  4. [Gelöst] Zigbee-Adapter bleibt Gelb
iobrokerzigbee
49 Beiträge 7 Kommentatoren 6.3k Aufrufe 8 Beobachtet
    @smart_home sagte in [Zigbee] Zigbee-Adapter bleibt Gelb:
    ttyACM0
    Jetzt mal ein
    sudo lsof /dev/ttyACM0
    Smart_HomeS Offline
    Smart_HomeS Offline
    Smart_Home
    @thomas-braun sagte in [Zigbee] Zigbee-Adapter bleibt Gelb:
    COMMAND   PID     USER   FD   TYPE DEVICE SIZE/OFF     NODE NAME
    node    10755 iobroker   26uW  CHR  166,0      0t0 11361267 /dev/ttyACM0
    • Smart_HomeS Smart_Home
      @smart_home
      iobroker stop
      sudo reboot
      Smart_HomeS 1 Antwort Letzte Antwort
        @smart_home
        iobroker stop
        sudo reboot
        Smart_HomeS Offline
        Smart_HomeS Offline
        Smart_Home
        Leider immer noch Gelb :-/
          @smart_home
          Gib mal das Link Target
          /dev/ttyACM0
          statt dem by-serial-Link im Adapter an.
            @smart_home
            /dev/ttyACM0
            Smart_HomeS Offline
            Smart_HomeS Offline
            Smart_Home
            schrieb am zuletzt editiert von Smart_Home
            /dev/ttyACM0
            So etwa?
            EDIT: Bringt leider keine Besserung. Weiterhin Gelb
            zigbee.0	2021-05-23 21:48:06.120	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
            zigbee.0	2021-05-23 21:48:06.120	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
            zigbee.0	2021-05-23 21:48:06.120	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
            zigbee.0	2021-05-23 21:48:06.120	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
            zigbee.0	2021-05-23 21:48:06.120	error	at new Promise (<anonymous>)
            zigbee.0	2021-05-23 21:48:06.120	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
            zigbee.0	2021-05-23 21:48:06.120	error	at Generator.next (<anonymous>)
            zigbee.0	2021-05-23 21:48:06.120	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
            zigbee.0	2021-05-23 21:48:06.120	error	(31076) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
            zigbee.0	2021-05-23 21:48:06.119	error	(31076) Failed to start Zigbee
            zigbee.0	2021-05-23 21:48:05.963	info	(31076) Installed Version: iobroker.zigbee@1.4.4
            zigbee.0	2021-05-23 21:48:05.936	info	(31076) Starting Zigbee npm ...
            zigbee.0	2021-05-23 21:48:05.935	info	(31076) Try to reconnect. 1 attempts left
            zigbee.0	2021-05-23 21:47:55.934	error	at fulfilled (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
            zigbee.0	2021-05-23 21:47:55.934	error	at Generator.next (<anonymous>)
            zigbee.0	2021-05-23 21:47:55.934	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:193:41)
            zigbee.0	2021-05-23 21:47:55.934	error	(31076) TypeError: Cannot read property 'error' of undefined
            zigbee.0	2021-05-23 21:47:55.932	error	(31076) Failed to start Zigbee
            zigbee.0	2021-05-23 21:47:54.394	info	(31076) Installed Version: iobroker.zigbee@1.4.4
            zigbee.0	2021-05-23 21:47:53.792	info	(31076) Starting Zigbee npm ...
            zigbee.0	2021-05-23 21:47:53.685	info	(31076) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
            Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
              /dev/ttyACM0
              So etwa?
              @smart_home
              Was ist denn das eigentlich für eine Hardware da?
              lsusb
                @smart_home
                lsusb
                Smart_HomeS Offline
                Smart_HomeS Offline
                Smart_Home
                Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                Bus 002 Device 002: ID 0451:16c8 Texas Instruments, Inc.
                Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                Bus 001 Device 002: ID 0627:0001 Adomax Technology Co., Ltd
                Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                  /dev/ttyACM0
                  So etwa?
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @smart_home
                  Bitte prüfen:
                  • welche Version der zigbee-herdsman-converters und zigbee-herdsman sind installiert
                  • Zigbee Adapter anhalten, auf debug stellen, log löschen, zigbee Adapter starten, log posten (Warnung - Log kann lang werden
                  A.
                  • AsgothianA Asgothian
                    @smart_home
                    Bitte prüfen:
                    A.
                    Smart_HomeS Offline
                    Smart_HomeS Offline
                    Smart_Home
                    @asgothian
                    Meintest du damit die Version vom Adapter selbst? Weil ich muss zugeben, die Begriffe "zigbee-herdsman-converters" und "zigbee-herdsman" sagen mir leider nichts :-/
                    Ich hoffe ich habe es richtig gemacht mit dem Log:
                    zigbee.0	2021-05-24 12:35:08.203	error	(24309) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-he
                    zigbee.0	2021-05-24 12:35:08.201	error	(24309) Failed to start Zigbee
                    zigbee.0	2021-05-24 12:35:08.022	info	(24309) Installed Version: iobroker.zigbee@1.4.4
                    zigbee.0	2021-05-24 12:35:08.004	info	(24309) Starting Zigbee npm ...
                    zigbee.0	2021-05-24 12:35:08.002	info	(24309) Try to reconnect. 1 attempts left
                    zigbee.0	2021-05-24 12:34:58.001	error	at fulfilled (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
                    zigbee.0	2021-05-24 12:34:58.001	error	at Generator.next (<anonymous>)
                    zigbee.0	2021-05-24 12:34:58.001	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:193:41)
                    zigbee.0	2021-05-24 12:34:58.001	error	(24309) TypeError: Cannot read property 'error' of undefined
                    zigbee.0	2021-05-24 12:34:58.000	error	(24309) Failed to start Zigbee
                    zigbee.0	2021-05-24 12:34:56.456	info	(24309) Installed Version: iobroker.zigbee@1.4.4
                    zigbee.0	2021-05-24 12:34:55.851	info	(24309) Starting Zigbee npm ...
                    zigbee.0	2021-05-24 12:34:55.742	info	(24309) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                    zigbee.0	2021-05-24 12:34:43.119	info	(22131) Got terminate signal TERMINATE_YOURSELF
                    zigbee.0	2021-05-24 12:34:43.099	error	(22131) Cannot read property 'getEntries' of null
                    zigbee.0	2021-05-24 12:34:43.098	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                    zigbee.0	2021-05-24 12:34:43.098	error	at Zigbee.emit (events.js:314:20)
                    zigbee.0	2021-05-24 12:34:43.098	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
                    zigbee.0	2021-05-24 12:34:43.098	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
                    zigbee.0	2021-05-24 12:34:43.098	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
                    zigbee.0	2021-05-24 12:34:43.098	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
                    zigbee.0	2021-05-24 12:34:43.098	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
                    zigbee.0	2021-05-24 12:34:43.098	error	at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
                    zigbee.0	2021-05-24 12:34:43.098	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                    zigbee.0	2021-05-24 12:34:43.098	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                    zigbee.0	2021-05-24 12:34:43.098	error	(22131) TypeError: Cannot read property 'getEntries' of null
                    zigbee.0	2021-05-24 12:34:43.093	error	(22131) unhandled promise rejection: Cannot read property 'getEntries' of null
                    zigbee.0	2021-05-24 12:34:43.093	error	(22131) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    zigbee.0	2021-05-24 12:34:43.091	info	(22131) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0	2021-05-24 12:34:43.090	info	(22131) terminating
                    zigbee.0	2021-05-24 12:34:43.089	warn	(22131) Failed to stop zigbee during startup
                    zigbee.0	2021-05-24 12:34:43.080	info	(22131) Zigbee: disabling joining new devices.
