  4. Druckerinfos mit Parser auslesen
    6.3k
113 Beiträge 7 Kommentatoren 19.1k Aufrufe 8 Beobachtet
  • FredFF FredF
    Mit meinem Brother kommt bei
    BK)**<.{8}(\d+)%
    die Meldung Please login.
    Wo gebe ich denn die Credentials an?
    <?xml version="1.0" encoding="iso-8859-1"?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"><html lang="en-gb" xmlns="http://www.w3.org/1999/xhtml" xml:lang="en-gb"><head><meta http-equiv="Content-Script-Type" content="text/javascript" /><meta http-equiv="content-style-type" content="text/css" /><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /><script type="text/javascript" src="/common/js/ews.js"></script>
     <link rel="stylesheet" type="text/css" href="../common/css/common.css" />
     <link rel="stylesheet" type="text/css" href="../common/css/ews.css" /><title>Brother MFC-J5335DW</title></head><body><div id="baseFrame"><div id="frameContainer"><div id="headerFrameContainerLeft"><div id="headerFrameContainerRight"><div id="headerFrameInner"><div id="headerFrame"><div id="modelName"><h1>MFC-J5335DW</h1><div class="SetBox" id="SetBoxAuthRight"><div id="SetBoxAuthLeft"><form method="post" action="/general/status.html"><div><input type="hidden" id="CSRFToken" name="CSRFToken" value="K+KaDzEImig3THsFocslFKgXdSs64g8JHQ=="/><!-- mid-begin: a37c7680312cdfbc7eb7ab5d5e8af4e37308d5cdf2d86a5b81ea67706103455f -->Login<!-- mid-end --><input type="password" id="LogBox" name="B9c2" autofocus /><input type="hidden" name="loginurl" value="/etc/loginerror.html?url=/general/information%2Ehtml"/><input id="login" type="submit" value="&nbsp;" /></div></form></div></div></div><div id="corporateLogo"><img src="/common/images/logo.gif" alt="Brother" /></div></div><div id="solutions"><div><span><a href="http://solutions.brother.com/cgi-bin/solutions.cgi?MDL=mfc674&amp;LNG=de&amp;SRC=DEVICE"><!-- mid-begin: 61bfd52616ea551fcd952e01af765fc3e71dce2a2a51f3e5e34dfaf931334696 -->Brother<br />Solutions&#32;Center<!-- mid-end --></a></span></div></div><div id="tabMenu"><ul><li><ul><li class="selected"><p><!-- mid-begin: 868421f57559a3ffdec79ca26081124e14de22207bbe28bc18e906c6072d6a63 -->General<!-- mid-end --></p></li></ul></li></ul></div></div></div></div><div id="mainFrameContainer"><div id="mainFrameTopLeft"><div id="mainFrameTopRight"><div id="mainFrameTopInner"><div id="subTabMenu"><div><span><a href="#topBack">Bottom<img src="/common/images/ic_bottom.gif" alt="Bottom" /></a></span></div></div></div></div></div><div id="mainFrameInner"><div id="subMenu"><div><a href="/general/status.html"><!-- mid-begin: caae736219827dda68b4d17bcf52417bd7a70e0d78a403c6f0b088d8068af6db -->Status<!-- mid-end --></a></div><div><a href="/general/reflesh.html" class="subPage"><!-- mid-begin: 2a045da7c4b03420a7481c91bc1af3125247576856513aaf85878da5f7bfe21b -->Auto&#32;Refresh&#32;Interval<!-- mid-end --></a></div></div><div id="rightFrameContainer"><div id="rightFrame"><div id="mainContent"><div id="pageTitle"><h2><!-- mid-begin: a67533155fd28586e19ffed21bac8f8e73af5603b44670438baad6f3562c6b66 -->Please&#32;Login<!-- mid-end --></h2></div><div id="pageContents"><div class="contentsGroup"><p class="noteMessage"><!-- mid-begin: b3476a46010a178c5887a4264d53013c4630e9486c21d5a58e9cb7930bb0723c -->To&#32;Access&#32;this&#32;page&#32;you&#32;are&#32;required&#32;to&#32;Login,&#32;please&#32;Login.<!-- mid-end --></p></div></div></div></div></div><script type="text/javascript"><!--
    SetMinHeight();
    // --></script></div><div id="mainFrameBottomLeft"><div id="mainFrameBottomRight"><div id="mainFrameBottomInner"></div></div></div></div><div id="footerFrameContainer"><div id="copyright">Copyright(C) 2000-2016 Brother Industries, Ltd. All Rights Reserved.</div><div id="topBack"><a href="#">Top<img src="/common/images/ic_pt.gif" alt="Top" /></a></div></div></div></div></body></html>
    #100
    @fredf sagte in Druckerinfos mit Parser auslesen:
    das geht eben nicht über den Parser.
