  4. Node-Red
  5. String aufteilen
    6.5k
String aufteilen
141 Beiträge 3 Kommentatoren 21.5k Aufrufe 2 Beobachtet
  • H hafo
    @mickym Hier das inject
           "id": "5a297e8e.abb9d8",
           "type": "inject",
           "z": "f70e8494.8c2a98",
           "name": "Payload",
           "props": [
                   "p": "payload"
                   "p": "min",
                   "v": "45",
                   "vt": "num"
                   "p": "lauf",
                   "v": "20",
                   "vt": "num"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "8",
           "payloadType": "num",
           "x": 240,
           "y": 360,
           "wires": [
                   "7f2b9df4.d30d04",
                   "d45a1c2a.6a7508",
                   "c93fa4d4.3573a"
           "id": "7f2b9df4.d30d04",
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "false",
           "statusVal": "",
           "statusType": "auto",
           "x": 460,
           "y": 300,
           "wires": []
           "id": "d45a1c2a.6a7508",
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "min",
           "targetType": "msg",
           "statusVal": "",
           "x": 470,
           "y": 360,
           "wires": []
           "id": "c93fa4d4.3573a",
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "lauf",
           "statusVal": "",
           "x": 460,
           "y": 400,
           "wires": []
    Ich habe im Changenod einmal Payload * 60000 getestet und ein etwas seltsames Resultat erhalten.
    Ich habe gerade keine Ahnung was du mit dem Haken in der Adapterkonfig meinst.
    Gemäss Beschreibung dient das Aggregator Node eher zum sammeln von Nachrichten über einen längeren Zeitraum.
    mickymM Offline
    mickymM Offline
    mickym
    #88
    @hafo sagte in String aufteilen:
           "type": "inject",
           "name": "Payload",
           "props": [
                   "p": "payload"
                   "p": "min",
                   "v": "45",
                   "vt": "num"
                   "p": "lauf",
                   "v": "20",
                   "vt": "num"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "8",
           "x": 240,
           "y": 360,
           "wires": [
                   "7f2b9df4.d30d04",
                   "d45a1c2a.6a7508",
                   "c93fa4d4.3573a"
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 460,
           "y": 300,
           "wires": []
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "min",
           "statusVal": "",
           "x": 470,
           "y": 360,
           "wires": []
           "type": "debug",
           "name": "",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "lauf",
           "statusVal": "",
           "x": 460,
           "y": 400,
           "wires": []
    Und damit führe ich jetzt die 4 Rechenoperationen von unten aus?
    • mickymM mickym
      @hafo
      Ich habe noch ein bisschen mit der sort Node rumgespielt und dabei ein paar ganz gute Erkenntnisse gewonnen. Wenn Du willst dann poste ich sie hier mal im Thread - später. ;)
      hafo
      #89
      @mickym Genau, damit bin ich gerade fertig geworden. Ich habe nun den Flow gelöscht welcher die Flow Variable bei einem Neustart neu initialisiert. Aber der String wird immer noch richtig generiert, von daher habe ich das Sort Node einfach zum sicher sein eingebaut.
      H 1 Antwort Letzte Antwort
      • H hafo
        hafo
        #90
        @hafo Moment, ich bereite dir gerade den original Flow vor.
        • H hafo
          mickymM Offline
          mickymM Offline
          mickym
          #91
          Na brauchst nicht - ich mach Dir für jeder Operation eine Change Node und von mir aus zum Schluss nochmal ein mit allen zusammen.
