  4. Erstinstallation iob mit CC26X2R1 - failed to start zigbee
    6.5k
gelöst
16 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • A Aprozz
    @arteck said in Erstinstallation iob mit CC26X2R1 - failed to start zigbee:
    https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
    Hier bitte,
    2021-05-27 10:13:39.662 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
    2021-05-27 10:13:39.748 - info: host.raspberrypi iobroker Update "system.adapter.zigbee.0"
    2021-05-27 10:13:39.759 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-05-27 10:13:39.763 - info: zigbee.0 (1355) Got terminate signal TERMINATE_YOURSELF
    2021-05-27 10:13:39.774 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2021-05-27 10:13:39.765 - info: zigbee.0 (1355) cleaned everything up...
    2021-05-27 10:13:39.769 - info: zigbee.0 (1355) Zigbee: disabling joining new devices.
    2021-05-27 10:13:39.771 - warn: zigbee.0 (1355) Failed to stop zigbee during startup
    2021-05-27 10:13:39.771 - info: zigbee.0 (1355) terminating
    2021-05-27 10:13:39.773 - info: zigbee.0 (1355) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-05-27 10:13:39.774 - error: zigbee.0 (1355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-05-27 10:13:39.775 - error: zigbee.0 (1355) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-05-27 10:13:39.778 - error: zigbee.0 (1355) TypeError: Cannot read property 'getEntries' of null
    at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
    at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
    at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
    at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
    at Zigbee.emit (events.js:314:20)
    at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
    2021-05-27 10:13:39.778 - error: zigbee.0 (1355) Cannot read property 'getEntries' of null
    2021-05-27 10:13:40.357 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-05-27 10:13:40.801 - info: host.raspberrypi iobroker exit 0
    2021-05-27 10:13:41.087 - info: host.raspberrypi Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
    2021-05-27 10:13:42.811 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1444
    2021-05-27 10:13:45.214 - info: zigbee.0 (1444) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
    2021-05-27 10:13:45.308 - info: zigbee.0 (1444) Starting Zigbee npm ...
    2021-05-27 10:13:45.516 - error: zigbee.0 (1444) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
    2021-05-27 10:13:45.517 - error: zigbee.0 (1444) Failed to start Zigbee
    2021-05-27 10:13:45.518 - error: zigbee.0 (1444) Error herdsman start
    2021-05-27 10:13:45.579 - info: zigbee.0 (1444) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
    2021-05-27 10:13:55.518 - info: zigbee.0 (1444) Try to reconnect. 1 attempts left
    2021-05-27 10:13:55.520 - info: zigbee.0 (1444) Starting Zigbee npm ...
    2021-05-27 10:13:55.527 - error: zigbee.0 (1444) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
    2021-05-27 10:13:55.529 - error: zigbee.0 (1444) Failed to start Zigbee
    2021-05-27 10:13:55.530 - error: zigbee.0 (1444) Error herdsman start
    2021-05-27 10:13:55.539 - info: zigbee.0 (1444) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
    2021-05-27 10:14:21.235 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
    2021-05-27 10:14:21.240 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2021-05-27 10:14:21.255 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
    2021-05-27 10:14:21.254 - info: zigbee.0 (1444) Got terminate signal TERMINATE_YOURSELF
    2021-05-27 10:14:21.258 - info: zigbee.0 (1444) cleaned everything up...
    2021-05-27 10:14:21.266 - info: zigbee.0 (1444) Zigbee: disabling joining new devices.
    2021-05-27 10:14:21.270 - warn: zigbee.0 (1444) Failed to stop zigbee during startup
    2021-05-27 10:14:21.272 - info: zigbee.0 (1444) terminating
    2021-05-27 10:14:21.274 - info: zigbee.0 (1444) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-05-27 10:14:21.277 - error: zigbee.0 (1444) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-05-27 10:14:21.278 - error: zigbee.0 (1444) unhandled promise rejection: Cannot read property 'getEntries' of null
    2021-05-27 10:14:21.280 - error: zigbee.0 (1444) TypeError: Cannot read property 'getEntries' of null
    at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
    at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
    at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
    at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2021-05-27 10:14:21.281 - error: zigbee.0 (1444) Cannot read property 'getEntries' of null
    2021-05-27 10:14:21.823 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    arteckA Offline
    arteckA Offline
    arteck
    @aprozz und das board hast du geflasht ?
    • arteckA arteck
      Aprozz
      @arteck
      Das Board habe ich mit dem Uniflash 6.3 und dem image "CC2652R_coordinator_20210120.hex" geflasht. Die Pruefung viel positiv aus.
      • A Aprozz
        @arteck
        arteckA Offline
        arteckA Offline
        arteck
        @aprozz das gibts doch nicht...hast due kiste mal neu gestartet ?
        wenn ja dann bitte adapter auf debug stellen und LOG posten
        A 3 Antworten Letzte Antwort
        • arteckA arteck
          Aprozz
          @arteck
          Hab den PI heute morgen mit "sudo shutdown -r now" neugestartet. Kann ich gleich nochmals probieren.
          v522533V 1 Antwort Letzte Antwort
          • arteckA arteck
            Aprozz
            @arteck
            2021-05-27 10:52:40.652 - info: host.raspberrypi "system.adapter.zigbee.0" enabled
            2021-05-27 10:52:40.707 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1503
            2021-05-27 10:52:43.127 - info: zigbee.0 (1503) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
            2021-05-27 10:52:43.222 - info: zigbee.0 (1503) Starting Zigbee npm ...
