  4. Seltsame Abstürze RPI4
69 Beiträge 10 Kommentatoren 10.6k Aufrufe 9 Beobachtet
  • wendy2702W wendy2702
    @uwe-waizmann Nacktes Linux ohne Desktop
    Iobroker mit Einzeiler installieren. Da kommt Node und NPM direkt richtig mit.
    Uwe WaizmannU Offline
    Uwe Waizmann
    hab jetzt neu installiert,
    zuerst iobroker
    dann emoncms
    iobroker restore läuft gerade
    kann vielleicht hier mal jemand drüber schauen ob das jetzt ok ist?
    ich hab davon leider keine Ahnung, sehe aber das wohl ein Fehler besteht
    pi@whome:~ $ dmesg -T
    [Mi Apr 14 11:11:22 2021] Booting Linux on physical CPU 0x0
    [Mi Apr 14 11:11:22 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
    [Mi Apr 14 11:11:22 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [Mi Apr 14 11:11:22 2021] CPU: div instructions available: patching division code
    [Mi Apr 14 11:11:22 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [Mi Apr 14 11:11:22 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
    [Mi Apr 14 11:11:22 2021] Memory policy: Data cache writealloc
    [Mi Apr 14 11:11:22 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
    [Mi Apr 14 11:11:22 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [Mi Apr 14 11:11:22 2021] Zone ranges:
    [Mi Apr 14 11:11:22 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [Mi Apr 14 11:11:22 2021]   Normal   empty
    [Mi Apr 14 11:11:22 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
    [Mi Apr 14 11:11:22 2021] Movable zone start for each node
    [Mi Apr 14 11:11:22 2021] Early memory node ranges
    [Mi Apr 14 11:11:22 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
    [Mi Apr 14 11:11:22 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [Mi Apr 14 11:11:22 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
    [Mi Apr 14 11:11:22 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
    [Mi Apr 14 11:11:22 2021] On node 0 totalpages: 2061056
    [Mi Apr 14 11:11:22 2021]   DMA zone: 2304 pages used for memmap
    [Mi Apr 14 11:11:22 2021]   DMA zone: 0 pages reserved
    [Mi Apr 14 11:11:22 2021]   DMA zone: 196608 pages, LIFO batch:63
    [Mi Apr 14 11:11:22 2021]   HighMem zone: 1864448 pages, LIFO batch:63
    [Mi Apr 14 11:11:22 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
    [Mi Apr 14 11:11:22 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
    [Mi Apr 14 11:11:22 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Mi Apr 14 11:11:22 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
    [Mi Apr 14 11:11:22 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:EE:BA:65 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=16ac31f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mi Apr 14 11:11:22 2021] Kernel parameter elevator= does not have any effect anymore.
                              Please use sysfs to set IO scheduler for individual devices.
    [Mi Apr 14 11:11:22 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [Mi Apr 14 11:11:22 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [Mi Apr 14 11:11:22 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
    [Mi Apr 14 11:11:22 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
    [Mi Apr 14 11:11:22 2021] Memory: 7799064K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183016K reserved, 262144K cma-reserved, 7457792K highmem)
    [Mi Apr 14 11:11:22 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [Mi Apr 14 11:11:22 2021] ftrace: allocating 33942 entries in 67 pages
    [Mi Apr 14 11:11:22 2021] ftrace: allocated 67 pages with 3 groups
    [Mi Apr 14 11:11:22 2021] rcu: Hierarchical RCU implementation.
    [Mi Apr 14 11:11:22 2021]       Rude variant of Tasks RCU enabled.
    [Mi Apr 14 11:11:22 2021]       Tracing variant of Tasks RCU enabled.
    [Mi Apr 14 11:11:22 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [Mi Apr 14 11:11:22 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Mi Apr 14 11:11:22 2021] GIC: Using split EOI/Deactivate mode
    [Mi Apr 14 11:11:22 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
    [Mi Apr 14 11:11:22 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [Mi Apr 14 11:11:22 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [Mi Apr 14 11:11:22 2021] bcm2835: system timer (irq = 25)
    [Mi Apr 14 11:11:22 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [Mi Apr 14 11:11:22 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [Mi Apr 14 11:11:22 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [Mi Apr 14 11:11:22 2021] Switching to timer-based delay loop, resolution 18ns
    [Mi Apr 14 11:11:22 2021] Console: colour dummy device 80x30
    [Mi Apr 14 11:11:22 2021] printk: console [tty1] enabled
    [Mi Apr 14 11:11:22 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [Mi Apr 14 11:11:22 2021] pid_max: default: 32768 minimum: 301
    [Mi Apr 14 11:11:22 2021] LSM: Security Framework initializing
    [Mi Apr 14 11:11:22 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Mi Apr 14 11:11:22 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Mi Apr 14 11:11:22 2021] Disabling memory control group subsystem
    [Mi Apr 14 11:11:22 2021] CPU: Testing write buffer coherency: ok
    [Mi Apr 14 11:11:22 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Mi Apr 14 11:11:22 2021] Setting up static identity map for 0x200000 - 0x20003c
    [Mi Apr 14 11:11:22 2021] rcu: Hierarchical SRCU implementation.
    [Mi Apr 14 11:11:22 2021] smp: Bringing up secondary CPUs ...
    [Mi Apr 14 11:11:22 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Mi Apr 14 11:11:22 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Mi Apr 14 11:11:22 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Mi Apr 14 11:11:22 2021] smp: Brought up 1 node, 4 CPUs
    [Mi Apr 14 11:11:22 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [Mi Apr 14 11:11:22 2021] CPU: All CPU(s) started in HYP mode.
    [Mi Apr 14 11:11:22 2021] CPU: Virtualization extensions available.
    [Mi Apr 14 11:11:22 2021] devtmpfs: initialized
    [Mi Apr 14 11:11:22 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [Mi Apr 14 11:11:22 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [Mi Apr 14 11:11:22 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [Mi Apr 14 11:11:22 2021] pinctrl core: initialized pinctrl subsystem
    [Mi Apr 14 11:11:22 2021] NET: Registered protocol family 16
    [Mi Apr 14 11:11:22 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [Mi Apr 14 11:11:22 2021] audit: initializing netlink subsys (disabled)
    [Mi Apr 14 11:11:22 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
    [Mi Apr 14 11:11:22 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Mi Apr 14 11:11:22 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [Mi Apr 14 11:11:22 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Mi Apr 14 11:11:22 2021] Serial: AMBA PL011 UART driver
    [Mi Apr 14 11:11:22 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [Mi Apr 14 11:11:22 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
    [Mi Apr 14 11:11:22 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
    [Mi Apr 14 11:11:22 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [Mi Apr 14 11:11:22 2021] vgaarb: loaded
    [Mi Apr 14 11:11:22 2021] SCSI subsystem initialized
    [Mi Apr 14 11:11:22 2021] usbcore: registered new interface driver usbfs
    [Mi Apr 14 11:11:22 2021] usbcore: registered new interface driver hub
    [Mi Apr 14 11:11:22 2021] usbcore: registered new device driver usb
    [Mi Apr 14 11:11:22 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [Mi Apr 14 11:11:22 2021] clocksource: Switched to clocksource arch_sys_counter
    [Mi Apr 14 11:11:23 2021] VFS: Disk quotas dquot_6.6.0
    [Mi Apr 14 11:11:23 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [Mi Apr 14 11:11:23 2021] FS-Cache: Loaded
    [Mi Apr 14 11:11:23 2021] CacheFiles: Loaded
    [Mi Apr 14 11:11:23 2021] simple-framebuffer 3e2fe000.framebuffer: framebuffer at 0x3e2fe000, 0x7f8000 bytes, mapped to 0x(ptrval)
    [Mi Apr 14 11:11:23 2021] simple-framebuffer 3e2fe000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
    [Mi Apr 14 11:11:23 2021] Console: switching to colour frame buffer device 240x67
    [Mi Apr 14 11:11:23 2021] simple-framebuffer 3e2fe000.framebuffer: fb0: simplefb registered!
    [Mi Apr 14 11:11:23 2021] NET: Registered protocol family 2
    [Mi Apr 14 11:11:23 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [Mi Apr 14 11:11:23 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [Mi Apr 14 11:11:23 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [Mi Apr 14 11:11:23 2021] TCP: Hash tables configured (established 8192 bind 8192)
    [Mi Apr 14 11:11:23 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Mi Apr 14 11:11:23 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Mi Apr 14 11:11:23 2021] NET: Registered protocol family 1
    [Mi Apr 14 11:11:23 2021] RPC: Registered named UNIX socket transport module.
    [Mi Apr 14 11:11:23 2021] RPC: Registered udp transport module.
    [Mi Apr 14 11:11:23 2021] RPC: Registered tcp transport module.
    [Mi Apr 14 11:11:23 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [Mi Apr 14 11:11:23 2021] PCI: CLS 0 bytes, default 64
    [Mi Apr 14 11:11:23 2021] Initialise system trusted keyrings
    [Mi Apr 14 11:11:23 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
    [Mi Apr 14 11:11:23 2021] zbud: loaded
    [Mi Apr 14 11:11:23 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Mi Apr 14 11:11:23 2021] NFS: Registering the id_resolver key type
    [Mi Apr 14 11:11:23 2021] Key type id_resolver registered
    [Mi Apr 14 11:11:23 2021] Key type id_legacy registered
    [Mi Apr 14 11:11:23 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [Mi Apr 14 11:11:23 2021] Key type asymmetric registered
    [Mi Apr 14 11:11:23 2021] Asymmetric key parser 'x509' registered
    [Mi Apr 14 11:11:23 2021] bounce: pool size: 64 pages
    [Mi Apr 14 11:11:23 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [Mi Apr 14 11:11:23 2021] io scheduler mq-deadline registered
    [Mi Apr 14 11:11:23 2021] io scheduler kyber registered
    [Mi Apr 14 11:11:23 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [Mi Apr 14 11:11:23 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [Mi Apr 14 11:11:23 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
    [Mi Apr 14 11:11:23 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [Mi Apr 14 11:11:23 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [Mi Apr 14 11:11:23 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [Mi Apr 14 11:11:23 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [Mi Apr 14 11:11:23 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [Mi Apr 14 11:11:23 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [Mi Apr 14 11:11:23 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [Mi Apr 14 11:11:23 2021] PCI: bus0: Fast back to back transfers disabled
    [Mi Apr 14 11:11:23 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [Mi Apr 14 11:11:23 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [Mi Apr 14 11:11:23 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
    [Mi Apr 14 11:11:23 2021] PCI: bus1: Fast back to back transfers disabled
    [Mi Apr 14 11:11:23 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [Mi Apr 14 11:11:23 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [Mi Apr 14 11:11:23 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [Mi Apr 14 11:11:23 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [Mi Apr 14 11:11:23 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [Mi Apr 14 11:11:23 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
    [Mi Apr 14 11:11:23 2021] iproc-rng200 fe104000.rng: hwrng registered
    [Mi Apr 14 11:11:23 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
    [Mi Apr 14 11:11:23 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [Mi Apr 14 11:11:23 2021] brd: module loaded
    [Mi Apr 14 11:11:23 2021] loop: module loaded
    [Mi Apr 14 11:11:23 2021] Loading iSCSI transport class v2.0-870.
    [Mi Apr 14 11:11:23 2021] libphy: Fixed MDIO Bus: probed
    [Mi Apr 14 11:11:23 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [Mi Apr 14 11:11:23 2021] libphy: bcmgenet MII bus: probed
    [Mi Apr 14 11:11:23 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [Mi Apr 14 11:11:23 2021] usbcore: registered new interface driver r8152
    [Mi Apr 14 11:11:23 2021] usbcore: registered new interface driver lan78xx
    [Mi Apr 14 11:11:23 2021] usbcore: registered new interface driver smsc95xx
    [Mi Apr 14 11:11:23 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [Mi Apr 14 11:11:23 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [Mi Apr 14 11:11:23 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
    [Mi Apr 14 11:11:23 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [Mi Apr 14 11:11:23 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Mi Apr 14 11:11:23 2021] usb usb1: Product: xHCI Host Controller
    [Mi Apr 14 11:11:23 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [Mi Apr 14 11:11:23 2021] usb usb1: SerialNumber: 0000:01:00.0
    [Mi Apr 14 11:11:23 2021] hub 1-0:1.0: USB hub found
    [Mi Apr 14 11:11:23 2021] hub 1-0:1.0: 1 port detected
    [Mi Apr 14 11:11:23 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [Mi Apr 14 11:11:23 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [Mi Apr 14 11:11:23 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [Mi Apr 14 11:11:23 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Mi Apr 14 11:11:23 2021] usb usb2: Product: xHCI Host Controller
    [Mi Apr 14 11:11:23 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
    [Mi Apr 14 11:11:23 2021] usb usb2: SerialNumber: 0000:01:00.0
    [Mi Apr 14 11:11:23 2021] hub 2-0:1.0: USB hub found
    [Mi Apr 14 11:11:23 2021] hub 2-0:1.0: 4 ports detected
    [Mi Apr 14 11:11:23 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Mi Apr 14 11:11:23 2021] dwc_otg: FIQ enabled
    [Mi Apr 14 11:11:23 2021] dwc_otg: NAK holdoff enabled
    [Mi Apr 14 11:11:23 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Mi Apr 14 11:11:23 2021] Module dwc_common_port init
    [Mi Apr 14 11:11:23 2021] usbcore: registered new interface driver uas
    [Mi Apr 14 11:11:23 2021] usbcore: registered new interface driver usb-storage
    [Mi Apr 14 11:11:23 2021] mousedev: PS/2 mouse device common for all mice
    [Mi Apr 14 11:11:23 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [Mi Apr 14 11:11:23 2021] sdhci: Secure Digital Host Controller Interface driver
    [Mi Apr 14 11:11:23 2021] sdhci: Copyright(c) Pierre Ossman
    [Mi Apr 14 11:11:23 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [Mi Apr 14 11:11:23 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Mi Apr 14 11:11:23 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Mi Apr 14 11:11:23 2021] hid: raw HID events driver (C) Jiri Kosina
    [Mi Apr 14 11:11:23 2021] usbcore: registered new interface driver usbhid
    [Mi Apr 14 11:11:23 2021] usbhid: USB HID core driver
    [Mi Apr 14 11:11:23 2021] Initializing XFRM netlink socket
    [Mi Apr 14 11:11:23 2021] NET: Registered protocol family 17
    [Mi Apr 14 11:11:23 2021] Key type dns_resolver registered
    [Mi Apr 14 11:11:23 2021] Registering SWP/SWPB emulation handler
    [Mi Apr 14 11:11:23 2021] registered taskstats version 1
    [Mi Apr 14 11:11:23 2021] Loading compiled-in X.509 certificates
    [Mi Apr 14 11:11:23 2021] Key type ._fscrypt registered
    [Mi Apr 14 11:11:23 2021] Key type .fscrypt registered
    [Mi Apr 14 11:11:23 2021] Key type fscrypt-provisioning registered
    [Mi Apr 14 11:11:23 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
    [Mi Apr 14 11:11:23 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [Mi Apr 14 11:11:23 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
    [Mi Apr 14 11:11:23 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [Mi Apr 14 11:11:23 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Mi Apr 14 11:11:23 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [Mi Apr 14 11:11:23 2021] of_cfs_init
    [Mi Apr 14 11:11:23 2021] of_cfs_init: OK
    [Mi Apr 14 11:11:23 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Mi Apr 14 11:11:23 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Mi Apr 14 11:11:23 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Mi Apr 14 11:11:23 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [Mi Apr 14 11:11:23 2021] Waiting for root device PARTUUID=16ac31f2-02...
    [Mi Apr 14 11:11:23 2021] random: fast init done
    [Mi Apr 14 11:11:23 2021] mmc1: new high speed SDIO card at address 0001
    [Mi Apr 14 11:11:23 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [Mi Apr 14 11:11:24 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [Mi Apr 14 11:11:24 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [Mi Apr 14 11:11:24 2021] usb 1-1: Product: USB2.0 Hub
    [Mi Apr 14 11:11:24 2021] hub 1-1:1.0: USB hub found
    [Mi Apr 14 11:11:24 2021] hub 1-1:1.0: 4 ports detected
    [Mi Apr 14 11:11:24 2021] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
    [Mi Apr 14 11:11:24 2021] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
    [Mi Apr 14 11:11:24 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [Mi Apr 14 11:11:24 2021] usb 1-1.1: Product: USB2.0 Hub
    [Mi Apr 14 11:11:24 2021] hub 1-1.1:1.0: USB hub found
    [Mi Apr 14 11:11:24 2021] hub 1-1.1:1.0: 4 ports detected
    [Mi Apr 14 11:11:24 2021] usb 1-1.1.3: new high-speed USB device number 4 using xhci_hcd
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3: Product: USB2.0 Hub
    [Mi Apr 14 11:11:25 2021] hub 1-1.1.3:1.0: USB hub found
    [Mi Apr 14 11:11:25 2021] hub 1-1.1.3:1.0: 4 ports detected
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.4: new high-speed USB device number 5 using xhci_hcd
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.4: New USB device found, idVendor=2109, idProduct=0711, bcdDevice=12.00
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.4: Product: VLI Product String
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.4: Manufacturer: VLI manufacture String
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.4: SerialNumber: 000000123AD6
    [Mi Apr 14 11:11:25 2021] usb-storage 1-1.1.4:1.0: USB Mass Storage device detected
    [Mi Apr 14 11:11:25 2021] usb-storage 1-1.1.4:1.0: Quirks match for vid 2109 pid 0711: 2000000
    [Mi Apr 14 11:11:25 2021] scsi host0: usb-storage 1-1.1.4:1.0
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.3: new low-speed USB device number 6 using xhci_hcd
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.3: New USB device found, idVendor=1c4f, idProduct=0026, bcdDevice= 1.10
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.3: Product: USB Keyboard
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.3: Manufacturer: SIGMACHIP
    [Mi Apr 14 11:11:25 2021] input: SIGMACHIP USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/0003:1C4F:0026.0001/input/input0
    [Mi Apr 14 11:11:25 2021] hid-generic 0003:1C4F:0026.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:01:00.0-1.1.3.3/input0
    [Mi Apr 14 11:11:25 2021] input: SIGMACHIP USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:1C4F:0026.0002/input/input1
    [Mi Apr 14 11:11:25 2021] input: SIGMACHIP USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:1C4F:0026.0002/input/input2
    [Mi Apr 14 11:11:25 2021] hid-generic 0003:1C4F:0026.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:01:00.0-1.1.3.3/input1
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.4: new full-speed USB device number 7 using xhci_hcd
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.00
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.4: Product: USB Receiver
    [Mi Apr 14 11:11:25 2021] usb 1-1.1.3.4: Manufacturer: Logitech
    [Mi Apr 14 11:11:25 2021] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.0/0003:046D:C52B.0003/input/input3
    [Mi Apr 14 11:11:26 2021] hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input0
    [Mi Apr 14 11:11:26 2021] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input4
    [Mi Apr 14 11:11:26 2021] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input5
    [Mi Apr 14 11:11:26 2021] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input6
    [Mi Apr 14 11:11:26 2021] hid-generic 0003:046D:C52B.0004: input,hiddev96,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input1
    [Mi Apr 14 11:11:26 2021] hid-generic 0003:046D:C52B.0005: hiddev97,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
    [Mi Apr 14 11:11:26 2021] scsi 0:0:0:0: Direct-Access     INTEL SS DSA2CW080G3      4PC1 PQ: 0 ANSI: 6
    [Mi Apr 14 11:11:26 2021] sd 0:0:0:0: [sda] 156301484 512-byte logical blocks: (80.0 GB/74.5 GiB)
    [Mi Apr 14 11:11:26 2021] sd 0:0:0:0: [sda] Write Protect is off
    [Mi Apr 14 11:11:26 2021] sd 0:0:0:0: [sda] Mode Sense: 1f 00 00 00
    [Mi Apr 14 11:11:26 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
    [Mi Apr 14 11:11:26 2021]  sda: sda1 sda2
    [Mi Apr 14 11:11:26 2021] sd 0:0:0:0: [sda] Attached SCSI disk
    [Mi Apr 14 11:11:26 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [Mi Apr 14 11:11:26 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Mi Apr 14 11:11:26 2021] devtmpfs: mounted
    [Mi Apr 14 11:11:26 2021] Freeing unused kernel memory: 2048K
    [Mi Apr 14 11:11:26 2021] Run /sbin/init as init process
    [Mi Apr 14 11:11:26 2021]   with arguments:
    [Mi Apr 14 11:11:26 2021]     /sbin/init
    [Mi Apr 14 11:11:26 2021]   with environment:
    [Mi Apr 14 11:11:26 2021]     HOME=/
    [Mi Apr 14 11:11:26 2021]     TERM=linux
    [Mi Apr 14 11:11:26 2021] systemd[1]: System time before build time, advancing clock.
    [Mi Apr 14 11:11:27 2021] NET: Registered protocol family 10
    [Mi Apr 14 11:11:27 2021] Segment Routing with IPv6
    [Mi Apr 14 11:11:27 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [Mi Apr 14 11:11:27 2021] systemd[1]: Detected architecture arm.
    [Mi Apr 14 11:11:27 2021] systemd[1]: Set hostname to <whome>.
    [Mi Apr 14 11:11:28 2021] random: systemd: uninitialized urandom read (16 bytes read)
    [Mi Apr 14 11:11:28 2021] systemd[1]: Listening on udev Control Socket.
    [Mi Apr 14 11:11:28 2021] systemd[1]: Listening on udev Kernel Socket.
    [Mi Apr 14 11:11:28 2021] systemd[1]: Reached target Swap.
    [Mi Apr 14 11:11:28 2021] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [Mi Apr 14 11:11:28 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
    [Mi Apr 14 11:11:28 2021] systemd[1]: Listening on Journal Socket.
    [Mi Apr 14 11:11:28 2021] systemd[1]: Starting udev Coldplug all Devices...
    [Mi Apr 14 11:11:28 2021] i2c /dev entries driver
    [Mi Apr 14 11:11:29 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
    [Mi Apr 14 11:11:29 2021] systemd-journald[119]: Received request to flush runtime journal from PID 1
    [Mi Apr 14 11:11:29 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [Mi Apr 14 11:11:29 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [Mi Apr 14 11:11:29 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [Mi Apr 14 11:11:29 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [Mi Apr 14 11:11:29 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [Mi Apr 14 11:11:29 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [Mi Apr 14 11:11:29 2021] [vc_sm_connected_init]: start
    [Mi Apr 14 11:11:29 2021] [vc_sm_connected_init]: installed successfully
    [Mi Apr 14 11:11:29 2021] mc: Linux media interface: v0.10
    [Mi Apr 14 11:11:29 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [Mi Apr 14 11:11:29 2021] bcm2835_audio bcm2835_audio: card created with 4 channels
    [Mi Apr 14 11:11:30 2021] videodev: Linux video capture interface: v2.00
    [Mi Apr 14 11:11:30 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [Mi Apr 14 11:11:30 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [Mi Apr 14 11:11:30 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [Mi Apr 14 11:11:30 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [Mi Apr 14 11:11:30 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [Mi Apr 14 11:11:30 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [Mi Apr 14 11:11:30 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Mi Apr 14 11:11:30 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [Mi Apr 14 11:11:30 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Mi Apr 14 11:11:30 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [Mi Apr 14 11:11:30 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Mi Apr 14 11:11:30 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [Mi Apr 14 11:11:30 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [Mi Apr 14 11:11:30 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [Mi Apr 14 11:11:30 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
    [Mi Apr 14 11:11:30 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [Mi Apr 14 11:11:30 2021] usbcore: registered new interface driver brcmfmac
    [Mi Apr 14 11:11:30 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
    [Mi Apr 14 11:11:30 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [Mi Apr 14 11:11:30 2021] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
    [Mi Apr 14 11:11:30 2021] fb0: switching to vc4drmfb from simple
    [Mi Apr 14 11:11:30 2021] Console: switching to colour dummy device 80x30
    [Mi Apr 14 11:11:30 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [Mi Apr 14 11:11:30 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [Mi Apr 14 11:11:30 2021] Console: switching to colour frame buffer device 240x67
    [Mi Apr 14 11:11:30 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [Mi Apr 14 11:11:30 2021] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
    [Mi Apr 14 11:11:31 2021] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
    [Mi Apr 14 11:11:31 2021] input: Logitech Wireless Device PID:400a Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input8
    [Mi Apr 14 11:11:31 2021] hid-generic 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
    [Mi Apr 14 11:11:31 2021] random: crng init done
    [Mi Apr 14 11:11:31 2021] random: 7 urandom warning(s) missed due to ratelimiting
    [Mi Apr 14 11:11:31 2021] input: Logitech Wireless Device PID:4003 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input12
    [Mi Apr 14 11:11:31 2021] input: Logitech Wireless Device PID:4003 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input13
    [Mi Apr 14 11:11:31 2021] input: Logitech Wireless Device PID:4003 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input14
    [Mi Apr 14 11:11:31 2021] hid-generic 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4003] on usb-0000:01:00.0-1.1.3.4/input2:2
    [Mi Apr 14 11:11:31 2021] input: Logitech Wireless Device PID:400a as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input18
    [Mi Apr 14 11:11:31 2021] logitech-hidpp-device 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
    [Mi Apr 14 11:11:32 2021] input: Logitech K270 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input19
    [Mi Apr 14 11:11:32 2021] logitech-hidpp-device 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K270] on usb-0000:01:00.0-1.1.3.4/input2:2
    [Mi Apr 14 11:11:33 2021] uart-pl011 fe201000.serial: no DMA platform data
    [Mi Apr 14 11:11:33 2021] 8021q: 802.1Q VLAN Support v1.8
    [Mi Apr 14 11:11:34 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
    [Mi Apr 14 11:11:34 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [Mi Apr 14 11:11:34 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [Mi Apr 14 11:11:39 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    [Mi Apr 14 11:11:39 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [Mi Apr 14 11:11:40 2021] Bluetooth: Core ver 2.22
    [Mi Apr 14 11:11:40 2021] NET: Registered protocol family 31
    [Mi Apr 14 11:11:40 2021] Bluetooth: HCI device and connection manager initialized
    [Mi Apr 14 11:11:40 2021] Bluetooth: HCI socket layer initialized
    [Mi Apr 14 11:11:40 2021] Bluetooth: L2CAP socket layer initialized
    [Mi Apr 14 11:11:40 2021] Bluetooth: SCO socket layer initialized
    [Mi Apr 14 11:11:40 2021] Bluetooth: HCI UART driver ver 2.3
    [Mi Apr 14 11:11:40 2021] Bluetooth: HCI UART protocol H4 registered
    [Mi Apr 14 11:11:40 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [Mi Apr 14 11:11:40 2021] Bluetooth: HCI UART protocol Broadcom registered
    [Mi Apr 14 11:11:40 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Mi Apr 14 11:11:40 2021] Bluetooth: BNEP filters: protocol multicast
    [Mi Apr 14 11:11:40 2021] Bluetooth: BNEP socket layer initialized
    [Mi Apr 14 11:11:53 2021] vcc-sd: disabling
    • Uwe WaizmannU Uwe Waizmann
      zuerst iobroker
      dann emoncms
      wendy2702W Online
      wendy2702W Online
      @uwe-waizmann Wo siehst du einen Fehler?
        @uwe-waizmann sagte in Seltsame Abstürze RPI4:
        Der Schuss kam bestimmt beim Stecker ziehen, was ich öfters machen musste wegen der Sromversorgung der SSD.
        Gut erkannt! Deswegen macht man das auch tunlichst nicht. Immer sauber herunterfahren!
        Ich würde neuinstallieren. Backup wieder drauf, fertig.
        Uwe Waizmann
        schrieb am zuletzt editiert von Uwe Waizmann
        gestern neu installiert und lief bis gerade eben.
        Platform linux
        Betriebssystem linux
        Architektur arm
        CPUs 4
        Geschwindigkeit 1500 MHz
        Modell ARMv7 Processor rev 3 (v7l)
        RAM 7.69 GB
        System Betriebszeit 00:11:33
        Node.js v12.22.1
        NPM 6.14.12
        Festplatte Größe 73.07 GB
        Festplatte frei 68.55 GB
        Anzahl der Adapter 338
        Betriebszeit 00:58:41
        Aktive Instanzen 18
        Hostname whome
        Um 16: 17 muss es dann passiert sein
        cloud.0	2021-04-15 17:07:24.077	info	(4326) Connection changed: connect
        cloud.0	2021-04-15 17:07:23.954	info	(4326) Trying to connect as system.user.admin
        sonoff.0	2021-04-15 17:06:36.217	info	(8365) Client [Temp2-DS18B20] connected with secret 1618499196215_9761
        sonoff.0	2021-04-15 17:06:34.602	info	(8365) Client [Terrasse_lux_led] connected with secret 1618499194601_2835
        sonoff.0	2021-04-15 17:06:32.648	info	(8365) Client [WekstattTemp] connected with secret 1618499192646_1301
        sonoff.0	2021-04-15 17:06:31.835	info	(8365) Client [Buero_Temp] connected with secret 1618499191833_7737
        sonoff.0	2021-04-15 17:06:29.594	info	(8365) Client [Steckdose12] connected with secret 1618499189588_613
        sonoff.0	2021-04-15 17:06:28.766	info	(8365) Client [Schalter-TV] connected with secret 1618499188765_7489
        web.0	2021-04-15 17:06:24.095	info	(9699) http server listening on port 8082
        web.0	2021-04-15 17:06:24.086	info	(9699) Allow states only when user is owner: false
        web.0	2021-04-15 17:06:24.084	info	(9699) simpleAPI server listening on port 8082
        web.0	2021-04-15 17:06:24.069	info	(9699) socket.io server listening on port 8082
        cloud.0	2021-04-15 17:06:23.944	info	(4326) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
        cloud.0	2021-04-15 17:06:23.820	info	(4326) Trying to connect as system.user.admin
        web.0	2021-04-15 17:06:23.768	info	(9699) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
        host.whome	2021-04-15 17:06:22.011	info	instance system.adapter.web.0 started with pid 9699
        sonoff.0	2021-04-15 17:06:19.987	info	(8365) Client [wama] connected with secret 1618499179967_1240
        telegram.1	2021-04-15 17:06:18.683	info	(9216) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
        shelly.0	2021-04-15 17:06:18.009	info	(8159) Shelly device 192.168.1.123 (shellyswitch25 / shellyswitch25-84CCA8B0CC8F / SHSW-25#84CCA8B0CC8F#1) with CoAP connected! Polltime set to 5 sec.
        host.whome	2021-04-15 17:06:16.139	info	instance system.adapter.telegram.1 started with pid 9216
        shelly.0	2021-04-15 17:06:15.551	info	(8159) Shelly device 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) with CoAP connected! Polltime set to 5 sec.
        shelly.0	2021-04-15 17:06:15.062	info	(8159) Shelly device 192.168.1.131 (shellydimmer2 / shellydimmer2-40F520015E03 / SHDM-2#40F520015E03#1) with CoAP connected! Polltime set to 5 sec.
        shelly.0	2021-04-15 17:06:14.829	info	(8159) Shelly device 192.168.1.127 (shelly1 / shelly1-F4CFA2E46301 / SHSW-1#F4CFA2E46301#1) with CoAP connected! Polltime set to 5 sec.
        shelly.0	2021-04-15 17:06:14.115	info	(8159) Shelly device 192.168.1.126 (shelly1 / shelly1-483FDA91AF1A / SHSW-1#483FDA91AF1A#1) with CoAP connected! Polltime set to 5 sec.
        telegram.0	2021-04-15 17:06:13.163	info	(8765) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
        shelly.0	2021-04-15 17:06:10.740	info	(8159) Shelly device 192.168.1.121 (shellyswitch25 / shellyswitch25-84CCA8B09E95 / SHSW-25#84CCA8B09E95#1) with CoAP connected! Polltime set to 5 sec.
        host.whome	2021-04-15 17:06:10.609	info	instance system.adapter.telegram.0 started with pid 8765
        shelly.0	2021-04-15 17:06:09.913	info	(8159) Shelly device 192.168.1.128 (shelly1 / shelly1-8CAAB5614D9F / SHSW-1#8CAAB5614D9F#1) with CoAP connected! Polltime set to 5 sec.
        shelly.0	2021-04-15 17:06:08.889	info	(8159) Shelly device 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) with CoAP connected! Polltime set to 5 sec.
        shelly.0	2021-04-15 17:06:08.384	info	(8159) Shelly device 192.168.1.122 (shellyswitch25 / shellyswitch25-483FDA8DDD51 / SHSW-25#483FDA8DDD51#1) with CoAP connected! Polltime set to 5 sec.
        sonoff.0	2021-04-15 17:06:07.384	info	(8365) Starting MQTT server on port 1884
        sonoff.0	2021-04-15 17:06:07.307	info	(8365) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
        shelly.0	2021-04-15 17:06:06.065	info	(8159) Listening for Shelly packets in the network
        shelly.0	2021-04-15 17:06:05.984	info	(8159) Starting Shelly adapter in CoAP modus.
        shelly.0	2021-04-15 17:06:05.933	info	(8159) Starting Adapter shelly.0 in version 4.0.7
        shelly.0	2021-04-15 17:06:05.885	info	(8159) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.2.16
        host.whome	2021-04-15 17:06:05.862	info	instance system.adapter.sonoff.0 started with pid 8365
        host.whome	2021-04-15 17:06:03.637	info	instance system.adapter.shelly.0 started with pid 8159
        sayit.0	2021-04-15 17:05:59.786	info	(7676) All files uploaded
        sayit.0	2021-04-15 17:05:59.573	info	(7676) Upload announce mp3 files
        sayit.0	2021-04-15 17:05:59.536	info	(7676) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
        node-red.0	2021-04-15 17:05:58.505	warn	(7014) 15 Apr 17:05:58 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
        host.whome	2021-04-15 17:05:57.481	info	instance system.adapter.sayit.0 started with pid 7676
        ping.0	2021-04-15 17:05:55.084	info	(7321) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
        node-red.0	2021-04-15 17:05:53.850	warn	(7014) 15 Apr 17:05:53 - [warn] Die Verwendung von editorTheme.palette.editable ist abgekündigt. Stattdessen externalModules.palette.allowInstall verwenden.