          • mickymM mickym
            hafo
            #92
            @mickym Ich hätte es sonst hier
                   "type": "inject",
                   "name": "Payload",
                   "props": [
                           "p": "payload"
                           "p": "min",
                           "v": "45",
                           "vt": "num"
                           "p": "lauf",
                           "v": "20",
                           "vt": "num"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "payload": "8",
                   "x": 260,
                   "y": 520,
                   "wires": [
                           "8c07b9d.02c72c8"
                   "id": "ff4f5ab8.50b5c8",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "send.tomstart",
                           "pt": "flow",
                           "to": "payload",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 930,
                   "y": 620,
                   "wires": [
                           "1d8b361f.e2080a"
                   "id": "613f3272.a40554",
                   "type": "function",
                   "name": "",
                   "func": "var math = Number(msg.payload) + Number(msg.lauf);\nmsg.payload = math;\nreturn msg;",
                   "outputs": 1,
                   "noerr": 0,
                   "initialize": "",
                   "finalize": "",
                   "libs": [],
                   "x": 720,
                   "y": 660,
                   "wires": [
                           "1a57a95b.78d267"
                   "id": "1a57a95b.78d267",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "send.tomend",
                           "pt": "flow",
                           "to": "payload",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 930,
                   "y": 660,
                   "wires": [
                           "1d8b361f.e2080a"
                   "id": "1d8b361f.e2080a",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "send",
                           "tot": "flow"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1190,
                   "y": 660,
                   "wires": [
                           "d1cb8c1a.20b868"
                   "id": "d1cb8c1a.20b868",
                   "type": "template",
                   "name": "Create timer",
                   "field": "payload",
                   "fieldType": "msg",
                   "format": "handlebars",
                   "syntax": "mustache",
                   "template": "{\"timers\":[{\"starttime\":{{payload.tomstart}},\"days\":[{{payload.tomtag}}],\"output\":\"0\",\"endtime\":{{payload.tomend}}}],\"settings\":{\"disabledDevices\":[]}}",
                   "output": "str",
                   "x": 1390,
                   "y": 660,
                   "wires": [
                           "cafc6f1d.b72b88"
                   "id": "e29d0be5.53d3d",
                   "type": "function",
                   "name": "",
                   "func": "var math = (Number(msg.payload) + Number(msg.min)) * 60000;\nmsg.payload = math;\nreturn msg;",
                   "outputs": 1,
                   "noerr": 0,
                   "initialize": "",
                   "finalize": "",
                   "libs": [],
                   "x": 640,
                   "y": 520,
                   "wires": [
                           "ff4f5ab8.50b5c8",
                           "237b16ca.6c1e82"
                   "id": "8c07b9d.02c72c8",
                   "type": "function",
                   "name": "",
                   "func": "var math = (Number(msg.payload) - 1) * 60;\nmsg.payload = math;\nreturn msg;",
                   "outputs": 1,
                   "noerr": 0,
                   "initialize": "",
                   "finalize": "",
                   "libs": [],
                   "x": 470,
                   "y": 520,
                   "wires": [
                           "e29d0be5.53d3d"
                   "id": "237b16ca.6c1e82",
                   "type": "calculator",
                   "name": "",
                   "inputMsgField": "lauf",
                   "outputMsgField": "lauf",
                   "operation": "mult",
                   "constant": "60000",
                   "round": false,
                   "decimals": 0,
                   "x": 580,
                   "y": 660,
                   "wires": [
                           "613f3272.a40554"
                   "id": "cafc6f1d.b72b88",
                   "type": "debug",
                   "name": "",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 1680,
                   "y": 660,
                   "wires": []
            mickymM H 2 Antworten Letzte Antwort
            • H hafo
                     "type": "inject",
                     "name": "Payload",
                     "props": [
                             "p": "payload"
                             "p": "min",
                             "v": "45",
                             "vt": "num"
                             "p": "lauf",
                             "v": "20",
                             "vt": "num"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "8",
                     "x": 260,
                     "y": 520,
                     "wires": [
                             "8c07b9d.02c72c8"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 930,
                     "y": 620,
                     "wires": [
                             "1d8b361f.e2080a"
                     "type": "function",
                     "name": "",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 720,
                     "y": 660,
                     "wires": [
                             "1a57a95b.78d267"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "send.tomend",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 930,
                     "y": 660,
                     "wires": [
                             "1d8b361f.e2080a"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "send",
                             "tot": "flow"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1190,
                     "y": 660,
                     "wires": [
                             "d1cb8c1a.20b868"
                     "type": "template",
                     "field": "payload",
                     "fieldType": "msg",
                     "output": "str",
                     "x": 1390,
                     "y": 660,
                     "wires": [
                             "cafc6f1d.b72b88"
                     "type": "function",
                     "name": "",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 640,
                     "y": 520,
                     "wires": [
                             "ff4f5ab8.50b5c8",
                             "237b16ca.6c1e82"
                     "type": "function",
                     "name": "",
                     "outputs": 1,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 470,
                     "y": 520,
                     "wires": [
                             "e29d0be5.53d3d"
                     "name": "",
                     "round": false,
                     "decimals": 0,
                     "x": 580,
                     "y": 660,
                     "wires": [
                             "613f3272.a40554"
                     "type": "debug",
                     "name": "",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1680,
                     "y": 660,
                     "wires": []
              mickymM Offline
              mickymM Offline
              mickym
              #93
              @hafo Nun ich verstehe einfach das Problem nicht??
