  4. [gelöst] Backitup kann influxdb Datenbank nicht sichern.
    6.5k
107 Beiträge 5 Kommentatoren 15.3k Aufrufe 7 Beobachtet
  • Christian KohlöffelC Christian Kohlöffel
    @christian-kohlöffel said in Backitup kann influxdb Datenbank nicht sichern.:
    CIFS: VFS: bogus file nlink value 0
    Nun habe ich noch auf smbv3 umgestellt und siehe da
    ==> ES FUNKTIONIERT
    Vielen Dank für euren TOP Support und die Ausdauer beim Debugging ....
    Started iobroker ...
    [DEBUG] [mount] - mount activ... umount is started before mount!!
    [DEBUG] [mount] - umount successfully completed
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 2156 states saved
    [DEBUG] [iobroker] - host.raspberrypi 2575 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_12-20_52_56_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Packed 28MB so far...
    [DEBUG] [influxDB] - Packed 63MB so far...
    [DEBUG] [influxDB] - Packed 73MB so far...
    [DEBUG] [influxDB] - Packed 92MB so far...
    [DEBUG] [influxDB] - Packed 129MB so far...
    [DEBUG] [influxDB] - Packed 140MB so far...
    [DEBUG] [influxDB] - Packed 153MB so far...
    [DEBUG] [influxDB] - Packed 194MB so far...
    [DEBUG] [influxDB] - Packed 212MB so far...
    [DEBUG] [influxDB] - Packed 218MB so far...
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_04_12-20_53_07_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - done
    [DEBUG] [redis] - Start Redis Backup ...
    [DEBUG] [redis] - Created redistmp directory
    [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_12-20_57_52_backupiobroker.tar.gz
    [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
    [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
    [DEBUG] [redis] - done
    [DEBUG] [cifs] - done
    [DEBUG] [clean] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    simatecS Offline
    simatecS Offline
    simatec
    #88
    Gerne ... freut mich, dass es nun geht. Du bist zwar mir bekannt der Einzige mit diesem Problem von einigen tausend, die Backitup nutzen, aber es hilft sicher auch anderen.
    Ich werde die Option „noserverino“ in der nächsten Version in der Config auswählbar machen.
    Also bei dem nächsten Update musst du dann nochmal in der Config unter „NAS / Kopieren“ die Option auswählen.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    Christian KohlöffelC 1 Antwort Letzte Antwort
    • simatecS simatec
      Christian KohlöffelC Offline
      Christian Kohlöffel
      schrieb am zuletzt editiert von Christian Kohlöffel
      #89
      @simatec
      Komisch, es geht aber schon wieder nicht mehr ....
      Also nur einmal. Nochmaliges Backup und wieder dieselbe Fehler Meldung. Ich starte mal nochmals neu etc. und schaue nochmals mit anderen smb Versionen.
        @simatec
        simatecS Offline
        simatecS Offline
        simatec
        #90
        Hast du wie Thomas empfohlen hat die 3.1.1 ausgewählt und in der FB Konfig smb v1 deaktiviert?
        • simatecS simatec
          Christian Kohlöffel
          #91
          @simatec
          Probiere ich gleich mal aus. Nach einem Neustart scheint es dann auch wieder zu gehen.
          Jetzt mache ich das gleiche gleich nochmals ....
            @simatec
            #92
            Ist eigentlich das Verzeichnis
            leer, wenn die Fritzbox nicht gemountet ist?
              Christian Kohlöffel
              #93
              Scheint nicht so, könnte aber durch das viele ausprobieren passiert sein, oder?:
              pi@raspberrypi:/opt/iobroker/backups $ ls
              2020_10_16-11_01_16_backupiobroker.tar.gz            iobroker_2021_04_11-11_01_47_backupiobroker.tar.gz
              2020_11_14-12_17_24_backupiobroker-migration.tar.gz  iobroker_2021_04_12-11_29_39_backupiobroker.tar.gz
              influxDB_2021_04_06-13_08_09_backupiobroker          iobroker_2021_04_12-11_31_07_backupiobroker.tar.gz
              influxDB_2021_04_06-20_42_54_backupiobroker          minimal_2019_07_05-16_31_00_backupiobroker.tar.gz
              influxDB_2021_04_10-11_16_08_backupiobroker          minimal_2019_07_05-16_34_26_backupiobroker.tar.gz
              influxDB_2021_04_10-11_19_37_backupiobroker          minimal_2019_07_05-16_38_03_backupiobroker.tar.gz
              influxDB_2021_04_10-11_19_37_backupiobroker.tar.gz   minimal_2019_07_05-16_39_57_backupiobroker.tar.gz
              influxDB_2021_04_10-11_26_55_backupiobroker.tar.gz   minimal_2019_07_05-16_44_06_backupiobroker.tar.gz
              influxDB_2021_04_10-14_09_39_backupiobroker          minimal_2019_07_05-16_44_52_backupiobroker.tar.gz
              influxDB_2021_04_10-14_16_00_backupiobroker.tar.gz   minimal_2019_07_05-16_45_40_backupiobroker.tar.gz
              influxDB_2021_04_10-14_25_24_backupiobroker.tar.gz   minimal_2019_07_05-16_49_17_backupiobroker.tar.gz
              influxDB_2021_04_11-10_42_17_backupiobroker.tar.gz   minimal_2019_07_05-16_51_12_backupiobroker.tar.gz
              influxDB_2021_04_11-11_01_55_backupiobroker.tar.gz   redis_2021_04_12-11_29_53_backupiobroker.tar.gz
              iobroker_2021_04_06-13_08_01_backupiobroker.tar.gz   redis_2021_04_12-11_31_16_backupiobroker.tar.gz
              iobroker_2021_04_10-11_15_57_backupiobroker.tar.gz   total_2019_07_22-03_00_21_backupiobroker.tar.gz
              iobroker_2021_04_10-11_19_29_backupiobroker.tar.gz   total_2019_07_23-03_00_20_backupiobroker.tar.gz
              iobroker_2021_04_10-11_26_47_backupiobroker.tar.gz   total_2019_07_30-03_00_21_backupiobroker.tar.gz
              iobroker_2021_04_10-14_09_31_backupiobroker.tar.gz   total_2019_08_11-03_00_21_backupiobroker.tar.gz
              iobroker_2021_04_10-14_15_51_backupiobroker.tar.gz   total_2019_08_25-03_00_21_backupiobroker.tar.gz
              iobroker_2021_04_10-14_25_16_backupiobroker.tar.gz   total_2019_08_26-17_26_29_backupiobroker.tar.gz
              iobroker_2021_04_11-10_42_09_backupiobroker.tar.gz   total_2019_08_26-19_22_49_backupiobroker.tar.gz
              Thomas BraunT simatecS 2 Antworten Letzte Antwort
                #94
                Mountpunkte müssen/sollten leer sein. Sonst hast du da ggf Doubletten bei den inodes.
