  4. Iobroker startet nicht mehr
    6.4k
erroriobrokerstatusstartet nicht
97 Beiträge 10 Kommentatoren 17.7k Aufrufe 10 Beobachtet
    @JayR
    iobroker stop
    iobroker fix
    JayRJ Offline
    JayRJ Offline
    JayR
    @Thomas-Braun said in Iobroker startet nicht mehr:
    iobroker fix
    pi@Collector:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
    2021-01-03 10:31:38.496  - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting
    2021-01-03 10:31:38.503  - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2021-01-03 10:31:38.504  - info: host.Collector hostname: Collector, node: v12.20.0
    2021-01-03 10:31:38.506  - info: host.Collector ip addresses: 192.168.20.2 fe80::6728:fc45:40bd:6d86
    2021-01-03 10:31:40.020  - info: host.Collector  Error inMem-objects listening on port 9001
    EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:31:40.027  - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:31:40.028  - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:31:40.031  - info: host.Collector terminated. Could not reset alive status for instances
    2021-01-03 10:31:40.035  - info: host.Collector iobroker _restart
    2021-01-03 10:31:41.296  - info: host.Collector  Error inMem-states listening on port 9000
    pi@Collector:/opt/iobroker $ iobroker stop
    pi@Collector:/opt/iobroker $ iobroker fix
    library: loaded
    Library version=2020-12-07
        Welcome to the ioBroker installation fixer!
        Script version: 2020-12-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    2021-01-03 10:32:53.481  - info: host.Collector iobroker.js-controller version 3.1.6 js-controller starting
    2021-01-03 10:32:53.488  - info: host.Collector Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
    2021-01-03 10:32:53.489  - info: host.Collector hostname: Collector, node: v12.20.0
    2021-01-03 10:32:53.491  - info: host.Collector ip addresses: 192.168.20.2 fe80::6728:fc45:40bd:6d86
    2021-01-03 10:32:54.959  - error: host.Collector uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:32:54.960  - error: host.Collector Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2021-01-03.log'
    2021-01-03 10:32:54.962  - info: host.Collector terminated. Could not reset alive status for instances
    2021-01-03 10:32:54.966  - info: host.Collector iobroker _restart
    Hat auch nichts gebracht. Habe vorher nochmal aufgesetzt und backup von gestern eingespielt.
    Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
    -1
    • JayRJ JayR
      iobroker fix
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      @JayR
      dmesg
      JayRJ 1 Antwort Letzte Antwort
        @JayR
        dmesg
        JayRJ Offline
        JayRJ Offline
        JayR
        dmesg
        pi@Collector:~ $ dmesg
        [    0.000000] Booting Linux on physical CPU 0x0
        [    0.000000] Linux version 5.4.51-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1333 SMP Mon Aug 10 16:51:40 BST 2020
        [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
        [    0.000000] CPU: div instructions available: patching division code
        [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
        [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
        [    0.000000] Memory policy: Data cache writealloc
        [    0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
        [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
        [    0.000000] On node 0 totalpages: 1012480
        [    0.000000]   DMA zone: 2304 pages used for memmap
        [    0.000000]   DMA zone: 0 pages reserved
        [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
        [    0.000000]   HighMem zone: 815872 pages, LIFO batch:63
        [    0.000000] percpu: Embedded 20 pages/cpu s49856 r8192 d23872 u81920
        [    0.000000] pcpu-alloc: s49856 r8192 d23872 u81920 alloc=20*4096
        [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010176
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1  smsc95xx.macaddr=DC:A6:32:50:00:01 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=7761be3b-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
        [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
        [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
        [    0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
        [    0.000000] Memory: 3654596K/4049920K available (10240K kernel code, 725K rwdata, 2740K rodata, 2048K init, 853K bss, 133180K reserved, 262144K cma-reserved, 3263488K highmem)
        [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
        [    0.000000] ftrace: allocating 30051 entries in 59 pages
        [    0.000000] rcu: Hierarchical RCU implementation.