    Je nachdem wie das gesichert ist geht das auch anders nicht.
    Deswegen war das meine erste Frage
    EDIT:
    du brauchst ein Web-interface mit den Toner/Tintenständen ohne login
    bei dir kommt:
    you are required to Login, please Login
    • K Kuddel
      ich habe seit gestern auch einen Brother (DCP-L3550CDW) im Haus und scheitere auch gerade an der Abfrage der Tonerstände per Parser, da ja per SNMP nichts sinnvolles rauskommt.
      Ich habe mal mi Schwarz angefangen zu testen:
      URL: http://192.168.4.101/general/information.html?kind=item
      ReqEx: (BK)**</dt><dd>(([0-9.]*)%)
      Rolle: Wert
      Typ: number
      Ergebnis:
      EDIT:
      Schwarze Magie ? Ich habe an den Einstellungen nichts verändert:
      wobei 32% aber falsch ist, da der Drucker ja neu ist:
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      #101
      @kuddel said in Druckerinfos mit Parser auslesen:
      DCP-L3550CDW
      snmp aktivieren für deinen drucker
      https://support.brother.com/g/b/faqend.aspx?c=de&lang=de&prod=dcpl3550cdw_eu&faqid=faq00100232_511
      oid zum probieren
      http://www.drucker-snmp.de/printer-administration/zaehlerstand-auslesen/
      alternativ oder ergänzend einen snmp browser um darüber andere oids zu finden, die passen könnten.
      darüber habe ich die bei mir gefunden
      https://www.heise.de/download/product/ireasoning-mib-browser-personal-edition-56374
      du musst beachten.
      wenn der füllstand in Prozent angezeigt wird, dann könnte im snmp der wert auch in 255 Einheiten (1 byte) stehen. 255=100% und 0=0%
      Meine Adapter und Widgets
      Links im Profil
      • OliverIOO OliverIO
        DCP-L3550CDW
        oid zum probieren
        du musst beachten.
        Kuddel
        schrieb am zuletzt editiert von Kuddel
        #102
        @oliverio
        SNMP aktiv: OK
        oid zum probieren:
        Gesamt Anzahl an gedruckten Seiten = 6
        Hersteller -= leer
        Lebensdauer Bandeinheit = 49986
        Lebensdauer Trommeleinheit = 17889
        Toner / Tintenpatrone Füllstand: schwarz = Black Toner Cartridge
        SNMP Browser (MIB Browser):
        • K Kuddel
          @oliverio
          SNMP aktiv: OK
          oid zum probieren:
          Hersteller -= leer
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #103
          @oliverio
          SNMP aktiv: OK
          oid zum probieren:
          Hersteller -= leer
          ok,
          sind aber wenige zeilen im mib browser
          ich habe da beim hl-3040cn über 2000 zeilen
          Links im Profil
            @oliverio
            SNMP aktiv: OK
            oid zum probieren:
            Hersteller -= leer
            ok,
            Kuddel
            #104
            @oliverio ja bei mir sind das auch so viele zeilen wie bei dir.
            ich kann ganz schön viel runterscrollen.
            Hast du deinen Tonerstand über SNMP ausgelesen?
            • K Kuddel
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #105
              ja habe ich, habe nun auch den post von damals gefunden, der mir geholfen hat:
              https://administrator.de/forum/brother-snmp-oid-toner-208991.html
              so, wenn ich jetzt folgendes in der Testumgebung bei mir mache:
              Name des Toners:
              root@nagios:~# snmpget -v1 -c public 192.168.120.31 1.3.6.1.2.1.43.11.1.1.6.1.1
              Antwort: SNMPv2-SMI::mib-2.43.11.1.1.6.1.1 = STRING: "Black Toner Cartridge"
              Zustand, wenn voll:
              root@nagios:~# snmpget -v1 -c public 192.168.120.31 1.3.6.1.2.1.43.11.1.1.8.1.1
              Antwort: SNMPv2-SMI::mib-2.43.11.1.1.8.1.1 = INTEGER: -2
              Aktueller Stand:
              root@nagios:~# snmpget -v1 -c public 192.168.120.31 1.3.6.1.2.1.43.11.1.1.9.1.1
              Antwort: SNMPv2-SMI::mib-2.43.11.1.1.9.1.1 = INTEGER: -3
              Rechne ich nun folgendes:
              Füllstand = Stand * 100 / Voll
              Füllstand = -2 * 100 / -3
              Füllstand = -200 / -3
              Füllstand = 66,67
              Sprich: Der Toner wird in 3er Schritten abgefragt. Nun musst du nur noch Schwellenwerte einbauen. D.h. alles über 40% ist ok. 10 - 40 % = Warning, weniger als 10% = error.
