  4. Zwei Bugs mit backitup 2.1.0 und 2.0.5
    6.5k
38 Beiträge 6 Kommentatoren 5.5k Aufrufe 5 Beobachtet
  • wendy2702W wendy2702
    @buddinski88 kannst du mal das komplette Log vom Backupitup adapter im Debug mode posten.
    Buddinski88
    @wendy2702, klar gerne. Hab eben den Debugmodus aktiviert und anbei das Log.
    backitup.0	2021-04-02 14:21:33.253	debug	(283789) [iobroker] exec: done
    backitup.0	2021-04-02 14:21:33.101	debug	(283789) [iobroker/umount] done
    backitup.0	2021-04-02 14:21:33.100	debug	(283789) [iobroker/umount] umount successfully completed
    backitup.0	2021-04-02 14:21:28.069	debug	(283789) [iobroker/umount] mount activ, umount is started ...
    backitup.0	2021-04-02 14:21:27.906	debug	(283789) [iobroker/historyJSON] done
    backitup.0	2021-04-02 14:21:27.905	debug	(283789) [iobroker/historyJSON] new history json values created
    backitup.0	2021-04-02 14:21:27.747	debug	(283789) [iobroker/historyHTML] done
    backitup.0	2021-04-02 14:21:27.746	debug	(283789) [iobroker/historyHTML] new history html values created
    backitup.0	2021-04-02 14:21:27.290	debug	(283789) [iobroker/pushover] done
    backitup.0	2021-04-02 14:21:27.289	debug	(283789) sendTo "send" to system.adapter.pushover.1 from system.adapter.backitup.0
    backitup.0	2021-04-02 14:21:26.977	debug	(283789) [iobroker/clean] done
    backitup.0	2021-04-02 14:21:26.977	debug	(283789) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
    backitup.0	2021-04-02 14:21:26.374	debug	(283789) [iobroker/cifs] done
    backitup.0	2021-04-02 14:21:25.619	debug	(283789) [iobroker/grafana] done
    backitup.0	2021-04-02 14:21:25.619	debug	(283789) [iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    backitup.0	2021-04-02 14:21:24.845	debug	(283789) [iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    backitup.0	2021-04-02 14:21:24.844	debug	(283789) [iobroker/grafana] Backup created: /opt/iobroker/backups/grafana_2021_04_02-14_21_19_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:21:19.580	debug	(283789) [iobroker/grafana] start Grafana backup compress ...
    backitup.0	2021-04-02 14:21:19.579	debug	(283789) [iobroker/grafana] found Dashboard: system
    backitup.0	2021-04-02 14:21:19.576	debug	(283789) [iobroker/grafana] found Dashboard: fritz-box-router-status
    backitup.0	2021-04-02 14:21:19.565	debug	(283789) [iobroker/grafana] found Dashboard: heizung
    backitup.0	2021-04-02 14:21:19.556	debug	(283789) [iobroker/grafana] found Dashboard: octoprint
    backitup.0	2021-04-02 14:21:19.520	debug	(283789) [iobroker/grafana] found Dashboard: proxmox
    backitup.0	2021-04-02 14:21:19.492	debug	(283789) [iobroker/grafana] found Dashboard: homematic
    backitup.0	2021-04-02 14:21:19.251	debug	(283789) [iobroker/grafana] Grafana is available ... Status: 200
    backitup.0	2021-04-02 14:21:19.218	debug	(283789) [iobroker/grafana] start Grafana request ...
    backitup.0	2021-04-02 14:21:19.217	debug	(283789) [iobroker/grafana] Created datasource directory
    backitup.0	2021-04-02 14:21:19.214	debug	(283789) [iobroker/grafana] Created dashboards_manually_restore directory
    backitup.0	2021-04-02 14:21:19.210	debug	(283789) [iobroker/grafana] Created dashboard directory
    backitup.0	2021-04-02 14:21:19.205	debug	(283789) [iobroker/grafana] Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    backitup.0	2021-04-02 14:21:19.199	debug	(283789) [iobroker/grafana] Start Grafana Backup ...
