<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehlermeldung bei js-controller Update]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
ich möchte meinen js-controller updaten, bekomme aber leider folgende Fehlermeldung</p>
<pre><code>Update js-controller from @3.2.16 to @3.3.7
NPM version: 6.14.12
npm install iobroker.js-controller@3.3.7 --loglevel error --unsafe-perm --prefix                     "/opt/iobroker" (System call)
npm ERR! code EACCES
npm ERR! syscall access
npm ERR! path /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-her                    dsman-converters/node_modules/acorn-globals
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/io                    broker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globals                    '
npm ERR!  [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/                    iobroker.zigbee/node_modules/zigbee-herdsman-converters/node_modules/acorn-globa                    ls'] {
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'access',
npm ERR!   path: '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee                    -herdsman-converters/node_modules/acorn-globals'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the                     current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check t                    he
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.
npm ERR!     /home/iobroker/.npm/_logs/2021-05-03T06_51_39_477Z-debug.log
host.ioBroker-GartenHalle Cannot install iobroker.js-controller@3.3.7: 243
</code></pre>
<p dir="auto">Was kann ich tun?</p>
]]></description><link>https://forum.iobroker.net/topic/44722/fehlermeldung-bei-js-controller-update</link><generator>RSS for Node</generator><lastBuildDate>Sun, 24 May 2026 03:11:21 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/44722.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 May 2021 07:00:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehlermeldung bei js-controller Update on Mon, 03 May 2021 07:11:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sunshineh" aria-label="Profile: sunshineh">@<bdi>sunshineh</bdi></a> iobroker fixer durchlaufen lassen. Der Update Vorgang kann auf bestimmte Verzeichnisse nicht schreibend zugreifen. Da hat jemand als root oder mit sudo hantiert.</p>
<p dir="auto">A.</p>
]]></description><link>https://forum.iobroker.net/post/624099</link><guid isPermaLink="true">https://forum.iobroker.net/post/624099</guid><dc:creator><![CDATA[Asgothian]]></dc:creator><pubDate>Mon, 03 May 2021 07:11:24 GMT</pubDate></item></channel></rss>
