  4. Node-Red
  5. String aufteilen
    6.5k
String aufteilen
141 Beiträge 3 Kommentatoren 21.5k Aufrufe 2 Beobachtet
  • mickymM mickym
    @hafo sagte in String aufteilen:
    Lieber wäre mir eh wenn es im Format ist welches der Timer frisst.
    Nun dann nimm noch mal den ursprünglichen Flow für den 1. Schritt:
           "id": "8dfb7709.f8f618",
           "type": "split",
           "z": "4922e7ed.227918",
           "name": "",
           "splt": ",",
           "spltType": "str",
           "arraySplt": 1,
           "arraySpltType": "len",
           "stream": false,
           "addname": "",
           "x": 1030,
           "y": 240,
           "wires": [
                   "44d1461a.1d3b68"
           "id": "44d1461a.1d3b68",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "0",
                   "fromt": "str",
                   "to": "false",
                   "tot": "bool"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "1",
                   "fromt": "str",
                   "to": "true",
                   "tot": "bool"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1210,
           "y": 240,
           "wires": [
                   "e67fc8a0.23b6e8"
           "id": "e67fc8a0.23b6e8",
           "type": "switch",
           "name": "",
           "property": "parts.index",
           "propertyType": "msg",
           "rules": [
                   "t": "eq",
                   "v": "0",
                   "vt": "num"
                   "t": "eq",
                   "v": "1",
                   "vt": "num"
                   "t": "eq",
                   "v": "2",
                   "vt": "num"
                   "t": "eq",
                   "v": "3",
                   "vt": "num"
                   "t": "eq",
                   "v": "4",
                   "vt": "num"
                   "t": "eq",
                   "v": "5",
                   "vt": "num"
                   "t": "eq",
                   "v": "6",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 7,
           "x": 1390,
           "y": 240,
           "wires": [
                   "c87f9620.f025e8"
                   "2b84bf3a.383dc"
                   "d25134f5.641878"
                   "b7ac809d.3b429"
                   "c643bb47.b63838"
                   "c105b962.146f38"
                   "36555c62.f06644"
           "id": "c87f9620.f025e8",
           "type": "ioBroker out",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.1Mo",
           "ack": "true",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 120,
           "wires": []
           "id": "2b84bf3a.383dc",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.2Di",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 160,
           "wires": []
           "id": "d25134f5.641878",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.3Mi",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 200,
           "wires": []
           "id": "b7ac809d.3b429",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.4Do",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 240,
           "wires": []
           "id": "c643bb47.b63838",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.5Fr",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 280,
           "wires": []
           "id": "c105b962.146f38",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.6Sa",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 320,
           "wires": []
           "id": "36555c62.f06644",
           "name": "",
           "topic": "0_userdata.0.Bewässerung.Tage.7So",
           "ack": "true",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1650,
           "y": 360,
           "wires": []
    EDIT - die debug Nodes im Flow noch getauscht!
    Schritt 2 - also füllen der Flow Variablen kann so bleiben, wie es ist.
    Schritt 3 angepasst:
           "id": "22a66311.f3560c",
           "type": "inject",
           "name": "Speichern",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "true",
           "payloadType": "bool",
           "x": 200,
           "y": 1940,
           "wires": [
                   "82dfdd05.4d8e1"
           "id": "fb4611b6.3419",
           "type": "ioBroker get",
           "name": "vis_Auswahl",
           "topic": "0_userdata.0.Bewässerung.vis_Auswahl",
           "attrname": "auswahl",
           "payloadType": "value",
           "x": 610,
           "y": 1940,
           "wires": [
                   "dea4991e.3e11c8"
           "id": "82dfdd05.4d8e1",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "days",
                   "tot": "flow"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 410,
           "y": 1940,
           "wires": [
                   "fb4611b6.3419"
           "id": "dea4991e.3e11c8",
           "type": "switch",
           "name": "Verteiler",
           "property": "auswahl",
           "rules": [
                   "t": "eq",
                   "v": "1",
                   "vt": "num"
                   "t": "eq",
                   "v": "2",
                   "vt": "num"
                   "t": "eq",
                   "v": "3",
                   "vt": "num"
                   "t": "eq",
                   "v": "4",
                   "vt": "num"
                   "t": "eq",
                   "v": "5",
                   "vt": "num"
                   "t": "eq",
                   "v": "6",
                   "vt": "num"
                   "t": "eq",
                   "v": "7",
                   "vt": "num"
           "checkall": "true",
           "repair": false,
           "outputs": 7,
           "x": 820,
           "y": 1940,
           "wires": [
                   "f65a811c.6b36c"
           "id": "f65a811c.6b36c",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "topic",
                   "pt": "msg",
                   "to": "0_userdata.0.Bewässerung.Tomaten_Tage",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1000,
           "y": 1980,
           "wires": [
                   "4760a6ff.969fe8"
           "id": "e7dc8e38.b0003",
           "name": "",
           "topic": "",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1680,
           "y": 1980,
           "wires": []
           "id": "4760a6ff.969fe8",
           "type": "split",
           "name": "",
           "splt": "\\n",
           "spltType": "str",
           "arraySplt": 1,
           "stream": false,
           "addname": "",
           "x": 1170,
           "y": 1980,
           "wires": [
                   "29b86736.dbc0f8"
           "id": "cb07faa.5e09e08",
           "type": "join",
           "name": "",
           "mode": "custom",
           "build": "string",
           "property": "payload",
           "key": "topic",
           "joiner": ",",
           "joinerType": "str",
           "accumulate": false,
           "timeout": "",
           "count": "",
           "reduceRight": false,
           "reduceExp": "",
           "reduceInit": "",
           "reduceInitType": "",
           "reduceFixup": "",
           "x": 1500,
           "y": 1980,
           "wires": [
                   "e7dc8e38.b0003"
           "id": "29b86736.dbc0f8",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "true",
                   "fromt": "bool",
                   "to": "1",
                   "tot": "str"
                   "t": "change",
                   "p": "payload",
                   "pt": "msg",
                   "from": "false",
                   "fromt": "bool",
                   "to": "0",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1330,
           "y": 1980,
           "wires": [
                   "cb07faa.5e09e08"
    Damit kannst Du nun noch statt der Inject Node Speichern nur den Datenpunkt, den Deine Vis Taste Speichern triggert vorne dran machen!
    hafo
    @mickym Ich hatte den alten Flow noch griffbereit. Das ganze sieht ohne die Tage so aus
    gross aber übersichtlich.
    Nun muss ich noch bei den Debug Platzhalter deinen Flow einpflanzen dann sollte es laufen. 👯
    • H hafo
      mickymM Offline
      mickymM Offline
      mickym
      @hafo Ich würde nur das Speichern entkoppeln und die vis_auswahl alleine triggern lassen. Sobald Du in der DropBox was in der Vis was auswählst wird dieser Datenpunkt dann getriggert und die Wochentage gefüllt und die Flow Variable ebenfalls.
      Das Speichern ist dann völlig entkoppelt und hängt dann nur an einem VIS Button.
      H 1 Antwort Letzte Antwort
      • mickymM mickym
        hafo
        schrieb am zuletzt editiert von hafo
        @mickym ich bin eigentlich davon ausgegangen dass es bereits wie von dir beschrieben läuft. Damit wird die Vis Anzeige und die Flow Variable gefüllt.
        Und mit diesem Flow gespeichert und in den Timer geworfen.
        Leider funktioniert das mit den Tagen noch überhaupt nicht, der Rest läuft.
        Edit:
        Schande über mich, dieser Flow wirft es in den Timer
        • H hafo
          Edit:
          mickymM Offline
          mickymM Offline
          mickym
          @hafo Also dann muss man halt Schritt für Schritt vorgehen.
          Wenn Du die vis_Auswahl Variable mit 7 triggerst, dann sollte ja der Datenpunkt Tomaten_Tage gelesen werden:
          1. Frage - werden die Datenpunkte gefüllt?
          2. Frage - wird die Flow Variable gefüllt`?
          Also mach mal einen Screenshot von den Flow Variablen
          • H hafo
            Edit:
            mickymM Offline
            mickymM Offline
            mickym
            @hafo Na das ist ja ne andere Geschichte mit Deinem Timer - es ist ja nur wichtig, dass der Flow über den wir geredet haben, den Datenpunkt Tomaten_Tage mit dem String füllt. Das müsstest Du ja dann auch am Timestamp sehen.
            • mickymM mickym
              hafo
              @mickym Ich habe alles mal durchgeschaut und noch einige falsche Datenpunkte gefunden. Aber leider komme ich noch nicht weiter.
              Die Tage werden beim auswählen korrekt gefüllt,
              wenn ich sie im vis ändere werden die Objekte korrekt verändert,
              beim speichern geschieht gar nichts.
              Er erkennt anscheinend auch nur false und schaut nicht die weiteren Datenpunkte an.
              Edit
              Mit dem Debug direkt hinter dem "Iobroker In" sehe ich dass er keinen String abruft, sondern nur die letzte Änderung. Wenn ich irgendwo einen Haken setze kommt ein true, wenn ich ihn wegnehme ein false.