        [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
        [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
        [    0.000000] GIC: Using split EOI/Deactivate mode
        [    0.000000] random: get_random_bytes called from start_kernel+0x340/0x518 with crng_init=0
        [    0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
        [    0.000031] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
        [    0.000111] bcm2835: system timer (irq = 17)
        [    0.000778] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
        [    0.000798] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
        [    0.000818] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
        [    0.000834] Switching to timer-based delay loop, resolution 18ns
        [    0.001076] Console: colour dummy device 80x30
        [    0.001568] printk: console [tty1] enabled
        [    0.001628] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
        [    0.001670] pid_max: default: 32768 minimum: 301
        [    0.001996] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.002037] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
        [    0.003216] Disabling memory control group subsystem
        [    0.003331] CPU: Testing write buffer coherency: ok
        [    0.003812] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.004657] Setting up static identity map for 0x200000 - 0x20003c
        [    0.004858] rcu: Hierarchical SRCU implementation.
        [    0.005491] smp: Bringing up secondary CPUs ...
        [    0.006640] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.007904] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
        [    0.009110] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
        [    0.009252] smp: Brought up 1 node, 4 CPUs
        [    0.009321] SMP: Total of 4 processors activated (432.00 BogoMIPS).
        [    0.009346] CPU: All CPU(s) started in HYP mode.
        [    0.009369] CPU: Virtualization extensions available.
        [    0.010141] devtmpfs: initialized
        [    0.023045] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
        [    0.023315] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.023362] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
        [    0.031107] pinctrl core: initialized pinctrl subsystem
        [    0.032143] NET: Registered protocol family 16
        [    0.035707] DMA: preallocated 1024 KiB pool for atomic coherent allocations
        [    0.037342] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.037376] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.037716] Serial: AMBA PL011 UART driver
        [    0.041133] bcm2835-mbox fe00b880.mailbox: mailbox enabled
        [    0.060888] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start
        [    0.070872] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094
        [    0.123663] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
        [    0.128092] vgaarb: loaded
        [    0.128563] SCSI subsystem initialized
        [    0.128800] usbcore: registered new interface driver usbfs
        [    0.128898] usbcore: registered new interface driver hub
        [    0.129029] usbcore: registered new device driver usb
        [    0.130521] clocksource: Switched to clocksource arch_sys_counter
        [    0.881806] VFS: Disk quotas dquot_6.6.0
        [    0.881936] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
        [    0.882124] FS-Cache: Loaded
        [    0.882306] CacheFiles: Loaded
        [    0.883098] simple-framebuffer: probe of 0.framebuffer failed with error -12
        [    0.891135] thermal_sys: Registered thermal governor 'step_wise'
        [    0.891493] NET: Registered protocol family 2
        [    0.892281] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    0.892332] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
        [    0.892426] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
        [    0.892514] TCP: Hash tables configured (established 8192 bind 8192)
        [    0.892668] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    0.892716] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
        [    0.892979] NET: Registered protocol family 1
        [    0.893717] RPC: Registered named UNIX socket transport module.
        [    0.893746] RPC: Registered udp transport module.
        [    0.893770] RPC: Registered tcp transport module.
        [    0.893794] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    0.893828] PCI: CLS 0 bytes, default 64
        [    0.895586] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
        [    0.897674] Initialise system trusted keyrings
        [    0.897918] workingset: timestamp_bits=14 max_order=20 bucket_order=6
        [    0.908543] FS-Cache: Netfs 'nfs' registered for caching
        [    0.909285] NFS: Registering the id_resolver key type
        [    0.909331] Key type id_resolver registered
        [    0.909356] Key type id_legacy registered
        [    0.909400] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
        [    0.910474] Key type asymmetric registered
        [    0.910542] Asymmetric key parser 'x509' registered
        [    0.910724] bounce: pool size: 64 pages
        [    0.910796] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
        [    0.911027] io scheduler mq-deadline registered
        [    0.911055] io scheduler kyber registered
        [    0.914781] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
        [    0.914822] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
        [    0.914906] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
        [    0.914989] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
        [    0.972633] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
        [    0.972966] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
        [    0.972999] pci_bus 0000:00: root bus resource [bus 00-ff]
        [    0.973031] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
        [    0.973106] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
        [    0.973357] pci 0000:00:00.0: PME# supported from D0 D3hot
        [    0.976729] PCI: bus0: Fast back to back transfers disabled
        [    0.976965] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
        [    0.977122] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
        [    0.977555] pci 0000:01:00.0: PME# supported from D0 D3cold
        [    0.980952] PCI: bus1: Fast back to back transfers disabled
        [    0.981023] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
        [    0.981061] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
        [    0.981159] pci 0000:00:00.0: PCI bridge to [bus 01]
        [    0.981195] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
        [    0.981507] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
        [    0.981749] pcieport 0000:00:00.0: PME: Signaling with IRQ 55
        [    0.982136] pcieport 0000:00:00.0: AER: enabled with IRQ 55
        [    0.982450] pci 0000:01:00.0: enabling device (0140 -> 0142)
        [    0.989030] iproc-rng200 fe104000.rng: hwrng registered
        [    0.989371] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
        [    0.989980] vc-sm: Videocore shared memory driver
        [    0.990575] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
        [    1.002086] brd: module loaded
        [    1.013778] loop: module loaded
        [    1.015072] Loading iSCSI transport class v2.0-870.