              Gruß,
              Florian
              bei mir ist es tatsächlich auch so, mit dem -3 und -2 (aktuell)
              Links im Profil
                Name des Toners:
                Zustand, wenn voll:
                Aktueller Stand:
                Füllstand = 66,67
                Gruß,
                Florian
                Kuddel
                #106
                @oliverio ja auf der Seite war ich heute auch schon.
                Die Logik geht aber nicht auf.
                Ich habe mal eben die gleichen Abfragen bei mir gemacht:
                Laut der Bespielrechnung (gleiche Werte für Stand und Voll) würde bei mir auch 66,67% rauskommen.
                Der Toner ist ja aber neu und noch komplett voll.
                • K Kuddel
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #107
                  bei mir passt es bisher.
                  drucke aber auch nicht viel.
                  werde es sehen, wenn es leerer wird
                  Links im Profil
                    Kuddel
                    #108
                    Da ich vom Parser Adaper und ReqEx überhaupt keine Ahnung habe, bräuchte ich noch einmal Hilfe für folgende Infos:
                    Den Seitenzähler konnte ich per SNMP abfragen, die Aufteilung in schwarzweiß und farbe nicht.
                    Quelltext
                    <?xml version="1.0" encoding="iso-8859-1"?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"><html lang="de" xmlns="http://www.w3.org/1999/xhtml" xml:lang="de"><head><meta http-equiv="Content-Script-Type" content="text/javascript" /><meta http-equiv="content-style-type" content="text/css" /><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" /><script type="text/javascript" src="/common/js/ews.js"></script><link rel="stylesheet" type="text/css" href="../common/css/common.css" />
                    <title>Brother DCP-L3550CDW series</title></head><body><div id="baseFrame"><div id="frameContainer"><div id="headerFrameContainerLeft"><div id="headerFrameContainerRight"><div id="headerFrameInner"><div id="headerFrame"><div id="modelName"><h1>DCP-L3550CDW series</h1><div class="SetBox" id="SetBoxAuthRight"><div id="SetBoxAuthLeft"><form method="post" action="/general/status.html"><div><input type="hidden" id="CSRFToken" name="CSRFToken" value="f9MDRVUttI96beZxOrP0UxbQCW0mNjPW3bcUY3A7iGWp0rXiKQ=="/>Anmelden<input type="password" id="LogBox" name="B129d" /><input type="hidden" name="loginurl" value="/general/information.html?kind=item"/><input id="login" type="submit" value="&nbsp;" /></div></form></div></div></div><div id="corporateLogo"><a href="http://www.brother.com" target="_blank" ><img src="/common/images/logo.gif" alt="Brother" /></a></div></div><div id="solutions"><div><span><a href="http://solutions.brother.com/cgi-bin/solutions.cgi?MDL=m00124&amp;LNG=de&amp;SRC=DEVICE">Brother<br />Solutions&#32;Center</a></span></div></div><div id="tabMenu"><ul><li><ul><li class="selected"><p>Allgemein</p></li></ul></li></ul></div></div></div></div><div id="mainFrameContainer"><div id="mainFrameTopLeft"><div id="mainFrameTopRight"><div id="mainFrameTopInner"><div id="subTabMenu"><div><span><a href="#topBack">Bottom<img src="/common/images/ic_bottom.gif" alt="Bottom" /></a></span></div></div></div></div></div><div id="mainFrameInner"><div id="subMenu"><div><a href="/general/status.html">Status</a></div><div><a href="/general/reflesh.html" class="subPage">Automatische&#32;Aktualisierung</a></div><div class="selected"><div class="top"><div class="bottom"><a href="/general/information.html?kind=item">Wartungsinformationen</a></div></div></div><div><a href="/general/lists.html">Berichte/Listen</a></div><div><a href="/general/find.html">Ger&auml;t&#32;suchen</a></div><div><a href="/general/contact.html">Ansprechpartner&#32;&amp;&#32;Standort</a></div><div><a href="/general/sleep.html">Energiespardauer</a></div><div><a href="/general/powerdown.html">Autom.