  4. [Neuer Adapter] EuSec
    6.8k
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 618.2k Aufrufe 147 Beobachtet
  • S Stormbringer
    @berndpehome ist zwar viel besser geworden aber stimmt das problem tritt bei mir auch auf
    berndpehome
    schrieb am zuletzt editiert von berndpehome
    jetzt wollte ich den eufy security client adapter installieren und dadurch geht der eufy security nicht mehr
    host.iobroker 2021-03-20 21:19:11.164 error instance system.adapter.eufy-security.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker 2021-03-20 21:19:11.163 error Caught by controller[0]: }
    host.iobroker 2021-03-20 21:19:11.163 error Caught by controller[0]: requestPath: 'eufy-security-client'
    host.iobroker 2021-03-20 21:19:11.163 error Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
    host.iobroker 2021-03-20 21:19:11.162 error Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker 2021-03-20 21:19:11.162 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32) {
    host.iobroker 2021-03-20 21:19:11.162 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.iobroker 2021-03-20 21:19:11.162 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.iobroker 2021-03-20 21:19:11.161 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eufy-security/build/main.js:38:32)
    host.iobroker 2021-03-20 21:19:11.161 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:74:18)
    host.iobroker 2021-03-20 21:19:11.160 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:887:19)
    host.iobroker 2021-03-20 21:19:11.160 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    host.iobroker 2021-03-20 21:19:11.160 error Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:802:27)
    host.iobroker 2021-03-20 21:19:11.159 error Caught by controller[0]: at Function.Module._findPath (internal/modules/cjs/loader.js:508:18)
    host.iobroker 2021-03-20 21:19:11.159 error Caught by controller[0]: at tryPackage (internal/modules/cjs/loader.js:295:19)
    host.iobroker 2021-03-20 21:19:11.159 error Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
    host.iobroker 2021-03-20 21:19:11.159 error Caught by controller[0]: ^
    host.iobroker 2021-03-20 21:19:11.158 error Caught by controller[0]: throw err;
    host.iobroker 2021-03-20 21:19:11.157 error Caught by controller[0]: internal/modules/cjs/loader.js:303
    kennt jemand eine lösung wie ich den eufy security client sauber deinstallieren kann?
    läuft wieder, client ordner hatte sich noch im docker versteckt, gelöscht und security adapter läuft wieder
    • B berndpehome
      bishop9191
      @berndpehome
      Ich stehe gerade etwas auf dem Schlauch. Ich habe den Eufy-Security Adapter installiert.
      Brauche ich zusätzlich den eufy-security-client Adapter?
      • B bishop9191
        @berndpehome
        berndpehome
        @bishop9191 nein
          bishop9191
          Seit ich auf die Version 0.4.3 bin, wird der Log mit Fehlern vollgemacht wenn eine Kamera etwas aufzeichnet. Hat das noch wer?
          Außerdem klappt die Aktivierung/Deaktivierung der Kameras nicht.
          Weiß jemand woran das liegen könnte?
          Ich nutze noch keinen 2FA... Sollte damit aber nichts zu tun haben, oder?
          • B bropat
            Hi @loverz,
            der eufy-security Adapter benötigt nun zwingend den web Adapter.
            Don LukaD Offline
            Don LukaD Offline
            Don Luka
            @bropat kannst du mir erklären was es mit folgender Fehlermeldung auf sich hat?
            Sam SonS 1 Antwort Letzte Antwort
              bjoernson
              Super vielen Dank für den tollen Adapter :)
              Gibt es die Möglichkeit zu erkennen ob eine Kamera gerade verbunden ist oder nicht (wenn z. B. der Stecker draußen ist). Bei mir ändern sich an den States leider nichts, wenn ich den Stecker ziehe. Ich bekomme nur eine entsprechende Fehlermeldung im Log.
              • B bropat
                Hi @loverz,
                N Offline
                N Offline
                nachon
                @bropat
                Moin Moin,
                ich weiss nicht, ob ich etwas übersehen habe oder falsch mache, aber nach der Installation kann ich den Adapter nirgends konfigurieren. Er taucht unter den Adaptern zwar auf, aber nicht unter den Objekten oder Instanzen.
                Mache ich da etwas falsch oder habe ich etwas übersehen?
                Danke vielmals und viele Grüße
                L 1 Antwort Letzte Antwort
                • N nachon
                  @bropat
                  Moin Moin,
                  loverz
                  #66
                  @nachon manchmal muss die Instanz auch manuell hinzugefügt werden.
                  Das geht direkt neben dem Adapter.
                  N 1 Antwort Letzte Antwort
                  • L loverz
                    N Offline
                    N Offline
                    nachon
                    #67
                    @loverz
                    Danke. Ich hätte auch selbst drauf kommen können. Das war der entscheidende Hinweis. :) TOP!
                    • B bropat
                      Hi @loverz,
                      Don LukaD Offline
                      Don LukaD Offline
                      Don Luka
                      schrieb am zuletzt editiert von Don Luka
                      #68
                      @bropat Ich weiss nicht was ich falsch mache😕
                      Weisst du weshalb die Instanz nicht startet und keine Objekte generiert werden?
                      Im Log sehe ich keine Einträge für den eufy Adapter
                      • Don LukaD Don Luka
                        Sam SonS Offline
                        Sam SonS Offline
                        Sam Son
                        schrieb am zuletzt editiert von Sam Son
                        #69
                        @don-luka Geh mal auf Logs, und schau ob du das was in rot findest für Quelle "eufy-security.0". Wenn du da nichts findest, wegen dem web Fehler, versuche mal den "WEB Server" Adapter zu installieren, das hatte bei mir geholfen bei einer ähnlichen Fehlermeldung.