    backitup.0	2021-04-02 14:21:19.047	debug	(283789) [iobroker/zigbee] done
    backitup.0	2021-04-02 14:21:19.046	debug	(283789) [iobroker/zigbee] found zigbee database: zigbee.0
    backitup.0	2021-04-02 14:21:18.441	debug	(283789) [iobroker/mysql] mysqldump: Couldn't execute 'SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, '$."number-of-buckets-specified"') FROM information_schema.COLU
    backitup.0	2021-04-02 14:21:18.441	debug	(283789) [iobroker/mysql] mysqldump: [Warning] Using a password on the command line interface can be insecure.
    backitup.0	2021-04-02 14:21:18.440	debug	(283789) [iobroker/mysql] [IGNORED] Error: Command failed: mysqldump -u iobrokerAdmin -p**** iobroker -h mysql -P 3306 --quick > /opt/iobroker/backups/mysql_2021_04_02-14_21_18_backupiobroker.sql
    backitup.0	2021-04-02 14:21:18.065	debug	(283789) [iobroker/iobroker] done
    backitup.0	2021-04-02 14:21:17.031	debug	(283789) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_04_02-14_21_04_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:21:07.438	debug	(283789) [iobroker/iobroker] host.iobroker-prod 19358 objects saved
    backitup.0	2021-04-02 14:21:07.379	debug	(283789) [iobroker/iobroker] host.iobroker-prod 18329 states saved
    backitup.0	2021-04-02 14:21:04.275	debug	(283789) [iobroker/mount] done
    backitup.0	2021-04-02 14:21:04.273	debug	(283789) [iobroker/mount] mount successfully completed
    backitup.0	2021-04-02 14:20:54.695	debug	(283789) detect last backup file: iobroker_2021_04_02-08_58_59_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.694	debug	(283789) detect backup file 19 from cifs: iobroker_2021_04_02-08_58_59_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.694	debug	(283789) detect backup file 18 from cifs: iobroker_2021_04_02-08_50_10_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.694	debug	(283789) detect backup file 17 from cifs: iobroker_2021_04_02-08_44_33_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.694	debug	(283789) detect backup file 16 from cifs: iobroker_2021_04_02-07_28_43_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.693	debug	(283789) detect backup file 15 from cifs: iobroker_2021_04_02-07_24_05_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.693	debug	(283789) detect backup file 14 from cifs: iobroker_2021_04_02-07_04_48_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.693	debug	(283789) detect backup file 13 from cifs: iobroker_2021_04_02-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.693	debug	(283789) detect backup file 12 from cifs: iobroker_2021_04_01-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.692	debug	(283789) detect backup file 11 from cifs: iobroker_2021_03_31-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.692	debug	(283789) detect backup file 10 from cifs: iobroker_2021_03_30-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.692	debug	(283789) detect backup file 9 from cifs: iobroker_2021_03_29-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.692	debug	(283789) detect backup file 8 from cifs: iobroker_2021_03_28-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.691	debug	(283789) detect backup file 7 from cifs: iobroker_2021_03_27-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.691	debug	(283789) detect backup file 6 from cifs: iobroker_2021_03_26-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.691	debug	(283789) detect backup file 5 from cifs: iobroker_2021_03_25-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.691	debug	(283789) detect backup file 4 from cifs: iobroker_2021_03_24-00_00_22_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.691	debug	(283789) detect backup file 3 from cifs: iobroker_2021_03_23-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.690	debug	(283789) detect backup file 2 from cifs: iobroker_2021_03_22-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.690	debug	(283789) detect backup file 1 from cifs: iobroker_2021_03_21-00_00_21_backupiobroker.tar.gz
    backitup.0	2021-04-02 14:20:54.092	debug	(283789) [iobroker/mount] umount successfully completed
    backitup.0	2021-04-02 14:20:54.049	debug	(283789) [iobroker/mount] mount activ... umount is started before mount!!
    backitup.0	2021-04-02 14:20:54.040	debug	(283789) Backup has started ...