&#32;Abschaltung</a></div><div><a href="/general/volume.html">Lautst&auml;rke</a></div><div><a href="/general/panel.html">Bedienfeld</a></div><div><a href="/general/notice_settings.html">Best&auml;tigungen</a></div></div><div id="rightFrameContainer"><div id="rightFrame"><div id="mainContent"><div id="pageTitle"><h2>Wartungsinformationen</h2></div><script type="text/javascript">
                    // <![CDATA[
                    function csv_file_download() {
                    }window.onload=csv_file_download;
                    </script>
                    <div id="pageContents"><form method="post" action="/general/information.html?kind=item"><div><input type="hidden" id="pageid" name="pageid" value="3" /></div><div class="CSRFToken"><input type="hidden" id="CSRFToken1" name="CSRFToken" value="Y9MDRdkxoT4LIB4eOj/oRqehRJVJHTwmmPlSk0HMTkXJIael3g=="/></div><div><input type="hidden" id="postif_registration_reject" name="postif_registration_reject" value="1" /></div><div class="contentsLine"><div class="contentsButtons"><input type="submit"  value="Exportieren" /></div></div><div class="contentsGroup"><h3>Knoteninformation</h3><dl class="items"><dt>Modellname</dt><dd>Brother&nbsp;DCP-L3550CDW&nbsp;series</dd><dt>Seriennr.</dt><dd>E79018K0N222147</dd><dt>Main-Firmware-Version</dt><dd>S</dd><dt>Sub1-Firmware-Version</dt><dd>1.59</dd><dt>Speichergr&ouml;&szlig;e</dt><dd>512<span class="unit">MB</span></dd></dl></div><div class="contentsGroup"><h3>Ger&auml;testatus</h3><dl class="items"><dt>Seitenz&auml;hler</dt><dd>6</dd><dt class="subhead"><span>Farbe</span></dt><dd>6</dd><dt class="subhead"><span>SCHWARZWEISS</span></dt><dd>0</dd></dl></div><div class="contentsGroup"><h3>Verbleibende&#32;Lebensdauer</h3><dl class="items"><dt>Trommeleinheit&#32;Cyan&#32;(C)*</dt><dd>100%</dd><dt>Trommeleinheit&#32;Magenta&#32;(M)*</dt><dd>100%</dd><dt>Trommeleinheit&#32;Gelb&#32;(Y)*</dt><dd>100%</dd><dt>Trommeleinheit&#32;Schwarz&#32;(BK)*</dt><dd>100%</dd><dt>Transfereinheit</dt><dd>49986<span class="unit">Seite(n)</span></dd><dt>(Verbleibende&#32;Lebensdauer&#32;in&#32;%)</dt><dd>(100%)</dd><dt>Fixiereinheit</dt><dd>49994<span class="unit">Seite(n)</span></dd><dt>(Verbleibende&#32;Lebensdauer&#32;in&#32;%)</dt><dd>(100%)</dd><dt>Papierzufuhr-Kit&#32;1</dt><dd>49995<span class="unit">Seite(n)</span></dd><dt>(Verbleibende&#32;Lebensdauer&#32;in&#32;%)</dt><dd>(100%)</dd><dt>Toner&nbsp;Cyan&#32;(C)**</dt><dd>100%</dd><dt>Toner&nbsp;Magenta&#32;(M)**</dt><dd>100%</dd><dt>Toner&nbsp;Gelb&#32;(Y)**</dt><dd>100%</dd><dt>Toner&nbsp;Schwarz&#32;(BK)**</dt><dd>100%</dd></dl></div><div class="contentsGroup"><h3>Gesamtanzahl&#32;gedruckter&#32;Seiten</h3><dl class="items"><dt>A4/Letter</dt><dd>2<span class="unit">Seite(n)</span></dd><dt>Legal/Folio</dt><dd>4<span class="unit">Seite(n)</span></dd><dt>B5/Executive</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Umschlag</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>A5</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Sonstige</dt><dd>0<span class="unit">Seite(n)</span></dd></dl></div><div