  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • J Jockelflo
    gibt es Erfahrungen bei den e-Autos wie e-Up und e-Golf? Ich finde keine Verbräuche bzw. das was ich finde stimmt nicht überein mit den Daten in Weconnect App und dem Auto.
    Sneak-L8
    #820
    @tombox gestenr gab es mal wieder ein paar Fehlerim Adapter. Evtl. hängt es damit zusammen, dass ich gestern die We Charge-Karte bekommen und in der Ap registriert habe. Mir scheint, da aber nur noch if (... == null) oder if (.... == undefined) zu fehlen:
    vw-connect.0	2021-03-27 04:31:51.106	error	at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    vw-connect.0	2021-03-27 04:31:51.106	error	at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.vw-connect/main.js:497:105)
    vw-connect.0	2021-03-27 04:31:51.106	error	(11256) TypeError: Cannot read property 'split' of undefined
    vw-connect.0	2021-03-27 04:31:47.235	error	(11256) TypeError: Cannot read property 'split' of undefined
    vw-connect.0	2021-03-27 04:31:47.234	error	(11256) Login was not successful, please check your login credentials and selected type
    Vielleicht kannst Du das bei eienr der nächsten Version prüfen.
    N 1 Antwort Letzte Antwort
    • E Offline
      Exile82
      #821
      Hi guys! I am quite new to iobroker but really like how it works and how flexible it is. I am driving an VW ID.3 so this adapter is the best thing that happened since I picked up my car.
      I have one concern though, and it is probably more connected to VW API etc. I would most of all be able to fetch the current mileage of the car. This seems not to be possible in the adapter. I know that VWs own app is a bit poor when it comes to this, but are there any possibilities to open for this? Also, lock state for the doors would be nice to integrate with the smart home.
      Thanks for reading!
        Sneak-L8
        #822
        Unfortunately ID.3 is not yet able to send milage to we connect. And as address, temperature,...
        It's not the problem of the adapter.
        E 1 Antwort Letzte Antwort
        • S Sneak-L8
          Exile82
          #823
          @sneak-l8 yeah, I suspected that. Hopefully such things will be available in the future as VW develops their app. But I have a feeling that they will not. 😉
          Thanks for a really nice adapter!
          • C Offline
            cybtrash
            schrieb am zuletzt editiert von cybtrash
            #824
            Hallo!
            Ich habe einen ID.3 und mich mit der Android We Connect ID App mit dem Auto verbunden, und kann von der App aus Heizung steuern und Ladezustand einsehen.
            Habe bei diesem Adapter also "ID" ausgewählt und meine Login Daten eingegeben.
            Im LOG kommt leider die Fehlermeldung
            vw-connect.0	2021-04-05 23:07:50.857	warn	(21857) Failled wall charger login
            vw-connect.0	2021-04-05 23:07:50.854	error	(21857) No Login Form found
            vw-connect.0	2021-04-05 23:07:46.197	info	(21857) starting. Version 0.0.30 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v12.21.0, js-controller: 3.2.16
            Was mache ich falsch? Vor allem warum steht da "wall charger login" ?
            • C cybtrash
              Hallo!
              tombox
              #825
              @cybtrash Nochmal die E-Mail adresse in den optionen überprüfen
              C 1 Antwort Letzte Antwort
              • T tombox
                cybtrash
                #826
                @tombox said in Test Adapter VW Connect v0.0.x für VW We Connect, ID:
                Ich merke gerade, dass unter Objekte die Daten des ID.3 aufgetaucht sind. Die Fehlermeldung bleibt weiterhin und kommt auch erneut wenn ich den Adapter neu lade.
                Werde ich erstmal ignorieren die Fehlermeldung..
                • S Sneak-L8
                  N Offline
                  N Offline
                  Night2k5
                  #827
                  @sneak-l8
                  Ist zwar schon ein paar Tage her deine Fehlermeldung, aber ich hatte bis gerade eben die selbe Meldung.
                  Log dich mal im Browser bei WeConnect ein:
                  https://www.portal.volkswagen-we.com/portal/de_DE/web/guest/home
                  Bei mir gab es eine Bestätigung wegen neuer Nutzungsbedingungen und die musste ich bestätigen. Jetzt funktioniert alles wieder bestens.
                  • N Night2k5
                    @sneak-l8
                    Sneak-L8
                    #828
                    @night2k5 Ja, das kenne ich schon. Genau das hab ich neulich auch gemacht. Aber die Fehlermeldung war eine technische und die kann man korrigieren.
                    Vielleicht man sogar eine Erkennung einbauen, die die Abfrage der Erklärung erkennt und entweder automatisch abnickt (dazu braucht es vielleicht eine Option in den Einstellungen) oder zumindest eine konkrete Meldung ausgibt, dass man der Erklärung zustimmen soll.
                    • S Sneak-L8
                      tombox
                      #829
                      @sneak-l8 Ich habe mal eine 0.33 veröffentlich in der versucht wird die bedingungen automatisch zu akzeptieren da man aber nur ein versuch zum testen hat kann ich es nicht garantieren
                      W 1 Antwort Letzte Antwort
                      • T tombox
                        W Offline
                        W Offline
                        Wueli
                        #830
                        Erstmal muss ich ein riesen Dankeschön an den / die Ersteller dieses Adapters aussprechen. Richtig gute Arbeit!
