  4. JavaScript
  5. Javascript | Button Hintergrundfarbe nach Wert
    6.3k
61 Beiträge 2 Kommentatoren 7.3k Aufrufe 2 Beobachtet
  • TG70T TG70
    @MCU erklärst du mir bitte kurz was dein Widget macht, du hast ja zwei Datensätze in 0_userdata**** angelegt. Was passiert da.
    Woher kommt der Wert 4 in "Zahl_SEL" deiner Ojekt ID?
    .... der zweite Datensatz "Zahl_SONOS" mit dem Wert "green", auf den du dann in der VIS über "background" zugreifst?
    Edit: so würde das bestimmt funktionieren, dass eben die Zahl 4 mit grünen Hintergrund angezeigt wird
    MCU
    @tg70 Das sind Beispielwerte, die ich selbst angelegt habe.
    Hier mit corona....
    [{"tpl":"tplValueFloat","data":{"oid":"coronavirus-statistics.0.Germany.todayDeaths","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"1001px","top":"145px","background":"{v:coronavirus-statistics.0.Germany.todayDeaths;(v<0)? \"green\": (v<35)? \"yellow\": (v<50)? \"red\": \"grey\"}","width":"104px","height":"72px"},"widgetSet":"basic"}]
    Hast du im CSS-Bereich was drin?
    • TG70T TG70
      TG70T Offline
      TG70T Offline
      TG70
      Forum Testing
      Also das funktioniert.
      Im CSS habe ich nur folgendes:
      .rotate90{
          transform: rotate(90deg);
      .rotate180{
          transform: rotate(180deg);
      .rotate270{
          transform: rotate(270deg);
      Habe es jetzt auf den Ort umgeschrieben dann funktioniert das auch, warum jetzt?
      {v:coronavirus-statistics.0.Germany.Kreis.Erding.cases7_per_100k; (v<50)? "green": (v<100)? "yellow": (v>100)? "red": "grey"}
      ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
      M TG70T 2 Antworten Letzte Antwort
      • TG70T TG70
        .rotate90{
        .rotate180{
        .rotate270{
        MCU
        @tg70 Hauptsache es funktioniert.
        • TG70T TG70
          .rotate90{
          .rotate180{
          .rotate270{
          TG70T Offline
          TG70T Offline
          TG70
          Forum Testing
          Seltsam verstehe ich nicht - hast die die Java Variante auch probiert?
          OFF TOPIC: Wenn ich schon mal so einen tollen Spezialisten habe - mein nächstes Projekt - ich möchte auch mit Bindings oder auch ander, alle VIS Hintegründe auf einmal ändern.
          Hab vorhin Hintegründe getestet und bei 92 Views ist das sehr viel geklicke
          • TG70T TG70
            MCU
            @tg70 ABER NUR FÜR EXPERTEN:
            /opt/iobroker/iobroker-data/files/vis.0/Projektname/vis-views.json
            Dort steht quasi das ganze Projekt in json.
            TG70T 1 Antwort Letzte Antwort
            • M MCU
              TG70T Offline
              TG70T Offline
              TG70
              Forum Testing
              @mcu ... kannst mir trotzdem mal schicken, wäre super. Bin zwar kein "Experte" aber doch "sehr intensiver" User....
              • TG70T TG70
                MCU
                @tg70 Die hast du auf Deinem System.
                • M MCU
                  TG70T Offline
                  TG70T Offline
                  TG70
                  Forum Testing
                  schrieb am zuletzt editiert von TG70
                  ja die vis-views.json
                  Du meinst jetzt in Verbindung mit dem VIS-Hintergrund zentral editieren/anpassen?
                  Also ich habe meine Buttons so aufgebaut, dass keine direkten Farben eingetragen sind, sondern nur Bindings, d.h. ich ändere einen Farbwert und alle Widgets werden angepasst.
                  Und über meine Setup View kann das direkt angepasst werden. Die ist aber erst im Aufbau.
