  4. JavaScript
  5. Javascript | Button Hintergrundfarbe nach Wert
    6.3k
61 Beiträge 2 Kommentatoren 7.3k Aufrufe 2 Beobachtet
  • TG70T TG70
    Also ich dachte ich löse das mit einem javascript und dem entsprechenden Link im
    Hintergrund Feld. Das ist das Java was dazu gehört:
    var idFarbe = "javascript.0.VIS.Corona";
    var idAktor = "coronavirus-statistics.0.Germany.Kreis.Roth.cases7_per_100k";
    createState(idFarbe, 'white', {
        def: 'white',
        type: 'string',
        role: 'text'
    on(idAktor, function (data) {
        if (data.state.val > 1 && data.state.val <= 49) setState(idFarbe, 'green');
        else if (data.state.val >= 50 && data.state.val <= 99) setState(idFarbe, 'yellow');
        else if (data.state.val >= 100 && data.state.val <= 1000) setState(idFarbe, 'red');
    Mein Button enthält eigentlich nur den Verweis im "background" Feld
    {javascript.0.VIS.Corona}
    [{"tpl":"i-vis-universal","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","iUniversalWidgetType":"State","iValueType":"boolean","iValueComparison":"equal","iStateResponseTime":"0","iStateResetValueTime":"0","iNavWait":"100","iPopUpBackground":"#666666","iPopUpPreventClickOutside":"","iPopUpShowTitle":"true","iPopUpTitle":"","iPopUpTitleColor":"#ffffff","iPopUpCloseBtnColor":"#dc2e2e","iPopUpWidth":"800px","iPopUpHeight":"500px","iPopUpPosition":"center","iPopUpCornerRadiusUL":"12","iPopUpCornerRadiusUR":"0","iPopUpCornerRadiusLR":"12","iPopUpCornerRadiusLL":"0","iPopUpShadowXOffset":"2","iPopUpShadowYOffset":"2","iPopUpShadowBlur":"2","iPopUpShadowSpread":"1","iPopUpShadowColor":"#111111","iButtonCol":"{javascript.0.VIS.Corona}","iButtonActive":"{javascript.0.VIS.Corona}","iButtonColHover":"","iOpacityBack":"1","iCornerRadiusUL":"12","iCornerRadiusUR":"0","iCornerRadiusLR":"12","iCornerRadiusLL":"0","iContentFlexDirection":"vertical","iContentVertAlign":"iSpace-between","iContentOrder":"orderImgText","iOpacityCtn":"1","iTextColor":"#ffffff","iTextSize":"12","iTextAlign":"iStart","iTextSpaceTop":"0","iTextSpaceBottom":"0","iTextSpaceLeft":"0","iTextSpaceRight":"0","iIconSize":"35","iImgAlign":"iCenter","iImgSpaceTop":"5","iImgSpaceBottom":"0","iImgSpaceLeft":"0","iImgSpaceRight":"0","iImgRotation":"0","iImgBlinkFalse":"0","iImgBlinkTrue":"0","iImgColorFalse":"","iImgColorTrue":"","iShadowXOffset":"2","iShadowYOffset":"2","iShadowBlur":"2","iShadowSpread":"1","iShadowColor":"#111111","iShadowColorActive":"#111111","iShadowColorHover":"","iShadowInnerXOffset":"0","iShadowInnerYOffset":"0","iShadowInnerBlur":"0","iShadowInnerSpread":"0","iShadowInnerColor":"#111111","iShadowInnerColorActive":"#111111","iShadowInnerColorHover":"","iBorderSize":"0","iBorderStyle":"none","iBorderColor":"#ffffff","iBorderColorActive":"#ffffff","iBorderColorHover":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid":"coronavirus-statistics.0.Germany.Kreis.Roth.cases7_per_100k"},"style":{"left":"664px","top":"459px"},"widgetSet":"vis-inventwo"}]
    MCU
    @tg70 Das javascript benötigst du, um die Hintergrund-Farbe zu ermitteln. Das Script ist aber nicht in der VIS. Dort wird nur mit Hilfe von sogenannten Bindings ({javascript.0.VIS.Corona}) der Wert der Farbe genutzt.
    TG70T 1 Antwort Letzte Antwort
    • M MCU
      TG70T Offline
      TG70T Offline
      TG70
      Forum Testing
      schrieb am zuletzt editiert von TG70
      genau so war mein Plan .... über das Script die Farbe ermitteln und in der VIS dann setzen.
      Erst wollte ich es mit einem Value-List probieren, aber da kriege ich die Eingrenzungen nicht hin.
      Da schaffe ich es immer nur mit 2 Werten.
      Über die Bedingungen hatte ich auch nachgedacht.
      Danach wollte ich einfach im "background" (genauer Code von gestern finde ich
      gerade nicht mehr)
      {v:adapter; (v<0) ? "green" : (v<35) ? "yellow" : (v<50) ? "red" : "grey"}
      ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
      • TG70T TG70
        gerade nicht mehr)
        MCU
        @tg70 Das funktioniert doch mit dem Hintergrund und dem letzten Binding. Oder hast du da jetzt noch Probleme?
        • M MCU
          TG70T Offline
          TG70T Offline
          TG70
          Forum Testing
          @mcu
          Nein funktioniert nicht ... es wird "kein" Hintegrund angezeigt.
