  4. tedee Smartlock über Homebridge Adapter
    5.2k
tedeesmartlockhomebridge
36 Beiträge 14 Kommentatoren 7.9k Aufrufe 15 Beobachtet
  • R Robbi12
    @mrMuppet said in [SOLVED] tedee Smartlock über Homebridge Adapter:
    homebridge-tedee
    Danke. Es klappt einfach nicht. Hier der LOG
    2020-11-24 20:11:12.174 - info: host.raspberrypi "system.adapter.ham.0" enabled
    2020-11-24 20:11:12.212 - info: host.raspberrypi instance system.adapter.ham.0 started with pid 8073
    2020-11-24 20:11:13.471 - info: ham.0 (8073) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.ham, node: v12.19.1, js-controller: 3.1.6
    2020-11-24 20:11:13.502 - info: ham.0 (8073) Install/Update the following Libraries: homebridge-tedee
    2020-11-24 20:11:13.503 - info: ham.0 (8073) Install/Update homebridge-tedee
    2020-11-24 20:11:13.505 - info: ham.0 (8073) npm install homebridge-tedee --production --loglevel error (System call)
    2020-11-24 20:11:17.923 - info: ham.0 (8073) + homebridge-tedee@0.2.0
    added 7 packages from 9 contributors and audited 7 packages in 3.046s
    2020-11-24 20:11:17.939 - info: ham.0 (8073)
    1 package is looking for funding
    run npm fund for details
    2020-11-24 20:11:17.941 - info: ham.0 (8073) found 0 vulnerabilities
    2020-11-24 20:11:17.968 - info: ham.0 (8073) All Libraries installed/updated
    2020-11-24 20:11:25.102 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-11-24 20:11:25.103 - error: ham.0 (8073) unhandled promise rejection: Request failed with status code 400
    2020-11-24 20:11:25.104 - error: ham.0 (8073) Error: Request failed with status code 400
    at createError (/opt/iobroker/node_modules/iobroker.ham/node_modules/axios/lib/core/createError.js:16:15)
    at settle (/opt/iobroker/node_modules/iobroker.ham/node_modules/axios/lib/core/settle.js:17:12)
    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.ham/node_modules/axios/lib/adapters/http.js:236:11)
    at IncomingMessage.emit (events.js:326:22)
    at endReadableNT (_stream_readable.js:1223:12)
    at processTicksAndRejections (internal/process/task_queues.js:84:21)
    2020-11-24 20:11:25.105 - info: ham.0 (8073) cleaned everything up...
    2020-11-24 20:11:25.124 - info: ham.0 (8073) terminating
    2020-11-24 20:11:25.125 - info: ham.0 (8073) Terminated (NO_ERROR): Without reason
    2020-11-24 20:11:25.656 - error: host.raspberrypi Caught by controller[0]: [2020-11-24 20:11:19] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-framework package.json does not contain the keyword 'homebridge-plugin'.
    2020-11-24 20:11:25.657 - error: host.raspberrypi Caught by controller[1]: [2020-11-24 20:11:19] Plugin /opt/iobroker/node_modules/homebridge-framework package.json does not contain the keyword 'homebridge-plugin'.
    2020-11-24 20:11:25.657 - error: host.raspberrypi Caught by controller[2]: [2020-11-24 20:11:19] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
    2020-11-24 20:11:25.658 - error: host.raspberrypi Caught by controller[3]: [2020-11-24 20:11:19] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-tedee' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tedee'.
    2020-11-24 20:11:25.658 - error: host.raspberrypi Caught by controller[4]: [2020-11-24 20:11:19] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-tedee' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tedee'.
