  4. Iobroker startet nicht mehr
    6.4k
erroriobrokerstatusstartet nicht
97 Beiträge 10 Kommentatoren 17.7k Aufrufe 10 Beobachtet
  • JayRJ JayR
    @Thomas-Braun said in Iobroker startet nicht mehr:
    iobroker fix
    pi@Collector:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
    2021-01-03 10:31:38.496  - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting
    2021-01-03 10:31:38.503  - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2021-01-03 10:31:38.504  - info: host.Collector hostname: Collector, node: v12.20.0
    2021-01-03 10:31:38.506  - info: host.Collector ip addresses: 192.168.20.2 fe80::6728:fc45:40bd:6d86
    2021-01-03 10:31:40.020  - info: host.Collector  Error inMem-objects listening on port 9001
    EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:31:40.027  - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:31:40.028  - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:31:40.031  - info: host.Collector terminated. Could not reset alive status for instances
    2021-01-03 10:31:40.035  - info: host.Collector iobroker _restart
    2021-01-03 10:31:41.296  - info: host.Collector  Error inMem-states listening on port 9000
    pi@Collector:/opt/iobroker $ iobroker stop
    pi@Collector:/opt/iobroker $ iobroker fix
    library: loaded
    Library version=2020-12-07
        Welcome to the ioBroker installation fixer!
        Script version: 2020-12-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    2021-01-03 10:32:53.481  - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting
    2021-01-03 10:32:53.488  - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2021-01-03 10:32:53.489  - info: host.Collector hostname: Collector, node: v12.20.0
    2021-01-03 10:32:53.491  - info: host.Collector ip addresses: 192.168.20.2 fe80::6728:fc45:40bd:6d86
    2021-01-03 10:32:54.959  - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:32:54.960  - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:32:54.962  - info: host.Collector terminated. Could not reset alive status for instances
    2021-01-03 10:32:54.966  - info: host.Collector iobroker _restart
    Hat auch nichts gebracht. Habe vorher nochmal aufgesetzt und backup von gestern eingespielt.
    GlasfaserG Offline
    GlasfaserG Offline
    @hoss0305 sagte in Iobroker startet nicht mehr:
    Was meinst Du mit falscher Pfad?
    Er hat den Befehl
    nicht im Pfad
    /opt/iobroker
    durchgeführt , deshalb kam dann das
    Error: Cannot find module '/home/pi/node_modules/iobroker.js-controller/controller.js'
    und im Pfad
    /home/pi/
    gibt es halt kein
    • H Offline
      Hoss0305
      @glasfaser
      @Thomas-Braun
      Wie geschrieben, bekomme ich das ioBroker WebUI nicht gestartet. Dieses Problem trat heute Vormittag ohne jegliches Zutun auf. Vor einer zur nächsten Minute war ein Zugriff nicht mehr möglich.
      Wenn ich den Befehl
      eigentlich wollte ich nun den angezeigten Code einfügen, jedoch erhalte ich jedes Mal, wenn ich diesen Text absenden möchte, eine Meldung: Forbidden Fehler!
      Keine Ahnung, was nun wieder falsch läuft.
      • H Offline
        Hoss0305
        @Thomas-Braun
        Wenn ich den Befehl
        eingebe, erhalte ich
        pi@ioBroker-Pi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
        - info: host.ioBroker-Pi iobroker.js-controller version 3.2.16 js-contr                        oller starting
        - info: host.ioBroker-Pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
        - info: host.ioBroker-Pi hostname: ioBroker-Pi, node: v12.22.1
        - info: host.ioBroker-Pi ip addresses: 192.168.123.61 2a02:2f4:484e:af00:dbf8:12ef:9fbf:4984 fe80::ee08:c96b:c94e:f438
        - info: host.ioBroker-Pi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
        - error: host.ioBroker-Pi No connection to databases possible, restart
        - info: host.ioBroker-Pi iobroker _restart
        Kann mir da irgend jemand helfen, woran es liegen könnte, dass ich das ioBroker WebUI nicht gestartet bekomme.
