  2. English
  3. Development
  4. New Adapter for rtl_433 incoming data
Geplant Angeheftet Gesperrt Verschoben Development
adapter
34 Beiträge 11 Kommentatoren 20.0k Aufrufe 13 Beobachtet
  • V vogtländer
    @phillipssc said in New Adapter for rtl_433 incoming data:
    344975000 -f 433920000
    thanks for your
    Answer. I switched to the current version. Unfortunately, I get the following error message listed below
    and in the adapter
    the settings cannot be saved.
    rtl_433.0 2021-03-26 11:51:26.329 error (13236) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:51:26.326 error (13236) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:51:26.248 error (13236) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.rtl_433/lib/brokerInterface.js:129:46 at /opt/iobroker/node_modules/iobroker.js-controller/lib/stat
    rtl_433.0 2021-03-26 11:51:26.240 error (13236) uncaught exception: Cannot read property 'val' of null
    rtl_433.0 2021-03-26 11:51:15.412 error (13175) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:51:15.407 error (13175) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:51:15.313 error (13175) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.rtl_433/lib/brokerInterface.js:129:46 at /opt/iobroker/node_modules/iobroker.js-controller/lib/stat
    rtl_433.0 2021-03-26 11:51:15.304 error (13175) uncaught exception: Cannot read property 'val' of null
    rtl_433.0 2021-03-26 11:51:06.473 error (13139) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.rtl_433/lib/brokerInterface.js:129:46 at /opt/iobroker/node_modules/iobroker.js-controller/lib/stat
    rtl_433.0 2021-03-26 11:51:06.469 error (13139) uncaught exception: Cannot read property 'val' of null
    rtl_433.0 2021-03-26 11:51:06.348 error (13139) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:51:06.339 error (13139) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:50:55.427 error (13097) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:50:55.422 error (13097) rtl_433 disconnected
    rtl_433.0 2021-03-26 11:50:55.342 error (13097) TypeError: Cannot read property 'val' of null at /opt/iobroker/node_modules/iobroker.rtl_433/lib/brokerInterface.js:129:46 at /opt/iobroker/node_modules/iobroker.js-controller/lib/stat
    phillipsscP Offline
    phillipsscP Offline
    phillipssc
    @vogtländer said in New Adapter for rtl_433 incoming data:
    That is an interesting error. I will make sure it doesn't happen again in the next version, but one of your objects did not get created correctly.
    If you can, check to see if you have an object without the discovered parameter in the META section:
    Find and delete that object (or enter a date for it) and you should be back in business.
    • V vogtländer
      thanks for your
      and in the adapter
      phillipsscP Offline
      phillipsscP Offline
      phillipssc
      @vogtländer - A new version is up that should let you put multiple frequencies in the configuration separated by a space or comma. The error you saw should be handled and if the adapter is put into debug mode, it should help you identify an improperly created device that is not behaving properly.
      V 1 Antwort Letzte Antwort
      • phillipsscP phillipssc
        V Offline
        V Offline
        vogtländer
        @phillipssc @phillipssc Sorry for reporting so late. I installed the update and the error has been fixed. But there is another problem.
        rtl_433.0 2021-04-01 15:33:46.507 debug (14260) Checking for dead devices...
        rtl_433.0 2021-04-01 15:33:16.507 debug (14260) Checking for dead devices...
        rtl_433.0 2021-04-01 15:32:46.508 debug (14260) Checking for dead devices...
        rtl_433.0 2021-04-01 15:32:16.502 info (14260) Go to https://github.com/merbanan/rtl_433 to for installation instructions
        rtl_433.0 2021-04-01 15:32:16.501 error (14260) rtl_433 error: {"code":"ERR_INVALID_ARG_VALUE"}
        rtl_433.0 2021-04-01 15:32:16.489 info (14260) spawning:
        phillipsscP 1 Antwort Letzte Antwort
        • V vogtländer
          phillipsscP Offline
          phillipsscP Offline
          phillipssc
          @vogtländer - What does your command line look like on the first tab of the setup page?
          V 2 Antworten Letzte Antwort
            V Offline
            V Offline
            vogtländer
            @phillipssc That was without input in the adapter and without rtl_433.conf
            when i enter my frequency it looks like this:
            rtl_433.0 2021-04-02 10:53:24.746 debug (5309) rtl_433.0.TFA-Pool-28: dead
            rtl_433.0 2021-04-02 10:53:24.682 debug (5309) Checking for dead devices...
            rtl_433.0 2021-04-02 10:53:08.926 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:07.858 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:06.770 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:05.727 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:04.688 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:03.653 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:02.518 debug (5309) sendTo "rtl_433" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:53:02.487 debug (5309) sendTo "listSerial" to system.adapter.admin.0 from system.adapter.rtl_433.0
            rtl_433.0 2021-04-02 10:52:54.676 info (5309) Go to https://github.com/merbanan/rtl_433 to for installation instructions
            rtl_433.0 2021-04-02 10:52:54.674 error (5309) rtl_433 error: {"code":"ERR_INVALID_ARG_VALUE"}
            rtl_433.0 2021-04-02 10:52:54.659 info (5309) spawning: -F json -C -f 868000000
            Another question where can you set the sample rate.