        host.whome	2021-04-15 17:05:53.362	info	instance system.adapter.ping.0 started with pid 7321
        host.whome	2021-04-15 17:05:51.992	info	Restart adapter system.adapter.web.0 because enabled
        host.whome	2021-04-15 17:05:51.992	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        node-red.0	2021-04-15 17:05:51.778	info	(7014) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
        web.0	2021-04-15 17:05:51.424	warn	(7008) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        web.0	2021-04-15 17:05:51.421	error	(7008) web.0 already running
        node-red.0	2021-04-15 17:05:51.316	info	(7014) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
        javascript.0	2021-04-15 17:05:50.371	info	(6399) script.js.rebootPi: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.366	info	(6399) Start javascript script.js.rebootPi
        javascript.0	2021-04-15 17:05:50.365	info	(6399) script.js.common.Wohnzimmer.Wohnzimmer: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.359	info	(6399) Start javascript script.js.common.Wohnzimmer.Wohnzimmer
        javascript.0	2021-04-15 17:05:50.357	info	(6399) script.js.common.Temperaturen.temp2: registered 3 subscriptions and 0 schedules
        javascript.0	2021-04-15 17:05:50.350	info	(6399) Start javascript script.js.common.Temperaturen.temp2
        javascript.0	2021-04-15 17:05:50.349	info	(6399) script.js.common.Temperaturen.aussen: registered 2 subscriptions and 0 schedules
        javascript.0	2021-04-15 17:05:50.343	info	(6399) Start javascript script.js.common.Temperaturen.aussen
        javascript.0	2021-04-15 17:05:50.342	info	(6399) script.js.common.Scripte.wama2: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.336	info	(6399) Start javascript script.js.common.Scripte.wama2
        javascript.0	2021-04-15 17:05:50.335	info	(6399) script.js.common.Scripte.Terasse_LED_stripe: registered 1 subscription and 1 schedule
        javascript.0	2021-04-15 17:05:50.328	info	(6399) Start javascript script.js.common.Scripte.Terasse_LED_stripe
        javascript.0	2021-04-15 17:05:50.327	info	(6399) script.js.common.Scripte.Tag: registered 0 subscriptions and 2 schedules
        javascript.0	2021-04-15 17:05:50.319	info	(6399) Start javascript script.js.common.Scripte.Tag
        javascript.0	2021-04-15 17:05:50.318	info	(6399) script.js.common.Scripte.Gute-Nacht: registered 2 subscriptions and 0 schedules
        javascript.0	2021-04-15 17:05:50.312	info	(6399) Start javascript script.js.common.Scripte.Gute-Nacht
        javascript.0	2021-04-15 17:05:50.311	info	(6399) script.js.common.Scripte.Flur: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.305	info	(6399) Start javascript script.js.common.Scripte.Flur
        javascript.0	2021-04-15 17:05:50.304	info	(6399) script.js.common.Scripte.Anwesenheit: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.297	info	(6399) Start javascript script.js.common.Scripte.Anwesenheit
        javascript.0	2021-04-15 17:05:50.296	info	(6399) script.js.common.Rolladen.RolladenAutomatik: registered 4 subscriptions and 2 schedules
        javascript.0	2021-04-15 17:05:50.279	info	(6399) Start javascript script.js.common.Rolladen.RolladenAutomatik
        javascript.0	2021-04-15 17:05:50.278	info	(6399) script.js.common.Rolladen.Rolladen: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.265	info	(6399) Start javascript script.js.common.Rolladen.Rolladen
        host.whome	2021-04-15 17:05:50.305	info	instance system.adapter.vis.0 terminated while should be started once
        javascript.0	2021-04-15 17:05:50.154	info	(6399) script.js.common.Heizung.Heizstab: registered 1 subscription and 1 schedule
        javascript.0	2021-04-15 17:05:50.144	info	(6399) Start javascript script.js.common.Heizung.Heizstab
        javascript.0	2021-04-15 17:05:50.143	info	(6399) script.js.common.Heizung.Auftau: registered 1 subscription and 1 schedule
        javascript.0	2021-04-15 17:05:50.107	info	(6399) Start javascript script.js.common.Heizung.Auftau
        javascript.0	2021-04-15 17:05:50.106	info	(6399) script.js.common.Buero.heizung_buero_boden: registered 1 subscription and 0 schedules
        javascript.0	2021-04-15 17:05:50.024	info	(6399) Start javascript script.js.common.Buero.heizung_buero_boden
        javascript.0	2021-04-15 17:05:49.886	info	(6399) received all states
        javascript.0	2021-04-15 17:05:49.827	info	(6399) received all objects
        vis.0	2021-04-15 17:05:49.704	info	(6713) Terminated (NO_ERROR): Without reason
        host.whome	2021-04-15 17:05:49.682	info	instance system.adapter.node-red.0 started with pid 7014
        host.whome	2021-04-15 17:05:49.653	info	instance system.adapter.web.0 started with pid 7008
        javascript.0	2021-04-15 17:05:49.056	info	(6399) requesting all objects
        javascript.0	2021-04-15 17:05:49.055	info	(6399) requesting all states
        javascript.0	2021-04-15 17:05:48.822	info	(6399) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
        vis.0	2021-04-15 17:05:48.521	info	(6713) vis license is OK.
        vis.0	2021-04-15 17:05:48.273	info	(6713) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
        host.whome	2021-04-15 17:05:46.071	info	Restart adapter system.adapter.telegram.1 because enabled
        host.whome	2021-04-15 17:05:46.069	error	instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.whome	2021-04-15 17:05:45.328	info	instance system.adapter.mqtt.0 started with pid 6670
        telegram.1	2021-04-15 17:05:45.109	warn	(6027) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        telegram.1	2021-04-15 17:05:45.103	error	(6027) telegram.1 already running
        host.whome	2021-04-15 17:05:43.741	info	instance system.adapter.javascript.0 started with pid 6399
        host.whome	2021-04-15 17:05:41.615	info	instance system.adapter.telegram.1 started with pid 6027
        info.0	2021-04-15 17:05:41.194	info	(5688) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
        host.whome	2021-04-15 17:05:40.493	info	Restart adapter system.adapter.telegram.0 because enabled
        host.whome	2021-04-15 17:05:40.493	error	instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        telegram.0	2021-04-15 17:05:39.912	warn	(5621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        telegram.0	2021-04-15 17:05:39.908	error	(5621) telegram.0 already running
        host.whome	2021-04-15 17:05:38.359	info	instance system.adapter.info.0 started with pid 5688
        host.whome	2021-04-15 17:05:37.684	info	instance system.adapter.telegram.0 started with pid 5621
        host.whome	2021-04-15 17:05:35.824	info	Restart adapter system.adapter.sonoff.0 because enabled
        host.whome	2021-04-15 17:05:35.824	error	instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        followthesun.0	2021-04-15 17:05:35.204	info	(5269) Daily sun parameter calculation scheduled for 00:00:23
        followthesun.0	2021-04-15 17:05:35.200	info	(5269) Sun position calculation will be done every 120 seconds
        followthesun.0	2021-04-15 17:05:35.164	info	(5269) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.followthesun, node: v12.22.1, js-controller: 3.2.16
        sonoff.0	2021-04-15 17:05:35.135	warn	(5300) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        sonoff.0	2021-04-15 17:05:35.132	error	(5300) sonoff.0 already running
        fb-checkpresence.0	2021-04-15 17:05:34.104	info	(4948) createMemberObjects finished successfully
        fb-checkpresence.0	2021-04-15 17:05:34.103	info	(4948) History function for Elke J3 disabled. Please select a history adapter in the configuration dialog!
        fb-checkpresence.0	2021-04-15 17:05:33.978	info	(4948) History function for Elke disabled. Please select a history adapter in the configuration dialog!
        fb-checkpresence.0	2021-04-15 17:05:33.877	info	(4948) History function for Uwe disabled. Please select a history adapter in the configuration dialog!
        fb-checkpresence.0	2021-04-15 17:05:33.717	info	(4948) createGlobalObjects finished successfully
        host.whome	2021-04-15 17:05:33.712	info	instance system.adapter.sonoff.0 started with pid 5300
        host.whome	2021-04-15 17:05:33.571	info	Restart adapter system.adapter.shelly.0 because enabled
        host.whome	2021-04-15 17:05:33.570	error	instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        fb-checkpresence.0	2021-04-15 17:05:33.427	info	(4948) service DeviceConfig1-Reboot is supported
        fb-checkpresence.0	2021-04-15 17:05:33.404	info	(4948) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
        fb-checkpresence.0	2021-04-15 17:05:33.387	info	(4948) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
        fb-checkpresence.0	2021-04-15 17:05:33.366	info	(4948) service DeviceInfo1-GetInfo is supported
        fb-checkpresence.0	2021-04-15 17:05:33.350	info	(4948) service WLANConfiguration3-GetInfo is supported
        host.whome	2021-04-15 17:05:33.330	info	instance system.adapter.followthesun.0 started with pid 5269
        fb-checkpresence.0	2021-04-15 17:05:33.330	info	(4948) service WLANConfiguration3-SetEnable is supported
        fb-checkpresence.0	2021-04-15 17:05:33.308	info	(4948) service WANPPPConnection1-GetInfo is supported
        fb-checkpresence.0	2021-04-15 17:05:33.288	info	(4948) service DeviceInfo1-GetSecurityPort is supported
        fb-checkpresence.0	2021-04-15 17:05:33.272	info	(4948) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2021-04-15 17:05:33.256	info	(4948) service Hosts1-GetSpecificHostEntry is supported
        fb-checkpresence.0	2021-04-15 17:05:33.235	info	(4948) service Hosts1-X_AVM-DE_GetMeshListPath is supported
        fb-checkpresence.0	2021-04-15 17:05:33.211	info	(4948) service Hosts1-X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2021-04-15 17:05:33.030	info	(4948) start fb-checkpresence: ip-address: "192.168.1.10" - interval devices: 1 Min. - interval members: 60 s
        fb-checkpresence.0	2021-04-15 17:05:32.989	info	(4948) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
        shelly.0	2021-04-15 17:05:32.944	warn	(4966) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        shelly.0	2021-04-15 17:05:32.940	error	(4966) shelly.0 already running
        host.whome	2021-04-15 17:05:31.141	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        cloud.0	2021-04-15 17:05:30.139	info	(4326) Connection changed: io server disconnect
        host.whome	2021-04-15 17:05:29.630	info	instance system.adapter.shelly.0 started with pid 4966
        host.whome	2021-04-15 17:05:29.520	info	instance system.adapter.fb-checkpresence.0 started with pid 4948
        cloud.0	2021-04-15 17:05:29.129	error	(4326) Cloud says: timeout
        host.whome	2021-04-15 17:05:27.436	info	Restart adapter system.adapter.sayit.0 because enabled
        host.whome	2021-04-15 17:05:27.435	error	instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        discovery.0	2021-04-15 17:05:27.205	info	(4621) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
        sayit.0	2021-04-15 17:05:26.859	warn	(4640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        sayit.0	2021-04-15 17:05:26.855	error	(4640) sayit.0 already running
        host.whome	2021-04-15 17:05:25.608	info	instance system.adapter.sayit.0 started with pid 4640
        host.whome	2021-04-15 17:05:25.435	info	instance system.adapter.discovery.0 started with pid 4621
        cloud.0	2021-04-15 17:05:24.164	info	(4326) Trying to connect as system.user.admin
        cloud.0	2021-04-15 17:05:23.803	info	(4326) Connecting with https://iobroker.net:10555 with "uwaizmann@gmail.com_c9f2a840-75ac-11eb-a278-59b6a78c6ee1"
        cloud.0	2021-04-15 17:05:23.721	info	(4326) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.1, js-controller: 3.2.16
        host.whome	2021-04-15 17:05:23.326	info	Restart adapter system.adapter.ping.0 because enabled
        host.whome	2021-04-15 17:05:23.325	error	instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        ping.0	2021-04-15 17:05:22.727	warn	(4301) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        ping.0	2021-04-15 17:05:22.724	error	(4301) ping.0 already running
        host.whome	2021-04-15 17:05:21.744	info	instance system.adapter.cloud.0 started with pid 4326
        host.whome	2021-04-15 17:05:21.559	info	instance system.adapter.ping.0 started with pid 4301
        backitup.0	2021-04-15 17:05:20.953	info	(3906) [iobroker] backup was activated at 03:00 every 1 day(s)
        backitup.0	2021-04-15 17:05:20.875	info	(3906) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
        chromecast.0	2021-04-15 17:05:19.911	info	(3979) Wohnzimmer - Connected client
        host.whome	2021-04-15 17:05:19.615	info	Restart adapter system.adapter.node-red.0 because enabled
        host.whome	2021-04-15 17:05:19.614	error	instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        chromecast.0	2021-04-15 17:05:19.162	info	(3979) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v12.22.1, js-controller: 3.2.16
        node-red.0	2021-04-15 17:05:19.016	warn	(3973) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        node-red.0	2021-04-15 17:05:19.013	error	(3973) node-red.0 already running
        host.whome	2021-04-15 17:05:17.597	info	instance system.adapter.chromecast.0 started with pid 3979
        host.whome	2021-04-15 17:05:17.567	info	instance system.adapter.node-red.0 started with pid 3973
        host.whome	2021-04-15 17:05:16.890	info	instance system.adapter.backitup.0 started with pid 3906
        host.whome	2021-04-15 17:05:15.296	info	Restart adapter system.adapter.mqtt.0 because enabled
        host.whome	2021-04-15 17:05:15.295	error	instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        mqtt.0	2021-04-15 17:05:14.720	error	(3643) mqtt.0 already running
        admin.0	2021-04-15 17:05:13.485	info	(3348) Use link "http://localhost:8081" to configure.
        host.whome	2021-04-15 17:05:13.654	info	Restart adapter system.adapter.javascript.0 because enabled
        host.whome	2021-04-15 17:05:13.653	error	instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.whome	2021-04-15 17:05:13.558	info	instance system.adapter.mqtt.0 started with pid 3643
        admin.0	2021-04-15 17:05:13.484	info	(3348) http server listening on port 8081
        admin.0	2021-04-15 17:05:13.117	info	(3348) received all objects
        javascript.0	2021-04-15 17:05:13.013	warn	(3305) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        javascript.0	2021-04-15 17:05:13.009	error	(3305) javascript.0 already running
        admin.0	2021-04-15 17:05:12.201	info	(3348) requesting all objects
        admin.0	2021-04-15 17:05:12.200	info	(3348) requesting all states
        admin.0	2021-04-15 17:05:12.121	info	(3348) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
        host.whome	2021-04-15 17:05:10.010	info	instance system.adapter.admin.0 started with pid 3348
        host.whome	2021-04-15 17:05:09.596	info	instance system.adapter.javascript.0 started with pid 3305
        host.whome	2021-04-15 17:05:08.329	info	Restart adapter system.adapter.info.0 because enabled
        host.whome	2021-04-15 17:05:08.328	error	instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        info.0	2021-04-15 17:05:07.754	warn	(2970) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        info.0	2021-04-15 17:05:07.751	error	(2970) info.0 already running
        host.whome	2021-04-15 17:05:05.582	info	instance system.adapter.info.0 started with pid 2970
        host.whome	2021-04-15 17:05:03.303	info	Restart adapter system.adapter.followthesun.0 because enabled
        host.whome	2021-04-15 17:05:03.302	error	instance system.adapter.followthesun.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        followthesun.0	2021-04-15 17:05:02.727	warn	(2671) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        followthesun.0	2021-04-15 17:05:02.724	error	(2671) followthesun.0 already running
        host.whome	2021-04-15 17:05:01.580	info	instance system.adapter.followthesun.0 started with pid 2671
        host.whome	2021-04-15 16:17:35.684	info	Restart adapter system.adapter.fb-checkpresence.0 because enabled
        host.whome	2021-04-15 16:17:35.683	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        fb-checkpresence.0	2021-04-15 16:17:35.108	warn	(2286) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        fb-checkpresence.0	2021-04-15 16:17:35.106	error	(2286) fb-checkpresence.0 already running
        host.whome	2021-04-15 16:17:33.769	info	instance system.adapter.fb-checkpresence.0 started with pid 2286
        host.whome	2021-04-15 16:17:31.615	info	Restart adapter system.adapter.discovery.0 because enabled
        host.whome	2021-04-15 16:17:31.614	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        discovery.0	2021-04-15 16:17:30.984	warn	(1939) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        discovery.0	2021-04-15 16:17:30.980	error	(1939) discovery.0 already running
        host.whome	2021-04-15 16:17:29.738	info	instance system.adapter.discovery.0 started with pid 1939
        host.whome	2021-04-15 16:17:27.923	info	Restart adapter system.adapter.cloud.0 because enabled
        host.whome	2021-04-15 16:17:27.922	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        cloud.0	2021-04-15 16:17:27.307	warn	(1640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        cloud.0	2021-04-15 16:17:27.304	error	(1640) cloud.0 already running
        host.whome	2021-04-15 16:17:25.765	info	instance system.adapter.cloud.0 started with pid 1640
        host.whome	2021-04-15 16:17:23.774	info	Restart adapter system.adapter.chromecast.0 because enabled
        host.whome	2021-04-15 16:17:23.773	error	instance system.adapter.chromecast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        host.whome	2021-04-15 16:17:23.772	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
        host.whome	2021-04-15 16:17:23.772	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
        host.whome	2021-04-15 16:17:23.771	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:168:15)
        host.whome	2021-04-15 16:17:23.771	error	Caught by controller[0]: at process.emit (events.js:314:20)
        host.whome	2021-04-15 16:17:23.771	error	Caught by controller[0]: at Object.onceWrapper (events.js:421:26)
        host.whome	2021-04-15 16:17:23.770	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
        host.whome	2021-04-15 16:17:23.770	error	Caught by controller[0]: at Adapter.emit (events.js:314:20)
        host.whome	2021-04-15 16:17:23.769	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
        host.whome	2021-04-15 16:17:23.769	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
        chromecast.0	2021-04-15 16:17:23.181	warn	(1322) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        chromecast.0	2021-04-15 16:17:23.178	error	(1322) chromecast.0 already running
        host.whome	2021-04-15 16:17:23.058	info	Restart adapter system.adapter.backitup.0 because enabled
        host.whome	2021-04-15 16:17:23.057	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        backitup.0	2021-04-15 16:17:22.451	warn	(1016) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        backitup.0	2021-04-15 16:17:22.448	error	(1016) backitup.0 already running
        host.whome	2021-04-15 16:17:21.708	info	instance system.adapter.chromecast.0 started with pid 1322
        host.whome	2021-04-15 16:17:17.698	info	instance system.adapter.backitup.0 started with pid 1016
        host.whome	2021-04-15 16:17:16.191	info	Restart adapter system.adapter.admin.0 because enabled
        host.whome	2021-04-15 16:17:16.190	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
        admin.0	2021-04-15 16:17:15.582	warn	(788) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
        admin.0	2021-04-15 16:17:15.578	error	(788) admin.0 already running
        host.whome	2021-04-15 16:17:13.783	info	instance system.adapter.admin.0 started with pid 788
        host.whome	2021-04-15 16:17:13.677	info	starting 19 instances
        host.whome	2021-04-15 16:17:13.618	info	25 instances found
        host.whome	2021-04-15 16:17:12.873	info	added notifications configuration of host
        host.whome	2021-04-15 16:17:12.807	info	connected to Objects and States
        host.whome-Server	2021-04-15 16:17:12.651	error	Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
        host.whome	2021-04-15 16:17:12.010	info	ip addresses: fe80::d8:6431:90b3:eeab
        host.whome	2021-04-15 16:17:12.010	info	hostname: whome, node: v12.22.1
        Hier noch dmesg -T nach dem Neustart
        pi@whome:~ $ dmesg -T
        [Do Apr 15 17:04:17 2021] Booting Linux on physical CPU 0x0
        [Do Apr 15 17:04:17 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
        [Do Apr 15 17:04:17 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [Do Apr 15 17:04:17 2021] CPU: div instructions available: patching division code
        [Do Apr 15 17:04:17 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [Do Apr 15 17:04:17 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
        [Do Apr 15 17:04:17 2021] Memory policy: Data cache writealloc
        [Do Apr 15 17:04:17 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
        [Do Apr 15 17:04:17 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [Do Apr 15 17:04:17 2021] Zone ranges:
        [Do Apr 15 17:04:17 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
        [Do Apr 15 17:04:17 2021]   Normal   empty
        [Do Apr 15 17:04:17 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
        [Do Apr 15 17:04:17 2021] Movable zone start for each node
        [Do Apr 15 17:04:17 2021] Early memory node ranges
        [Do Apr 15 17:04:17 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
        [Do Apr 15 17:04:17 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
        [Do Apr 15 17:04:17 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
        [Do Apr 15 17:04:17 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
        [Do Apr 15 17:04:17 2021] On node 0 totalpages: 2061056
        [Do Apr 15 17:04:17 2021]   DMA zone: 2304 pages used for memmap
        [Do Apr 15 17:04:17 2021]   DMA zone: 0 pages reserved
        [Do Apr 15 17:04:17 2021]   DMA zone: 196608 pages, LIFO batch:63
        [Do Apr 15 17:04:17 2021]   HighMem zone: 1864448 pages, LIFO batch:63
        [Do Apr 15 17:04:17 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
        [Do Apr 15 17:04:17 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
        [Do Apr 15 17:04:17 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [Do Apr 15 17:04:17 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
        [Do Apr 15 17:04:17 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:EE:BA:65 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=ac5233f7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Do Apr 15 17:04:17 2021] Kernel parameter elevator= does not have any effect anymore.
                                  Please use sysfs to set IO scheduler for individual devices.
        [Do Apr 15 17:04:17 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [Do Apr 15 17:04:17 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [Do Apr 15 17:04:17 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
        [Do Apr 15 17:04:17 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
        [Do Apr 15 17:04:17 2021] Memory: 7799064K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183016K reserved, 262144K cma-reserved, 7457792K highmem)
        [Do Apr 15 17:04:17 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [Do Apr 15 17:04:17 2021] ftrace: allocating 33942 entries in 67 pages
        [Do Apr 15 17:04:17 2021] ftrace: allocated 67 pages with 3 groups
        [Do Apr 15 17:04:17 2021] rcu: Hierarchical RCU implementation.
        [Do Apr 15 17:04:17 2021]       Rude variant of Tasks RCU enabled.
        [Do Apr 15 17:04:17 2021]       Tracing variant of Tasks RCU enabled.
        [Do Apr 15 17:04:17 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [Do Apr 15 17:04:17 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [Do Apr 15 17:04:17 2021] GIC: Using split EOI/Deactivate mode
        [Do Apr 15 17:04:17 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
        [Do Apr 15 17:04:17 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [Do Apr 15 17:04:17 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [Do Apr 15 17:04:17 2021] bcm2835: system timer (irq = 25)
        [Do Apr 15 17:04:17 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [Do Apr 15 17:04:17 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [Do Apr 15 17:04:17 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [Do Apr 15 17:04:17 2021] Switching to timer-based delay loop, resolution 18ns
        [Do Apr 15 17:04:17 2021] Console: colour dummy device 80x30
        [Do Apr 15 17:04:17 2021] printk: console [tty1] enabled
        [Do Apr 15 17:04:17 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [Do Apr 15 17:04:17 2021] pid_max: default: 32768 minimum: 301
        [Do Apr 15 17:04:17 2021] LSM: Security Framework initializing
        [Do Apr 15 17:04:17 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [Do Apr 15 17:04:17 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [Do Apr 15 17:04:17 2021] Disabling memory control group subsystem
        [Do Apr 15 17:04:17 2021] CPU: Testing write buffer coherency: ok
        [Do Apr 15 17:04:17 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [Do Apr 15 17:04:17 2021] Setting up static identity map for 0x200000 - 0x20003c
        [Do Apr 15 17:04:17 2021] rcu: Hierarchical SRCU implementation.
        [Do Apr 15 17:04:17 2021] smp: Bringing up secondary CPUs ...
        [Do Apr 15 17:04:17 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [Do Apr 15 17:04:17 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [Do Apr 15 17:04:17 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [Do Apr 15 17:04:17 2021] smp: Brought up 1 node, 4 CPUs
        [Do Apr 15 17:04:17 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [Do Apr 15 17:04:17 2021] CPU: All CPU(s) started in HYP mode.
        [Do Apr 15 17:04:17 2021] CPU: Virtualization extensions available.
        [Do Apr 15 17:04:17 2021] devtmpfs: initialized
        [Do Apr 15 17:04:17 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [Do Apr 15 17:04:17 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [Do Apr 15 17:04:17 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [Do Apr 15 17:04:17 2021] pinctrl core: initialized pinctrl subsystem
        [Do Apr 15 17:04:17 2021] NET: Registered protocol family 16
        [Do Apr 15 17:04:17 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [Do Apr 15 17:04:17 2021] audit: initializing netlink subsys (disabled)
        [Do Apr 15 17:04:17 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
        [Do Apr 15 17:04:17 2021] thermal_sys: Registered thermal governor 'step_wise'
        [Do Apr 15 17:04:17 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [Do Apr 15 17:04:17 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [Do Apr 15 17:04:17 2021] Serial: AMBA PL011 UART driver
        [Do Apr 15 17:04:17 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [Do Apr 15 17:04:17 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
        [Do Apr 15 17:04:17 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
        [Do Apr 15 17:04:17 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [Do Apr 15 17:04:17 2021] vgaarb: loaded
        [Do Apr 15 17:04:17 2021] SCSI subsystem initialized
        [Do Apr 15 17:04:17 2021] usbcore: registered new interface driver usbfs
        [Do Apr 15 17:04:17 2021] usbcore: registered new interface driver hub
        [Do Apr 15 17:04:17 2021] usbcore: registered new device driver usb
        [Do Apr 15 17:04:17 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
        [Do Apr 15 17:04:17 2021] clocksource: Switched to clocksource arch_sys_counter
        [Do Apr 15 17:04:18 2021] VFS: Disk quotas dquot_6.6.0
        [Do Apr 15 17:04:18 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [Do Apr 15 17:04:18 2021] FS-Cache: Loaded
        [Do Apr 15 17:04:18 2021] CacheFiles: Loaded
        [Do Apr 15 17:04:18 2021] simple-framebuffer 3e2fe000.framebuffer: framebuffer at 0x3e2fe000, 0x7f8000 bytes, mapped to 0x(ptrval)
        [Do Apr 15 17:04:18 2021] simple-framebuffer 3e2fe000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
        [Do Apr 15 17:04:18 2021] Console: switching to colour frame buffer device 240x67
        [Do Apr 15 17:04:18 2021] simple-framebuffer 3e2fe000.framebuffer: fb0: simplefb registered!
        [Do Apr 15 17:04:18 2021] NET: Registered protocol family 2
        [Do Apr 15 17:04:18 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [Do Apr 15 17:04:18 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [Do Apr 15 17:04:18 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [Do Apr 15 17:04:18 2021] TCP: Hash tables configured (established 8192 bind 8192)
        [Do Apr 15 17:04:18 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [Do Apr 15 17:04:18 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [Do Apr 15 17:04:18 2021] NET: Registered protocol family 1
        [Do Apr 15 17:04:18 2021] RPC: Registered named UNIX socket transport module.
        [Do Apr 15 17:04:18 2021] RPC: Registered udp transport module.
        [Do Apr 15 17:04:18 2021] RPC: Registered tcp transport module.
        [Do Apr 15 17:04:18 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [Do Apr 15 17:04:18 2021] PCI: CLS 0 bytes, default 64
        [Do Apr 15 17:04:18 2021] Initialise system trusted keyrings
        [Do Apr 15 17:04:18 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
        [Do Apr 15 17:04:18 2021] zbud: loaded
        [Do Apr 15 17:04:18 2021] FS-Cache: Netfs 'nfs' registered for caching
        [Do Apr 15 17:04:18 2021] NFS: Registering the id_resolver key type
        [Do Apr 15 17:04:18 2021] Key type id_resolver registered
        [Do Apr 15 17:04:18 2021] Key type id_legacy registered
        [Do Apr 15 17:04:18 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [Do Apr 15 17:04:18 2021] Key type asymmetric registered
        [Do Apr 15 17:04:18 2021] Asymmetric key parser 'x509' registered
        [Do Apr 15 17:04:18 2021] bounce: pool size: 64 pages
        [Do Apr 15 17:04:18 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [Do Apr 15 17:04:18 2021] io scheduler mq-deadline registered
        [Do Apr 15 17:04:18 2021] io scheduler kyber registered
        [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
        [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
        [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
        [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [Do Apr 15 17:04:18 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
        [Do Apr 15 17:04:18 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
        [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
        [Do Apr 15 17:04:18 2021] PCI: bus0: Fast back to back transfers disabled
        [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
        [Do Apr 15 17:04:18 2021] PCI: bus1: Fast back to back transfers disabled
        [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
        [Do Apr 15 17:04:18 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [Do Apr 15 17:04:18 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [Do Apr 15 17:04:18 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
        [Do Apr 15 17:04:18 2021] iproc-rng200 fe104000.rng: hwrng registered
        [Do Apr 15 17:04:18 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
        [Do Apr 15 17:04:18 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [Do Apr 15 17:04:18 2021] brd: module loaded
        [Do Apr 15 17:04:18 2021] loop: module loaded
        [Do Apr 15 17:04:18 2021] Loading iSCSI transport class v2.0-870.
        [Do Apr 15 17:04:18 2021] libphy: Fixed MDIO Bus: probed
        [Do Apr 15 17:04:18 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [Do Apr 15 17:04:18 2021] libphy: bcmgenet MII bus: probed
        [Do Apr 15 17:04:18 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver r8152
        [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver lan78xx
        [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver smsc95xx
        [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
        [Do Apr 15 17:04:18 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
        [Do Apr 15 17:04:18 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [Do Apr 15 17:04:18 2021] usb usb1: Product: xHCI Host Controller
        [Do Apr 15 17:04:18 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        [Do Apr 15 17:04:18 2021] usb usb1: SerialNumber: 0000:01:00.0
        [Do Apr 15 17:04:18 2021] hub 1-0:1.0: USB hub found
        [Do Apr 15 17:04:18 2021] hub 1-0:1.0: 1 port detected
        [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [Do Apr 15 17:04:18 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
        [Do Apr 15 17:04:18 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [Do Apr 15 17:04:18 2021] usb usb2: Product: xHCI Host Controller
        [Do Apr 15 17:04:18 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
        [Do Apr 15 17:04:18 2021] usb usb2: SerialNumber: 0000:01:00.0
        [Do Apr 15 17:04:18 2021] hub 2-0:1.0: USB hub found
        [Do Apr 15 17:04:18 2021] hub 2-0:1.0: 4 ports detected
        [Do Apr 15 17:04:18 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [Do Apr 15 17:04:18 2021] dwc_otg: FIQ enabled
        [Do Apr 15 17:04:18 2021] dwc_otg: NAK holdoff enabled
        [Do Apr 15 17:04:18 2021] dwc_otg: FIQ split-transaction FSM enabled
        [Do Apr 15 17:04:18 2021] Module dwc_common_port init
        [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver uas
        [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver usb-storage
        [Do Apr 15 17:04:18 2021] mousedev: PS/2 mouse device common for all mice
        [Do Apr 15 17:04:18 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [Do Apr 15 17:04:18 2021] sdhci: Secure Digital Host Controller Interface driver
        [Do Apr 15 17:04:18 2021] sdhci: Copyright(c) Pierre Ossman
        [Do Apr 15 17:04:18 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [Do Apr 15 17:04:18 2021] sdhci-pltfm: SDHCI platform and OF driver helper
        [Do Apr 15 17:04:18 2021] ledtrig-cpu: registered to indicate activity on CPUs
        [Do Apr 15 17:04:18 2021] hid: raw HID events driver (C) Jiri Kosina
        [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver usbhid
        [Do Apr 15 17:04:18 2021] usbhid: USB HID core driver
        [Do Apr 15 17:04:18 2021] Initializing XFRM netlink socket
        [Do Apr 15 17:04:18 2021] NET: Registered protocol family 17
        [Do Apr 15 17:04:18 2021] Key type dns_resolver registered
        [Do Apr 15 17:04:18 2021] Registering SWP/SWPB emulation handler
        [Do Apr 15 17:04:18 2021] registered taskstats version 1
        [Do Apr 15 17:04:18 2021] Loading compiled-in X.509 certificates
        [Do Apr 15 17:04:18 2021] Key type ._fscrypt registered
        [Do Apr 15 17:04:18 2021] Key type .fscrypt registered
        [Do Apr 15 17:04:18 2021] Key type fscrypt-provisioning registered
        [Do Apr 15 17:04:18 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
        [Do Apr 15 17:04:18 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [Do Apr 15 17:04:18 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
        [Do Apr 15 17:04:18 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [Do Apr 15 17:04:18 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [Do Apr 15 17:04:18 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [Do Apr 15 17:04:18 2021] of_cfs_init
        [Do Apr 15 17:04:18 2021] of_cfs_init: OK
        [Do Apr 15 17:04:18 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [Do Apr 15 17:04:18 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [Do Apr 15 17:04:18 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [Do Apr 15 17:04:18 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        [Do Apr 15 17:04:18 2021] Waiting for root device PARTUUID=ac5233f7-02...