              • H hafo
                Edit
                mickymM Offline
                mickymM Offline
                mickym
                @hafo Ändert sich den der Flow Kontext hast Du denn den 2. Part auch richtig implementiert?
                Schau doch mal ob sich beim VIS drücken die FLOW Variable geändert wird? Musst Du danach immer aktualisieren.
                Also hast Du diesen Part implementiert?
                und die vorherige Version mit dem switch Node.
                Auch hier wieder Tage klein machen bei Dir wahrscheinlich.
                • mickymM mickym
                  hafo
                  @mickym sehe ich die Flow Variable irgendwo, oder ist die nur mit einem Debug Node hinter dem functions Node sichtbar?
                  • H hafo
                    Edit
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @hafo Das passt doch schau halt mal ob die Flow Variablen entsprechende Deinen Datenpunkten gesetzt sind.
                    • H hafo
                      mickymM Offline
                      mickymM Offline
                      mickym
                      • mickymM mickym
                        hafo
                        @mickym sehr gut, das habe ich gesucht.
                        Ja, die Flow Variable wird angepasst.
                        • H hafo
                          mickymM Offline
                          mickymM Offline
                          mickym
                          Nun wenn die Flow Variable passt - dann geh halt weiter:
                          1. Nachdem Du Speichern drückst - sollte doch Dein
                          Change Node - die Payload auf die flow Variable setzen (ggf. Prüfen)
                          1. Die Auswahl wird über getNode gelesen und in msg.auswahl gespeichert:
                          dann wird die vis_Auswahl abgerufen und in msg.auswahl gespeichert und die muss dann im Verteiler stehen:
                          Prüfe doch bitte, ob nach Deinem Verteiler beim Speichern drücken mittels Debug Node eine Nachricht kommt.
                          • mickymM mickym
                            hafo
                            @mickym Dann wird dort das Problem sein, ich habe da etwas improvisiert.
                            • H hafo
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @hafo Nun improvisieren - kann Auswirkungen haben, das die Puzzlestückchen nicht mehr zusammenpassen.
                              Kommst Du denn mit meiner Anleitung nun zurecht?
                              Wichtig ist, dass aus Deinem Verteiler das Objekt der Flow Variablen rauskommt. ;)
                              Dann muss der Topic richtig gesetzt werden
                              Dann wird wieder das Objekt auseinandergenommen um alle trues und falses in 0 und 1 zu übersetzen und dann wird das wieder als String zusammengesetzt.
                              Wenn Du anderweitig vorher schon in Deinem Verteiler verteilst, dann brauchst doch nur die Change Node, die die Flow-Variable in die payload kopiert vorne hinhängen.
                              • mickymM mickym
                                hafo
                                @mickym Ich starte meinen Pi einmal neu. Aktuell werden keine der Bewässerungsobjekte aktualisiert. Ich kann sie auch nicht direkt von Hand ändern. Seltsamerweise wird im Vis aber alles angepasst wenn ich es auswähle.
                                • H hafo
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Na hoffentlich hast Du Dir nicht anderweitig eine Endlosschleife eingefangen. ggf. Debug Nodes an Ein- oder Ausgänge hängen.
                                  H 3 Antworten Letzte Antwort
                                  • mickymM mickym
                                    hafo
                                    @mickym Ich bin noch nicht weiter gekommen. Hier beim Timer habe ich ja nicht viel geändert
                                           "id": "f1325bf4.4ed0f",
                                           "type": "ui_time_scheduler",
                                           "z": "95848418.340d58",
                                           "group": "df42ab16.59cb78",
                                           "name": "Bewässerung",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Tomaten"
                                           "onlySendChange": false,
                                           "customPayload": false,
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 200,
                                           "y": 340,
                                           "wires": [
                                                   "15cd23d8.ca16d4"
                                           "outputLabels": [
                                               "Info",
                                               "Chili",
                                               "Gewuertz",
                                               "Rasen",
                                               "Himbeeren",
                                               "Gemuese",
                                               "Feigenbaum",
                                               "Tomaten"
                                           "id": "9334f2a7.e7bae",
                                           "name": "Tomaten",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.12",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 700,
                                           "y": 360,
                                           "wires": []
                                           "id": "15cd23d8.ca16d4",
                                           "type": "change",
                                           "name": "change true",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 450,
                                           "y": 360,
                                           "wires": [
                                                   "9334f2a7.e7bae"
                                           "id": "1df93fe2.46fbe",
                                           "type": "ioBroker in",
                                           "name": "Tomaten Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Tomaten_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "fireOnStart": "true",
                                           "x": 140,
                                           "y": 40,
                                           "wires": [
                                                   "18e28c07.feb6a4"
                                           "id": "a9f1efd2.7ba",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.tomstart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 810,
                                           "y": 140,
                                           "wires": [
                                                   "49b35f45.913428"
                                           "id": "edbdcaab.6c3bf8",
                                           "type": "function",
                                           "name": "",
                                           "func": "var math = Number(msg.payload) + Number(msg.lauf);\nmsg.payload = math;\nreturn msg;",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 600,
                                           "y": 180,
                                           "wires": [
                                                   "98df7f5d.11b1a8"
                                           "id": "bd4c9090.779998",
                                           "name": "Tomaten Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Tomaten_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 290,
                                           "y": 180,
                                           "wires": [
                                                   "61f31e86.30eb7"
                                           "id": "98df7f5d.11b1a8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.tomend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 810,
                                           "y": 180,
                                           "wires": [
                                                   "49b35f45.913428"
                                           "id": "24fcb6c1.8936a2",
                                           "name": "Tomaten Tage",
                                           "topic": "0_userdata.0.Bewässerung.Tomaten_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 130,
                                           "y": 240,
                                           "wires": [
                                                   "ec2da415.2a4fd8"
                                           "id": "ec2da415.2a4fd8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.tomtag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 800,
                                           "y": 220,
                                           "wires": [
                                                   "49b35f45.913428"
                                           "id": "f8cc9712.2ab86",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 80,
                                           "y": 180,
                                           "wires": [
                                                   "bd4c9090.779998"
                                           "id": "49b35f45.913428",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1070,
                                           "y": 180,
                                           "wires": [
                                                   "df48c94f.bf566"
                                           "id": "df48c94f.bf566",
                                           "type": "template",
                                           "name": "Create timer",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "format": "handlebars",
                                           "syntax": "mustache",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.tomstart}},\"days\":[{{payload.tomtag}}],\"output\":\"0\",\"endtime\":{{payload.tomend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1270,
                                           "y": 180,
                                           "wires": [
                                                   "f1325bf4.4ed0f"
                                           "id": "a2212093.185978",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Tomaten_Startzeit_m",
                                           "attrname": "min",
                                           "x": 550,
                                           "y": 40,
                                           "wires": [
                                                   "cd67691.76bf218"
                                           "id": "cd67691.76bf218",
                                           "type": "function",
                                           "name": "",
                                           "func": "var math = (Number(msg.payload) + Number(msg.min)) * 60000;\nmsg.payload = math;\nreturn msg;",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 720,
                                           "y": 40,
                                           "wires": [
                                                   "a9f1efd2.7ba",
                                                   "bd4c9090.779998"
                                           "id": "18e28c07.feb6a4",
                                           "type": "function",
                                           "name": "",
                                           "func": "var math = (Number(msg.payload) - 1) * 60;\nmsg.payload = math;\nreturn msg;",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 350,
                                           "y": 40,
                                           "wires": [
                                                   "a2212093.185978"
                                           "id": "61f31e86.30eb7",
                                           "type": "calculator",
                                           "name": "",
                                           "inputMsgField": "lauf",
                                           "outputMsgField": "lauf",
                                           "operation": "mult",
                                           "constant": "60000",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 460,
                                           "y": 180,
                                           "wires": [
                                                   "edbdcaab.6c3bf8"
                                           "id": "c5a2845b.60457",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Gewuertz"
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 240,
                                           "y": 900,
                                           "wires": [
                                                   "677967fd.d6508"
                                           "outputLabels": [
                                               "Info",
                                               "Chili"
                                           "id": "e0307c77.b211c",
                                           "name": "Gewürtz",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.4",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 740,
                                           "y": 920,
                                           "wires": []
                                           "id": "677967fd.d6508",
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 550,
                                           "y": 920,
                                           "wires": [
                                                   "e0307c77.b211c"
                                           "id": "caf7b2e8.1894b",
                                           "name": "Gewuertz Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Gewuertz_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 190,
                                           "y": 600,
                                           "wires": [
                                                   "fc7a7352.44fc9"
                                           "id": "5ecdf7a0.e5c52",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.gewstart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 700,
                                           "wires": [
                                                   "b11dd4d7.897628"
                                           "id": "1cf4d57e.33b613",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 640,
                                           "y": 740,
                                           "wires": [
                                                   "49c2e1d4.4d6fa"
                                           "id": "a8d69e10.cd63e",
                                           "name": "Gewuertz Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Gewuertz_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 330,
                                           "y": 740,
                                           "wires": [
                                                   "9eb12009.2f268"
                                           "id": "49c2e1d4.4d6fa",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.gewend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 740,
                                           "wires": [
                                                   "b11dd4d7.897628"
                                           "id": "a7e14d02.fec93",
                                           "name": "Gewuertz Tage",
                                           "topic": "0_userdata.0.Bewässerung.Gewuertz_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 180,
                                           "y": 800,
                                           "wires": [
                                                   "710ebd7a.a08164"
                                           "id": "710ebd7a.a08164",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.gewtag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 780,
                                           "wires": [
                                                   "b11dd4d7.897628"
                                           "id": "65326eb6.d8ded",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 130,
                                           "y": 740,
                                           "wires": [
                                                   "a8d69e10.cd63e"
                                           "id": "b11dd4d7.897628",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1110,
                                           "y": 740,
                                           "wires": [
                                                   "961552c6.c4d6d"
                                           "id": "961552c6.c4d6d",
                                           "type": "template",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.gewstart}},\"days\":[{{payload.gewtag}}],\"output\":\"0\",\"endtime\":{{payload.gewend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1310,
                                           "y": 740,
                                           "wires": [
                                                   "c5a2845b.60457"
                                           "id": "5350d0ee.b87ef",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Gewuertz_Startzeit_m",
                                           "attrname": "min",
                                           "x": 590,
                                           "y": 600,
                                           "wires": [
                                                   "d7ca170f.1c93a8"
                                           "id": "d7ca170f.1c93a8",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 760,
                                           "y": 600,
                                           "wires": [
                                                   "5ecdf7a0.e5c52",
                                                   "a8d69e10.cd63e"