        • H Hoss0305
          @Thomas-Braun
          Wenn ich den Befehl
          GlasfaserG Offline
          GlasfaserG Offline
          • info: host.ioBroker-Pi-Server
          Der Port 9001 wird schon auf deinem System genutzt , deshalb startet ioBroker nicht
          H 1 Antwort Letzte Antwort
          • GlasfaserG Glasfaser
            Hoss0305
            @glasfaser
            Wie kann ich denn ermitteln, wodurch der Port 9001 belegt ist, das System hat doch zuvor immer funktioniert.
            • H Hoss0305
              @glasfaser
              GlasfaserG Offline
              GlasfaserG Offline
              @hoss0305
              https://forum.iobroker.net/topic/43839/gelöst-ich-bekomme-den-iobroker-auf-nuc-nicht-ans-laufen?_=1617990930977
                @hoss0305
                Hoss0305
                @glasfaser
                Wenn ich mit
                netstat
                da rangehe, erhalte ich:
                pi@ioBroker-Pi:/opt/iobroker $ netstat
                Aktive Internetverbindungen (ohne Server)
                Proto Recv-Q Send-Q Local Address           Foreign Address         State
                tcp        0      0 localhost:49308         localhost:9001          VERBUNDEN
                tcp        0      0 ioBroker-Pi-WLAN.:45890 FR-PAR-ANX-R009.te:5938 VERBUNDEN
                tcp        0      0 localhost:9001          localhost:49308         VERBUNDEN
                tcp        0      0 localhost:44256         localhost:9000          VERBUNDEN
                tcp        0      0 localhost:49310         localhost:9001          VERBUNDEN
                tcp        0      0 localhost:9000          localhost:44258         VERBUNDEN
                tcp        0    240 ioBroker-Pi-WLAN.fr:ssh MININT-91OJ9JA.fr:54023 VERBUNDEN
                tcp        0      0 localhost:9000          localhost:44256         VERBUNDEN
                tcp        0      0 localhost:9001          localhost:49310         VERBUNDEN
                tcp        0      0 localhost:44258         localhost:9000          VERBUNDEN
                Aktive Sockets in der UNIX-Dom▒ne (ohne Server)
                Proto RefCnt Flags       Type       State         I-Node   Pfad
                unix  2      [ ]         DGRAM                    10511    /run/systemd/journal/syslog
                unix  14     [ ]         DGRAM                    10535    /run/systemd/journal/dev-log
                unix  2      [ ]         DGRAM                    14650    /var/run/wpa_supplicant/wlan0
                unix  2      [ ]         DGRAM                    14655    /var/run/wpa_supplicant/p2p-dev-wlan0
                unix  3      [ ]         DGRAM                    10446    /run/systemd/notify
                unix  2      [ ]         DGRAM                    16602    /run/user/1000/systemd/notify
                unix  7      [ ]         DGRAM                    10465    /run/systemd/journal/socket
                unix  2      [ ]         DGRAM                    15598
                unix  3      [ ]         STREAM     VERBUNDEN     12767    /var/run/dbus/system_bus_socket
                unix  3      [ ]         STREAM     VERBUNDEN     15875    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     15053
                unix  3      [ ]         STREAM     VERBUNDEN     15071
                unix  3      [ ]         STREAM     VERBUNDEN     15605
                unix  3      [ ]         STREAM     VERBUNDEN     6135
                unix  3      [ ]         STREAM     VERBUNDEN     12193
                unix  3      [ ]         STREAM     VERBUNDEN     12764    /var/run/dbus/system_bus_socket
                unix  3      [ ]         STREAM     VERBUNDEN     6137     /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     13764    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     15536
                unix  3      [ ]         STREAM     VERBUNDEN     14281    /var/run/dbus/system_bus_socket
                unix  2      [ ]         DGRAM                    15540
                unix  2      [ ]         DGRAM                    14511
                unix  2      [ ]         DGRAM                    15706
                unix  3      [ ]         STREAM     VERBUNDEN     14561
                unix  3      [ ]         STREAM     VERBUNDEN     15974
                unix  3      [ ]         STREAM     VERBUNDEN     13928    /var/run/dbus/system_bus_socket
                unix  3      [ ]         STREAM     VERBUNDEN     15973
                unix  2      [ ]         DGRAM                    10664
                unix  3      [ ]         STREAM     VERBUNDEN     15549    /run/systemd/journal/stdout
                unix  3      [ ]         DGRAM                    5963