        [Do Apr 15 17:04:18 2021] random: fast init done
        [Do Apr 15 17:04:18 2021] mmc1: new high speed SDIO card at address 0001
        [Do Apr 15 17:04:18 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [Do Apr 15 17:04:19 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [Do Apr 15 17:04:19 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [Do Apr 15 17:04:19 2021] usb 1-1: Product: USB2.0 Hub
        [Do Apr 15 17:04:19 2021] hub 1-1:1.0: USB hub found
        [Do Apr 15 17:04:19 2021] hub 1-1:1.0: 4 ports detected
        [Do Apr 15 17:04:19 2021] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
        [Do Apr 15 17:04:19 2021] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
        [Do Apr 15 17:04:19 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [Do Apr 15 17:04:19 2021] usb 1-1.1: Product: USB2.0 Hub
        [Do Apr 15 17:04:19 2021] hub 1-1.1:1.0: USB hub found
        [Do Apr 15 17:04:19 2021] hub 1-1.1:1.0: 4 ports detected
        [Do Apr 15 17:04:19 2021] usb 1-1.1.3: new high-speed USB device number 4 using xhci_hcd
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3: Product: USB2.0 Hub
        [Do Apr 15 17:04:20 2021] hub 1-1.1.3:1.0: USB hub found
        [Do Apr 15 17:04:20 2021] hub 1-1.1.3:1.0: 4 ports detected
        [Do Apr 15 17:04:20 2021] usb 1-1.1.4: new high-speed USB device number 5 using xhci_hcd
        [Do Apr 15 17:04:20 2021] usb 1-1.1.4: New USB device found, idVendor=2109, idProduct=0711, bcdDevice=12.00
        [Do Apr 15 17:04:20 2021] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
        [Do Apr 15 17:04:20 2021] usb 1-1.1.4: Product: VLI Product String
        [Do Apr 15 17:04:20 2021] usb 1-1.1.4: Manufacturer: VLI manufacture String
        [Do Apr 15 17:04:20 2021] usb 1-1.1.4: SerialNumber: 000000123AD6
        [Do Apr 15 17:04:20 2021] usb-storage 1-1.1.4:1.0: USB Mass Storage device detected
        [Do Apr 15 17:04:20 2021] usb-storage 1-1.1.4:1.0: Quirks match for vid 2109 pid 0711: 2000000
        [Do Apr 15 17:04:20 2021] scsi host0: usb-storage 1-1.1.4:1.0
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: new low-speed USB device number 6 using xhci_hcd
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: New USB device found, idVendor=1c4f, idProduct=0026, bcdDevice= 1.10
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: Product: USB Keyboard
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: Manufacturer: SIGMACHIP
        [Do Apr 15 17:04:20 2021] input: SIGMACHIP USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/0003:1C4F:0026.0001/input/input0
        [Do Apr 15 17:04:20 2021] hid-generic 0003:1C4F:0026.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:01:00.0-1.1.3.3/input0
        [Do Apr 15 17:04:20 2021] input: SIGMACHIP USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:1C4F:0026.0002/input/input1
        [Do Apr 15 17:04:20 2021] input: SIGMACHIP USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:1C4F:0026.0002/input/input2
        [Do Apr 15 17:04:20 2021] hid-generic 0003:1C4F:0026.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:01:00.0-1.1.3.3/input1
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: new full-speed USB device number 7 using xhci_hcd
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.00
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: Product: USB Receiver
        [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: Manufacturer: Logitech
        [Do Apr 15 17:04:20 2021] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.0/0003:046D:C52B.0003/input/input3
        [Do Apr 15 17:04:21 2021] hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input0
        [Do Apr 15 17:04:21 2021] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input4
        [Do Apr 15 17:04:21 2021] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input5
        [Do Apr 15 17:04:21 2021] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input6
        [Do Apr 15 17:04:21 2021] hid-generic 0003:046D:C52B.0004: input,hiddev96,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input1
        [Do Apr 15 17:04:21 2021] hid-generic 0003:046D:C52B.0005: hiddev97,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
        [Do Apr 15 17:04:21 2021] scsi 0:0:0:0: Direct-Access     INTEL SS DSA2CW080G3      4PC1 PQ: 0 ANSI: 6
        [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] 156301484 512-byte logical blocks: (80.0 GB/74.5 GiB)
        [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Write Protect is off
        [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Mode Sense: 1f 00 00 00
        [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
        [Do Apr 15 17:04:21 2021]  sda: sda1 sda2
        [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Attached SCSI disk
        [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
        [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): write access will be enabled during recovery
        [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): 6 orphan inodes deleted
        [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): recovery complete
        [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [Do Apr 15 17:04:21 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Do Apr 15 17:04:21 2021] devtmpfs: mounted
        [Do Apr 15 17:04:21 2021] Freeing unused kernel memory: 2048K
        [Do Apr 15 17:04:21 2021] Run /sbin/init as init process
        [Do Apr 15 17:04:21 2021]   with arguments:
        [Do Apr 15 17:04:21 2021]     /sbin/init
        [Do Apr 15 17:04:21 2021]   with environment:
        [Do Apr 15 17:04:21 2021]     HOME=/
        [Do Apr 15 17:04:21 2021]     TERM=linux
        [Do Apr 15 17:04:22 2021] systemd[1]: System time before build time, advancing clock.
        [Do Apr 15 17:04:22 2021] NET: Registered protocol family 10
        [Do Apr 15 17:04:22 2021] Segment Routing with IPv6
        [Do Apr 15 17:04:22 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [Do Apr 15 17:04:22 2021] systemd[1]: Detected architecture arm.
        [Do Apr 15 17:04:22 2021] systemd[1]: Set hostname to <whome>.
        [Do Apr 15 17:04:23 2021] random: systemd: uninitialized urandom read (16 bytes read)
        [Do Apr 15 17:04:23 2021] systemd[1]: Listening on Journal Audit Socket.
        [Do Apr 15 17:04:23 2021] systemd[1]: Listening on Syslog Socket.
        [Do Apr 15 17:04:23 2021] systemd[1]: Listening on Journal Socket.
        [Do Apr 15 17:04:23 2021] systemd[1]: Starting Create list of required static device nodes for the current kernel...
        [Do Apr 15 17:04:23 2021] systemd[1]: Starting Restore / save the current clock...
        [Do Apr 15 17:04:23 2021] systemd[1]: Mounting RPC Pipe File System...
        [Do Apr 15 17:04:23 2021] systemd[1]: Starting Load Kernel Modules...
        [Do Apr 15 17:04:23 2021] i2c /dev entries driver
        [Do Apr 15 17:04:24 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
        [Do Apr 15 17:04:24 2021] systemd-journald[119]: Received request to flush runtime journal from PID 1
        [Do Apr 15 17:04:25 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [Do Apr 15 17:04:25 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [Do Apr 15 17:04:25 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [Do Apr 15 17:04:25 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [Do Apr 15 17:04:25 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [Do Apr 15 17:04:25 2021] mc: Linux media interface: v0.10
        [Do Apr 15 17:04:25 2021] bcm2835_audio bcm2835_audio: card created with 4 channels
        [Do Apr 15 17:04:25 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [Do Apr 15 17:04:25 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [Do Apr 15 17:04:25 2021] [vc_sm_connected_init]: start
        [Do Apr 15 17:04:25 2021] [vc_sm_connected_init]: installed successfully
        [Do Apr 15 17:04:25 2021] videodev: Linux video capture interface: v2.00
        [Do Apr 15 17:04:25 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [Do Apr 15 17:04:25 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [Do Apr 15 17:04:25 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [Do Apr 15 17:04:25 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [Do Apr 15 17:04:25 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [Do Apr 15 17:04:25 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [Do Apr 15 17:04:25 2021] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
        [Do Apr 15 17:04:25 2021] fb0: switching to vc4drmfb from simple
        [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [Do Apr 15 17:04:25 2021] Console: switching to colour dummy device 80x30
        [Do Apr 15 17:04:25 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        [Do Apr 15 17:04:25 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [Do Apr 15 17:04:26 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [Do Apr 15 17:04:26 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
        [Do Apr 15 17:04:26 2021] Console: switching to colour frame buffer device 240x67
        [Do Apr 15 17:04:26 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
        [Do Apr 15 17:04:26 2021] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
        [Do Apr 15 17:04:26 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [Do Apr 15 17:04:26 2021] usbcore: registered new interface driver brcmfmac
        [Do Apr 15 17:04:26 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        [Do Apr 15 17:04:26 2021] random: crng init done
        [Do Apr 15 17:04:26 2021] random: 7 urandom warning(s) missed due to ratelimiting
        [Do Apr 15 17:04:26 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
        [Do Apr 15 17:04:26 2021] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
        [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:400a Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input8
        [Do Apr 15 17:04:26 2021] hid-generic 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
        [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:4003 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input12
        [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:4003 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input13
        [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:4003 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input14
        [Do Apr 15 17:04:26 2021] hid-generic 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4003] on usb-0000:01:00.0-1.1.3.4/input2:2
        [Do Apr 15 17:04:27 2021] input: Logitech Wireless Device PID:400a as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input18
        [Do Apr 15 17:04:27 2021] logitech-hidpp-device 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
        [Do Apr 15 17:04:27 2021] input: Logitech K270 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input19
        [Do Apr 15 17:04:27 2021] logitech-hidpp-device 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K270] on usb-0000:01:00.0-1.1.3.4/input2:2
        [Do Apr 15 17:04:28 2021] uart-pl011 fe201000.serial: no DMA platform data
        [Do Apr 15 17:04:29 2021] 8021q: 802.1Q VLAN Support v1.8
        [Do Apr 15 17:04:29 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
        [Do Apr 15 17:04:30 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
        [Do Apr 15 17:04:30 2021] bcmgenet fd580000.ethernet eth0: Link is Down
        [Do Apr 15 17:04:33 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
        [Do Apr 15 17:04:33 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [Do Apr 15 17:04:35 2021] Bluetooth: Core ver 2.22
        [Do Apr 15 17:04:35 2021] NET: Registered protocol family 31
        [Do Apr 15 17:04:35 2021] Bluetooth: HCI device and connection manager initialized
        [Do Apr 15 17:04:35 2021] Bluetooth: HCI socket layer initialized
        [Do Apr 15 17:04:35 2021] Bluetooth: L2CAP socket layer initialized
        [Do Apr 15 17:04:35 2021] Bluetooth: SCO socket layer initialized
        [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART driver ver 2.3
        [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART protocol H4 registered
        [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART protocol Broadcom registered
        [Do Apr 15 17:04:36 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [Do Apr 15 17:04:36 2021] Bluetooth: BNEP filters: protocol multicast
        [Do Apr 15 17:04:36 2021] Bluetooth: BNEP socket layer initialized
        pi@whome:~ $
        • Uwe WaizmannU Uwe Waizmann
          gestern neu installiert und lief bis gerade eben.
          Platform linux
          Betriebssystem linux
          Architektur arm
          CPUs 4
          Geschwindigkeit 1500 MHz
          Modell ARMv7 Processor rev 3 (v7l)
          RAM 7.69 GB
          System Betriebszeit 00:11:33
          Node.js v12.22.1
          NPM 6.14.12
          Festplatte Größe 73.07 GB
          Festplatte frei 68.55 GB
          Anzahl der Adapter 338
          Betriebszeit 00:58:41
          Aktive Instanzen 18
          Hostname whome
          Um 16: 17 muss es dann passiert sein
          cloud.0	2021-04-15 17:07:24.077	info	(4326) Connection changed: connect
          cloud.0	2021-04-15 17:07:23.954	info	(4326) Trying to connect as system.user.admin
          sonoff.0	2021-04-15 17:06:36.217	info	(8365) Client [Temp2-DS18B20] connected with secret 1618499196215_9761
          sonoff.0	2021-04-15 17:06:34.602	info	(8365) Client [Terrasse_lux_led] connected with secret 1618499194601_2835
          sonoff.0	2021-04-15 17:06:32.648	info	(8365) Client [WekstattTemp] connected with secret 1618499192646_1301
          sonoff.0	2021-04-15 17:06:31.835	info	(8365) Client [Buero_Temp] connected with secret 1618499191833_7737
          sonoff.0	2021-04-15 17:06:29.594	info	(8365) Client [Steckdose12] connected with secret 1618499189588_613
          sonoff.0	2021-04-15 17:06:28.766	info	(8365) Client [Schalter-TV] connected with secret 1618499188765_7489
          web.0	2021-04-15 17:06:24.095	info	(9699) http server listening on port 8082
          web.0	2021-04-15 17:06:24.086	info	(9699) Allow states only when user is owner: false
          web.0	2021-04-15 17:06:24.084	info	(9699) simpleAPI server listening on port 8082
          web.0	2021-04-15 17:06:24.069	info	(9699) socket.io server listening on port 8082
          cloud.0	2021-04-15 17:06:23.944	info	(4326) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
          cloud.0	2021-04-15 17:06:23.820	info	(4326) Trying to connect as system.user.admin
          web.0	2021-04-15 17:06:23.768	info	(9699) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
          host.whome	2021-04-15 17:06:22.011	info	instance system.adapter.web.0 started with pid 9699
          sonoff.0	2021-04-15 17:06:19.987	info	(8365) Client [wama] connected with secret 1618499179967_1240
          telegram.1	2021-04-15 17:06:18.683	info	(9216) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
          shelly.0	2021-04-15 17:06:18.009	info	(8159) Shelly device 192.168.1.123 (shellyswitch25 / shellyswitch25-84CCA8B0CC8F / SHSW-25#84CCA8B0CC8F#1) with CoAP connected! Polltime set to 5 sec.
          host.whome	2021-04-15 17:06:16.139	info	instance system.adapter.telegram.1 started with pid 9216
          shelly.0	2021-04-15 17:06:15.551	info	(8159) Shelly device 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) with CoAP connected! Polltime set to 5 sec.
          shelly.0	2021-04-15 17:06:15.062	info	(8159) Shelly device 192.168.1.131 (shellydimmer2 / shellydimmer2-40F520015E03 / SHDM-2#40F520015E03#1) with CoAP connected! Polltime set to 5 sec.
          shelly.0	2021-04-15 17:06:14.829	info	(8159) Shelly device 192.168.1.127 (shelly1 / shelly1-F4CFA2E46301 / SHSW-1#F4CFA2E46301#1) with CoAP connected! Polltime set to 5 sec.
          shelly.0	2021-04-15 17:06:14.115	info	(8159) Shelly device 192.168.1.126 (shelly1 / shelly1-483FDA91AF1A / SHSW-1#483FDA91AF1A#1) with CoAP connected! Polltime set to 5 sec.
          telegram.0	2021-04-15 17:06:13.163	info	(8765) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
          shelly.0	2021-04-15 17:06:10.740	info	(8159) Shelly device 192.168.1.121 (shellyswitch25 / shellyswitch25-84CCA8B09E95 / SHSW-25#84CCA8B09E95#1) with CoAP connected! Polltime set to 5 sec.
          host.whome	2021-04-15 17:06:10.609	info	instance system.adapter.telegram.0 started with pid 8765
          shelly.0	2021-04-15 17:06:09.913	info	(8159) Shelly device 192.168.1.128 (shelly1 / shelly1-8CAAB5614D9F / SHSW-1#8CAAB5614D9F#1) with CoAP connected! Polltime set to 5 sec.
          shelly.0	2021-04-15 17:06:08.889	info	(8159) Shelly device 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) with CoAP connected! Polltime set to 5 sec.
          shelly.0	2021-04-15 17:06:08.384	info	(8159) Shelly device 192.168.1.122 (shellyswitch25 / shellyswitch25-483FDA8DDD51 / SHSW-25#483FDA8DDD51#1) with CoAP connected! Polltime set to 5 sec.
          sonoff.0	2021-04-15 17:06:07.384	info	(8365) Starting MQTT server on port 1884
          sonoff.0	2021-04-15 17:06:07.307	info	(8365) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
          shelly.0	2021-04-15 17:06:06.065	info	(8159) Listening for Shelly packets in the network
          shelly.0	2021-04-15 17:06:05.984	info	(8159) Starting Shelly adapter in CoAP modus.
          shelly.0	2021-04-15 17:06:05.933	info	(8159) Starting Adapter shelly.0 in version 4.0.7
          shelly.0	2021-04-15 17:06:05.885	info	(8159) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.2.16
          host.whome	2021-04-15 17:06:05.862	info	instance system.adapter.sonoff.0 started with pid 8365
          host.whome	2021-04-15 17:06:03.637	info	instance system.adapter.shelly.0 started with pid 8159
          sayit.0	2021-04-15 17:05:59.786	info	(7676) All files uploaded
          sayit.0	2021-04-15 17:05:59.573	info	(7676) Upload announce mp3 files
          sayit.0	2021-04-15 17:05:59.536	info	(7676) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
          node-red.0	2021-04-15 17:05:58.505	warn	(7014) 15 Apr 17:05:58 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
          host.whome	2021-04-15 17:05:57.481	info	instance system.adapter.sayit.0 started with pid 7676
          ping.0	2021-04-15 17:05:55.084	info	(7321) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
          node-red.0	2021-04-15 17:05:53.850	warn	(7014) 15 Apr 17:05:53 - [warn] Die Verwendung von editorTheme.palette.editable ist abgekündigt. Stattdessen externalModules.palette.allowInstall verwenden.
          host.whome	2021-04-15 17:05:53.362	info	instance system.adapter.ping.0 started with pid 7321
          host.whome	2021-04-15 17:05:51.992	info	Restart adapter system.adapter.web.0 because enabled
          host.whome	2021-04-15 17:05:51.992	error	instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          node-red.0	2021-04-15 17:05:51.778	info	(7014) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
          web.0	2021-04-15 17:05:51.424	warn	(7008) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          web.0	2021-04-15 17:05:51.421	error	(7008) web.0 already running
          node-red.0	2021-04-15 17:05:51.316	info	(7014) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
          javascript.0	2021-04-15 17:05:50.371	info	(6399) script.js.rebootPi: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.366	info	(6399) Start javascript script.js.rebootPi
          javascript.0	2021-04-15 17:05:50.365	info	(6399) script.js.common.Wohnzimmer.Wohnzimmer: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.359	info	(6399) Start javascript script.js.common.Wohnzimmer.Wohnzimmer
          javascript.0	2021-04-15 17:05:50.357	info	(6399) script.js.common.Temperaturen.temp2: registered 3 subscriptions and 0 schedules
          javascript.0	2021-04-15 17:05:50.350	info	(6399) Start javascript script.js.common.Temperaturen.temp2
          javascript.0	2021-04-15 17:05:50.349	info	(6399) script.js.common.Temperaturen.aussen: registered 2 subscriptions and 0 schedules
          javascript.0	2021-04-15 17:05:50.343	info	(6399) Start javascript script.js.common.Temperaturen.aussen
          javascript.0	2021-04-15 17:05:50.342	info	(6399) script.js.common.Scripte.wama2: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.336	info	(6399) Start javascript script.js.common.Scripte.wama2
          javascript.0	2021-04-15 17:05:50.335	info	(6399) script.js.common.Scripte.Terasse_LED_stripe: registered 1 subscription and 1 schedule
          javascript.0	2021-04-15 17:05:50.328	info	(6399) Start javascript script.js.common.Scripte.Terasse_LED_stripe
          javascript.0	2021-04-15 17:05:50.327	info	(6399) script.js.common.Scripte.Tag: registered 0 subscriptions and 2 schedules
          javascript.0	2021-04-15 17:05:50.319	info	(6399) Start javascript script.js.common.Scripte.Tag
          javascript.0	2021-04-15 17:05:50.318	info	(6399) script.js.common.Scripte.Gute-Nacht: registered 2 subscriptions and 0 schedules
          javascript.0	2021-04-15 17:05:50.312	info	(6399) Start javascript script.js.common.Scripte.Gute-Nacht
          javascript.0	2021-04-15 17:05:50.311	info	(6399) script.js.common.Scripte.Flur: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.305	info	(6399) Start javascript script.js.common.Scripte.Flur
          javascript.0	2021-04-15 17:05:50.304	info	(6399) script.js.common.Scripte.Anwesenheit: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.297	info	(6399) Start javascript script.js.common.Scripte.Anwesenheit
          javascript.0	2021-04-15 17:05:50.296	info	(6399) script.js.common.Rolladen.RolladenAutomatik: registered 4 subscriptions and 2 schedules
          javascript.0	2021-04-15 17:05:50.279	info	(6399) Start javascript script.js.common.Rolladen.RolladenAutomatik
          javascript.0	2021-04-15 17:05:50.278	info	(6399) script.js.common.Rolladen.Rolladen: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.265	info	(6399) Start javascript script.js.common.Rolladen.Rolladen
          host.whome	2021-04-15 17:05:50.305	info	instance system.adapter.vis.0 terminated while should be started once
          javascript.0	2021-04-15 17:05:50.154	info	(6399) script.js.common.Heizung.Heizstab: registered 1 subscription and 1 schedule
          javascript.0	2021-04-15 17:05:50.144	info	(6399) Start javascript script.js.common.Heizung.Heizstab
          javascript.0	2021-04-15 17:05:50.143	info	(6399) script.js.common.Heizung.Auftau: registered 1 subscription and 1 schedule
          javascript.0	2021-04-15 17:05:50.107	info	(6399) Start javascript script.js.common.Heizung.Auftau
          javascript.0	2021-04-15 17:05:50.106	info	(6399) script.js.common.Buero.heizung_buero_boden: registered 1 subscription and 0 schedules
          javascript.0	2021-04-15 17:05:50.024	info	(6399) Start javascript script.js.common.Buero.heizung_buero_boden
          javascript.0	2021-04-15 17:05:49.886	info	(6399) received all states
          javascript.0	2021-04-15 17:05:49.827	info	(6399) received all objects
          vis.0	2021-04-15 17:05:49.704	info	(6713) Terminated (NO_ERROR): Without reason
          host.whome	2021-04-15 17:05:49.682	info	instance system.adapter.node-red.0 started with pid 7014
          host.whome	2021-04-15 17:05:49.653	info	instance system.adapter.web.0 started with pid 7008
          javascript.0	2021-04-15 17:05:49.056	info	(6399) requesting all objects
          javascript.0	2021-04-15 17:05:49.055	info	(6399) requesting all states
          javascript.0	2021-04-15 17:05:48.822	info	(6399) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
          vis.0	2021-04-15 17:05:48.521	info	(6713) vis license is OK.
          vis.0	2021-04-15 17:05:48.273	info	(6713) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
          host.whome	2021-04-15 17:05:46.071	info	Restart adapter system.adapter.telegram.1 because enabled
          host.whome	2021-04-15 17:05:46.069	error	instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          host.whome	2021-04-15 17:05:45.328	info	instance system.adapter.mqtt.0 started with pid 6670
          telegram.1	2021-04-15 17:05:45.109	warn	(6027) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          telegram.1	2021-04-15 17:05:45.103	error	(6027) telegram.1 already running
          host.whome	2021-04-15 17:05:43.741	info	instance system.adapter.javascript.0 started with pid 6399
          host.whome	2021-04-15 17:05:41.615	info	instance system.adapter.telegram.1 started with pid 6027
          info.0	2021-04-15 17:05:41.194	info	(5688) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
          host.whome	2021-04-15 17:05:40.493	info	Restart adapter system.adapter.telegram.0 because enabled
          host.whome	2021-04-15 17:05:40.493	error	instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          telegram.0	2021-04-15 17:05:39.912	warn	(5621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          telegram.0	2021-04-15 17:05:39.908	error	(5621) telegram.0 already running
          host.whome	2021-04-15 17:05:38.359	info	instance system.adapter.info.0 started with pid 5688
          host.whome	2021-04-15 17:05:37.684	info	instance system.adapter.telegram.0 started with pid 5621
          host.whome	2021-04-15 17:05:35.824	info	Restart adapter system.adapter.sonoff.0 because enabled
          host.whome	2021-04-15 17:05:35.824	error	instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          followthesun.0	2021-04-15 17:05:35.204	info	(5269) Daily sun parameter calculation scheduled for 00:00:23
          followthesun.0	2021-04-15 17:05:35.200	info	(5269) Sun position calculation will be done every 120 seconds
          followthesun.0	2021-04-15 17:05:35.164	info	(5269) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.followthesun, node: v12.22.1, js-controller: 3.2.16
          sonoff.0	2021-04-15 17:05:35.135	warn	(5300) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          sonoff.0	2021-04-15 17:05:35.132	error	(5300) sonoff.0 already running
          fb-checkpresence.0	2021-04-15 17:05:34.104	info	(4948) createMemberObjects finished successfully
          fb-checkpresence.0	2021-04-15 17:05:34.103	info	(4948) History function for Elke J3 disabled. Please select a history adapter in the configuration dialog!
          fb-checkpresence.0	2021-04-15 17:05:33.978	info	(4948) History function for Elke disabled. Please select a history adapter in the configuration dialog!
          fb-checkpresence.0	2021-04-15 17:05:33.877	info	(4948) History function for Uwe disabled. Please select a history adapter in the configuration dialog!
          fb-checkpresence.0	2021-04-15 17:05:33.717	info	(4948) createGlobalObjects finished successfully
          host.whome	2021-04-15 17:05:33.712	info	instance system.adapter.sonoff.0 started with pid 5300
          host.whome	2021-04-15 17:05:33.571	info	Restart adapter system.adapter.shelly.0 because enabled
          host.whome	2021-04-15 17:05:33.570	error	instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          fb-checkpresence.0	2021-04-15 17:05:33.427	info	(4948) service DeviceConfig1-Reboot is supported
          fb-checkpresence.0	2021-04-15 17:05:33.404	info	(4948) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
          fb-checkpresence.0	2021-04-15 17:05:33.387	info	(4948) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
          fb-checkpresence.0	2021-04-15 17:05:33.366	info	(4948) service DeviceInfo1-GetInfo is supported
          fb-checkpresence.0	2021-04-15 17:05:33.350	info	(4948) service WLANConfiguration3-GetInfo is supported
          host.whome	2021-04-15 17:05:33.330	info	instance system.adapter.followthesun.0 started with pid 5269
          fb-checkpresence.0	2021-04-15 17:05:33.330	info	(4948) service WLANConfiguration3-SetEnable is supported
          fb-checkpresence.0	2021-04-15 17:05:33.308	info	(4948) service WANPPPConnection1-GetInfo is supported
          fb-checkpresence.0	2021-04-15 17:05:33.288	info	(4948) service DeviceInfo1-GetSecurityPort is supported
          fb-checkpresence.0	2021-04-15 17:05:33.272	info	(4948) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
          fb-checkpresence.0	2021-04-15 17:05:33.256	info	(4948) service Hosts1-GetSpecificHostEntry is supported
          fb-checkpresence.0	2021-04-15 17:05:33.235	info	(4948) service Hosts1-X_AVM-DE_GetMeshListPath is supported
          fb-checkpresence.0	2021-04-15 17:05:33.211	info	(4948) service Hosts1-X_AVM-DE_GetHostListPath is supported
          fb-checkpresence.0	2021-04-15 17:05:33.030	info	(4948) start fb-checkpresence: ip-address: "192.168.1.10" - interval devices: 1 Min. - interval members: 60 s
          fb-checkpresence.0	2021-04-15 17:05:32.989	info	(4948) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
          shelly.0	2021-04-15 17:05:32.944	warn	(4966) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          shelly.0	2021-04-15 17:05:32.940	error	(4966) shelly.0 already running
          host.whome	2021-04-15 17:05:31.141	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          cloud.0	2021-04-15 17:05:30.139	info	(4326) Connection changed: io server disconnect
          host.whome	2021-04-15 17:05:29.630	info	instance system.adapter.shelly.0 started with pid 4966
          host.whome	2021-04-15 17:05:29.520	info	instance system.adapter.fb-checkpresence.0 started with pid 4948
          cloud.0	2021-04-15 17:05:29.129	error	(4326) Cloud says: timeout
          host.whome	2021-04-15 17:05:27.436	info	Restart adapter system.adapter.sayit.0 because enabled
          host.whome	2021-04-15 17:05:27.435	error	instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          discovery.0	2021-04-15 17:05:27.205	info	(4621) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
          sayit.0	2021-04-15 17:05:26.859	warn	(4640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          sayit.0	2021-04-15 17:05:26.855	error	(4640) sayit.0 already running
          host.whome	2021-04-15 17:05:25.608	info	instance system.adapter.sayit.0 started with pid 4640
          host.whome	2021-04-15 17:05:25.435	info	instance system.adapter.discovery.0 started with pid 4621
          cloud.0	2021-04-15 17:05:24.164	info	(4326) Trying to connect as system.user.admin
          cloud.0	2021-04-15 17:05:23.803	info	(4326) Connecting with https://iobroker.net:10555 with "uwaizmann@gmail.com_c9f2a840-75ac-11eb-a278-59b6a78c6ee1"
          cloud.0	2021-04-15 17:05:23.721	info	(4326) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.1, js-controller: 3.2.16
          host.whome	2021-04-15 17:05:23.326	info	Restart adapter system.adapter.ping.0 because enabled
          host.whome	2021-04-15 17:05:23.325	error	instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          ping.0	2021-04-15 17:05:22.727	warn	(4301) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          ping.0	2021-04-15 17:05:22.724	error	(4301) ping.0 already running
          host.whome	2021-04-15 17:05:21.744	info	instance system.adapter.cloud.0 started with pid 4326
          host.whome	2021-04-15 17:05:21.559	info	instance system.adapter.ping.0 started with pid 4301
          backitup.0	2021-04-15 17:05:20.953	info	(3906) [iobroker] backup was activated at 03:00 every 1 day(s)
          backitup.0	2021-04-15 17:05:20.875	info	(3906) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
          chromecast.0	2021-04-15 17:05:19.911	info	(3979) Wohnzimmer - Connected client
          host.whome	2021-04-15 17:05:19.615	info	Restart adapter system.adapter.node-red.0 because enabled
          host.whome	2021-04-15 17:05:19.614	error	instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          chromecast.0	2021-04-15 17:05:19.162	info	(3979) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v12.22.1, js-controller: 3.2.16
          node-red.0	2021-04-15 17:05:19.016	warn	(3973) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          node-red.0	2021-04-15 17:05:19.013	error	(3973) node-red.0 already running
          host.whome	2021-04-15 17:05:17.597	info	instance system.adapter.chromecast.0 started with pid 3979
          host.whome	2021-04-15 17:05:17.567	info	instance system.adapter.node-red.0 started with pid 3973
          host.whome	2021-04-15 17:05:16.890	info	instance system.adapter.backitup.0 started with pid 3906
          host.whome	2021-04-15 17:05:15.296	info	Restart adapter system.adapter.mqtt.0 because enabled
          host.whome	2021-04-15 17:05:15.295	error	instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          mqtt.0	2021-04-15 17:05:14.720	error	(3643) mqtt.0 already running
          admin.0	2021-04-15 17:05:13.485	info	(3348) Use link "http://localhost:8081" to configure.
          host.whome	2021-04-15 17:05:13.654	info	Restart adapter system.adapter.javascript.0 because enabled
          host.whome	2021-04-15 17:05:13.653	error	instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          host.whome	2021-04-15 17:05:13.558	info	instance system.adapter.mqtt.0 started with pid 3643
          admin.0	2021-04-15 17:05:13.484	info	(3348) http server listening on port 8081
          admin.0	2021-04-15 17:05:13.117	info	(3348) received all objects
          javascript.0	2021-04-15 17:05:13.013	warn	(3305) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          javascript.0	2021-04-15 17:05:13.009	error	(3305) javascript.0 already running
          admin.0	2021-04-15 17:05:12.201	info	(3348) requesting all objects
          admin.0	2021-04-15 17:05:12.200	info	(3348) requesting all states
          admin.0	2021-04-15 17:05:12.121	info	(3348) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
          host.whome	2021-04-15 17:05:10.010	info	instance system.adapter.admin.0 started with pid 3348
          host.whome	2021-04-15 17:05:09.596	info	instance system.adapter.javascript.0 started with pid 3305
          host.whome	2021-04-15 17:05:08.329	info	Restart adapter system.adapter.info.0 because enabled
          host.whome	2021-04-15 17:05:08.328	error	instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          info.0	2021-04-15 17:05:07.754	warn	(2970) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          info.0	2021-04-15 17:05:07.751	error	(2970) info.0 already running
          host.whome	2021-04-15 17:05:05.582	info	instance system.adapter.info.0 started with pid 2970
          host.whome	2021-04-15 17:05:03.303	info	Restart adapter system.adapter.followthesun.0 because enabled
          host.whome	2021-04-15 17:05:03.302	error	instance system.adapter.followthesun.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          followthesun.0	2021-04-15 17:05:02.727	warn	(2671) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          followthesun.0	2021-04-15 17:05:02.724	error	(2671) followthesun.0 already running
          host.whome	2021-04-15 17:05:01.580	info	instance system.adapter.followthesun.0 started with pid 2671
          host.whome	2021-04-15 16:17:35.684	info	Restart adapter system.adapter.fb-checkpresence.0 because enabled
          host.whome	2021-04-15 16:17:35.683	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          fb-checkpresence.0	2021-04-15 16:17:35.108	warn	(2286) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          fb-checkpresence.0	2021-04-15 16:17:35.106	error	(2286) fb-checkpresence.0 already running
          host.whome	2021-04-15 16:17:33.769	info	instance system.adapter.fb-checkpresence.0 started with pid 2286
          host.whome	2021-04-15 16:17:31.615	info	Restart adapter system.adapter.discovery.0 because enabled
          host.whome	2021-04-15 16:17:31.614	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          discovery.0	2021-04-15 16:17:30.984	warn	(1939) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          discovery.0	2021-04-15 16:17:30.980	error	(1939) discovery.0 already running
          host.whome	2021-04-15 16:17:29.738	info	instance system.adapter.discovery.0 started with pid 1939
          host.whome	2021-04-15 16:17:27.923	info	Restart adapter system.adapter.cloud.0 because enabled
          host.whome	2021-04-15 16:17:27.922	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          cloud.0	2021-04-15 16:17:27.307	warn	(1640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          cloud.0	2021-04-15 16:17:27.304	error	(1640) cloud.0 already running
          host.whome	2021-04-15 16:17:25.765	info	instance system.adapter.cloud.0 started with pid 1640
          host.whome	2021-04-15 16:17:23.774	info	Restart adapter system.adapter.chromecast.0 because enabled
          host.whome	2021-04-15 16:17:23.773	error	instance system.adapter.chromecast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          host.whome	2021-04-15 16:17:23.772	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
          host.whome	2021-04-15 16:17:23.772	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
          host.whome	2021-04-15 16:17:23.771	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:168:15)
          host.whome	2021-04-15 16:17:23.771	error	Caught by controller[0]: at process.emit (events.js:314:20)
          host.whome	2021-04-15 16:17:23.771	error	Caught by controller[0]: at Object.onceWrapper (events.js:421:26)
          host.whome	2021-04-15 16:17:23.770	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
          host.whome	2021-04-15 16:17:23.770	error	Caught by controller[0]: at Adapter.emit (events.js:314:20)
          host.whome	2021-04-15 16:17:23.769	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
          host.whome	2021-04-15 16:17:23.769	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
          chromecast.0	2021-04-15 16:17:23.181	warn	(1322) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          chromecast.0	2021-04-15 16:17:23.178	error	(1322) chromecast.0 already running
          host.whome	2021-04-15 16:17:23.058	info	Restart adapter system.adapter.backitup.0 because enabled
          host.whome	2021-04-15 16:17:23.057	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          backitup.0	2021-04-15 16:17:22.451	warn	(1016) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          backitup.0	2021-04-15 16:17:22.448	error	(1016) backitup.0 already running
          host.whome	2021-04-15 16:17:21.708	info	instance system.adapter.chromecast.0 started with pid 1322
          host.whome	2021-04-15 16:17:17.698	info	instance system.adapter.backitup.0 started with pid 1016
          host.whome	2021-04-15 16:17:16.191	info	Restart adapter system.adapter.admin.0 because enabled
          host.whome	2021-04-15 16:17:16.190	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
          admin.0	2021-04-15 16:17:15.582	warn	(788) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
          admin.0	2021-04-15 16:17:15.578	error	(788) admin.0 already running
          host.whome	2021-04-15 16:17:13.783	info	instance system.adapter.admin.0 started with pid 788
          host.whome	2021-04-15 16:17:13.677	info	starting 19 instances
          host.whome	2021-04-15 16:17:13.618	info	25 instances found
          host.whome	2021-04-15 16:17:12.873	info	added notifications configuration of host
          host.whome	2021-04-15 16:17:12.807	info	connected to Objects and States
          host.whome-Server	2021-04-15 16:17:12.651	error	Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
          host.whome	2021-04-15 16:17:12.010	info	ip addresses: fe80::d8:6431:90b3:eeab
          host.whome	2021-04-15 16:17:12.010	info	hostname: whome, node: v12.22.1
          Hier noch dmesg -T nach dem Neustart
          pi@whome:~ $ dmesg -T
          [Do Apr 15 17:04:17 2021] Booting Linux on physical CPU 0x0
          [Do Apr 15 17:04:17 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
          [Do Apr 15 17:04:17 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
          [Do Apr 15 17:04:17 2021] CPU: div instructions available: patching division code
          [Do Apr 15 17:04:17 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
          [Do Apr 15 17:04:17 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.4
          [Do Apr 15 17:04:17 2021] Memory policy: Data cache writealloc
          [Do Apr 15 17:04:17 2021] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
          [Do Apr 15 17:04:17 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
          [Do Apr 15 17:04:17 2021] Zone ranges:
          [Do Apr 15 17:04:17 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
          [Do Apr 15 17:04:17 2021]   Normal   empty
          [Do Apr 15 17:04:17 2021]   HighMem  [mem 0x0000000030000000-0x00000001ffffffff]
          [Do Apr 15 17:04:17 2021] Movable zone start for each node
          [Do Apr 15 17:04:17 2021] Early memory node ranges
          [Do Apr 15 17:04:17 2021]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
          [Do Apr 15 17:04:17 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
          [Do Apr 15 17:04:17 2021]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
          [Do Apr 15 17:04:17 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
          [Do Apr 15 17:04:17 2021] On node 0 totalpages: 2061056
          [Do Apr 15 17:04:17 2021]   DMA zone: 2304 pages used for memmap
          [Do Apr 15 17:04:17 2021]   DMA zone: 0 pages reserved
          [Do Apr 15 17:04:17 2021]   DMA zone: 196608 pages, LIFO batch:63
          [Do Apr 15 17:04:17 2021]   HighMem zone: 1864448 pages, LIFO batch:63
          [Do Apr 15 17:04:17 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
          [Do Apr 15 17:04:17 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
          [Do Apr 15 17:04:17 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Do Apr 15 17:04:17 2021] Built 1 zonelists, mobility grouping on.  Total pages: 2058752
          [Do Apr 15 17:04:17 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:EE:BA:65 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=ac5233f7-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Do Apr 15 17:04:17 2021] Kernel parameter elevator= does not have any effect anymore.