    backitup.0	2021-04-02 14:20:54.029	error	(283789) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
    backitup.0	2021-04-02 14:20:51.862	debug	(283789) mount successfully completed
    backitup.0	2021-04-02 14:20:51.392	debug	(283789) telegram-instance:
    backitup.0	2021-04-02 14:20:50.206	info	(283789) [ccu] backup was activated at 01:30 every 3 day(s)
    backitup.0	2021-04-02 14:20:50.184	info	(283789) [iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0	2021-04-02 14:20:50.117	info	(283789) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.0, js-controller: 3.2.16
    backitup.0	2021-04-02 14:20:50.107	info	(283789) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    backitup.0	2021-04-02 14:20:50.104	debug	(283789) Plugin sentry Initialize Plugin (enabled=true)
    backitup.0	2021-04-02 14:20:49.215	debug	(283789) statesDB connected
    backitup.0	2021-04-02 14:20:49.215	debug	(283789) States connected to redis: 127.0.0.1:9000
    backitup.0	2021-04-02 14:20:49.199	debug	(283789) States create User PubSub Client
    backitup.0	2021-04-02 14:20:49.198	debug	(283789) States create System PubSub Client
    backitup.0	2021-04-02 14:20:49.162	debug	(283789) Redis States: Use Redis connection: 127.0.0.1:9000
    backitup.0	2021-04-02 14:20:49.160	debug	(283789) objectDB connected
    backitup.0	2021-04-02 14:20:49.154	debug	(283789) Objects connected to redis: 127.0.0.1:9001
    backitup.0	2021-04-02 14:20:49.138	debug	(283789) Objects client initialize lua scripts
    backitup.0	2021-04-02 14:20:49.138	debug	(283789) Objects create User PubSub Client
    backitup.0	2021-04-02 14:20:49.137	debug	(283789) Objects create System PubSub Client
    backitup.0	2021-04-02 14:20:49.136	debug	(283789) Objects client ready ... initialize now
    backitup.0	2021-04-02 14:20:49.114	debug	(283789) Redis Objects: Use Redis connection: 127.0.0.1:9001
    backitup.0	2021-04-02 14:20:44.432	info	(3546) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    backitup.0	2021-04-02 14:20:44.431	info	(3546) terminating
    backitup.0	2021-04-02 14:20:44.430	info	(3546) cleaned everything up...
    backitup.0	2021-04-02 14:20:44.429	info	(3546) Got terminate signal TERMINATE_YOURSELF
    • B Buddinski88
      simatecS Offline
      simatecS Offline
      simatec
      @buddinski88
      Stelle mal zum testen den mount aus und erstelle das Backup mal lokal.
      So wie ich das sehe, passt irgendwas mit deinen Rechten auf dem NAS nicht
      Das würde auch erklären, warum Backitup auf dem NAS die alten Files nicht löschen kann
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • simatecS simatec
        @buddinski88
        Buddinski88
        @simatec danke das du auch mit auf die Fehler schaust.
        Ich habe gerade einen Test gemacht (NAS) ist deaktiviert und Debug des Adapters an.
        Leider kommen beide Fehlermeldungen immer noch:
        backitup.0	2021-04-02 19:35:43.969	debug	(701811) [iobroker] exec: done
        backitup.0	2021-04-02 19:35:43.663	debug	(701811) [iobroker/historyJSON] done
        backitup.0	2021-04-02 19:35:43.663	debug	(701811) [iobroker/historyJSON] new history json values created
        backitup.0	2021-04-02 19:35:43.508	debug	(701811) [iobroker/historyHTML] done
        backitup.0	2021-04-02 19:35:43.507	debug	(701811) [iobroker/historyHTML] new history html values created
        backitup.0	2021-04-02 19:35:43.052	debug	(701811) [iobroker/pushover] done
        backitup.0	2021-04-02 19:35:43.051	debug	(701811) sendTo "send" to system.adapter.pushover.1 from system.adapter.backitup.0
        backitup.0	2021-04-02 19:35:42.743	debug	(701811) [iobroker/clean] done
        backitup.0	2021-04-02 19:35:42.742	debug	(701811) [iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
        backitup.0	2021-04-02 19:35:41.382	debug	(701811) [iobroker/grafana] done
        backitup.0	2021-04-02 19:35:41.381	debug	(701811) [iobroker/grafana] Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        backitup.0	2021-04-02 19:35:41.369	debug	(701811) [iobroker/grafana] Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
        backitup.0	2021-04-02 19:35:41.368	debug	(701811) [iobroker/grafana] Backup created: /opt/iobroker/backups/grafana_2021_04_02-19_35_36_backupiobroker.tar.gz
        backitup.0	2021-04-02 19:35:36.218	debug	(701811) [iobroker/grafana] start Grafana backup compress ...