        [    1.017014] libphy: Fixed MDIO Bus: probed
        [    1.017612] bcmgenet fd580000.ethernet: failed to get enet clock
        [    1.017645] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
        [    1.017680] bcmgenet fd580000.ethernet: failed to get enet-wol clock
        [    1.017714] bcmgenet fd580000.ethernet: failed to get enet-eee clock
        [    1.017754] bcmgenet: Skipping UMAC reset
        [    1.030569] libphy: bcmgenet MII bus: probed
        [    1.110631] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
        [    1.111635] usbcore: registered new interface driver r8152
        [    1.111715] usbcore: registered new interface driver lan78xx
        [    1.111798] usbcore: registered new interface driver smsc95xx
        [    1.112211] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.112260] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
        [    1.114589] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
        [    1.115860] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
        [    1.115897] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.115929] usb usb1: Product: xHCI Host Controller
        [    1.115955] usb usb1: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
        [    1.115982] usb usb1: SerialNumber: 0000:01:00.0
        [    1.116565] hub 1-0:1.0: USB hub found
        [    1.116670] hub 1-0:1.0: 1 port detected
        [    1.117209] xhci_hcd 0000:01:00.0: xHCI Host Controller
        [    1.117249] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
        [    1.117290] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
        [    1.117742] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
        [    1.117777] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
        [    1.117809] usb usb2: Product: xHCI Host Controller
        [    1.117835] usb usb2: Manufacturer: Linux 5.4.51-v7l+ xhci-hcd
        [    1.117862] usb usb2: SerialNumber: 0000:01:00.0
        [    1.118401] hub 2-0:1.0: USB hub found
        [    1.118497] hub 2-0:1.0: 4 ports detected
        [    1.119923] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
        [    1.120206] dwc_otg: FIQ enabled
        [    1.120217] dwc_otg: NAK holdoff enabled
        [    1.120229] dwc_otg: FIQ split-transaction FSM enabled
        [    1.120243] Module dwc_common_port init
        [    1.120718] usbcore: registered new interface driver uas
        [    1.120840] usbcore: registered new interface driver usb-storage
        [    1.121043] mousedev: PS/2 mouse device common for all mice
        [    1.123034] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
        [    1.125530] sdhci: Secure Digital Host Controller Interface driver
        [    1.125560] sdhci: Copyright(c) Pierre Ossman
        [    1.126128] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
        [    1.126653] sdhci-pltfm: SDHCI platform and OF driver helper
        [    1.130354] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.130734] hidraw: raw HID events driver (C) Jiri Kosina
        [    1.130919] usbcore: registered new interface driver usbhid
        [    1.130945] usbhid: USB HID core driver
        [    1.131939] vchiq: vchiq_init_state: slot_zero = (ptrval)
        [    1.133812] [vc_sm_connected_init]: start
        [    1.142681] [vc_sm_connected_init]: end - returning 0
        [    1.144723] Initializing XFRM netlink socket
        [    1.144774] NET: Registered protocol family 17
        [    1.144901] Key type dns_resolver registered
        [    1.145281] Registering SWP/SWPB emulation handler
        [    1.145595] registered taskstats version 1
        [    1.145626] Loading compiled-in X.509 certificates
        [    1.146143] Key type ._fscrypt registered
        [    1.146170] Key type .fscrypt registered
        [    1.156120] uart-pl011 fe201000.serial: cts_event_workaround enabled
        [    1.156218] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
        [    1.162173] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
        [    1.163102] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
        [    1.163133] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
        [    1.213738] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
        [    1.215452] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.217120] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.220087] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
        [    1.222385] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
        [    1.227787] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
        [    1.230566] of_cfs_init
        [    1.230687] of_cfs_init: OK
        [    1.231741] Waiting for root device PARTUUID=7761be3b-02...
