  4. Fehlermeldung bei js-controller Update
2 Beiträge 2 Kommentatoren 338 Aufrufe 2 Beobachtet
    sunshineh
    ich möchte meinen js-controller updaten, bekomme aber leider folgende Fehlermeldung
    Update js-controller from @3.2.16 to @3.3.7
    NPM version: 6.14.12
    npm install iobroker.js-controller@3.3.7 --loglevel error --unsafe-perm --prefix                     "/opt/iobroker" (System call)
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-her                    dsman-converters/node_modules/acorn-globals
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/io                    broker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals                    '
    npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/                    iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globa                    ls'] {
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee                    -herdsman-converters/node_modules/acorn-globals'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the                     current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check t                    he
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR!     /home/iobroker/.npm/_logs/2021-05-03T06_51_39_477Z-debug.log
    host.ioBroker-GartenHalle Cannot install iobroker.js-controller@3.3.7: 243
    Was kann ich tun?
    • S sunshineh
      npm ERR! errno -13
      npm ERR! }
      npm ERR!
      npm ERR!
      Was kann ich tun?
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @sunshineh iobroker fixer durchlaufen lassen. Der Update Vorgang kann auf bestimmte Verzeichnisse nicht schreibend zugreifen. Da hat jemand als root oder mit sudo hantiert.
      A.
