  4. Seltsame Abstürze RPI4
69 Beiträge 10 Kommentatoren 10.6k Aufrufe 9 Beobachtet
    @uwe-waizmann sagte in Seltsame Abstürze RPI4:
    Kannst du mal nach dem kernel.log und dem sys.log schauen? Sollten in /var/log/ liegen. So um 16:17 herum sollte da was drinstehen.
    Uwe WaizmannU Offline
    Uwe Waizmann
    sehr gerne, hoffe wir kommen dem Problem näher, denn so nervt das schon gewaltig :-(
    kern.log
    Apr 15 16:17:06 whome kernel: [    4.893869] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    Apr 15 16:17:06 whome kernel: [    4.897861] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    Apr 15 16:17:06 whome kernel: [    4.902417] devtmpfs: mounted
    Apr 15 16:17:06 whome kernel: [    4.915383] Freeing unused kernel memory: 2048K
    Apr 15 16:17:06 whome kernel: [    4.933736] Run /sbin/init as init process
    Apr 15 16:17:06 whome kernel: [    4.937579]   with arguments:
    Apr 15 16:17:06 whome kernel: [    4.937593]     /sbin/init
    Apr 15 16:17:06 whome kernel: [    4.937607]   with environment:
    Apr 15 16:17:06 whome kernel: [    4.937622]     HOME=/
    Apr 15 16:17:06 whome kernel: [    4.937636]     TERM=linux
    Apr 15 16:17:06 whome kernel: [    5.556776] NET: Registered protocol family 10
    Apr 15 16:17:06 whome kernel: [    5.562163] Segment Routing with IPv6
    Apr 15 16:17:06 whome kernel: [    6.594095] random: systemd: uninitialized urandom read (16 bytes read)
    Apr 15 16:17:06 whome kernel: [    6.615339] random: systemd: uninitialized urandom read (16 bytes read)
    Apr 15 16:17:06 whome kernel: [    6.630295] random: systemd: uninitialized urandom read (16 bytes read)
    Apr 15 16:17:06 whome kernel: [    6.793710] i2c /dev entries driver
    Apr 15 16:17:06 whome kernel: [    7.539932] EXT4-fs (sda2): re-mounted. Opts: (null)
    Apr 15 16:17:06 whome kernel: [    8.394406] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    Apr 15 16:17:06 whome kernel: [    8.402145] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    Apr 15 16:17:06 whome kernel: [    8.407404] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    Apr 15 16:17:06 whome kernel: [    8.408391] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    Apr 15 16:17:06 whome kernel: [    8.483250] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.501575] mc: Linux media interface: v0.10
    Apr 15 16:17:06 whome kernel: [    8.501830] bcm2835_audio bcm2835_audio: card created with 4 channels
    Apr 15 16:17:06 whome kernel: [    8.525521] bcm2835_audio bcm2835_audio: card created with 4 channels
    Apr 15 16:17:06 whome kernel: [    8.527497] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.529773] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    Apr 15 16:17:06 whome kernel: [    8.529800] [vc_sm_connected_init]: start
    Apr 15 16:17:06 whome kernel: [    8.563801] [vc_sm_connected_init]: installed successfully
    Apr 15 16:17:06 whome kernel: [    8.590989] videodev: Linux video capture interface: v2.00
    Apr 15 16:17:06 whome kernel: [    8.642519] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.659713] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.662353] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.673004] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.700340] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    Apr 15 16:17:06 whome kernel: [    8.711331] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    Apr 15 16:17:06 whome kernel: [    8.717865] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    Apr 15 16:17:06 whome kernel: [    8.732122] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    Apr 15 16:17:06 whome kernel: [    8.741645] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    Apr 15 16:17:06 whome kernel: [    8.741994] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    Apr 15 16:17:06 whome kernel: [    8.742030] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    Apr 15 16:17:06 whome kernel: [    8.742056] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    Apr 15 16:17:06 whome kernel: [    8.742114] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    Apr 15 16:17:06 whome kernel: [    8.746199] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    Apr 15 16:17:06 whome kernel: [    8.787872] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    Apr 15 16:17:06 whome kernel: [    8.815075] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    Apr 15 16:17:06 whome kernel: [    8.815137] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    Apr 15 16:17:06 whome kernel: [    8.825070] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    Apr 15 16:17:06 whome kernel: [    8.825119] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    Apr 15 16:17:06 whome kernel: [    8.845696] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    Apr 15 16:17:06 whome kernel: [    8.845726] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
    Apr 15 16:17:06 whome kernel: [    8.845743] fb0: switching to vc4drmfb from simple