                    zigbee.0	2021-05-24 12:34:43.075	info	(22131) cleaned everything up...
                    zigbee.0	2021-05-24 12:34:43.071	info	(22131) Got terminate signal TERMINATE_YOURSELF
                    zigbee.0	2021-05-24 12:32:58.173	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                    zigbee.0	2021-05-24 12:32:58.173	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                    zigbee.0	2021-05-24 12:32:58.173	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                    zigbee.0	2021-05-24 12:32:58.173	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                    zigbee.0	2021-05-24 12:32:58.173	error	at new Promise (<anonymous>)
                    zigbee.0	2021-05-24 12:32:58.173	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                    zigbee.0	2021-05-24 12:32:58.173	error	at Generator.next (<anonymous>)
                    zigbee.0	2021-05-24 12:32:58.173	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                    zigbee.0	2021-05-24 12:32:58.173	error	(22131) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                    zigbee.0	2021-05-24 12:32:58.171	error	(22131) Failed to start Zigbee
                    zigbee.0	2021-05-24 12:32:58.025	info	(22131) Installed Version: iobroker.zigbee@1.4.4
                    zigbee.0	2021-05-24 12:32:58.003	info	(22131) Starting Zigbee npm ...
                    zigbee.0	2021-05-24 12:32:58.001	info	(22131) Try to reconnect. 1 attempts left
                    zigbee.0	2021-05-24 12:32:47.999	error	at fulfilled (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:24:58)
                    zigbee.0	2021-05-24 12:32:47.999	error	at Generator.next (<anonymous>)
                    zigbee.0	2021-05-24 12:32:47.999	error	at ZnpAdapterManager.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/manager.js:193:41)
                    zigbee.0	2021-05-24 12:32:47.999	error	(22131) TypeError: Cannot read property 'error' of undefined
                    zigbee.0	2021-05-24 12:32:47.998	error	(22131) Failed to start Zigbee
                    zigbee.0	2021-05-24 12:32:46.453	info	(22131) Installed Version: iobroker.zigbee@1.4.4
                    zigbee.0	2021-05-24 12:32:45.863	info	(22131) Starting Zigbee npm ...
                    zigbee.0	2021-05-24 12:32:45.751	info	(22131) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                    zigbee.0	2021-05-24 12:32:33.435	info	(21853) Installed Version: iobroker.zigbee@1.4.4
                    zigbee.0	2021-05-24 12:32:33.424	info	(21853) Got terminate signal TERMINATE_YOURSELF
                    zigbee.0	2021-05-24 12:32:33.421	error	(21853) Cannot read property 'getEntries' of null
                    zigbee.0	2021-05-24 12:32:33.421	error	at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                    zigbee.0	2021-05-24 12:32:33.421	error	at Zigbee.emit (events.js:314:20)
                    zigbee.0	2021-05-24 12:32:33.421	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:581:41)
                    zigbee.0	2021-05-24 12:32:33.421	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:310:20)
                    zigbee.0	2021-05-24 12:32:33.421	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:192:42)
                    zigbee.0	2021-05-24 12:32:33.421	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
                    zigbee.0	2021-05-24 12:32:33.421	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:206:49)
                    zigbee.0	2021-05-24 12:32:33.421	error	at Controller.getDevices (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
                    zigbee.0	2021-05-24 12:32:33.421	error	at Function.all (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                    zigbee.0	2021-05-24 12:32:33.421	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
                    zigbee.0	2021-05-24 12:32:33.421	error	(21853) TypeError: Cannot read property 'getEntries' of null
                    zigbee.0	2021-05-24 12:32:33.418	error	(21853) unhandled promise rejection: Cannot read property 'getEntries' of null
                    zigbee.0	2021-05-24 12:32:33.417	error	(21853) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    zigbee.0	2021-05-24 12:32:33.416	info	(21853) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0	2021-05-24 12:32:33.415	info	(21853) terminating
                    zigbee.0	2021-05-24 12:32:33.414	warn	(21853) Failed to stop zigbee during startup
                    zigbee.0	2021-05-24 12:32:33.412	info	(21853) Zigbee: disabling joining new devices.