    2020-11-24 20:11:25.658 - error: host.raspberrypi Caught by controller[5]: [2020-11-24 20:11:19] [TedeePlatform] Error while retrieving access token: Error: Request failed with status code 400
    2020-11-24 20:11:25.658 - error: host.raspberrypi Caught by controller[6]: [2020-11-24 20:11:22] [TedeePlatform] Error while retrieving access token: Error: Request failed with status code 400
    2020-11-24 20:11:25.659 - error: host.raspberrypi Caught by controller[7]: [2020-11-24 20:11:25] [TedeePlatform] Error while retrieving access token: Error: Request failed with status code 400
    2020-11-24 20:11:25.659 - info: host.raspberrypi instance system.adapter.ham.0 terminated with code 0 (NO_ERROR)
    2020-11-24 20:11:25.660 - info: host.raspberrypi Restart adapter system.adapter.ham.0 because enabled
    mrMuppet
    @Robbi12 Tut mir leid, da hab ich leider auch keine Idee. Bei mir haben Tedee und nest-cam mit der richtigen Konfigdatei direkt funktioniert.
    Ich nehme mal das SOLVED aus dem Thread-Titel. Vielleicht lesen dann noch mehr Leute mit.
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • R Robbi12
      homebridge-tedee
      GoodOld
      schrieb am zuletzt editiert von GoodOld
      @Robbi12 Hi, hast du das hier auch gemacht?
      sudo npm install -g homebridge-tedee
      Weitere Infos :
      https://github.com/lukasroegner/homebridge-tedee
      R 2 Antworten Letzte Antwort
      • G GoodOld
        Weitere Infos :
        Robbi12
        @GoodOld said in tedee Smartlock über Homebridge Adapter:
        Danke. Ja habe ich gerade nochmals gemacht. Ich glaube meine Konfiguration stimmt nicht. Blick da nicht durch.
        Hab den Adapter installiert. homebridge-tedee auch. Da ist alles normal. Keine Fehlermeldung. Erst wenn ich die Konfigurationsdatei rein mache kommen die Fehler.
        Da mache ich sicher was falsch
        • G GoodOld
          Weitere Infos :
          Robbi12
          @GoodOld
          Hallo. Nun habe ich die Fehlermeldung los. Aber er legt keine Objekte an. Ansonsten läuft der Adapter grün.
          R 1 Antwort Letzte Antwort
          • R Robbi12
            @GoodOld
            Robbi12
            @Robbi12
            Mann oh Mann. Es war so einfach. Ein kleinster Fehler und große Wirkung mit ewiger Suche. Beim Namen in meinem Schloß in der App war nach dem letzten Buchstaben ein Leerzeichen reingekommen. Nicht zu sehen. So konnte es nicht angesprochen werden.
            G YodameisterY 2 Antworten Letzte Antwort
            • R Robbi12
              @Robbi12
              GoodOld
              @robbi12 kommt mir bekannt vor :)
              • R Robbi12
                @Robbi12
                YodameisterY Offline
                Yodameister
                schrieb am zuletzt editiert von Yodameister
                @robbi12 sagte in tedee Smartlock über Homebridge Adapter:
                @Robbi12
                @Robbi12
                Moin , aber ich verstehe das richtig , man benötigt das Schloß und die Tedee Bridge als Hardware ? oder entfällt die Bridge ?
                Maik
                A L 2 Antworten Letzte Antwort
                • YodameisterY Yodameister
                  @Robbi12
                  @Robbi12
                  Astradeck
                  Habe mein Tedee-Smartlock jetzt seit ein paar Tagen und bin soweit zufrieden.
                  Wollte mein Smartlock jetzt bei ioBroker anbinden. Habe den "Homebridge accessories manager" (HAM) installiert. Er läuft im Wrapper-Modus und unter "zusätzliche Module" hab ich das Modul "Homebridge-Tedee" eingetragen.