          Deshalb habe ich es mit dem u.g. Weg probiert. (Java/Binding)
          • TG70T TG70
            @mcu
            MCU
            @tg70 Hast du das Update auf 1.3.8 gemacht?
            Bei mir funktionieren beide Wege.
            • M MCU
              TG70T Offline
              TG70T Offline
              TG70
              Forum Testing
              @mcu sagte in Javascript | Button Hintergrundfarbe nach Wert: 1. 3.8
              bisher noch nicht ... kann ich den updaten? Auf "Beta" bin ich - wird kein Update Symbol angezeigt. Oder geht das nur über die Console?
              • TG70T TG70
                MCU
                @tg70 Erst die Adapter updaten:
                • M MCU
                  TG70T Offline
                  TG70T Offline
                  TG70
                  Forum Testing
                  genau dieses Symbol ist beim VIS (Visualisierung) nicht vorhanden.
                  Nur beim etlichen anderen Adaptern, da ich ja keine Betas installiert habe
                  • TG70T TG70
                    MCU
                    @TG70
                    • M MCU
                      @TG70
                      TG70T Offline
                      TG70T Offline
                      TG70
                      Forum Testing
                      Ok ich habs über die Konsole gemacht. Die restlichen Adapter lasse ich mal vorerst nicht
                      auf Beta
                      • TG70T TG70
                        auf Beta
                        MCU
                        @tg70 Und funktioniert es jetzt?
                        • M MCU
                          TG70T Offline
                          TG70T Offline
                          TG70
                          Forum Testing
                          @mcu .. leider nein 😧 ... was ist bei mir falsch
                          VIS
                          • TG70T TG70
                            VIS
                            MCU
                            @tg70 Nimm doch mal das Widget was ich dir geschickt habe. Wie sieht es da aus?
                            Und schick mir das, was du da gerade nutzt als Export.
                            • M MCU
                              TG70T Offline
                              TG70T Offline
                              TG70
                              Forum Testing
                              @MCU erklärst du mir bitte kurz was dein Widget macht, du hast ja zwei Datensätze in 0_userdata**** angelegt. Was passiert da.
                              Woher kommt der Wert 4 in "Zahl_SEL" deiner Ojekt ID?
                              .... der zweite Datensatz "Zahl_SONOS" mit dem Wert "green", auf den du dann in der VIS über "background" zugreifst?
                              Edit: so würde das bestimmt funktionieren, dass eben die Zahl 4 mit grünen Hintergrund angezeigt wird
                              M TG70T 2 Antworten Letzte Antwort
                              • TG70T TG70
                                MCU
                                @tg70 Das sind Beispielwerte, die ich selbst angelegt habe.
                                Hier mit corona....
                                [{"tpl":"tplValueFloat","data":{"oid":"coronavirus-statistics.0.Germany.todayDeaths","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","is_comma":"true","factor":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"1001px","top":"145px","background":"{v:coronavirus-statistics.0.Germany.todayDeaths;(v<0)? \"green\": (v<35)? \"yellow\": (v<50)? \"red\": \"grey\"}","width":"104px","height":"72px"},"widgetSet":"basic"}]
                                Hast du im CSS-Bereich was drin?
                                • TG70T TG70
                                  TG70T Offline
                                  TG70T Offline
                                  TG70
                                  Forum Testing
                                  Also das funktioniert.
                                  Im CSS habe ich nur folgendes:
                                  .rotate90{
                                      transform: rotate(90deg);
                                  .rotate180{
                                      transform: rotate(180deg);
                                  .rotate270{
                                      transform: rotate(270deg);
                                  Habe es jetzt auf den Ort umgeschrieben dann funktioniert das auch, warum jetzt?
                                  {v:coronavirus-statistics.0.Germany.Kreis.Erding.cases7_per_100k; (v<50)? "green": (v<100)? "yellow": (v>100)? "red": "grey"}
                                  • TG70T TG70
                                    .rotate90{
                                    .rotate180{
                                    .rotate270{
                                    MCU
                                    @tg70 Hauptsache es funktioniert.
                                    • TG70T TG70
                                      .rotate90{
                                      .rotate180{
                                      .rotate270{
                                      TG70T Offline
                                      TG70T Offline
                                      TG70
                                      Forum Testing
                                      Seltsam verstehe ich nicht - hast die die Java Variante auch probiert?
                                      OFF TOPIC: Wenn ich schon mal so einen tollen Spezialisten habe - mein nächstes Projekt - ich möchte auch mit Bindings oder auch ander, alle VIS Hintegründe auf einmal ändern.
                                      Hab vorhin Hintegründe getestet und bei 92 Views ist das sehr viel geklicke
                                      • TG70T TG70
                                        MCU
                                        @tg70 ABER NUR FÜR EXPERTEN:
                                        /opt/iobroker/iobroker-data/files/vis.0/Projektname/vis-views.json
                                        Dort steht quasi das ganze Projekt in json.
                                        • M MCU
                                          TG70T Offline
                                          TG70T Offline
                                          TG70
                                          Forum Testing
                                          @mcu ... kannst mir trotzdem mal schicken, wäre super. Bin zwar kein "Experte" aber doch "sehr intensiver" User....