                        Don LukaD 1 Antwort Letzte Antwort
                          Sam SonS Offline
                          Sam SonS Offline
                          Sam Son
                          #70
                          Wie kann man sich die letzten Bilder / Streams ansehen?
                          • Ich habe die IP herausgefunden meiner wired doorbell herausgefunden
                          • Im Adapter finde ich z.B. /eufy-security.0/T8200NXXXXXXXXXX/last_event/T8200NXXXXXXXXXX.jpeg
                          • Wenn ich das ganze kombinieren, zu z.b. "http://193.80.75.XX:8082/eufy-security.0/T8200NXXXXXXXXXX/last_event/T8200NXXXXXXXXXX.jpeg" und Browser öffnene will funktioniert das aber nicht
                          Geht das eventuell nicht mit der Wired Doorbell, oder mach ich was falsch?
                          • nukleuzN Offline
                            nukleuzN Offline
                            nukleuz
                            #71
                            ich verfolge diesen Beitrag seit ein paar Tagen...
                            Ich stehe kurz vor dem Kauf einer Türklingel von eufy.
                            Was ich nicht ganz verstanden habe:
                            Ist es möglich auch einen Stream der Türklingeln abzugreifen/anzuzeigen oder nur bei den Kameras?
                            Hat jemand auch schon, wenn möglich, den Stream in Lovelace zum Laufen bekommen?
                            Danke für Infos und frohe Ostern 🐣
                            Intel NUC -> ProxMox -> Debian -> ioBroker (Master)| RPI3B+ -> rtl_433 (Slave) | CCU2
                              michael 1975
                              #72
                              Bei mir bleibt die Instanz auch rot
                              an was kann das Liegen.
                              Gruß Micha
                              • Sam SonS Sam Son
                                berndpehome
                                #73
                                @sam-son
                                du musst die ip von deinem Iobroker eingeben dann gehts im Browser
                                • nukleuzN nukleuz
                                  berndpehome
                                  #74
                                  @nukleuz
                                  man kann auch den Stream abgreifen aber im Iobroker Vis ist es mir leider auch noch nicht gelungen.
                                  Ich habe mein Vis jetzt so angepasst das wenn es Klingelt oder eine Gesichtserkennung stattfindet mir die Vis auf die Eufy umschaltet und ich das aktuelle Bild der WiredDoorbell T8200 sehe und gleichzeitig bekomme ich auf meinem Echo Show8 den Livestream.
                                  nukleuzN 1 Antwort Letzte Antwort
                                  • B berndpehome
                                    @nukleuz
                                    nukleuzN Offline
                                    nukleuzN Offline
                                    nukleuz
                                    #75
                                    @berndpehome
                                    Ok, danke für Info.
                                    Dann wird der Stream "nur" als RTSP ausgegeben...
                                    Was meinst du mit VIS schaltet auf Eufy um?
                                    Der Livestream auf dem Echo Show -> muss der noch bestätigt werden oder macht das der Skill automatisch - das Abspielen?
                                    • B bropat
                                      Mit den Push-Benachrichtigung erhalte ich im Adapter z.B Motion-Events. Ich möchte nun diese "Events" korrekt im Adapter implementieren.
                                      Ich bekomme bei einem Motion-Event nur den Auslöser. z.B.:
                                         "id":"<redacted>",
                                         "from":"348804314802",
                                         "to":"<redacted>",
                                         "category":"com.oceanwing.battery.cam",
                                         "persistentId":"0:1605347025068035%0d2a775cf9fd7ecd",
                                         "ttl":3600,
                                         "sent":"1605347025064",
                                         "payload":{
                                            "content":"Vorne:Someone has been spotted",
                                            "device_sn":"<redacted>",
                                            "event_time":"1605347024692",
                                            "payload":{
                                               "a":1,
                                               "s":"<redacted>",
                                               "c":0,
                                               "i":"0",
                                               "k":92,
                                               "create_time":1605347024692,
                                               "session_id":"<redacted>",
                                               "notification_style":1,
                                               "push_count":1,
                                               "p":"20201114104341",
                                               "n":"Vorne"
                                            "push_time":"1605347025054",
                                            "station_sn":"<redacted>",
                                            "title":"",
                                            "type":"9",
                                            "google.c.sender.id":"348804314802"
                                      Wie sollte dies implementiert werden? Gibt es hier eine Best Practice?
                                      Kann mir hier jemand helfen? :)
                                      marcbroe
                                      #76
                                      @bropat Wie kann ich z.B. per Blockly den Status ändern? Also von "Auswärts" nach z.B. Daheim :-) Danke schon einmal.
                                      Auch ein großes Lob an den Entwickler :-) Ich hoffe das es weiterentwickelt wird... Es ist definitiv eine "Paypalspende" wert :-)
                                      • nukleuzN nukleuz
                                        @berndpehome
                                        Ok, danke für Info.
                                        berndpehome
                                        #77
                                        @nukleuz
                                        mit VIS schaltet auf Eufy um meine ich das egal welche VIS Seite gerade offen ist mir für 2 Minuten eine VIS Seite mit aktuellem Kamerabild gezeigt wird und dann wieder zurück auf den Homescreen geschalten wird und ob der Skill das automatisch macht müsste ich mal testen da ich mir sofort ein Blockly geschrieben habe des dem ECHO Show sagt er soll mir die Türklingel zeigen wenn die Klingel gedrückt wird, müsste ich mal ohne Skill testen.
                                        • B berndpehome
                                          @nukleuz
                                          nukleuzN Offline
                                          nukleuzN Offline
                                          nukleuz
                                          #78
                                          @berndpehome
                                          Kannst du mal dein Blockly zeigen, wie du das mit dem Bild auf dem Echo gelöst hast? Danke vorab.