                                           "id": "fc7a7352.44fc9",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 400,
                                           "y": 600,
                                           "wires": [
                                                   "5350d0ee.b87ef"
                                           "id": "9eb12009.2f268",
                                           "name": "",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 500,
                                           "y": 740,
                                           "wires": [
                                                   "1cf4d57e.33b613"
                                           "id": "f742c03b.2b4018",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Rasen"
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 240,
                                           "y": 1340,
                                           "wires": [
                                                   "881632b6.31c788"
                                           "outputLabels": [
                                               "Info",
                                               "Chili"
                                           "id": "62ea3655.fb8248",
                                           "name": "Rasen",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.16",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 730,
                                           "y": 1360,
                                           "wires": []
                                           "id": "881632b6.31c788",
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 490,
                                           "y": 1360,
                                           "wires": [
                                                   "62ea3655.fb8248"
                                           "id": "4b2cc279.165b9c",
                                           "name": "Rasen Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Rasen_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 180,
                                           "y": 1040,
                                           "wires": [
                                                   "7c130cf9.58ddf4"
                                           "id": "9a31aa7.81634d8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.rasstart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 1140,
                                           "wires": [
                                                   "478bd581.773b1c"
                                           "id": "7c888e93.75e008",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 640,
                                           "y": 1180,
                                           "wires": [
                                                   "22336e17.68a50a"
                                           "id": "16fd25cd.411922",
                                           "name": "Rasen Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Rasen_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 320,
                                           "y": 1180,
                                           "wires": [
                                                   "537f95ef.af8cf4"
                                           "id": "22336e17.68a50a",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.rasend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 840,
                                           "y": 1180,
                                           "wires": [
                                                   "478bd581.773b1c"
                                           "id": "e8ab5570.c9b078",
                                           "name": "Rasen Tage",
                                           "topic": "0_userdata.0.Bewässerung.Rasen_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 170,
                                           "y": 1240,
                                           "wires": [
                                                   "cc068c34.857cd8"
                                           "id": "cc068c34.857cd8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.rastag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 840,
                                           "y": 1220,
                                           "wires": [
                                                   "478bd581.773b1c"
                                           "id": "f7ab960.ee03fe8",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 120,
                                           "y": 1180,
                                           "wires": [
                                                   "16fd25cd.411922"
                                           "id": "478bd581.773b1c",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1130,
                                           "y": 1180,
                                           "wires": [
                                                   "685c0011.4d76d8"
                                           "id": "685c0011.4d76d8",
                                           "type": "template",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.rasstart}},\"days\":[{{payload.rastag}}],\"output\":\"0\",\"endtime\":{{payload.rasend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1310,
                                           "y": 1180,
                                           "wires": [
                                                   "f742c03b.2b4018"
                                           "id": "6179abe5.5008cc",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Rasen_Startzeit_m",
                                           "attrname": "min",
                                           "x": 590,
                                           "y": 1040,
                                           "wires": [
                                                   "eff73484.e162f8"
                                           "id": "eff73484.e162f8",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 760,
                                           "y": 1040,
                                           "wires": [
                                                   "9a31aa7.81634d8",
                                                   "16fd25cd.411922"
                                           "id": "7c130cf9.58ddf4",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 390,
                                           "y": 1040,
                                           "wires": [
                                                   "6179abe5.5008cc"
                                           "id": "537f95ef.af8cf4",
                                           "name": "",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 500,
                                           "y": 1180,
                                           "wires": [
                                                   "7c888e93.75e008"
                                           "id": "ffade621.e21408",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Himbeeren"
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 260,
                                           "y": 1840,
                                           "wires": [
                                                   "2d9e3615.954982"
                                           "outputLabels": [
                                               "Info",
                                               "Chili"
                                           "id": "3e99677c.33493",
                                           "name": "Himbeeren",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.15",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 770,
                                           "y": 1860,
                                           "wires": []
                                           "id": "2d9e3615.954982",
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 530,
                                           "y": 1840,
                                           "wires": [
                                                   "3e99677c.33493"
                                           "id": "b1133be4.6945e8",
                                           "name": "Himbeeren Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Himbeeren_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 210,
                                           "y": 1540,
                                           "wires": [
                                                   "43163347.805d3c"
                                           "id": "5776e8d5.98b4a8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.himstart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 870,
                                           "y": 1640,
                                           "wires": [
                                                   "b5b9c48d.0ac7c8"
                                           "id": "93bbcc75.140c6",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 660,
                                           "y": 1680,
                                           "wires": [
                                                   "27b37ef4.39d9b2"
                                           "id": "aaf11e52.96428",
                                           "name": "Himbeeren Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Himbeeren_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 350,
                                           "y": 1680,
                                           "wires": [
                                                   "889ba824.5c7ba8"
                                           "id": "27b37ef4.39d9b2",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.himend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 870,
                                           "y": 1680,
                                           "wires": [
                                                   "b5b9c48d.0ac7c8"
                                           "id": "a2e37a01.8b062",
                                           "name": "Himbeeren Tage",
                                           "topic": "0_userdata.0.Bewässerung.Himbeeren_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 200,
                                           "y": 1740,
                                           "wires": [
                                                   "17cc38bc.d0b1df"
                                           "id": "17cc38bc.d0b1df",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.himtag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 860,
                                           "y": 1720,
                                           "wires": [
                                                   "b5b9c48d.0ac7c8"
                                           "id": "71fcb2df.72fd44",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 150,
                                           "y": 1680,
                                           "wires": [
                                                   "aaf11e52.96428"
                                           "id": "b5b9c48d.0ac7c8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1130,
                                           "y": 1680,
                                           "wires": [
                                                   "d35b19a6.f1acf"
                                           "id": "d35b19a6.f1acf",
                                           "type": "template",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.himstart}},\"days\":[{{payload.himtag}}],\"output\":\"0\",\"endtime\":{{payload.himend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1330,
                                           "y": 1680,
                                           "wires": [
                                                   "ffade621.e21408"
                                           "id": "58fac00.fbd1ac",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Himbeeren_Startzeit_m",
                                           "attrname": "min",
                                           "x": 610,
                                           "y": 1540,
                                           "wires": [
                                                   "46fe7ce9.fc5d64"
                                           "id": "46fe7ce9.fc5d64",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 780,
                                           "y": 1540,
                                           "wires": [
                                                   "5776e8d5.98b4a8",
                                                   "aaf11e52.96428"
                                           "id": "43163347.805d3c",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 410,
                                           "y": 1540,
                                           "wires": [
                                                   "58fac00.fbd1ac"
                                           "id": "889ba824.5c7ba8",
                                           "name": "",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 520,
                                           "y": 1680,
                                           "wires": [
                                                   "93bbcc75.140c6"
                                           "id": "6a1dc60e.2815c8",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Chili"
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 280,
                                           "y": 2280,
                                           "wires": [
                                                   "644cc02f.578248"
                                           "outputLabels": [
                                               "Info",
                                               "Chili"
                                           "id": "c739c937.d838",
                                           "name": "Chili",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.5",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 770,
                                           "y": 2300,
                                           "wires": []
                                           "id": "644cc02f.578248",
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 530,
                                           "y": 2300,
                                           "wires": [
                                                   "c739c937.d838"
                                           "id": "13823c3c.7d6a9c",
                                           "name": "Chili Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Chili_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 210,
                                           "y": 1980,
                                           "wires": [
                                                   "27224828.5dd5e8"
                                           "id": "c252fe8b.8de62",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.chistart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 890,
                                           "y": 2080,
                                           "wires": [
                                                   "a99a6d33.3ba328"
                                           "id": "10e12809.1df7c8",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 680,
                                           "y": 2120,
                                           "wires": [
                                                   "3b1211e.2f1936e"
                                           "id": "dd403d5.078954",
                                           "name": "Chili Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Chili_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 350,
                                           "y": 2120,
                                           "wires": [
                                                   "17acd138.a9cb87"
                                           "id": "3b1211e.2f1936e",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.chiend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 880,
                                           "y": 2120,
                                           "wires": [
                                                   "a99a6d33.3ba328"
                                           "id": "b6c311c.a8d61f",
                                           "name": "Chili Tage",
                                           "topic": "0_userdata.0.Bewässerung.Chili_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 200,
                                           "y": 2180,
                                           "wires": [
                                                   "79a48db9.90d15c"
                                           "id": "79a48db9.90d15c",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.chitag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 880,
                                           "y": 2160,
                                           "wires": [
                                                   "a99a6d33.3ba328"
                                           "id": "fe7dee7f.a8929",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 150,
                                           "y": 2120,
                                           "wires": [
                                                   "dd403d5.078954"
                                           "id": "a99a6d33.3ba328",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1150,
                                           "y": 2120,
                                           "wires": [
                                                   "ea332364.09e1a8"
                                           "id": "ea332364.09e1a8",
                                           "type": "template",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.chistart}},\"days\":[{{payload.chitag}}],\"output\":\"0\",\"endtime\":{{payload.chiend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1350,