        [    1.267632] random: fast init done
        [    1.291176] mmc1: new high speed SDIO card at address 0001
        [    1.480554] usb 1-1: new high-speed USB device number 2 using xhci_hcd
        [    1.663157] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
        [    1.663195] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
        [    1.663225] usb 1-1: Product: USB2.0 Hub
        [    1.664843] hub 1-1:1.0: USB hub found
        [    1.665184] hub 1-1:1.0: 4 ports detected
        [    1.811052] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
        [    1.842059] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
        [    1.842097] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
        [    1.842127] usb 2-1: Product: Best USB Device
        [    1.842154] usb 2-1: Manufacturer: ULT-Best
        [    1.842179] usb 2-1: SerialNumber: 0420042327B7
        [    1.863132] scsi host0: uas
        [    1.864451] scsi 0:0:0:0: Direct-Access     SanDisk  SSD PLUS 120GB   0    PQ: 0 ANSI: 6
        [    1.866361] sd 0:0:0:0: [sda] 234455040 512-byte logical blocks: (120 GB/112 GiB)
        [    1.866555] sd 0:0:0:0: [sda] Write Protect is off
        [    1.866588] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
        [    1.866906] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
        [    1.867593] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
        [    1.870317]  sda: sda1 sda2
        [    1.873178] sd 0:0:0:0: [sda] Attached SCSI disk
        [    1.902962] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.903057] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [    1.905551] devtmpfs: mounted
        [    1.913542] Freeing unused kernel memory: 2048K
        [    1.940823] Run /sbin/init as init process
        [    2.149706] systemd[1]: System time before build time, advancing clock.
        [    2.209477] NET: Registered protocol family 10
        [    2.210927] Segment Routing with IPv6
        [    2.237383] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
        [    2.238184] systemd[1]: Detected architecture arm.
        [    2.286895] systemd[1]: Set hostname to <Collector>.
        [    2.848709] random: systemd: uninitialized urandom read (16 bytes read)
        [    2.857687] random: systemd: uninitialized urandom read (16 bytes read)
        [    2.858082] systemd[1]: Listening on initctl Compatibility Named Pipe.
        [    2.858958] random: systemd: uninitialized urandom read (16 bytes read)
        [    2.859443] systemd[1]: Listening on udev Kernel Socket.
        [    2.863017] systemd[1]: Created slice system-systemd\x2dfsck.slice.
        [    2.863869] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
        [    2.882035] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
        [    2.882744] systemd[1]: Listening on fsck to fsckd communication Socket.
        [    2.883858] systemd[1]: Listening on udev Control Socket.
        [    3.542942] EXT4-fs (sda2): re-mounted. Opts: (null)
        [    3.640889] systemd-journald[114]: Received request to flush runtime journal from PID 1
        [    4.125205] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
        [    4.125700] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
        [    4.129607] mc: Linux media interface: v0.10
        [    4.138104] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
        [    4.143325] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
        [    4.145577] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.147648] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
        [    4.147678] [vc_sm_connected_init]: start
        [    4.156937] [vc_sm_connected_init]: installed successfully
        [    4.164791] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.207111] videodev: Linux video capture interface: v2.00
        [    4.239174] bcm2835_audio bcm2835_audio: card created with 8 channels
        [    4.247104] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.247888] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.256671] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.278056] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.306813] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
        [    4.328194] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
        [    4.328259] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
        [    4.328717] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
        [    4.329251] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
        [    4.329753] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
        [    4.330252] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
        [    4.330277] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
        [    4.330297] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
        [    4.330316] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
        [    4.330335] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
        [    4.330576] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
        [    4.341423] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
        [    4.341463] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
        [    4.349497] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
        [    4.349539] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
        [    4.421533] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    4.552795] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    4.640754] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
        [    4.646868] [drm] No displays found. Consider forcing hotplug if HDMI is attached
        [    4.646991] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
        [    4.647014] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
        [    4.647026] [drm] No driver support for vblank timestamp query.
