  4. [Gelöst] Installation auf Raspi 3B schlägt immer wieder fehl
14 Beiträge 5 Kommentatoren 477 Aufrufe 4 Beobachtet
  • M Manuel001
    Ich habe schon 2 Raspberry Pi 2 mit IoBroker laufen. Jetzt wollte ich noch einen weiteren (Pi 3B) einrichten, aber ich scheitere daran.
    Folgendes habe ich gemacht:
    Raspberry Pi OS Lite Image installiert -> deutsche Tastatur, fixe IP und SSH eingestellt.
    Dann ->
    curl -sLf https://iobroker.net/install.sh | bash -
        Welcome to the ioBroker installer!
        Installer version: 2021-04-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
    Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.9 kB]
    Get:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0        MB]
    Get:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [376 kB]
    Fetched 13.4 MB in 16s (854 kB/s)
    Reading package lists... Done
        Node.js not found. Installing...
    ## Installing the NodeSource Node.js 12.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Rele        ase'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor |        tee /usr/share/keyrings/nodesource.gpg >/dev/null
    gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
    ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesourc        e.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodes        ource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Get:3 https://deb.nodesource.com/node_12.x buster InRelease [4584 B]
    Get:4 https://deb.nodesource.com/node_12.x buster/main armhf Packages [773 B]
    Fetched 5357 B in 2s (2219 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo te        e /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.co        m/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    Installed nodejs
    Node.js Installed successfully!
    Changing npm registry to https://registry.npmjs.org
    Installed acl
    Installed gcc-c++
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed git
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed python-dev
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:56,
                     from ../src/main.cpp:3:
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast betwe        en incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::        addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>,        void*)'} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion o        f macro 'NODE_MODULE_X'
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:770:3: note: in expansion of macro 'NODE_MODULE_X'
    ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /home/pi/.cache/node-gyp/12.22.1/include/node/node.h:736:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
    ../src/serialport.cpp:486:1: note: in expansion of macro 'NODE_MODULE'
     NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function 'int setup(int, OpenBaton*)':
    ../src/serialport_unix.cpp:176:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: 'snprintf' output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function 'void EIO_Open(uv_work_t*)':
    ../src/serialport_unix.cpp:86:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: 'snprintf' output 22 or more bytes (assuming 1045) into a destination of size 1024
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    Ich habe es 2x versucht und immer mit dem gleichen Ergebnis.
    Beim 1. Versuch habe ich vorher noch Nodejs installiert.
    Vor dem 2. Versuch habe ich wieder mit dem frischen Image angefangt.
    Irgend jemand eine Idee, was ich falsch mache?
    UncleSamU Offline
    UncleSamU Offline
    UncleSam
    @manuel001 Gibt es einen Grund, dass du nicht das fertige Image nimmst? (oder ist das nicht für Pi3?)
    https://www.iobroker.net/#en/download
    Ansonsten: ja, was @Thomas-Braun schon sagt: ich sehe keinen Fehler und du sagst auch nicht, was schief geht, ausser dass du "scheiterst".
    Und wenn er immer am gleichen Ort abbricht: Spannungs- oder SD-Karten-Problem?
    Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
    ♡-lichen Dank an meine Sponsoren
    • M Manuel001
      Die Meldungen ab Zeile 102 sind also normal?
      Der letzte Teil ab Zeile 189 war gelb hinterlegt. Danach ist nichts mehr gekommen.
      Also kein Schritt 4/4.
      Ich habe mich jetzt nochmal mit SSH verbunden und das probiert:
      pi@ioBrokerWallbox:~ $ ps -A | grep iobroker
      pi@ioBrokerWallbox:~ $ cd /opt/iobroker
      pi@ioBrokerWallbox:/opt/iobroker $ iobroker start
      -bash: iobroker: command not found
      Dann habe ich nochmal curl -sLf https://iobroker.net/install.sh | bash - ausgeführt und es ist folgendes innerhalb von ein paar Sekunden durchgelaufen:
      Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
      Fetched 408 kB in 2s (185 kB/s)
      Installed gcc-c++
          Finalizing installation (4/4)
      Enabling autostart...
      Created symlink /etc/systemd/system/multi-user.target.wants/iobroker.service → /lib/systemd/system/iobroker.service.
      Autostart enabled!
          ioBroker was installed successfully
      Da dürfte irgendetwas gehängt sein. Aber jetzt funktioniert es!
      @manuel001 sagte in Installation auf Raspberry Pi 3B schlägt immer wieder fehl:
      Ja, das ist die Kompilierung von serialport. Das sieht immer so 'schräg' aus.
      • UncleSamU UncleSam
        Manuel001
        @unclesam
        Naja. Das fertige Image hätte ich zwischen Versuch 1 und Versuch 2 probiert.
        Da bin ich aber daran gescheitert, dass es keine Konsolenausgabe über HDMI gab (SSH hat funktioniert) und ich konnte keine fixe IP einstellen.
        Das habe ich hier rein geschrieben: https://forum.iobroker.net/topic/41520/test-image-raspberry-pi-os-v1-0-0/52
          Manuel001
          Ah ok danke. Irgendwie hat das für mich als Laie nicht so normal ausgeschaut. Vor allem, weil es danach gehängt ist.
          • M Manuel001
            HomoranH Offline
            HomoranH Offline
            danach kommt eine längere Zeit eine Aktion im Hintergrund.
            Die dauert.
            Danach geht's schon weiter!
              Die dauert.
              Manuel001
              Dann war ich wohl zu ungeduldig.
              Es hat für mich einfach nach Fehler ausgeschaut, wenn die halbe Seite mit Gelb hinterlegt ist.
              • M Manuel001
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @manuel001 sagte in [Gelöst] Installation auf Raspi 3B schlägt immer wieder fehl:
                Dann hast du die gelbe Meldung wohl nicht gelesen :)
                Die müsste dir nämlich etwas zum integrierten error reporting erklären.
                • AlCalzoneA AlCalzone
                  Manuel001
                  @alcalzone
                  Wenn da mehrmals ""Error: %s, cannot open %s", strerror(errno), data->path)" steht, sieht das für mich als Laie so aus, wie wenn da etwas nicht funktioniert hat.
                  • M Manuel001
                    @alcalzone
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @manuel001 Touché
                    Ich erinnere mich allerdings nur an eine längere Pause bei der Installation, vor der ebenfalls in gelbem Text fast Vollbild erklärt wird, wie man die Fehlerberichterstattung abschalten kann.
                      @manuel001 Touché
                      Manuel001
                      @alcalzone
                      Ja das war eh diese Meldung. (habe ich mir erst später genauer gelesen)
                      Aber sind die Zeilen mit "Error: %s, cannot open %s", strerror(errno), data->path)" normal bzw. können ignoriert werden?
                      • M Manuel001
                        @alcalzone
                        @manuel001
                        Ja. Das ist harmlos.