    Apr 15 16:17:06 whome kernel: [    8.845909] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    Apr 15 16:17:06 whome kernel: [    8.845954] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    Apr 15 16:17:06 whome kernel: [    8.846545] Console: switching to colour dummy device 80x30
    Apr 15 16:17:06 whome kernel: [    8.873819] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    Apr 15 16:17:06 whome kernel: [    8.899427] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    Apr 15 16:17:06 whome kernel: [    9.029595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    Apr 15 16:17:06 whome kernel: [    9.032332] sd 0:0:0:0: Attached scsi generic sg0 type 0
    Apr 15 16:17:06 whome kernel: [    9.087145] Console: switching to colour frame buffer device 240x67
    Apr 15 16:17:06 whome kernel: [    9.099033] brcmfmac: F1 signature read @0x18000000=0x15264345
    Apr 15 16:17:06 whome kernel: [    9.111849] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
    Apr 15 16:17:06 whome kernel: [    9.123088] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Apr 15 16:17:06 whome kernel: [    9.124185] usbcore: registered new interface driver brcmfmac
    Apr 15 16:17:06 whome kernel: [    9.159380] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    Apr 15 16:17:06 whome kernel: [    9.400951] random: crng init done
    Apr 15 16:17:06 whome kernel: [    9.400968] random: 7 urandom warning(s) missed due to ratelimiting
    Apr 15 16:17:06 whome kernel: [    9.403086] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Apr 15 16:17:06 whome kernel: [    9.414017] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    Apr 15 16:17:06 whome kernel: [    9.550053] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
    Apr 15 16:17:06 whome kernel: [    9.691025] input: Logitech Wireless Device PID:400a Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input8
    Apr 15 16:17:06 whome kernel: [    9.691694] hid-generic 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
    Apr 15 16:17:06 whome kernel: [    9.695990] input: Logitech Wireless Device PID:4003 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input12
    Apr 15 16:17:06 whome kernel: [    9.701763] input: Logitech Wireless Device PID:4003 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input13
    Apr 15 16:17:06 whome kernel: [    9.702186] input: Logitech Wireless Device PID:4003 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input14
    Apr 15 16:17:06 whome kernel: [    9.702655] hid-generic 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4003] on usb-0000:01:00.0-1.1.3.4/input2:2
    Apr 15 16:17:06 whome kernel: [   10.517714] input: Logitech Wireless Device PID:400a as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input18
    Apr 15 16:17:06 whome kernel: [   10.519729] logitech-hidpp-device 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
    Apr 15 16:17:06 whome kernel: [   10.935588] input: Logitech K270 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input19
    Apr 15 16:17:06 whome kernel: [   10.936905] logitech-hidpp-device 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K270] on usb-0000:01:00.0-1.1.3.4/input2:2
    Apr 15 16:17:06 whome kernel: [   11.906258] uart-pl011 fe201000.serial: no DMA platform data
    Apr 15 16:17:06 whome kernel: [   12.142710] 8021q: 802.1Q VLAN Support v1.8
    Apr 15 16:17:06 whome kernel: [   12.713688] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    Apr 15 16:17:07 whome kernel: [   13.254551] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    Apr 15 16:17:07 whome kernel: [   13.254961] bcmgenet fd580000.ethernet eth0: Link is Down
    Apr 15 16:17:10 whome kernel: [   16.393559] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    Apr 15 16:17:10 whome kernel: [   16.393588] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Apr 15 16:17:12 whome kernel: [   18.782512] Bluetooth: Core ver 2.22
    Apr 15 16:17:12 whome kernel: [   18.782572] NET: Registered protocol family 31
    Apr 15 16:17:12 whome kernel: [   18.782579] Bluetooth: HCI device and connection manager initialized
    Apr 15 16:17:12 whome kernel: [   18.782596] Bluetooth: HCI socket layer initialized
    Apr 15 16:17:12 whome kernel: [   18.782606] Bluetooth: L2CAP socket layer initialized
    Apr 15 16:17:12 whome kernel: [   18.782621] Bluetooth: SCO socket layer initialized
    Apr 15 16:17:12 whome kernel: [   18.795842] Bluetooth: HCI UART driver ver 2.3
    Apr 15 16:17:12 whome kernel: [   18.795856] Bluetooth: HCI UART protocol H4 registered
    Apr 15 16:17:12 whome kernel: [   18.795927] Bluetooth: HCI UART protocol Three-wire (H5) registered
    Apr 15 16:17:12 whome kernel: [   18.796133] Bluetooth: HCI UART protocol Broadcom registered
    Apr 15 16:17:13 whome kernel: [   19.002855] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    Apr 15 16:17:13 whome kernel: [   19.002863] Bluetooth: BNEP filters: protocol multicast
    Apr 15 16:17:13 whome kernel: [   19.002876] Bluetooth: BNEP socket layer initialized
    Apr 15 17:26:28 whome kernel: [    0.000000] Booting Linux on physical CPU 0x0
    die sys.log hört am 15.04 00:00 auf
    code_text
    • wendy2702W Online
      wendy2702W Online
      Wie ist der PI im Netzwerk angebunden?