        [    4.647037] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
        [    4.648663] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
        [    4.673646] sd 0:0:0:0: Attached scsi generic sg0 type 0
        [    4.713394] brcmfmac: F1 signature read @0x18000000=0x15264345
        [    4.731345] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    4.732230] usbcore: registered new interface driver brcmfmac
        [    4.739728] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
        [    4.972427] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
        [    4.986873] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
        [    6.767427] uart-pl011 fe201000.serial: no DMA platform data
        [    6.821962] 8021q: 802.1Q VLAN Support v1.8
        [    6.865753] random: crng init done
        [    6.865770] random: 7 urandom warning(s) missed due to ratelimiting
        [    7.080560] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:307200k SSFS
        [    7.274028] bcmgenet: Skipping UMAC reset
        [    7.275478] bcmgenet fd580000.ethernet: configuring instance for external RGMII
        [    7.275658] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
        [    7.275841] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
        [   13.378458] Bluetooth: Core ver 2.22
        [   13.378515] NET: Registered protocol family 31
        [   13.378523] Bluetooth: HCI device and connection manager initialized
        [   13.378540] Bluetooth: HCI socket layer initialized
        [   13.378551] Bluetooth: L2CAP socket layer initialized
        [   13.378579] Bluetooth: SCO socket layer initialized
        [   13.390408] Bluetooth: HCI UART driver ver 2.3
        [   13.390420] Bluetooth: HCI UART protocol H4 registered
        [   13.390470] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [   13.390699] Bluetooth: HCI UART protocol Broadcom registered
        [   13.531883] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [   13.531892] Bluetooth: BNEP filters: protocol multicast
        [   13.531913] Bluetooth: BNEP socket layer initialized
        [   31.124526] FS-Cache: Netfs 'cifs' registered for caching
        [   31.138074] Key type cifs.spnego registered
        [   31.138090] Key type cifs.idmap registered
        [   31.138879] CIFS: Attempting to mount //192.168.1.3/Backup/iobroker
        • JayRJ JayR
          dmesg
          JayRJ Offline
          JayRJ Offline
          JayR
          @JayR said in Iobroker startet nicht mehr:
          dmesg
          pi@Collector:~ $ node node_modules/iobroker.js-controller/controller.js --logs
          internal/modules/cjs/loader.js:818
            throw err;
          Error: Cannot find module '/home/pi/node_modules/iobroker.js-controller/controller.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
              at Function.Module._load (internal/modules/cjs/loader.js:667:27)
              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
              at internal/main/run_main_module.js:17:47 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          pi@Collector:~ $
          • JayRJ JayR
            dmesg
              throw err;
              requireStack: []
            pi@Collector:~ $
            JayRJ Offline
            JayRJ Offline
            JayR
            @JayR : Sorry war falscher Pfad. Nach einen Neustart sieht es nun so aus als würde es wieder laufen. Herzlichen Dank für die Hilfe. @Thomas-Braun
            • JayRJ JayR
              JayRJ Offline
              JayRJ Offline
              JayR
              Im Log taucht aber immer der error auf:
              error: host.Collector Multihost discovery server: error: Error: bind EADDRINUSE 0.0.0.0:50005
              H 1 Antwort Letzte Antwort
              • JayRJ JayR
                Hoss0305
                @jayr
                ich habe genau das selbe Problem mit meinem ioBroker. Auch in meinem Fall läßt sich das WebUI nicht öffnen. Ich die gesamten Schritte gem. dieser Arbeitsanleitung von Thomas-Braun nachvollzogen und wie bei Dir die selben Ergebnisse. Was ich nur am Ende nicht verstehe, ist, was Du nun gemacht hast, damit der ioBroker per WebUI wieder erreichbar ist. Was meinst Du mit falscher Pfad? Wäre toll, wenn Du mir mal antworten würdest.
                • JayRJ JayR
                  iobroker fix
                  library: loaded
                  Installed gcc-c++
                  Autostart enabled!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @hoss0305 sagte in Iobroker startet nicht mehr:
                  Er hat den Befehl
                  nicht im Pfad
                  /opt/iobroker
                  durchgeführt , deshalb kam dann das
                  und im Pfad
                  /home/pi/
                  gibt es halt kein
                  • H Offline
                    Hoss0305
                    @glasfaser
                    @Thomas-Braun
                    Wie geschrieben, bekomme ich das ioBroker WebUI nicht gestartet. Dieses Problem trat heute Vormittag ohne jegliches Zutun auf. Vor einer zur nächsten Minute war ein Zugriff nicht mehr möglich.