                                    Please use sysfs to set IO scheduler for individual devices.
          [Do Apr 15 17:04:17 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
          [Do Apr 15 17:04:17 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [Do Apr 15 17:04:17 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
          [Do Apr 15 17:04:17 2021] software IO TLB: mapped [mem 0x0000000014c00000-0x0000000018c00000] (64MB)
          [Do Apr 15 17:04:17 2021] Memory: 7799064K/8244224K available (10240K kernel code, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 183016K reserved, 262144K cma-reserved, 7457792K highmem)
          [Do Apr 15 17:04:17 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [Do Apr 15 17:04:17 2021] ftrace: allocating 33942 entries in 67 pages
          [Do Apr 15 17:04:17 2021] ftrace: allocated 67 pages with 3 groups
          [Do Apr 15 17:04:17 2021] rcu: Hierarchical RCU implementation.
          [Do Apr 15 17:04:17 2021]       Rude variant of Tasks RCU enabled.
          [Do Apr 15 17:04:17 2021]       Tracing variant of Tasks RCU enabled.
          [Do Apr 15 17:04:17 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
          [Do Apr 15 17:04:17 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
          [Do Apr 15 17:04:17 2021] GIC: Using split EOI/Deactivate mode
          [Do Apr 15 17:04:17 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=0
          [Do Apr 15 17:04:17 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
          [Do Apr 15 17:04:17 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
          [Do Apr 15 17:04:17 2021] bcm2835: system timer (irq = 25)
          [Do Apr 15 17:04:17 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
          [Do Apr 15 17:04:17 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [Do Apr 15 17:04:17 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
          [Do Apr 15 17:04:17 2021] Switching to timer-based delay loop, resolution 18ns
          [Do Apr 15 17:04:17 2021] Console: colour dummy device 80x30
          [Do Apr 15 17:04:17 2021] printk: console [tty1] enabled
          [Do Apr 15 17:04:17 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
          [Do Apr 15 17:04:17 2021] pid_max: default: 32768 minimum: 301
          [Do Apr 15 17:04:17 2021] LSM: Security Framework initializing
          [Do Apr 15 17:04:17 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Do Apr 15 17:04:17 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Do Apr 15 17:04:17 2021] Disabling memory control group subsystem
          [Do Apr 15 17:04:17 2021] CPU: Testing write buffer coherency: ok
          [Do Apr 15 17:04:17 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [Do Apr 15 17:04:17 2021] Setting up static identity map for 0x200000 - 0x20003c
          [Do Apr 15 17:04:17 2021] rcu: Hierarchical SRCU implementation.
          [Do Apr 15 17:04:17 2021] smp: Bringing up secondary CPUs ...
          [Do Apr 15 17:04:17 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [Do Apr 15 17:04:17 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
          [Do Apr 15 17:04:17 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
          [Do Apr 15 17:04:17 2021] smp: Brought up 1 node, 4 CPUs
          [Do Apr 15 17:04:17 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
          [Do Apr 15 17:04:17 2021] CPU: All CPU(s) started in HYP mode.
          [Do Apr 15 17:04:17 2021] CPU: Virtualization extensions available.
          [Do Apr 15 17:04:17 2021] devtmpfs: initialized
          [Do Apr 15 17:04:17 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
          [Do Apr 15 17:04:17 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [Do Apr 15 17:04:17 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [Do Apr 15 17:04:17 2021] pinctrl core: initialized pinctrl subsystem
          [Do Apr 15 17:04:17 2021] NET: Registered protocol family 16
          [Do Apr 15 17:04:17 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
          [Do Apr 15 17:04:17 2021] audit: initializing netlink subsys (disabled)
          [Do Apr 15 17:04:17 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
          [Do Apr 15 17:04:17 2021] thermal_sys: Registered thermal governor 'step_wise'
          [Do Apr 15 17:04:17 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
          [Do Apr 15 17:04:17 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
          [Do Apr 15 17:04:17 2021] Serial: AMBA PL011 UART driver
          [Do Apr 15 17:04:17 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [Do Apr 15 17:04:17 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:10:40, variant start
          [Do Apr 15 17:04:17 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
          [Do Apr 15 17:04:17 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
          [Do Apr 15 17:04:17 2021] vgaarb: loaded
          [Do Apr 15 17:04:17 2021] SCSI subsystem initialized
          [Do Apr 15 17:04:17 2021] usbcore: registered new interface driver usbfs
          [Do Apr 15 17:04:17 2021] usbcore: registered new interface driver hub
          [Do Apr 15 17:04:17 2021] usbcore: registered new device driver usb
          [Do Apr 15 17:04:17 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
          [Do Apr 15 17:04:17 2021] clocksource: Switched to clocksource arch_sys_counter
          [Do Apr 15 17:04:18 2021] VFS: Disk quotas dquot_6.6.0
          [Do Apr 15 17:04:18 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
          [Do Apr 15 17:04:18 2021] FS-Cache: Loaded
          [Do Apr 15 17:04:18 2021] CacheFiles: Loaded
          [Do Apr 15 17:04:18 2021] simple-framebuffer 3e2fe000.framebuffer: framebuffer at 0x3e2fe000, 0x7f8000 bytes, mapped to 0x(ptrval)
          [Do Apr 15 17:04:18 2021] simple-framebuffer 3e2fe000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
          [Do Apr 15 17:04:18 2021] Console: switching to colour frame buffer device 240x67
          [Do Apr 15 17:04:18 2021] simple-framebuffer 3e2fe000.framebuffer: fb0: simplefb registered!
          [Do Apr 15 17:04:18 2021] NET: Registered protocol family 2
          [Do Apr 15 17:04:18 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
          [Do Apr 15 17:04:18 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
          [Do Apr 15 17:04:18 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Do Apr 15 17:04:18 2021] TCP: Hash tables configured (established 8192 bind 8192)
          [Do Apr 15 17:04:18 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Do Apr 15 17:04:18 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Do Apr 15 17:04:18 2021] RPC: Registered named UNIX socket transport module.
          [Do Apr 15 17:04:18 2021] RPC: Registered udp transport module.
          [Do Apr 15 17:04:18 2021] RPC: Registered tcp transport module.
          [Do Apr 15 17:04:18 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Do Apr 15 17:04:18 2021] PCI: CLS 0 bytes, default 64
          [Do Apr 15 17:04:18 2021] Initialise system trusted keyrings
          [Do Apr 15 17:04:18 2021] workingset: timestamp_bits=14 max_order=21 bucket_order=7
          [Do Apr 15 17:04:18 2021] zbud: loaded
          [Do Apr 15 17:04:18 2021] FS-Cache: Netfs 'nfs' registered for caching
          [Do Apr 15 17:04:18 2021] NFS: Registering the id_resolver key type
          [Do Apr 15 17:04:18 2021] Key type id_resolver registered
          [Do Apr 15 17:04:18 2021] Key type id_legacy registered
          [Do Apr 15 17:04:18 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Do Apr 15 17:04:18 2021] Key type asymmetric registered
          [Do Apr 15 17:04:18 2021] Asymmetric key parser 'x509' registered
          [Do Apr 15 17:04:18 2021] bounce: pool size: 64 pages
          [Do Apr 15 17:04:18 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
          [Do Apr 15 17:04:18 2021] io scheduler mq-deadline registered
          [Do Apr 15 17:04:18 2021] io scheduler kyber registered
          [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
          [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
          [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
          [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [Do Apr 15 17:04:18 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [Do Apr 15 17:04:18 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
          [Do Apr 15 17:04:18 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
          [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
          [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
          [Do Apr 15 17:04:18 2021] PCI: bus0: Fast back to back transfers disabled
          [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
          [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
          [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: PME# supported from D0 D3hot
          [Do Apr 15 17:04:18 2021] PCI: bus1: Fast back to back transfers disabled
          [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
          [Do Apr 15 17:04:18 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
          [Do Apr 15 17:04:18 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
          [Do Apr 15 17:04:18 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
          [Do Apr 15 17:04:18 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
          [Do Apr 15 17:04:18 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
          [Do Apr 15 17:04:18 2021] iproc-rng200 fe104000.rng: hwrng registered
          [Do Apr 15 17:04:18 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
          [Do Apr 15 17:04:18 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
          [Do Apr 15 17:04:18 2021] brd: module loaded
          [Do Apr 15 17:04:18 2021] loop: module loaded
          [Do Apr 15 17:04:18 2021] Loading iSCSI transport class v2.0-870.
          [Do Apr 15 17:04:18 2021] libphy: Fixed MDIO Bus: probed
          [Do Apr 15 17:04:18 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [Do Apr 15 17:04:18 2021] libphy: bcmgenet MII bus: probed
          [Do Apr 15 17:04:18 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver r8152
          [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver lan78xx
          [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver smsc95xx
          [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000030000000890
          [Do Apr 15 17:04:18 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
          [Do Apr 15 17:04:18 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Do Apr 15 17:04:18 2021] usb usb1: Product: xHCI Host Controller
          [Do Apr 15 17:04:18 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
          [Do Apr 15 17:04:18 2021] usb usb1: SerialNumber: 0000:01:00.0
          [Do Apr 15 17:04:18 2021] hub 1-0:1.0: USB hub found
          [Do Apr 15 17:04:18 2021] hub 1-0:1.0: 1 port detected
          [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [Do Apr 15 17:04:18 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [Do Apr 15 17:04:18 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
          [Do Apr 15 17:04:18 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Do Apr 15 17:04:18 2021] usb usb2: Product: xHCI Host Controller
          [Do Apr 15 17:04:18 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
          [Do Apr 15 17:04:18 2021] usb usb2: SerialNumber: 0000:01:00.0
          [Do Apr 15 17:04:18 2021] hub 2-0:1.0: USB hub found
          [Do Apr 15 17:04:18 2021] hub 2-0:1.0: 4 ports detected
          [Do Apr 15 17:04:18 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Do Apr 15 17:04:18 2021] dwc_otg: FIQ enabled
          [Do Apr 15 17:04:18 2021] dwc_otg: NAK holdoff enabled
          [Do Apr 15 17:04:18 2021] dwc_otg: FIQ split-transaction FSM enabled
          [Do Apr 15 17:04:18 2021] Module dwc_common_port init
          [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver uas
          [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver usb-storage
          [Do Apr 15 17:04:18 2021] mousedev: PS/2 mouse device common for all mice
          [Do Apr 15 17:04:18 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Do Apr 15 17:04:18 2021] sdhci: Secure Digital Host Controller Interface driver
          [Do Apr 15 17:04:18 2021] sdhci: Copyright(c) Pierre Ossman
          [Do Apr 15 17:04:18 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
          [Do Apr 15 17:04:18 2021] sdhci-pltfm: SDHCI platform and OF driver helper
          [Do Apr 15 17:04:18 2021] ledtrig-cpu: registered to indicate activity on CPUs
          [Do Apr 15 17:04:18 2021] hid: raw HID events driver (C) Jiri Kosina
          [Do Apr 15 17:04:18 2021] usbcore: registered new interface driver usbhid
          [Do Apr 15 17:04:18 2021] usbhid: USB HID core driver
          [Do Apr 15 17:04:18 2021] Initializing XFRM netlink socket
          [Do Apr 15 17:04:18 2021] NET: Registered protocol family 17
          [Do Apr 15 17:04:18 2021] Key type dns_resolver registered
          [Do Apr 15 17:04:18 2021] Registering SWP/SWPB emulation handler
          [Do Apr 15 17:04:18 2021] registered taskstats version 1
          [Do Apr 15 17:04:18 2021] Loading compiled-in X.509 certificates
          [Do Apr 15 17:04:18 2021] Key type ._fscrypt registered
          [Do Apr 15 17:04:18 2021] Key type .fscrypt registered
          [Do Apr 15 17:04:18 2021] Key type fscrypt-provisioning registered
          [Do Apr 15 17:04:18 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
          [Do Apr 15 17:04:18 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [Do Apr 15 17:04:18 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
          [Do Apr 15 17:04:18 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Do Apr 15 17:04:18 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Do Apr 15 17:04:18 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [Do Apr 15 17:04:18 2021] of_cfs_init
          [Do Apr 15 17:04:18 2021] of_cfs_init: OK
          [Do Apr 15 17:04:18 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
          [Do Apr 15 17:04:18 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [Do Apr 15 17:04:18 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
          [Do Apr 15 17:04:18 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
          [Do Apr 15 17:04:18 2021] Waiting for root device PARTUUID=ac5233f7-02...
          [Do Apr 15 17:04:18 2021] random: fast init done
          [Do Apr 15 17:04:18 2021] mmc1: new high speed SDIO card at address 0001
          [Do Apr 15 17:04:18 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [Do Apr 15 17:04:19 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [Do Apr 15 17:04:19 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Do Apr 15 17:04:19 2021] usb 1-1: Product: USB2.0 Hub
          [Do Apr 15 17:04:19 2021] hub 1-1:1.0: USB hub found
          [Do Apr 15 17:04:19 2021] hub 1-1:1.0: 4 ports detected
          [Do Apr 15 17:04:19 2021] usb 1-1.1: new high-speed USB device number 3 using xhci_hcd
          [Do Apr 15 17:04:19 2021] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
          [Do Apr 15 17:04:19 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Do Apr 15 17:04:19 2021] usb 1-1.1: Product: USB2.0 Hub
          [Do Apr 15 17:04:19 2021] hub 1-1.1:1.0: USB hub found
          [Do Apr 15 17:04:19 2021] hub 1-1.1:1.0: 4 ports detected
          [Do Apr 15 17:04:19 2021] usb 1-1.1.3: new high-speed USB device number 4 using xhci_hcd
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice= 9.01
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3: Product: USB2.0 Hub
          [Do Apr 15 17:04:20 2021] hub 1-1.1.3:1.0: USB hub found
          [Do Apr 15 17:04:20 2021] hub 1-1.1.3:1.0: 4 ports detected
          [Do Apr 15 17:04:20 2021] usb 1-1.1.4: new high-speed USB device number 5 using xhci_hcd
          [Do Apr 15 17:04:20 2021] usb 1-1.1.4: New USB device found, idVendor=2109, idProduct=0711, bcdDevice=12.00
          [Do Apr 15 17:04:20 2021] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [Do Apr 15 17:04:20 2021] usb 1-1.1.4: Product: VLI Product String
          [Do Apr 15 17:04:20 2021] usb 1-1.1.4: Manufacturer: VLI manufacture String
          [Do Apr 15 17:04:20 2021] usb 1-1.1.4: SerialNumber: 000000123AD6
          [Do Apr 15 17:04:20 2021] usb-storage 1-1.1.4:1.0: USB Mass Storage device detected
          [Do Apr 15 17:04:20 2021] usb-storage 1-1.1.4:1.0: Quirks match for vid 2109 pid 0711: 2000000
          [Do Apr 15 17:04:20 2021] scsi host0: usb-storage 1-1.1.4:1.0
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: new low-speed USB device number 6 using xhci_hcd
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: New USB device found, idVendor=1c4f, idProduct=0026, bcdDevice= 1.10
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: Product: USB Keyboard
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.3: Manufacturer: SIGMACHIP
          [Do Apr 15 17:04:20 2021] input: SIGMACHIP USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/0003:1C4F:0026.0001/input/input0
          [Do Apr 15 17:04:20 2021] hid-generic 0003:1C4F:0026.0001: input,hidraw0: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:01:00.0-1.1.3.3/input0
          [Do Apr 15 17:04:20 2021] input: SIGMACHIP USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:1C4F:0026.0002/input/input1
          [Do Apr 15 17:04:20 2021] input: SIGMACHIP USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:1C4F:0026.0002/input/input2
          [Do Apr 15 17:04:20 2021] hid-generic 0003:1C4F:0026.0002: input,hidraw1: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:01:00.0-1.1.3.3/input1
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: new full-speed USB device number 7 using xhci_hcd
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.00
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: Product: USB Receiver
          [Do Apr 15 17:04:20 2021] usb 1-1.1.3.4: Manufacturer: Logitech
          [Do Apr 15 17:04:20 2021] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.0/0003:046D:C52B.0003/input/input3
          [Do Apr 15 17:04:21 2021] hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input0
          [Do Apr 15 17:04:21 2021] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input4
          [Do Apr 15 17:04:21 2021] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input5
          [Do Apr 15 17:04:21 2021] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.1/0003:046D:C52B.0004/input/input6
          [Do Apr 15 17:04:21 2021] hid-generic 0003:046D:C52B.0004: input,hiddev96,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input1
          [Do Apr 15 17:04:21 2021] hid-generic 0003:046D:C52B.0005: hiddev97,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
          [Do Apr 15 17:04:21 2021] scsi 0:0:0:0: Direct-Access     INTEL SS DSA2CW080G3      4PC1 PQ: 0 ANSI: 6
          [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] 156301484 512-byte logical blocks: (80.0 GB/74.5 GiB)
          [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Write Protect is off
          [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Mode Sense: 1f 00 00 00
          [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
          [Do Apr 15 17:04:21 2021]  sda: sda1 sda2
          [Do Apr 15 17:04:21 2021] sd 0:0:0:0: [sda] Attached SCSI disk
          [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
          [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): write access will be enabled during recovery
          [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): orphan cleanup on readonly fs
          [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): 6 orphan inodes deleted
          [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): recovery complete
          [Do Apr 15 17:04:21 2021] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
          [Do Apr 15 17:04:21 2021] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Do Apr 15 17:04:21 2021] devtmpfs: mounted
          [Do Apr 15 17:04:21 2021] Freeing unused kernel memory: 2048K
          [Do Apr 15 17:04:21 2021] Run /sbin/init as init process
          [Do Apr 15 17:04:21 2021]   with arguments:
          [Do Apr 15 17:04:21 2021]     /sbin/init
          [Do Apr 15 17:04:21 2021]   with environment:
          [Do Apr 15 17:04:21 2021]     HOME=/
          [Do Apr 15 17:04:21 2021]     TERM=linux
          [Do Apr 15 17:04:22 2021] systemd[1]: System time before build time, advancing clock.
          [Do Apr 15 17:04:22 2021] NET: Registered protocol family 10
          [Do Apr 15 17:04:22 2021] Segment Routing with IPv6
          [Do Apr 15 17:04:22 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
          [Do Apr 15 17:04:22 2021] systemd[1]: Detected architecture arm.
          [Do Apr 15 17:04:22 2021] systemd[1]: Set hostname to <whome>.
          [Do Apr 15 17:04:23 2021] random: systemd: uninitialized urandom read (16 bytes read)
          [Do Apr 15 17:04:23 2021] systemd[1]: Listening on Journal Audit Socket.
          [Do Apr 15 17:04:23 2021] systemd[1]: Listening on Syslog Socket.
          [Do Apr 15 17:04:23 2021] systemd[1]: Listening on Journal Socket.
          [Do Apr 15 17:04:23 2021] systemd[1]: Starting Create list of required static device nodes for the current kernel...
          [Do Apr 15 17:04:23 2021] systemd[1]: Starting Restore / save the current clock...
          [Do Apr 15 17:04:23 2021] systemd[1]: Mounting RPC Pipe File System...
          [Do Apr 15 17:04:23 2021] systemd[1]: Starting Load Kernel Modules...
          [Do Apr 15 17:04:23 2021] i2c /dev entries driver
          [Do Apr 15 17:04:24 2021] EXT4-fs (sda2): re-mounted. Opts: (null)
          [Do Apr 15 17:04:24 2021] systemd-journald[119]: Received request to flush runtime journal from PID 1
          [Do Apr 15 17:04:25 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
          [Do Apr 15 17:04:25 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
          [Do Apr 15 17:04:25 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
          [Do Apr 15 17:04:25 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
          [Do Apr 15 17:04:25 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Do Apr 15 17:04:25 2021] mc: Linux media interface: v0.10
          [Do Apr 15 17:04:25 2021] bcm2835_audio bcm2835_audio: card created with 4 channels
          [Do Apr 15 17:04:25 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Do Apr 15 17:04:25 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Do Apr 15 17:04:25 2021] [vc_sm_connected_init]: start
          [Do Apr 15 17:04:25 2021] [vc_sm_connected_init]: installed successfully
          [Do Apr 15 17:04:25 2021] videodev: Linux video capture interface: v2.00
          [Do Apr 15 17:04:25 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Do Apr 15 17:04:25 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Do Apr 15 17:04:25 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
          [Do Apr 15 17:04:25 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
          [Do Apr 15 17:04:25 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [Do Apr 15 17:04:25 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
          [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [Do Apr 15 17:04:25 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
          [Do Apr 15 17:04:25 2021] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
          [Do Apr 15 17:04:25 2021] fb0: switching to vc4drmfb from simple
          [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [Do Apr 15 17:04:25 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [Do Apr 15 17:04:25 2021] Console: switching to colour dummy device 80x30
          [Do Apr 15 17:04:25 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
          [Do Apr 15 17:04:25 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Do Apr 15 17:04:26 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Do Apr 15 17:04:26 2021] sd 0:0:0:0: Attached scsi generic sg0 type 0
          [Do Apr 15 17:04:26 2021] Console: switching to colour frame buffer device 240x67
          [Do Apr 15 17:04:26 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
          [Do Apr 15 17:04:26 2021] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
          [Do Apr 15 17:04:26 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Do Apr 15 17:04:26 2021] usbcore: registered new interface driver brcmfmac
          [Do Apr 15 17:04:26 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
          [Do Apr 15 17:04:26 2021] random: crng init done
          [Do Apr 15 17:04:26 2021] random: 7 urandom warning(s) missed due to ratelimiting
          [Do Apr 15 17:04:26 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
          [Do Apr 15 17:04:26 2021] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
          [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:400a Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input8
          [Do Apr 15 17:04:26 2021] hid-generic 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
          [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:4003 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input12
          [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:4003 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input13
          [Do Apr 15 17:04:26 2021] input: Logitech Wireless Device PID:4003 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input14
          [Do Apr 15 17:04:26 2021] hid-generic 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4003] on usb-0000:01:00.0-1.1.3.4/input2:2
          [Do Apr 15 17:04:27 2021] input: Logitech Wireless Device PID:400a as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input18
          [Do Apr 15 17:04:27 2021] logitech-hidpp-device 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
          [Do Apr 15 17:04:27 2021] input: Logitech K270 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input19
          [Do Apr 15 17:04:27 2021] logitech-hidpp-device 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K270] on usb-0000:01:00.0-1.1.3.4/input2:2
          [Do Apr 15 17:04:28 2021] uart-pl011 fe201000.serial: no DMA platform data
          [Do Apr 15 17:04:29 2021] 8021q: 802.1Q VLAN Support v1.8
          [Do Apr 15 17:04:29 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
          [Do Apr 15 17:04:30 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
          [Do Apr 15 17:04:30 2021] bcmgenet fd580000.ethernet eth0: Link is Down
          [Do Apr 15 17:04:33 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
          [Do Apr 15 17:04:33 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [Do Apr 15 17:04:35 2021] Bluetooth: Core ver 2.22
          [Do Apr 15 17:04:35 2021] NET: Registered protocol family 31
          [Do Apr 15 17:04:35 2021] Bluetooth: HCI device and connection manager initialized
          [Do Apr 15 17:04:35 2021] Bluetooth: HCI socket layer initialized
          [Do Apr 15 17:04:35 2021] Bluetooth: L2CAP socket layer initialized
          [Do Apr 15 17:04:35 2021] Bluetooth: SCO socket layer initialized
          [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART driver ver 2.3
          [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART protocol H4 registered
          [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Do Apr 15 17:04:35 2021] Bluetooth: HCI UART protocol Broadcom registered
          [Do Apr 15 17:04:36 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Do Apr 15 17:04:36 2021] Bluetooth: BNEP filters: protocol multicast
          [Do Apr 15 17:04:36 2021] Bluetooth: BNEP socket layer initialized
          pi@whome:~ $
          @uwe-waizmann Geht das Log noch ein wenig weiter zurück?
          Uwe WaizmannU 2 Antworten Letzte Antwort
            Uwe WaizmannU Offline
            Uwe Waizmann
            leider nein
            Uwe WaizmannU 1 Antwort Letzte Antwort
            • Uwe WaizmannU Uwe Waizmann
              leider nein
              Uwe Waizmann
                Uwe Waizmann
                gefunden /opt/iobroker/log
                2021-04-15 00:00:28.074  - info: followthesun.0 (26948) Cronjob 'Sun parameter calculation' starts
                2021-04-15 00:05:38.015  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 00:05:38.050  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 00:46:49.140  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 00:46:49.143  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 00:55:48.747  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 00:55:48.748  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 00:56:18.774  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 00:56:18.776  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 01:06:58.958  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 01:06:58.960  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 01:07:28.979  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 01:07:28.983  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 01:37:09.452  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 01:37:09.457  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 01:37:40.471  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 01:37:40.472  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 01:47:09.629  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 01:47:09.631  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 01:47:51.708  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 01:47:51.709  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 02:18:10.222  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 02:18:10.223  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 02:18:50.224  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 02:18:50.225  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 02:38:00.591  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 02:38:00.592  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 02:38:30.612  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 02:38:30.613  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 02:52:10.866  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 02:52:10.867  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 02:52:40.860  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 02:52:40.861  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:00:29.309  - warn: telegram.0 (12415) 1 of 1 recipients are unknown!