                                           "y": 2120,
                                           "wires": [
                                                   "6a1dc60e.2815c8"
                                           "id": "99cc1f9a.000d5",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Chili_Startzeit_m",
                                           "attrname": "min",
                                           "x": 630,
                                           "y": 1980,
                                           "wires": [
                                                   "f31fe6d6.ea30f"
                                           "id": "f31fe6d6.ea30f",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 800,
                                           "y": 1980,
                                           "wires": [
                                                   "c252fe8b.8de62",
                                                   "dd403d5.078954"
                                           "id": "27224828.5dd5e8",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 430,
                                           "y": 1980,
                                           "wires": [
                                                   "99cc1f9a.000d5"
                                           "id": "17acd138.a9cb87",
                                           "name": "",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 540,
                                           "y": 2120,
                                           "wires": [
                                                   "10e12809.1df7c8"
                                           "id": "fb61e295.e1c3f8",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Gemuese"
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 240,
                                           "y": 2720,
                                           "wires": [
                                                   "eb50c5c1.3f81e8"
                                           "outputLabels": [
                                               "Info",
                                               "Chili"
                                           "id": "4d59c645.a9ef3",
                                           "name": "Gemüse",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.14",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 740,
                                           "y": 2740,
                                           "wires": []
                                           "id": "eb50c5c1.3f81e8",
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 490,
                                           "y": 2740,
                                           "wires": [
                                                   "4d59c645.a9ef3"
                                           "id": "bac661ce.7b14a8",
                                           "name": "Gemuese Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Gemuese_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 190,
                                           "y": 2420,
                                           "wires": [
                                                   "655ca02b.c39688"
                                           "id": "ede61f85.9b1fe8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.gemstart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 2520,
                                           "wires": [
                                                   "88855f2e.c147e8"
                                           "id": "2c5a53a9.e88674",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 640,
                                           "y": 2560,
                                           "wires": [
                                                   "fe9a251d.6c58b8"
                                           "id": "ce8ee0.d1b9192",
                                           "name": "Gemuese Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Gemuese_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 330,
                                           "y": 2560,
                                           "wires": [
                                                   "ad223f59.b03b3"
                                           "id": "fe9a251d.6c58b8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.gemend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 2560,
                                           "wires": [
                                                   "88855f2e.c147e8"
                                           "id": "8dd057c3.525f",
                                           "name": "Gemuese Tage",
                                           "topic": "0_userdata.0.Bewässerung.Gemuese_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 180,
                                           "y": 2620,
                                           "wires": [
                                                   "1ea15f91.006e4"
                                           "id": "1ea15f91.006e4",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.gemtag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 850,
                                           "y": 2600,
                                           "wires": [
                                                   "88855f2e.c147e8"
                                           "id": "704a9b39.fff60c",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 130,
                                           "y": 2560,
                                           "wires": [
                                                   "ce8ee0.d1b9192"
                                           "id": "88855f2e.c147e8",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1110,
                                           "y": 2560,
                                           "wires": [
                                                   "7695f95c.e0115"
                                           "id": "7695f95c.e0115",
                                           "type": "template",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.gemstart}},\"days\":[{{payload.gemtag}}],\"output\":\"0\",\"endtime\":{{payload.gemend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1310,
                                           "y": 2560,
                                           "wires": [
                                                   "fb61e295.e1c3f8"
                                           "id": "465c6378.063754",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Gemuese_Startzeit_m",
                                           "attrname": "min",
                                           "x": 590,
                                           "y": 2420,
                                           "wires": [
                                                   "71bb1787.93aa1"
                                           "id": "71bb1787.93aa1",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 760,
                                           "y": 2420,
                                           "wires": [
                                                   "ede61f85.9b1fe8",
                                                   "ce8ee0.d1b9192"
                                           "id": "655ca02b.c39688",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 390,
                                           "y": 2420,
                                           "wires": [
                                                   "465c6378.063754"
                                           "id": "ad223f59.b03b3",
                                           "name": "",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 500,
                                           "y": 2560,
                                           "wires": [
                                                   "2c5a53a9.e88674"
                                           "id": "509af3bd.f017f4",
                                           "startDay": "1",
                                           "refresh": 60,
                                           "devices": [
                                               "Feigenbaum"
                                           "eventMode": false,
                                           "eventOptions": [],
                                           "sendTopic": false,
                                           "lat": "46.98015",
                                           "lon": "9.5706316",
                                           "outputs": 2,
                                           "order": 1,
                                           "width": 0,
                                           "height": 0,
                                           "x": 260,
                                           "y": 3140,
                                           "wires": [
                                                   "5a50917e.fb2e08"
                                           "outputLabels": [
                                               "Info",
                                               "Chili"
                                           "id": "8d0f9b68.f48f6",
                                           "name": "Feigenbaum",
                                           "topic": "mqtt.0.ESP_Bewaesserung.GPIO.13",
                                           "ack": "false",
                                           "stateName": "",
                                           "role": "",
                                           "payloadType": "",
                                           "readonly": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 770,
                                           "y": 3160,
                                           "wires": []
                                           "id": "5a50917e.fb2e08",
                                           "type": "change",
                                           "rules": [
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "true",
                                                   "fromt": "bool",
                                                   "to": "1",
                                                   "tot": "num"
                                                   "t": "change",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "from": "false",
                                                   "fromt": "bool",
                                                   "to": "0",
                                                   "tot": "num"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 510,
                                           "y": 3160,
                                           "wires": [
                                                   "8d0f9b68.f48f6"
                                           "id": "a03757aa.177f78",
                                           "name": "Feigenbaum Startzeit",
                                           "topic": "0_userdata.0.Bewässerung.Feigenbaum_Startzeit",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 220,
                                           "y": 2840,
                                           "wires": [
                                                   "ae205d88.b3a16"
                                           "id": "880223f9.33fa5",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.feistart",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 860,
                                           "y": 2940,
                                           "wires": [
                                                   "e69125f9.5d323"
                                           "id": "4813b70.5ccf5c8",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 660,
                                           "y": 2980,
                                           "wires": [
                                                   "cc150fa0.200788"
                                           "id": "7a9f5936.318408",
                                           "name": "Feigenbaum Laufzeit",
                                           "topic": "0_userdata.0.Bewässerung.Feigenbaum_Laufzeit",
                                           "attrname": "lauf",
                                           "x": 340,
                                           "y": 2980,
                                           "wires": [
                                                   "7240e8b9.feeb68"
                                           "id": "cc150fa0.200788",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.feiend",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 860,
                                           "y": 2980,
                                           "wires": [
                                                   "e69125f9.5d323"
                                           "id": "dd944832.19d71",
                                           "name": "Feigenbaum Tage",
                                           "topic": "0_userdata.0.Bewässerung.Feigenbaum_Tage",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 210,
                                           "y": 3040,
                                           "wires": [
                                                   "42552839.ddf258"
                                           "id": "42552839.ddf258",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "send.feitag",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 860,
                                           "y": 3020,
                                           "wires": [
                                                   "e69125f9.5d323"
                                           "id": "4bd2bfd5.a0f29",
                                           "onlyack": "",
                                           "func": "rbe",
                                           "gap": "",
                                           "x": 100,
                                           "y": 2980,
                                           "wires": [
                                                   "7a9f5936.318408"
                                           "id": "e69125f9.5d323",
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "send",
                                                   "tot": "flow"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1130,
                                           "y": 2980,
                                           "wires": [
                                                   "f67212ea.6d15a"
                                           "id": "f67212ea.6d15a",
                                           "type": "template",
                                           "field": "payload",
                                           "fieldType": "msg",
                                           "template": "{\"timers\":[{\"starttime\":{{payload.feistart}},\"days\":[{{payload.feitag}}],\"output\":\"0\",\"endtime\":{{payload.feiend}}}],\"settings\":{\"disabledDevices\":[]}}",
                                           "output": "str",
                                           "x": 1330,
                                           "y": 2980,
                                           "wires": [
                                                   "509af3bd.f017f4"
                                           "id": "1c9bcf61.13c8b1",
                                           "name": "min",
                                           "topic": "0_userdata.0.Bewässerung.Feigenbaum_Startzeit_m",
                                           "attrname": "min",
                                           "x": 610,
                                           "y": 2840,
                                           "wires": [
                                                   "9ab0b244.3d9638"
                                           "id": "9ab0b244.3d9638",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 780,
                                           "y": 2840,
                                           "wires": [
                                                   "880223f9.33fa5",
                                                   "7a9f5936.318408"
                                           "id": "ae205d88.b3a16",
                                           "type": "function",
                                           "name": "",
                                           "outputs": 1,
                                           "noerr": 0,
                                           "initialize": "",
                                           "finalize": "",
                                           "libs": [],
                                           "x": 410,
                                           "y": 2840,
                                           "wires": [
                                                   "1c9bcf61.13c8b1"
                                           "id": "7240e8b9.feeb68",
                                           "name": "",
                                           "round": false,
                                           "decimals": 0,
                                           "x": 520,
                                           "y": 2980,
                                           "wires": [
                                                   "4813b70.5ccf5c8"
                                           "id": "df42ab16.59cb78",
                                           "type": "ui_group",
                                           "name": "Standard",
                                           "tab": "29502947.69c12e",
                                           "order": 1,
                                           "disp": true,
                                           "width": "6",
                                           "collapse": false
                                           "id": "29502947.69c12e",
                                           "type": "ui_tab",
                                           "name": "Home",
