  4. Aeotec Gen5 nicht "Connected"
    6.8k
31 Beiträge 3 Kommentatoren 3.6k Aufrufe 3 Beobachtet
    @christian-bock-skole
    Bitte in CodeTags
    c0c68552-9cdf-403f-939d-4f0ace65bd47-image.png eingebettet posten.
    Danke.
    Christian Bock SkoleC Offline
    So?
    Bin neu in diesen Sachen...
    zB
    javascript.0 2021-05-20 19:40:00.002 warn (2237) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
    • Christian Bock SkoleC Christian Bock Skole
      So?
      zB
      Ja, das kann man wesentlich besser lesen. Kannst du in einen vorherigen Beiträgen noch ergänzen.
        @christian-bock-skole sagte in Aeotec Gen5 nicht "Connected":
        Wo soll ich nach device node suchen?
        Das ist nicht das Ende von
        dmesg -T
        Christian Bock SkoleC 1 Antwort Letzte Antwort
          dmesg -T
          @thomas-braun said in Aeotec Gen5 nicht "Connected":
          dmesg -T
          Tut mir leid, aber ich weiss nicht wo ich suchen soll...
          iobroker@iobroker-pi:~ $ dmesg -T
          [Thu May 20 13:56:41 2021] Booting Linux on physical CPU 0x0
          [Thu May 20 13:56:41 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
          [Thu May 20 13:56:41 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
          [Thu May 20 13:56:41 2021] CPU: div instructions available: patching division code
          [Thu May 20 13:56:41 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
          [Thu May 20 13:56:41 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
          [Thu May 20 13:56:41 2021] Memory policy: Data cache writealloc
          [Thu May 20 13:56:41 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
          [Thu May 20 13:56:41 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
          [Thu May 20 13:56:41 2021] Zone ranges:
          [Thu May 20 13:56:41 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
          [Thu May 20 13:56:41 2021]   Normal   empty
          [Thu May 20 13:56:41 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
          [Thu May 20 13:56:41 2021] Movable zone start for each node
          [Thu May 20 13:56:41 2021] Early memory node ranges
          [Thu May 20 13:56:41 2021]   node   0: [mem 0x0000000000000000-0x000000003e5fffff]
          [Thu May 20 13:56:41 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
          [Thu May 20 13:56:41 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
          [Thu May 20 13:56:41 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
          [Thu May 20 13:56:41 2021] On node 0 totalpages: 2074112
          [Thu May 20 13:56:41 2021]   DMA zone: 2304 pages used for memmap
          [Thu May 20 13:56:41 2021]   DMA zone: 0 pages reserved
          [Thu May 20 13:56:41 2021]   DMA zone: 196608 pages, LIFO batch:63
          [Thu May 20 13:56:41 2021]   HighMem zone: 1877504 pages, LIFO batch:63
          [Thu May 20 13:56:41 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
          [Thu May 20 13:56:41 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
          [Thu May 20 13:56:41 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Thu May 20 13:56:41 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2071808
          [Thu May 20 13:56:41 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D7:19:36 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=db2e8953-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Thu May 20 13:56:41 2021] Kernel parameter elevator= does not have any effect anymore.
                                     Please use sysfs to set IO scheduler for individual devices.
          [Thu May 20 13:56:41 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
          [Thu May 20 13:56:41 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [Thu May 20 13:56:41 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
          [Thu May 20 13:56:41 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
          [Thu May 20 13:56:41 2021] Memory: 7850668K/8296448K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183636K reserved, 262144K cma-reserved, 7510016K highmem)
          [Thu May 20 13:56:41 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [Thu May 20 13:56:41 2021] ftrace: allocating 33942 entries in 67 pages
          [Thu May 20 13:56:41 2021] ftrace: allocated 67 pages with 3 groups
          [Thu May 20 13:56:41 2021] rcu: Hierarchical RCU implementation.
          [Thu May 20 13:56:41 2021]      Rude variant of Tasks RCU enabled.
          [Thu May 20 13:56:41 2021]      Tracing variant of Tasks RCU enabled.