                unix  3      [ ]         DGRAM                    10668
                unix  3      [ ]         STREAM     VERBUNDEN     12651
                unix  3      [ ]         DGRAM                    5962
                unix  3      [ ]         STREAM     VERBUNDEN     10660
                unix  3      [ ]         STREAM     VERBUNDEN     5452     /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     13569    /run/systemd/journal/stdout
                unix  2      [ ]         DGRAM                    5960
                unix  3      [ ]         DGRAM                    10667
                unix  3      [ ]         STREAM     VERBUNDEN     12548
                unix  3      [ ]         STREAM     VERBUNDEN     14041    /var/run/dbus/system_bus_socket
                unix  3      [ ]         STREAM     VERBUNDEN     12649
                unix  2      [ ]         DGRAM                    12900
                unix  3      [ ]         STREAM     VERBUNDEN     12788
                unix  3      [ ]         STREAM     VERBUNDEN     16608
                unix  2      [ ]         DGRAM                    12646
                unix  2      [ ]         DGRAM                    5340
                unix  2      [ ]         DGRAM                    12550
                unix  3      [ ]         STREAM     VERBUNDEN     14736    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     17451    /var/run/dbus/system_bus_socket
                unix  3      [ ]         STREAM     VERBUNDEN     12648
                unix  3      [ ]         STREAM     VERBUNDEN     12902
                unix  3      [ ]         STREAM     VERBUNDEN     14497    /run/systemd/journal/stdout
                unix  3      [ ]         DGRAM                    16605
                unix  3      [ ]         STREAM     VERBUNDEN     12761
                unix  3      [ ]         STREAM     VERBUNDEN     12762
                unix  3      [ ]         STREAM     VERBUNDEN     12713
                unix  2      [ ]         DGRAM                    16587
                unix  3      [ ]         STREAM     VERBUNDEN     12719
                unix  3      [ ]         DGRAM                    16604
                unix  3      [ ]         STREAM     VERBUNDEN     5973
                unix  3      [ ]         STREAM     VERBUNDEN     12765    /var/run/dbus/system_bus_socket
                unix  2      [ ]         DGRAM                    17432
                unix  3      [ ]         STREAM     VERBUNDEN     12763    /var/run/dbus/system_bus_socket
                unix  3      [ ]         STREAM     VERBUNDEN     16579
                unix  3      [ ]         STREAM     VERBUNDEN     17439    /run/systemd/journal/stdout
                unix  2      [ ]         DGRAM                    16584
                unix  2      [ ]         DGRAM                    8572
                unix  3      [ ]         DGRAM                    5965
                unix  2      [ ]         STREAM     VERBUNDEN     16494
                unix  3      [ ]         STREAM     VERBUNDEN     12896
                unix  3      [ ]         DGRAM                    10448
                unix  3      [ ]         STREAM     VERBUNDEN     13937    /var/run/dbus/system_bus_socket
                unix  3      [ ]         DGRAM                    5964
                unix  3      [ ]         DGRAM                    10449
                unix  3      [ ]         STREAM     VERBUNDEN     12766    /var/run/dbus/system_bus_socket
                unix  2      [ ]         DGRAM                    13863
                unix  2      [ ]         DGRAM                    13869
                unix  2      [ ]         DGRAM                    13847
                unix  3      [ ]         STREAM     VERBUNDEN     13754
                unix  3      [ ]         STREAM     VERBUNDEN     13465
                unix  3      [ ]         STREAM     VERBUNDEN     13758    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     12489    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     26289
                unix  3      [ ]         STREAM     VERBUNDEN     12464    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     13686
                unix  3      [ ]         STREAM     VERBUNDEN     13567
                unix  3      [ ]         STREAM     VERBUNDEN     27060    /run/systemd/journal/stdout
                unix  3      [ ]         STREAM     VERBUNDEN     13687    /run/systemd/journal/stdout
                unix  2      [ ]         DGRAM                    13929
                unix  3      [ ]         STREAM     VERBUNDEN     13860
                Da kann ich aber leider immer noch nicht erkennen, wodurch der Port belegt ist, sorry, bin leider noch nicht ganz so fit mit dem System.