                2021-04-15 03:02:20.995  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:02:20.996  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:02:51.526  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:02:51.528  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:12:41.127  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:12:41.128  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:13:11.135  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:13:11.136  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:23:51.203  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:23:51.204  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:24:22.260  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:24:22.262  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:37:11.361  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:37:11.362  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:37:41.360  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:37:41.365  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 03:52:13.670  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: Device timeout
                    at fn.ontimeout (/opt/iobroker/node_modules/castv2-client/lib/senders/platform.js:56:26)
                    at Object.onceWrapper (events.js:420:28)
                    at fn.emit (events.js:314:20)
                    at Timeout.ontimeout [as _onTimeout] (/opt/iobroker/node_modules/castv2-client/lib/controllers/heartbeat.js:44:10)
                    at listOnTimeout (internal/timers.js:554:17)
                    at processTimers (internal/timers.js:497:7)
                2021-04-15 03:52:13.689  - info: chromecast.0 (12982) Wohnzimmer - client disconnected
                2021-04-15 03:52:16.808  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                    at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
                2021-04-15 03:52:17.817  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                2021-04-15 03:52:19.824  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                2021-04-15 03:52:22.830  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                2021-04-15 03:52:26.844  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: read ECONNRESET
                    at TLSWrap.onStreamRead (internal/stream_base_commons.js:209:20)
                2021-04-15 03:52:28.449  - info: chromecast.0 (12982) Received keep alive for disconnected device Wohnzimmer
                2021-04-15 03:52:28.451  - info: chromecast.0 (12982) Reconnecting Wohnzimmer to 192.168.1.25:8009
                2021-04-15 03:52:30.261  - info: chromecast.0 (12982) Wohnzimmer - Connected client
                2021-04-15 03:57:31.646  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 03:57:31.648  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 04:39:23.894  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 04:39:23.895  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 04:48:22.475  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 04:48:22.477  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 04:48:52.510  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 04:48:52.513  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 05:02:12.758  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 05:02:12.769  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 05:02:42.749  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 05:02:42.751  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 05:57:05.124  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 05:57:05.126  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 05:57:33.556  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 05:57:33.557  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 06:07:13.724  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 06:07:13.724  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 06:50:55.885  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 06:50:55.887  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:00:04.445  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:00:04.447  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:00:34.460  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:00:34.461  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:10:14.597  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:10:14.598  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:10:54.623  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:10:54.624  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:20:34.782  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:20:34.783  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:21:04.808  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:21:04.809  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:31:35.464  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:31:35.465  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:32:04.954  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:32:04.955  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:42:56.183  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:42:56.184  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:43:26.712  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:43:26.715  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:52:35.796  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:52:35.796  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:53:05.848  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 07:53:05.849  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 07:55:11.765  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                2021-04-15 07:55:11.995  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                2021-04-15 07:55:14.717  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                2021-04-15 07:57:45.852  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                2021-04-15 07:58:20.248  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                2021-04-15 07:58:29.915  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                2021-04-15 07:59:24.967  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                2021-04-15 08:00:50.418  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                2021-04-15 08:02:45.426  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:02:45.426  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:03:25.478  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:03:25.479  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:05:19.580  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                2021-04-15 08:05:23.881  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                2021-04-15 08:07:49.732  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                2021-04-15 08:11:55.333  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                2021-04-15 08:13:05.633  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:13:05.634  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:13:35.657  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:13:35.658  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:25:45.906  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:25:45.907  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:26:15.890  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:26:15.891  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:26:26.852  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                2021-04-15 08:26:28.228  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                2021-04-15 08:26:34.544  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                2021-04-15 08:29:52.933  - info: fb-checkpresence.0 (26624) newActive Elke J3 false
                2021-04-15 08:35:46.050  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:35:46.056  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:36:16.046  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:36:16.047  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:46:26.150  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:46:26.151  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:46:56.175  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:46:56.177  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:56:16.254  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:56:16.261  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 08:56:57.304  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 08:56:57.305  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 09:06:37.392  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 09:06:37.396  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 09:07:06.352  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 09:07:06.353  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 10:08:57.227  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 10:08:57.229  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 10:31:23.250  - info: fb-checkpresence.0 (26624) newActive Uwe false
                2021-04-15 10:31:23.283  - warn: sonoff.0 (29561) Client "Steckdose10" not connected
                2021-04-15 10:57:55.907  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                2021-04-15 11:10:37.886  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 11:10:37.887  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 12:17:25.886  - info: fb-checkpresence.0 (26624) newActive Elke J3 true
                2021-04-15 12:17:25.949  - warn: sonoff.0 (29561) Client "Steckdose10" not connected
                2021-04-15 12:48:18.590  - info: fb-checkpresence.0 (26624) newActive Uwe true
                2021-04-15 12:50:24.286  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                2021-04-15 12:50:25.217  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                2021-04-15 12:50:31.202  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                2021-04-15 13:35:59.700  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                2021-04-15 13:47:28.462  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                2021-04-15 13:47:28.788  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                2021-04-15 13:47:30.865  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                2021-04-15 15:33:31.443  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                2021-04-15 15:33:31.451  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                2021-04-15 16:17:12.004  - info: host.whome iobroker.js-controller version 3.2.16 js-controller starting
                2021-04-15 16:17:12.009  - info: host.whome Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                2021-04-15 16:17:12.010  - info: host.whome hostname: whome, node: v12.22.1
                2021-04-15 16:17:12.010  - info: host.whome ip addresses: fe80::d8:6431:90b3:eeab
                2021-04-15 16:17:12.651  - error: host.whome-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                2021-04-15 16:17:12.807  - info: host.whome connected to Objects and States
                2021-04-15 16:17:12.873  - info: host.whome added notifications configuration of host
                2021-04-15 16:17:13.618  - info: host.whome 25 instances found
                2021-04-15 16:17:13.677  - info: host.whome starting 19 instances
                2021-04-15 16:17:13.783  - info: host.whome instance system.adapter.admin.0 started with pid 788
                2021-04-15 16:17:15.578  - error: admin.0 (788) admin.0 already running
                2021-04-15 16:17:15.582  - warn: admin.0 (788) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 16:17:16.190  - error: host.whome instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 16:17:16.191  - info: host.whome Restart adapter system.adapter.admin.0 because enabled
                2021-04-15 16:17:17.698  - info: host.whome instance system.adapter.backitup.0 started with pid 1016
                2021-04-15 16:17:21.708  - info: host.whome instance system.adapter.chromecast.0 started with pid 1322
                2021-04-15 16:17:22.448  - error: backitup.0 (1016) backitup.0 already running
                2021-04-15 16:17:22.451  - warn: backitup.0 (1016) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 16:17:23.057  - error: host.whome instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 16:17:23.058  - info: host.whome Restart adapter system.adapter.backitup.0 because enabled
                2021-04-15 16:17:23.178  - error: chromecast.0 (1322) chromecast.0 already running
                2021-04-15 16:17:23.181  - warn: chromecast.0 (1322) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 16:17:23.769  - error: host.whome Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                2021-04-15 16:17:23.769  - error: host.whome Caught by controller[0]:     at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
                2021-04-15 16:17:23.770  - error: host.whome Caught by controller[0]:     at Adapter.emit (events.js:314:20)
                2021-04-15 16:17:23.770  - error: host.whome Caught by controller[0]:     at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                2021-04-15 16:17:23.771  - error: host.whome Caught by controller[0]:     at Object.onceWrapper (events.js:421:26)
                2021-04-15 16:17:23.771  - error: host.whome Caught by controller[0]:     at process.emit (events.js:314:20)
                2021-04-15 16:17:23.771  - error: host.whome Caught by controller[0]:     at process.exit (internal/process/per_thread.js:168:15)
                2021-04-15 16:17:23.772  - error: host.whome Caught by controller[0]:     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                2021-04-15 16:17:23.772  - error: host.whome Caught by controller[0]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
                2021-04-15 16:17:23.773  - error: host.whome instance system.adapter.chromecast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 16:17:23.774  - info: host.whome Restart adapter system.adapter.chromecast.0 because enabled
                2021-04-15 16:17:25.765  - info: host.whome instance system.adapter.cloud.0 started with pid 1640
                2021-04-15 16:17:27.304  - error: cloud.0 (1640) cloud.0 already running
                2021-04-15 16:17:27.307  - warn: cloud.0 (1640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 16:17:27.922  - error: host.whome instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 16:17:27.923  - info: host.whome Restart adapter system.adapter.cloud.0 because enabled
                2021-04-15 16:17:29.738  - info: host.whome instance system.adapter.discovery.0 started with pid 1939
                2021-04-15 16:17:30.980  - error: discovery.0 (1939) discovery.0 already running
                2021-04-15 16:17:30.984  - warn: discovery.0 (1939) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 16:17:31.614  - error: host.whome instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 16:17:31.615  - info: host.whome Restart adapter system.adapter.discovery.0 because enabled
                2021-04-15 16:17:33.769  - info: host.whome instance system.adapter.fb-checkpresence.0 started with pid 2286
                2021-04-15 16:17:35.106  - error: fb-checkpresence.0 (2286) fb-checkpresence.0 already running
                2021-04-15 16:17:35.108  - warn: fb-checkpresence.0 (2286) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 16:17:35.683  - error: host.whome instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 16:17:35.684  - info: host.whome Restart adapter system.adapter.fb-checkpresence.0 because enabled
                2021-04-15 17:05:01.580  - info: host.whome instance system.adapter.followthesun.0 started with pid 2671
                2021-04-15 17:05:02.724  - error: followthesun.0 (2671) followthesun.0 already running
                2021-04-15 17:05:02.727  - warn: followthesun.0 (2671) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:03.302  - error: host.whome instance system.adapter.followthesun.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:03.303  - info: host.whome Restart adapter system.adapter.followthesun.0 because enabled
                2021-04-15 17:05:05.582  - info: host.whome instance system.adapter.info.0 started with pid 2970
                2021-04-15 17:05:07.751  - error: info.0 (2970) info.0 already running
                2021-04-15 17:05:07.754  - warn: info.0 (2970) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:08.328  - error: host.whome instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:08.329  - info: host.whome Restart adapter system.adapter.info.0 because enabled
                2021-04-15 17:05:09.596  - info: host.whome instance system.adapter.javascript.0 started with pid 3305
                2021-04-15 17:05:10.010  - info: host.whome instance system.adapter.admin.0 started with pid 3348
                2021-04-15 17:05:12.121  - info: admin.0 (3348) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:12.200  - info: admin.0 (3348) requesting all states
                2021-04-15 17:05:12.201  - info: admin.0 (3348) requesting all objects
                2021-04-15 17:05:13.009  - error: javascript.0 (3305) javascript.0 already running
                2021-04-15 17:05:13.013  - warn: javascript.0 (3305) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:13.117  - info: admin.0 (3348) received all objects
                2021-04-15 17:05:13.484  - info: admin.0 (3348) http server listening on port 8081
                2021-04-15 17:05:13.558  - info: host.whome instance system.adapter.mqtt.0 started with pid 3643
                2021-04-15 17:05:13.653  - error: host.whome instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:13.654  - info: host.whome Restart adapter system.adapter.javascript.0 because enabled
                2021-04-15 17:05:13.485  - info: admin.0 (3348) Use link "http://localhost:8081" to configure.
                2021-04-15 17:05:14.720  - error: mqtt.0 (3643) mqtt.0 already running
                2021-04-15 17:05:15.295  - error: host.whome instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:15.296  - info: host.whome Restart adapter system.adapter.mqtt.0 because enabled
                2021-04-15 17:05:16.890  - info: host.whome instance system.adapter.backitup.0 started with pid 3906
                2021-04-15 17:05:17.567  - info: host.whome instance system.adapter.node-red.0 started with pid 3973
                2021-04-15 17:05:17.597  - info: host.whome instance system.adapter.chromecast.0 started with pid 3979
                2021-04-15 17:05:19.013  - error: node-red.0 (3973) node-red.0 already running
                2021-04-15 17:05:19.016  - warn: node-red.0 (3973) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:19.162  - info: chromecast.0 (3979) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:19.614  - error: host.whome instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:19.615  - info: host.whome Restart adapter system.adapter.node-red.0 because enabled
                2021-04-15 17:05:19.911  - info: chromecast.0 (3979) Wohnzimmer - Connected client
                2021-04-15 17:05:20.875  - info: backitup.0 (3906) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:20.953  - info: backitup.0 (3906) [iobroker] backup was activated at 03:00 every 1 day(s)
                2021-04-15 17:05:21.559  - info: host.whome instance system.adapter.ping.0 started with pid 4301
                2021-04-15 17:05:21.744  - info: host.whome instance system.adapter.cloud.0 started with pid 4326
                2021-04-15 17:05:22.724  - error: ping.0 (4301) ping.0 already running
                2021-04-15 17:05:22.727  - warn: ping.0 (4301) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:23.325  - error: host.whome instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:23.326  - info: host.whome Restart adapter system.adapter.ping.0 because enabled
                2021-04-15 17:05:23.721  - info: cloud.0 (4326) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:23.803  - info: cloud.0 (4326) Connecting with https://iobroker.net:10555 with "uwaizmann@gmail.com_c9f2a840-75ac-11eb-a278-59b6a78c6ee1"
                2021-04-15 17:05:24.164  - info: cloud.0 (4326) Trying to connect as system.user.admin
                2021-04-15 17:05:25.435  - info: host.whome instance system.adapter.discovery.0 started with pid 4621
                2021-04-15 17:05:25.608  - info: host.whome instance system.adapter.sayit.0 started with pid 4640
                2021-04-15 17:05:26.855  - error: sayit.0 (4640) sayit.0 already running
                2021-04-15 17:05:26.859  - warn: sayit.0 (4640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:27.205  - info: discovery.0 (4621) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:27.435  - error: host.whome instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:27.436  - info: host.whome Restart adapter system.adapter.sayit.0 because enabled
                2021-04-15 17:05:29.129  - error: cloud.0 (4326) Cloud says: timeout
                2021-04-15 17:05:29.520  - info: host.whome instance system.adapter.fb-checkpresence.0 started with pid 4948
                2021-04-15 17:05:29.630  - info: host.whome instance system.adapter.shelly.0 started with pid 4966
                2021-04-15 17:05:30.139  - info: cloud.0 (4326) Connection changed: io server disconnect
                2021-04-15 17:05:31.141  - info: host.whome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2021-04-15 17:05:32.940  - error: shelly.0 (4966) shelly.0 already running
                2021-04-15 17:05:32.944  - warn: shelly.0 (4966) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:32.989  - info: fb-checkpresence.0 (4948) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:33.030  - info: fb-checkpresence.0 (4948) start fb-checkpresence: ip-address: "192.168.1.10" - interval devices: 1 Min. - interval members: 60 s
                2021-04-15 17:05:33.211  - info: fb-checkpresence.0 (4948) service Hosts1-X_AVM-DE_GetHostListPath is supported
                2021-04-15 17:05:33.235  - info: fb-checkpresence.0 (4948) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                2021-04-15 17:05:33.256  - info: fb-checkpresence.0 (4948) service Hosts1-GetSpecificHostEntry is supported
                2021-04-15 17:05:33.272  - info: fb-checkpresence.0 (4948) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                2021-04-15 17:05:33.288  - info: fb-checkpresence.0 (4948) service DeviceInfo1-GetSecurityPort is supported
                2021-04-15 17:05:33.308  - info: fb-checkpresence.0 (4948) service WANPPPConnection1-GetInfo is supported
                2021-04-15 17:05:33.330  - info: fb-checkpresence.0 (4948) service WLANConfiguration3-SetEnable is supported
                2021-04-15 17:05:33.330  - info: host.whome instance system.adapter.followthesun.0 started with pid 5269
                2021-04-15 17:05:33.350  - info: fb-checkpresence.0 (4948) service WLANConfiguration3-GetInfo is supported
                2021-04-15 17:05:33.366  - info: fb-checkpresence.0 (4948) service DeviceInfo1-GetInfo is supported
                2021-04-15 17:05:33.387  - info: fb-checkpresence.0 (4948) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                2021-04-15 17:05:33.404  - info: fb-checkpresence.0 (4948) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                2021-04-15 17:05:33.427  - info: fb-checkpresence.0 (4948) service DeviceConfig1-Reboot is supported
                2021-04-15 17:05:33.570  - error: host.whome instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:33.571  - info: host.whome Restart adapter system.adapter.shelly.0 because enabled
                2021-04-15 17:05:33.712  - info: host.whome instance system.adapter.sonoff.0 started with pid 5300
                2021-04-15 17:05:33.717  - info: fb-checkpresence.0 (4948) createGlobalObjects finished successfully
                2021-04-15 17:05:33.877  - info: fb-checkpresence.0 (4948) History function for Uwe disabled. Please select a history adapter in the configuration dialog!
                2021-04-15 17:05:33.978  - info: fb-checkpresence.0 (4948) History function for Elke disabled. Please select a history adapter in the configuration dialog!
                2021-04-15 17:05:34.103  - info: fb-checkpresence.0 (4948) History function for Elke J3 disabled. Please select a history adapter in the configuration dialog!
                2021-04-15 17:05:34.104  - info: fb-checkpresence.0 (4948) createMemberObjects finished successfully
                2021-04-15 17:05:35.132  - error: sonoff.0 (5300) sonoff.0 already running
                2021-04-15 17:05:35.135  - warn: sonoff.0 (5300) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:35.164  - info: followthesun.0 (5269) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.followthesun, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:35.200  - info: followthesun.0 (5269) Sun position calculation will be done every 120 seconds
                2021-04-15 17:05:35.204  - info: followthesun.0 (5269) Daily sun parameter calculation scheduled for 00:00:23
                2021-04-15 17:05:35.824  - error: host.whome instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:35.824  - info: host.whome Restart adapter system.adapter.sonoff.0 because enabled
                2021-04-15 17:05:37.684  - info: host.whome instance system.adapter.telegram.0 started with pid 5621
                2021-04-15 17:05:38.359  - info: host.whome instance system.adapter.info.0 started with pid 5688
                2021-04-15 17:05:39.908  - error: telegram.0 (5621) telegram.0 already running
                2021-04-15 17:05:39.912  - warn: telegram.0 (5621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:40.493  - error: host.whome instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:40.493  - info: host.whome Restart adapter system.adapter.telegram.0 because enabled
                2021-04-15 17:05:41.194  - info: info.0 (5688) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:41.615  - info: host.whome instance system.adapter.telegram.1 started with pid 6027
                2021-04-15 17:05:43.741  - info: host.whome instance system.adapter.javascript.0 started with pid 6399
                2021-04-15 17:05:45.103  - error: telegram.1 (6027) telegram.1 already running
                2021-04-15 17:05:45.109  - warn: telegram.1 (6027) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:45.328  - info: host.whome instance system.adapter.mqtt.0 started with pid 6670
                2021-04-15 17:05:46.069  - error: host.whome instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:46.071  - info: host.whome Restart adapter system.adapter.telegram.1 because enabled
                2021-04-15 17:05:48.273  - info: vis.0 (6713) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:48.521  - info: vis.0 (6713) vis license is OK.
                2021-04-15 17:05:48.822  - info: javascript.0 (6399) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:49.055  - info: javascript.0 (6399) requesting all states
                2021-04-15 17:05:49.056  - info: javascript.0 (6399) requesting all objects
                2021-04-15 17:05:49.653  - info: host.whome instance system.adapter.web.0 started with pid 7008
                2021-04-15 17:05:49.682  - info: host.whome instance system.adapter.node-red.0 started with pid 7014
                2021-04-15 17:05:49.704  - info: vis.0 (6713) Terminated (NO_ERROR): Without reason
                2021-04-15 17:05:49.827  - info: javascript.0 (6399) received all objects
                2021-04-15 17:05:49.886  - info: javascript.0 (6399) received all states
                2021-04-15 17:05:50.024  - info: javascript.0 (6399) Start javascript script.js.common.Buero.heizung_buero_boden
                2021-04-15 17:05:50.106  - info: javascript.0 (6399) script.js.common.Buero.heizung_buero_boden: registered 1 subscription and 0 schedules
                2021-04-15 17:05:50.107  - info: javascript.0 (6399) Start javascript script.js.common.Heizung.Auftau
                2021-04-15 17:05:50.143  - info: javascript.0 (6399) script.js.common.Heizung.Auftau: registered 1 subscription and 1 schedule
                2021-04-15 17:05:50.144  - info: javascript.0 (6399) Start javascript script.js.common.Heizung.Heizstab
                2021-04-15 17:05:50.154  - info: javascript.0 (6399) script.js.common.Heizung.Heizstab: registered 1 subscription and 1 schedule
                2021-04-15 17:05:50.305  - info: host.whome instance system.adapter.vis.0 terminated while should be started once
                2021-04-15 17:05:50.265  - info: javascript.0 (6399) Start javascript script.js.common.Rolladen.Rolladen
                2021-04-15 17:05:50.278  - info: javascript.0 (6399) script.js.common.Rolladen.Rolladen: registered 1 subscription and 0 schedules
                2021-04-15 17:05:50.279  - info: javascript.0 (6399) Start javascript script.js.common.Rolladen.RolladenAutomatik
                2021-04-15 17:05:50.296  - info: javascript.0 (6399) script.js.common.Rolladen.RolladenAutomatik: registered 4 subscriptions and 2 schedules
                2021-04-15 17:05:50.297  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Anwesenheit
                2021-04-15 17:05:50.304  - info: javascript.0 (6399) script.js.common.Scripte.Anwesenheit: registered 1 subscription and 0 schedules
                2021-04-15 17:05:50.305  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Flur
                2021-04-15 17:05:50.311  - info: javascript.0 (6399) script.js.common.Scripte.Flur: registered 1 subscription and 0 schedules
                2021-04-15 17:05:50.312  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Gute-Nacht
                2021-04-15 17:05:50.318  - info: javascript.0 (6399) script.js.common.Scripte.Gute-Nacht: registered 2 subscriptions and 0 schedules
                2021-04-15 17:05:50.319  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Tag
                2021-04-15 17:05:50.327  - info: javascript.0 (6399) script.js.common.Scripte.Tag: registered 0 subscriptions and 2 schedules
                2021-04-15 17:05:50.328  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Terasse_LED_stripe
                2021-04-15 17:05:50.335  - info: javascript.0 (6399) script.js.common.Scripte.Terasse_LED_stripe: registered 1 subscription and 1 schedule
                2021-04-15 17:05:50.336  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.wama2
                2021-04-15 17:05:50.342  - info: javascript.0 (6399) script.js.common.Scripte.wama2: registered 1 subscription and 0 schedules
                2021-04-15 17:05:50.343  - info: javascript.0 (6399) Start javascript script.js.common.Temperaturen.aussen
                2021-04-15 17:05:50.349  - info: javascript.0 (6399) script.js.common.Temperaturen.aussen: registered 2 subscriptions and 0 schedules
                2021-04-15 17:05:50.350  - info: javascript.0 (6399) Start javascript script.js.common.Temperaturen.temp2
                2021-04-15 17:05:50.357  - info: javascript.0 (6399) script.js.common.Temperaturen.temp2: registered 3 subscriptions and 0 schedules
                2021-04-15 17:05:50.359  - info: javascript.0 (6399) Start javascript script.js.common.Wohnzimmer.Wohnzimmer
                2021-04-15 17:05:50.365  - info: javascript.0 (6399) script.js.common.Wohnzimmer.Wohnzimmer: registered 1 subscription and 0 schedules
                2021-04-15 17:05:50.366  - info: javascript.0 (6399) Start javascript script.js.rebootPi
                2021-04-15 17:05:50.371  - info: javascript.0 (6399) script.js.rebootPi: registered 1 subscription and 0 schedules
                2021-04-15 17:05:51.316  - info: node-red.0 (7014) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:51.421  - error: web.0 (7008) web.0 already running
                2021-04-15 17:05:51.424  - warn: web.0 (7008) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                2021-04-15 17:05:51.778  - info: node-red.0 (7014) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                2021-04-15 17:05:51.992  - error: host.whome instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                2021-04-15 17:05:51.992  - info: host.whome Restart adapter system.adapter.web.0 because enabled
                2021-04-15 17:05:53.362  - info: host.whome instance system.adapter.ping.0 started with pid 7321
                2021-04-15 17:05:53.850  - warn: node-red.0 (7014) 15 Apr 17:05:53 - [warn] Die Verwendung von editorTheme.palette.editable ist abgekündigt. Stattdessen externalModules.palette.allowInstall verwenden.
                2021-04-15 17:05:55.084  - info: ping.0 (7321) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:57.481  - info: host.whome instance system.adapter.sayit.0 started with pid 7676
                2021-04-15 17:05:58.505  - warn: node-red.0 (7014) 15 Apr 17:05:58 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                2021-04-15 17:05:59.536  - info: sayit.0 (7676) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:05:59.573  - info: sayit.0 (7676) Upload announce mp3 files
                2021-04-15 17:05:59.786  - info: sayit.0 (7676) All files uploaded
                2021-04-15 17:06:03.637  - info: host.whome instance system.adapter.shelly.0 started with pid 8159
                2021-04-15 17:06:05.862  - info: host.whome instance system.adapter.sonoff.0 started with pid 8365
                2021-04-15 17:06:05.885  - info: shelly.0 (8159) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:06:05.933  - info: shelly.0 (8159) Starting Adapter shelly.0 in version 4.0.7
                2021-04-15 17:06:05.984  - info: shelly.0 (8159) Starting Shelly adapter in CoAP modus.
                2021-04-15 17:06:06.065  - info: shelly.0 (8159) Listening for Shelly packets in the network
                2021-04-15 17:06:07.307  - info: sonoff.0 (8365) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:06:07.384  - info: sonoff.0 (8365) Starting MQTT  server on port 1884
                2021-04-15 17:06:08.384  - info: shelly.0 (8159) Shelly device 192.168.1.122 (shellyswitch25 / shellyswitch25-483FDA8DDD51 / SHSW-25#483FDA8DDD51#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:08.889  - info: shelly.0 (8159) Shelly device 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:09.913  - info: shelly.0 (8159) Shelly device 192.168.1.128 (shelly1 / shelly1-8CAAB5614D9F / SHSW-1#8CAAB5614D9F#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:10.609  - info: host.whome instance system.adapter.telegram.0 started with pid 8765
                2021-04-15 17:06:10.740  - info: shelly.0 (8159) Shelly device 192.168.1.121 (shellyswitch25 / shellyswitch25-84CCA8B09E95 / SHSW-25#84CCA8B09E95#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:13.163  - info: telegram.0 (8765) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:06:14.115  - info: shelly.0 (8159) Shelly device 192.168.1.126 (shelly1 / shelly1-483FDA91AF1A / SHSW-1#483FDA91AF1A#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:14.829  - info: shelly.0 (8159) Shelly device 192.168.1.127 (shelly1 / shelly1-F4CFA2E46301 / SHSW-1#F4CFA2E46301#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:15.062  - info: shelly.0 (8159) Shelly device 192.168.1.131 (shellydimmer2 / shellydimmer2-40F520015E03 / SHDM-2#40F520015E03#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:15.551  - info: shelly.0 (8159) Shelly device 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:16.139  - info: host.whome instance system.adapter.telegram.1 started with pid 9216
                2021-04-15 17:06:18.009  - info: shelly.0 (8159) Shelly device 192.168.1.123 (shellyswitch25 / shellyswitch25-84CCA8B0CC8F / SHSW-25#84CCA8B0CC8F#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:06:18.683  - info: telegram.1 (9216) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:06:19.987  - info: sonoff.0 (8365) Client [wama] connected with secret 1618499179967_1240
                2021-04-15 17:06:22.011  - info: host.whome instance system.adapter.web.0 started with pid 9699
                2021-04-15 17:06:23.768  - info: web.0 (9699) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:06:23.820  - info: cloud.0 (4326) Trying to connect as system.user.admin
                2021-04-15 17:06:23.944  - info: cloud.0 (4326) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                2021-04-15 17:06:24.069  - info: web.0 (9699) socket.io server listening on port 8082
                2021-04-15 17:06:24.084  - info: web.0 (9699) simpleAPI server listening on port 8082
                2021-04-15 17:06:24.086  - info: web.0 (9699) Allow states only when user is owner: false
                2021-04-15 17:06:24.095  - info: web.0 (9699) http server listening on port 8082
                2021-04-15 17:06:28.766  - info: sonoff.0 (8365) Client [Schalter-TV] connected with secret 1618499188765_7489
                2021-04-15 17:06:29.594  - info: sonoff.0 (8365) Client [Steckdose12] connected with secret 1618499189588_613
                2021-04-15 17:06:31.835  - info: sonoff.0 (8365) Client [Buero_Temp] connected with secret 1618499191833_7737
                2021-04-15 17:06:32.648  - info: sonoff.0 (8365) Client [WekstattTemp] connected with secret 1618499192646_1301
                2021-04-15 17:06:34.602  - info: sonoff.0 (8365) Client [Terrasse_lux_led] connected with secret 1618499194601_2835
                2021-04-15 17:06:36.217  - info: sonoff.0 (8365) Client [Temp2-DS18B20] connected with secret 1618499196215_9761
                2021-04-15 17:07:23.954  - info: cloud.0 (4326) Trying to connect as system.user.admin
                2021-04-15 17:07:24.077  - info: cloud.0 (4326) Connection changed: connect
                2021-04-15 17:15:44.289  - info: host.whome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                2021-04-15 17:26:21.072  - info: web.0 (9699) terminated http server on port 8082
                2021-04-15 17:26:21.082  - info: node-red.0 (7014) kill node-red task
                2021-04-15 17:26:21.080  - info: chromecast.0 (3979) Unload triggered
                2021-04-15 17:26:21.075  - info: fb-checkpresence.0 (4948) cleaned everything up ...
                2021-04-15 17:26:21.082  - info: chromecast.0 (3979) Destroying chromecast scanner
                2021-04-15 17:26:21.087  - info: chromecast.0 (3979) Wohnzimmer - client disconnected
                2021-04-15 17:26:21.088  - info: chromecast.0 (3979) Unload completed sucesfully
                2021-04-15 17:26:21.121  - info: info.0 (5688) cleaned everything up...
                2021-04-15 17:26:21.163  - info: followthesun.0 (5269) cleaned everything up...
                2021-04-15 17:26:21.062  - info: host.whome received SIGTERM
                2021-04-15 17:26:21.195  - info: sayit.0 (7676) stopping...
                2021-04-15 17:26:21.179  - info: backitup.0 (3906) cleaned everything up...
                2021-04-15 17:26:21.178  - info: host.whome stopInstance system.adapter.admin.0 (force=false, process=true)
                2021-04-15 17:26:21.179  - info: host.whome stopInstance system.adapter.backitup.0 (force=false, process=true)
                2021-04-15 17:26:21.180  - info: host.whome stopInstance system.adapter.chromecast.0 (force=false, process=true)
                2021-04-15 17:26:21.186  - info: host.whome stopInstance system.adapter.cloud.0 (force=false, process=true)
                2021-04-15 17:26:21.188  - info: host.whome stopInstance system.adapter.discovery.0 (force=false, process=true)
                2021-04-15 17:26:21.189  - info: host.whome stopInstance system.adapter.ecovacs-deebot.0 (force=false, process=false)
                2021-04-15 17:26:21.190  - info: host.whome stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
                2021-04-15 17:26:21.190  - info: host.whome stopInstance system.adapter.followthesun.0 (force=false, process=true)
                2021-04-15 17:26:21.191  - info: host.whome stopInstance system.adapter.info.0 (force=false, process=true)
                2021-04-15 17:26:21.192  - info: host.whome stopInstance system.adapter.javascript.0 (force=false, process=true)
                2021-04-15 17:26:21.193  - info: host.whome stopInstance system.adapter.midea.0 (force=false, process=false)
                2021-04-15 17:26:21.194  - info: host.whome stopInstance system.adapter.mqtt.0 (force=false, process=true)
                2021-04-15 17:26:21.196  - info: host.whome stopInstance system.adapter.node-red.0 (force=false, process=true)
                2021-04-15 17:26:21.197  - info: host.whome stopInstance system.adapter.ping.0 (force=false, process=true)
                2021-04-15 17:26:21.198  - info: host.whome stopInstance system.adapter.sayit.0 (force=false, process=true)
                2021-04-15 17:26:21.199  - info: host.whome stopInstance system.adapter.shelly.0 (force=false, process=true)
                2021-04-15 17:26:21.200  - info: host.whome stopInstance system.adapter.sonoff.0 (force=false, process=true)
                2021-04-15 17:26:21.201  - info: host.whome stopInstance system.adapter.telegram.0 (force=false, process=true)
                2021-04-15 17:26:21.201  - info: host.whome stopInstance system.adapter.telegram.1 (force=false, process=true)
                2021-04-15 17:26:21.202  - info: host.whome stopInstance system.adapter.tr-064.0 (force=false, process=false)
                2021-04-15 17:26:21.203  - info: host.whome stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
                2021-04-15 17:26:21.203  - info: host.whome stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                2021-04-15 17:26:21.204  - info: host.whome stopInstance system.adapter.vis.0 (force=false, process=false)
                2021-04-15 17:26:21.204  - info: host.whome stopInstance system.adapter.web.0 (force=false, process=true)
                2021-04-15 17:26:21.075  - info: admin.0 (3348) terminating http server on port 8081
                2021-04-15 17:26:21.231  - info: javascript.0 (6399) Stop script script.js.common.Buero.heizung_buero_boden
                2021-04-15 17:26:21.278  - info: chromecast.0 (3979) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.291  - info: admin.0 (3348) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.267  - info: shelly.0 (8159) Closing Adapter
                2021-04-15 17:26:21.288  - info: backitup.0 (3906) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.317  - info: fb-checkpresence.0 (4948) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.317  - info: cloud.0 (4326) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.319  - info: discovery.0 (4621) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.338  - info: followthesun.0 (5269) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.340  - info: info.0 (5688) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.355  - info: node-red.0 (7014) node-red exited with 0
                2021-04-15 17:26:21.253  - info: javascript.0 (6399) Stop script script.js.common.Heizung.Auftau
                2021-04-15 17:26:21.254  - info: javascript.0 (6399) Stop script script.js.common.Heizung.Heizstab
                2021-04-15 17:26:21.255  - info: javascript.0 (6399) Stop script script.js.common.Rolladen.Rolladen
                2021-04-15 17:26:21.318  - info: javascript.0 (6399) Stop script script.js.common.Rolladen.RolladenAutomatik
                2021-04-15 17:26:21.332  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Anwesenheit
                2021-04-15 17:26:21.334  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Flur
                2021-04-15 17:26:21.346  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Gute-Nacht
                2021-04-15 17:26:21.357  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Tag
                2021-04-15 17:26:21.358  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Terasse_LED_stripe
                2021-04-15 17:26:21.359  - info: javascript.0 (6399) Stop script script.js.common.Scripte.wama2
                2021-04-15 17:26:21.367  - info: javascript.0 (6399) Stop script script.js.common.Temperaturen.aussen
                2021-04-15 17:26:21.369  - info: javascript.0 (6399) Stop script script.js.common.Temperaturen.temp2
                2021-04-15 17:26:21.369  - info: javascript.0 (6399) Stop script script.js.common.Wohnzimmer.Wohnzimmer
                2021-04-15 17:26:21.370  - info: javascript.0 (6399) Stop script script.js.rebootPi
                2021-04-15 17:26:21.383  - info: javascript.0 (6399) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.415  - info: fb-checkpresence.0 (4948) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.434  - info: discovery.0 (4621) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.447  - info: shelly.0 (8159) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.445  - info: ping.0 (7321) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.450  - info: sonoff.0 (8365) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.455  - info: telegram.1 (9216) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.453  - info: telegram.0 (8765) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.466  - info: web.0 (9699) Got terminate signal TERMINATE_YOURSELF
                2021-04-15 17:26:21.495  - info: followthesun.0 (5269) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.502  - info: chromecast.0 (3979) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.499  - info: host.whome stopInstance system.adapter.admin.0 send kill signal
                2021-04-15 17:26:21.499  - info: backitup.0 (3906) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.508  - info: node-red.0 (7014) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.508  - info: cloud.0 (4326) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.500  - info: host.whome stopInstance system.adapter.backitup.0 send kill signal
                2021-04-15 17:26:21.501  - info: host.whome stopInstance system.adapter.chromecast.0 send kill signal
                2021-04-15 17:26:21.501  - info: host.whome stopInstance system.adapter.cloud.0 send kill signal
                2021-04-15 17:26:21.501  - info: host.whome stopInstance system.adapter.discovery.0 send kill signal
                2021-04-15 17:26:21.502  - info: host.whome stopInstance system.adapter.fb-checkpresence.0 send kill signal
                2021-04-15 17:26:21.502  - info: host.whome stopInstance system.adapter.followthesun.0 send kill signal
                2021-04-15 17:26:21.503  - info: host.whome stopInstance system.adapter.info.0 send kill signal
                2021-04-15 17:26:21.503  - info: host.whome stopInstance system.adapter.javascript.0 send kill signal
                2021-04-15 17:26:21.505  - info: host.whome stopInstance system.adapter.mqtt.0 send kill signal
                2021-04-15 17:26:21.512  - info: web.0 (9699) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.508  - info: info.0 (5688) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.519  - info: admin.0 (3348) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.520  - info: host.whome stopInstance system.adapter.ping.0 send kill signal
                2021-04-15 17:26:21.563  - info: shelly.0 (8159) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.576  - info: host.whome stopInstance system.adapter.shelly.0 send kill signal
                2021-04-15 17:26:21.577  - info: host.whome stopInstance system.adapter.sonoff.0 send kill signal
                2021-04-15 17:26:21.577  - info: host.whome stopInstance system.adapter.telegram.0 send kill signal
                2021-04-15 17:26:21.578  - info: host.whome stopInstance system.adapter.telegram.1 send kill signal
                2021-04-15 17:26:21.578  - info: host.whome stopInstance system.adapter.web.0 send kill signal
                2021-04-15 17:26:21.580  - info: javascript.0 (6399) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.613  - info: telegram.1 (9216) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.628  - info: sonoff.0 (8365) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.632  - info: telegram.0 (8765) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.688  - info: ping.0 (7321) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:21.701  - info: sayit.0 (7676) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2021-04-15 17:26:22.010  - info: host.whome instance system.adapter.fb-checkpresence.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.181  - info: host.whome instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.210  - warn: shelly.0 (8159) redis get shelly.0.SHSW-1#F4CFA2E46301#1.Relay0.Timer, error - Connection is closed.
                2021-04-15 17:26:22.217  - info: host.whome stopInstance timeout 1000 system.adapter.node-red.0 killing pid  7014
                2021-04-15 17:26:22.221  - info: host.whome stopInstance timeout 1000 system.adapter.sayit.0 killing pid  7676
                2021-04-15 17:26:22.234  - warn: shelly.0 (8159) redis get shelly.0.SHSW-25#483FDA8DCC8E#1.Relay0.Timer, error - Connection is closed.
                2021-04-15 17:26:22.241  - warn: shelly.0 (8159) redis get shelly.0.SHSW-25#483FDA8DCC8E#1.Relay1.Timer, error - Connection is closed.
                2021-04-15 17:26:22.243  - warn: shelly.0 (8159) redis get shelly.0.SHSW-25#483FDA8DCC8E#1.Shutter.Duration, error - Connection is closed.
                2021-04-15 17:26:22.279  - error: shelly.0 (8159) Error in function httpIoBrokerState for state SHSW-25#483FDA8DCC8E#1.name and request{"url":"http://192.168.1.120/settings","timeout":5000} for 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) (Error: Connection is closed.)
                2021-04-15 17:26:22.306  - error: shelly.0 (8159) Error in function httpIoBrokerState for state SHSW-1#483FDA6F6EBC#1.Relay0.ChannelName and request{"url":"http://192.168.1.125/settings/relay/0","timeout":5000} for 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) (Error: Connection is closed.)