          [Thu May 20 13:56:41 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
          [Thu May 20 13:56:41 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
          [Thu May 20 13:56:41 2021] GIC: Using split EOI/Deactivate mode
          [Thu May 20 13:56:41 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
          [Thu May 20 13:56:41 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
          [Thu May 20 13:56:41 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
          [Thu May 20 13:56:41 2021] bcm2835: system timer (irq = 25)
          [Thu May 20 13:56:41 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [Thu May 20 13:56:41 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [Thu May 20 13:56:41 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
          [Thu May 20 13:56:41 2021] Switching to timer-based delay loop, resolution 18ns
          [Thu May 20 13:56:41 2021] Console: colour dummy device 80x30
          [Thu May 20 13:56:41 2021] printk: console [tty1] enabled
          [Thu May 20 13:56:41 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
          [Thu May 20 13:56:41 2021] pid_max: default: 32768 minimum: 301
          [Thu May 20 13:56:41 2021] LSM: Security Framework initializing
          [Thu May 20 13:56:41 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Thu May 20 13:56:41 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Thu May 20 13:56:41 2021] Disabling memory control group subsystem
          [Thu May 20 13:56:41 2021] CPU: Testing write buffer coherency: ok
          [Thu May 20 13:56:41 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [Thu May 20 13:56:41 2021] Setting up static identity map for 0x200000 - 0x20003c
          [Thu May 20 13:56:41 2021] rcu: Hierarchical SRCU implementation.
          [Thu May 20 13:56:41 2021] smp: Bringing up secondary CPUs ...
          [Thu May 20 13:56:41 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [Thu May 20 13:56:41 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
          [Thu May 20 13:56:41 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
          [Thu May 20 13:56:41 2021] smp: Brought up 1 node, 4 CPUs
          [Thu May 20 13:56:41 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
          [Thu May 20 13:56:41 2021] CPU: All CPU(s) started in HYP mode.
          [Thu May 20 13:56:41 2021] CPU: Virtualization extensions available.
          [Thu May 20 13:56:41 2021] devtmpfs: initialized
          [Thu May 20 13:56:41 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
          [Thu May 20 13:56:41 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [Thu May 20 13:56:41 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [Thu May 20 13:56:41 2021] pinctrl core: initialized pinctrl subsystem
          [Thu May 20 13:56:41 2021] NET: Registered protocol family 16
          [Thu May 20 13:56:41 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
          [Thu May 20 13:56:41 2021] audit: initializing netlink subsys (disabled)
          [Thu May 20 13:56:41 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
          [Thu May 20 13:56:41 2021] thermal_sys: Registered thermal governor 'step_wise'
          [Thu May 20 13:56:41 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
          [Thu May 20 13:56:41 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
          [Thu May 20 13:56:41 2021] Serial: AMBA PL011 UART driver
          [Thu May 20 13:56:41 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [Thu May 20 13:56:41 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:56, variant start_cd
          [Thu May 20 13:56:41 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
          [Thu May 20 13:56:41 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
          [Thu May 20 13:56:41 2021] vgaarb: loaded
          [Thu May 20 13:56:41 2021] SCSI subsystem initialized
          [Thu May 20 13:56:41 2021] usbcore: registered new interface driver usbfs
          [Thu May 20 13:56:41 2021] usbcore: registered new interface driver hub
          [Thu May 20 13:56:41 2021] usbcore: registered new device driver usb
          [Thu May 20 13:56:41 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
          [Thu May 20 13:56:41 2021] clocksource: Switched to clocksource arch_sys_counter
          [Thu May 20 13:56:42 2021] VFS: Disk quotas dquot_6.6.0
          [Thu May 20 13:56:42 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
          [Thu May 20 13:56:42 2021] FS-Cache: Loaded
          [Thu May 20 13:56:42 2021] CacheFiles: Loaded
          [Thu May 20 13:56:42 2021] NET: Registered protocol family 2
          [Thu May 20 13:56:42 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
          [Thu May 20 13:56:42 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
          [Thu May 20 13:56:42 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Thu May 20 13:56:42 2021] TCP: Hash tables configured (established 8192 bind 8192)
          [Thu May 20 13:56:42 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Thu May 20 13:56:42 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Thu May 20 13:56:42 2021] NET: Registered protocol family 1
          [Thu May 20 13:56:42 2021] RPC: Registered named UNIX socket transport module.
          [Thu May 20 13:56:42 2021] RPC: Registered udp transport module.
          [Thu May 20 13:56:42 2021] RPC: Registered tcp transport module.