                • GlasfaserG Offline
                  GlasfaserG Offline
                  @hoss0305
                  Zeige mal
                  iobroker status
                  iobroker list instances
                  ps auxww|grep io
                  • H Offline
                    Hoss0305
                    So, hier die Codezeilen entsprechend Deinen Anfragen
                    pi@ioBroker-Pi:/opt/iobroker $ iobroker status
                    Objects type: file
                    States  type: file
                    pi@ioBroker-Pi:/opt/iobroker $ iobroker list instances
                    + instance is alive
                    pi@ioBroker-Pi:/opt/iobroker $ ps auxww|grep io
                    root        11  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/0]
                    root        14  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/1]
                    root        19  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/2]
                    root        24  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/3]
                    root        56  0.0  0.0      0     0 ?        I<   20:23   0:00 [rpciod]
                    root        58  0.0  0.0      0     0 ?        I<   20:23   0:00 [xprtiod]
                    root        60  0.0  0.0      0     0 ?        I<   20:23   0:00 [nfsiod]
                    root        63  0.0  0.0      0     0 ?        I<   20:23   0:00 [DWC Notificatio]
                    message+   321  0.0  0.3   6652  3552 ?        Ss   20:23   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                    avahi      356  0.0  0.2   5772  2624 ?        Ss   20:23   0:00 avahi-daemon: running [ioBroker-Pi.local]
                    iobroker   569  2.7  5.2 138676 49524 ?        Ssl  20:23   0:07 iobroker.js-controller
                    pi         745  0.0  0.1   4900  1592 pts/0    S+   20:28   0:00 grep --color=auto io
                      GlasfaserG Offline
                      @hoss0305
                      Hast du deine Pi mal neu gestartet ?
                      Zeige mal
                      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        @hoss0305
                        Zeige mal
                        Hoss0305
                        @glasfaser
                        Ja, diverse Male, auch schon längere Zeit vom Netzstrom getrennt und dann wieder in Betrieb genommen, ohne jegliche Veränderungen.
                        pi@ioBroker-Pi:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        /usr/bin/nodejs
                        v12.22.1
                        /usr/bin/node
                        v12.22.1
                        /usr/bin/npm
                        6.14.12
                        nodejs:
                          Installiert:           12.22.1-1nodesource1
                          Installationskandidat: 12.22.1-1nodesource1
                          Versionstabelle:
                         *** 12.22.1-1nodesource1 500
                                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                             10.24.0~dfsg-1~deb10u1 500
                          GlasfaserG Offline
                          @hoss0305
                          Hast du da was abgeschnitten , die Ausgabe fehlt von deinen vorhandenen Instanzen .
                            @hoss0305
                            Hoss0305
                            @glasfaser sagte in Iobroker startet nicht mehr:
                            Nö, habe ich nicht. Da steht nur:
                            + instance is alive
                            • H Hoss0305
                              + instance is alive
                              @hoss0305
                              iobroker status
                                @hoss0305
                                iobroker status
                                Hoss0305
                                @thomas-braun sagte in Iobroker startet nicht mehr:
                                iobroker status
                                Objects type: file
                                States  type: file
                                • H Hoss0305
                                  iobroker status
                                  Objects type: file
                                  States  type: file
                                  @hoss0305
                                  iobroker start admin
                                    @hoss0305
                                    Hoss0305
                                    Nach Eingabe von
                                    iobroker start Admin
                                    erscheint
                                    pi@ioBroker-Pi:/opt/iobroker $ iobroker start admin
                                    Cannot find any instances of "admin"!
                                    • H Hoss0305
                                      Nach Eingabe von
                                      erscheint
                                      @hoss0305
                                      iobroker list adapters
                                        @hoss0305
                                        Hoss0305
                                        pi@ioBroker-Pi:/opt/iobroker $ iobroker list adapters
                                        Da wird nichts angezeigt!
                                        • H Hoss0305
                                          @hoss0305
                                          Installiere es nochmal:
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install iobroker.js-controller