                Da deuten ja auch die Meldungen drauf hin. Mach das Verzeichnis mal leer. Entweder löschen oder da wegschieben.
                  simatecS Offline
                  simatecS Offline
                  simatec
                  #95
                  Mache mal ein
                  sudo umount /opt/iobroker/backups
                  Schaue dann nochmal ... Bei meinen Systemen liegen aber auch lokal Backups und das tut dem mount nix. Also bei mir zumindest noch nie Probleme gehabt. Nutze allerdings hauptsächlich NFS
                  Thomas BraunT Christian KohlöffelC 2 Antworten Letzte Antwort
                  • simatecS simatec
                    Mache mal ein
                    #96
                    @simatec sagte in Backitup kann influxdb Datenbank nicht sichern.:
                    Bei meinen Systemen liegen aber such lokal Backups und das tut dem mount nix
                    Solange die inodes unterschiedliche Nummerierung haben ist das auch kein großes Problem. Wenn die allerdings auf den beiden Dateisystemen gleich lautend sich überlagern hast du ein Problem.
                    • simatecS simatec
                      Mache mal ein
                      Christian Kohlöffel
                      #97
                      @simatec
                      pi@raspberrypi:/opt/iobroker/backups $ sudo umount /opt/iobroker/backups
                      umount: /opt/iobroker/backups: not mounted.
                      Soll ich das alles löschen? Wenn ja passt der Befehl?
                      sudo rm -r /opt/iobroker/backups/
                        @simatec
                        #98
                        sudo -u iobroker rm /opt/iobroker/backups/*
                          @simatec
                          simatecS Offline
                          simatecS Offline
                          simatec
                          #99
                          sudo rm -rf /opt/iobroker/backups/*
                          • simatecS simatec
                            Christian Kohlöffel
                            #100
                            @simatec
                            Super, danke euch beiden ✌
                              @simatec
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #101
                              Kein Problem ... kannst du das Thema bitte noch auf [gelöst] setzen?
                              • simatecS simatec
                                „noserverino“ wird in Backitup nicht als Option verwendet.
                                Ich könnte das aber testhalber mal einbauen
                                #102
                                @simatec sagte in [gelöst] Backitup kann influxdb Datenbank nicht sichern.:
                                Hi @simatec ,
                                ich habe jetzt auch mal mit der Option 'noserverino' herumgespielt.
                                Also bei mir muss die bei Backups von redis auf ein FritzNAS (SMB 3.1.1) auch gesetzt sein, sonst wird das Backup nicht geschrieben.
                                Vermutlich als Nebeneffekt: Jetzt funktioniert auch das gemeinsame Backup auf GoogleDrive und das FritzNAS in einer Instanz. Bislang hatte ich das in jeweils eigene Instanzen aufteilen müssen.
                                  Hi @simatec ,
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #103
                                  @thomas-braun Super ... dann hat die Funktion zu integrieren etwas positives gebracht
                                  • simatecS simatec
                                    #104
                                    @simatec
                                    Ich würde das aber vielleicht noch in die ReadMe aufnehmen.
                                    Vielleicht unter dem Punkt 'redis-Backup'.
                                    Bei anderen Typen weiß ich nicht ob die Option gesetzt werden muss.
                                    Wobei es hier ja auch um influx-Backup ging.
                                      @simatec
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #105
                                      Ja nehme ich mit auf. War die Tage nur mit der 2.1.3 beschäftigt
                                      • V Offline
                                        V Offline
                                        virFortis
                                        #106
                                        Ich wollte mich mal einfach nur bedanken. Habe heute ioBroker, Grafana und InfluxDB für die Rücksicherung eingestellt. Der ioBroker und Grafana liefen ohne Probleme aber die InfluxDb wollte und wollte einfach nicht. Problem war auch bei mir die SMB Version von 1.0. Nach euren Beiträgen und der Umstellung auf 3.1.1 werden jetzt alle in einem rutsch erfolgreich gesichert.
                                        • V virFortis
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #107
                                          @virfortis Das hört man gerne 👍