          [Thu May 20 13:56:42 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Thu May 20 13:56:42 2021] PCI: CLS 0 bytes, default 64
          [Thu May 20 13:56:42 2021] Initialise system trusted keyrings
          [Thu May 20 13:56:42 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
          [Thu May 20 13:56:42 2021] zbud: loaded
          [Thu May 20 13:56:42 2021] FS-Cache: Netfs 'nfs' registered for caching
          [Thu May 20 13:56:42 2021] NFS: Registering the id_resolver key type
          [Thu May 20 13:56:42 2021] Key type id_resolver registered
          [Thu May 20 13:56:42 2021] Key type id_legacy registered
          [Thu May 20 13:56:42 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Thu May 20 13:56:42 2021] Key type asymmetric registered
          [Thu May 20 13:56:42 2021] Asymmetric key parser 'x509' registered
          [Thu May 20 13:56:42 2021] bounce: pool size: 64 pages
          [Thu May 20 13:56:42 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
          [Thu May 20 13:56:42 2021] io scheduler mq-deadline registered
          [Thu May 20 13:56:42 2021] io scheduler kyber registered
          [Thu May 20 13:56:42 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [Thu May 20 13:56:42 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
          [Thu May 20 13:56:42 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
          [Thu May 20 13:56:42 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
          [Thu May 20 13:56:42 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [Thu May 20 13:56:42 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [Thu May 20 13:56:42 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
          [Thu May 20 13:56:42 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
          [Thu May 20 13:56:42 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [Thu May 20 13:56:42 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
          [Thu May 20 13:56:42 2021] PCI: bus0: Fast back to back transfers disabled
          [Thu May 20 13:56:42 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [Thu May 20 13:56:42 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [Thu May 20 13:56:42 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
          [Thu May 20 13:56:42 2021] PCI: bus1: Fast back to back transfers disabled
          [Thu May 20 13:56:42 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [Thu May 20 13:56:42 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
          [Thu May 20 13:56:42 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
          [Thu May 20 13:56:42 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [Thu May 20 13:56:42 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
          [Thu May 20 13:56:42 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
          [Thu May 20 13:56:42 2021] iproc-rng200 fe104000.rng: hwrng registered
          [Thu May 20 13:56:42 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_size:0x3f600000(1014 MiB)
          [Thu May 20 13:56:42 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
          [Thu May 20 13:56:42 2021] brd: module loaded
          [Thu May 20 13:56:42 2021] loop: module loaded
          [Thu May 20 13:56:42 2021] Loading iSCSI transport class v2.0-870.
          [Thu May 20 13:56:42 2021] libphy: Fixed MDIO Bus: probed
          [Thu May 20 13:56:42 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [Thu May 20 13:56:42 2021] libphy: bcmgenet MII bus: probed
          [Thu May 20 13:56:42 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [Thu May 20 13:56:42 2021] usbcore: registered new interface driver r8152
          [Thu May 20 13:56:42 2021] usbcore: registered new interface driver lan78xx
          [Thu May 20 13:56:42 2021] usbcore: registered new interface driver smsc95xx
          [Thu May 20 13:56:42 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [Thu May 20 13:56:42 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [Thu May 20 13:56:42 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
          [Thu May 20 13:56:42 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
          [Thu May 20 13:56:42 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Thu May 20 13:56:42 2021] usb usb1: Product: xHCI Host Controller
          [Thu May 20 13:56:42 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
          [Thu May 20 13:56:42 2021] usb usb1: SerialNumber: 0000:01:00.0
          [Thu May 20 13:56:42 2021] hub 1-0:1.0: USB hub found
          [Thu May 20 13:56:42 2021] hub 1-0:1.0: 1 port detected
          [Thu May 20 13:56:42 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [Thu May 20 13:56:42 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [Thu May 20 13:56:42 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
          [Thu May 20 13:56:42 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Thu May 20 13:56:42 2021] usb usb2: Product: xHCI Host Controller