              Habe hier 4 mal das gerechnet was Du unten angegeben hast:
                     "type": "inject",
                     "z": "f19174b9.aa88f8",
                     "name": "Payload",
                     "props": [
                             "p": "payload"
                             "p": "min",
                             "v": "45",
                             "vt": "num"
                             "p": "lauf",
                             "v": "20",
                             "vt": "num"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "8",
                     "x": 580,
                     "y": 1260,
                     "wires": [
                             "7f2b9df4.d30d04",
                             "d45a1c2a.6a7508",
                             "c93fa4d4.3573a",
                             "6e679c0.c2cb864",
                             "6f0bb159.6ecbe",
                             "3549ae59.415702",
                             "a625c6c2.2ddfa8"
                     "type": "debug",
                     "name": "",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 800,
                     "y": 1200,
                     "wires": []
                     "type": "debug",
                     "name": "",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "min",
                     "statusVal": "",
                     "x": 810,
                     "y": 1260,
                     "wires": []
                     "type": "debug",
                     "name": "",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "lauf",
                     "statusVal": "",
                     "x": 800,
                     "y": 1300,
                     "wires": []
                     "id": "6e679c0.c2cb864",
                     "type": "change",
                     "name": "payload * 60000",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "payload * 60000",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 820,
                     "y": 1400,
                     "wires": [
                             "7e6953dd.b53aec"
                     "id": "7e6953dd.b53aec",
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "complete": "payload",
                     "statusVal": "",
                     "x": 1070,
                     "y": 1400,
                     "wires": []
                     "id": "6f0bb159.6ecbe",
                     "type": "change",
                     "name": "(payload - 1) * 60",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "(payload - 1) * 60",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 1460,
                     "wires": [
                             "c033f0e3.dd226"
                     "id": "c033f0e3.dd226",
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1070,
                     "y": 1460,
                     "wires": []
                     "id": "3549ae59.415702",
                     "type": "change",
                     "name": "(payload + min) * 60000;",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "(payload + min) * 60000",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 850,
                     "y": 1520,
                     "wires": [
                             "1ddb1d5.a41cce3"
                     "id": "1ddb1d5.a41cce3",
                     "type": "debug",
                     "name": "(payload + min) * 60000",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1130,
                     "y": 1520,
                     "wires": []
                     "id": "a625c6c2.2ddfa8",
                     "type": "change",
                     "name": "payload + lauf",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "payload + lauf",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 830,
                     "y": 1580,
                     "wires": [
                             "2dfa315e.be413e"
                     "id": "2dfa315e.be413e",
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1080,
                     "y": 1580,
                     "wires": []
              • H hafo
                       "type": "inject",
                       "name": "Payload",
                       "props": [
                               "p": "payload"
                               "p": "min",
                               "v": "45",
                               "vt": "num"
                               "p": "lauf",
                               "v": "20",
                               "vt": "num"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "8",
                       "x": 260,
                       "y": 520,
                       "wires": [
                               "8c07b9d.02c72c8"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 930,
                       "y": 620,
                       "wires": [
                               "1d8b361f.e2080a"
                       "type": "function",
                       "name": "",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 720,
                       "y": 660,
                       "wires": [
                               "1a57a95b.78d267"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "send.tomend",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 930,
                       "y": 660,
                       "wires": [
                               "1d8b361f.e2080a"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "send",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1190,
                       "y": 660,
                       "wires": [
                               "d1cb8c1a.20b868"
                       "type": "template",
                       "field": "payload",
                       "fieldType": "msg",
                       "output": "str",
                       "x": 1390,
                       "y": 660,
                       "wires": [
                               "cafc6f1d.b72b88"
                       "type": "function",
                       "name": "",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 640,
                       "y": 520,
                       "wires": [
                               "ff4f5ab8.50b5c8",
                               "237b16ca.6c1e82"
                       "type": "function",
                       "name": "",
                       "outputs": 1,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 470,
                       "y": 520,
                       "wires": [
                               "e29d0be5.53d3d"
                       "name": "",
                       "round": false,
                       "decimals": 0,
                       "x": 580,
                       "y": 660,
                       "wires": [
                               "613f3272.a40554"
                       "type": "debug",
                       "name": "",
                       "active": true,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 1680,
                       "y": 660,
                       "wires": []
                hafo
                #94
                Ich sehe gerade dass ich da besser zuerst alle Daten einsammle und dann durch die Rechner laufen lasse. So langsam verstehe ich das Prinzip.
                • H hafo
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #95
                  @hafo Na Du kannst sie HuckePack nehmen - das geht auch oder sammelst wieder in Flow Variable und schreibst zum Schluss. ;)
                  Ich sags immer wieder - Nachrichten warten nicht auf Dich und wenn nichts gespeichert wird, ist die Nachricht, hat sie mal eine Node passiert, Schall und Rauch. ;)
                  HuckePack kannst Du sie nehmen, wenn Du Deine Get-Nodes alle in unterschiedliche Eigenschaften speichern lässt, dann schleppst Du die im Nachrichtenobjekt mit und kannst dann damit rechnen!