            2021-05-27 10:52:43.441 - error: zigbee.0 (1503) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
            2021-05-27 10:52:43.442 - error: zigbee.0 (1503) Failed to start Zigbee
            2021-05-27 10:52:43.442 - error: zigbee.0 (1503) Error herdsman start
            2021-05-27 10:52:43.507 - info: zigbee.0 (1503) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
            2021-05-27 10:52:53.444 - info: zigbee.0 (1503) Try to reconnect. 1 attempts left
            2021-05-27 10:52:53.446 - info: zigbee.0 (1503) Starting Zigbee npm ...
            2021-05-27 10:52:53.455 - error: zigbee.0 (1503) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
            2021-05-27 10:52:53.456 - error: zigbee.0 (1503) Failed to start Zigbee
            2021-05-27 10:52:53.458 - error: zigbee.0 (1503) Error herdsman start
            2021-05-27 10:52:53.467 - info: zigbee.0 (1503) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
            • A Aprozz
              @arteck
              v522533V Offline
              v522533V Offline
              v522533
              @aprozz
              ich hatte das auch schonmal. Versuch mal folgendes:
              1. Zigbee Adapter stoppen
              2. Stick abziehen
              3. ca. 10 Sek warten
              4. Stick wieder einstecken
              5. Adapter starten
              Bei mir hat das funktioniert, warum weiss ich nicht ;)
              Gruß Chris
              • arteckA arteck
                Aprozz
                @arteck
                Und jetzt der log nach dem Neustart;
                2021-05-27 10:55:27.239 - info: zigbee.0 (1503) Got terminate signal TERMINATE_YOURSELF
                2021-05-27 10:55:27.288 - info: zigbee.0 (1503) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-05-27 10:55:27.743 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-05-27 10:55:27.774 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-05-27 10:55:27.785 - info: host.raspberrypi instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-05-27 10:55:27.844 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-05-27 10:55:27.845 - info: host.raspberrypi All instances are stopped.
                2021-05-27 10:55:27.957 - info: host.raspberrypi terminated
                2021-05-27 10:55:46.720 - info: host.raspberrypi iobroker.js-controller version 3.2.16 js-controller starting
                2021-05-27 10:55:46.726 - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                2021-05-27 10:55:46.726 - info: host.raspberrypi hostname: raspberrypi, node: v12.22.1
                2021-05-27 10:55:46.727 - info: host.raspberrypi ip addresses: 192.168.178.47 fe80::c55c:c16:1073:a262
                2021-05-27 10:55:47.116 - info: host.raspberrypi connected to Objects and States
                2021-05-27 10:55:47.143 - info: host.raspberrypi added notifications configuration of host
                2021-05-27 10:55:47.634 - info: host.raspberrypi 4 instances found
                2021-05-27 10:55:47.651 - info: host.raspberrypi starting 4 instances
                2021-05-27 10:55:47.708 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 579
                2021-05-27 10:55:49.902 - info: admin.0 (579) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
                2021-05-27 10:55:49.953 - info: admin.0 (579) requesting all states
                2021-05-27 10:55:49.954 - info: admin.0 (579) requesting all objects
                2021-05-27 10:55:50.228 - info: admin.0 (579) received all objects
                2021-05-27 10:55:50.363 - info: admin.0 (579) http server listening on port 8081
                2021-05-27 10:55:50.364 - info: admin.0 (579) Use link "http://localhost:8081" to configure.
                2021-05-27 10:55:51.700 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 594
                2021-05-27 10:55:53.265 - info: discovery.0 (594) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
                2021-05-27 10:55:55.709 - info: host.raspberrypi instance system.adapter.info.0 started with pid 609
                2021-05-27 10:55:58.582 - info: info.0 (609) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
                2021-05-27 10:55:59.671 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 815
                2021-05-27 10:56:17.071 - info: zigbee.0 (815) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                2021-05-27 10:56:17.200 - info: zigbee.0 (815) Starting Zigbee npm ...
                2021-05-27 10:56:17.511 - error: zigbee.0 (815) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
                2021-05-27 10:56:17.512 - error: zigbee.0 (815) Failed to start Zigbee
                2021-05-27 10:56:17.512 - error: zigbee.0 (815) Error herdsman start
                2021-05-27 10:56:17.581 - info: zigbee.0 (815) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
                2021-05-27 10:56:27.514 - info: zigbee.0 (815) Try to reconnect. 1 attempts left
                2021-05-27 10:56:27.515 - info: zigbee.0 (815) Starting Zigbee npm ...
                2021-05-27 10:56:27.523 - error: zigbee.0 (815) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-idusb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00'"
                2021-05-27 10:56:27.524 - error: zigbee.0 (815) Failed to start Zigbee
                2021-05-27 10:56:27.525 - error: zigbee.0 (815) Error herdsman start
                2021-05-27 10:56:27.530 - info: zigbee.0 (815) Installed Version: ioBroker/ioBroker.zigbee#50d5b069ff6756f41fcda6af42a9faf01969462d
                • v522533V v522533
                  @aprozz
                  2. Stick abziehen
                  5. Adapter starten
                  Aprozz
                  @v522533
                  Danke fuer den Tipp, kann ich leider erst heute Abend ausprobieren...
                  • A Aprozz
                    @v522533
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @aprozz
                    hier ist das problem
                    so muss das
                    /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.15__Embed_with_CMSIS-DAP_L1100MXG-if00
                    wenns immer noch nicht geht zeigmal
                    ls -l /dev/serial/by-id
                    • arteckA arteck
                      @aprozz
                      so muss das
                      Aprozz
                      @arteck
                      Ich fress einen Besen! hab bestimmt schon zwei oder dreimal den Pfad kopiert.
                      Danke fuer die Hilfe, es laeuft jetzt. 👍
                      • A Aprozz
                        @arteck
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @aprozz setzt bitte den Beitrag auf gelöst