          [Thu May 20 13:56:42 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
          [Thu May 20 13:56:42 2021] usb usb2: SerialNumber: 0000:01:00.0
          [Thu May 20 13:56:42 2021] hub 2-0:1.0: USB hub found
          [Thu May 20 13:56:42 2021] hub 2-0:1.0: 4 ports detected
          [Thu May 20 13:56:42 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Thu May 20 13:56:42 2021] dwc_otg: FIQ enabled
          [Thu May 20 13:56:42 2021] dwc_otg: NAK holdoff enabled
          [Thu May 20 13:56:42 2021] dwc_otg: FIQ split-transaction FSM enabled
          [Thu May 20 13:56:42 2021] Module dwc_common_port init
          [Thu May 20 13:56:42 2021] usbcore: registered new interface driver uas
          [Thu May 20 13:56:42 2021] usbcore: registered new interface driver usb-storage
          [Thu May 20 13:56:42 2021] mousedev: PS/2 mouse device common for all mice
          [Thu May 20 13:56:42 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Thu May 20 13:56:42 2021] sdhci: Secure Digital Host Controller Interface driver
          [Thu May 20 13:56:42 2021] sdhci: Copyright(c) Pierre Ossman
          [Thu May 20 13:56:42 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
          [Thu May 20 13:56:42 2021] sdhci-pltfm: SDHCI platform and OF driver helper
          [Thu May 20 13:56:42 2021] ledtrig-cpu: registered to indicate activity on CPUs
          [Thu May 20 13:56:42 2021] hid: raw HID events driver (C) Jiri Kosina
          [Thu May 20 13:56:42 2021] usbcore: registered new interface driver usbhid
          [Thu May 20 13:56:42 2021] usbhid: USB HID core driver
          [Thu May 20 13:56:42 2021] Initializing XFRM netlink socket
          [Thu May 20 13:56:42 2021] NET: Registered protocol family 17
          [Thu May 20 13:56:42 2021] Key type dns_resolver registered
          [Thu May 20 13:56:42 2021] Registering SWP/SWPB emulation handler
          [Thu May 20 13:56:42 2021] registered taskstats version 1
          [Thu May 20 13:56:42 2021] Loading compiled-in X.509 certificates
          [Thu May 20 13:56:42 2021] Key type ._fscrypt registered
          [Thu May 20 13:56:42 2021] Key type .fscrypt registered
          [Thu May 20 13:56:42 2021] Key type fscrypt-provisioning registered
          [Thu May 20 13:56:42 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
          [Thu May 20 13:56:42 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [Thu May 20 13:56:42 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
          [Thu May 20 13:56:42 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Thu May 20 13:56:42 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Thu May 20 13:56:42 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [Thu May 20 13:56:42 2021] of_cfs_init
          [Thu May 20 13:56:42 2021] of_cfs_init: OK
          [Thu May 20 13:56:42 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
          [Thu May 20 13:56:42 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [Thu May 20 13:56:42 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
          [Thu May 20 13:56:42 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
          [Thu May 20 13:56:42 2021] Waiting for root device PARTUUID=db2e8953-02...
          [Thu May 20 13:56:42 2021] random: fast init done
          [Thu May 20 13:56:42 2021] mmc1: new high speed SDIO card at address 0001
          [Thu May 20 13:56:42 2021] mmc0: new ultra high speed DDR50 SDHC card at address 5048
          [Thu May 20 13:56:42 2021] mmcblk0: mmc0:5048 SDCHE 29.2 GiB
          [Thu May 20 13:56:42 2021]  mmcblk0: p1 p2
          [Thu May 20 13:56:42 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu May 20 13:56:42 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu May 20 13:56:42 2021] devtmpfs: mounted
          [Thu May 20 13:56:42 2021] Freeing unused kernel memory: 2048K
          [Thu May 20 13:56:42 2021] Run /sbin/init as init process
          [Thu May 20 13:56:42 2021]   with arguments:
          [Thu May 20 13:56:42 2021]     /sbin/init
          [Thu May 20 13:56:42 2021]   with environment:
          [Thu May 20 13:56:42 2021]     HOME=/
          [Thu May 20 13:56:42 2021]     TERM=linux
          [Thu May 20 13:56:42 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [Thu May 20 13:56:43 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [Thu May 20 13:56:43 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Thu May 20 13:56:43 2021] usb 1-1: Product: USB2.0 Hub
          [Thu May 20 13:56:43 2021] hub 1-1:1.0: USB hub found
          [Thu May 20 13:56:43 2021] hub 1-1:1.0: 4 ports detected
          [Thu May 20 13:56:43 2021] systemd[1]: System time before build time, advancing clock.
          [Thu May 20 13:56:43 2021] NET: Registered protocol family 10
          [Thu May 20 13:56:43 2021] Segment Routing with IPv6
          [Thu May 20 13:56:43 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
          [Thu May 20 13:56:43 2021] systemd[1]: Detected architecture arm.