                  Hier in Deinen get NOdes unterschiedliche Eigenschaften benennen, dann werden die mitgeschleift, sonst überschreibst Du die payload ja immer wieder:
                  Schau Dir halt auch in den Debug Nodes in solchen Fällen nicht nur die Payload sondern das gesamte Nachrichtenobjekt an!!!
                  Ich weiß am Anfang braucht es etwas - damit man versteht was Nachrichten und ein Nachrichtenobjekt ist. Aber wenn Du das mal verstanden hast, dann spielst Du in NodeRed wie ein Pianist auf dem Klavier. ;)
                  • mickymM mickym
                    hafo
                    #96
                    @mickym Danke, das habe ich schon mal gemacht mit dem HuckePack.
                    Ich habe nun aber dein "Nummer / Zahl" Problem.
                    "Invalid JSONata expression: The left side of the "-" operator must evaluate to a number"
                    • H hafo
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #97
                      @hafo Wie gesagt - Du bist nicht meiner Empfehlung gefolgt und hast die Stringkonvertierung in dem Adapter ausgeschaltet.
                      Du kannst das entweder jetzt machen - musst halt aufpassen, ob Du nicht schon viel konvertiert hast oder musst halt immer weiter konvertieren.
                      Wenn Du weiter konvertieren willst, dann musst halt alles mit $number() in JSONATA umwandeln oder Du liest Zahlen, die im iobroker als Zahl definiert sind auch als Zahl aus und machst diesen unsäglichen Haken raus!!!
                      Ansonsten kannst Du auch in JSONATA weiterhin Zahlen konvertieren:
                      • mickymM mickym
                        hafo
                        #98
                        @mickym Nein, der Haken ist bei mir gesetzt. Aber vielleicht habe ich bei den Objekten etwas falsches eingestellt.
                        • H hafo
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #99
                          @mickym Nein, der Haken ist bei mir gesetzt. 😠 😡 Aber vielleicht habe ich bei den Objekten etwas falsches eingestellt.
                          Das ist doch das Problem!!!! Haken raus!!!!
                          Mit gesetztem Haken kann im Datenpunkt stehen was will - es wird alles in Strings gewandelt!
                          • mickymM mickym
                            hafo
                            #100
                            @mickym Ich glaub ich bin schon zu lange am Computer 🤦
                            Jedenfalls triggert er nun wieder in alle unendlichkeit
                            • H hafo
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #101
                              @hafo Nein - Du hast nun umgestellt und nun kommen auch Deine booleans als booleans und nicht mehr als String.
                              Das ist jetzt vielleicht leider Umstellungsaufwand - deswegen empfehle ich den Haken von Beginn an rauszunehmen, sonst kannst halt weiter konvertieren.
                              Du kannst den Haken ja erst mal wieder rein nehmen und dann anfangen zu suchen:
                              Wenn Du im JSONATA konvertieren willst, dann geht das schon
                              Ich finde es auf Dauer umständlich, aber wie gesagt nun musst Du erst mal schauen, wo Deine Datentypen nicht mehr passen.
                              • H hafo
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #102
                                @hafo Der switch hinter Deinen Trigger wird wahrscheinlich nicht mehr passen, da der auf String und nicht auf Boolean abprüft.
                                den musst mit Sicherheit umstellen:
                                Einfach alle Eingänge überprüfen, ob der richtige Datentyp nun im weiteren Verlauf verwendet wird. Ansonsten zurück kannst immer. Aber ich denke lieber einmal Schmerzen, als dauernd konvertieren. ;)
                                • mickymM mickym
                                  hafo
                                  schrieb am zuletzt editiert von hafo
                                  #103
                                  @mickym das habe ich zuerst geändert. Beim oberen Beispiel ist dieser Switch gar nicht angehängt, und der untere sollte sämtliche Nachrichten in Boolean false ändern.
                                  Da muss ich noch ein bisschen suchen.
                                  OK, es läuft wieder. Ich musste natürlich beim Trigger einstellen dass er nur auf geänderte Nachrichten reagiert.
                                  • H hafo
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #104
                                    @hafo Na gut - :) Du wirst erleichtert sein, dass Du Dir nun eine Menge Konvertiererei sparst. Das Rechnen sollte nun ohne den JSONATA Fehler funktionieren, wenn die Datenpunkte vom Typ Zahl sind.