                                           "icon": "dashboard",
                                           "disabled": false,
                                           "hidden": false
                                    • mickymM mickym
                                      hafo
                                      @mickym Hier beim Vis füller funktioniert eigentlich alles wie gewünscht
                                             "id": "9e190b64.53d15",
                                             "z": "99194dc0.5d65f",
                                             "name": "Vis Auswahl",
                                             "topic": "0_userdata.0.Bewässerung.vis.Auswahl",
                                             "onlyack": "",
                                             "func": "rbe",
                                             "gap": "",
                                             "fireOnStart": "false",
                                             "x": 90,
                                             "y": 520,
                                             "wires": [
                                                     "1e3267dc.fdde18"
                                             "id": "1e3267dc.fdde18",
                                             "type": "switch",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "Chili",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Gewuertz",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Rasen",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Himbeeren",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Gemuese",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Feigenbaum",
                                                     "vt": "str"
                                                     "t": "eq",
                                                     "v": "Tomaten",
                                                     "vt": "str"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 7,
                                             "x": 260,
                                             "y": 520,
                                             "wires": [
                                                     "d701193.8d08d68",
                                                     "d61802a5.3c8ee8",
                                                     "ed935774.7ff95",
                                                     "6d7eebae.187484"
                                                     "6069718b.b27198",
                                                     "3064f4bf.b9cfd4",
                                                     "db6d1d71.321db",
                                                     "c50a6d57.163c98"
                                                     "6a6c068a.66fae",
                                                     "7c456758.fd2e28",
                                                     "420e5dd6.a6a794",
                                                     "fdab73fb.a29758"
                                                     "b29ffe85.62b778",
                                                     "a655384e.cc9f48",
                                                     "85581d0d.dcdac8",
                                                     "cb96de0f.567aa8"
                                                     "9a7fe8d.96ed618",
                                                     "8ecb2b31.69c9a",
                                                     "57cab2ad.5238ec",
                                                     "2bb7c24b.2e20ce"
                                                     "21765429.9e148c",
                                                     "96ac89c7.f640c",
                                                     "fe4ba9f8.37b3e8",
                                                     "a3da58b6.1c94d8"
                                                     "32de8143.168756",
                                                     "4e50060a.be7778",
                                                     "1386479f.8c24d",
                                                     "760b9f83.494e5"
                                             "id": "32de8143.168756",
                                             "name": "Tomaten",
                                             "attrname": "payload",
                                             "x": 680,
                                             "y": 300,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "b3bfd4c2.e5c2c8",
                                             "type": "split",
                                             "name": "",
                                             "splt": ",",
                                             "spltType": "str",
                                             "arraySplt": 1,
                                             "stream": false,
                                             "addname": "",
                                             "x": 1030,
                                             "y": 180,
                                             "wires": [
                                                     "1b19502c.f6aba"
                                             "id": "1b19502c.f6aba",
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "change",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "from": "0",
                                                     "fromt": "str",
                                                     "to": "false",
                                                     "tot": "bool"
                                                     "t": "change",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "from": "1",
                                                     "fromt": "str",
                                                     "to": "true",
                                                     "tot": "bool"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1210,
                                             "y": 180,
                                             "wires": [
                                                     "d6edd7f5.488038"
                                             "id": "d6edd7f5.488038",
                                             "type": "switch",
                                             "name": "",
                                             "rules": [
                                                     "t": "eq",
                                                     "v": "0",
                                                     "vt": "num"
                                                     "t": "eq",
                                                     "v": "1",
                                                     "vt": "num"
                                                     "t": "eq",
                                                     "v": "2",
                                                     "vt": "num"
                                                     "t": "eq",
                                                     "v": "3",
                                                     "vt": "num"
                                                     "t": "eq",
                                                     "v": "4",
                                                     "vt": "num"
                                                     "t": "eq",
                                                     "v": "5",
                                                     "vt": "num"
                                                     "t": "eq",
                                                     "v": "6",
                                                     "vt": "num"
                                             "checkall": "true",
                                             "repair": false,
                                             "outputs": 7,
                                             "x": 1390,
                                             "y": 180,
                                             "wires": [
                                                     "a79df2d.709cb1"
                                                     "b0e42158.9a50a"
                                                     "2fda9826.954298"
                                                     "13fd78fb.1e2217"
                                                     "192afa2f.c005b6"
                                                     "76e613ea.b8d75c"
                                                     "4b4341e2.22c508"
                                             "id": "6a6c068a.66fae",
                                             "name": "Rasen",
                                             "x": 670,
                                             "y": 140,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "6069718b.b27198",
                                             "name": "Gewuertz",
                                             "x": 680,
                                             "y": 100,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "b29ffe85.62b778",
                                             "x": 690,
                                             "y": 180,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "d701193.8d08d68",
                                             "name": "Chili",
                                             "x": 670,
                                             "y": 60,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "21765429.9e148c",
                                             "x": 690,
                                             "y": 260,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "9a7fe8d.96ed618",
                                             "name": "Gemuese",
                                             "x": 680,
                                             "y": 220,
                                             "wires": [
                                                     "b3bfd4c2.e5c2c8"
                                             "id": "a79df2d.709cb1",
                                             "name": "Mo",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.1Mo",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 60,
                                             "wires": []
                                             "id": "b0e42158.9a50a",
                                             "name": "Di",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.2Di",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 100,
                                             "wires": []
                                             "id": "2fda9826.954298",
                                             "name": "Mi",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.3Mi",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 140,
                                             "wires": []
                                             "id": "13fd78fb.1e2217",
                                             "name": "Do",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.4Do",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 180,
                                             "wires": []
                                             "id": "192afa2f.c005b6",
                                             "name": "Fr",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.5Fr",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 220,
                                             "wires": []
                                             "id": "76e613ea.b8d75c",
                                             "name": "Sa",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.6Sa",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 260,
                                             "wires": []
                                             "id": "4b4341e2.22c508",
                                             "name": "So",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.7So",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1590,
                                             "y": 300,
                                             "wires": []
                                             "id": "4e50060a.be7778",
                                             "name": "Tomaten",
                                             "x": 680,
                                             "y": 640,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "7c456758.fd2e28",
                                             "name": "Rasen",
                                             "x": 670,
                                             "y": 480,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "3064f4bf.b9cfd4",
                                             "name": "Gewuertz",
                                             "x": 680,
                                             "y": 440,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "a655384e.cc9f48",
                                             "x": 690,
                                             "y": 520,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "d61802a5.3c8ee8",
                                             "name": "Chili",
                                             "x": 670,
                                             "y": 400,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "96ac89c7.f640c",
                                             "x": 690,
                                             "y": 600,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "8ecb2b31.69c9a",
                                             "name": "Gemuese",
                                             "x": 680,
                                             "y": 560,
                                             "wires": [
                                                     "b3311a52.9de078"
                                             "id": "1386479f.8c24d",
                                             "name": "Tomaten",
                                             "x": 680,
                                             "y": 960,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "420e5dd6.a6a794",
                                             "name": "Rasen",
                                             "x": 670,
                                             "y": 800,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "db6d1d71.321db",
                                             "name": "Gewuertz",
                                             "x": 680,
                                             "y": 760,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "85581d0d.dcdac8",
                                             "x": 690,
                                             "y": 840,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "ed935774.7ff95",
                                             "name": "Chili",
                                             "x": 670,
                                             "y": 720,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "fe4ba9f8.37b3e8",
                                             "x": 690,
                                             "y": 920,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "57cab2ad.5238ec",
                                             "name": "Gemuese",
                                             "x": 680,
                                             "y": 880,
                                             "wires": [
                                                     "88eb3cc4.1f7df8"
                                             "id": "b3311a52.9de078",
                                             "name": "vis Laufzeit",
                                             "topic": "0_userdata.0.Bewässerung.vis.Laufzeit",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1210,
                                             "y": 620,
                                             "wires": []
                                             "id": "88eb3cc4.1f7df8",
                                             "name": "Startzeit h",
                                             "topic": "0_userdata.0.Bewässerung.vis.Startzeit_h",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1040,
                                             "y": 840,
                                             "wires": []
                                             "id": "760b9f83.494e5",
                                             "name": "Tomaten",
                                             "x": 680,
                                             "y": 1300,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "fdab73fb.a29758",
                                             "name": "Rasen",
                                             "x": 670,
                                             "y": 1140,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "c50a6d57.163c98",
                                             "name": "Gewuertz",
                                             "x": 680,
                                             "y": 1100,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "cb96de0f.567aa8",
                                             "x": 690,
                                             "y": 1180,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "6d7eebae.187484",
                                             "name": "Chili",
                                             "x": 670,
                                             "y": 1060,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "a3da58b6.1c94d8",
                                             "x": 690,
                                             "y": 1260,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "2bb7c24b.2e20ce",
                                             "name": "Gemuese",
                                             "x": 680,
                                             "y": 1220,
                                             "wires": [
                                                     "e50834b8.eed6d"
                                             "id": "e50834b8.eed6d",