          [Thu May 20 13:56:43 2021] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
          [Thu May 20 13:56:43 2021] systemd[1]: Set hostname to <iobroker-pi>.
          [Thu May 20 13:56:43 2021] usb 1-1.4: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
          [Thu May 20 13:56:43 2021] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [Thu May 20 13:56:43 2021] usb 1-1.4: Product: ConBee II
          [Thu May 20 13:56:43 2021] usb 1-1.4: Manufacturer: dresden elektronik ingenieurtechnik GmbH
          [Thu May 20 13:56:43 2021] usb 1-1.4: SerialNumber: DE2148335
          [Thu May 20 13:56:43 2021] systemd-sysv-generator[104]: Overwriting existing symlink /run/systemd/generator.late/iobroker.service with real service.
          [Thu May 20 13:56:44 2021] random: systemd: uninitialized urandom read (16 bytes read)
          [Thu May 20 13:56:44 2021] systemd[1]: Listening on Journal Socket.
          [Thu May 20 13:56:44 2021] systemd[1]: Created slice system-getty.slice.
          [Thu May 20 13:56:44 2021] systemd[1]: Listening on udev Control Socket.
          [Thu May 20 13:56:44 2021] systemd[1]: Listening on Journal Socket (/dev/log).
          [Thu May 20 13:56:44 2021] systemd[1]: Starting Create list of required static device nodes for the current kernel...
          [Thu May 20 13:56:44 2021] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
          [Thu May 20 13:56:44 2021] systemd[1]: Listening on udev Kernel Socket.
          [Thu May 20 13:56:44 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          [Thu May 20 13:56:44 2021] systemd-journald[112]: Received request to flush runtime journal from PID 1
          [Thu May 20 13:56:45 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
          [Thu May 20 13:56:45 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
          [Thu May 20 13:56:45 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
          [Thu May 20 13:56:45 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
          [Thu May 20 13:56:45 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu May 20 13:56:45 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Thu May 20 13:56:45 2021] [vc_sm_connected_init]: start
          [Thu May 20 13:56:45 2021] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
          [Thu May 20 13:56:45 2021] [vc_sm_connected_init]: failed to initialize shared memory service
          [Thu May 20 13:56:45 2021] mc: Linux media interface: v0.10
          [Thu May 20 13:56:45 2021] videodev: Linux video capture interface: v2.00
          [Thu May 20 13:56:45 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu May 20 13:56:45 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu May 20 13:56:45 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
          [Thu May 20 13:56:45 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu May 20 13:56:45 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu May 20 13:56:45 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu May 20 13:56:45 2021] bcm2835_mmal_vchiq: Failed to open VCHI service connection (status=-1)
          [Thu May 20 13:56:45 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Thu May 20 13:56:45 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Thu May 20 13:56:45 2021] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
          [Thu May 20 13:56:45 2021] usbcore: registered new interface driver cdc_acm
          [Thu May 20 13:56:45 2021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
          [Thu May 20 13:56:45 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
          [Thu May 20 13:56:45 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Thu May 20 13:56:45 2021] usbcore: registered new interface driver brcmfmac
          [Thu May 20 13:56:45 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
          [Thu May 20 13:56:45 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
          [Thu May 20 13:56:45 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
          [Thu May 20 13:56:45 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
          [Thu May 20 13:56:45 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
          [Thu May 20 13:56:46 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Thu May 20 13:56:46 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
          [Thu May 20 13:56:48 2021] uart-pl011 fe201000.serial: no DMA platform data
          [Thu May 20 13:56:48 2021] random: crng init done
          [Thu May 20 13:56:48 2021] random: 7 urandom warning(s) missed due to ratelimiting
          [Thu May 20 13:56:48 2021] 8021q: 802.1Q VLAN Support v1.8
          [Thu May 20 13:56:48 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
          [Thu May 20 13:56:48 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
          [Thu May 20 13:56:48 2021] bcmgenet fd580000.ethernet eth0: Link is Down
          [Thu May 20 13:56:53 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
          [Thu May 20 13:56:53 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [Thu May 20 13:56:54 2021] Bluetooth: Core ver 2.22
          [Thu May 20 13:56:54 2021] NET: Registered protocol family 31
          [Thu May 20 13:56:54 2021] Bluetooth: HCI device and connection manager initialized
          [Thu May 20 13:56:54 2021] Bluetooth: HCI socket layer initialized
          [Thu May 20 13:56:54 2021] Bluetooth: L2CAP socket layer initialized
          [Thu May 20 13:56:54 2021] Bluetooth: SCO socket layer initialized
          [Thu May 20 13:56:54 2021] Bluetooth: HCI UART driver ver 2.3
          [Thu May 20 13:56:54 2021] Bluetooth: HCI UART protocol H4 registered
          [Thu May 20 13:56:54 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Thu May 20 13:56:54 2021] Bluetooth: HCI UART protocol Broadcom registered
          [Thu May 20 13:56:55 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Thu May 20 13:56:55 2021] Bluetooth: BNEP filters: protocol multicast
          [Thu May 20 13:56:55 2021] Bluetooth: BNEP socket layer initialized
            dmesg -T
            ttyACM0
            Das dürfte dein Device sein. Also /dev/ttyACM0 im Adapter angeben.