                    zigbee.0	2021-05-24 12:32:33.408	info	(21853) cleaned everything up...
                    zigbee.0	2021-05-24 12:32:33.407	info	(21853) Got terminate signal TERMINATE_YOURSELF
                    zigbee.0	2021-05-24 12:32:32.766	info	(21853) Starting Zigbee npm ...
                    zigbee.0	2021-05-24 12:32:32.663	info	(21853) starting. Version 1.4.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
                    EDIT: Habe gerade auch nochmal auf meinem Slave geschaut. Da funktioniert die Steuerung über Zigbee problemlos und der Adapter ist grün :)
                    • arteckA Offline
                      arteckA Offline
                      arteck
                      @Smart_Home du betreibst 2 instanzen des adapter ??
                      einmanl auf dem Host ainemal auf dem Slave ?? oder wie soll ich das verstehen ??
                        @asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @smart_home Bitte prüfen:
                        • Version zigbee-herdsman-converters, zu finden in der Datei /opt/iobroker/node_modules/zigbee-herdsman-converters/package.json (sowohl auf dem Master als auch auf dem Slave)
                        • Version zigbee-herdsman, zu finden in der Datei /opt/iobroker/node_modules/zigbee-herdsman/package.json (sowohl auf dem Master als auch auf dem Slave)
                        Sollten die Dateien an der Stelle nicht zu finden sein bitte via "npm list" herausfinden wo sich die Bibliotheken befinden und deren Versionsnummer heraus suchen
                        Auffällig ist das im Log versucht wird den Herdsman zu starten, dieser aber keine Meldung bringt. Das ist auffällig. Dementsprechend hat das in Debug setzen anscheinend nicht funktioniert.
                        A.
                        • arteckA arteck
                          Smart_HomeS Offline
                          Smart_HomeS Offline
                          Smart_Home
                          @arteck
                          Genau so ist das :) Deshalb habe ich einmal zigbee.0 und einmal zigbee.1
                            A.
                            Smart_HomeS Offline
                            Smart_HomeS Offline
                            Smart_Home
                            @asgothian
                            Ich komme bis in das Unterverzeichnis "zigbee-herdsman-converters"
                            Was muss ich eingeben, um package.json öffnen zu können? :)
                              @asgothian
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @smart_home
                              am besten kopierst Du dir die Datei auf dein Hauptsystem und öffnest sie mit einem Texteditor.
                              A.
                              Smart_HomeS 2 Antworten Letzte Antwort
                                @smart_home
                                A.