                    Wenn ich den Befehl
                    eigentlich wollte ich nun den angezeigten Code einfügen, jedoch erhalte ich jedes Mal, wenn ich diesen Text absenden möchte, eine Meldung: Forbidden Fehler!
                    Keine Ahnung, was nun wieder falsch läuft.
                    • H Offline
                      Hoss0305
                      @Thomas-Braun
                      Wenn ich den Befehl
                      eingebe, erhalte ich
                      pi@ioBroker-Pi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
                      - info: host.ioBroker-Pi iobroker.js-controller version 3.2.16 js-contr                        oller starting
                      - info: host.ioBroker-Pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                      - info: host.ioBroker-Pi hostname: ioBroker-Pi, node: v12.22.1
                      - info: host.ioBroker-Pi ip addresses: 192.168.123.61 2a02:2f4:484e:af00:dbf8:12ef:9fbf:4984 fe80::ee08:c96b:c94e:f438
                      - info: host.ioBroker-Pi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
                      - error: host.ioBroker-Pi No connection to databases possible, restart
                      - info: host.ioBroker-Pi iobroker _restart
                      Kann mir da irgend jemand helfen, woran es liegen könnte, dass ich das ioBroker WebUI nicht gestartet bekomme.
                      • H Hoss0305
                        @Thomas-Braun
                        Wenn ich den Befehl
                        GlasfaserG Offline
                        GlasfaserG Offline
                        • info: host.ioBroker-Pi-Server
                        Der Port 9001 wird schon auf deinem System genutzt , deshalb startet ioBroker nicht
                        • GlasfaserG Glasfaser
                          Hoss0305
                          @glasfaser
                          Wie kann ich denn ermitteln, wodurch der Port 9001 belegt ist, das System hat doch zuvor immer funktioniert.
                          • H Hoss0305
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @hoss0305
                            https://forum.iobroker.net/topic/43839/gelöst-ich-bekomme-den-iobroker-auf-nuc-nicht-ans-laufen?_=1617990930977
                              @hoss0305
                              Hoss0305
                              @glasfaser
                              Wenn ich mit
                              netstat
                              da rangehe, erhalte ich:
                              pi@ioBroker-Pi:/opt/iobroker $ netstat
                              Aktive Internetverbindungen (ohne Server)
                              Proto Recv-Q Send-Q Local Address           Foreign Address         State
                              tcp        0      0 localhost:49308         localhost:9001          VERBUNDEN
                              tcp        0      0 ioBroker-Pi-WLAN.:45890 FR-PAR-ANX-R009.te:5938 VERBUNDEN
                              tcp        0      0 localhost:9001          localhost:49308         VERBUNDEN
                              tcp        0      0 localhost:44256         localhost:9000          VERBUNDEN
                              tcp        0      0 localhost:49310         localhost:9001          VERBUNDEN
                              tcp        0      0 localhost:9000          localhost:44258         VERBUNDEN
                              tcp        0    240 ioBroker-Pi-WLAN.fr:ssh MININT-91OJ9JA.fr:54023 VERBUNDEN
                              tcp        0      0 localhost:9000          localhost:44256         VERBUNDEN
                              tcp        0      0 localhost:9001          localhost:49310         VERBUNDEN
                              tcp        0      0 localhost:44258         localhost:9000          VERBUNDEN
                              Aktive Sockets in der UNIX-Dom▒ne (ohne Server)
                              Proto RefCnt Flags       Type       State         I-Node   Pfad
                              unix  2      [ ]         DGRAM                    10511    /run/systemd/journal/syslog
                              unix  14     [ ]         DGRAM                    10535    /run/systemd/journal/dev-log
                              unix  2      [ ]         DGRAM                    14650    /var/run/wpa_supplicant/wlan0
                              unix  2      [ ]         DGRAM                    14655    /var/run/wpa_supplicant/p2p-dev-wlan0
                              unix  3      [ ]         DGRAM                    10446    /run/systemd/notify
                              unix  2      [ ]         DGRAM                    16602    /run/user/1000/systemd/notify
                              unix  7      [ ]         DGRAM                    10465    /run/systemd/journal/socket
                              unix  2      [ ]         DGRAM                    15598
                              unix  3      [ ]         STREAM     VERBUNDEN     12767    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         STREAM     VERBUNDEN     15875    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     15053
                              unix  3      [ ]         STREAM     VERBUNDEN     15071
                              unix  3      [ ]         STREAM     VERBUNDEN     15605
                              unix  3      [ ]         STREAM     VERBUNDEN     6135
                              unix  3      [ ]         STREAM     VERBUNDEN     12193
                              unix  3      [ ]         STREAM     VERBUNDEN     12764    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         STREAM     VERBUNDEN     6137     /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     13764    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     15536
                              unix  3      [ ]         STREAM     VERBUNDEN     14281    /var/run/dbus/system_bus_socket
                              unix  2      [ ]         DGRAM                    15540
                              unix  2      [ ]         DGRAM                    14511
                              unix  2      [ ]         DGRAM                    15706