            [Edit:] Könnte auch der ConBee II sein.
            Gib mal die Ausgabe von
            lsusb
            Am Rande: Halt dein Betriebssystem auf Stand. Da ist vermutlich länger kein Update mehr gelaufen.
              ttyACM0
              lsusb
              schrieb am zuletzt editiert von Christian Bock Skole
              lsusb
              iobroker@iobroker-pi:~ $ lsusb
              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
              Bus 001 Device 003: ID 1cf1:0030 Dresden Elektronik
              Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
              Sind das die 4 USBs?
                lsusb
                Jein. Das sind die beiden USB3.0-Ports, dein Zigbee-Stick, der USB-Controller, die beiden USB2.0-Ports.
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  https://www.raspberrypi.org/forums/viewtopic.php?t=245031
                  Den Stick musst du an einem externen USB 2.0-Hub betreiben, sonst wird das nix.
                  Stattdessen würde ich dir aber raten, lieber einen brandaktuellen 700er Stick zu kaufen, die sind auch recht günstig:
                  z.B. https://www.mouser.de/ProductDetail/Silicon-Labs/SLUSB001A?qs=u16ybLDytRbJsMfgk3EnSA==
                  • AlCalzoneA AlCalzone
                    @alcalzone
                    Arrrrgh! Da kann man ja lange dmesgn, rum lsusb'en oder was auch immer, wenn das Ding so 'krumm' ist.
                      @alcalzone
                      @thomas-braun @AlCalzone
                      danke euch beide für eure mühe
                      Dann muss ich sehen was ich kaufen kann. Mein Plan war dieses als Unterricht in der Berufsschule in der ich arbeite zu machen (Norwegen). Finde hier fast nur den Aeotec.
                      Ist es aber so, das es wenn ich ein USB2 hub dazwischen stecke, das es dann klappt?
                      Thomas BraunT AlCalzoneA 2 Antworten Letzte Antwort
                        @christian-bock-skole Liest sich so. Wenn man den Einträgen glauben darf dann wurden da grob die USB-Specs missachtet, bei USB2.0 ist das aber wohl nicht so wild.
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          Da muss es aber mindestens den Gen5+ geben, oder?
                          Sollte - wenn den das verkorkste Verhalten nicht stört.
                            @alcalzone
                            Unglaublich..... Es steht ein Hinweis in einem Geschäft, das man ihn nur mit einem USB2 hub an Rpi4 anschliessen kann...hatten nicht den +
                            Hab sonnst nichts mit zwave bei https://no.rs-online.com/web/ oder https://www.elfadistrelec.no/ gefunden. Sind doch grosse Firmen von denen wir sonnst viel kaufen
                              @alcalzone
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @christian-bock-skole Ich hör mich mal um - da muss es doch Möglichkeiten geben, an was gescheites zu kommen.
                              Edit: Was ist hiermit? https://no.mouser.com/ProductDetail/Silicon-Labs/SLUSB001A?qs=u16ybLDytRbJsMfgk3EnSA==
                                @alcalzone
                                Ich untersuche ob das geht. Staatliches einkaufsystem in den Schulen. Mouser hat Adresse in Schweden...
                                  @alcalzone
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  Ahh, die gute alte Bürokratie... Bei uns geht sowas dann meistens mit ner guten Begründung trotzdem.