                                Smart_HomeS Offline
                                Smart_HomeS Offline
                                Smart_Home
                                @asgothian
                                Ich sage mal so, über Putty schaffe ich es bis hierhin:
                                x@ioBroker:~$ cd /opt
                                x@ioBroker:/opt$ cd iobroker
                                x@ioBroker:/opt/iobroker$ cd node_modules
                                x@ioBroker:/opt/iobroker/node_modules$ cd zigbee-herdsman-converters
                                x@ioBroker:/opt/iobroker/node_modules/zigbee-herdsman-converters$
                                EDIT: Danke an @Thomas-Braun
                                Dann erhalte ich folgende Ausgabe für Master:
                                x@ioBroker:/opt/iobroker/node_modules/zigbee-herdsman-converters$ less package.json
                                  "_from": "zigbee-herdsman-converters@^14.0.57",
                                  "_id": "zigbee-herdsman-converters@14.0.61",
                                  "_inBundle": false,
                                  "_integrity": "sha512-DsgU7AJfrcaaJqsogo4zJ1YpkdS/HBYDyUC1kJeLXL6Z+dBFaAX5yvNWS2gedCz8qel11NboatUrcKUtmo4WDQ==",
                                  "_location": "/zigbee-herdsman-converters",
                                  "_phantomChildren": {
                                    "@serialport/parser-inter-byte-timeout": "9.0.1"
                                  "_requested": {
                                    "type": "range",
                                    "registry": true,
                                    "raw": "zigbee-herdsman-converters@^14.0.57",
                                    "name": "zigbee-herdsman-converters",
                                    "escapedName": "zigbee-herdsman-converters",
                                    "rawSpec": "^14.0.57",
                                    "saveSpec": null,
                                    "fetchSpec": "^14.0.57"
                                  "_requiredBy": [
                                    "/iobroker.zigbee"
                                  "_resolved": "https://registry.npmjs.org/zigbee-herdsman-converters/-/zigbee-herdsman-converters-14.0.61.tgz",
                                  "_shasum": "536e2a06d0f856a1fcf293170f4f51ec0b96db27",
                                  "_shrinkwrap": {
                                    "version": "14.0.61",
                                    "lockfileVersion": 1,
                                    "requires": true,
                                    "dependencies": {
                                      "@babel/code-frame": {
                                        "version": "7.12.11",
                                        "resolved": "https://registry.npmjs.org/@babel/code-frame/-/code-frame-7.12.11.tgz",
                                        "integrity": "sha512-Zt1yodBx1UcyiePMSkWnU4hPqhwq7hGi2nFL1LeA3EUl+q2LQx16MISgJ0+z7dnmgvP9QtIleuETGOiOH1RcIw==",
                                        "dev": true,
                                        "requires": {
                                          "@babel/highlight": "^7.10.4"
                                      "@babel/core": {
                                        "version": "7.12.16",
                                        "resolved": "https://registry.npmjs.org/@babel/core/-/core-7.12.16.tgz",
                                        "integrity": "sha512-t/hHIB504wWceOeaOoONOhu+gX+hpjfeN6YRBT209X/4sibZQfSF1I0HFRRlBe97UZZosGx5XwUg1ZgNbelmNw==",
                                        "dev": true,
                                        "requires": {
                                          "@babel/code-frame": "^7.12.13",
                                Und für Slave folgende Ausgabe:
                                x@ioBroker-Slave:/opt/iobroker/node_modules/zigbee-herdsman-converters$ less package.json
                                  "_id": "zigbee-herdsman-converters@14.0.156",
                                  "_inBundle": false,
                                  "_integrity": "sha512-pQ7b33ZEGP1fjwhWmlAFlsknRWSVMfJmKutiYZlZlOv5cdFnrIEpwaBwEgzAmwqNWEBMsjIr3Lz8/W2dS8vpuQ==",
                                    "@serialport/parser-inter-byte-timeout": "9.0.7",
                                    "mz": "2.7.0"
                                  "_requested": {
                                    "type": "range",
                                    "registry": true,
                                    "saveSpec": null,
                                  "_requiredBy": [
                                    "/iobroker.zigbee"
                                  @asgothian
                                    "_inBundle": false,
                                    "_requested": {
                                      "type": "range",
                                      "registry": true,
                                      "saveSpec": null,
                                    "_requiredBy": [
                                      "/iobroker.zigbee"
                                    "_shrinkwrap": {
                                      "requires": true,
                                      "dependencies": {
                                          "dev": true,
                                          "requires": {
                                        "@babel/core": {
                                          "dev": true,
                                          "requires": {
                                    "_inBundle": false,
                                      "mz": "2.7.0"
                                    "_requested": {
                                      "type": "range",
                                      "registry": true,
                                      "saveSpec": null,
                                    "_requiredBy": [
                                      "/iobroker.zigbee"
                                  @smart_home
                                  less DATEINAME
                                    @smart_home
                                    A.