      Sicher das der einen kompletten restart macht und nicht nur die Netzwerkverbindung verliert?
      Hängt der an einem 100Mbit Port ?
      Was ist da noch alles direkt oder indirekt per Bluetooth angeschlossen?
      Uwe WaizmannU 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        Uwe Waizmann
        @wendy2702
        er hängt direkt mit Kabel an einer Fritzbox
        Bluetooth ist gar nichts dran.
        Sonst ist seit gestern über den Hub nur die Tastatur und die Maus angeschlossen.
        Nein, er hängt dann komplett, kann mit Tastatur nichts mehr machen, nur noch Stecker ziehen.
        Bei früheren Abstürzen konnte ich ihn noch an pingen, hab ich heute aber nicht probiert.
        Per putty komme ich dann aber auch nicht mehr dran.
        • Uwe WaizmannU Uwe Waizmann
          @wendy2702
          wendy2702W Online
          wendy2702W Online
          @uwe-waizmann Und die FB hat nur 100Mbit Ports oder wird im Energiesparmode betrieben?
            Uwe Waizmann
            @wendy2702
            Und es ist gerade wieder passiert :-(
            Kann jetzt aber sagen wann genau.
            Beim Kaffee trinken schau ich mit der APP auf die VIS, alles ok, auch Refresh funktioniert.
            Ich wecke meinen PC auf, wo iobroker und VIS im Browser offen sind, dann bleibt er stehen.
            Ping geht noch, ssh keine Chance mehr, er steht da wie eingefroren.
            Der Port war im Green Mode mit 100Mbit/s, hab ihn jetzt umgeschaltet auf 1Gbit/s.
            hier der Log vor dem Absturz.
            Etwas seltsam finde ich den Sprung der Uhrzeit von 8:44 zurück auf 8:17
            	2021-04-16 09:11:08.079	error	(3092) info.0 already running
            host.whome	2021-04-16 09:11:05.914	info	instance system.adapter.info.0 started with pid 3092
            host.whome	2021-04-16 09:11:03.695	info	Restart adapter system.adapter.followthesun.0 because enabled
            host.whome	2021-04-16 09:11:03.694	error	instance system.adapter.followthesun.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            followthesun.0	2021-04-16 09:11:03.070	warn	(2739) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            followthesun.0	2021-04-16 09:11:03.066	error	(2739) followthesun.0 already running
            host.whome	2021-04-16 09:11:01.906	info	instance system.adapter.followthesun.0 started with pid 2739
            host.whome	2021-04-16 09:10:59.818	info	Restart adapter system.adapter.fb-checkpresence.0 because enabled
            host.whome	2021-04-16 09:10:59.817	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            fb-checkpresence.0	2021-04-16 09:10:59.245	warn	(2354) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            fb-checkpresence.0	2021-04-16 09:10:59.243	error	(2354) fb-checkpresence.0 already running
            host.whome	2021-04-16 08:17:34.535	info	instance system.adapter.fb-checkpresence.0 started with pid 2354
            host.whome	2021-04-16 08:17:32.241	info	Restart adapter system.adapter.discovery.0 because enabled
            host.whome	2021-04-16 08:17:32.240	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            discovery.0	2021-04-16 08:17:31.663	warn	(2032) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            discovery.0	2021-04-16 08:17:31.660	error	(2032) discovery.0 already running
            host.whome	2021-04-16 08:17:30.513	info	instance system.adapter.discovery.0 started with pid 2032
            host.whome	2021-04-16 08:17:28.574	info	Restart adapter system.adapter.cloud.0 because enabled
            host.whome	2021-04-16 08:17:28.573	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            cloud.0	2021-04-16 08:17:27.996	warn	(1697) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            cloud.0	2021-04-16 08:17:27.993	error	(1697) cloud.0 already running
            host.whome	2021-04-16 08:17:26.529	info	instance system.adapter.cloud.0 started with pid 1697
            host.whome	2021-04-16 08:17:24.403	info	Restart adapter system.adapter.chromecast.0 because enabled
            host.whome	2021-04-16 08:17:24.402	error	instance system.adapter.chromecast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            host.whome	2021-04-16 08:17:24.402	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
            host.whome	2021-04-16 08:17:24.402	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
            host.whome	2021-04-16 08:17:24.401	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:168:15)
            host.whome	2021-04-16 08:17:24.401	error	Caught by controller[0]: at process.emit (events.js:314:20)
            host.whome	2021-04-16 08:17:24.400	error	Caught by controller[0]: at Object.onceWrapper (events.js:421:26)