                        Eine Frage hätte ich allerdings. Wir haben einen E-Golf und ich würde gerne den Ladestrom ändern können. In der we connect app ist dies unter Einstellungen möglich aber im Adapter leider nur lesend. Besteht da die Möglichkeit dieses noch anzupassen? Hintergrund ist, ich habe eine "dumme" Wallbox aber möchte je nachdem wie viel Strom vom Dach kommt die Ladeleistung anpassen lassen über iobroker.
                        Vielen Dank schon mal für die ganze Mühe.
                        • W Wueli
                          tombox
                          #831
                          @wueli In der Github version ist es jetzt drin bitte mal testen. Ein neuer Punkt unter remote.
                          • T tombox
                            derrapf
                            #832
                            An alle
                            Darf ich mal ganz doof fragen:
                            Ich habe mir den Adapter mal installiert und mit meinen myAudi Daten versorgt.
                            Nun bekomme ich folgende Datenpunkte.
                            Danach habe ich die View importiert (vorher die richtige WAU* Nummer durch Suchen/Ersetzen eingetragen) und alles was elektrisch ist rausgeschmissen.
                            Nun hätte ich gedacht, dass ich aber solche Sachen wie die Standheizung steuern kann oder den Parkplatz sehe usw.
                            Funktioniert aber bei mir nicht. Habe mal die Hupe ausprobiert.. da hupt nichts.
                            Mir ist auch aufgefallen dass viele Datenpunkte aus Deiner View fehlen.
                            Z.B. habe ich nicht:
                            vw-connect.0.WAUxxxx.tripdata.*
                            vw-connect.0.WAUxxxx.status.*
                            vw-connect.0.WAUxxxx.position.*
                            vw-connect.0.WAUxxxx.climater.*
                            Die View sieht dann natürlich ziemlich bescheiden aus (Experimental-Status).
                            Frage: Mach ich was falsch?
                            Oder kann mein Audi die Daten nicht liefern (BJ 2017) ?
                            Gruss Ralf
                            • D derrapf
                              An alle
                              Gruss Ralf
                              tombox
                              #833
                              @derrapf Siehst du denn die ganzen Daten in der audi app?
                              • T tombox
                                derrapf
                                schrieb am zuletzt editiert von derrapf
                                #834
                                @tombox Die hab ich gar nicht installiert. Moment. Ich such die im Store und installiert die mal...
                                ...Da kommt jetzt "Kontaktieren Sie Ihren in myAudi gespeicherten Audi Partner um sich als Besitzer Ihres Fahrzeugs festlegen zu lassen"
                                WTF?? Warum muss ein Anderer festlegen, dass mir mein Auto gehört??
                                Ansonsten sehe ich nur ein Fahrtenbuch, Kostenbuch, Servicethemen, Fahrzeugaustattung, und Upgrades. Also nix für das ich diese App bräuchte. Ich glaub deswegen hatte ich sie auch wieder runter geschmissen.
                                Ich seh grad: Ziele kann ich noch eingeben, irgendwelche News abrufen, und mich mit dem WLAN des Audi verbinden damit ich Online Radio hören kann
                                Keine Daten...oder Status...
                                Gruss Ralf
                                T J 2 Antworten Letzte Antwort
                                • D derrapf
                                  Gruss Ralf
                                  tombox
                                  #835
                                  @derrapf ja dann musst du Audi kontaktieren dass sie dein Fahrzeug mit dir verknüpfen
                                  • T tombox
                                    W Offline
                                    W Offline
                                    Wueli
                                    #836
                                    @tombox vielen Dank für die schnelle Anpassung. Funktioniert soweit in iobroker alles. Muss jetzt mal schauen wie ich das am schönsten mit nem Schalter im vis darstellen kann, dass der Wert einstellbar ist und auch entsprechend angezeigt wird wenn durch andere Instanzen umgeschaltet wird.
                                    • W Wueli
                                      tombox
                                      #837
                                      @wueli das sich der wert extern aktualisiert muss ich noch machen
                                      • D derrapf
                                        Gruss Ralf
                                        jhg
                                        #838
                                        @derrapf Wenn die Verifizierung nicht stattfinden würde, könnte jeder den Zugang zu deinem Auto aktivieren.
                                        Das möchtest du sicher auch nicht.
                                        Bei neueren Modellen im VW Konzern ist das besser gelöst, da wird ein QR-Code im Auto gescannt.
                                        Dann spart man sich den Aufwand.
                                        Da der Adapter genau dasselbe macht, wie die App, kannst du dich jetzt über fehlende Funktionalität aufregen oder dein Auto aktivieren.
                                        Eine andere Möglichkeit gibt es nicht.
                                        • W Offline
                                          W Offline
                                          Wueli
                                          #839
                                          @tombox ja das wäre super. Aktuell zeigt er im remote Reiter nur das an was ich zuletzt zum Auto geschickt habe. In der älteren Version deines Adapters war der Status abrufbar unter charger. Weiß aber nicht mehr den Reiter.