                2021-04-15 17:26:22.324  - error: shelly.0 (8159) Error in function httpIoBrokerState for state SHSW-25#483FDA8DCC8E#1.Relay1.ChannelName and request{"url":"http://192.168.1.120/settings/relay/1","timeout":5000} for 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) (Error: Connection is closed.)
                2021-04-15 17:26:22.348  - error: shelly.0 (8159) Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.uptime": Connection is closed.
                2021-04-15 17:26:22.349  - warn: shelly.0 (8159) Could not check object existence of state shelly.0.SHSW-1#F4CFA2E46301#1.uptime: Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.uptime": Connection is closed.
                2021-04-15 17:26:22.350  - warn: shelly.0 (8159) get state error: Connection is closed.
                2021-04-15 17:26:22.350  - error: shelly.0 (8159) Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.rssi": Connection is closed.
                2021-04-15 17:26:22.351  - warn: shelly.0 (8159) Could not check object existence of state shelly.0.SHSW-1#F4CFA2E46301#1.rssi: Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.rssi": Connection is closed.
                2021-04-15 17:26:22.351  - warn: shelly.0 (8159) get state error: Connection is closed.
                2021-04-15 17:26:22.693  - info: host.whome instance system.adapter.chromecast.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.698  - info: host.whome instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.699  - warn: host.whome instance system.adapter.node-red.0 terminated due to SIGTERM
                2021-04-15 17:26:22.699  - info: host.whome instance system.adapter.node-red.0 terminated with code null ()
                2021-04-15 17:26:22.700  - warn: host.whome instance system.adapter.sayit.0 terminated due to SIGTERM
                2021-04-15 17:26:22.700  - info: host.whome instance system.adapter.sayit.0 terminated with code null ()
                2021-04-15 17:26:22.702  - info: host.whome stopInstance system.adapter.javascript.0 killing pid 6399
                2021-04-15 17:26:22.702  - info: host.whome stopInstance system.adapter.mqtt.0 killing pid 6670
                2021-04-15 17:26:22.703  - info: host.whome stopInstance system.adapter.ping.0 killing pid 7321
                2021-04-15 17:26:22.703  - info: host.whome stopInstance system.adapter.sonoff.0 killing pid 8365
                2021-04-15 17:26:22.704  - info: host.whome stopInstance system.adapter.telegram.0 killing pid 8765
                2021-04-15 17:26:22.705  - info: host.whome stopInstance system.adapter.telegram.1 killing pid 9216
                2021-04-15 17:26:22.773  - info: host.whome instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.854  - info: host.whome instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.856  - info: host.whome instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.857  - info: host.whome instance system.adapter.followthesun.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.857  - info: host.whome instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.932  - info: host.whome instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                2021-04-15 17:26:22.933  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.112  - warn: host.whome Cannot get view: Connection is closed.
                2021-04-15 17:26:23.113  - warn: host.whome Cannot get view: Connection is closed.
                2021-04-15 17:26:23.114  - warn: host.whome Cannot get view: Connection is closed.
                2021-04-15 17:26:23.116  - warn: host.whome instance system.adapter.javascript.0 terminated due to SIGTERM
                2021-04-15 17:26:23.117  - info: host.whome instance system.adapter.javascript.0 terminated with code null ()
                2021-04-15 17:26:23.118  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.119  - warn: host.whome instance system.adapter.mqtt.0 terminated due to SIGTERM
                2021-04-15 17:26:23.119  - info: host.whome instance system.adapter.mqtt.0 terminated with code null ()
                2021-04-15 17:26:23.120  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.120  - warn: host.whome instance system.adapter.ping.0 terminated due to SIGTERM
                2021-04-15 17:26:23.120  - info: host.whome instance system.adapter.ping.0 terminated with code null ()
                2021-04-15 17:26:23.121  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.121  - warn: host.whome instance system.adapter.sonoff.0 terminated due to SIGTERM
                2021-04-15 17:26:23.122  - info: host.whome instance system.adapter.sonoff.0 terminated with code null ()
                2021-04-15 17:26:23.122  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.122  - warn: host.whome instance system.adapter.telegram.0 terminated due to SIGTERM
                2021-04-15 17:26:23.123  - info: host.whome instance system.adapter.telegram.0 terminated with code null ()
                2021-04-15 17:26:23.123  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.124  - warn: host.whome instance system.adapter.telegram.1 terminated due to SIGTERM
                2021-04-15 17:26:23.125  - info: host.whome instance system.adapter.telegram.1 terminated with code null ()
                2021-04-15 17:26:23.125  - info: host.whome All instances are stopped.
                2021-04-15 17:26:23.133  - info: host.whome terminated
                2021-04-15 17:26:36.997  - info: host.whome iobroker.js-controller version 3.2.16 js-controller starting
                2021-04-15 17:26:37.003  - info: host.whome Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                2021-04-15 17:26:37.003  - info: host.whome hostname: whome, node: v12.22.1
                2021-04-15 17:26:37.004  - info: host.whome ip addresses: fe80::d8:6431:90b3:eeab
                2021-04-15 17:26:37.645  - info: host.whome connected to Objects and States
                2021-04-15 17:26:37.702  - info: host.whome added notifications configuration of host
                2021-04-15 17:26:38.566  - info: host.whome 25 instances found
                2021-04-15 17:26:38.645  - info: host.whome starting 19 instances
                2021-04-15 17:26:38.832  - info: host.whome instance system.adapter.admin.0 started with pid 918
                2021-04-15 17:26:42.290  - info: admin.0 (918) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:26:42.351  - info: admin.0 (918) requesting all states
                2021-04-15 17:26:42.352  - info: admin.0 (918) requesting all objects
                2021-04-15 17:26:43.158  - info: host.whome instance system.adapter.backitup.0 started with pid 1187
                2021-04-15 17:26:43.384  - info: admin.0 (918) received all objects
                2021-04-15 17:26:43.896  - info: admin.0 (918) http server listening on port 8081
                2021-04-15 17:26:43.897  - info: admin.0 (918) Use link "http://localhost:8081" to configure.
                2021-04-15 17:26:46.673  - info: host.whome instance system.adapter.chromecast.0 started with pid 1485
                2021-04-15 17:26:48.224  - info: chromecast.0 (1485) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:26:48.402  - info: backitup.0 (1187) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:26:48.499  - info: backitup.0 (1187) [iobroker] backup was activated at 03:00 every 1 day(s)
                2021-04-15 17:26:49.002  - info: chromecast.0 (1485) Wohnzimmer - Connected client
                2021-04-15 17:26:50.749  - info: host.whome instance system.adapter.cloud.0 started with pid 1832
                2021-04-15 17:26:52.640  - info: cloud.0 (1832) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:26:52.705  - info: cloud.0 (1832) Connecting with https://iobroker.net:10555 with "uwaizmann@gmail.com_c9f2a840-75ac-11eb-a278-59b6a78c6ee1"
                2021-04-15 17:26:53.017  - info: cloud.0 (1832) Trying to connect as system.user.admin
                2021-04-15 17:26:53.097  - info: cloud.0 (1832) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                2021-04-15 17:26:54.767  - info: host.whome instance system.adapter.discovery.0 started with pid 2156
                2021-04-15 17:26:56.298  - info: discovery.0 (2156) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:20.347  - info: host.whome instance system.adapter.fb-checkpresence.0 started with pid 2474
                2021-04-15 17:27:21.765  - info: fb-checkpresence.0 (2474) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:21.797  - info: fb-checkpresence.0 (2474) start fb-checkpresence: ip-address: "192.168.1.10" - interval devices: 1 Min. - interval members: 60 s
                2021-04-15 17:27:21.990  - info: fb-checkpresence.0 (2474) service Hosts1-X_AVM-DE_GetHostListPath is supported
                2021-04-15 17:27:22.004  - info: fb-checkpresence.0 (2474) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                2021-04-15 17:27:22.017  - info: fb-checkpresence.0 (2474) service Hosts1-GetSpecificHostEntry is supported
                2021-04-15 17:27:22.030  - info: fb-checkpresence.0 (2474) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                2021-04-15 17:27:22.044  - info: fb-checkpresence.0 (2474) service DeviceInfo1-GetSecurityPort is supported
                2021-04-15 17:27:22.061  - info: fb-checkpresence.0 (2474) service WANPPPConnection1-GetInfo is supported
                2021-04-15 17:27:22.078  - info: fb-checkpresence.0 (2474) service WLANConfiguration3-SetEnable is supported
                2021-04-15 17:27:22.093  - info: fb-checkpresence.0 (2474) service WLANConfiguration3-GetInfo is supported
                2021-04-15 17:27:22.105  - info: fb-checkpresence.0 (2474) service DeviceInfo1-GetInfo is supported
                2021-04-15 17:27:22.115  - info: fb-checkpresence.0 (2474) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                2021-04-15 17:27:22.126  - info: fb-checkpresence.0 (2474) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                2021-04-15 17:27:22.137  - info: fb-checkpresence.0 (2474) service DeviceConfig1-Reboot is supported
                2021-04-15 17:27:22.326  - info: fb-checkpresence.0 (2474) createGlobalObjects finished successfully
                2021-04-15 17:27:22.456  - info: fb-checkpresence.0 (2474) History function for Uwe disabled. Please select a history adapter in the configuration dialog!
                2021-04-15 17:27:22.716  - info: fb-checkpresence.0 (2474) History function for Elke disabled. Please select a history adapter in the configuration dialog!
                2021-04-15 17:27:22.757  - info: fb-checkpresence.0 (2474) History function for Elke J3 disabled. Please select a history adapter in the configuration dialog!
                2021-04-15 17:27:22.758  - info: fb-checkpresence.0 (2474) createMemberObjects finished successfully
                2021-04-15 17:27:24.363  - info: host.whome instance system.adapter.followthesun.0 started with pid 2817
                2021-04-15 17:27:26.100  - info: followthesun.0 (2817) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.followthesun, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:26.159  - info: followthesun.0 (2817) Sun position calculation will be done every 120 seconds
                2021-04-15 17:27:26.165  - info: followthesun.0 (2817) Daily sun parameter calculation scheduled for 00:00:35
                2021-04-15 17:27:28.324  - info: host.whome instance system.adapter.info.0 started with pid 3154
                2021-04-15 17:27:31.397  - info: info.0 (3154) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:33.269  - info: host.whome instance system.adapter.javascript.0 started with pid 3708
                2021-04-15 17:27:36.374  - info: host.whome instance system.adapter.mqtt.0 started with pid 4221
                2021-04-15 17:27:38.398  - info: javascript.0 (3708) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:38.610  - info: javascript.0 (3708) requesting all states
                2021-04-15 17:27:38.611  - info: javascript.0 (3708) requesting all objects
                2021-04-15 17:27:39.429  - info: javascript.0 (3708) received all objects
                2021-04-15 17:27:39.486  - info: javascript.0 (3708) received all states
                2021-04-15 17:27:39.827  - info: javascript.0 (3708) Start javascript script.js.common.Buero.heizung_buero_boden
                2021-04-15 17:27:39.903  - info: javascript.0 (3708) script.js.common.Buero.heizung_buero_boden: registered 1 subscription and 0 schedules
                2021-04-15 17:27:39.904  - info: javascript.0 (3708) Start javascript script.js.common.Heizung.Auftau
                2021-04-15 17:27:39.922  - info: javascript.0 (3708) script.js.common.Heizung.Auftau: registered 1 subscription and 1 schedule
                2021-04-15 17:27:39.923  - info: javascript.0 (3708) Start javascript script.js.common.Heizung.Heizstab
                2021-04-15 17:27:39.931  - info: javascript.0 (3708) script.js.common.Heizung.Heizstab: registered 1 subscription and 1 schedule
                2021-04-15 17:27:39.932  - info: javascript.0 (3708) Start javascript script.js.common.Rolladen.Rolladen
                2021-04-15 17:27:39.937  - info: javascript.0 (3708) script.js.common.Rolladen.Rolladen: registered 1 subscription and 0 schedules
                2021-04-15 17:27:39.938  - info: javascript.0 (3708) Start javascript script.js.common.Rolladen.RolladenAutomatik
                2021-04-15 17:27:39.948  - info: javascript.0 (3708) script.js.common.Rolladen.RolladenAutomatik: registered 4 subscriptions and 2 schedules
                2021-04-15 17:27:39.949  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Anwesenheit
                2021-04-15 17:27:39.954  - info: javascript.0 (3708) script.js.common.Scripte.Anwesenheit: registered 1 subscription and 0 schedules
                2021-04-15 17:27:39.955  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Flur
                2021-04-15 17:27:39.960  - info: javascript.0 (3708) script.js.common.Scripte.Flur: registered 1 subscription and 0 schedules
                2021-04-15 17:27:39.961  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Gute-Nacht
                2021-04-15 17:27:39.967  - info: javascript.0 (3708) script.js.common.Scripte.Gute-Nacht: registered 2 subscriptions and 0 schedules
                2021-04-15 17:27:39.967  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Tag
                2021-04-15 17:27:39.975  - info: javascript.0 (3708) script.js.common.Scripte.Tag: registered 0 subscriptions and 2 schedules
                2021-04-15 17:27:39.976  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Terasse_LED_stripe
                2021-04-15 17:27:39.982  - info: javascript.0 (3708) script.js.common.Scripte.Terasse_LED_stripe: registered 1 subscription and 1 schedule
                2021-04-15 17:27:39.983  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.wama2
                2021-04-15 17:27:39.988  - info: javascript.0 (3708) script.js.common.Scripte.wama2: registered 1 subscription and 0 schedules
                2021-04-15 17:27:40.000  - info: javascript.0 (3708) Start javascript script.js.common.Temperaturen.aussen
                2021-04-15 17:27:40.007  - info: javascript.0 (3708) script.js.common.Temperaturen.aussen: registered 2 subscriptions and 0 schedules
                2021-04-15 17:27:40.008  - info: javascript.0 (3708) Start javascript script.js.common.Temperaturen.temp2
                2021-04-15 17:27:40.015  - info: javascript.0 (3708) script.js.common.Temperaturen.temp2: registered 3 subscriptions and 0 schedules
                2021-04-15 17:27:40.016  - info: javascript.0 (3708) Start javascript script.js.common.Wohnzimmer.Wohnzimmer
                2021-04-15 17:27:40.023  - info: javascript.0 (3708) script.js.common.Wohnzimmer.Wohnzimmer: registered 1 subscription and 0 schedules
                2021-04-15 17:27:40.024  - info: javascript.0 (3708) Start javascript script.js.rebootPi
                2021-04-15 17:27:40.030  - info: javascript.0 (3708) script.js.rebootPi: registered 1 subscription and 0 schedules
                2021-04-15 17:27:40.333  - info: host.whome instance system.adapter.node-red.0 started with pid 4516
                2021-04-15 17:27:41.735  - info: node-red.0 (4516) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:42.172  - info: node-red.0 (4516) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                2021-04-15 17:27:44.199  - warn: node-red.0 (4516) 15 Apr 17:27:44 - [warn] Die Verwendung von editorTheme.palette.editable ist abgekündigt. Stattdessen externalModules.palette.allowInstall verwenden.
                2021-04-15 17:27:44.340  - info: host.whome instance system.adapter.ping.0 started with pid 4870
                2021-04-15 17:27:46.139  - info: ping.0 (4870) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:48.346  - info: host.whome instance system.adapter.sayit.0 started with pid 5200
                2021-04-15 17:27:49.310  - warn: node-red.0 (4516) 15 Apr 17:27:49 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                2021-04-15 17:27:50.406  - info: sayit.0 (5200) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:50.441  - info: sayit.0 (5200) Upload announce mp3 files
                2021-04-15 17:27:50.545  - info: sayit.0 (5200) All files uploaded
                2021-04-15 17:27:52.332  - info: host.whome instance system.adapter.shelly.0 started with pid 5516
                2021-04-15 17:27:54.704  - info: shelly.0 (5516) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:54.739  - info: shelly.0 (5516) Starting Adapter shelly.0 in version 4.0.7
                2021-04-15 17:27:54.778  - info: shelly.0 (5516) Starting Shelly adapter in CoAP modus.
                2021-04-15 17:27:54.868  - info: shelly.0 (5516) Listening for Shelly packets in the network
                2021-04-15 17:27:56.341  - info: host.whome instance system.adapter.sonoff.0 started with pid 5843
                2021-04-15 17:27:57.802  - info: sonoff.0 (5843) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:27:57.896  - info: sonoff.0 (5843) Starting MQTT  server on port 1884
                2021-04-15 17:27:58.380  - info: shelly.0 (5516) Shelly device 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:27:59.507  - info: shelly.0 (5516) Shelly device 192.168.1.128 (shelly1 / shelly1-8CAAB5614D9F / SHSW-1#8CAAB5614D9F#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:27:59.909  - info: shelly.0 (5516) Shelly device 192.168.1.131 (shellydimmer2 / shellydimmer2-40F520015E03 / SHDM-2#40F520015E03#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:00.338  - info: host.whome instance system.adapter.telegram.0 started with pid 6182
                2021-04-15 17:28:01.996  - info: shelly.0 (5516) Shelly device 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:02.785  - info: shelly.0 (5516) Shelly device 192.168.1.121 (shellyswitch25 / shellyswitch25-84CCA8B09E95 / SHSW-25#84CCA8B09E95#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:03.352  - info: telegram.0 (6182) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:28:03.692  - info: shelly.0 (5516) Shelly device 192.168.1.126 (shelly1 / shelly1-483FDA91AF1A / SHSW-1#483FDA91AF1A#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:04.313  - info: shelly.0 (5516) Shelly device 192.168.1.127 (shelly1 / shelly1-F4CFA2E46301 / SHSW-1#F4CFA2E46301#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:04.340  - info: host.whome instance system.adapter.telegram.1 started with pid 6497
                2021-04-15 17:28:05.646  - info: shelly.0 (5516) Shelly device 192.168.1.123 (shellyswitch25 / shellyswitch25-84CCA8B0CC8F / SHSW-25#84CCA8B0CC8F#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:06.873  - info: shelly.0 (5516) Shelly device 192.168.1.122 (shellyswitch25 / shellyswitch25-483FDA8DDD51 / SHSW-25#483FDA8DDD51#1) with CoAP connected! Polltime set to 5 sec.
                2021-04-15 17:28:06.904  - info: sonoff.0 (5843) Client [Buero_Temp] connected with secret 1618500486885_4558
                2021-04-15 17:28:07.082  - info: sonoff.0 (5843) Client [wama] connected with secret 1618500487080_7114
                2021-04-15 17:28:07.242  - info: sonoff.0 (5843) Client [Temp2-DS18B20] connected with secret 1618500487219_5502
                2021-04-15 17:28:07.317  - info: telegram.1 (6497) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:28:07.622  - info: sonoff.0 (5843) Client [Terrasse_lux_led] connected with secret 1618500487620_9651
                2021-04-15 17:28:07.709  - info: sonoff.0 (5843) Client [WekstattTemp] connected with secret 1618500487707_5656
                2021-04-15 17:28:07.753  - info: sonoff.0 (5843) Client [Schalter-TV] connected with secret 1618500487749_4349
                2021-04-15 17:28:07.756  - info: sonoff.0 (5843) Client [Steckdose12] connected with secret 1618500487751_3495
                2021-04-15 17:28:10.082  - info: vis.0 (6836) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:28:10.331  - info: vis.0 (6836) vis license is OK.
                2021-04-15 17:28:11.354  - info: vis.0 (6836) Terminated (NO_ERROR): Without reason
                2021-04-15 17:28:11.927  - info: host.whome instance system.adapter.vis.0 terminated while should be started once
                2021-04-15 17:28:12.370  - info: host.whome instance system.adapter.web.0 started with pid 7199
                2021-04-15 17:28:14.332  - info: web.0 (7199) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
                2021-04-15 17:28:14.664  - info: web.0 (7199) socket.io server listening on port 8082
                2021-04-15 17:28:14.674  - info: web.0 (7199) simpleAPI server listening on port 8082
                2021-04-15 17:28:14.675  - info: web.0 (7199) Allow states only when user is owner: false
                2021-04-15 17:28:14.684  - info: web.0 (7199) http server listening on port 8082
                2021-04-15 17:28:14.698  - info: cloud.0 (1832) Trying to connect as system.user.admin
                2021-04-15 17:28:14.823  - info: cloud.0 (1832) Connection changed: connect
                • Uwe WaizmannU Uwe Waizmann
                  gefunden /opt/iobroker/log
                  2021-04-15 00:00:28.074  - info: followthesun.0 (26948) Cronjob 'Sun parameter calculation' starts
                  2021-04-15 00:05:38.015  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 00:05:38.050  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 00:46:49.140  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 00:46:49.143  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 00:55:48.747  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 00:55:48.748  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 00:56:18.774  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 00:56:18.776  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 01:06:58.958  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 01:06:58.960  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 01:07:28.979  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 01:07:28.983  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 01:37:09.452  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 01:37:09.457  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 01:37:40.471  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 01:37:40.472  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 01:47:09.629  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 01:47:09.631  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 01:47:51.708  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 01:47:51.709  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 02:18:10.222  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 02:18:10.223  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 02:18:50.224  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 02:18:50.225  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 02:38:00.591  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 02:38:00.592  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 02:38:30.612  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 02:38:30.613  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 02:52:10.866  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 02:52:10.867  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 02:52:40.860  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 02:52:40.861  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:00:29.309  - warn: telegram.0 (12415) 1 of 1 recipients are unknown!
                  2021-04-15 03:02:20.995  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:02:20.996  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:02:51.526  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:02:51.528  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:12:41.127  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:12:41.128  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:13:11.135  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:13:11.136  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:23:51.203  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:23:51.204  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:24:22.260  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:24:22.262  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:37:11.361  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:37:11.362  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:37:41.360  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:37:41.365  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 03:52:13.670  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: Device timeout
                      at fn.ontimeout (/opt/iobroker/node_modules/castv2-client/lib/senders/platform.js:56:26)
                      at Object.onceWrapper (events.js:420:28)
                      at fn.emit (events.js:314:20)
                      at Timeout.ontimeout [as _onTimeout] (/opt/iobroker/node_modules/castv2-client/lib/controllers/heartbeat.js:44:10)
                      at listOnTimeout (internal/timers.js:554:17)
                      at processTimers (internal/timers.js:497:7)
                  2021-04-15 03:52:13.689  - info: chromecast.0 (12982) Wohnzimmer - client disconnected
                  2021-04-15 03:52:16.808  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                      at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16)
                  2021-04-15 03:52:17.817  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                  2021-04-15 03:52:19.824  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                  2021-04-15 03:52:22.830  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: connect ECONNREFUSED 192.168.1.25:8009
                  2021-04-15 03:52:26.844  - warn: chromecast.0 (12982) Wohnzimmer - Client error: Error: read ECONNRESET
                      at TLSWrap.onStreamRead (internal/stream_base_commons.js:209:20)
                  2021-04-15 03:52:28.449  - info: chromecast.0 (12982) Received keep alive for disconnected device Wohnzimmer
                  2021-04-15 03:52:28.451  - info: chromecast.0 (12982) Reconnecting Wohnzimmer to 192.168.1.25:8009
                  2021-04-15 03:52:30.261  - info: chromecast.0 (12982) Wohnzimmer - Connected client
                  2021-04-15 03:57:31.646  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 03:57:31.648  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 04:39:23.894  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 04:39:23.895  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 04:48:22.475  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 04:48:22.477  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 04:48:52.510  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 04:48:52.513  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 05:02:12.758  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 05:02:12.769  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 05:02:42.749  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 05:02:42.751  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 05:57:05.124  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 05:57:05.126  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 05:57:33.556  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 05:57:33.557  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 06:07:13.724  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 06:07:13.724  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 06:50:55.885  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 06:50:55.887  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:00:04.445  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:00:04.447  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:00:34.460  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:00:34.461  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:10:14.597  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:10:14.598  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:10:54.623  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:10:54.624  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:20:34.782  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:20:34.783  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:21:04.808  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:21:04.809  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:31:35.464  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:31:35.465  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:32:04.954  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:32:04.955  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:42:56.183  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:42:56.184  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:43:26.712  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:43:26.715  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:52:35.796  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:52:35.796  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:53:05.848  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 07:53:05.849  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 07:55:11.765  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                  2021-04-15 07:55:11.995  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                  2021-04-15 07:55:14.717  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                  2021-04-15 07:57:45.852  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                  2021-04-15 07:58:20.248  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                  2021-04-15 07:58:29.915  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                  2021-04-15 07:59:24.967  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                  2021-04-15 08:00:50.418  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                  2021-04-15 08:02:45.426  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:02:45.426  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:03:25.478  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:03:25.479  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:05:19.580  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                  2021-04-15 08:05:23.881  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.30
                  2021-04-15 08:07:49.732  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                  2021-04-15 08:11:55.333  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                  2021-04-15 08:13:05.633  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:13:05.634  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:13:35.657  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:13:35.658  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:25:45.906  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:25:45.907  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:26:15.890  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:26:15.891  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:26:26.852  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                  2021-04-15 08:26:28.228  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                  2021-04-15 08:26:34.544  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                  2021-04-15 08:29:52.933  - info: fb-checkpresence.0 (26624) newActive Elke J3 false
                  2021-04-15 08:35:46.050  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:35:46.056  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:36:16.046  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:36:16.047  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:46:26.150  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:46:26.151  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:46:56.175  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:46:56.177  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:56:16.254  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:56:16.261  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 08:56:57.304  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 08:56:57.305  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 09:06:37.392  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 09:06:37.396  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 09:07:06.352  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 09:07:06.353  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 10:08:57.227  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 10:08:57.229  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 10:31:23.250  - info: fb-checkpresence.0 (26624) newActive Uwe false
                  2021-04-15 10:31:23.283  - warn: sonoff.0 (29561) Client "Steckdose10" not connected
                  2021-04-15 10:57:55.907  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                  2021-04-15 11:10:37.886  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 11:10:37.887  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 12:17:25.886  - info: fb-checkpresence.0 (26624) newActive Elke J3 true
                  2021-04-15 12:17:25.949  - warn: sonoff.0 (29561) Client "Steckdose10" not connected
                  2021-04-15 12:48:18.590  - info: fb-checkpresence.0 (26624) newActive Uwe true
                  2021-04-15 12:50:24.286  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                  2021-04-15 12:50:25.217  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                  2021-04-15 12:50:31.202  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                  2021-04-15 13:35:59.700  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                  2021-04-15 13:47:28.462  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                  2021-04-15 13:47:28.788  - info: web.0 (30538) <==Disconnect system.user.admin from ::ffff:192.168.1.26 vis.0
                  2021-04-15 13:47:30.865  - info: web.0 (30538) ==>Connected system.user.admin from ::ffff:192.168.1.26
                  2021-04-15 15:33:31.443  - info: javascript.0 (27741) script.js.common.Heizung.Auftau: Auftau Aus
                  2021-04-15 15:33:31.451  - info: javascript.0 (27741) script.js.common.Heizung.Heizstab: HeizStab AUS
                  2021-04-15 16:17:12.004  - info: host.whome iobroker.js-controller version 3.2.16 js-controller starting
                  2021-04-15 16:17:12.009  - info: host.whome Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                  2021-04-15 16:17:12.010  - info: host.whome hostname: whome, node: v12.22.1
                  2021-04-15 16:17:12.010  - info: host.whome ip addresses: fe80::d8:6431:90b3:eeab
                  2021-04-15 16:17:12.651  - error: host.whome-Server Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                  2021-04-15 16:17:12.807  - info: host.whome connected to Objects and States
                  2021-04-15 16:17:12.873  - info: host.whome added notifications configuration of host
                  2021-04-15 16:17:13.618  - info: host.whome 25 instances found
                  2021-04-15 16:17:13.677  - info: host.whome starting 19 instances
                  2021-04-15 16:17:13.783  - info: host.whome instance system.adapter.admin.0 started with pid 788
                  2021-04-15 16:17:15.578  - error: admin.0 (788) admin.0 already running
                  2021-04-15 16:17:15.582  - warn: admin.0 (788) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 16:17:16.190  - error: host.whome instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 16:17:16.191  - info: host.whome Restart adapter system.adapter.admin.0 because enabled
                  2021-04-15 16:17:17.698  - info: host.whome instance system.adapter.backitup.0 started with pid 1016
                  2021-04-15 16:17:21.708  - info: host.whome instance system.adapter.chromecast.0 started with pid 1322
                  2021-04-15 16:17:22.448  - error: backitup.0 (1016) backitup.0 already running
                  2021-04-15 16:17:22.451  - warn: backitup.0 (1016) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 16:17:23.057  - error: host.whome instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 16:17:23.058  - info: host.whome Restart adapter system.adapter.backitup.0 because enabled
                  2021-04-15 16:17:23.178  - error: chromecast.0 (1322) chromecast.0 already running
                  2021-04-15 16:17:23.181  - warn: chromecast.0 (1322) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 16:17:23.769  - error: host.whome Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                  2021-04-15 16:17:23.769  - error: host.whome Caught by controller[0]:     at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
                  2021-04-15 16:17:23.770  - error: host.whome Caught by controller[0]:     at Adapter.emit (events.js:314:20)
                  2021-04-15 16:17:23.770  - error: host.whome Caught by controller[0]:     at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                  2021-04-15 16:17:23.771  - error: host.whome Caught by controller[0]:     at Object.onceWrapper (events.js:421:26)
                  2021-04-15 16:17:23.771  - error: host.whome Caught by controller[0]:     at process.emit (events.js:314:20)
                  2021-04-15 16:17:23.771  - error: host.whome Caught by controller[0]:     at process.exit (internal/process/per_thread.js:168:15)
                  2021-04-15 16:17:23.772  - error: host.whome Caught by controller[0]:     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                  2021-04-15 16:17:23.772  - error: host.whome Caught by controller[0]:     at processTicksAndRejections (internal/process/task_queues.js:97:5)
                  2021-04-15 16:17:23.773  - error: host.whome instance system.adapter.chromecast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 16:17:23.774  - info: host.whome Restart adapter system.adapter.chromecast.0 because enabled
                  2021-04-15 16:17:25.765  - info: host.whome instance system.adapter.cloud.0 started with pid 1640
                  2021-04-15 16:17:27.304  - error: cloud.0 (1640) cloud.0 already running
                  2021-04-15 16:17:27.307  - warn: cloud.0 (1640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 16:17:27.922  - error: host.whome instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 16:17:27.923  - info: host.whome Restart adapter system.adapter.cloud.0 because enabled
                  2021-04-15 16:17:29.738  - info: host.whome instance system.adapter.discovery.0 started with pid 1939
                  2021-04-15 16:17:30.980  - error: discovery.0 (1939) discovery.0 already running
                  2021-04-15 16:17:30.984  - warn: discovery.0 (1939) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 16:17:31.614  - error: host.whome instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 16:17:31.615  - info: host.whome Restart adapter system.adapter.discovery.0 because enabled
                  2021-04-15 16:17:33.769  - info: host.whome instance system.adapter.fb-checkpresence.0 started with pid 2286
                  2021-04-15 16:17:35.106  - error: fb-checkpresence.0 (2286) fb-checkpresence.0 already running
                  2021-04-15 16:17:35.108  - warn: fb-checkpresence.0 (2286) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 16:17:35.683  - error: host.whome instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 16:17:35.684  - info: host.whome Restart adapter system.adapter.fb-checkpresence.0 because enabled
                  2021-04-15 17:05:01.580  - info: host.whome instance system.adapter.followthesun.0 started with pid 2671
                  2021-04-15 17:05:02.724  - error: followthesun.0 (2671) followthesun.0 already running
                  2021-04-15 17:05:02.727  - warn: followthesun.0 (2671) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:03.302  - error: host.whome instance system.adapter.followthesun.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:03.303  - info: host.whome Restart adapter system.adapter.followthesun.0 because enabled
                  2021-04-15 17:05:05.582  - info: host.whome instance system.adapter.info.0 started with pid 2970
                  2021-04-15 17:05:07.751  - error: info.0 (2970) info.0 already running
                  2021-04-15 17:05:07.754  - warn: info.0 (2970) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:08.328  - error: host.whome instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:08.329  - info: host.whome Restart adapter system.adapter.info.0 because enabled
                  2021-04-15 17:05:09.596  - info: host.whome instance system.adapter.javascript.0 started with pid 3305
                  2021-04-15 17:05:10.010  - info: host.whome instance system.adapter.admin.0 started with pid 3348
                  2021-04-15 17:05:12.121  - info: admin.0 (3348) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:12.200  - info: admin.0 (3348) requesting all states
                  2021-04-15 17:05:12.201  - info: admin.0 (3348) requesting all objects
                  2021-04-15 17:05:13.009  - error: javascript.0 (3305) javascript.0 already running
                  2021-04-15 17:05:13.013  - warn: javascript.0 (3305) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:13.117  - info: admin.0 (3348) received all objects
                  2021-04-15 17:05:13.484  - info: admin.0 (3348) http server listening on port 8081
                  2021-04-15 17:05:13.558  - info: host.whome instance system.adapter.mqtt.0 started with pid 3643
                  2021-04-15 17:05:13.653  - error: host.whome instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:13.654  - info: host.whome Restart adapter system.adapter.javascript.0 because enabled
                  2021-04-15 17:05:13.485  - info: admin.0 (3348) Use link "http://localhost:8081" to configure.
