  4. Wetterdatendarstellung von HM- und HMIP-Geräten inn float
    2.6k
    4.5k
27 Beiträge 4 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    kanzlerleuk
    http://192.168.178.39:8082/flot/index.html?range=1440&zoom=false&axeX=lines&axeY=inside&hoverDetail=true&aggregate=onchange&chartType=step&live=60&instance=sql.0&l%5B0%5D%5Bid%5D=hm-rpc.0.LEQ0799023.1.TEMPERATURE&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%231868a8&l%5B0%5D%5Bthickness%5D=1&l%5B0%5D%5Bshadowsize%5D=1&l%5B0%5D%5Bsmoothing%5D=0&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5Bunit%5D=%C2%B0C&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bname%5D=Temperatur+Hauswand&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bxaxe%5D=bottom&l%5B0%5D%5Bmin%5D=-5&l%5B0%5D%5Bmax%5D=25&l%5B0%5D%5Binstance%5D=sql.0&l%5B1%5D%5Bid%5D=hm-rpc.0.LEQ0799023.1.HUMIDITY&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%2300FF00&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Luftfeuchte+Hauswand&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=100&l%5B1%5D%5Binstance%5D=sql.0&l%5B2%5D%5Bid%5D=HmIP-SWO-PR+00185BE9A574BB%3A1.ACTUAL_TEMPERATURE&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%23ff004d&l%5B2%5D%5Bthickness%5D=1&l%5B2%5D%5Bshadowsize%5D=1&l%5B2%5D%5Bname%5D=Temperatur+Gartenhaus&l%5B2%5D%5Bxmove%5D=0&l%5B2%5D%5Byaxe%5D=right&l%5B2%5D%5Bxaxe%5D=bottom&l%5B2%5D%5BafterComma%5D=0&l%5B2%5D%5Bdashes%5D=false&l%5B2%5D%5BdashLength%5D=10&l%5B2%5D%5BspaceLength%5D=10&l%5B2%5D%5Bmultiplicator%5D=1&l%5B2%5D%5Bunit%5D=%C2%B0C&l%5B2%5D%5Bsmoothing%5D=0&l%5B2%5D%5Binstance%5D=sql.0&l%5B2%5D%5Bmin%5D=-5&l%5B2%5D%5Bmax%5D=25&l%5B3%5D%5Bid%5D=HmIP-SWO-PR+00185BE9A574BB%3A1.HUMIDITY&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bthickness%5D=1&l%5B3%5D%5Bshadowsize%5D=1&l%5B3%5D%5Bname%5D=Luftfeuchte+Gartenhaus&l%5B3%5D%5Bxmove%5D=0&l%5B3%5D%5Byaxe%5D=left&l%5B3%5D%5Bxaxe%5D=bottom&l%5B3%5D%5BafterComma%5D=0&l%5B3%5D%5Bdashes%5D=false&l%5B3%5D%5BdashLength%5D=10&l%5B3%5D%5BspaceLength%5D=10&l%5B3%5D%5Bmultiplicator%5D=1&l%5B3%5D%5Bunit%5D=%25&l%5B3%5D%5Bsmoothing%5D=0&l%5B3%5D%5Binstance%5D=sql.0&l%5B3%5D%5Bmin%5D=0&l%5B3%5D%5Bmax%5D=100&aggregateType=step&aggregateSpan=300&relativeEnd=now&timeType=relative&noBorder=noborder&bg=rgba(0%2C0%2C0%2C0)&timeFormat=%25H%3A%25M&useComma=true&noedit=true&animation=0&legend=se
    • K kanzlerleuk
      Bei dem y-Achsenbereich kann nichts angezeigt werden, wo kann man das einstellen? Die Temperatur nochmal aktuell.
      @kanzlerleuk sagte in Wetterdatendarstellung von HM- und HMIP-Geräten inn float:
      Endlicch sieht man die Orsache!
      wenn du nur +/- 0 hast sieht man deine Werte nicht.
      Wenn du die gleiche Achsen nehmen willst wie für HomeMatic musst du das auch unter mehr definieren
        kanzlerleuk
        @homoran Vielen Dank für deine intensive Hilfe.
        Bitte weise einem alten Mann noch einmal den Weg:
        "wenn du nur +/- 0 hast sieht man deine Werte nicht." - Wo kann ich das ändern?
        "Wenn du die gleiche Achsen nehmen willst wie für HomeMatic musst du das auch unter mehr definieren" - dto.
        Dann wäre Ostern für mich gerettet.
        • K kanzlerleuk
          entweder indem du wie Paul schrieb sinnvolle min / max Werte einträgst, oder unter dem Menüpunkt mehr die gewünschte Refernez-Achse angeibst
          -1
            kanzlerleuk
            @homoran Vielen Dank für eure Mühe, ich bin zu neu im float und bekomme es nicht hin.
            Trotzdem euch allen frohe Ostern und bleibt stark!
            • K kanzlerleuk
              wo hakt es denn?
              Hast du mal das Zahnrad unter "mehr" bei den HmIP Datenreihen angeklickt und y-Achse ausgewählt?
                wo hakt es denn?
                kanzlerleuk
                ich bin zu blöd und weis nicht wo ich was eintragen soll, habe sogar eine kleine Doku von float 😢
                • K kanzlerleuk
                  in der Tabelle muss t u erst mal in den ersten beiden Zeilen sinnvolle MIN und MAX Werte für Temperatur und Feuchte einstellen
                  in den Zeilen 3 und 4 trägst du dann hier unter gemeinsame Y-Achse woe jetzt default steht die entsprechende Achse 1 oder 2 (je nachdem was Temp oder Feuchte ist) ein
                  K sigi234S 2 Antworten Letzte Antwort
                    kanzlerleuk
                    @homoran Lieber Homoran, vielen Dank für deine ausdauernde Hilfe. Jetzt komme ich weiter.
                    Ein frohes Osterfest wünscht
                    Thomas
                      sigi234S Online
                      sigi234S Online
                      Und wieder ein glücklicher iobroker User.......👍 😀
                      • sigi234S sigi234
                        kanzlerleuk
                        @sigi234 Voting unten rechts würde ich gern benutzen aber wo ist das genau wobei ich weis wo unten rechts ist.