                              unix  3      [ ]         STREAM     VERBUNDEN     14561
                              unix  3      [ ]         STREAM     VERBUNDEN     15974
                              unix  3      [ ]         STREAM     VERBUNDEN     13928    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         STREAM     VERBUNDEN     15973
                              unix  2      [ ]         DGRAM                    10664
                              unix  3      [ ]         STREAM     VERBUNDEN     15549    /run/systemd/journal/stdout
                              unix  3      [ ]         DGRAM                    5963
                              unix  3      [ ]         DGRAM                    10668
                              unix  3      [ ]         STREAM     VERBUNDEN     12651
                              unix  3      [ ]         DGRAM                    5962
                              unix  3      [ ]         STREAM     VERBUNDEN     10660
                              unix  3      [ ]         STREAM     VERBUNDEN     5452     /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     13569    /run/systemd/journal/stdout
                              unix  2      [ ]         DGRAM                    5960
                              unix  3      [ ]         DGRAM                    10667
                              unix  3      [ ]         STREAM     VERBUNDEN     12548
                              unix  3      [ ]         STREAM     VERBUNDEN     14041    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         STREAM     VERBUNDEN     12649
                              unix  2      [ ]         DGRAM                    12900
                              unix  3      [ ]         STREAM     VERBUNDEN     12788
                              unix  3      [ ]         STREAM     VERBUNDEN     16608
                              unix  2      [ ]         DGRAM                    12646
                              unix  2      [ ]         DGRAM                    5340
                              unix  2      [ ]         DGRAM                    12550
                              unix  3      [ ]         STREAM     VERBUNDEN     14736    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     17451    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         STREAM     VERBUNDEN     12648
                              unix  3      [ ]         STREAM     VERBUNDEN     12902
                              unix  3      [ ]         STREAM     VERBUNDEN     14497    /run/systemd/journal/stdout
                              unix  3      [ ]         DGRAM                    16605
                              unix  3      [ ]         STREAM     VERBUNDEN     12761
                              unix  3      [ ]         STREAM     VERBUNDEN     12762
                              unix  3      [ ]         STREAM     VERBUNDEN     12713
                              unix  2      [ ]         DGRAM                    16587
                              unix  3      [ ]         STREAM     VERBUNDEN     12719
                              unix  3      [ ]         DGRAM                    16604
                              unix  3      [ ]         STREAM     VERBUNDEN     5973
                              unix  3      [ ]         STREAM     VERBUNDEN     12765    /var/run/dbus/system_bus_socket
                              unix  2      [ ]         DGRAM                    17432
                              unix  3      [ ]         STREAM     VERBUNDEN     12763    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         STREAM     VERBUNDEN     16579
                              unix  3      [ ]         STREAM     VERBUNDEN     17439    /run/systemd/journal/stdout
                              unix  2      [ ]         DGRAM                    16584
                              unix  2      [ ]         DGRAM                    8572
                              unix  3      [ ]         DGRAM                    5965
                              unix  2      [ ]         STREAM     VERBUNDEN     16494
                              unix  3      [ ]         STREAM     VERBUNDEN     12896
                              unix  3      [ ]         DGRAM                    10448
                              unix  3      [ ]         STREAM     VERBUNDEN     13937    /var/run/dbus/system_bus_socket
                              unix  3      [ ]         DGRAM                    5964
                              unix  3      [ ]         DGRAM                    10449
                              unix  3      [ ]         STREAM     VERBUNDEN     12766    /var/run/dbus/system_bus_socket
                              unix  2      [ ]         DGRAM                    13863
                              unix  2      [ ]         DGRAM                    13869
                              unix  2      [ ]         DGRAM                    13847
                              unix  3      [ ]         STREAM     VERBUNDEN     13754
                              unix  3      [ ]         STREAM     VERBUNDEN     13465
                              unix  3      [ ]         STREAM     VERBUNDEN     13758    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     12489    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     26289
                              unix  3      [ ]         STREAM     VERBUNDEN     12464    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     13686
                              unix  3      [ ]         STREAM     VERBUNDEN     13567
                              unix  3      [ ]         STREAM     VERBUNDEN     27060    /run/systemd/journal/stdout
                              unix  3      [ ]         STREAM     VERBUNDEN     13687    /run/systemd/journal/stdout
                              unix  2      [ ]         DGRAM                    13929
                              unix  3      [ ]         STREAM     VERBUNDEN     13860
                              Da kann ich aber leider immer noch nicht erkennen, wodurch der Port belegt ist, sorry, bin leider noch nicht ganz so fit mit dem System.