            host.whome	2021-04-16 08:17:24.400	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
            host.whome	2021-04-16 08:17:24.400	error	Caught by controller[0]: at Adapter.emit (events.js:314:20)
            host.whome	2021-04-16 08:17:24.399	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
            host.whome	2021-04-16 08:17:24.399	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
            chromecast.0	2021-04-16 08:17:23.756	warn	(1338) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            chromecast.0	2021-04-16 08:17:23.754	error	(1338) chromecast.0 already running
            host.whome	2021-04-16 08:17:23.464	info	Restart adapter system.adapter.backitup.0 because enabled
            host.whome	2021-04-16 08:17:23.463	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            backitup.0	2021-04-16 08:17:22.811	warn	(986) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            backitup.0	2021-04-16 08:17:22.807	error	(986) backitup.0 already running
            host.whome	2021-04-16 08:17:22.444	info	instance system.adapter.chromecast.0 started with pid 1338
            host.whome	2021-04-16 08:17:18.432	info	instance system.adapter.backitup.0 started with pid 986
            host.whome	2021-04-16 08:17:16.950	info	Restart adapter system.adapter.admin.0 because enabled
            host.whome	2021-04-16 08:17:16.949	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
            admin.0	2021-04-16 08:17:16.350	warn	(799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
            admin.0	2021-04-16 08:17:16.347	error	(799) admin.0 already running
            host.whome	2021-04-16 08:17:14.531	info	instance system.adapter.admin.0 started with pid 799
            host.whome	2021-04-16 08:17:14.412	info	starting 19 instances
            host.whome	2021-04-16 08:17:14.353	info	25 instances found
            host.whome	2021-04-16 08:17:13.756	info	added notifications configuration of host
            host.whome	2021-04-16 08:17:13.702	info	connected to Objects and States
            host.whome-Server	2021-04-16 08:17:13.563	error	Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
            host.whome	2021-04-16 08:17:13.068	info	ip addresses: fe80::d8:6431:90b3:eeab
            host.whome	2021-04-16 08:17:13.067	info	hostname: whome, node: v12.22.1
            host.whome	2021-04-16 08:17:13.066	info	Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
            web.0	2021-04-16 08:44:55.078	info
            web.0	2021-04-16 08:44:55.078	info	(7199) <==Disconnect system.user.admin from ::ffff:192.168.1.30
            web.0	2021-04-16 08:44:41.152	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
            web.0	2021-04-16 08:44:41.019	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
            web.0	2021-04-16 08:42:25.371	info	(7199) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
            web.0	2021-04-16 08:42:25.200	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
            web.0	2021-04-16 08:42:25.078	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
            web.0	2021-04-16 08:37:19.727	info	(7199) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
            web.0	2021-04-16 08:32:53.878	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
              @wendy2702
              wendy2702W Online
              wendy2702W Online
              @uwe-waizmann Blöde Frage: dein Rechner und PI haben nicht zufällig dieselbe IP Adresse ?
              Thomas BraunT Uwe WaizmannU 2 Antworten Letzte Antwort
                @wendy2702 sagte in Seltsame Abstürze RPI4:
                Haben alle die 127.0.0.1!
                OliverIOO wendy2702W 2 Antworten Letzte Antwort
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @thomas-braun said in Seltsame Abstürze RPI4:
                  hey, die hab ich auch
                  Meine Adapter und Widgets
                  Links im Profil
                  • OliverIOO OliverIO
                    #66
                    @oliverio Gib die zurück! Die ist mir! :-D
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #67
                      musst einen Antrag bei https://www.iana.org/ stellen.
                      Links im Profil
                        wendy2702W Online
                        wendy2702W Online
                        #68
                        @thomas-braun Menno....
                        Dachte immer das wäre meine 😥
                          Uwe Waizmann
                          #69
                          @wendy2702
                          Nein, haben alle zugewiesene IP, sonst würd ich bei den vielen Geräten nicht mehr durchblicken
