  4. DasWetter macht Fehler ...
daswetter meldungdaswetter
4 Beiträge 2 Kommentatoren 369 Aufrufe 2 Beobachtet
  • RoboCopR Offline
    RoboCopR Offline
    RoboCop
    daswetter bring Fehler im LOG aber sonst kann ich nichts feststellen...
    daswetter.0	2021-05-13 19:45:31.824	info	(51926) cleaned everything up...
    daswetter.0	2021-05-13 19:45:31.297	info	(51926) Terminated (NO_ERROR): Without reason
    daswetter.0	2021-05-13 19:45:24.432	info	(51926) still wrong data structure from server received! repaired...
    daswetter.0	2021-05-13 19:45:11.965	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.834	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.705	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.571	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.440	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.308	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.153	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:11.025	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:10.689	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:10.466	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:10.307	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:10.146	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:10.011	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:09.817	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:09.687	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:09.552	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:09.207	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.984	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.824	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.663	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.495	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.350	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.182	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:08.049	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:07.556	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:07.380	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:07.205	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:07.027	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:06.392	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:06.243	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:06.085	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:05.917	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:04.951	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:04.808	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:04.551	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:04.412	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:04.238	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:04.034	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:03.882	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
    daswetter.0	2021-05-13 19:45:03.732	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
    tuya.0	2021-05-13 19:45:03.367	info	(23904) 3500016168c63adcb7ec Init with IP=192.168.178.40, Key=755fc3008961d8cc, Version=3.1
    daswetter.0	2021-05-13 19:45:02.315	info	(51926) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.18.4, js-controller: 3.2.16
    wer kann mir helfen?
    • RoboCopR RoboCop
      @robocop sagte in DasWetter macht Fehler ...:
      Die Suchfunktion.
      https://forum.iobroker.net/topic/44962/warnung-beim-das-wetter-adapter
      RoboCopR 1 Antwort Letzte Antwort
        Die Suchfunktion.
        RoboCopR Offline
        RoboCopR Offline
        RoboCop
        schrieb am zuletzt editiert von RoboCop
        @thomas-braun Danke für den Link, ich hatte die SuchFunktion bemüt, aber wenn man/frau/inter nach "daswetter" sucht findet man/frau/inter nichts passendes. Werde beim nächsten Suchen verschiedene Schreibweisen des Begriffes versuchen.
        Aber trotzdem Danke für den Hinweis.
        LG Robbie
        • RoboCopR RoboCop
          LG Robbie
          @robocop
          Ich habe nach der Fehlermeldung gesucht.