                              • GlasfaserG Offline
                                GlasfaserG Offline
                                @hoss0305
                                Zeige mal
                                iobroker status
                                iobroker list instances
                                ps auxww|grep io
                                • H Offline
                                  Hoss0305
                                  So, hier die Codezeilen entsprechend Deinen Anfragen
                                  pi@ioBroker-Pi:/opt/iobroker $ iobroker status
                                  Objects type: file
                                  States  type: file
                                  pi@ioBroker-Pi:/opt/iobroker $ iobroker list instances
                                  + instance is alive
                                  pi@ioBroker-Pi:/opt/iobroker $ ps auxww|grep io
                                  root        11  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/0]
                                  root        14  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/1]
                                  root        19  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/2]
                                  root        24  0.0  0.0      0     0 ?        S    20:23   0:00 [migration/3]
                                  root        56  0.0  0.0      0     0 ?        I<   20:23   0:00 [rpciod]
                                  root        58  0.0  0.0      0     0 ?        I<   20:23   0:00 [xprtiod]
                                  root        60  0.0  0.0      0     0 ?        I<   20:23   0:00 [nfsiod]
                                  root        63  0.0  0.0      0     0 ?        I<   20:23   0:00 [DWC Notificatio]
                                  message+   321  0.0  0.3   6652  3552 ?        Ss   20:23   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
                                  avahi      356  0.0  0.2   5772  2624 ?        Ss   20:23   0:00 avahi-daemon: running [ioBroker-Pi.local]
                                  iobroker   569  2.7  5.2 138676 49524 ?        Ssl  20:23   0:07 iobroker.js-controller
                                  pi         745  0.0  0.1   4900  1592 pts/0    S+   20:28   0:00 grep --color=auto io
                                    GlasfaserG Offline
                                    @hoss0305
                                    Hast du deine Pi mal neu gestartet ?
                                    Zeige mal
                                    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                      @hoss0305
                                      Zeige mal
                                      Hoss0305
                                      @glasfaser
                                      Ja, diverse Male, auch schon längere Zeit vom Netzstrom getrennt und dann wieder in Betrieb genommen, ohne jegliche Veränderungen.
                                      pi@ioBroker-Pi:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                      /usr/bin/nodejs
                                      v12.22.1
                                      /usr/bin/node
                                      v12.22.1
                                      /usr/bin/npm
                                      6.14.12
                                      nodejs:
                                        Installiert:           12.22.1-1nodesource1
                                        Installationskandidat: 12.22.1-1nodesource1
                                        Versionstabelle:
                                       *** 12.22.1-1nodesource1 500
                                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                           10.24.0~dfsg-1~deb10u1 500
                                        GlasfaserG Offline
                                        @hoss0305
                                        Hast du da was abgeschnitten , die Ausgabe fehlt von deinen vorhandenen Instanzen .
                                          @hoss0305
                                          Hoss0305
                                          @glasfaser sagte in Iobroker startet nicht mehr:
                                          Nö, habe ich nicht. Da steht nur:
                                          + instance is alive