            I would test the frequency change if the basic settings work
              klassisch
              schrieb am zuletzt editiert von klassisch
              Thanks for developing this adapter and contributing to the ioBroker community.
              I am widely using 433 sensors. To integrate into ioBroker I am curently using RFLink which uses cheap RXB6 receivers and an arduino Mega 2560 to decode the received messages. An ioBroker adapter manages the messages into the objects folders, the pairing etc.
              As far as I understood, your adapter does similar things:
              • transceiver is a common USB SDR-stick such as Realtek RTL2832 based units
              • as a decoder serves the rtl_433 SW (which also is available for Windows). This is where the "magic happens" and novel units have to be implemented
              • your adapter glues the rtl_433 project to ioBroker, supplying a HMI for pairing and organized the object folders.
              Did I get this correctly?
              V phillipsscP 2 Antworten Letzte Antwort
                V Offline
                V Offline
                vogtländer
                @phillipssc
                Hello, I've now found time to deal with the problem.
                I updated the rtl_433 installation (not adapter). After that I got better logs and could
                customize the command line like this:
                rtl_433 -F json -f 868000000 -s 1024000 -f 433920000 -s 250000 -H 300 and it runs.
                I think there is the problem in the adapter that the command line is not created correctly.
                Still, the adapter is awesome!
                • K klassisch
                  V Offline
                  V Offline
                  vogtländer
                  @klassisch
                  yes this is how the adapter works.
                  It recognizes a large number of devices and also works simultaneously in the frequency range of approx. 433-868Mhz. The only disadvantage as far as I know you can only receive data.
                  Sending is not possible.
                  • V vogtländer
                    @klassisch
                    klassisch
                    @vogtländer sagte in New Adapter for rtl_433 incoming data:
                    For me that would be no limitation. Althoug RFLink also supports transmitting, I neither use it nor need it. Most of the 433MHz units do not have a backward channel and are 2nd choice for actuators. For actuators I prefer Homematic, Shelly, Zigbee.
                    As far as I am informed, the RTL2832 has an on chip integrated USB interface. This could be a disadvantage for my mode of operation. I modified the arduino Mega for usage over Ethernet. This makes me independent of the location of my ioBroker computer.
                    • V vogtländer
                      @phillipssc
                      phillipsscP Offline
                      phillipsscP Offline
                      phillipssc
                      @vogtländer - It looks like it had to do with unit conversion. It would have been interesting to see what that said - but I will cover it in the next round none the less.
                      • K klassisch
                        phillipsscP Offline
                        phillipsscP Offline
                        phillipssc
                        @klassisch said in New Adapter for rtl_433 incoming data:
                        Yes, that's precisely it, and as mentioned incoming messages only
                        • K klassisch
                          phillipsscP Offline
                          phillipsscP Offline
                          phillipssc
                          @klassisch "This makes me independent of the location of my ioBroker computer." You can use this as such in this adapter too. Rtl_433 runs on top of Rtl-sdr. You can run rtl_sdr on a Raspberry Pi with the dongle in tcp_ip mode. Feed the params into rtl_433 (which my adapter supports) and it will connect to the remote computer for the data. Better instructions are in my README
                          K R 2 Antworten Letzte Antwort
                            klassisch
                            @phillipssc because ioBroker supports multihost operation, this is always an (additional) option. You can also run your adapter on a raspi (or similar) as an ioBroker slave.
                              Radi
                              schrieb am zuletzt editiert von Radi
                              @phillipssc Could You please explain the settings for tcp_ip mode. I'am not able to get it working. I get these messages:
                              rtl_433.0
                              	2021-09-28 17:52:52.688	debug	rtl_433 ret: -2:null
                              rtl_433.0
                              	2021-09-28 17:52:52.687	info	Go to https://github.com/merbanan/rtl_433 to for installation instructions
                              rtl_433.0
                              	2021-09-28 17:52:52.686	error	rtl_433 is not found on the system. Please check the installation of rtl_433
                              rtl_433.0
                              	2021-09-28 17:52:52.682	info	spawning: rtl_tcp=192.168.69.140
                              rtl_433.0
                              	2021-09-28 17:52:52.626	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:52:22.625	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:51:52.624	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:51:22.624	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:51:12.681	debug	killing rtl_433
                              rtl_433.0
                              	2021-09-28 17:51:12.680	error	rtl_433 disconnected, reconnecting in 100s ...