                                             "name": "Startzeit m",
                                             "topic": "0_userdata.0.Bewässerung.vis.Startzeit_m",
                                             "ack": "false",
                                             "stateName": "",
                                             "role": "",
                                             "payloadType": "",
                                             "readonly": "",
                                             "stateUnit": "",
                                             "stateMin": "",
                                             "stateMax": "",
                                             "x": 1040,
                                             "y": 1200,
                                             "wires": []
                                             "id": "e873a002.44c598",
                                             "name": "",
                                             "topic": "0_userdata.0.Bewässerung.vis.tage.*",
                                             "onlyack": "",
                                             "func": "all",
                                             "gap": "",
                                             "x": 1190,
                                             "y": 440,
                                             "wires": [
                                                     "263f94d9.d8b034"
                                             "id": "263f94d9.d8b034",
                                             "type": "change",
                                             "name": "",
                                             "rules": [
                                                     "t": "change",
                                                     "p": "topic",
                                                     "pt": "msg",
                                                     "from": ".*\\/(.*)$",
                                                     "fromt": "re",
                                                     "to": "$1",
                                                     "tot": "str"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1470,
                                             "y": 440,
                                             "wires": [
                                                     "3ba68664.834632"
                                             "id": "3ba68664.834632",
                                             "type": "function",
                                             "name": "setze Flow variable",
                                             "func": "fTopic='days.' + msg.topic;\nflow.set(fTopic,msg.payload);\nreturn null;",
                                             "outputs": 1,
                                             "noerr": 0,
                                             "initialize": "",
                                             "finalize": "",
                                             "libs": [],
                                             "x": 1690,
                                             "y": 440,
                                             "wires": [
                                      • mickymM mickym
                                        hafo
                                        @mickym und beim Speichern sind einige Punkte noch gar nicht angeschlossen welche ich nicht ändern kann
                                               "id": "5a0431bb.bb2aa",
                                               "z": "4524d790.7edb8",
                                               "name": "Trigger",
                                               "topic": "0_userdata.0.Bewässerung.vis.Trigger",
                                               "onlyack": false,
                                               "func": "all",
                                               "gap": "",
                                               "x": 50,
                                               "y": 540,
                                               "wires": [
                                                       "e1c0ce04.dc943",
                                                       "dd0d5311.5fd338",
                                                       "3b3d0198.835f8e"
                                               "id": "939eb60f.3fddd8",
                                               "name": "Auswahl",
                                               "x": 420,
                                               "y": 540,
                                               "wires": [
                                                       "f4ee1dde.995a48"
                                               "id": "f4ee1dde.995a48",
                                               "type": "switch",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "Chili",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Gewuertz",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Rasen",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Himbeeren",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Gemuese",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Feigenbaum",
                                                       "vt": "str"
                                                       "t": "eq",
                                                       "v": "Tomaten",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 7,
                                               "x": 640,
                                               "y": 540,
                                               "wires": [
                                                       "6824380c.31de8",
                                                       "e96d9792.c38ca8",
                                                       "4ddfdab2.40b44c"
                                                       "27ccefaf.7772b8",
                                                       "bc8b762e.a2b03",
                                                       "3a5b4365.9f12f4"
                                                       "1c52b2f5.2355b5",
                                                       "bbd132d0.1499a8",
                                                       "1ad712f3.535975"
                                                       "f7d776ee.abc678",
                                                       "116a72ac.bcfd1d",
                                                       "9f318fdc.0e71c"
                                                       "63af54e3.178164",
                                                       "9c3b0be0.5f03c",
                                                       "a99e178f.55716"
                                                       "1fa7d74b.223c81",
                                                       "488b900f.2e8fa8",
                                                       "925569ae.414b78",
                                                       "59cd7ef3.1e074"
                                                       "fbd3e57a.8cf3c8",
                                                       "d3d4682e.04a438",
                                                       "9048443a.d290c8",
                                                       "82dfdd05.4d8e1"
                                               "id": "6824380c.31de8",
                                               "x": 1040,
                                               "y": 20,
                                               "wires": [
                                                       "489cc313.0c59bc"
                                               "id": "e96d9792.c38ca8",
                                               "x": 1050,
                                               "y": 60,
                                               "wires": [
                                                       "932a9248.21b268"
                                               "id": "4ddfdab2.40b44c",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 100,
                                               "wires": [
                                                       "e31c1a25.6b3868"
                                               "id": "489cc313.0c59bc",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1290,
                                               "y": 20,
                                               "wires": []
                                               "id": "932a9248.21b268",
                                               "name": "Feigenbaum Startzeit m",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1330,
                                               "y": 60,
                                               "wires": []
                                               "id": "e31c1a25.6b3868",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1290,
                                               "y": 100,
                                               "wires": []
                                               "id": "422d5faa.75ad48",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "complete": "false",
                                               "statusVal": "",
                                               "statusType": "auto",
                                               "x": 1050,
                                               "y": 140,
                                               "wires": []
                                               "id": "27ccefaf.7772b8",
                                               "x": 1040,
                                               "y": 180,
                                               "wires": [
                                                       "679934ff.917364"
                                               "id": "bc8b762e.a2b03",
                                               "x": 1050,
                                               "y": 220,
                                               "wires": [
                                                       "9ae748ec.4841b8"
                                               "id": "3a5b4365.9f12f4",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 260,
                                               "wires": [
                                                       "b146a4d4.25c008"
                                               "id": "679934ff.917364",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 180,
                                               "wires": []
                                               "id": "9ae748ec.4841b8",
                                               "name": "Gewuertz Startzeit m",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1320,
                                               "y": 220,
                                               "wires": []
                                               "id": "b146a4d4.25c008",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 260,
                                               "wires": []
                                               "id": "7ed32ced.72114c",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 1050,
                                               "y": 300,
                                               "wires": []
                                               "id": "1c52b2f5.2355b5",
                                               "x": 1040,
                                               "y": 340,
                                               "wires": [
                                                       "b79f93d4.3001e"
                                               "id": "bbd132d0.1499a8",
                                               "x": 1050,
                                               "y": 380,
                                               "wires": [
                                                       "3488b4bd.05ae0c"
                                               "id": "1ad712f3.535975",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 420,
                                               "wires": [
                                                       "54929399.82fab4"
                                               "id": "b79f93d4.3001e",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1300,
                                               "y": 340,
                                               "wires": []
                                               "id": "3488b4bd.05ae0c",
                                               "name": "Rasen Startzeit m",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 380,
                                               "wires": []
                                               "id": "54929399.82fab4",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1300,
                                               "y": 420,
                                               "wires": []
                                               "id": "6a95c670.57983",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 1050,
                                               "y": 460,
                                               "wires": []
                                               "id": "f7d776ee.abc678",
                                               "x": 1040,
                                               "y": 500,
                                               "wires": [
                                                       "765d7d00.e345d4"
                                               "id": "116a72ac.bcfd1d",
                                               "x": 1050,
                                               "y": 540,
                                               "wires": [
                                                       "c61adffd.1f67b8"
                                               "id": "9f318fdc.0e71c",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 580,
                                               "wires": [
                                                       "cfbb3f17.ed621"
                                               "id": "765d7d00.e345d4",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 500,
                                               "wires": []
                                               "id": "c61adffd.1f67b8",
                                               "name": "Himbeeren Startzeit m",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1320,
                                               "y": 540,
                                               "wires": []
                                               "id": "cfbb3f17.ed621",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 580,
                                               "wires": []
                                               "id": "dd39475.6a48eb8",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 1050,
                                               "y": 620,
                                               "wires": []
                                               "id": "63af54e3.178164",
                                               "x": 1040,
                                               "y": 660,
                                               "wires": [
                                                       "1b25caae.27731d"
                                               "id": "9c3b0be0.5f03c",
                                               "x": 1050,
                                               "y": 700,
                                               "wires": [
                                                       "ea0f0759.38f0e8"
                                               "id": "a99e178f.55716",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 740,
                                               "wires": [
                                                       "3567546e.7a226c"
                                               "id": "1b25caae.27731d",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 660,
                                               "wires": []
                                               "id": "ea0f0759.38f0e8",
                                               "name": "Gemuese Startzeit m",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1320,
                                               "y": 700,
                                               "wires": []
                                               "id": "3567546e.7a226c",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 740,
                                               "wires": []
                                               "id": "f46dbee3.80c9b8",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 1050,
                                               "y": 780,
                                               "wires": []
                                               "id": "1fa7d74b.223c81",
                                               "x": 1040,
                                               "y": 820,
                                               "wires": [
                                                       "40c36cb7.9f548c"
                                               "id": "488b900f.2e8fa8",
                                               "x": 1050,
                                               "y": 860,
                                               "wires": [
                                                       "d7d41d45.826528"
                                               "id": "925569ae.414b78",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 900,
                                               "wires": [
                                                       "b797b23.ae5c75"
                                               "id": "40c36cb7.9f548c",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1320,
                                               "y": 820,
                                               "wires": []
                                               "id": "d7d41d45.826528",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1330,
                                               "y": 860,