                                    Smart_HomeS Offline
                                    Smart_HomeS Offline
                                    Smart_Home
                                    @asgothian
                                    Seit dem Update des Zigbee Adapters bleibt der Adapter nun sogar nur rot:
                                    zigbee.0	2021-05-29 11:55:34.080	info	(22108) Got terminate signal TERMINATE_YOURSELF
                                    zigbee.0	2021-05-29 11:55:34.070	error	(22108) Cannot read property 'getEntries' of null
                                    zigbee.0	2021-05-29 11:55:34.069	error	(22108) TypeError: Cannot read property 'getEntries' of null at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/
                                    zigbee.0	2021-05-29 11:55:34.068	error	(22108) unhandled promise rejection: Cannot read property 'getEntries' of null
                                    zigbee.0	2021-05-29 11:55:34.067	error	(22108) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    zigbee.0	2021-05-29 11:55:34.066	info	(22108) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    zigbee.0	2021-05-29 11:55:34.064	info	(22108) terminating
                                    zigbee.0	2021-05-29 11:55:34.063	warn	(22108) Failed to stop zigbee during startup
                                    zigbee.0	2021-05-29 11:55:34.061	info	(22108) Zigbee: disabling joining new devices.
                                    zigbee.0	2021-05-29 11:55:34.057	info	(22108) cleaned everything up...
                                    zigbee.0	2021-05-29 11:55:34.055	info	(22108) Got terminate signal TERMINATE_YOURSELF
                                    zigbee.0	2021-05-29 11:53:49.075	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
                                    zigbee.0	2021-05-29 11:53:49.075	error	at SerialPort._error (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
                                    zigbee.0	2021-05-29 11:53:49.075	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:134:49)
                                    zigbee.0	2021-05-29 11:53:49.075	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:23:12)
                                    zigbee.0	2021-05-29 11:53:49.075	error	at new Promise (<anonymous>)
                                    zigbee.0	2021-05-29 11:53:49.075	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:27:71
                                    zigbee.0	2021-05-29 11:53:49.075	error	at Generator.next (<anonymous>)
                                    zigbee.0	2021-05-29 11:53:49.075	error	at Znp.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:136:32)
                                    zigbee.0	2021-05-29 11:53:49.075	error	(22108) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
                                    zigbee.0	2021-05-29 11:53:49.074	error	(22108) Failed to start Zigbee
                                    zigbee.0	2021-05-29 11:53:48.879	info	(22108) Installed Version: iobroker.zigbee@1.5.5
                                    zigbee.0	2021-05-29 11:53:48.854	info	(22108) Starting Zigbee npm ...
                                    zigbee.0	2021-05-29 11:53:48.852	info	(22108) Try to reconnect. 1 attempts left
                                    Wenn ich in Terminal den Befehl eingebe, um zu schauen, ob er den Stick findet, kommt folgende Meldung:
                                    /opt/iobroker$ ls-la /dev/serial/by-id
                                    /bin/sh: 1: ls-la: not found
                                    Das ganze läuft über Proxmox und dort wird mir der USB-Stick angezeigt:
                                      @asgothian
                                      @smart_home
                                      ls -la
                                      man beachte das Leerzeichen
                                        @smart_home
                                        ls -la
                                        Smart_HomeS Offline
                                        Smart_HomeS Offline
                                        Smart_Home
                                        Sorry, mein Fehler :)
                                        Jetzt findet er ihn. Aber leider führt das nicht zur Lösung :-/
                                        C 1 Antwort Letzte Antwort
                                          ChristianG
                                          @smart_home Hallo @Smart_Home ,
                                          ich hatte das gleiche Problem nach dem Update. Habe zwei Tage gebraucht um es wieder ans laufen zu bekommen.
                                          Mein Lösung war es, den Adapter vom GitHub Link direkt drüber zu installieren und schon hatte er sich wieder verbunden.
                                          Liebe Grüße
                                          Chris