                                    • mickymM mickym
                                      @hafo
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #105
                                      @mickym sagte in String aufteilen:
                                      @hafo
                                      So ich habe nun auch herausgefunden, wie man mit den Sort Nodes ggf. auch selbst eine Sortierreihenfolge definieren kann, selbst wenn man das nicht so vorab so vorbildlich gemacht hat, wie Du und immer eine Zahl vorangestellt hat. Das hat zwar bisschen Tüftelei gekostet, aber vielleicht ist das für den einen oder anderen interessant:
                                      Also was sieht man:
                                      1. Das Array mit durcheinandergewürfelten Wochentagen.
                                      2. Mit Standardeinstellungen wird das Array natürlich alphabetisch sortiert:
                                      3. Um nun eine eigene Reihenfolge festzulegen, kann man ein Objekt erstellen und den Begriffen, in diesem Fall Zahlenwerte zuordnen.
                                        In der letzten Node sieht man werden die Wochentage nun auch in dem Array richtig sortiert.
                                        Dies erfolgt über eine JSONATA Funktion - Kopfzerbrechen hat mir das $ Zeichen gemacht, dass von der Node als Platzhalter für die Arrayelemente verwendet.
                                      $lookup(
                                             "Mo":0,
                                             "Di":1,
                                             "Mi":2,
                                             "Do":3,
                                             "Fr":4,
                                             "Sa":5,
                                             "So":6
                                      Grundsätzlich kann man auch nur mit einer JSONATA Funktion in einer Change Node ein Array sortieren:
                                      Das ist aber bissi komplizierter - hier mal die JSONATA Defintion:
                                      $sort(payload,function($l, $r){
                                         $lookup(
                                                 "Mo":0,
                                                 "Di":1,
                                                 "Mi":2,
                                                 "Do":3,
                                                 "Fr":4,
                                                 "Sa":5,
                                                 "So":6
                                             $l
                                         ) > $lookup(
                                                 "Mo":0,
                                                 "Di":1,
                                                 "Mi":2,
                                                 "Do":3,
                                                 "Fr":4,
                                                 "Sa":5,
                                                 "So":6
                                             $r
                                      Hat man kein Objekt sondern splittet ein Array - dann kann man ebenfalls anstelle von dem topic bzw. key zum Beispiel nach der Payload sortieren:
                                      $lookup(
                                             "Mo":0,
                                             "Di":1,
                                             "Mi":2,
                                             "Do":3,
                                             "Fr":4,
                                             "Sa":5,
                                             "So":6
                                         payload
                                      Hier muss ich dann die payload, statt der $ eingeben, da hier die payload ja bereits den skalaren Wert enthalten.
                                      Jedenfalls habe ich heute auch wieder einiges gelernt und vielleicht hilft das auch dem einen oder anderen.
                                      • H hafo
                                        Hallo zusammen
                                        Ich habe einen String mit 7 Zahlen (0 oder 1)
                                        "0,0,0,1,0,0,1"
                                        Nun würde ich gerne mit einem Funktions- oder Changenode die Zahlen auf 7 Ausgänge aufteilen. Im Idealfall wird gleich noch ein "0" noch durch "false" ersetzt und "1" durch "true".
                                        Mit dem Changenode komme ich nicht wirklich an mein Ziel, ich finde da die passende Funktion nicht. Eventuell würde es mit Jsonata gehen.
                                        Daher habe ich mit dem Funktionsnode gestartet, aber ohne Java Kentnisse ist das nicht so einfach. Damit geht es schon mal nicht
                                        var string = msg.payload;
                                        var msg1 = string.substr(1);
                                        var msg2 = string.substr(2);
                                        var msg3 = string.substr(3);
                                        var msg4 = string.substr(4);
                                        var msg5 = string.substr(5);
                                        var msg6 = string.substr(6);
                                        var msg7 = string.substr(7);
                                        return [ msg1, msg2, msg3, msg4, msg5, msg6, msg7 ];
                                        Kann mir bitte jemand einen Schubs in die richtige Richtung geben?
                                        Gruss
                                        Hansjürg
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #106
                                        @hafo Ich habe übrigens nun auch mal Deinen Scheduler Node installiert. Den finde ich ganz gut - allerdings wundert mich, dass Du den verwendest, da Du ja das NodeRed Dashboard gar nicht nutzt. ;)
                                        • mickymM mickym
                                          hafo
                                          #107
                                          @mickym Das war beim einstellen ganz nützlich.
                                          Ich habe gerade etwas Mühe alle strings in Zahlen zu ändern. Auch wenn das Objekt eine Zahl enthalten sollte, wird manchmal ein String ausgelesen. Bei den Stunden klappt es, bei den Minuten nicht. Irgendwie macht das Vis teilweise strings.