                  2021-04-15 17:05:14.720  - error: mqtt.0 (3643) mqtt.0 already running
                  2021-04-15 17:05:15.295  - error: host.whome instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:15.296  - info: host.whome Restart adapter system.adapter.mqtt.0 because enabled
                  2021-04-15 17:05:16.890  - info: host.whome instance system.adapter.backitup.0 started with pid 3906
                  2021-04-15 17:05:17.567  - info: host.whome instance system.adapter.node-red.0 started with pid 3973
                  2021-04-15 17:05:17.597  - info: host.whome instance system.adapter.chromecast.0 started with pid 3979
                  2021-04-15 17:05:19.013  - error: node-red.0 (3973) node-red.0 already running
                  2021-04-15 17:05:19.016  - warn: node-red.0 (3973) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:19.162  - info: chromecast.0 (3979) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:19.614  - error: host.whome instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:19.615  - info: host.whome Restart adapter system.adapter.node-red.0 because enabled
                  2021-04-15 17:05:19.911  - info: chromecast.0 (3979) Wohnzimmer - Connected client
                  2021-04-15 17:05:20.875  - info: backitup.0 (3906) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:20.953  - info: backitup.0 (3906) [iobroker] backup was activated at 03:00 every 1 day(s)
                  2021-04-15 17:05:21.559  - info: host.whome instance system.adapter.ping.0 started with pid 4301
                  2021-04-15 17:05:21.744  - info: host.whome instance system.adapter.cloud.0 started with pid 4326
                  2021-04-15 17:05:22.724  - error: ping.0 (4301) ping.0 already running
                  2021-04-15 17:05:22.727  - warn: ping.0 (4301) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:23.325  - error: host.whome instance system.adapter.ping.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:23.326  - info: host.whome Restart adapter system.adapter.ping.0 because enabled
                  2021-04-15 17:05:23.721  - info: cloud.0 (4326) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:23.803  - info: cloud.0 (4326) Connecting with https://iobroker.net:10555 with "uwaizmann@gmail.com_c9f2a840-75ac-11eb-a278-59b6a78c6ee1"
                  2021-04-15 17:05:24.164  - info: cloud.0 (4326) Trying to connect as system.user.admin
                  2021-04-15 17:05:25.435  - info: host.whome instance system.adapter.discovery.0 started with pid 4621
                  2021-04-15 17:05:25.608  - info: host.whome instance system.adapter.sayit.0 started with pid 4640
                  2021-04-15 17:05:26.855  - error: sayit.0 (4640) sayit.0 already running
                  2021-04-15 17:05:26.859  - warn: sayit.0 (4640) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:27.205  - info: discovery.0 (4621) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:27.435  - error: host.whome instance system.adapter.sayit.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:27.436  - info: host.whome Restart adapter system.adapter.sayit.0 because enabled
                  2021-04-15 17:05:29.129  - error: cloud.0 (4326) Cloud says: timeout
                  2021-04-15 17:05:29.520  - info: host.whome instance system.adapter.fb-checkpresence.0 started with pid 4948
                  2021-04-15 17:05:29.630  - info: host.whome instance system.adapter.shelly.0 started with pid 4966
                  2021-04-15 17:05:30.139  - info: cloud.0 (4326) Connection changed: io server disconnect
                  2021-04-15 17:05:31.141  - info: host.whome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2021-04-15 17:05:32.940  - error: shelly.0 (4966) shelly.0 already running
                  2021-04-15 17:05:32.944  - warn: shelly.0 (4966) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:32.989  - info: fb-checkpresence.0 (4948) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:33.030  - info: fb-checkpresence.0 (4948) start fb-checkpresence: ip-address: "192.168.1.10" - interval devices: 1 Min. - interval members: 60 s
                  2021-04-15 17:05:33.211  - info: fb-checkpresence.0 (4948) service Hosts1-X_AVM-DE_GetHostListPath is supported
                  2021-04-15 17:05:33.235  - info: fb-checkpresence.0 (4948) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                  2021-04-15 17:05:33.256  - info: fb-checkpresence.0 (4948) service Hosts1-GetSpecificHostEntry is supported
                  2021-04-15 17:05:33.272  - info: fb-checkpresence.0 (4948) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                  2021-04-15 17:05:33.288  - info: fb-checkpresence.0 (4948) service DeviceInfo1-GetSecurityPort is supported
                  2021-04-15 17:05:33.308  - info: fb-checkpresence.0 (4948) service WANPPPConnection1-GetInfo is supported
                  2021-04-15 17:05:33.330  - info: fb-checkpresence.0 (4948) service WLANConfiguration3-SetEnable is supported
                  2021-04-15 17:05:33.330  - info: host.whome instance system.adapter.followthesun.0 started with pid 5269
                  2021-04-15 17:05:33.350  - info: fb-checkpresence.0 (4948) service WLANConfiguration3-GetInfo is supported
                  2021-04-15 17:05:33.366  - info: fb-checkpresence.0 (4948) service DeviceInfo1-GetInfo is supported
                  2021-04-15 17:05:33.387  - info: fb-checkpresence.0 (4948) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                  2021-04-15 17:05:33.404  - info: fb-checkpresence.0 (4948) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                  2021-04-15 17:05:33.427  - info: fb-checkpresence.0 (4948) service DeviceConfig1-Reboot is supported
                  2021-04-15 17:05:33.570  - error: host.whome instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:33.571  - info: host.whome Restart adapter system.adapter.shelly.0 because enabled
                  2021-04-15 17:05:33.712  - info: host.whome instance system.adapter.sonoff.0 started with pid 5300
                  2021-04-15 17:05:33.717  - info: fb-checkpresence.0 (4948) createGlobalObjects finished successfully
                  2021-04-15 17:05:33.877  - info: fb-checkpresence.0 (4948) History function for Uwe disabled. Please select a history adapter in the configuration dialog!
                  2021-04-15 17:05:33.978  - info: fb-checkpresence.0 (4948) History function for Elke disabled. Please select a history adapter in the configuration dialog!
                  2021-04-15 17:05:34.103  - info: fb-checkpresence.0 (4948) History function for Elke J3 disabled. Please select a history adapter in the configuration dialog!
                  2021-04-15 17:05:34.104  - info: fb-checkpresence.0 (4948) createMemberObjects finished successfully
                  2021-04-15 17:05:35.132  - error: sonoff.0 (5300) sonoff.0 already running
                  2021-04-15 17:05:35.135  - warn: sonoff.0 (5300) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:35.164  - info: followthesun.0 (5269) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.followthesun, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:35.200  - info: followthesun.0 (5269) Sun position calculation will be done every 120 seconds
                  2021-04-15 17:05:35.204  - info: followthesun.0 (5269) Daily sun parameter calculation scheduled for 00:00:23
                  2021-04-15 17:05:35.824  - error: host.whome instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:35.824  - info: host.whome Restart adapter system.adapter.sonoff.0 because enabled
                  2021-04-15 17:05:37.684  - info: host.whome instance system.adapter.telegram.0 started with pid 5621
                  2021-04-15 17:05:38.359  - info: host.whome instance system.adapter.info.0 started with pid 5688
                  2021-04-15 17:05:39.908  - error: telegram.0 (5621) telegram.0 already running
                  2021-04-15 17:05:39.912  - warn: telegram.0 (5621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:40.493  - error: host.whome instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:40.493  - info: host.whome Restart adapter system.adapter.telegram.0 because enabled
                  2021-04-15 17:05:41.194  - info: info.0 (5688) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:41.615  - info: host.whome instance system.adapter.telegram.1 started with pid 6027
                  2021-04-15 17:05:43.741  - info: host.whome instance system.adapter.javascript.0 started with pid 6399
                  2021-04-15 17:05:45.103  - error: telegram.1 (6027) telegram.1 already running
                  2021-04-15 17:05:45.109  - warn: telegram.1 (6027) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:45.328  - info: host.whome instance system.adapter.mqtt.0 started with pid 6670
                  2021-04-15 17:05:46.069  - error: host.whome instance system.adapter.telegram.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:46.071  - info: host.whome Restart adapter system.adapter.telegram.1 because enabled
                  2021-04-15 17:05:48.273  - info: vis.0 (6713) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:48.521  - info: vis.0 (6713) vis license is OK.
                  2021-04-15 17:05:48.822  - info: javascript.0 (6399) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:49.055  - info: javascript.0 (6399) requesting all states
                  2021-04-15 17:05:49.056  - info: javascript.0 (6399) requesting all objects
                  2021-04-15 17:05:49.653  - info: host.whome instance system.adapter.web.0 started with pid 7008
                  2021-04-15 17:05:49.682  - info: host.whome instance system.adapter.node-red.0 started with pid 7014
                  2021-04-15 17:05:49.704  - info: vis.0 (6713) Terminated (NO_ERROR): Without reason
                  2021-04-15 17:05:49.827  - info: javascript.0 (6399) received all objects
                  2021-04-15 17:05:49.886  - info: javascript.0 (6399) received all states
                  2021-04-15 17:05:50.024  - info: javascript.0 (6399) Start javascript script.js.common.Buero.heizung_buero_boden
                  2021-04-15 17:05:50.106  - info: javascript.0 (6399) script.js.common.Buero.heizung_buero_boden: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:50.107  - info: javascript.0 (6399) Start javascript script.js.common.Heizung.Auftau
                  2021-04-15 17:05:50.143  - info: javascript.0 (6399) script.js.common.Heizung.Auftau: registered 1 subscription and 1 schedule
                  2021-04-15 17:05:50.144  - info: javascript.0 (6399) Start javascript script.js.common.Heizung.Heizstab
                  2021-04-15 17:05:50.154  - info: javascript.0 (6399) script.js.common.Heizung.Heizstab: registered 1 subscription and 1 schedule
                  2021-04-15 17:05:50.305  - info: host.whome instance system.adapter.vis.0 terminated while should be started once
                  2021-04-15 17:05:50.265  - info: javascript.0 (6399) Start javascript script.js.common.Rolladen.Rolladen
                  2021-04-15 17:05:50.278  - info: javascript.0 (6399) script.js.common.Rolladen.Rolladen: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:50.279  - info: javascript.0 (6399) Start javascript script.js.common.Rolladen.RolladenAutomatik
                  2021-04-15 17:05:50.296  - info: javascript.0 (6399) script.js.common.Rolladen.RolladenAutomatik: registered 4 subscriptions and 2 schedules
                  2021-04-15 17:05:50.297  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Anwesenheit
                  2021-04-15 17:05:50.304  - info: javascript.0 (6399) script.js.common.Scripte.Anwesenheit: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:50.305  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Flur
                  2021-04-15 17:05:50.311  - info: javascript.0 (6399) script.js.common.Scripte.Flur: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:50.312  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Gute-Nacht
                  2021-04-15 17:05:50.318  - info: javascript.0 (6399) script.js.common.Scripte.Gute-Nacht: registered 2 subscriptions and 0 schedules
                  2021-04-15 17:05:50.319  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Tag
                  2021-04-15 17:05:50.327  - info: javascript.0 (6399) script.js.common.Scripte.Tag: registered 0 subscriptions and 2 schedules
                  2021-04-15 17:05:50.328  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.Terasse_LED_stripe
                  2021-04-15 17:05:50.335  - info: javascript.0 (6399) script.js.common.Scripte.Terasse_LED_stripe: registered 1 subscription and 1 schedule
                  2021-04-15 17:05:50.336  - info: javascript.0 (6399) Start javascript script.js.common.Scripte.wama2
                  2021-04-15 17:05:50.342  - info: javascript.0 (6399) script.js.common.Scripte.wama2: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:50.343  - info: javascript.0 (6399) Start javascript script.js.common.Temperaturen.aussen
                  2021-04-15 17:05:50.349  - info: javascript.0 (6399) script.js.common.Temperaturen.aussen: registered 2 subscriptions and 0 schedules
                  2021-04-15 17:05:50.350  - info: javascript.0 (6399) Start javascript script.js.common.Temperaturen.temp2
                  2021-04-15 17:05:50.357  - info: javascript.0 (6399) script.js.common.Temperaturen.temp2: registered 3 subscriptions and 0 schedules
                  2021-04-15 17:05:50.359  - info: javascript.0 (6399) Start javascript script.js.common.Wohnzimmer.Wohnzimmer
                  2021-04-15 17:05:50.365  - info: javascript.0 (6399) script.js.common.Wohnzimmer.Wohnzimmer: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:50.366  - info: javascript.0 (6399) Start javascript script.js.rebootPi
                  2021-04-15 17:05:50.371  - info: javascript.0 (6399) script.js.rebootPi: registered 1 subscription and 0 schedules
                  2021-04-15 17:05:51.316  - info: node-red.0 (7014) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:51.421  - error: web.0 (7008) web.0 already running
                  2021-04-15 17:05:51.424  - warn: web.0 (7008) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                  2021-04-15 17:05:51.778  - info: node-red.0 (7014) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  2021-04-15 17:05:51.992  - error: host.whome instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                  2021-04-15 17:05:51.992  - info: host.whome Restart adapter system.adapter.web.0 because enabled
                  2021-04-15 17:05:53.362  - info: host.whome instance system.adapter.ping.0 started with pid 7321
                  2021-04-15 17:05:53.850  - warn: node-red.0 (7014) 15 Apr 17:05:53 - [warn] Die Verwendung von editorTheme.palette.editable ist abgekündigt. Stattdessen externalModules.palette.allowInstall verwenden.
                  2021-04-15 17:05:55.084  - info: ping.0 (7321) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:57.481  - info: host.whome instance system.adapter.sayit.0 started with pid 7676
                  2021-04-15 17:05:58.505  - warn: node-red.0 (7014) 15 Apr 17:05:58 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                  2021-04-15 17:05:59.536  - info: sayit.0 (7676) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:05:59.573  - info: sayit.0 (7676) Upload announce mp3 files
                  2021-04-15 17:05:59.786  - info: sayit.0 (7676) All files uploaded
                  2021-04-15 17:06:03.637  - info: host.whome instance system.adapter.shelly.0 started with pid 8159
                  2021-04-15 17:06:05.862  - info: host.whome instance system.adapter.sonoff.0 started with pid 8365
                  2021-04-15 17:06:05.885  - info: shelly.0 (8159) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:06:05.933  - info: shelly.0 (8159) Starting Adapter shelly.0 in version 4.0.7
                  2021-04-15 17:06:05.984  - info: shelly.0 (8159) Starting Shelly adapter in CoAP modus.
                  2021-04-15 17:06:06.065  - info: shelly.0 (8159) Listening for Shelly packets in the network
                  2021-04-15 17:06:07.307  - info: sonoff.0 (8365) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:06:07.384  - info: sonoff.0 (8365) Starting MQTT  server on port 1884
                  2021-04-15 17:06:08.384  - info: shelly.0 (8159) Shelly device 192.168.1.122 (shellyswitch25 / shellyswitch25-483FDA8DDD51 / SHSW-25#483FDA8DDD51#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:08.889  - info: shelly.0 (8159) Shelly device 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:09.913  - info: shelly.0 (8159) Shelly device 192.168.1.128 (shelly1 / shelly1-8CAAB5614D9F / SHSW-1#8CAAB5614D9F#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:10.609  - info: host.whome instance system.adapter.telegram.0 started with pid 8765
                  2021-04-15 17:06:10.740  - info: shelly.0 (8159) Shelly device 192.168.1.121 (shellyswitch25 / shellyswitch25-84CCA8B09E95 / SHSW-25#84CCA8B09E95#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:13.163  - info: telegram.0 (8765) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:06:14.115  - info: shelly.0 (8159) Shelly device 192.168.1.126 (shelly1 / shelly1-483FDA91AF1A / SHSW-1#483FDA91AF1A#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:14.829  - info: shelly.0 (8159) Shelly device 192.168.1.127 (shelly1 / shelly1-F4CFA2E46301 / SHSW-1#F4CFA2E46301#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:15.062  - info: shelly.0 (8159) Shelly device 192.168.1.131 (shellydimmer2 / shellydimmer2-40F520015E03 / SHDM-2#40F520015E03#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:15.551  - info: shelly.0 (8159) Shelly device 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:16.139  - info: host.whome instance system.adapter.telegram.1 started with pid 9216
                  2021-04-15 17:06:18.009  - info: shelly.0 (8159) Shelly device 192.168.1.123 (shellyswitch25 / shellyswitch25-84CCA8B0CC8F / SHSW-25#84CCA8B0CC8F#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:06:18.683  - info: telegram.1 (9216) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:06:19.987  - info: sonoff.0 (8365) Client [wama] connected with secret 1618499179967_1240
                  2021-04-15 17:06:22.011  - info: host.whome instance system.adapter.web.0 started with pid 9699
                  2021-04-15 17:06:23.768  - info: web.0 (9699) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:06:23.820  - info: cloud.0 (4326) Trying to connect as system.user.admin
                  2021-04-15 17:06:23.944  - info: cloud.0 (4326) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                  2021-04-15 17:06:24.069  - info: web.0 (9699) socket.io server listening on port 8082
                  2021-04-15 17:06:24.084  - info: web.0 (9699) simpleAPI server listening on port 8082
                  2021-04-15 17:06:24.086  - info: web.0 (9699) Allow states only when user is owner: false
                  2021-04-15 17:06:24.095  - info: web.0 (9699) http server listening on port 8082
                  2021-04-15 17:06:28.766  - info: sonoff.0 (8365) Client [Schalter-TV] connected with secret 1618499188765_7489
                  2021-04-15 17:06:29.594  - info: sonoff.0 (8365) Client [Steckdose12] connected with secret 1618499189588_613
                  2021-04-15 17:06:31.835  - info: sonoff.0 (8365) Client [Buero_Temp] connected with secret 1618499191833_7737
                  2021-04-15 17:06:32.648  - info: sonoff.0 (8365) Client [WekstattTemp] connected with secret 1618499192646_1301
                  2021-04-15 17:06:34.602  - info: sonoff.0 (8365) Client [Terrasse_lux_led] connected with secret 1618499194601_2835
                  2021-04-15 17:06:36.217  - info: sonoff.0 (8365) Client [Temp2-DS18B20] connected with secret 1618499196215_9761
                  2021-04-15 17:07:23.954  - info: cloud.0 (4326) Trying to connect as system.user.admin
                  2021-04-15 17:07:24.077  - info: cloud.0 (4326) Connection changed: connect
                  2021-04-15 17:15:44.289  - info: host.whome Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2021-04-15 17:26:21.072  - info: web.0 (9699) terminated http server on port 8082
                  2021-04-15 17:26:21.082  - info: node-red.0 (7014) kill node-red task
                  2021-04-15 17:26:21.080  - info: chromecast.0 (3979) Unload triggered
                  2021-04-15 17:26:21.075  - info: fb-checkpresence.0 (4948) cleaned everything up ...
                  2021-04-15 17:26:21.082  - info: chromecast.0 (3979) Destroying chromecast scanner
                  2021-04-15 17:26:21.087  - info: chromecast.0 (3979) Wohnzimmer - client disconnected
                  2021-04-15 17:26:21.088  - info: chromecast.0 (3979) Unload completed sucesfully
                  2021-04-15 17:26:21.121  - info: info.0 (5688) cleaned everything up...
                  2021-04-15 17:26:21.163  - info: followthesun.0 (5269) cleaned everything up...
                  2021-04-15 17:26:21.062  - info: host.whome received SIGTERM
                  2021-04-15 17:26:21.195  - info: sayit.0 (7676) stopping...
                  2021-04-15 17:26:21.179  - info: backitup.0 (3906) cleaned everything up...
                  2021-04-15 17:26:21.178  - info: host.whome stopInstance system.adapter.admin.0 (force=false, process=true)
                  2021-04-15 17:26:21.179  - info: host.whome stopInstance system.adapter.backitup.0 (force=false, process=true)
                  2021-04-15 17:26:21.180  - info: host.whome stopInstance system.adapter.chromecast.0 (force=false, process=true)
                  2021-04-15 17:26:21.186  - info: host.whome stopInstance system.adapter.cloud.0 (force=false, process=true)
                  2021-04-15 17:26:21.188  - info: host.whome stopInstance system.adapter.discovery.0 (force=false, process=true)
                  2021-04-15 17:26:21.189  - info: host.whome stopInstance system.adapter.ecovacs-deebot.0 (force=false, process=false)
                  2021-04-15 17:26:21.190  - info: host.whome stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
                  2021-04-15 17:26:21.190  - info: host.whome stopInstance system.adapter.followthesun.0 (force=false, process=true)
                  2021-04-15 17:26:21.191  - info: host.whome stopInstance system.adapter.info.0 (force=false, process=true)
                  2021-04-15 17:26:21.192  - info: host.whome stopInstance system.adapter.javascript.0 (force=false, process=true)
                  2021-04-15 17:26:21.193  - info: host.whome stopInstance system.adapter.midea.0 (force=false, process=false)
                  2021-04-15 17:26:21.194  - info: host.whome stopInstance system.adapter.mqtt.0 (force=false, process=true)
                  2021-04-15 17:26:21.196  - info: host.whome stopInstance system.adapter.node-red.0 (force=false, process=true)
                  2021-04-15 17:26:21.197  - info: host.whome stopInstance system.adapter.ping.0 (force=false, process=true)
                  2021-04-15 17:26:21.198  - info: host.whome stopInstance system.adapter.sayit.0 (force=false, process=true)
                  2021-04-15 17:26:21.199  - info: host.whome stopInstance system.adapter.shelly.0 (force=false, process=true)
                  2021-04-15 17:26:21.200  - info: host.whome stopInstance system.adapter.sonoff.0 (force=false, process=true)
                  2021-04-15 17:26:21.201  - info: host.whome stopInstance system.adapter.telegram.0 (force=false, process=true)
                  2021-04-15 17:26:21.201  - info: host.whome stopInstance system.adapter.telegram.1 (force=false, process=true)
                  2021-04-15 17:26:21.202  - info: host.whome stopInstance system.adapter.tr-064.0 (force=false, process=false)
                  2021-04-15 17:26:21.203  - info: host.whome stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
                  2021-04-15 17:26:21.203  - info: host.whome stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
                  2021-04-15 17:26:21.204  - info: host.whome stopInstance system.adapter.vis.0 (force=false, process=false)
                  2021-04-15 17:26:21.204  - info: host.whome stopInstance system.adapter.web.0 (force=false, process=true)
                  2021-04-15 17:26:21.075  - info: admin.0 (3348) terminating http server on port 8081
                  2021-04-15 17:26:21.231  - info: javascript.0 (6399) Stop script script.js.common.Buero.heizung_buero_boden
                  2021-04-15 17:26:21.278  - info: chromecast.0 (3979) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.291  - info: admin.0 (3348) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.267  - info: shelly.0 (8159) Closing Adapter
                  2021-04-15 17:26:21.288  - info: backitup.0 (3906) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.317  - info: fb-checkpresence.0 (4948) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.317  - info: cloud.0 (4326) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.319  - info: discovery.0 (4621) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.338  - info: followthesun.0 (5269) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.340  - info: info.0 (5688) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.355  - info: node-red.0 (7014) node-red exited with 0
                  2021-04-15 17:26:21.253  - info: javascript.0 (6399) Stop script script.js.common.Heizung.Auftau
                  2021-04-15 17:26:21.254  - info: javascript.0 (6399) Stop script script.js.common.Heizung.Heizstab
                  2021-04-15 17:26:21.255  - info: javascript.0 (6399) Stop script script.js.common.Rolladen.Rolladen
                  2021-04-15 17:26:21.318  - info: javascript.0 (6399) Stop script script.js.common.Rolladen.RolladenAutomatik
                  2021-04-15 17:26:21.332  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Anwesenheit
                  2021-04-15 17:26:21.334  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Flur
                  2021-04-15 17:26:21.346  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Gute-Nacht
                  2021-04-15 17:26:21.357  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Tag
                  2021-04-15 17:26:21.358  - info: javascript.0 (6399) Stop script script.js.common.Scripte.Terasse_LED_stripe
                  2021-04-15 17:26:21.359  - info: javascript.0 (6399) Stop script script.js.common.Scripte.wama2
                  2021-04-15 17:26:21.367  - info: javascript.0 (6399) Stop script script.js.common.Temperaturen.aussen
                  2021-04-15 17:26:21.369  - info: javascript.0 (6399) Stop script script.js.common.Temperaturen.temp2
                  2021-04-15 17:26:21.369  - info: javascript.0 (6399) Stop script script.js.common.Wohnzimmer.Wohnzimmer
                  2021-04-15 17:26:21.370  - info: javascript.0 (6399) Stop script script.js.rebootPi
                  2021-04-15 17:26:21.383  - info: javascript.0 (6399) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.415  - info: fb-checkpresence.0 (4948) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.434  - info: discovery.0 (4621) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.447  - info: shelly.0 (8159) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.445  - info: ping.0 (7321) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.450  - info: sonoff.0 (8365) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.455  - info: telegram.1 (9216) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.453  - info: telegram.0 (8765) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.466  - info: web.0 (9699) Got terminate signal TERMINATE_YOURSELF
                  2021-04-15 17:26:21.495  - info: followthesun.0 (5269) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.502  - info: chromecast.0 (3979) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.499  - info: host.whome stopInstance system.adapter.admin.0 send kill signal
                  2021-04-15 17:26:21.499  - info: backitup.0 (3906) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.508  - info: node-red.0 (7014) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.508  - info: cloud.0 (4326) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.500  - info: host.whome stopInstance system.adapter.backitup.0 send kill signal
                  2021-04-15 17:26:21.501  - info: host.whome stopInstance system.adapter.chromecast.0 send kill signal
                  2021-04-15 17:26:21.501  - info: host.whome stopInstance system.adapter.cloud.0 send kill signal
                  2021-04-15 17:26:21.501  - info: host.whome stopInstance system.adapter.discovery.0 send kill signal
                  2021-04-15 17:26:21.502  - info: host.whome stopInstance system.adapter.fb-checkpresence.0 send kill signal
                  2021-04-15 17:26:21.502  - info: host.whome stopInstance system.adapter.followthesun.0 send kill signal
                  2021-04-15 17:26:21.503  - info: host.whome stopInstance system.adapter.info.0 send kill signal
                  2021-04-15 17:26:21.503  - info: host.whome stopInstance system.adapter.javascript.0 send kill signal
                  2021-04-15 17:26:21.505  - info: host.whome stopInstance system.adapter.mqtt.0 send kill signal
                  2021-04-15 17:26:21.512  - info: web.0 (9699) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.508  - info: info.0 (5688) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.519  - info: admin.0 (3348) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.520  - info: host.whome stopInstance system.adapter.ping.0 send kill signal
                  2021-04-15 17:26:21.563  - info: shelly.0 (8159) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.576  - info: host.whome stopInstance system.adapter.shelly.0 send kill signal
                  2021-04-15 17:26:21.577  - info: host.whome stopInstance system.adapter.sonoff.0 send kill signal
                  2021-04-15 17:26:21.577  - info: host.whome stopInstance system.adapter.telegram.0 send kill signal
                  2021-04-15 17:26:21.578  - info: host.whome stopInstance system.adapter.telegram.1 send kill signal
                  2021-04-15 17:26:21.578  - info: host.whome stopInstance system.adapter.web.0 send kill signal
                  2021-04-15 17:26:21.580  - info: javascript.0 (6399) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.613  - info: telegram.1 (9216) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.628  - info: sonoff.0 (8365) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.632  - info: telegram.0 (8765) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.688  - info: ping.0 (7321) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:21.701  - info: sayit.0 (7676) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  2021-04-15 17:26:22.010  - info: host.whome instance system.adapter.fb-checkpresence.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.181  - info: host.whome instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.210  - warn: shelly.0 (8159) redis get shelly.0.SHSW-1#F4CFA2E46301#1.Relay0.Timer, error - Connection is closed.
                  2021-04-15 17:26:22.217  - info: host.whome stopInstance timeout 1000 system.adapter.node-red.0 killing pid  7014
                  2021-04-15 17:26:22.221  - info: host.whome stopInstance timeout 1000 system.adapter.sayit.0 killing pid  7676
                  2021-04-15 17:26:22.234  - warn: shelly.0 (8159) redis get shelly.0.SHSW-25#483FDA8DCC8E#1.Relay0.Timer, error - Connection is closed.
                  2021-04-15 17:26:22.241  - warn: shelly.0 (8159) redis get shelly.0.SHSW-25#483FDA8DCC8E#1.Relay1.Timer, error - Connection is closed.
                  2021-04-15 17:26:22.243  - warn: shelly.0 (8159) redis get shelly.0.SHSW-25#483FDA8DCC8E#1.Shutter.Duration, error - Connection is closed.
                  2021-04-15 17:26:22.279  - error: shelly.0 (8159) Error in function httpIoBrokerState for state SHSW-25#483FDA8DCC8E#1.name and request{"url":"http://192.168.1.120/settings","timeout":5000} for 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) (Error: Connection is closed.)
                  2021-04-15 17:26:22.306  - error: shelly.0 (8159) Error in function httpIoBrokerState for state SHSW-1#483FDA6F6EBC#1.Relay0.ChannelName and request{"url":"http://192.168.1.125/settings/relay/0","timeout":5000} for 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) (Error: Connection is closed.)
                  2021-04-15 17:26:22.324  - error: shelly.0 (8159) Error in function httpIoBrokerState for state SHSW-25#483FDA8DCC8E#1.Relay1.ChannelName and request{"url":"http://192.168.1.120/settings/relay/1","timeout":5000} for 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) (Error: Connection is closed.)
                  2021-04-15 17:26:22.348  - error: shelly.0 (8159) Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.uptime": Connection is closed.
                  2021-04-15 17:26:22.349  - warn: shelly.0 (8159) Could not check object existence of state shelly.0.SHSW-1#F4CFA2E46301#1.uptime: Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.uptime": Connection is closed.
                  2021-04-15 17:26:22.350  - warn: shelly.0 (8159) get state error: Connection is closed.
                  2021-04-15 17:26:22.350  - error: shelly.0 (8159) Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.rssi": Connection is closed.
                  2021-04-15 17:26:22.351  - warn: shelly.0 (8159) Could not check object existence of state shelly.0.SHSW-1#F4CFA2E46301#1.rssi: Cannot check object existence of "shelly.0.SHSW-1#F4CFA2E46301#1.rssi": Connection is closed.
                  2021-04-15 17:26:22.351  - warn: shelly.0 (8159) get state error: Connection is closed.
                  2021-04-15 17:26:22.693  - info: host.whome instance system.adapter.chromecast.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.698  - info: host.whome instance system.adapter.cloud.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.699  - warn: host.whome instance system.adapter.node-red.0 terminated due to SIGTERM
                  2021-04-15 17:26:22.699  - info: host.whome instance system.adapter.node-red.0 terminated with code null ()
                  2021-04-15 17:26:22.700  - warn: host.whome instance system.adapter.sayit.0 terminated due to SIGTERM
                  2021-04-15 17:26:22.700  - info: host.whome instance system.adapter.sayit.0 terminated with code null ()
                  2021-04-15 17:26:22.702  - info: host.whome stopInstance system.adapter.javascript.0 killing pid 6399
                  2021-04-15 17:26:22.702  - info: host.whome stopInstance system.adapter.mqtt.0 killing pid 6670
                  2021-04-15 17:26:22.703  - info: host.whome stopInstance system.adapter.ping.0 killing pid 7321
                  2021-04-15 17:26:22.703  - info: host.whome stopInstance system.adapter.sonoff.0 killing pid 8365
                  2021-04-15 17:26:22.704  - info: host.whome stopInstance system.adapter.telegram.0 killing pid 8765
                  2021-04-15 17:26:22.705  - info: host.whome stopInstance system.adapter.telegram.1 killing pid 9216
                  2021-04-15 17:26:22.773  - info: host.whome instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.854  - info: host.whome instance system.adapter.info.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.856  - info: host.whome instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.857  - info: host.whome instance system.adapter.followthesun.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.857  - info: host.whome instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.932  - info: host.whome instance system.adapter.shelly.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                  2021-04-15 17:26:22.933  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.112  - warn: host.whome Cannot get view: Connection is closed.
                  2021-04-15 17:26:23.113  - warn: host.whome Cannot get view: Connection is closed.
                  2021-04-15 17:26:23.114  - warn: host.whome Cannot get view: Connection is closed.
                  2021-04-15 17:26:23.116  - warn: host.whome instance system.adapter.javascript.0 terminated due to SIGTERM
                  2021-04-15 17:26:23.117  - info: host.whome instance system.adapter.javascript.0 terminated with code null ()
                  2021-04-15 17:26:23.118  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.119  - warn: host.whome instance system.adapter.mqtt.0 terminated due to SIGTERM
                  2021-04-15 17:26:23.119  - info: host.whome instance system.adapter.mqtt.0 terminated with code null ()
                  2021-04-15 17:26:23.120  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.120  - warn: host.whome instance system.adapter.ping.0 terminated due to SIGTERM
                  2021-04-15 17:26:23.120  - info: host.whome instance system.adapter.ping.0 terminated with code null ()
                  2021-04-15 17:26:23.121  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.121  - warn: host.whome instance system.adapter.sonoff.0 terminated due to SIGTERM
                  2021-04-15 17:26:23.122  - info: host.whome instance system.adapter.sonoff.0 terminated with code null ()
                  2021-04-15 17:26:23.122  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.122  - warn: host.whome instance system.adapter.telegram.0 terminated due to SIGTERM
                  2021-04-15 17:26:23.123  - info: host.whome instance system.adapter.telegram.0 terminated with code null ()
                  2021-04-15 17:26:23.123  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.124  - warn: host.whome instance system.adapter.telegram.1 terminated due to SIGTERM
                  2021-04-15 17:26:23.125  - info: host.whome instance system.adapter.telegram.1 terminated with code null ()
                  2021-04-15 17:26:23.125  - info: host.whome All instances are stopped.
                  2021-04-15 17:26:23.133  - info: host.whome terminated
                  2021-04-15 17:26:36.997  - info: host.whome iobroker.js-controller version 3.2.16 js-controller starting
                  2021-04-15 17:26:37.003  - info: host.whome Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                  2021-04-15 17:26:37.003  - info: host.whome hostname: whome, node: v12.22.1
                  2021-04-15 17:26:37.004  - info: host.whome ip addresses: fe80::d8:6431:90b3:eeab
                  2021-04-15 17:26:37.645  - info: host.whome connected to Objects and States
                  2021-04-15 17:26:37.702  - info: host.whome added notifications configuration of host
                  2021-04-15 17:26:38.566  - info: host.whome 25 instances found
                  2021-04-15 17:26:38.645  - info: host.whome starting 19 instances
                  2021-04-15 17:26:38.832  - info: host.whome instance system.adapter.admin.0 started with pid 918
                  2021-04-15 17:26:42.290  - info: admin.0 (918) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:26:42.351  - info: admin.0 (918) requesting all states
                  2021-04-15 17:26:42.352  - info: admin.0 (918) requesting all objects
                  2021-04-15 17:26:43.158  - info: host.whome instance system.adapter.backitup.0 started with pid 1187
                  2021-04-15 17:26:43.384  - info: admin.0 (918) received all objects
                  2021-04-15 17:26:43.896  - info: admin.0 (918) http server listening on port 8081
                  2021-04-15 17:26:43.897  - info: admin.0 (918) Use link "http://localhost:8081" to configure.