                  Mein Config sieht so aus:
                    "platforms": [
                        "platform": "TedeePlatform",
                        "emailAddress": "MEIN-TEDEE-Mail",
                        "password": "MEIN-TEDEE-Passwort",
                        "devices": [
                            "name": "Wohnungstuer",
                            "unlatchFromUnlockedToUnlocked": false,
                            "unlatchLock": true,
                            "disableUnlock": true,
                            "defaultLockName": "Lock",
                            "defaultLatchName": "Latch"
                        "updateInterval": 30
                  Wenn ich den Adapter starte, wechselt die Adapter-Anzeige von Grün auf Rot und im Log stehen dann folgende Fehler:
                  ham.0	2021-02-23 07:18:15.144	error	(22549) Cannot read property 'length' of undefined
                  ham.0	2021-02-23 07:18:15.144	error	at processImmediate (internal/timers.js:463:21)
                  ham.0	2021-02-23 07:18:15.144	error	at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
                  ham.0	2021-02-23 07:18:15.144	error	at /opt/iobroker/node_modules/iobroker.ham/main.js:276:39
                  ham.0	2021-02-23 07:18:15.144	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:109:23)
                  ham.0	2021-02-23 07:18:15.144	error	at HomebridgeWrapper.init (/opt/iobroker/node_modules/homebridge-plugin-wrapper/index.js:258:17)
                  ham.0	2021-02-23 07:18:15.144	error	at Server.start (/opt/iobroker/node_modules/homebridge-plugin-wrapper/homebridge/server.js:75:37)
                  ham.0	2021-02-23 07:18:15.144	error	(22549) TypeError: Cannot read property 'length' of undefined
                  ham.0	2021-02-23 07:18:15.143	error	(22549) unhandled promise rejection: Cannot read property 'length' of undefined
                  ham.0	2021-02-23 07:18:15.142	error	(22549) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  und dann
                  host.raspberrypi	2021-02-23 07:18:45.852	info	instance system.adapter.ham.0 started with pid 22596
                  host.raspberrypi	2021-02-23 07:18:15.780	info	Restart adapter system.adapter.ham.0 because enabled
                  host.raspberrypi	2021-02-23 07:18:15.780	error	instance system.adapter.ham.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  host.raspberrypi	2021-02-23 07:18:15.779	error	Caught by controller[5]: [2/23/2021, 07:18:13] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-tedee' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobr
                  host.raspberrypi	2021-02-23 07:18:15.779	error	Caught by controller[4]: [2/23/2021, 07:18:13] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-tedee' since we already loaded the same plugin from '/opt/iobroker/node_modules
                  host.raspberrypi	2021-02-23 07:18:15.778	error	Caught by controller[3]: [2/23/2021, 07:18:13] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                  host.raspberrypi	2021-02-23 07:18:15.778	error	Caught by controller[2]: [2/23/2021, 07:18:13] Plugin /opt/iobroker/node_modules/homebridge-framework package.json does not contain the keyword 'homebridge-plugin'.
                  host.raspberrypi	2021-02-23 07:18:15.778	error	Caught by controller[1]: [2/23/2021, 07:18:13] Warning: skipping plugin found at '/opt/iobroker/node_modules/homebridge-airrohr' since we already loaded the same plugin from '/opt/iobroker/node_modul
                  host.raspberrypi	2021-02-23 07:18:15.777	error	Caught by controller[0]: [2/23/2021, 07:18:13] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-framework package.json does not contain the keyword 'homebridge-plugin'.
                  ham.0	2021-02-23 07:18:15.168	warn	(22549) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  Ich habe testweise mal ein anderes NPM-Modul mit entsprechender Config getestet und da funktioniert alles - der Adapter bleibt grün und die Datenpunkte stehen unter Objekte. Also der HAM-Adapter und die NPM-Anbindung funktioniert im Grunde.
                  Habe dann mal den "Homebridge-Tedee" wieder eingetragen und die Config von mir rausgenommen. Auch dann läuft das HAM-Modul (bleibt also grün).
                  Und jetzt stehe ich etwas auf dem Schlauch und weiß nicht weiter. Hat einer von Euch eine Idee?
                  • A Astradeck
                      "platforms": [
                          "devices": [
                    und dann
                    Astradeck
                    Der Fehler lag vermutlich am "Wrapper-Modus"...
                    Ich habe gerade noch mal ein paar Sachen getestet und habe den HAM-Adapter im IOBroker von "Wrapper" auf "Lokaler Modus" umgestellt und jetzt läuft es.
                    Der HAM-Adapter läuft (ist grün) und die Datenpunkte werden erstellt.
                      @Robbi12
                      @Robbi12
                      Luc
                      @yodameister Hallo,
                      Bin gerade auch über den Kauf von einem tedee Schloss am grübeln wie ich diesen im ioBroker auf meinem docker buanet/ioBroker integriert bekomme ...