        backitup.0	2021-04-02 19:35:36.217	debug	(701811) [iobroker/grafana] found Dashboard: system
        backitup.0	2021-04-02 19:35:36.193	debug	(701811) [iobroker/grafana] found Dashboard: proxmox
        backitup.0	2021-04-02 19:35:36.189	debug	(701811) [iobroker/grafana] found Dashboard: fritz-box-router-status
        backitup.0	2021-04-02 19:35:36.184	debug	(701811) [iobroker/grafana] found Dashboard: octoprint
        backitup.0	2021-04-02 19:35:36.122	debug	(701811) [iobroker/grafana] found Dashboard: heizung
        backitup.0	2021-04-02 19:35:36.070	debug	(701811) [iobroker/grafana] found Dashboard: homematic
        backitup.0	2021-04-02 19:35:35.832	debug	(701811) [iobroker/grafana] Grafana is available ... Status: 200
        backitup.0	2021-04-02 19:35:35.786	debug	(701811) [iobroker/grafana] start Grafana request ...
        backitup.0	2021-04-02 19:35:35.785	debug	(701811) [iobroker/grafana] Created datasource directory
        backitup.0	2021-04-02 19:35:35.785	debug	(701811) [iobroker/grafana] Created dashboards_manually_restore directory
        backitup.0	2021-04-02 19:35:35.784	debug	(701811) [iobroker/grafana] Created dashboard directory
        backitup.0	2021-04-02 19:35:35.784	debug	(701811) [iobroker/grafana] Created grafana_tmp directory
        backitup.0	2021-04-02 19:35:35.783	debug	(701811) [iobroker/grafana] old grafana_tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
        backitup.0	2021-04-02 19:35:35.777	debug	(701811) [iobroker/grafana] Try deleting the old grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
        backitup.0	2021-04-02 19:35:35.777	debug	(701811) [iobroker/grafana] Start Grafana Backup ...
        backitup.0	2021-04-02 19:35:35.625	debug	(701811) [iobroker/zigbee] done
        backitup.0	2021-04-02 19:35:35.624	debug	(701811) [iobroker/zigbee] found zigbee database: zigbee.0
        backitup.0	2021-04-02 19:35:35.019	debug	(701811) [iobroker/mysql] mysqldump: Couldn't execute 'SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, '$."number-of-buckets-specified"') FROM information_schema.COLU
        backitup.0	2021-04-02 19:35:35.019	debug	(701811) [iobroker/mysql] mysqldump: [Warning] Using a password on the command line interface can be insecure.
        backitup.0	2021-04-02 19:35:35.018	debug	(701811) [iobroker/mysql] [IGNORED] Error: Command failed: mysqldump -u iobrokerAdmin -p**** iobroker -h mysql -P 3306 --quick > /opt/iobroker/backups/mysql_2021_04_02-19_35_34_backupiobroker.sql
        backitup.0	2021-04-02 19:35:34.672	debug	(701811) [iobroker/iobroker] done
        backitup.0	2021-04-02 19:35:33.643	debug	(701811) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2021_04_02-19_35_19_backupiobroker.tar.gz
        backitup.0	2021-04-02 19:35:23.246	debug	(701811) [iobroker/iobroker] host.iobroker-prod 19372 objects saved
        backitup.0	2021-04-02 19:35:23.185	debug	(701811) [iobroker/iobroker] host.iobroker-prod 18340 states saved
        backitup.0	2021-04-02 19:35:19.564	debug	(701811) Backup has started ...