                  D.h. die Button Hintegrund Farbe #171717 wird hier eingetragen und man sieht das Ergebnis oben auch gleich wie es aussehen wird:
                  • TG70T TG70
                    MCU
                    @tg70 Ja genau. Aber erst kopieren als Sicherung.
                    Dort kannst du dann nach background-color suchen und ersetzen:
                    Aber nicht alle backgroundcolor ersetzen nur die von den views.
                    • M MCU
                      TG70T Offline
                      TG70T Offline
                      TG70
                      Forum Testing
                      @mcu ... ja sehr geschickte Variante... ich hätte das gerne über eine VIS ändern wollen, so wie eben meine Widgets etc. auch... ist sowas möglich?
                      • TG70T TG70
                        MCU
                        @tg70 Verstehe ich nicht das ist doch die VIS und dort passt du dann Deine Farbe #171717 in ein Binding an.
                        Funktioniert anscheinend nicht.!!!
                        • M MCU
                          TG70T Offline
                          TG70T Offline
                          TG70
                          Forum Testing
                          @mcu .. genau ich schreibe einfach im dem Beispiel mit "Button" die Farbe #171717 in den Datensatz, wo alle Widgets Hintergründe mit Bindings angebunden sind.
                          So in der Art möchte ich das eben mit den VIEW Hintergründen machen, ggf. auch mit Hintegrundbildern
                          • TG70T TG70
                            MCU
                            @tg70 Bei den allgemeinen Hintergründe funktioniert ein Binding anscheinend nicht:
                            • M MCU
                              TG70T Offline
                              TG70T Offline
                              TG70
                              Forum Testing
                              @mcu ... genau, das habe ich auch probiert. Wie wäre sowas dann möglich?
                              • TG70T TG70
                                MCU
                                @tg70 Ich hatte es gehofft. Muss noch daran arbeiten.
                                • M MCU
                                  TG70T Offline
                                  TG70T Offline
                                  TG70
                                  Forum Testing
                                  @mcu Soll ich da mal einen neuen Thread aufmachen?
                                  • TG70T TG70
                                    MCU
                                    @tg70 Du willst doch nur zwischen zwei Farben hin und herschalten? Maximale Anzahl der Farben?
                                    • M MCU
                                      TG70T Offline
                                      TG70T Offline
                                      TG70
                                      Forum Testing
                                      @mcu du meinst jetzt die Hintergründe oder was meinst du?
                                      • TG70T TG70
                                        MCU
                                        @tg70 Ja
                                        Kannst auch mal hier schauen:
                                        https://forum.iobroker.net/topic/765/css-hintergrund-für-view
                                        Wenn man nur in CSS folgenden Eintrag macht, sind alle View mit Hintergrund green:
                                        • M MCU
                                          @tg70 Ja
                                          TG70T Offline
                                          TG70T Offline
                                          TG70
                                          Forum Testing
                                          schau ich mir gleich an ... bin gespannt....
                                          DU schau mal, die Farbe "red" funktioniert bei mir nicht
                                          {v:coronavirus-statistics.0.Germany.Stadt.Nürnberg.cases7_per_100k; (v<50)? "green": (v<100)? "yellow": (v>100)? "red": "grey"}
                                          [{"tpl":"tplValueFloat","data":{"oid":"coronavirus-statistics.0.Germany.Stadt.Nürnberg.cases7_per_100k","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":false,"factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"digits":"1"},"style":{"left":"142px","top":"583px","background":"{v:coronavirus-statistics.0.Germany.Stadt.Nürnberg.cases7_per_100k; (v<50)? "green": (v<100)? "yellow": (v>100)? "red": "grey"}","width":"54px","height":"16px","border-width":"1px","border-style":"solid","border-radius":"4px","border-color":"grey","color":"black","text-align":"center","font-size":"16px","font-weight":"bolder","font-variant":"normal","background-color":""},"widgetSet":"basic"}]