                      Meine Infrastruktur; (Habe Focus auf tedee Smartlock integration und die anderen Details weggelassen)
                      • Synology NAS mit docker image von buanet (Funktioniert über ein Jahr so wie ein normaler ioBroker)
                      • apple TV (4. Generation) die Apple Homekit kompatibel. (Etwa 8m weit weg um die Ecke ;-) )
                      • yahka instanz Ver 0.12.0
                      Gemäss HOW-TO hier in den Artikeln ist mir klar wie ich ioBroker konfigurieren muss, damit das Schloss integriert werden kann.
                      Folgende Fragen bleiben jedoch noch. (Eine hast du auch gestellt, jedoch habe ich keine Antwort im den Diskussionen gesehen)
                      1. Braucht man die Bridge von tedee um das tedee Schloss in ioBroker rein zu bekommen, oder hängt sich das Schloss "alleine" in homekit rein (Ohne tedee bridge) ?
                      2. Hatte heute ein Chat mit tedee die mich informierten, dass Homekit erst in ein paar Wochen mittels update im Schloss "nachgeschoben" wird. Sehe ich auch im Internet "... Polish smart lock manufacturer Tedee, who are incidentally in the process of adding HomeKit to their new smart lock ..." Nehme an, dass dies die spezifische Funktionalität des HomeBridge Adapters ist, "Nicht Homekit kompatibele" Geräte doch integrieren zu können?
                      3. Nehme an, dass ich mit HoemBridge den yahka nicht mehr benötige?
                      Sorry für die Länge :-( ...
                      Luc
                      L 1 Antwort Letzte Antwort
                      • L Luc
                        @yodameister Hallo,
                        Luc
                        Luc
                        Habe Antworten selber gefunden .... Glaube irgendetwas mache ich falsch ? 😕 Sehe nicht oft Antworten auf meine Posts ... oder jeder denkt .. Er wird es finden .. ;-) ... Falls einer sieht was bei meinen Posts nicht klappt, so bin ich offen etwas dazu zu lernen .. ;-)
                        • L Luc
                          mrMuppet
                          @luc Sorry, ich glaube du machst nichts falsch! Aber nicht immer sind genug User eines exotischen Adapters online. :-)
                          Ich könnte jetzt auch noch mal deine Fragen beantworten (dann hilft es vielleicht einem anderen /Suchfunktion)
                          1- die Bridge brauchst du trotzdem, sonst hast du keinen Zugang zur API etc. - Das Schloß selbst kommuniziert nur über Bluetooth
                          2- Homebridge ist eigentlich dazu gedacht Geräte ohne Homekit-unterstützung kompatibel mit Homekit zu machen. Das IOBroker das nutzen kann ist ein schöner Nebeneffekt.
                          3- brauchst du nicht mehr.
                          • M mrMuppet
                            Luc
                            @mrmuppet Hallo "Muppet" ;-) ...
                            Vielen Dank für die Antwort ... Sorry für meine längere Zeit zum Antworten .. Bin auf mein tedee Schloss inklusive Bridge am warten .. somit aktuell ein "bisschen" weniger aktiv ... So wie alles angekommen ist, so werde ich mein Glück versuchen. Super Arbeit an alle die hier mithelfen. Berauschend wir ioBroker so mit allen Adaptern zusammen arbeiten kann!
                            Vielen Dank auch für die Bestätigung, dass ich mein Post hier "richtig" abgesetzt habe .... Einfach super so auf der ganzen Welt verteilt miteinander arbeiten zu können ..
                            Alles Gute so weit aus Luxemburg,
                            Luc
                            • L Offline
                              LotharF
                              Hab mein tedee Türschloss über die Bridge mittlerweile seit einiger Zeit erfolgreich am laufen und nutze auch RFID um die Tür öffnen zu können 😊
                              Gestern hatten wir nun einen Internetausfall und plötzlich war die Bridge nicht mehr verbunden / erreichbar und es war keine Steuerung vom Schloss über die Bridge per ioBroker mehr möglich 😕
                              Ich vermute mal, dass die Bridge auch immer "nach Hause telefoniert" und ohne Internet dann die Funktion einfach eingestellt hat.