                              rtl_433.0
                              	2021-09-28 17:51:12.680	debug	rtl_433 ret: -2:null
                              rtl_433.0
                              	2021-09-28 17:51:12.678	info	Go to https://github.com/merbanan/rtl_433 to for installation instructions
                              rtl_433.0
                              	2021-09-28 17:51:12.677	error	rtl_433 is not found on the system. Please check the installation of rtl_433
                              rtl_433.0
                              	2021-09-28 17:51:12.673	info	spawning: rtl_tcp=192.168.69.140
                              rtl_433.0
                              	2021-09-28 17:50:52.624	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:50:34.582	silly	redis message expired/evicted __keyevent@0__:expired:io.system.adapter.dwd.0.connected
                              rtl_433.0
                              	2021-09-28 17:50:22.624	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:49:52.672	debug	killing rtl_433
                              rtl_433.0
                              	2021-09-28 17:49:52.672	error	rtl_433 disconnected, reconnecting in 80s ...
                              rtl_433.0
                              	2021-09-28 17:49:52.671	debug	rtl_433 ret: -2:null
                              rtl_433.0
                              	2021-09-28 17:49:52.669	info	Go to https://github.com/merbanan/rtl_433 to for installation instructions
                              rtl_433.0
                              	2021-09-28 17:49:52.669	error	rtl_433 is not found on the system. Please check the installation of rtl_433
                              rtl_433.0
                              	2021-09-28 17:49:52.663	info	spawning: rtl_tcp=192.168.69.140
                              rtl_433.0
                              	2021-09-28 17:49:52.623	debug	Checking for dead devices...
                              rtl_433.0
                              	2021-09-28 17:49:22.623	debug	Checking for dead devices...
                              • R Radi
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                rtl_433.0
                                phillipsscP Offline
                                phillipsscP Offline
                                phillipssc
                                schrieb am zuletzt editiert von phillipssc
                                @radi - Sorry I didn't see this sooner.
                                If you want to use TCP/IP to read an adapter. The remote host with the RTL-SDR dongle must be running rtl_sdr (rtl_tcp is included with the dist). Then on that host you would run the command:
                                rtl_tcp -a hostname -I <ip address>
                                On your ioBroker server you will need to run rtl_433 (which also requires rtl_sdr) and configure the instance with the ip address. You can take ioBroker out of the picture for testing and run the command:
                                rtl_433 -F json -d rtl_tcp://<ip address>:1234
                                In each case the <ip address> would be the address of the host with the RTL-SDR dongle - presumably 192.168.69.140
                                From the looks of the log provided rtl_433 is not installed on the ioBroker host yet
                                W 1 Antwort Letzte Antwort
                                • w00dst0ckW Offline
                                  w00dst0ckW Offline
                                  w00dst0ck
                                  Hello @phillipssc,
                                  I've installed your adapter yesterday and it works very well.
                                  But I've got a problem when I restart the adapter in iobroker.
                                  The spawned subprocess ob rtl_433 won't be killed and on the next restart it' not possible to start a new instance of rtl_433 because the usb device is blocked by the older process.
                                  Any advice?
                                  E 1 Antwort Letzte Antwort
                                  • w00dst0ckW w00dst0ck
                                    Hello @phillipssc,
                                    Any advice?
                                    Elmar Faber
                                    @w00dst0ck @phillipssc I have the same problem, is there a chance to solve the problem?
                                    w00dst0ckW 1 Antwort Letzte Antwort
                                    • E Elmar Faber
                                      w00dst0ckW Offline
                                      w00dst0ckW Offline
                                      w00dst0ck
                                      @elmar-faber as you can see, my question is unanswered.
                                        W Offline
                                        W Offline
                                        Wolfi
                                        schrieb am zuletzt editiert von Wolfi
                                        @phillipssc
                                        help can't get it to work in iobroker (TCP/IP)
                                        what command on the RTL-SDR host
                                        and which one in the iobroker adapter ??
                                        Please be more specific command with example IP
                                        42e2f40f-24b5-4e57-bb76-5e20f91e1693-image.png f91a5d7e-c3aa-4b51-91f7-4c752878e7d6-image.png
                                        • W Wolfi
                                          @phillipssc
                                          phillipsscP Offline
                                          phillipsscP Offline
                                          phillipssc
                                          @wolfi Sorry I missed this. I'm not sure what the test you did makes sense. What happens if you run rtl_433 -F json -d rtl_tcp://192.168.178.153:1234 ?
                                          R 1 Antwort Letzte Antwort