                  2021-04-15 17:26:46.673  - info: host.whome instance system.adapter.chromecast.0 started with pid 1485
                  2021-04-15 17:26:48.224  - info: chromecast.0 (1485) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:26:48.402  - info: backitup.0 (1187) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:26:48.499  - info: backitup.0 (1187) [iobroker] backup was activated at 03:00 every 1 day(s)
                  2021-04-15 17:26:49.002  - info: chromecast.0 (1485) Wohnzimmer - Connected client
                  2021-04-15 17:26:50.749  - info: host.whome instance system.adapter.cloud.0 started with pid 1832
                  2021-04-15 17:26:52.640  - info: cloud.0 (1832) starting. Version 4.0.10 in /opt/iobroker/node_modules/iobroker.cloud, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:26:52.705  - info: cloud.0 (1832) Connecting with https://iobroker.net:10555 with "uwaizmann@gmail.com_c9f2a840-75ac-11eb-a278-59b6a78c6ee1"
                  2021-04-15 17:26:53.017  - info: cloud.0 (1832) Trying to connect as system.user.admin
                  2021-04-15 17:26:53.097  - info: cloud.0 (1832) Adapter redirected temporally to "https://iobroker.net:10556" in one minute. Reason: command from server
                  2021-04-15 17:26:54.767  - info: host.whome instance system.adapter.discovery.0 started with pid 2156
                  2021-04-15 17:26:56.298  - info: discovery.0 (2156) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:20.347  - info: host.whome instance system.adapter.fb-checkpresence.0 started with pid 2474
                  2021-04-15 17:27:21.765  - info: fb-checkpresence.0 (2474) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:21.797  - info: fb-checkpresence.0 (2474) start fb-checkpresence: ip-address: "192.168.1.10" - interval devices: 1 Min. - interval members: 60 s
                  2021-04-15 17:27:21.990  - info: fb-checkpresence.0 (2474) service Hosts1-X_AVM-DE_GetHostListPath is supported
                  2021-04-15 17:27:22.004  - info: fb-checkpresence.0 (2474) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                  2021-04-15 17:27:22.017  - info: fb-checkpresence.0 (2474) service Hosts1-GetSpecificHostEntry is supported
                  2021-04-15 17:27:22.030  - info: fb-checkpresence.0 (2474) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                  2021-04-15 17:27:22.044  - info: fb-checkpresence.0 (2474) service DeviceInfo1-GetSecurityPort is supported
                  2021-04-15 17:27:22.061  - info: fb-checkpresence.0 (2474) service WANPPPConnection1-GetInfo is supported
                  2021-04-15 17:27:22.078  - info: fb-checkpresence.0 (2474) service WLANConfiguration3-SetEnable is supported
                  2021-04-15 17:27:22.093  - info: fb-checkpresence.0 (2474) service WLANConfiguration3-GetInfo is supported
                  2021-04-15 17:27:22.105  - info: fb-checkpresence.0 (2474) service DeviceInfo1-GetInfo is supported
                  2021-04-15 17:27:22.115  - info: fb-checkpresence.0 (2474) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                  2021-04-15 17:27:22.126  - info: fb-checkpresence.0 (2474) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                  2021-04-15 17:27:22.137  - info: fb-checkpresence.0 (2474) service DeviceConfig1-Reboot is supported
                  2021-04-15 17:27:22.326  - info: fb-checkpresence.0 (2474) createGlobalObjects finished successfully
                  2021-04-15 17:27:22.456  - info: fb-checkpresence.0 (2474) History function for Uwe disabled. Please select a history adapter in the configuration dialog!
                  2021-04-15 17:27:22.716  - info: fb-checkpresence.0 (2474) History function for Elke disabled. Please select a history adapter in the configuration dialog!
                  2021-04-15 17:27:22.757  - info: fb-checkpresence.0 (2474) History function for Elke J3 disabled. Please select a history adapter in the configuration dialog!
                  2021-04-15 17:27:22.758  - info: fb-checkpresence.0 (2474) createMemberObjects finished successfully
                  2021-04-15 17:27:24.363  - info: host.whome instance system.adapter.followthesun.0 started with pid 2817
                  2021-04-15 17:27:26.100  - info: followthesun.0 (2817) starting. Version 0.3.3 in /opt/iobroker/node_modules/iobroker.followthesun, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:26.159  - info: followthesun.0 (2817) Sun position calculation will be done every 120 seconds
                  2021-04-15 17:27:26.165  - info: followthesun.0 (2817) Daily sun parameter calculation scheduled for 00:00:35
                  2021-04-15 17:27:28.324  - info: host.whome instance system.adapter.info.0 started with pid 3154
                  2021-04-15 17:27:31.397  - info: info.0 (3154) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:33.269  - info: host.whome instance system.adapter.javascript.0 started with pid 3708
                  2021-04-15 17:27:36.374  - info: host.whome instance system.adapter.mqtt.0 started with pid 4221
                  2021-04-15 17:27:38.398  - info: javascript.0 (3708) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:38.610  - info: javascript.0 (3708) requesting all states
                  2021-04-15 17:27:38.611  - info: javascript.0 (3708) requesting all objects
                  2021-04-15 17:27:39.429  - info: javascript.0 (3708) received all objects
                  2021-04-15 17:27:39.486  - info: javascript.0 (3708) received all states
                  2021-04-15 17:27:39.827  - info: javascript.0 (3708) Start javascript script.js.common.Buero.heizung_buero_boden
                  2021-04-15 17:27:39.903  - info: javascript.0 (3708) script.js.common.Buero.heizung_buero_boden: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:39.904  - info: javascript.0 (3708) Start javascript script.js.common.Heizung.Auftau
                  2021-04-15 17:27:39.922  - info: javascript.0 (3708) script.js.common.Heizung.Auftau: registered 1 subscription and 1 schedule
                  2021-04-15 17:27:39.923  - info: javascript.0 (3708) Start javascript script.js.common.Heizung.Heizstab
                  2021-04-15 17:27:39.931  - info: javascript.0 (3708) script.js.common.Heizung.Heizstab: registered 1 subscription and 1 schedule
                  2021-04-15 17:27:39.932  - info: javascript.0 (3708) Start javascript script.js.common.Rolladen.Rolladen
                  2021-04-15 17:27:39.937  - info: javascript.0 (3708) script.js.common.Rolladen.Rolladen: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:39.938  - info: javascript.0 (3708) Start javascript script.js.common.Rolladen.RolladenAutomatik
                  2021-04-15 17:27:39.948  - info: javascript.0 (3708) script.js.common.Rolladen.RolladenAutomatik: registered 4 subscriptions and 2 schedules
                  2021-04-15 17:27:39.949  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Anwesenheit
                  2021-04-15 17:27:39.954  - info: javascript.0 (3708) script.js.common.Scripte.Anwesenheit: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:39.955  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Flur
                  2021-04-15 17:27:39.960  - info: javascript.0 (3708) script.js.common.Scripte.Flur: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:39.961  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Gute-Nacht
                  2021-04-15 17:27:39.967  - info: javascript.0 (3708) script.js.common.Scripte.Gute-Nacht: registered 2 subscriptions and 0 schedules
                  2021-04-15 17:27:39.967  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Tag
                  2021-04-15 17:27:39.975  - info: javascript.0 (3708) script.js.common.Scripte.Tag: registered 0 subscriptions and 2 schedules
                  2021-04-15 17:27:39.976  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.Terasse_LED_stripe
                  2021-04-15 17:27:39.982  - info: javascript.0 (3708) script.js.common.Scripte.Terasse_LED_stripe: registered 1 subscription and 1 schedule
                  2021-04-15 17:27:39.983  - info: javascript.0 (3708) Start javascript script.js.common.Scripte.wama2
                  2021-04-15 17:27:39.988  - info: javascript.0 (3708) script.js.common.Scripte.wama2: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:40.000  - info: javascript.0 (3708) Start javascript script.js.common.Temperaturen.aussen
                  2021-04-15 17:27:40.007  - info: javascript.0 (3708) script.js.common.Temperaturen.aussen: registered 2 subscriptions and 0 schedules
                  2021-04-15 17:27:40.008  - info: javascript.0 (3708) Start javascript script.js.common.Temperaturen.temp2
                  2021-04-15 17:27:40.015  - info: javascript.0 (3708) script.js.common.Temperaturen.temp2: registered 3 subscriptions and 0 schedules
                  2021-04-15 17:27:40.016  - info: javascript.0 (3708) Start javascript script.js.common.Wohnzimmer.Wohnzimmer
                  2021-04-15 17:27:40.023  - info: javascript.0 (3708) script.js.common.Wohnzimmer.Wohnzimmer: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:40.024  - info: javascript.0 (3708) Start javascript script.js.rebootPi
                  2021-04-15 17:27:40.030  - info: javascript.0 (3708) script.js.rebootPi: registered 1 subscription and 0 schedules
                  2021-04-15 17:27:40.333  - info: host.whome instance system.adapter.node-red.0 started with pid 4516
                  2021-04-15 17:27:41.735  - info: node-red.0 (4516) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:42.172  - info: node-red.0 (4516) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  2021-04-15 17:27:44.199  - warn: node-red.0 (4516) 15 Apr 17:27:44 - [warn] Die Verwendung von editorTheme.palette.editable ist abgekündigt. Stattdessen externalModules.palette.allowInstall verwenden.
                  2021-04-15 17:27:44.340  - info: host.whome instance system.adapter.ping.0 started with pid 4870
                  2021-04-15 17:27:46.139  - info: ping.0 (4870) starting. Version 1.4.12 in /opt/iobroker/node_modules/iobroker.ping, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:48.346  - info: host.whome instance system.adapter.sayit.0 started with pid 5200
                  2021-04-15 17:27:49.310  - warn: node-red.0 (4516) 15 Apr 17:27:49 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                  2021-04-15 17:27:50.406  - info: sayit.0 (5200) starting. Version 1.12.2 in /opt/iobroker/node_modules/iobroker.sayit, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:50.441  - info: sayit.0 (5200) Upload announce mp3 files
                  2021-04-15 17:27:50.545  - info: sayit.0 (5200) All files uploaded
                  2021-04-15 17:27:52.332  - info: host.whome instance system.adapter.shelly.0 started with pid 5516
                  2021-04-15 17:27:54.704  - info: shelly.0 (5516) starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:54.739  - info: shelly.0 (5516) Starting Adapter shelly.0 in version 4.0.7
                  2021-04-15 17:27:54.778  - info: shelly.0 (5516) Starting Shelly adapter in CoAP modus.
                  2021-04-15 17:27:54.868  - info: shelly.0 (5516) Listening for Shelly packets in the network
                  2021-04-15 17:27:56.341  - info: host.whome instance system.adapter.sonoff.0 started with pid 5843
                  2021-04-15 17:27:57.802  - info: sonoff.0 (5843) starting. Version 2.4.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:27:57.896  - info: sonoff.0 (5843) Starting MQTT  server on port 1884
                  2021-04-15 17:27:58.380  - info: shelly.0 (5516) Shelly device 192.168.1.125 (shelly1 / shelly1-483FDA6F6EBC / SHSW-1#483FDA6F6EBC#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:27:59.507  - info: shelly.0 (5516) Shelly device 192.168.1.128 (shelly1 / shelly1-8CAAB5614D9F / SHSW-1#8CAAB5614D9F#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:27:59.909  - info: shelly.0 (5516) Shelly device 192.168.1.131 (shellydimmer2 / shellydimmer2-40F520015E03 / SHDM-2#40F520015E03#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:00.338  - info: host.whome instance system.adapter.telegram.0 started with pid 6182
                  2021-04-15 17:28:01.996  - info: shelly.0 (5516) Shelly device 192.168.1.120 (shellyswitch25 / shellyswitch25-483FDA8DCC8E / SHSW-25#483FDA8DCC8E#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:02.785  - info: shelly.0 (5516) Shelly device 192.168.1.121 (shellyswitch25 / shellyswitch25-84CCA8B09E95 / SHSW-25#84CCA8B09E95#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:03.352  - info: telegram.0 (6182) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:28:03.692  - info: shelly.0 (5516) Shelly device 192.168.1.126 (shelly1 / shelly1-483FDA91AF1A / SHSW-1#483FDA91AF1A#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:04.313  - info: shelly.0 (5516) Shelly device 192.168.1.127 (shelly1 / shelly1-F4CFA2E46301 / SHSW-1#F4CFA2E46301#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:04.340  - info: host.whome instance system.adapter.telegram.1 started with pid 6497
                  2021-04-15 17:28:05.646  - info: shelly.0 (5516) Shelly device 192.168.1.123 (shellyswitch25 / shellyswitch25-84CCA8B0CC8F / SHSW-25#84CCA8B0CC8F#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:06.873  - info: shelly.0 (5516) Shelly device 192.168.1.122 (shellyswitch25 / shellyswitch25-483FDA8DDD51 / SHSW-25#483FDA8DDD51#1) with CoAP connected! Polltime set to 5 sec.
                  2021-04-15 17:28:06.904  - info: sonoff.0 (5843) Client [Buero_Temp] connected with secret 1618500486885_4558
                  2021-04-15 17:28:07.082  - info: sonoff.0 (5843) Client [wama] connected with secret 1618500487080_7114
                  2021-04-15 17:28:07.242  - info: sonoff.0 (5843) Client [Temp2-DS18B20] connected with secret 1618500487219_5502
                  2021-04-15 17:28:07.317  - info: telegram.1 (6497) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:28:07.622  - info: sonoff.0 (5843) Client [Terrasse_lux_led] connected with secret 1618500487620_9651
                  2021-04-15 17:28:07.709  - info: sonoff.0 (5843) Client [WekstattTemp] connected with secret 1618500487707_5656
                  2021-04-15 17:28:07.753  - info: sonoff.0 (5843) Client [Schalter-TV] connected with secret 1618500487749_4349
                  2021-04-15 17:28:07.756  - info: sonoff.0 (5843) Client [Steckdose12] connected with secret 1618500487751_3495
                  2021-04-15 17:28:10.082  - info: vis.0 (6836) starting. Version 1.3.4 in /opt/iobroker/node_modules/iobroker.vis, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:28:10.331  - info: vis.0 (6836) vis license is OK.
                  2021-04-15 17:28:11.354  - info: vis.0 (6836) Terminated (NO_ERROR): Without reason
                  2021-04-15 17:28:11.927  - info: host.whome instance system.adapter.vis.0 terminated while should be started once
                  2021-04-15 17:28:12.370  - info: host.whome instance system.adapter.web.0 started with pid 7199
                  2021-04-15 17:28:14.332  - info: web.0 (7199) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.1, js-controller: 3.2.16
                  2021-04-15 17:28:14.664  - info: web.0 (7199) socket.io server listening on port 8082
                  2021-04-15 17:28:14.674  - info: web.0 (7199) simpleAPI server listening on port 8082
                  2021-04-15 17:28:14.675  - info: web.0 (7199) Allow states only when user is owner: false
                  2021-04-15 17:28:14.684  - info: web.0 (7199) http server listening on port 8082
                  2021-04-15 17:28:14.698  - info: cloud.0 (1832) Trying to connect as system.user.admin
                  2021-04-15 17:28:14.823  - info: cloud.0 (1832) Connection changed: connect
                  @uwe-waizmann sagte in Seltsame Abstürze RPI4:
                  Kannst du mal nach dem kernel.log und dem sys.log schauen? Sollten in /var/log/ liegen. So um 16:17 herum sollte da was drinstehen.
                  Uwe WaizmannU 1 Antwort Letzte Antwort
                    Uwe WaizmannU Offline
                    Uwe Waizmann
                    sehr gerne, hoffe wir kommen dem Problem näher, denn so nervt das schon gewaltig :-(
                    kern.log
                    Apr 15 16:17:06 whome kernel: [    4.893869] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
                    Apr 15 16:17:06 whome kernel: [    4.897861] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    Apr 15 16:17:06 whome kernel: [    4.902417] devtmpfs: mounted
                    Apr 15 16:17:06 whome kernel: [    4.915383] Freeing unused kernel memory: 2048K
                    Apr 15 16:17:06 whome kernel: [    4.933736] Run /sbin/init as init process
                    Apr 15 16:17:06 whome kernel: [    4.937579]   with arguments:
                    Apr 15 16:17:06 whome kernel: [    4.937593]     /sbin/init
                    Apr 15 16:17:06 whome kernel: [    4.937607]   with environment:
                    Apr 15 16:17:06 whome kernel: [    4.937622]     HOME=/
                    Apr 15 16:17:06 whome kernel: [    4.937636]     TERM=linux
                    Apr 15 16:17:06 whome kernel: [    5.556776] NET: Registered protocol family 10
                    Apr 15 16:17:06 whome kernel: [    5.562163] Segment Routing with IPv6
                    Apr 15 16:17:06 whome kernel: [    6.594095] random: systemd: uninitialized urandom read (16 bytes read)
                    Apr 15 16:17:06 whome kernel: [    6.615339] random: systemd: uninitialized urandom read (16 bytes read)
                    Apr 15 16:17:06 whome kernel: [    6.630295] random: systemd: uninitialized urandom read (16 bytes read)
                    Apr 15 16:17:06 whome kernel: [    6.793710] i2c /dev entries driver
                    Apr 15 16:17:06 whome kernel: [    7.539932] EXT4-fs (sda2): re-mounted. Opts: (null)
                    Apr 15 16:17:06 whome kernel: [    8.394406] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
                    Apr 15 16:17:06 whome kernel: [    8.402145] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
                    Apr 15 16:17:06 whome kernel: [    8.407404] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
                    Apr 15 16:17:06 whome kernel: [    8.408391] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
                    Apr 15 16:17:06 whome kernel: [    8.483250] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.501575] mc: Linux media interface: v0.10
                    Apr 15 16:17:06 whome kernel: [    8.501830] bcm2835_audio bcm2835_audio: card created with 4 channels
                    Apr 15 16:17:06 whome kernel: [    8.525521] bcm2835_audio bcm2835_audio: card created with 4 channels
                    Apr 15 16:17:06 whome kernel: [    8.527497] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.529773] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
                    Apr 15 16:17:06 whome kernel: [    8.529800] [vc_sm_connected_init]: start
                    Apr 15 16:17:06 whome kernel: [    8.563801] [vc_sm_connected_init]: installed successfully
                    Apr 15 16:17:06 whome kernel: [    8.590989] videodev: Linux video capture interface: v2.00
                    Apr 15 16:17:06 whome kernel: [    8.642519] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.659713] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.662353] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.673004] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.700340] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
                    Apr 15 16:17:06 whome kernel: [    8.711331] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
                    Apr 15 16:17:06 whome kernel: [    8.717865] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
                    Apr 15 16:17:06 whome kernel: [    8.732122] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
                    Apr 15 16:17:06 whome kernel: [    8.741645] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
                    Apr 15 16:17:06 whome kernel: [    8.741994] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
                    Apr 15 16:17:06 whome kernel: [    8.742030] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
                    Apr 15 16:17:06 whome kernel: [    8.742056] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
                    Apr 15 16:17:06 whome kernel: [    8.742114] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
                    Apr 15 16:17:06 whome kernel: [    8.746199] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
                    Apr 15 16:17:06 whome kernel: [    8.787872] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
                    Apr 15 16:17:06 whome kernel: [    8.815075] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
                    Apr 15 16:17:06 whome kernel: [    8.815137] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
                    Apr 15 16:17:06 whome kernel: [    8.825070] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
                    Apr 15 16:17:06 whome kernel: [    8.825119] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
                    Apr 15 16:17:06 whome kernel: [    8.845696] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                    Apr 15 16:17:06 whome kernel: [    8.845726] checking generic (3e2fe000 7f8000) vs hw (0 ffffffffffffffff)
                    Apr 15 16:17:06 whome kernel: [    8.845743] fb0: switching to vc4drmfb from simple
                    Apr 15 16:17:06 whome kernel: [    8.845909] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
                    Apr 15 16:17:06 whome kernel: [    8.845954] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
                    Apr 15 16:17:06 whome kernel: [    8.846545] Console: switching to colour dummy device 80x30
                    Apr 15 16:17:06 whome kernel: [    8.873819] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                    Apr 15 16:17:06 whome kernel: [    8.899427] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                    Apr 15 16:17:06 whome kernel: [    9.029595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                    Apr 15 16:17:06 whome kernel: [    9.032332] sd 0:0:0:0: Attached scsi generic sg0 type 0
                    Apr 15 16:17:06 whome kernel: [    9.087145] Console: switching to colour frame buffer device 240x67
                    Apr 15 16:17:06 whome kernel: [    9.099033] brcmfmac: F1 signature read @0x18000000=0x15264345
                    Apr 15 16:17:06 whome kernel: [    9.111849] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
                    Apr 15 16:17:06 whome kernel: [    9.123088] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                    Apr 15 16:17:06 whome kernel: [    9.124185] usbcore: registered new interface driver brcmfmac
                    Apr 15 16:17:06 whome kernel: [    9.159380] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
                    Apr 15 16:17:06 whome kernel: [    9.400951] random: crng init done
                    Apr 15 16:17:06 whome kernel: [    9.400968] random: 7 urandom warning(s) missed due to ratelimiting
                    Apr 15 16:17:06 whome kernel: [    9.403086] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                    Apr 15 16:17:06 whome kernel: [    9.414017] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                    Apr 15 16:17:06 whome kernel: [    9.550053] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1.3.4/input2
                    Apr 15 16:17:06 whome kernel: [    9.691025] input: Logitech Wireless Device PID:400a Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input8
                    Apr 15 16:17:06 whome kernel: [    9.691694] hid-generic 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
                    Apr 15 16:17:06 whome kernel: [    9.695990] input: Logitech Wireless Device PID:4003 Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input12
                    Apr 15 16:17:06 whome kernel: [    9.701763] input: Logitech Wireless Device PID:4003 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input13
                    Apr 15 16:17:06 whome kernel: [    9.702186] input: Logitech Wireless Device PID:4003 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input14
                    Apr 15 16:17:06 whome kernel: [    9.702655] hid-generic 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4003] on usb-0000:01:00.0-1.1.3.4/input2:2
                    Apr 15 16:17:06 whome kernel: [   10.517714] input: Logitech Wireless Device PID:400a as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:400A.0006/input/input18
                    Apr 15 16:17:06 whome kernel: [   10.519729] logitech-hidpp-device 0003:046D:400A.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:400a] on usb-0000:01:00.0-1.1.3.4/input2:1
                    Apr 15 16:17:06 whome kernel: [   10.935588] input: Logitech K270 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.4/1-1.1.3.4:1.2/0003:046D:C52B.0005/0003:046D:4003.0007/input/input19
                    Apr 15 16:17:06 whome kernel: [   10.936905] logitech-hidpp-device 0003:046D:4003.0007: input,hidraw4: USB HID v1.11 Keyboard [Logitech K270] on usb-0000:01:00.0-1.1.3.4/input2:2
                    Apr 15 16:17:06 whome kernel: [   11.906258] uart-pl011 fe201000.serial: no DMA platform data
                    Apr 15 16:17:06 whome kernel: [   12.142710] 8021q: 802.1Q VLAN Support v1.8
                    Apr 15 16:17:06 whome kernel: [   12.713688] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k FS
                    Apr 15 16:17:07 whome kernel: [   13.254551] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                    Apr 15 16:17:07 whome kernel: [   13.254961] bcmgenet fd580000.ethernet eth0: Link is Down
                    Apr 15 16:17:10 whome kernel: [   16.393559] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
                    Apr 15 16:17:10 whome kernel: [   16.393588] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                    Apr 15 16:17:12 whome kernel: [   18.782512] Bluetooth: Core ver 2.22
                    Apr 15 16:17:12 whome kernel: [   18.782572] NET: Registered protocol family 31
                    Apr 15 16:17:12 whome kernel: [   18.782579] Bluetooth: HCI device and connection manager initialized
                    Apr 15 16:17:12 whome kernel: [   18.782596] Bluetooth: HCI socket layer initialized
                    Apr 15 16:17:12 whome kernel: [   18.782606] Bluetooth: L2CAP socket layer initialized
                    Apr 15 16:17:12 whome kernel: [   18.782621] Bluetooth: SCO socket layer initialized
                    Apr 15 16:17:12 whome kernel: [   18.795842] Bluetooth: HCI UART driver ver 2.3
                    Apr 15 16:17:12 whome kernel: [   18.795856] Bluetooth: HCI UART protocol H4 registered
                    Apr 15 16:17:12 whome kernel: [   18.795927] Bluetooth: HCI UART protocol Three-wire (H5) registered
                    Apr 15 16:17:12 whome kernel: [   18.796133] Bluetooth: HCI UART protocol Broadcom registered
                    Apr 15 16:17:13 whome kernel: [   19.002855] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                    Apr 15 16:17:13 whome kernel: [   19.002863] Bluetooth: BNEP filters: protocol multicast
                    Apr 15 16:17:13 whome kernel: [   19.002876] Bluetooth: BNEP socket layer initialized
                    Apr 15 17:26:28 whome kernel: [    0.000000] Booting Linux on physical CPU 0x0
                    die sys.log hört am 15.04 00:00 auf
                    code_text
                    • wendy2702W Online
                      wendy2702W Online
                      Wie ist der PI im Netzwerk angebunden?
                      Sicher das der einen kompletten restart macht und nicht nur die Netzwerkverbindung verliert?
                      Hängt der an einem 100Mbit Port ?
                      Was ist da noch alles direkt oder indirekt per Bluetooth angeschlossen?
                      • wendy2702W wendy2702
                        Uwe Waizmann
                        @wendy2702
                        er hängt direkt mit Kabel an einer Fritzbox
                        Bluetooth ist gar nichts dran.
                        Sonst ist seit gestern über den Hub nur die Tastatur und die Maus angeschlossen.
                        Nein, er hängt dann komplett, kann mit Tastatur nichts mehr machen, nur noch Stecker ziehen.
                        Bei früheren Abstürzen konnte ich ihn noch an pingen, hab ich heute aber nicht probiert.
                        Per putty komme ich dann aber auch nicht mehr dran.
                        • Uwe WaizmannU Uwe Waizmann
                          @wendy2702
                          wendy2702W Online
                          wendy2702W Online
                          @uwe-waizmann Und die FB hat nur 100Mbit Ports oder wird im Energiesparmode betrieben?
                            Uwe Waizmann
                            @wendy2702
                            Und es ist gerade wieder passiert :-(
                            Kann jetzt aber sagen wann genau.
                            Beim Kaffee trinken schau ich mit der APP auf die VIS, alles ok, auch Refresh funktioniert.
                            Ich wecke meinen PC auf, wo iobroker und VIS im Browser offen sind, dann bleibt er stehen.
                            Ping geht noch, ssh keine Chance mehr, er steht da wie eingefroren.
                            Der Port war im Green Mode mit 100Mbit/s, hab ihn jetzt umgeschaltet auf 1Gbit/s.
                            hier der Log vor dem Absturz.
                            Etwas seltsam finde ich den Sprung der Uhrzeit von 8:44 zurück auf 8:17
                            	2021-04-16 09:11:08.079	error	(3092) info.0 already running
                            host.whome	2021-04-16 09:11:05.914	info	instance system.adapter.info.0 started with pid 3092
                            host.whome	2021-04-16 09:11:03.695	info	Restart adapter system.adapter.followthesun.0 because enabled
                            host.whome	2021-04-16 09:11:03.694	error	instance system.adapter.followthesun.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            followthesun.0	2021-04-16 09:11:03.070	warn	(2739) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            followthesun.0	2021-04-16 09:11:03.066	error	(2739) followthesun.0 already running
                            host.whome	2021-04-16 09:11:01.906	info	instance system.adapter.followthesun.0 started with pid 2739
                            host.whome	2021-04-16 09:10:59.818	info	Restart adapter system.adapter.fb-checkpresence.0 because enabled
                            host.whome	2021-04-16 09:10:59.817	error	instance system.adapter.fb-checkpresence.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            fb-checkpresence.0	2021-04-16 09:10:59.245	warn	(2354) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            fb-checkpresence.0	2021-04-16 09:10:59.243	error	(2354) fb-checkpresence.0 already running
                            host.whome	2021-04-16 08:17:34.535	info	instance system.adapter.fb-checkpresence.0 started with pid 2354
                            host.whome	2021-04-16 08:17:32.241	info	Restart adapter system.adapter.discovery.0 because enabled
                            host.whome	2021-04-16 08:17:32.240	error	instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            discovery.0	2021-04-16 08:17:31.663	warn	(2032) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            discovery.0	2021-04-16 08:17:31.660	error	(2032) discovery.0 already running
                            host.whome	2021-04-16 08:17:30.513	info	instance system.adapter.discovery.0 started with pid 2032
                            host.whome	2021-04-16 08:17:28.574	info	Restart adapter system.adapter.cloud.0 because enabled
                            host.whome	2021-04-16 08:17:28.573	error	instance system.adapter.cloud.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            cloud.0	2021-04-16 08:17:27.996	warn	(1697) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            cloud.0	2021-04-16 08:17:27.993	error	(1697) cloud.0 already running
                            host.whome	2021-04-16 08:17:26.529	info	instance system.adapter.cloud.0 started with pid 1697
                            host.whome	2021-04-16 08:17:24.403	info	Restart adapter system.adapter.chromecast.0 because enabled
                            host.whome	2021-04-16 08:17:24.402	error	instance system.adapter.chromecast.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            host.whome	2021-04-16 08:17:24.402	error	Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
                            host.whome	2021-04-16 08:17:24.402	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:352:25)
                            host.whome	2021-04-16 08:17:24.401	error	Caught by controller[0]: at process.exit (internal/process/per_thread.js:168:15)
                            host.whome	2021-04-16 08:17:24.401	error	Caught by controller[0]: at process.emit (events.js:314:20)
                            host.whome	2021-04-16 08:17:24.400	error	Caught by controller[0]: at Object.onceWrapper (events.js:421:26)
                            host.whome	2021-04-16 08:17:24.400	error	Caught by controller[0]: at process.stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8620:22)
                            host.whome	2021-04-16 08:17:24.400	error	Caught by controller[0]: at Adapter.emit (events.js:314:20)
                            host.whome	2021-04-16 08:17:24.399	error	Caught by controller[0]: at Adapter.unload (/opt/iobroker/node_modules/iobroker.chromecast/main.js:79:19)
                            host.whome	2021-04-16 08:17:24.399	error	Caught by controller[0]: TypeError: Cannot read property 'info' of undefined
                            chromecast.0	2021-04-16 08:17:23.756	warn	(1338) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            chromecast.0	2021-04-16 08:17:23.754	error	(1338) chromecast.0 already running
                            host.whome	2021-04-16 08:17:23.464	info	Restart adapter system.adapter.backitup.0 because enabled
                            host.whome	2021-04-16 08:17:23.463	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            backitup.0	2021-04-16 08:17:22.811	warn	(986) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            backitup.0	2021-04-16 08:17:22.807	error	(986) backitup.0 already running
                            host.whome	2021-04-16 08:17:22.444	info	instance system.adapter.chromecast.0 started with pid 1338
                            host.whome	2021-04-16 08:17:18.432	info	instance system.adapter.backitup.0 started with pid 986
                            host.whome	2021-04-16 08:17:16.950	info	Restart adapter system.adapter.admin.0 because enabled
                            host.whome	2021-04-16 08:17:16.949	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            admin.0	2021-04-16 08:17:16.350	warn	(799) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            admin.0	2021-04-16 08:17:16.347	error	(799) admin.0 already running
                            host.whome	2021-04-16 08:17:14.531	info	instance system.adapter.admin.0 started with pid 799
                            host.whome	2021-04-16 08:17:14.412	info	starting 19 instances
                            host.whome	2021-04-16 08:17:14.353	info	25 instances found
                            host.whome	2021-04-16 08:17:13.756	info	added notifications configuration of host
                            host.whome	2021-04-16 08:17:13.702	info	connected to Objects and States
                            host.whome-Server	2021-04-16 08:17:13.563	error	Cannot load /opt/iobroker/iobroker-data/states.json: /opt/iobroker/iobroker-data/states.json: Unexpected end of JSON input. Try last Backup!
                            host.whome	2021-04-16 08:17:13.068	info	ip addresses: fe80::d8:6431:90b3:eeab
                            host.whome	2021-04-16 08:17:13.067	info	hostname: whome, node: v12.22.1
                            host.whome	2021-04-16 08:17:13.066	info	Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                            web.0	2021-04-16 08:44:55.078	info
                            web.0	2021-04-16 08:44:55.078	info	(7199) <==Disconnect system.user.admin from ::ffff:192.168.1.30
                            web.0	2021-04-16 08:44:41.152	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
                            web.0	2021-04-16 08:44:41.019	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
                            web.0	2021-04-16 08:42:25.371	info	(7199) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                            web.0	2021-04-16 08:42:25.200	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
                            web.0	2021-04-16 08:42:25.078	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
                            web.0	2021-04-16 08:37:19.727	info	(7199) <==Disconnect system.user.admin from ::ffff:192.168.1.30 vis.0
                            web.0	2021-04-16 08:32:53.878	info	(7199) ==>Connected system.user.admin from ::ffff:192.168.1.30
                              @wendy2702
                              wendy2702W Online
                              wendy2702W Online
                              @uwe-waizmann Blöde Frage: dein Rechner und PI haben nicht zufällig dieselbe IP Adresse ?
                              Thomas BraunT Uwe WaizmannU 2 Antworten Letzte Antwort
                                @wendy2702 sagte in Seltsame Abstürze RPI4:
                                Haben alle die 127.0.0.1!
                                OliverIOO wendy2702W 2 Antworten Letzte Antwort
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @thomas-braun said in Seltsame Abstürze RPI4:
                                  hey, die hab ich auch
                                  Meine Adapter und Widgets
                                  Links im Profil
                                  • OliverIOO OliverIO
                                    #66
                                    @oliverio Gib die zurück! Die ist mir! :-D
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #67
                                      musst einen Antrag bei https://www.iana.org/ stellen.
                                      Links im Profil
                                        wendy2702W Online
                                        wendy2702W Online
                                        #68
                                        @thomas-braun Menno....
                                        Dachte immer das wäre meine 😥
                                          Uwe Waizmann
                                          #69
                                          @wendy2702
                                          Nein, haben alle zugewiesene IP, sonst würd ich bei den vielen Geräten nicht mehr durchblicken