                              Kann das jemand bestätigen oder gibt es eine Möglichkeit, auch ohne Internet über die Bridge das Schloss per ioBroker zu steuern?
                              • L LotharF
                                Robbi12
                                @lotharf Hallo. Welchen RFID hast du und wie hast den integriert?
                                • L Offline
                                  LotharF
                                  schrieb am zuletzt editiert von LotharF
                                  Ich hab einen RC522 am ESP8266 angeschlossen. Dazu habe ich dann die Tasmota SW mit den benötigten Sachen neu compiliert (Link).
                                  Die eingelesenen RFID-Codes werte ich dann per Blockly aus und lasse dann über die tedee Bridge das Schloss steuern :-)
                                  • L LotharF
                                    tilly001
                                    @lotharf
                                    Hallo Lotharf,
                                    ich habe in Iobroker den Homebride Adaper mit allen Datenpunkten lauffähig.
                                    Kannst du mir mal auf die Sprünge helfen wie ich z.B. den von dir genannten RFID Reader dazu bringe das Schloss zu öffnen?
                                    Ich komme einfach nicht weiter ;-(
                                    Gruß Stefan
                                    • T tilly001
                                      @lotharf
                                      Hallo Lotharf,
                                      Gruß Stefan
                                      LotharF
                                      Das ist eigentlich recht simpel. Voraussetzung ist nur, dass du das tedee über den ioBroker öffnen kannst ;-) (tedee öffnen)
                                      Dann brauchst du noch die tedee Bridge damit du überhaupt per ioBroker auf das Schloss zugreifen kannst.
                                      Ich habe einen ESP8266 mit tasmota und angeschlossenem RFID ... der sich im gleichen Netz / WLAN befindet wie die tedee Bridge. Das Teil habe ich "Klingelmodul" genannt da ich hier noch andere Sachen mit mache.
                                      An mein ESP8266 "Klingelmodul" habe ich dann noch einen 5VSummer angeschlossen der dann über "Power2" geteuert wird. So habe ich draußen eine akustische Rückmeldung, ob der Chip erkannt wurde oder nicht.
                                      Den ESP8266 findest du dann ja unter den Objekten im ioBroker bei den Sonoff Sachen. Da habe ich dann u.A. den Eintrag "RC522_UID". Sobald ich dann einen RFID Chip vor den Sensor halte, wird hier der Code vom Chip angezeigt.
                                      Den da angezeigten Wert werte ich dann per Script aus ... und steuere das tedee je nach Status (AUF / ZU / Türfalle).
                                        Astradeck
                                        schrieb am zuletzt editiert von Astradeck
                                        Ich muss den alten Thread nochmal beleben....
                                        [Fehler gefunden - siehe unten]
                                        Mir ist gerade aufgefallen, dass meine Tedee-Objekte im HAM nicht mehr aktualisiert werden - so wie ich das gesehen habe, seit war die letzte Aktualisierung Anfang Februar.
                                        Bisher hat alles super funktioniert ... aber jetzt leider nicht mehr.
                                        Habe den HAM im ioBroker auch nochmal komplett gelöscht und neu installiert und "homebridge-tedee" neu eingerichtet. Leider werden die Infos zum Tedee-Schloss nicht mehr als Objekt angezeigt...
                                        Hat jemand von Euch das gleiche Problem?
                                        [Fehlerbehebung]
                                        Ich habe vor einiger Zeit mal mein Schloss in der meiner Tedee-App neu einrichten müssen und dabei habe ich den Namen des Schlosses nicht mehr so genannt, wie vorher. Habe jetzt das Schloss in der App in den alten Namen umbenannt und schon wurde wieder alles aktualisiert!
                                          Schimi
                                          Hat jemand auch das Keypad eimgebunden?
                                          Wäre es moglich nen Screenshot von den Objekten zu erhalten?
                                          Holger76H 1 Antwort Letzte Antwort