        backitup.0	2021-04-02 19:35:04.889	debug	(701811) telegram-instance:
        backitup.0	2021-04-02 19:35:03.836	debug	(701811) No backup file was found
        backitup.0	2021-04-02 19:35:03.828	info	(701811) [ccu] backup was activated at 01:30 every 3 day(s)
        backitup.0	2021-04-02 19:35:03.799	info	(701811) [iobroker] backup was activated at 02:40 every 1 day(s)
        backitup.0	2021-04-02 19:35:03.732	info	(701811) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.20.0, js-controller: 3.2.16
        backitup.0	2021-04-02 19:35:03.723	info	(701811) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
        backitup.0	2021-04-02 19:35:03.719	debug	(701811) Plugin sentry Initialize Plugin (enabled=true)
        backitup.0	2021-04-02 19:35:03.178	debug	(701811) statesDB connected
        backitup.0	2021-04-02 19:35:03.177	debug	(701811) States connected to redis: 127.0.0.1:9000
        backitup.0	2021-04-02 19:35:03.164	debug	(701811) States create User PubSub Client
        backitup.0	2021-04-02 19:35:03.163	debug	(701811) States create System PubSub Client
        backitup.0	2021-04-02 19:35:03.147	debug	(701811) Redis States: Use Redis connection: 127.0.0.1:9000
        backitup.0	2021-04-02 19:35:03.145	debug	(701811) objectDB connected
        backitup.0	2021-04-02 19:35:03.136	debug	(701811) Objects connected to redis: 127.0.0.1:9001
        backitup.0	2021-04-02 19:35:03.112	debug	(701811) Objects client initialize lua scripts
        backitup.0	2021-04-02 19:35:03.111	debug	(701811) Objects create User PubSub Client
        backitup.0	2021-04-02 19:35:03.110	debug	(701811) Objects create System PubSub Client
        backitup.0	2021-04-02 19:35:03.084	debug	(701811) Objects client ready ... initialize now
        backitup.0	2021-04-02 19:35:02.953	debug	(701811) Redis Objects: Use Redis connection: 127.0.0.1:9001
        • B Buddinski88
          simatecS Offline
          simatecS Offline
          simatec
          @buddinski88
          Das liegt aber nicht an Backitup.
          Backitup verwendet die mysqldump und den originalen Backup Prozess von mysql.
          Deine Datenbank hat ein Problem.
          Schaue dir mal deine Datenbank genauer an.
          Die zweite Meldung im clean ist die Konsequenz daraus.
          Es werden keine Backups gelöscht, da die neuen Backups fehlerhaft sind.
          • simatecS simatec
            @buddinski88
            Buddinski88
            @simatec, guten morgen. Ich habe mir die Datenbank mal angeschaut.
            Das Statement wird entweder im Log abgeschnitten oder ist falsch, denn die Tabelle COLU gibt es nicht, sondern nur COLUMNS.
            Daraus ergibt sich dann folgendes Statement:
            SELECT COLUMN_NAME, JSON_EXTRACT(HISTOGRAM, '$."number-of-buckets-specified"') FROM information_schema.COLUMNS
            Dann kommt aber schon die nächste Meldung, wenn ich das in PhpMyAdmin ausführe:
            #1054 - Unbekanntes Tabellenfeld 'HISTOGRAM' in field list
            Kennst du eine Möglichkeit die Datenbank zu reparieren?
            wendy2702W metaxaM 2 Antworten Letzte Antwort
            • B Buddinski88
              wendy2702W Online
              wendy2702W Online
              @buddinski88 nur am Handy gesucht, passt das :
              https://serverfault.com/questions/912162/mysqldump-throws-unknown-table-column-statistics-in-information-schema-1109
              • B Buddinski88
                metaxaM Offline
                metaxaM Offline
                metaxa
                @buddinski88 sagte in Zwei Bugs mit backitup 2.1.0 und 2.0.5:
                Servus, hast du eine machbare Reparaturmöglichkeit gefunden? Den Link von @wendy2702 habe ich mir angesehen, scheitere an meinen rudimentären mySQL sowie Englischkenntnissen. Das Tool "MySqlRepairToolbox" habe ich mir runtergeladen, kann dort aber nicht meine MariaDB 5 auf der Syno auswählen.