                                               "wires": []
                                               "id": "b797b23.ae5c75",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1320,
                                               "y": 900,
                                               "wires": []
                                               "id": "fbd3e57a.8cf3c8",
                                               "x": 1040,
                                               "y": 980,
                                               "wires": [
                                                       "d80e42f7.54a0a8"
                                               "id": "d3d4682e.04a438",
                                               "x": 1050,
                                               "y": 1020,
                                               "wires": [
                                                       "590624f7.4905bc"
                                               "id": "9048443a.d290c8",
                                               "name": "Laufzeit",
                                               "x": 1040,
                                               "y": 1060,
                                               "wires": [
                                                       "37ff6b5e.5100b4"
                                               "id": "d80e42f7.54a0a8",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 980,
                                               "wires": []
                                               "id": "590624f7.4905bc",
                                               "name": "Tomaten Startzeit m",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1320,
                                               "y": 1020,
                                               "wires": []
                                               "id": "37ff6b5e.5100b4",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1310,
                                               "y": 1060,
                                               "wires": []
                                               "id": "e1c0ce04.dc943",
                                               "type": "delay",
                                               "name": "500ms",
                                               "pauseType": "delay",
                                               "timeout": "500",
                                               "timeoutUnits": "milliseconds",
                                               "rate": "1",
                                               "nbRateUnits": "1",
                                               "rateUnits": "second",
                                               "randomFirst": "1",
                                               "randomLast": "5",
                                               "randomUnits": "seconds",
                                               "drop": false,
                                               "x": 90,
                                               "y": 640,
                                               "wires": [
                                                       "9dc503de.f151c8"
                                               "id": "431d5592.997bfc",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 530,
                                               "y": 640,
                                               "wires": []
                                               "id": "9dc503de.f151c8",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "false",
                                                       "tot": "bool"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 330,
                                               "y": 640,
                                               "wires": [
                                                       "431d5592.997bfc"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "days",
                                                       "tot": "flow"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 1100,
                                               "wires": [
                                                       "5317be7b.ef4338",
                                                       "d22a9254.04dc08"
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1980,
                                               "y": 1100,
                                               "wires": []
                                               "type": "split",
                                               "name": "",
                                               "splt": "\\n",
                                               "spltType": "str",
                                               "arraySplt": 1,
                                               "stream": false,
                                               "addname": "",
                                               "x": 1430,
                                               "y": 1100,
                                               "wires": [
                                                       "29b86736.dbc0f8"
                                               "type": "join",
                                               "name": "",
                                               "mode": "custom",
                                               "build": "string",
                                               "key": "topic",
                                               "joiner": ",",
                                               "timeout": "",
                                               "count": "",
                                               "reduceExp": "",
                                               "reduceInit": "",
                                               "reduceFixup": "",
                                               "x": 1790,
                                               "y": 1100,
                                               "wires": [
                                                       "e7dc8e38.b0003"
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "change",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "from": "true",
                                                       "fromt": "bool",
                                                       "to": "1",
                                                       "tot": "str"
                                                       "t": "change",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "from": "false",
                                                       "fromt": "bool",
                                                       "to": "0",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1610,
                                               "y": 1100,
                                               "wires": [
                                                       "cb07faa.5e09e08"
                                               "id": "dd0d5311.5fd338",
                                               "type": "switch",
                                               "name": "",
                                               "rules": [
                                                       "t": "eq",
                                                       "v": "true",
                                                       "vt": "str"
                                               "checkall": "true",
                                               "repair": false,
                                               "outputs": 1,
                                               "x": 230,
                                               "y": 540,
                                               "wires": [
                                                       "939eb60f.3fddd8"
                                               "id": "59cd7ef3.1e074",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "to": "days",
                                                       "tot": "flow"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1070,
                                               "y": 940,
                                               "wires": [
                                                       "db94aeb0.49345"
                                               "id": "5317be7b.ef4338",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "set",
                                                       "p": "topic",
                                                       "pt": "msg",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1280,
                                               "y": 1100,
                                               "wires": [
                                                       "4760a6ff.969fe8",
                                                       "d22a9254.04dc08"
                                               "id": "73707462.c1cf2c",
                                               "ack": "false",
                                               "stateName": "",
                                               "role": "",
                                               "payloadType": "",
                                               "readonly": "",
                                               "stateUnit": "",
                                               "stateMin": "",
                                               "stateMax": "",
                                               "x": 1830,
                                               "y": 940,
                                               "wires": []
                                               "id": "db94aeb0.49345",
                                               "type": "split",
                                               "name": "",
                                               "splt": "\\n",
                                               "spltType": "str",
                                               "arraySplt": 1,
                                               "stream": false,
                                               "addname": "",
                                               "x": 1270,
                                               "y": 940,
                                               "wires": [
                                                       "32f703ab.b2f2fc"
                                               "id": "763e93da.627a34",
                                               "type": "join",
                                               "name": "",
                                               "mode": "custom",
                                               "build": "string",
                                               "key": "topic",
                                               "joiner": ",",
                                               "timeout": "",
                                               "count": "",
                                               "reduceExp": "",
                                               "reduceInit": "",
                                               "reduceFixup": "",
                                               "x": 1630,
                                               "y": 940,
                                               "wires": [
                                                       "73707462.c1cf2c"
                                               "id": "32f703ab.b2f2fc",
                                               "type": "change",
                                               "name": "",
                                               "rules": [
                                                       "t": "change",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "from": "true",
                                                       "fromt": "bool",
                                                       "to": "1",
                                                       "tot": "str"
                                                       "t": "change",
                                                       "p": "payload",
                                                       "pt": "msg",
                                                       "from": "false",
                                                       "fromt": "bool",
                                                       "to": "0",
                                                       "tot": "str"
                                               "action": "",
                                               "property": "",
                                               "from": "",
                                               "to": "",
                                               "reg": false,
                                               "x": 1450,
                                               "y": 940,
                                               "wires": [
                                                       "763e93da.627a34"
                                               "id": "d22a9254.04dc08",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 1500,
                                               "y": 1260,
                                               "wires": []
                                               "id": "3b3d0198.835f8e",
                                               "type": "debug",
                                               "name": "",
                                               "active": true,
                                               "tosidebar": true,
                                               "console": false,
                                               "tostatus": false,
                                               "statusVal": "",
                                               "x": 180,
                                               "y": 440,
                                               "wires": []
                                        • H hafo
                                                 "name": "Trigger",
                                                 "onlyack": false,
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 50,
                                                 "y": 540,
                                                 "wires": [
                                                         "e1c0ce04.dc943",
                                                         "dd0d5311.5fd338",
                                                         "3b3d0198.835f8e"
                                                 "name": "Auswahl",
                                                 "x": 420,
                                                 "y": 540,
                                                 "wires": [
                                                         "f4ee1dde.995a48"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "Chili",
                                                         "vt": "str"
                                                         "t": "eq",
                                                         "v": "Gewuertz",
                                                         "vt": "str"
                                                         "t": "eq",
                                                         "v": "Rasen",
                                                         "vt": "str"
                                                         "t": "eq",
                                                         "v": "Himbeeren",
                                                         "vt": "str"
                                                         "t": "eq",
                                                         "v": "Gemuese",
                                                         "vt": "str"
                                                         "t": "eq",
                                                         "v": "Feigenbaum",
                                                         "vt": "str"
                                                         "t": "eq",
                                                         "v": "Tomaten",
                                                         "vt": "str"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 7,
                                                 "x": 640,
                                                 "y": 540,
                                                 "wires": [
                                                         "6824380c.31de8",
                                                         "e96d9792.c38ca8",
                                                         "4ddfdab2.40b44c"
                                                         "27ccefaf.7772b8",
                                                         "bc8b762e.a2b03",
                                                         "3a5b4365.9f12f4"
                                                         "1c52b2f5.2355b5",
                                                         "bbd132d0.1499a8",
                                                         "1ad712f3.535975"
                                                         "f7d776ee.abc678",
                                                         "116a72ac.bcfd1d",
                                                         "9f318fdc.0e71c"
                                                         "63af54e3.178164",
                                                         "9c3b0be0.5f03c",
                                                         "a99e178f.55716"
                                                         "1fa7d74b.223c81",
                                                         "488b900f.2e8fa8",
                                                         "925569ae.414b78",
                                                         "59cd7ef3.1e074"
                                                         "fbd3e57a.8cf3c8",
                                                         "d3d4682e.04a438",
                                                         "9048443a.d290c8",
                                                         "82dfdd05.4d8e1"
                                                 "x": 1040,
