integer63
                    Tom SonT Offline
                    Tom SonT Offline
                    Tom Son
                    @integer63 hab ich gesehen, werde die Aktualisierung morgen machen, habe heute keine Lust was wieder her zu stellen, falls was schiefläuft...
                    • Tom SonT Tom Son
                      UI 6.0.44
                      Backend 6.0.45
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @tom-son hab die Version noch nicht getestet, bin noch auf 0.5.8
                      • G Offline
                        Georgius
                        Hi
                        Wo finde ich in dem Adapter die Temperatur der Dream Mashine Pro?
                        • Tom SonT Offline
                          Tom SonT Offline
                          Tom Son
                          Ich habe jetzt den neuesten Adapter zum laufen bekommen, fragt mich nicht genau wie :-) auf jedenfall muss man bei den Alarms alle Hacken rausnehmen, auch den ganz oben "Alarmmeldungen aktualisieren" und der Tipp mit dem Passwort neu eingeben (obwohl es das gleiche ist) hat auch geholfen...
                          Zudem hab ich noch ein FW update vom CC 2k+ bekommen und den Netzwerk Kontroller auf den letzten Stand gebracht.
                          Bis heute alles grün...
                          • Tom SonT Tom Son
                            crunchipC Abwesend
                            crunchipC Abwesend
                            @tom-son sagte in UniFi Adapter v0.5.7 stable:
                            das hatte ich weiter oben schon geschrieben
                            • NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              @Scrounger
                              Ich hab gesehn, dass du auch am Unifi-Adapter mitarbeitest.
                              Ich bekomm laufend die Meldung unifi.0.default.num_new_alarms" is missing the required property "common.type
                              Issue gibt es schon.
                              Adapter: 0.5.10
                              Admin: 5.1.25
                              JS-Controller: 3.3.18
                              Node.js: v14.17.1
                              NPM: 6.14.13
                              Hast du einen Tipp dazu?
                              ° Fixer ---> iob fix
                              ScroungerS 1 Antwort Letzte Antwort
                              • NegaleinN Negalein
                                @Scrounger
                                Adapter: 0.5.10
                                Admin: 5.1.25
                                Node.js: v14.17.1
                                NPM: 6.14.13
                                ScroungerS Offline
                                ScroungerS Offline
                                Scrounger
                                @negalein
                                Jup das Alarm Zeug hatte ich damals implementiert.
                                Schau ich mir an, aber wird sicher etwas dauern hab Grad nicht soviel Zeit. Außerdem ist das doch nur nen "Schönheitsfehler" der das Log zu spamt?
                                • ScroungerS Scrounger
                                  @negalein
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  @scrounger sagte in UniFi Adapter v0.5.7 stable:
                                  Ja, nur ein Schönheitsfehler, aber spamt das Log sehr zu.