                Oder hat irgend ein anderer WIssender die Zeit und Muße mir zu helfen?
                Meine Fehlermeldung im Backitup Adapter:
                BackItUp:
                Your backup was not completely created. Please check the errors!!
                mysql: Error: Command failed: mysqldump  -u andreas -p**** ioBroker -h 192.168.0.98 -P 3306 --quick --single-transaction > /opt/iobroker/backups/mysql_2021_04_13-02_15_50_backupiobroker.sql
                /bin/sh: 1: mysqldump: not found
                • metaxaM metaxa
                  BackItUp:
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @metaxa schaue mal bitte in die Doku ...
                  https://github.com/simatec/ioBroker.backitup/blob/master/docs/de/backitup.md#mysql-backup
                  metaxaM 1 Antwort Letzte Antwort
                  • simatecS simatec
                    metaxaM Offline
                    metaxaM Offline
                    metaxa
                    schrieb am zuletzt editiert von metaxa
                    @simatec sagte in Zwei Bugs mit backitup 2.1.0 und 2.0.5:
                    Danke dir, hätte ich selbst drauf kommen können ☝ !
                    Nur jetzt bin ich irgendwie tiefer reingerutscht.
                    1. "sudo apt-get install mysql-client" fehlerfrei durchgeführt
                    2. neue Fehlermeldung:
                    mount: Error: Command failed: sudo mount -t cifs -o username=Andreas,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.0.98/backups/io_096_vm /opt/iobroker/backups mount error(16): Device or resource busy Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
                    1. Nachgelesen in der Doku und im Log:
                    (2451) [iobroker] Backup folder not created: Error: EPERM: operation not permitted, chmod '/opt/iobroker/backups'Please reinstall backitup and run "iobroker fix"!!
                    1. BackitUp drüberinstalliert und anschließend den Fixer erfolgreich ausgeführt.
                    2. Neue Fehlermeldung:
                    mysql: Error: Command failed: mysqldump  -u andreas -p**** ioBroker -h 192.168.0.98 -P 3306 --quick --single-transaction > /opt/iobroker/backups/mysql_2021_04_13-13_43_34_backupiobroker.sql
                    /bin/sh: 1: cannot create /opt/iobroker/backups/mysql_2021_04_13-13_43_34_backupiobroker.sql: Permission denied
                    1. Jetzt habe ich mittels WinSCP den backup Ordner angesehen und festgestellt, da sind ein Haufen backups drinnen (SQL Backups alle mit 0KB) Ich habe jetzt einmal alle Dateien gelöscht.
                    2. Ich komme einfach nicht weiter, hier das Log. Irgendwas darf iO irgendwo nicht 😣
                    Started iobroker ...
                    [DEBUG] [mount] - Wake on LAN wait 10 Seconds for NAS!
                    [DEBUG] [mount] - Wake on LAN MAC-Address: 20:DE:20:DE:20:DE
                    [DEBUG] [mount] - mount activ... umount is started before mount!!