class="contentsGroup"><h3>Gesamtanzahl&#32;gedruckter&#32;Seiten</h3><dl class="items"><dt>Normal/D&uuml;nn/Recycled</dt><dd>6<span class="unit">Seite(n)</span></dd><dt>Dick/Dicker/Briefpapier</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Umschl&auml;ge/Umschl&auml;ge&#32;Dick/Umschl&auml;ge&#32;D&uuml;nn</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Etikett</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Hagaki</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Glanz</dt><dd>0<span class="unit">Seite(n)</span></dd></dl></div><div class="contentsGroup"><h3>Gesamtanzahl&#32;gedruckter&#32;Seiten</h3><dl class="items"><dt>Insgesamt</dt><dd>6<span class="unit">Seite(n)</span></dd><dt class="subhead"><span>Farbe</span></dt><dd>6</dd><dt class="subhead"><span>SCHWARZWEISS</span></dt><dd>0</dd><dt class="subhead"><span>2-seitiger&#32;Druck</span></dt><dd>2</dd><dt class="subhead"><span>Farbe&#32;2-seitig</span></dt><dd>2</dd><dt class="subhead"><span>S/W&#32;2-seitig</span></dt><dd>0</dd><dt>Kopie</dt><dd>0<span class="unit">Seite(n)</span></dd><dt class="subhead"><span>Farbe</span></dt><dd>0</dd><dt class="subhead"><span>SCHWARZWEISS</span></dt><dd>0</dd><dt class="subhead"><span>2-seitiger&#32;Druck</span></dt><dd>0</dd><dt class="subhead"><span>Farbe&#32;2-seitig</span></dt><dd>0</dd><dt class="subhead"><span>S/W&#32;2-seitig</span></dt><dd>0</dd><dt>Drucken</dt><dd>6<span class="unit">Seite(n)</span></dd><dt class="subhead"><span>Farbe</span></dt><dd>6</dd><dt class="subhead"><span>SCHWARZWEISS</span></dt><dd>0</dd><dt class="subhead"><span>2-seitiger&#32;Druck</span></dt><dd>2</dd><dt class="subhead"><span>Farbe&#32;2-seitig</span></dt><dd>2</dd><dt class="subhead"><span>S/W&#32;2-seitig</span></dt><dd>0</dd><dt>Sonstige</dt><dd>0<span class="unit">Seite(n)</span></dd><dt class="subhead"><span>Farbe</span></dt><dd>0</dd><dt class="subhead"><span>SCHWARZWEISS</span></dt><dd>0</dd><dt class="subhead"><span>2-seitiger&#32;Druck</span></dt><dd>0</dd><dt class="subhead"><span>Farbe&#32;2-seitig</span></dt><dd>0</dd><dt class="subhead"><span>S/W&#32;2-seitig</span></dt><dd>0</dd></dl></div><div class="contentsGroup"><h3>Gesamtanzahl&#32;gescannter&#32;Seiten</h3><dl class="items"><dt>ADF***</dt><dd>1<span class="unit">Seite(n)</span></dd><dt>Flachbett</dt><dd>0<span class="unit">Seite(n)</span></dd><dt>Seitenzahl&#32;Scan</dt><dd>1<span class="unit">Seite(n)</span></dd></dl></div><div class="contentsGroup"><h3>Bisher&#32;ausgetauscht</h3><dl class="items"><dt>Toner&nbsp;Cyan&#32;(C)</dt><dd>0</dd><dt>Toner&nbsp;Magenta&#32;(M)</dt><dd>0</dd><dt>Toner&nbsp;Gelb&#32;(Y)</dt><dd>0</dd><dt>Toner&nbsp;Schwarz&#32;(BK)</dt><dd>0</dd><dt>Trommeleinheit&#32;Cyan&#32;(C)</dt><dd>0</dd><dt>Trommeleinheit&#32;Magenta&#32;(M)</dt><dd>0</dd><dt>Trommeleinheit&#32;Gelb&#32;(Y)</dt><dd>0</dd><dt>Trommeleinheit&#32;Schwarz&#32;(BK)</dt><dd>0</dd><dt>Transfereinheit</dt><dd>0</dd><dt>Fixiereinheit</dt><dd>0</dd><dt>Papierzufuhr-Kit&#32;1</dt><dd>0</dd><dt>Toner-Abfallbeh&auml;lter</dt><dd>0</dd></dl></div><div class="contentsGroup"><dl class="items"><dt>Gesamtanzahl&#32;Papierstaus</dt><dd>0</dd><dt class="subhead"><span>Stau&#32;manuelle&#32;Zufuhr</span></dt><dd>0</dd><dt class="subhead"><span>Stau&#32;Zuf&uuml;hrung&#32;1</span></dt><dd>0</dd><dt class="subhead"><span>Stau&#32;innen</span></dt><dd>0</dd><dt class="subhead"><span>Stau&#32;hinten</span></dt><dd>0</dd><dt class="subhead"><span>Stau&#32;2-seitig</span></dt><dd>0</dd></dl></div><div