                                                 "y": 20,
                                                 "wires": [
                                                         "489cc313.0c59bc"
                                                 "x": 1050,
                                                 "y": 60,
                                                 "wires": [
                                                         "932a9248.21b268"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 100,
                                                 "wires": [
                                                         "e31c1a25.6b3868"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1290,
                                                 "y": 20,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1330,
                                                 "y": 60,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1290,
                                                 "y": 100,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1050,
                                                 "y": 140,
                                                 "wires": []
                                                 "x": 1040,
                                                 "y": 180,
                                                 "wires": [
                                                         "679934ff.917364"
                                                 "x": 1050,
                                                 "y": 220,
                                                 "wires": [
                                                         "9ae748ec.4841b8"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 260,
                                                 "wires": [
                                                         "b146a4d4.25c008"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 180,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1320,
                                                 "y": 220,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 260,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1050,
                                                 "y": 300,
                                                 "wires": []
                                                 "x": 1040,
                                                 "y": 340,
                                                 "wires": [
                                                         "b79f93d4.3001e"
                                                 "x": 1050,
                                                 "y": 380,
                                                 "wires": [
                                                         "3488b4bd.05ae0c"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 420,
                                                 "wires": [
                                                         "54929399.82fab4"
                                                 "type": "ioBroker out",
                                                 "ack": "false",
                                                 "autoCreate": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1300,
                                                 "y": 340,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 380,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1300,
                                                 "y": 420,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1050,
                                                 "y": 460,
                                                 "wires": []
                                                 "x": 1040,
                                                 "y": 500,
                                                 "wires": [
                                                         "765d7d00.e345d4"
                                                 "x": 1050,
                                                 "y": 540,
                                                 "wires": [
                                                         "c61adffd.1f67b8"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 580,
                                                 "wires": [
                                                         "cfbb3f17.ed621"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 500,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1320,
                                                 "y": 540,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 580,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1050,
                                                 "y": 620,
                                                 "wires": []
                                                 "x": 1040,
                                                 "y": 660,
                                                 "wires": [
                                                         "1b25caae.27731d"
                                                 "x": 1050,
                                                 "y": 700,
                                                 "wires": [
                                                         "ea0f0759.38f0e8"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 740,
                                                 "wires": [
                                                         "3567546e.7a226c"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 660,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1320,
                                                 "y": 700,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 740,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1050,
                                                 "y": 780,
                                                 "wires": []
                                                 "type": "ioBroker get",
                                                 "payloadType": "value",
                                                 "x": 1040,
                                                 "y": 820,
                                                 "wires": [
                                                         "40c36cb7.9f548c"
                                                 "x": 1050,
                                                 "y": 860,
                                                 "wires": [
                                                         "d7d41d45.826528"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 900,
                                                 "wires": [
                                                         "b797b23.ae5c75"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1320,
                                                 "y": 820,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1330,
                                                 "y": 860,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1320,
                                                 "y": 900,
                                                 "wires": []
                                                 "x": 1040,
                                                 "y": 980,
                                                 "wires": [
                                                         "d80e42f7.54a0a8"
                                                 "x": 1050,
                                                 "y": 1020,
                                                 "wires": [
                                                         "590624f7.4905bc"
                                                 "name": "Laufzeit",
                                                 "x": 1040,
                                                 "y": 1060,
                                                 "wires": [
                                                         "37ff6b5e.5100b4"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 980,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1320,
                                                 "y": 1020,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1310,
                                                 "y": 1060,
                                                 "wires": []
                                                 "type": "delay",
                                                 "name": "500ms",
                                                 "timeout": "500",
                                                 "rate": "1",
                                                 "nbRateUnits": "1",
                                                 "randomFirst": "1",
                                                 "randomLast": "5",
                                                 "drop": false,
                                                 "x": 90,
                                                 "y": 640,
                                                 "wires": [
                                                         "9dc503de.f151c8"
                                                 "name": "Speichern",
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 530,
                                                 "y": 640,
                                                 "wires": []
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 330,
                                                 "y": 640,
                                                 "wires": [
                                                         "431d5592.997bfc"
                                                 "id": "82dfdd05.4d8e1",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "days",
                                                         "tot": "flow"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1070,
                                                 "y": 1100,
                                                 "wires": [
                                                         "5317be7b.ef4338",
                                                         "d22a9254.04dc08"
                                                 "id": "e7dc8e38.b0003",
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1980,
                                                 "y": 1100,
                                                 "wires": []
                                                 "id": "4760a6ff.969fe8",
                                                 "type": "split",
                                                 "name": "",
                                                 "splt": "\\n",
                                                 "spltType": "str",
                                                 "arraySplt": 1,
                                                 "arraySpltType": "len",
                                                 "stream": false,
                                                 "addname": "",
                                                 "x": 1430,
                                                 "y": 1100,
                                                 "wires": [
                                                         "29b86736.dbc0f8"
                                                 "id": "cb07faa.5e09e08",
                                                 "type": "join",
                                                 "name": "",
                                                 "mode": "custom",
                                                 "build": "string",
                                                 "property": "payload",
                                                 "propertyType": "msg",
                                                 "key": "topic",
                                                 "joiner": ",",
                                                 "joinerType": "str",
                                                 "accumulate": false,
                                                 "timeout": "",
                                                 "count": "",
                                                 "reduceRight": false,
                                                 "reduceExp": "",
                                                 "reduceInit": "",
                                                 "reduceInitType": "",
                                                 "reduceFixup": "",
                                                 "x": 1790,
                                                 "y": 1100,
                                                 "wires": [
                                                         "e7dc8e38.b0003"
                                                 "id": "29b86736.dbc0f8",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "true",
                                                         "fromt": "bool",
                                                         "to": "1",
                                                         "tot": "str"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "false",
                                                         "fromt": "bool",
                                                         "to": "0",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1610,
                                                 "y": 1100,
                                                 "wires": [
                                                         "cb07faa.5e09e08"
                                                 "type": "switch",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "true",
                                                         "vt": "str"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 1,
                                                 "x": 230,
                                                 "y": 540,
                                                 "wires": [
                                                         "939eb60f.3fddd8"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "days",
                                                         "tot": "flow"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1070,
                                                 "y": 940,
                                                 "wires": [
                                                         "db94aeb0.49345"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "topic",
                                                         "pt": "msg",
                                                         "to": "0_userdata.0.Bewässerung.Tomaten_Tage",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1280,
                                                 "y": 1100,
                                                 "wires": [
                                                         "4760a6ff.969fe8",
                                                         "d22a9254.04dc08"
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 1830,
                                                 "y": 940,
                                                 "wires": []
                                                 "type": "split",
                                                 "name": "",
                                                 "splt": "\\n",
                                                 "spltType": "str",
                                                 "arraySplt": 1,
                                                 "stream": false,
                                                 "addname": "",
                                                 "x": 1270,
                                                 "y": 940,
                                                 "wires": [
                                                         "32f703ab.b2f2fc"
                                                 "type": "join",
                                                 "name": "",
                                                 "mode": "custom",
                                                 "build": "string",
                                                 "key": "topic",
                                                 "joiner": ",",
                                                 "timeout": "",
                                                 "count": "",
                                                 "reduceExp": "",
                                                 "reduceInit": "",
                                                 "reduceFixup": "",
                                                 "x": 1630,
                                                 "y": 940,
                                                 "wires": [
                                                         "73707462.c1cf2c"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "true",
                                                         "fromt": "bool",
                                                         "to": "1",
                                                         "tot": "str"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "false",
                                                         "fromt": "bool",
                                                         "to": "0",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1450,
                                                 "y": 940,
                                                 "wires": [
                                                         "763e93da.627a34"
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1500,
                                                 "y": 1260,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 180,
                                                 "y": 440,
                                                 "wires": []
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @hafo Nun wie gesagt an dem TimerFlow haben wir ja nichts gemacht - den lass ich mal aussen vor. Du hast ja nun 2 Debug Nodes an Deinen Speichern Flow gehängt. Kommt da was raus und was?
                                          Du musst halt systematisch den Flow verfolgen.
                                          H 1 Antwort Letzte Antwort