                    [DEBUG] [mount] - umount successfully completed
                    [DEBUG] [mount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****"}
                    [DEBUG] [mount] - mount successfully completed
                    [DEBUG] [mount] - done
                    [DEBUG] [iobroker] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"096_VM100","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****","context":{"fileNames":[],"errors":{},"done":["umount","mount"],"types":[]},"adapter":null},"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"cech.andreas@chello.at","emailSender":"smart-kb@inode.at","onlyError":false,"emailWaiting":60000,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [iobroker] - host.ioBroker-Prod 23419 states saved
                    [DEBUG] [iobroker] - host.ioBroker-Prod 25891 objects saved
                    [ERROR] [iobroker] - host.ioBroker-Prod Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error: EACCES: permission denied, open '/opt/iobroker/backups/iobroker_2021_04_13-14_26_33_096_VM100_backupiobroker.tar.gz'
                    [ERROR] [iobroker] - host.ioBroker-Prod Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                    [DEBUG] [iobroker] - done
                    [DEBUG] [zigbee] - found zigbee database: zigbee.0
                    [DEBUG] [zigbee] - done
                    [ERROR] [zigbee] - [IGNORED] Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz'
                    [DEBUG] [cifs] - done
                    [DEBUG] [cifs] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****","backupDir":"/opt/iobroker/backups","deleteBackupAfter":0}
                    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                    [DEBUG] [clean] - done
                    [DEBUG] [email] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"096_VM100","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_04_13-14_26_33_096_VM100_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz"],"errors":{"zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz'"},"done":["umount","mount","iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"cech.andreas@chello.at","emailSender":"smart-kb@inode.at","onlyError":false,"emailWaiting":60000,"systemLang":"de","time":"13. April 2021 um 14:26 Uhr"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [historyHTML] - new history html values created
                    [DEBUG] [historyHTML] - done
                    [DEBUG] [historyJSON] - new history json values created
                    [DEBUG] [historyJSON] - done
                    [DEBUG] [historyHTML] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"096_VM100","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_04_13-14_26_33_096_VM100_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz"],"errors":{"zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz'"},"done":["umount","mount","iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"13. April 2021 um 14:26 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"cech.andreas@chello.at","emailSender":"smart-kb@inode.at","onlyError":false,"emailWaiting":60000,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [umount] - mount activ, umount is started ...
                    [DEBUG] [historyJSON] start with {"type":"creator","time":"02:15","debugging":true,"everyXDays":"2","nameSuffix":"096_VM100","deleteBackupAfter":0,"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****","context":{"fileNames":["/opt/iobroker/backups/iobroker_2021_04_13-14_26_33_096_VM100_backupiobroker.tar.gz","/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz"],"errors":{"zigbee":"Error: EACCES: permission denied, open '/opt/iobroker/backups/zigbee.0_2021_04_13-14_26_49_backupiobroker.tar.gz'"},"done":["umount","mount","iobroker"],"types":["iobroker"]},"adapter":null},"dir":"/opt/iobroker","zigbee":{"enabled":true,"type":"creator","ftp":{"enabled":false,"type":"storage","source":"cifs","host":"","debugging":true,"deleteOldBackup":false,"ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal","user":"","pass":"****","port":"21"},"cifs":{"enabled":true,"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****"},"dropbox":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessToken":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"webdav":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"username":"username","pass":"****","url":"https://example.com/remote.php/dav/files/username/","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/iobroker"},"googledrive":{"enabled":false,"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":false,"accessJson":"****","ownDir":false,"bkpType":"Minimal","dir":"/backupDir","dirMinimal":"/backupDir/minimal"},"path":"/opt/iobroker/iobroker-data"},"historyHTML":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"13. April 2021 um 14:26 Uhr"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"none","onlyError":false,"telegramWaiting":0,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"cech.andreas@chello.at","emailSender":"smart-kb@inode.at","onlyError":false,"emailWaiting":60000,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"systemLang":"de"},"backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [umount] start with {"mountType":"NFS","type":"storage","source":"cifs","mount":"192.168.0.98","debugging":true,"fileDir":"/opt/iobroker/node_modules/iobroker.backitup","wakeOnLAN":true,"macAd":"20:DE:20:DE:20:DE","wolTime":"10","smb":"vers=1.0","sudo":true,"cifsDomain":"","deleteOldBackup":true,"ownDir":true,"bkpType":"Minimal","dir":"/volume1/backups/io_096_vm","dirMinimal":"/volume1/backups/io_096_vm","user":"Andreas","pass":"****","backupDir":"/opt/iobroker/backups"}
                    [DEBUG] [umount] - umount successfully completed
                    [DEBUG] [umount] - done
                    [EXIT] 9
                    [DEBUG] [email] - [iobroker] used E-Mail-Instance: email.0
                    [DEBUG] [email] - done
                    [EXIT] 9
                    Es ist aber sicher kein Bug im Adapter, soll ich mit meiner gesamten Anfrage ins Hauptforum übersiedeln?