class="contentsGroup"><dl class="items"><dt>Gesamtanzahl&#32;Papierstau&#32;(ADF)***</dt><dd>0</dd></dl></div><div class="contentsGroup"><h3>Fehler-Chronik(letzte&#32;10&#32;Fehler)</h3><table class="list errorHistory" summary="Error History"><tbody><tr><th>1</th></tr><tr><th>2</th></tr><tr><th>3</th></tr><tr><th>4</th></tr><tr><th>5</th></tr><tr><th>6</th></tr><tr><th>7</th></tr><tr><th>8</th></tr><tr><th>9</th></tr><tr><th>10</th></tr></tbody></table></div><div class="contentsGroup"><p class="noteMessage">*Basiert&#32;auf&#32;Druck&#32;im&#32;Format&#32;A4/Letter<br />**Die&#32;Restlebensdauer&#32;ist&#32;von&#32;der&#32;Art&#32;der&#32;gedruckten&#32;Dokumente,&#32;ihrer&#32;Deckung&#32;sowie&#32;von&#32;der&#32;Ger&auml;tenutzung&#32;abh&auml;ngig.<br />***Automatischer&#32;Vorlageneinzug<br /></p></div><div class="contentsGroup"><p class="noteMessage">Diese&#32;Wartungsinformation&#32;kann&#32;in&#32;eine&#32;CSV-Datei&#32;konvertiert&#32;werden.<br />Klicken&#32;Sie&#32;auf&#32;Exportieren&#32;um&#32;die&#32;CSV-Datei&#32;zu&#32;erzeugen.</p></div><div class="contentsButtons"><input type="submit"  value="Exportieren" /></div></form></div></div></div></div><script type="text/javascript"><!--
                    SetMinHeight();
                    // --></script></div><div id="mainFrameBottomLeft"><div id="mainFrameBottomRight"><div id="mainFrameBottomInner"></div></div></div></div><div id="footerFrameContainer"><div id="copyright">Copyright(C) 2000-2018 Brother Industries, Ltd. All Rights Reserved.</div><div id="topBack"><a href="#">Top<img src="/common/images/ic_pt.gif" alt="Top" /></a></div></div></div></div></body></html>
                    • K Kuddel
                      Quelltext
                      // <![CDATA[
                      </script>
                      SetMinHeight();
                      #109
                      @kuddel
                      über Parser:
                      Farbe Farbe[^\d]+(\d+) Typ number; NUM 0
                      Schwarzweiß: ISS[^\d]+(\d+) Typ number; NUM 0
                        @kuddel
                        über Parser:
                        Kuddel
                        #110
                        @homoran sagte in Druckerinfos mit Parser auslesen:
                        @kuddel
                        über Parser:
                        Farbe geht mit folgenden Einstellungen:
                        Farbe Colour[^\d]+(\d+) Typ number; NUM 0
                        Schwarz mit:
                        Schwarz B&amp;W[^\d]+(\d+) Typ number; NUM 0
                        Vielen Dank für die schnelle Hilfe
                        • K Kuddel
                          @kuddel
                          über Parser:
                          Schwarz mit:
                          #111
                          @kuddel wieso hast du jetzt einen anderen Quelltext?
                            Kuddel
                            #112
                            @homoran habe den Quelltext per Firefox kopiert. Ich vermute mal, dass der Firefox das was ins deutsche übersetzt hat und der Parser Adapter die original Sprache verwendet
                            • K Kuddel
                              #113
                              @kuddel sagte in Druckerinfos mit Parser auslesen:
                              oder verschiedene Sprachversionen im Drucker existieren
                              Wenn der parser die englische abruft kann natürlich mein RegEx von der deutschen Version nicht passen
