<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DasWetter macht Fehler ...]]></title><description><![CDATA[<p dir="auto">daswetter bring Fehler im LOG aber sonst kann ich nichts feststellen...</p>
<pre><code>daswetter.0	2021-05-13 19:45:31.824	info	(51926) cleaned everything up...
daswetter.0	2021-05-13 19:45:31.297	info	(51926) Terminated (NO_ERROR): Without reason
daswetter.0	2021-05-13 19:45:24.432	info	(51926) still wrong data structure from server received! repaired...
daswetter.0	2021-05-13 19:45:11.965	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.834	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.705	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.571	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.440	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.308	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.153	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:11.025	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:10.689	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:10.466	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:10.307	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:10.146	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:10.011	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:09.817	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:09.687	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:09.552	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:09.207	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.984	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.824	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.663	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.495	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.350	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.182	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:08.049	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:07.556	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:07.380	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:07.205	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:07.027	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:06.392	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:06.243	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:06.085	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:05.917	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:04.951	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 8","role":"weather"}}} {"type":"channel","common":{"name":"Hour 8","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:04.808	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}} {"type":"channel","common":{"name":"Hour 7","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:04.551	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}} {"type":"channel","common":{"name":"Hour 6","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:04.412	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 5","role":"weather"}}} {"type":"channel","common":{"name":"Hour 5","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:04.238	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 4","role":"weather"}}} {"type":"channel","common":{"name":"Hour 4","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:04.034	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 3","role":"weather"}}} {"type":"channel","common":{"name":"Hour 3","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:03.882	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 2","role":"weather"}}} {"type":"channel","common":{"name":"Hour 2","role":"weather"},"native":{},"from":"system.adapter.daswet
daswetter.0	2021-05-13 19:45:03.732	warn	(51926) change object {"type":"channel","common":{"common":{"name":"Hour 1","role":"weather"}}} {"type":"channel","common":{"name":"Hour 1","role":"weather"},"native":{},"from":"system.adapter.daswet
tuya.0	2021-05-13 19:45:03.367	info	(23904) 3500016168c63adcb7ec Init with IP=192.168.178.40, Key=755fc3008961d8cc, Version=3.1
daswetter.0	2021-05-13 19:45:02.315	info	(51926) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.18.4, js-controller: 3.2.16
</code></pre>
<p dir="auto">wer kann mir helfen?</p>
]]></description><link>https://forum.iobroker.net/topic/44992/daswetter-macht-fehler</link><generator>RSS for Node</generator><lastBuildDate>Sun, 24 May 2026 14:37:04 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/44992.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 May 2021 17:58:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DasWetter macht Fehler ... on Fri, 14 May 2021 06:27:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robocop" aria-label="Profile: robocop">@<bdi>robocop</bdi></a><br />
Ich habe nach der Fehlermeldung gesucht.</p>
]]></description><link>https://forum.iobroker.net/post/628642</link><guid isPermaLink="true">https://forum.iobroker.net/post/628642</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 14 May 2021 06:27:03 GMT</pubDate></item><item><title><![CDATA[Reply to DasWetter macht Fehler ... on Fri, 14 May 2021 06:25:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Danke für den Link, ich hatte die SuchFunktion bemüt, aber wenn man/frau/inter nach "daswetter" sucht findet man/frau/inter nichts passendes. Werde beim nächsten Suchen verschiedene Schreibweisen des Begriffes versuchen.<br />
Aber trotzdem Danke für den Hinweis.</p>
<p dir="auto">LG Robbie</p>
]]></description><link>https://forum.iobroker.net/post/628640</link><guid isPermaLink="true">https://forum.iobroker.net/post/628640</guid><dc:creator><![CDATA[RoboCop]]></dc:creator><pubDate>Fri, 14 May 2021 06:25:56 GMT</pubDate></item><item><title><![CDATA[Reply to DasWetter macht Fehler ... on Thu, 13 May 2021 18:06:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robocop" aria-label="Profile: robocop">@<bdi>robocop</bdi></a> sagte in <a href="/post/628444">DasWetter macht Fehler ...</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">Die Suchfunktion.</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/44962/warnung-beim-das-wetter-adapter">https://forum.iobroker.net/topic/44962/warnung-beim-das-wetter-adapter</a></p>
]]></description><link>https://forum.iobroker.net/post/628457</link><guid isPermaLink="true">https://forum.iobroker.net/post/628457</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 13 May 2021 18:06:44 GMT</pubDate></item></channel></rss>