                    LG
                    • metaxaM metaxa
                      [EXIT] 9
                      [EXIT] 9
                      LG
                      simatecS Offline
                      simatecS Offline
                      simatec
                      @metaxa sagte in Zwei Bugs mit backitup 2.1.0 und 2.0.5:
                      Permission denied
                      Du hast keine Rechte auf deinem NAS, um Dateien zu schreiben.
                      Was hast du für ein NAS? Zeige mal die Einstellungen von deinem NAS
                      • simatecS simatec
                        Permission denied
                        metaxaM Offline
                        metaxaM Offline
                        metaxa
                        (Muss mir mal gleich selbst auf die Schulter klopfen, ich habe alle meine Backups die im iobroker/backups gemounted waren durch meine Löschorgie auf dem NAS gelöscht :-))
                        Aktuell sind aber wieder neue Backups im Ordner:
                        Kann es sein, dass iO den Unterordner SQL nicht anlegen kann?
                        • metaxaM metaxa
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @metaxa SQL hat keinen Unterordner ...
                          Welche Version von Backitup nutzt du denn?
                          • simatecS simatec
                            metaxaM Offline
                            metaxaM Offline
                            metaxa
                            @simatec Sorry, für die späte Rückmeldung. Ich versuchte den Fehler einzugrenzen.
                            BackitUp: 2.1.0 (heute morgen upgedated) 1x Host, 1x Slave
                            Node JS: 12.19.0
                            NPM: 6.14.8
                            JS-Controller: 3.2.16
                            Es läuft jetzt alles!
                            Was mußte ich machen. Nach jeder Änderung in der Adapteroberfläche ging danach nichts mehr, endete immer in dieser Art Fehlermeldungen:
                            BackItUp:
                            Nach einem Neustart der vollständigen VM ging es dann immer auf Anhieb. Ich habe das Gefühl, dass der Unmountbefehl immer wieder hängen blieb.
                            NFS habe ich wieder rausgenommen, auch die Freigabe auf dem NAS (Screen weiter oben) und bin wieder retour auf CIFS. Paar Steps mit Zwischenkontrollen und Neustarts brachten das Ergebnis. Scheinbar ist das ändern der Cronjobs nund speichern der Config kein Problem.
                            Für Zigbee, SQL, usw. werden keine Unterverzeichnisse angeboten, auch keine eigenen Cronjobs. Die werden offensichtlich mit dem ioBroker Backup paralell angestossen.
                            Gibt es dafür einen bestimmten Grund?
                            Danke jedenfalls für den tollen Adapter und deine Muße mir heute unter "Bugs" dennoch zuhelfen.
                            LG, mxa
                            simatecS M 2 Antworten Letzte Antwort
                            • metaxaM metaxa
                              Node JS: 12.19.0
                              NPM: 6.14.8
                              BackItUp:
                              LG, mxa
                              simatecS Offline
                              simatecS Offline
                              simatec
                              @metaxa Gerne ... kein Problem
                              • metaxaM metaxa
                                Node JS: 12.19.0
                                NPM: 6.14.8
                                BackItUp:
                                LG, mxa
                                michael_4358
                                @metaxa
                                habe auf meinem pi das gleiche problem...
                                kann aber deine fehler behebung nicht ganz nach vollziehen
                                hast du einfach die alten backups gelöscht und alles neugestartet??
                                • M michael_4358
                                  @metaxa
                                  metaxaM Offline
                                  metaxaM Offline
                                  metaxa
                                  @michael_4358 was willst du alles backupen, welche adapter?
                                  • metaxaM metaxa
                                    michael_4358
                                    @metaxa ioBroker;zigbee;jarvis
                                    und wenn ich die history mit einbinde stürtzt das adapter ab
                                    • M michael_4358
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      @michael_4358
                                      Ohne Debug Log wird es schwierig dir zu helfen
                                      • simatecS simatec
                                        @michael_4358
                                        michael_4358
                                        @simatec
                                        wendy2702W simatecS 2 Antworten Letzte Antwort
                                        • M michael_4358
                                          @simatec
                                          wendy2702W Online
                                          wendy2702W Online
                                          @michael_4358 kannst du das logfile bitte als Text in Code Tags </> posten!
